path: root/fs/ext2/dir.c
2011-01-10ext2: speed up file creates by optimizing rec_len functionsEric Sandeen
The addition of 64k block capability in the rec_len_from_disk and rec_len_to_disk functions added a bit of math overhead which slows down file create workloads needlessly when the architecture cannot even support 64k blocks, thanks to page size limits. The directory entry checking can also be optimized a bit by sprinkling in some unlikely() conditions to move the error handling out of line. bonnie++ sequential file creates on a 512MB ramdisk speeds up from about 2200/s to about 2500/s, about a 14% improvement. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-25fs: add sync_inode_metadataChristoph Hellwig
Add a new helper to write out the inode using the writeback code, that is including the correct dirty bit and list manipulation. A few of filesystems already opencode this, and a lot of others should be using it instead of using write_inode_now which also writes out the data. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09introduce __block_write_beginChristoph Hellwig
Split up the block_write_begin implementation - __block_write_begin is a new trivial wrapper for block_prepare_write that always takes an already allocated page and can be either called from block_write_begin or filesystem code that already has a page allocated. Remove the handling of already allocated pages from block_write_begin after switching all callers that do it to __block_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09clean up write_begin usage for directories in pagecacheChristoph Hellwig
For filesystem that implement directories in pagecache we call block_write_begin with an already allocated page for this code, while the normal regular file write path uses the default block_write_begin behaviour. Get rid of the __foofs_write_begin helper and opencode the normal write_begin call in foofs_write_begin, while adding a new foofs_prepare_chunk helper for the directory code. The added benefit is that foofs_prepare_chunk has a much saner calling convention. Note that the interruptible flag passed into block_write_begin is always ignored if we already pass in a page (see next patch for details), and we never were doing truncations of exessive blocks for this case either so we can switch directly to block_write_begin_newtrunc. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16ext2: report metadata errors during fsyncJan Kara
When an IO error happens while writing metadata buffers, we should better report it and call ext2_error since the filesystem is probably no longer consistent. Sometimes such IO errors happen while flushing thread does background writeback, the buffer gets later evicted from memory, and thus the only trace of the error remains as AS_EIO bit set in blockdevice's mapping. So we check this bit in ext2_fsync and report the error although we cannot be really sure which buffer we failed to write. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-10ext2: fix comment in ext2_find_entry about return valuesJérémy Cochoy
Signed-off-by: Jérémy Cochoy <jeremy.cochoy@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-06-18ext2: Do not update mtime of a moved directoryJan Kara
One of our users is complaining that his backup tool is upset on ext2 (while it's happy on ext3, xfs, ...) because of the mtime change. The problem is: mkdir foo mkdir bar mkdir foo/a Now under ext2: mv foo/a foo/b changes mtime of 'foo/a' (foo/b after the move). That does not really make sense and it does not happen under any other filesystem I've seen. More complicated is: mv foo/a bar/a This changes mtime of foo/a (bar/a after the move) and it makes some sense since we had to update parent directory pointer of foo/a. But again, no other filesystem does this. So after some thoughts I'd vote for consistency and change ext2 to behave the same as other filesystems. Do not update mtime of a moved directory. Specs don't say anything about it (neither that it should, nor that it should not be updated) and other common filesystems (ext3, ext4, xfs, reiserfs, fat, ...) don't do it. So let's become more consistent. Spotted by ronny.pretzsch@dfs.de, initial fix by Jörn Engel. Reported-by: <ronny.pretzsch@dfs.de> Cc: <hare@suse.de> Cc: Jörn Engel <joern@logfs.org> Signed-off-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11switch ext2 to simple_fsync()Al Viro
kill ext2_sync_file() (along with ext2/fsync.c), get rid of ext2_update_inode() - it's an alias of ext2_write_inode(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-15ext2: also update the inode on disk when dir is IS_DIRSYNCJan Kara
We used to just write changed page for IS_DIRSYNC inodes. But we also have to update the directory inode itself just for the case that we've allocated a new block and changed i_size. [akpm@linux-foundation.org: still sync the data page] Signed-off-by: Jan Kara <jack@suse.cz> Tested-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23[PATCH] get rid of on-stack dentry in ext2_get_parent()Al Viro
2008-10-16ext2: avoid printk floods in the face of directory corruptionEric Sandeen
A very large directory with many read failures (either due to storage problems, or due to invalid size & blocks from corruption) will generate a printk storm as the filesystem continues to try to read all the blocks. This flood of messages can tie up the box until it is complete - which may be a very long time, especially for very large corrupted values. This is fixed by only reporting the corruption once each time we try to read the directory. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Eugene Teo <eugeneteo@kernel.sg> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ext2: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-04-28fs/ext2: use BUG_ONJulia Lawall
if (...) BUG(); should be replaced with BUG_ON(...) when the test has no side-effects to allow a definition of BUG_ON that drops the code completely. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @ disable unlikely @ expression E,f; @@ ( if (<... f(...) ...>) { BUG(); } | - if (unlikely(E)) { BUG(); } + BUG_ON(E); ) @@ expression E,f; @@ ( if (<... f(...) ...>) { BUG(); } | - if (E) { BUG(); } + BUG_ON(E); ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ext2: improve ext2_readdir() return valueAkinobu Mita
Improve ext2_readdir() return value for ext2_get_page() failure by using the actual result of ext2_get_page(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06BKL-removal: convert ext2 over to use unlocked_ioctlAndi Kleen
I checked ext2_ioctl and could not find anything in there that would need the BKL. So convert it over to use unlocked_ioctl Signed-off-by: Andi Kleen <ak@suse.de> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22ext2: avoid rec_len overflow with 64KB block sizeJan Kara
With 64KB blocksize, a directory entry can have size 64KB which does not fit into 16 bits we have for entry length. So we store 0xffff instead and convert the value when read from / written to disk. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ext2: convert to new aopsNick Piggin
Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: make read_cache_page synchronousNick Piggin
Ensure pages are uptodate after returning from read_cache_page, which allows us to cut out most of the filesystem-internal PageUptodate calls. I didn't have a great look down the call chains, but this appears to fixes 7 possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in block2mtd. All depending on whether the filler is async and/or can return with a !uptodate page. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] ext2: skip pages past number of blocks in ext2_find_entryEric Sandeen
This one was pointed out on the MOKB site: http://kernelfun.blogspot.com/2006/11/mokb-09-11-2006-linux-26x-ext2checkpage.html If a directory's i_size is corrupted, ext2_find_entry() will keep processing pages until the i_size is reached, even if there are no more blocks associated with the directory inode. This patch puts in some minimal sanity-checking so that we don't keep checking pages (and issuing errors) if we know there can be no more data to read, based on the block count of the directory inode. This is somewhat similar in approach to the ext3 patch I sent earlier this year. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] ext2: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the ext2 filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Move the Ext2 device ioctl compat stuff to the Ext2 driver ↵David Howells
[try #6] Move the Ext2 device ioctl compat stuff from fs/compat_ioctl.c to the Ext2 driver so that the Ext2 header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-06-25[PATCH] ext2: cleanup: put_page and comment fixEvgeniy Dushistov
Things which force me think a little: why so? Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] read_mapping_page for address spacePekka Enberg
Add read_mapping_page() which is used for callers that pass mapping->a_ops->readpage as the filler for read_cache_page. This removes some duplication from filesystem code. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26BUG_ON() Conversion in fs/ext2/Eric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-15[PATCH] Fix ext2 readdir f_pos re-validation logicAl Viro
This fixes not one, but _two_, silly (but admittedly hard to hit) bugs in the ext2 filesystem "readdir()" function. It also cleans up the code to avoid the unnecessary goto mess. The bugs were related to re-valiating the f_pos value after somebody had either done an "lseek()" on the directory to an invalid offset, or when the offset had become invalid due to a file being unlinked in the directory. The code would not only set the f_version too eagerly, it would also not update f_pos appropriately for when the offset fixup took place. When that happened, we'd occasionally subsequently fail the readdir() even when we shouldn't (no real harm done, but an ugly printk, and obviously you would end up not necessarily seeing all entries). Thanks to Masoud Sharbiani <masouds@google.com> who noticed the problem and had a test-case for it, and also fixed up a thinko in the first version of this patch. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Masoud Sharbiani <masouds@google.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11ext2: trivial indentation fix.Luiz Fernando Capitulino
This memset() line was indented with seven spaces, this patch fixes it to use a tab instead. Yes, very trivial but it's the third time I have to look at this line.. Signed-off-by: Luiz Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Adrian Bunk <bunk@stusta.de>
