path: root/fs/exofs/pnfs.h
2010-01-05exofs: fix pnfs_osd re-definitions in pre-pnfs treesBoaz Harrosh
Some on disk exofs constants and types are defined in the pnfs_osd_xdr.h file. Since we needed these types before the pnfs-objects code was accepted to mainline we duplicated the minimal needed definitions into an exofs local header. The definitions where conditionally included depending on !CONFIG_PNFS defined. So if PNFS was present in the tree definitions are taken from there and if not they are defined locally. That was all good but, the CONFIG_PNFS is planed to be included upstream before the pnfs-objects is also included. (The first pnfs batch might be pnfs-files only) So condition exofs local definitions on the absence of pnfs_osd_xdr.h inclusion (__PNFS_OSD_XDR_H__ not defined). User code must make sure that in future pnfs_osd_xdr.h will be included before fs/exofs/pnfs.h, which happens to be so in current code. Once pnfs-objects hits mainline, exofs's local header will be removed. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2009-12-10exofs: Multi-device mirror supportBoaz Harrosh
This patch changes on-disk format, it is accompanied with a parallel patch to mkfs.exofs that enables multi-device capabilities. After this patch, old exofs will refuse to mount a new formatted FS and new exofs will refuse an old format. This is done by moving the magic field offset inside the FSCB. A new FSCB *version* field was added. In the future, exofs will refuse to mount unmatched FSCB version. To up-grade or down-grade an exofs one must use mkfs.exofs --upgrade option before mounting. Introduced, a new object that contains a *device-table*. This object contains the default *data-map* and a linear array of devices information, which identifies the devices used in the filesystem. This object is only written to offline by mkfs.exofs. This is why it is kept separate from the FSCB, since the later is written to while mounted. Same partition number, same object number is used on all devices only the device varies. * define the new format, then load the device table on mount time make sure every thing is supported. * Change I/O engine to now support Mirror IO, .i.e write same data to multiple devices, read from a random device to spread the read-load from multiple clients (TODO: stripe read) Implementation notes: A few points introduced in previous patch should be mentioned here: * Special care was made so absolutlly all operation that have any chance of failing are done before any osd-request is executed. This is to minimize the need for a data consistency recovery, to only real IO errors. * Each IO state has a kref. It starts at 1, any osd-request executed will increment the kref, finally when all are executed the first ref is dropped. At IO-done, each request completion decrements the kref, the last one to return executes the internal _last_io() routine. _last_io() will call the registered io_state_done. On sync mode a caller does not supply a done method, indicating a synchronous request, the caller is put to sleep and a special io_state_done is registered that will awaken the caller. Though also in sync mode all operations are executed in parallel. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
