path: root/fs/exofs
2016-10-27fs: exofs: print a hex number after a 0x prefixUwe Kleine-König
It makes the message hard to interpret correctly if a base 10 number is prefixed by 0x. So change to a hex number. Link: http://lkml.kernel.org/r/20161026125658.25728-2-u.kleine-koenig@pengutronix.de Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Boaz Harrosh <ooo@electrozaur.com> Cc: Benny Halevy <bhalevy@primarydata.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-11fs: use mapping_set_error instead of opencoded set_bitMichal Hocko
The mapping_set_error() helper sets the correct AS_ flag for the mapping so there is no reason to open code it. Use the helper directly. [akpm@linux-foundation.org: be honest about conversion from -ENXIO to -EIO] Link: http://lkml.kernel.org/r/20160912111608.2588-2-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: ">rename2() work from Miklos + current_time() from Deepa" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fs: Replace current_fs_time() with current_time() fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps fs: Replace CURRENT_TIME with current_time() for inode timestamps fs: proc: Delete inode time initializations in proc_alloc_inode() vfs: Add current_time() api vfs: add note about i_op->rename changes to porting fs: rename "rename2" i_op to "rename" vfs: remove unused i_op->rename fs: make remaining filesystems use .rename2 libfs: support RENAME_NOREPLACE in simple_rename() fs: support RENAME_NOREPLACE for local filesystems ncpfs: fix unused variable warning
2016-10-10Merge remote-tracking branch 'ovl/rename2' into for-linusAl Viro
2016-09-27fs: Replace CURRENT_TIME with current_time() for inode timestampsDeepa Dinamani
CURRENT_TIME macro is not appropriate for filesystems as it doesn't use the right granularity for filesystem timestamps. Use current_time() instead. CURRENT_TIME is also not y2038 safe. This is also in preparation for the patch that transitions vfs timestamps to use 64 bit time and hence make them y2038 safe. As part of the effort current_time() will be extended to do range checks. Hence, it is necessary for all file system timestamps to use current_time(). Also, current_time() will be transitioned along with vfs to be y2038 safe. Note that whenever a single call to current_time() is used to change timestamps in different inodes, it is because they share the same time granularity. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Felipe Balbi <balbi@kernel.org> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Acked-by: David Sterba <dsterba@suse.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-27fs: rename "rename2" i_op to "rename"Miklos Szeredi
Generated patch: sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2` sed -i "s/\brename2\b/rename/g" `git grep -wl rename2` Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-09-27fs: support RENAME_NOREPLACE for local filesystemsMiklos Szeredi
This is trivial to do: - add flags argument to foo_rename() - check if flags doesn't have any other than RENAME_NOREPLACE - assign foo_rename() to .rename2 instead of .rename Filesystems converted: affs, bfs, exofs, ext2, hfs, hfsplus, jffs2, jfs, logfs, minix, msdos, nilfs2, omfs, reiserfs, sysvfs, ubifs, udf, ufs, vfat. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Acked-by: Boaz Harrosh <ooo@electrozaur.com> Acked-by: Richard Weinberger <richard@nod.at> Acked-by: Bob Copeland <me@bobcopeland.com> Acked-by: Jan Kara <jack@suse.cz> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Jaegeuk Kim <jaegeuk@kernel.org> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Mikulas Patocka <mpatocka@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Dave Kleikamp <shaggy@kernel.org> Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Christoph Hellwig <hch@infradead.org>
2016-09-22fs: Give dentry to inode_change_ok() instead of inodeJan Kara
inode_change_ok() will be resposible for clearing capabilities and IMA extended attributes and as such will need dentry. Give it as an argument to inode_change_ok() instead of an inode. Also rename inode_change_ok() to setattr_prepare() to better relect that it does also some modifications in addition to checks. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2016-06-07block, fs, mm, drivers: use bio set/get op accessorsMike Christie
This patch converts the simple bi_rw use cases in the block, drivers, mm and fs code to set/get the bio operation using bio_set_op_attrs/bio_op These should be simple one or two liner cases, so I just did them in one patch. The next patches handle the more complicated cases in a module per patch. Signed-off-by: Mike Christie <mchristi@redhat.com> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-05-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (21 commits) gitignore: fix wording mfd: ab8500-debugfs: fix "between" in printk memstick: trivial fix of spelling mistake on management cpupowerutils: bench: fix "average" treewide: Fix typos in printk IB/mlx4: printk fix pinctrl: sirf/atlas7: fix printk spelling serial: mctrl_gpio: Grammar s/lines GPIOs/line GPIOs/, /sets/set/ w1: comment spelling s/minmum/minimum/ Blackfin: comment spelling s/divsor/divisor/ metag: Fix misspellings in comments. ia64: Fix misspellings in comments. hexagon: Fix misspellings in comments. tools/perf: Fix misspellings in comments. cris: Fix misspellings in comments. c6x: Fix misspellings in comments. blackfin: Fix misspelling of 'register' in comment. avr32: Fix misspelling of 'definitions' in comment. treewide: Fix typos in printk Doc: treewide : Fix typos in DocBook/filesystem.xml ...
2016-05-17Merge branch 'work.preadv2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs cleanups from Al Viro: "More cleanups from Christoph" * 'work.preadv2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: nfsd: use RWF_SYNC fs: add RWF_DSYNC aand RWF_SYNC ceph: use generic_write_sync fs: simplify the generic_write_sync prototype fs: add IOCB_SYNC and IOCB_DSYNC direct-io: remove the offset argument to dio_complete direct-io: eliminate the offset argument to ->direct_IO xfs: eliminate the pos variable in xfs_file_dio_aio_write filemap: remove the pos argument to generic_file_direct_write filemap: remove pos variables in generic_file_read_iter
2016-05-09more trivial ->iterate_shared conversionsAl Viro
2016-05-02make ext2_get_page() and friends work without external serializationAl Viro
Right now ext2_get_page() (and its analogues in a bunch of other filesystems) relies upon the directory being locked - the way it sets and tests Checked and Error bits would be racy without that. Switch to a slightly different scheme, _not_ setting Checked in case of failure. That way the logics becomes if Checked => OK else if Error => fail else if !validate => fail else => OK with validation setting Checked or Error on success and failure resp. and returning which one had happened. Equivalent to the current logics, but unlike the current logics not sensitive to the order of set_bit, test_bit getting reordered by CPU, etc. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-02Merge getxattr prototype change into work.lookupsAl Viro
The rest of work.xattr stuff isn't needed for this branch
2016-05-01direct-io: eliminate the offset argument to ->direct_IOChristoph Hellwig
Including blkdev_direct_IO and dax_do_io. It has to be ki_pos to actually work, so eliminate the superflous argument. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-04-18treewide: Fix typos in printkMasanari Iida
This patch fix spelling typos found in printk within various part of the kernel sources. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2016-04-10don't bother with ->d_inode->i_sb - it's always equal to ->d_sbAl Viro
... and neither can ever be NULL Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-04-04mm, fs: get rid of PAGE_CACHE_* and page_cache_{get,release} macrosKirill A. Shutemov
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time ago with promise that one day it will be possible to implement page cache with bigger chunks than PAGE_SIZE. This promise never materialized. And unlikely will. We have many places where PAGE_CACHE_SIZE assumed to be equal to PAGE_SIZE. And it's constant source of confusion on whether PAGE_CACHE_* or PAGE_* constant should be used in a particular case, especially on the border between fs and mm. Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much breakage to be doable. Let's stop pretending that pages in page cache are special. They are not. The changes are pretty straight-forward: - <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN}; - page_cache_get() -> get_page(); - page_cache_release() -> put_page(); This patch contains automated changes generated with coccinelle using script below. For some reason, coccinelle doesn't patch header files. I've called spatch for them manually. The only adjustment after coccinelle is revert of changes to PAGE_CAHCE_ALIGN definition: we are going to drop it later. There are few places in the code where coccinelle didn't reach. I'll fix them manually in a separate patch. Comments and documentation also will be addressed with the separate patch. virtual patch @@ expression E; @@ - E << (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ expression E; @@ - E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ @@ - PAGE_CACHE_SHIFT + PAGE_SHIFT @@ @@ - PAGE_CACHE_SIZE + PAGE_SIZE @@ @@ - PAGE_CACHE_MASK + PAGE_MASK @@ expression E; @@ - PAGE_CACHE_ALIGN(E) + PAGE_ALIGN(E) @@ expression E; @@ - page_cache_get(E) + get_page(E) @@ expression E; @@ - page_cache_release(E) + put_page(E) Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-22wrappers for ->i_mutex accessAl Viro
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested}, inode_foo(inode) being mutex_foo(&inode->i_mutex). Please, use those for access to ->i_mutex; over the coming cycle ->i_mutex will become rwsem, with ->lookup() done with it held only shared. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-14kmemcg: account certain kmem allocations to memcgVladimir Davydov
Mark those kmem allocations that are known to be easily triggered from userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to memcg. For the list, see below: - threadinfo - task_struct - task_delay_info - pid - cred - mm_struct - vm_area_struct and vm_region (nommu) - anon_vma and anon_vma_chain - signal_struct - sighand_struct - fs_struct - files_struct - fdtable and fdtable->full_fds_bits - dentry and external_name - inode for all filesystems. This is the most tedious part, because most filesystems overwrite the alloc_inode method. The list is far from complete, so feel free to add more objects. Nevertheless, it should be close to "account everything" approach and keep most workloads within bounds. Malevolent users will be able to breach the limit, but this was possible even with the former "account everything" approach (simply because it did not account everything in fact). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Tejun Heo <tj@kernel.org> Cc: Greg Thelen <gthelen@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-11Merge branch 'work.symlinks' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs RCU symlink updates from Al Viro: "Replacement of ->follow_link/->put_link, allowing to stay in RCU mode even if the symlink is not an embedded one. No changes since the mailbomb on Jan 1" * 'work.symlinks' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: switch ->get_link() to delayed_call, kill ->put_link() kill free_page_put_link() teach nfs_get_link() to work in RCU mode teach proc_self_get_link()/proc_thread_self_get_link() to work in RCU mode teach shmem_get_link() to work in RCU mode teach page_get_link() to work in RCU mode replace ->follow_link() with new method that could stay in RCU mode don't put symlink bodies in pagecache into highmem namei: page_getlink() and page_follow_link_light() are the same thing ufs: get rid of ->setattr() for symlinks udf: don't duplicate page_symlink_inode_operations logfs: don't duplicate page_symlink_inode_operations switch befs long symlinks to page_symlink_operations
2015-12-12osd fs: __r4w_get_page rely on PageUptodate for uptodateHugh Dickins
Commit 42cb14b110a5 ("mm: migrate dirty page without clear_page_dirty_for_io etc") simplified the migration of a PageDirty pagecache page: one stat needs moving from zone to zone and that's about all. It's convenient and safest for it to shift the PageDirty bit from old page to new, just before updating the zone stats: before copying data and marking the new PageUptodate. This is all done while both pages are isolated and locked, just as before; and just as before, there's a moment when the new page is visible in the radix_tree, but not yet PageUptodate. What's new is that it may now be briefly visible as PageDirty before it is PageUptodate. When I scoured the tree to see if this could cause a problem anywhere, the only places I found were in two similar functions __r4w_get_page(): which look up a page with find_get_page() (not using page lock), then claim it's uptodate if it's PageDirty or PageWriteback or PageUptodate. I'm not sure whether that was right before, but now it might be wrong (on rare occasions): only claim the page is uptodate if PageUptodate. Or perhaps the page in question could never be migratable anyway? Signed-off-by: Hugh Dickins <hughd@google.com> Tested-by: Boaz Harrosh <ooo@electrozaur.com> Cc: Benny Halevy <bhalevy@panasas.com> Cc: Trond Myklebust <trond.myklebust@primarydata.com> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-12-08don't put symlink bodies in pagecache into highmemAl Viro
kmap() in page_follow_link_light() needed to go - allowing to hold an arbitrary number of kmaps for long is a great way to deadlocking the system. new helper (inode_nohighmem(inode)) needs to be used for pagecache symlinks inodes; done for all in-tree cases. page_follow_link_light() instrumented to yell about anything missed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-11-09fs/exofs/namei.c: remove unnecessary new_valid_dev() checkYaowei Bai
new_valid_dev() always returns 1, so the !new_valid_dev() check is not needed. Remove it. Signed-off-by: Yaowei Bai <bywxiaobai@163.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Acked-by: Boaz Harrosh <ooo@electrozaur.com> Cc: Benny Halevy <bhalevy@primarydata.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-23pagemap.h: move dir_pages() over thereFabian Frederick
That function was declared in a lot of filesystems to calculate directory pages. Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-05-10exofs: switch to {simple,page}_symlink_inode_operationsAl Viro
ACK-by: Boaz Harrosh <ooo@electrozaur.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11direct_IO: remove rw from a_ops->direct_IO()Omar Sandoval
Now that no one is using rw, remove it completely. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11make new_sync_{read,write}() staticAl Viro
All places outside of core VFS that checked ->read and ->write for being NULL or called the methods directly are gone now, so NULL {read,write} with non-NULL {read,write}_iter will do the right thing in all cases. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-16vfs: remove get_xip_memMatthew Wilcox
All callers of get_xip_mem() are now gone. Remove checks for it, initialisers of it, documentation of it and the only implementation of it. Also remove mm/filemap_xip.c as it is now empty. Also remove documentation of the long-gone get_xip_page(). Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com> Cc: Andreas Dilger <andreas.dilger@intel.com> Cc: Boaz Harrosh <boaz@plexistor.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Dave Chinner <david@fromorbit.com> Cc: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Ross Zwisler <ross.zwisler@linux.intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-20fs: remove mapping->backing_dev_infoChristoph Hellwig
Now that we never use the backing_dev_info pointer in struct address_space we can simply remove it and save 4 to 8 bytes in every inode. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Reviewed-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com>
2015-01-20fs: introduce f_op->mmap_capabilities for nommu mmap supportChristoph Hellwig
Since "BDI: Provide backing device capability information [try #3]" the backing_dev_info structure also provides flags for the kind of mmap operation available in a nommu environment, which is entirely unrelated to it's original purpose. Introduce a new nommu-only file operation to provide this information to the nommu mmap code instead. Splitting this from the backing_dev_info structure allows to remove lots of backing_dev_info instance that aren't otherwise needed, and entirely gets rid of the concept of providing a backing_dev_info for a character device. It also removes the need for the mtd_inodefs filesystem. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Tejun Heo <tj@kernel.org> Acked-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-10-19Boaz Harrosh - Fix broken email addressBoaz Harrosh
I no longer have access to the Panasas email. So change to an email that can always reach me. Signed-off-by: Boaz Harrosh <ooo@electrozaur.com>
2014-08-08fs/exofs/ore_raid.c: replace count*size kzalloc by kcallocFabian Frederick
kcalloc manages count*sizeof overflow. Signed-off-by: Fabian Frederick <fabf@skynet.be> Acked-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "This the bunch that sat in -next + lock_parent() fix. This is the minimal set; there's more pending stuff. In particular, I really hope to get acct.c fixes merged this cycle - we need that to deal sanely with delayed-mntput stuff. In the next pile, hopefully - that series is fairly short and localized (kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more iov_iter work. Most of prereqs for ->splice_write with sane locking order are there and Kent's dio rewrite would also fit nicely on top of this pile" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits) lock_parent: don't step on stale ->d_parent of all-but-freed one kill generic_file_splice_write() ceph: switch to iter_file_splice_write() shmem: switch to iter_file_splice_write() nfs: switch to iter_splice_write_file() fs/splice.c: remove unneeded exports ocfs2: switch to iter_file_splice_write() ->splice_write() via ->write_iter() bio_vec-backed iov_iter optimize copy_page_{to,from}_iter() bury generic_file_aio_{read,write} lustre: get rid of messing with iovecs ceph: switch to ->write_iter() ceph_sync_direct_write: stop poking into iov_iter guts ceph_sync_read: stop poking into iov_iter guts new helper: copy_page_from_iter() fuse: switch to ->write_iter() btrfs: switch to ->write_iter() ocfs2: switch to ->write_iter() xfs: switch to ->write_iter() ...
2014-06-12->splice_write() via ->write_iter()Al Viro
iter_file_splice_write() - a ->splice_write() instance that gathers the pipe buffers, builds a bio_vec-based iov_iter covering those and feeds it to ->write_iter(). A bunch of simple cases coverted to that... [AV: fixed the braino spotted by Cyrill] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-22ore: Support for raid 6Boaz Harrosh
This simple patch adds support for raid6 to the ORE. Most operations and calculations where already for the general case. Only things left: * call async_gen_syndrome() in the case of raid6 (NOTE that the raid6 math is the one supported by the Linux Kernel see: crypto/async_tx/async_pq.c) * call _ore_add_parity_unit() twice with only last call generating the redundancy pages. * Fix couple BUGS in old code a. In reads when parity==2 it can happen that per_dev->length=0 but per_dev->offset was set and adjusted by _ore_add_sg_seg(). Don't let it be overwritten. b. The all 'cur_comp > starting_dev' thing to determine if: "per_dev->offset is in the current stripe number or the next one." Was a complete raid5/4 accident. When parity==2 this is not at all true usually. All we need to do is increment si->ob_offset once we pass by the first parity device. (This also greatly simplifies the code, amen) c. Calculation of si->dev rotation can overflow when parity==2. * Then last enable raid6 in ore_verify_layout() I want to deeply thank Daniel Gryniewicz who found first all the bugs in the old raid code, and inspired these patches: Inspired-by Daniel Gryniewicz <dang@linuxbox.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2014-05-22ore: Remove redundant dev_order(), more cleanupsBoaz Harrosh
Two cleanups: * si->cur_comp, si->cur_pg where always calculated after the call to ore_calc_stripe_info() with the help of _dev_order(...). But these are already calculated by ore_calc_stripe_info() and can be just set there. (This is left over from the time that si->cur_comp, si->cur_pg were only used by raid code, but now the main loop manages them anyway even though they are ultimately not used in none raid code) * si->cur_comp - For the very last stripe case, was set inside _ore_add_parity_unit(). This is not clear and will be wrong for coming raid6 so move this to only caller. Now si->cur_comp is only manipulated within _prepare_for_striping(), always next to the manipulation of cur_dev. Which is much easier to understand and follow. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2014-05-22ore: (trivial) reformat some codeBoaz Harrosh
rearrange some source lines. Nothing changed. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2014-05-06write_iter variants of {__,}generic_file_aio_write()Al Viro
2014-05-06switch simple generic_file_aio_read() users to ->read_iter()Al Viro
2014-05-06pass iov_iter to ->direct_IO()Al Viro
unmodified, for now Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-10Merge branch 'for-linus' of git://git.open-osd.org/linux-open-osdLinus Torvalds
Pull exofs updates from Boaz Harrosh: "Trivial updates to exofs for 3.15-rc1 Just a few fixes sent by people" * 'for-linus' of git://git.open-osd.org/linux-open-osd: MAINTAINERS: Update email address for bhalevy fs: Mark functions as static in exofs/ore_raid.c fs: Mark function as static in exofs/super.c
2014-04-03mm + fs: store shadow entries in page cacheJohannes Weiner
Reclaim will be leaving shadow entries in the page cache radix tree upon evicting the real page. As those pages are found from the LRU, an iput() can lead to the inode being freed concurrently. At this point, reclaim must no longer install shadow pages because the inode freeing code needs to ensure the page tree is really empty. Add an address_space flag, AS_EXITING, that the inode freeing code sets under the tree lock before doing the final truncate. Reclaim will check for this flag before installing shadow pages. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Minchan Kim <minchan@kernel.org> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Bob Liu <bob.liu@oracle.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Cc: Greg Thelen <gthelen@google.com> Cc: Hugh Dickins <hughd@google.com> Cc: Jan Kara <jack@suse.cz> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Luigi Semenzato <semenzato@google.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Metin Doslu <metin@citusdata.com> Cc: Michel Lespinasse <walken@google.com> Cc: Ozgun Erdogan <ozgun@citusdata.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Ryan Mallon <rmallon@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-04-03fs: Mark functions as static in exofs/ore_raid.cRashika Kheria
Mark functions as static in exofs/ore_raid.c because they are not used outside this file. This also eliminates the following warning in exofs/ore_raid.c: fs/exofs/ore_raid.c:24:14: warning: no previous prototype for _raid_page_alloc [-Wmissing-prototypes] fs/exofs/ore_raid.c:29:6: warning: no previous prototype for _raid_page_free [-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2014-04-03fs: Mark function as static in exofs/super.cRashika Kheria
Mark function as static in exofs/super.c because it is not used outside this file. This also eliminates the following warning in exofs/super.c: fs/exofs/super.c:546:5: warning: no previous prototype \ for __alloc_dev_table[-Wmissing-prototypes] Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2014-01-23exofs: Print less in r4wBoaz Harrosh
In debug mode exofs is too verbose. Hiding the real problems remove some trivial stuff. Also fix some other prints. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2014-01-23exofs: Allow corrupted directory entry to be empty fileBoaz Harrosh
If there was an error in fetching an object or extracting inode info from attributes. Which means corrupted storage. Let it be an empty ZERO dated directory entry so it can be deleted. Otherwise the all directory will be inaccessible. This does not loose data, because if there is an orphan object somewhere it will be recovered by fschk. But usually this only means corrupted dir entry. The object was never generated and only its link exist. This way we can delete the bad entry. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2014-01-23exofs: Allow O_DIRECT openBoaz Harrosh
With this minimal do nothing patch an application can open O_DIRECT and then actually do buffered sync IO instead. But the aio API is supported which is a good thing Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2014-01-23ore: Don't crash on NULL bio in _clear_bioBoaz Harrosh
In the case of target returning OSD_ERR_PRI_CLEAR_PAGES when we only sent for attributes don't crash on NULL bio. This is an osd-target bug but don't crash regardless Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
