path: root/fs/ext2/acl.c
2014-01-25ext2/3/4: use generic posix ACL infrastructureChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-25fs: make posix_acl_create more usefulChristoph Hellwig
Rename the current posix_acl_created to __posix_acl_create and add a fully featured helper to set up the ACLs on file creation that uses get_acl(). Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-01-25fs: make posix_acl_chmod more usefulChristoph Hellwig
Rename the current posix_acl_chmod to __posix_acl_chmod and add a fully featured ACL chmod helper that uses the ->set_acl inode operation. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-18userns: Convert extN to support kuids and kgids in posix aclsEric W. Biederman
Convert ext2, ext3, and ext4 to fully support the posix acl changes, using e_uid e_gid instead e_id. Enabled building with posix acls enabled, all filesystems supporting user namespaces, now also support posix acls when user namespaces are enabled. Cc: Theodore Tso <tytso@mit.edu> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-18userns: Pass a userns parameter into posix_acl_to_xattr and posix_acl_from_xattrEric W. Biederman
- Pass the user namespace the uid and gid values in the xattr are stored in into posix_acl_from_xattr. - Pass the user namespace kuid and kgid values should be converted into when storing uid and gid values in an xattr in posix_acl_to_xattr. - Modify all callers of posix_acl_from_xattr and posix_acl_to_xattr to pass in &init_user_ns. In the short term this change is not strictly needed but it makes the code clearer. In the longer term this change is necessary to be able to mount filesystems outside of the initial user namespace that natively store posix acls in the linux xattr format. Cc: Theodore Tso <tytso@mit.edu> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Jan Kara <jack@suse.cz> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2011-08-01switch posix_acl_equiv_mode() to umode_t *Al Viro
... so that &inode->i_mode could be passed to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-08-01switch posix_acl_create() to umode_t *Al Viro
so we can pass &inode->i_mode to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25fs: take the ACL checks to common codeChristoph Hellwig
Replace the ->check_acl method with a ->get_acl method that simply reads an ACL from disk after having a cache miss. This means we can replace the ACL checking boilerplate code with a single implementation in namei.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplates around posix_acl_create_masq()Al Viro
new helper: posix_acl_create(&acl, gfp, mode_p). Replaces acl with modified clone, on failure releases acl and replaces with NULL. Returns 0 or -ve on error. All callers of posix_acl_create_masq() switched. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplate around posix_acl_chmod_masq()Al Viro
new helper: posix_acl_chmod(&acl, gfp, mode). Replaces acl with modified clone or with NULL if that has failed; returns 0 or -ve on error. All callers of posix_acl_chmod_masq() switched to that - they'd been doing exactly the same thing. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25vfs: move ACL cache lookup into generic codeLinus Torvalds
This moves logic for checking the cached ACL values from low-level filesystems into generic code. The end result is a streamlined ACL check that doesn't need to load the inode->i_op->check_acl pointer at all for the common cached case. The filesystems also don't need to check for a non-blocking RCU walk case in their acl_check() functions, because that is all handled at a VFS layer. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to ->check_acl()Al Viro
not used in the instances anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: pass MAY_NOT_BLOCK to ->check_acl()Al Viro
2011-03-23userns: rename is_owner_or_cap to inode_owner_or_capableSerge E. Hallyn
And give it a kernel-doc comment. [akpm@linux-foundation.org: btrfs changed in linux-next] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-07ext2,3,4: provide simple rcu-walk ACL implementationNick Piggin
This simple implementation just checks for no ACLs on the inode, and if so, then the rcu-walk may proceed, otherwise fail it. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: provide rcu-walk aware permission i_opsNick Piggin
2010-06-25ext2: update ctime when changing the file's permission by setfaclJan Kara
ext2 didn't update the ctime of the file when its permission was changed. Steps to reproduce: # touch aaa # stat -c %Z aaa 1275289822 # setfacl -m 'u::x,g::x,o::x' aaa # stat -c %Z aaa 1275289822 <- unchanged But, according to the spec of the ctime, ext2 must update it. Port of ext3 patch by Miao Xie <miaox@cn.fujitsu.com>. Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21ext2: constify xattr_handlerStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16sanitize xattr handler prototypesChristoph Hellwig
Add a flags argument to struct xattr_handler and pass it to all xattr handler methods. This allows using the same methods for multiple handlers, e.g. for the ACL methods which perform exactly the same action for the access and default ACLs, just using a different underlying attribute. With a little more groundwork it'll also allow sharing the methods for the regular user/trusted/secure handlers in extN, ocfs2 and jffs2 like it's already done for xfs in this patch. Also change the inode argument to the handlers to a dentry to allow using the handlers mechnism for filesystems that require it later, e.g. cifs. [with GFS2 bits updated by Steven Whitehouse <swhiteho@redhat.com>] Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-08ext[234]: move over to 'check_acl' permission modelLinus Torvalds
Don't implement per-filesystem 'extX_permission()' functions that have to be called for every path component operation, and instead just expose the actual ACL checking so that the VFS layer can now do it for us. Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-24helpers for acl caching + switch to thoseAl Viro
helpers: get_cached_acl(inode, type), set_cached_acl(inode, type, acl), forget_cached_acl(inode, type). ubifs/xattr.c needed includes reordered, the rest is a plain switchover. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-24switch ext2 to inode->i_aclAl Viro
2009-03-31New helper - current_umask()Al Viro
current->fs->umask is what most of fs_struct users are doing. Put that into a helper function. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] sanitize ->permission() prototypeAl Viro
* kill nameidata * argument; map the 3 bits in ->flags anybody cares about to new MAY_... ones and pass with the mask. * kill redundant gfs2_iop_permission() * sanitize ecryptfs_permission() * fix remaining places where ->permission() instances might barf on new MAY_... found in mask. The obvious next target in that direction is permission(9) folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-07-17Introduce is_owner_or_cap() to wrap CAP_FOWNER use with fsuid checkSatyam Sharma
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant users to it. This is done because we want to avoid bugs in the future where we check for only effective fsuid of the current task against a file's owning uid, without simultaneously checking for CAP_FOWNER as well, thus violating its semantics. [ XFS uses special macros and structures, and in general looked ... untouchable, so we leave it alone -- but it has been looked over. ] The (current->fsuid != inode->i_uid) check in generic_permission() and exec_permission_lite() is left alone, because those operations are covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-27[PATCH] fs: Removing useless castsPanagiotis Issaris
* Removing useless casts * Removing useless wrapper * Conversion from kmalloc+memset to kzalloc Signed-off-by: Panagiotis Issaris <takis@issaris.org> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] Fix two ext[23] uninitialized warningsAndreas Gruenbacher
There is a code path that passed size to ext2_xattr_set (ext3_xattr_set_handle) before initializing it. The callees don't use the value in that case, but gcc cannot tell. Always initialize size to get rid of the warnings. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] remove <linux/xattr_acl.h>Christoph Hellwig
This file duplicates <linux/posix_acl_xattr.h>, using slightly different names. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] Fix acl Oopsakpm@osdl.org
) From: Andreas Gruenbacher <agruen@suse.de> ext[23]_get_acl will return an error when reading the attribute fails or out-of-memory occurs. Catch this case. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
