path: root/fs/exofs/ios.c
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-08-11Merge branch 'for-linus' of git://git.open-osd.org/linux-open-osdLinus Torvalds
* 'for-linus' of git://git.open-osd.org/linux-open-osd: exofs: Fix groups code when num_devices is not divisible by group_width exofs: Remove useless optimization exofs: exofs_file_fsync and exofs_file_flush correctness exofs: Remove superfluous dependency on buffer_head and writeback
2010-08-11Merge branch 'master' into for-nextJiri Kosina
Conflicts: fs/exofs/inode.c
2010-08-09fix printk typo 'faild'Paul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-07block: unify flags for struct bio and struct requestChristoph Hellwig
Remove the current bio flags and reuse the request flags for the bio, too. This allows to more easily trace the type of I/O from the filesystem down to the block driver. There were two flags in the bio that were missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've renamed two request flags that had a superflous RW in them. Note that the flags are in bio.h despite having the REQ_ name - as blkdev.h includes bio.h that is the only way to go for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-04exofs: Fix groups code when num_devices is not divisible by group_widthBoaz Harrosh
There is a bug when num_devices is not divisible by group_width * mirrors. We would not return to the proper device and offset when looping on to the next group. The fix makes code simpler actually. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2010-08-04exofs: Remove useless optimizationBoaz Harrosh
We used to compact all used devices in an IO to the beginning of the device array in an io_state. And keep a last device used so in later loops we don't iterate on all device slots. This does not prevent us from checking if slots are empty since in reads we only read from a single mirror and jump to the next mirror-set. This optimization is marginal, and needlessly complicates the code. Specially when we will later want to support raid/456 with same abstract code. So remove the distinction between "dev" and "comp". Only "dev" is used both as the device used and as the index (component) in the device array. [Note that now the io_state->dev member is redundant but I keep it because I might want to optimize by only IOing a single group, though keeping a group_width*mirrors devices in io_state, we now keep num-devices in each io_state] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-28exofs: groups supportBoaz Harrosh
* _calc_stripe_info() changes to accommodate for grouping calculations. Returns additional information * old _prepare_pages() becomes _prepare_one_group() which stores pages belonging to one device group. * New _prepare_for_striping iterates on all groups calling _prepare_one_group(). * Enable mounting of groups data_maps (group_width != 0) [QUESTION] what is faster A or B; A. x += stride; x = x % width + first_x; B x += stride if (x < last_x) x = first_x; Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2010-02-28exofs: Prepare for groupsBoaz Harrosh
* Rename _offset_dev_unit_off() to _calc_stripe_info() and recieve a struct for the output params * In _prepare_for_striping we only need to call _calc_stripe_info() once. The other componets are easy to calculate from that. This code was inspired by what's done in truncate. * Some code shifts that make sense now but will make more sense when group support is added. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2010-02-28exofs: convert io_state to use pages array instead of bio at inputBoaz Harrosh
* inode.c operations are full-pages based, and not actually true scatter-gather * Lets us use more pages at once upto 512 (from 249) in 64 bit * Brings us much much closer to be able to use exofs's io_state engine from objlayout driver. (Once I decide where to put the common code) After RAID0 patch the outer (input) bio was never used as a bio, but was simply a page carrier into the raid engine. Even in the simple mirror/single-dev arrangement pages info was copied into a second bio. It is now easer to just pass a pages array into the io_state and prepare bio(s) once. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2010-02-28exofs: RAID0 supportBoaz Harrosh
We now support striping over mirror devices. Including variable sized stripe_unit. Some limits: * stripe_unit must be a multiple of PAGE_SIZE * stripe_unit * stripe_count is maximum upto 32-bit (4Gb) Tested RAID0 over mirrors, RAID0 only, mirrors only. All check. Design notes: * I'm not using a vectored raid-engine mechanism yet. Following the pnfs-objects-layout data-map structure, "Mirror" is just a private case of "group_width" == 1, and RAID0 is a private case of "Mirrors" == 1. The performance lose of the general case over the particular special case optimization is totally negligible, also considering the extra code size. * In general I added a prepare_stripes() stage that divides the to-be-io pages to the participating devices, the previous exofs_ios_write/read, now becomes _write/read_mirrors and a new write/read upper layer loops on all devices calling _write/read_mirrors. Effectively the prepare_stripes stage is the all secret. Also truncate need fixing to accommodate for striping. * In a RAID0 arrangement, in a regular usage scenario, if all inode layouts will start at the same device, the small files fill up the first device and the later devices stay empty, the farther the device the emptier it is. To fix that, each inode will start at a different stripe_unit, according to it's obj_id modulus number-of-stripe-units. And will then span all stripe-units in the same incrementing order wrapping back to the beginning of the device table. We call it a stripe-units moving window. Special consideration was taken to keep all devices in a mirror arrangement identical. So a broken osd-device could just be cloned from one of the mirrors and no FS scrubbing is needed. (We do that by rotating stripe-unit at a time and not a single device at a time.) TODO: We no longer verify object_length == inode->i_size in exofs_iget. (since i_size is stripped on multiple objects now). I should introduce a multiple-device attribute reading, and use it in exofs_iget. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2010-02-28exofs: Define on-disk per-inode optional layout attributeBoaz Harrosh
* Layouts describe the way a file is spread on multiple devices. The layout information is stored in the objects attribute introduced in this patch. * There can be multiple generating function for the layout. Currently defined: - No attribute present - use below moving-window on global device table, all devices. (This is the only one currently used in exofs) - an obj_id generated moving window - the obj_id is a randomizing factor in the otherwise global map layout. - An explicit layout stored, including a data_map and a device index list. - More might be defined in future ... * There are two attributes defined of the same structure: A-data-files-layout - This layout is used by data-files. If present at a directory, all files of that directory will be created with this layout. A-meta-data-layout - This layout is used by a directory and other meta-data information. Also inherited at creation of subdirectories. * At creation time inodes are created with the layout specified above. A usermode utility may change the creation layout on a give directory or file. Which in the case of directories, will also apply to newly created files/subdirectories, children of that directory. In the simple unaltered case of a newly created exofs, no layout attributes are present, and all layouts adhere to the layout specified at the device-table. * In case of a future file system loaded in an old exofs-driver. At iget(), the generating_function is inspected and if not supported will return an IO error to the application and the inode will not be loaded. So not to damage any data. Note: After this patch we do not yet support any type of layout only the RAID0 patch that enables striping at the super-block level will add support for RAID0 layouts above. This way we are past and future compatible and fully bisectable. * Access to the device table is done by an accessor since it will change according to above information. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2010-02-28exofs: unindent exofs_sbi_readBoaz Harrosh
The original idea was that a mirror read can be sub-divided to multiple devices. But this has very little gain and only at very large IOes so it's not going to be implemented soon. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2010-02-28exofs: Move layout related members to a layout structureBoaz Harrosh
* Abstract away those members in exofs_sb_info that are related/needed by a layout into a new exofs_layout structure. Embed it in exofs_sb_info. * At exofs_io_state receive/keep a pointer to an exofs_layout. No need for an exofs_sb_info pointer, all we need is at exofs_layout. * Change any usage of above exofs_sb_info members to their new name. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2010-02-28exofs: Recover in the case of read-passed-end-of-fileBoaz Harrosh
In check_io, implement the case of reading passed end of file, by clearing the pages and recover with no error. In a raid arrangement this can become a legitimate situation in case of holes in the file. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2010-02-28exofs: debug print even lessBoaz Harrosh
* Last debug trimming left in some stupid print, remove them. Fixup some other prints * Shift printing from inode.c to ios.c * Add couple of prints when memory allocation fails. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2009-12-10exofs: Multi-device mirror supportBoaz Harrosh
This patch changes on-disk format, it is accompanied with a parallel patch to mkfs.exofs that enables multi-device capabilities. After this patch, old exofs will refuse to mount a new formatted FS and new exofs will refuse an old format. This is done by moving the magic field offset inside the FSCB. A new FSCB *version* field was added. In the future, exofs will refuse to mount unmatched FSCB version. To up-grade or down-grade an exofs one must use mkfs.exofs --upgrade option before mounting. Introduced, a new object that contains a *device-table*. This object contains the default *data-map* and a linear array of devices information, which identifies the devices used in the filesystem. This object is only written to offline by mkfs.exofs. This is why it is kept separate from the FSCB, since the later is written to while mounted. Same partition number, same object number is used on all devices only the device varies. * define the new format, then load the device table on mount time make sure every thing is supported. * Change I/O engine to now support Mirror IO, .i.e write same data to multiple devices, read from a random device to spread the read-load from multiple clients (TODO: stripe read) Implementation notes: A few points introduced in previous patch should be mentioned here: * Special care was made so absolutlly all operation that have any chance of failing are done before any osd-request is executed. This is to minimize the need for a data consistency recovery, to only real IO errors. * Each IO state has a kref. It starts at 1, any osd-request executed will increment the kref, finally when all are executed the first ref is dropped. At IO-done, each request completion decrements the kref, the last one to return executes the internal _last_io() routine. _last_io() will call the registered io_state_done. On sync mode a caller does not supply a done method, indicating a synchronous request, the caller is put to sleep and a special io_state_done is registered that will awaken the caller. Though also in sync mode all operations are executed in parallel. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2009-12-10exofs: Move all operations to an io_engineBoaz Harrosh
In anticipation for multi-device operations, we separate osd operations into an abstract I/O API. Currently only one device is used but later when adding more devices, we will drive all devices in parallel according to a "data_map" that describes how data is arranged on multiple devices. The file system level operates, like before, as if there is one object (inode-number) and an i_size. The io engine will split this to the same object-number but on multiple device. At first we introduce Mirror (raid 1) layout. But at the final outcome we intend to fully implement the pNFS-Objects data-map, including raid 0,4,5,6 over mirrored devices, over multiple device-groups. And more. See: http://tools.ietf.org/html/draft-ietf-nfsv4-pnfs-obj-12 * Define an io_state based API for accessing osd storage devices in an abstract way. Usage: First a caller allocates an io state with: exofs_get_io_state(struct exofs_sb_info *sbi, struct exofs_io_state** ios); Then calles one of: exofs_sbi_create(struct exofs_io_state *ios); exofs_sbi_remove(struct exofs_io_state *ios); exofs_sbi_write(struct exofs_io_state *ios); exofs_sbi_read(struct exofs_io_state *ios); exofs_oi_truncate(struct exofs_i_info *oi, u64 new_len); And when done exofs_put_io_state(struct exofs_io_state *ios); * Convert all source files to use this new API * Convert from bio_alloc to bio_kmalloc * In io engine we make use of the now fixed osd_req_decode_sense There are no functional changes or on disk additions after this patch. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2009-12-10exofs: move osd.c to ios.cBoaz Harrosh
If I do a "git mv" together with a massive code change and commit in one patch, git looses the rename and records a delete/new instead. This is bad because I want a rename recorded so later rebased/cherry-picked patches to the old name will work. Also the --follow is lost. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
