path: root/fs/ext2/namei.c
2011-03-08Merge branch 'master' of git://git.infradead.org/users/eparis/selinux into nextJames Morris
2011-03-02ext2: Fix link count corruption under heavy link+rename loadJosh Hunt
vfs_rename_other() does not lock renamed inode with i_mutex. Thus changing i_nlink in a non-atomic manner (which happens in ext2_rename()) can corrupt it as reported and analyzed by Josh. In fact, there is no good reason to mess with i_nlink of the moved file. We did it presumably to simulate linking into the new directory and unlinking from an old one. But the practical effect of this is disputable because fsck can possibly treat file as being properly linked into both directories without writing any error which is confusing. So we just stop increment-decrement games with i_nlink which also fixes the corruption. CC: stable@kernel.org CC: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Josh Hunt <johunt@akamai.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-02-01fs/vfs/security: pass last path component to LSM on inode creationEric Paris
SELinux would like to implement a new labeling behavior of newly created inodes. We currently label new inodes based on the parent and the creating process. This new behavior would also take into account the name of the new object when deciding the new label. This is not the (supposed) full path, just the last component of the path. This is very useful because creating /etc/shadow is different than creating /etc/passwd but the kernel hooks are unable to differentiate these operations. We currently require that userspace realize it is doing some difficult operation like that and than userspace jumps through SELinux hoops to get things set up correctly. This patch does not implement new behavior, that is obviously contained in a seperate SELinux patch, but it does pass the needed name down to the correct LSM hook. If no such name exists it is fine to pass NULL. Signed-off-by: Eric Paris <eparis@redhat.com>
2011-01-10ext2: Remove redundant unlikely()Tobias Klauser
IS_ERR() already implies unlikely(), so it can be omitted here. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-03-05dquot: cleanup dquot initialize routineChristoph Hellwig
Get rid of the initialize dquot operation - it is now always called from the filesystem and if a filesystem really needs it's own (which none currently does) it can just call into it's own routine directly. Rename the now static low-level dquot_initialize helper to __dquot_initialize and vfs_dq_init to dquot_initialize to have a consistent namespace. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: move dquot initialization responsibility into the filesystemChristoph Hellwig
Currently various places in the VFS call vfs_dq_init directly. This means we tie the quota code into the VFS. Get rid of that and make the filesystem responsible for the initialization. For most metadata operations this is a straight forward move into the methods, but for truncate and open it's a bit more complicated. For truncate we currently only call vfs_dq_init for the sys_truncate case because open already takes care of it for ftruncate and open(O_TRUNC) - the new code causes an additional vfs_dq_init for those which is harmless. For open the initialization is moved from do_filp_open into the open method, which means it happens slightly earlier now, and only for regular files. The latter is fine because we don't need to initialize it for operations on special files, and we already do it as part of the namespace operations for directories. Add a dquot_file_open helper that filesystems that support generic quotas can use to fill in ->open. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-09-23ext2: fix format string compile warning (ino_t)Heiko Carstens
Unlike on most other architectures ino_t is an unsigned int on s390. So add an explicit cast to avoid this compile warning: fs/ext2/namei.c: In function 'ext2_lookup': fs/ext2/namei.c:73: warning: format '%lu' expects type 'long unsigned int', but argument 4 has type 'ino_t' Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-08ext[234]: move over to 'check_acl' permission modelLinus Torvalds
Don't implement per-filesystem 'extX_permission()' functions that have to be called for every path component operation, and instead just expose the actual ACL checking so that the VFS layer can now do it for us. Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-05ext2: fix unbalanced kmap()/kunmap()Nicolas Pitre
In ext2_rename(), dir_page is acquired through ext2_dotdot(). It is then released through ext2_set_link() but only if old_dir != new_dir. Failing that, the pkmap reference count is never decremented and the page remains pinned forever. Repeat that a couple times with highmem pages and all pkmap slots get exhausted, and every further kmap() calls end up stalling on the pkmap_map_wait queue at which point the whole system comes to a halt. Signed-off-by: Nicolas Pitre <nico@marvell.com> Acked-by: Theodore Ts'o <tytso@mit.edu> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30ext2: return -EIO not -ESTALE on directory traversal through deleted inodeBryan Donlan
ext2_iget() returns -ESTALE if invoked on a deleted inode, in order to report errors to NFS properly. However, in ext[234]_lookup(), this -ESTALE can be propagated to userspace if the filesystem is corrupted such that a directory entry references a deleted inode. This leads to a misleading error message - "Stale NFS file handle" - and confusion on the part of the admin. The bug can be easily reproduced by creating a new filesystem, making a link to an unused inode using debugfs, then mounting and attempting to ls -l said link. This patch thus changes ext2_lookup to return -EIO if it receives -ESTALE from ext2_iget(), as ext2 does for other filesystem metadata corruption; and also invokes the appropriate ext*_error functions when this case is detected. Signed-off-by: Bryan Donlan <bdonlan@gmail.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18ext2: Do not update mtime of a moved directoryJan Kara
One of our users is complaining that his backup tool is upset on ext2 (while it's happy on ext3, xfs, ...) because of the mtime change. The problem is: mkdir foo mkdir bar mkdir foo/a Now under ext2: mv foo/a foo/b changes mtime of 'foo/a' (foo/b after the move). That does not really make sense and it does not happen under any other filesystem I've seen. More complicated is: mv foo/a bar/a This changes mtime of foo/a (bar/a after the move) and it makes some sense since we had to update parent directory pointer of foo/a. But again, no other filesystem does this. So after some thoughts I'd vote for consistency and change ext2 to behave the same as other filesystems. Do not update mtime of a moved directory. Specs don't say anything about it (neither that it should, nor that it should not be updated) and other common filesystems (ext3, ext4, xfs, reiserfs, fat, ...) don't do it. So let's become more consistent. Spotted by ronny.pretzsch@dfs.de, initial fix by Jörn Engel. Reported-by: <ronny.pretzsch@dfs.de> Cc: <hare@suse.de> Cc: Jörn Engel <joern@logfs.org> Signed-off-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-31nfsd race fixes: ext2Al Viro
* make ext2_new_inode() put the inode into icache in locked state * do not unlock until the inode is fully set up; otherwise nfsd might pick it in half-baked state. * make sure that ext2_new_inode() does *not* lead to two inodes with the same inumber hashed at the same time; otherwise a bogus fhandle coming from nfsd might race with inode creation: nfsd: iget_locked() creates inode nfsd: try to read from disk, block on that. ext2_new_inode(): allocate inode with that inumber ext2_new_inode(): insert it into icache, set it up and dirty ext2_write_inode(): get the relevant part of inode table in cache, set the entry for our inode (and start writing to disk) nfsd: get CPU again, look into inode table, see nice and sane on-disk inode, set the in-core inode from it oops - we have two in-core inodes with the same inumber live in icache, both used for IO. Welcome to fs corruption... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-23[PATCH] get rid of on-stack dentry in ext2_get_parent()Al Viro
2008-10-23[PATCH] switch all filesystems over to d_obtain_aliasChristoph Hellwig
Switch all users of d_alloc_anon to d_obtain_alias. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-07iget: stop EXT2 from using iget() and read_inode()David Howells
Stop the EXT2 filesystem from using iget() and read_inode(). Replace ext2_read_inode() with ext2_iget(), and call that instead of iget(). ext2_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. ext2_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Cc: <linux-ext4@vger.kernel.org> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-01[PATCH] r/o bind mounts: unlink: monitor i_nlinkDave Hansen
When a filesystem decrements i_nlink to zero, it means that a write must be performed in order to drop the inode from the filesystem. We're shortly going to have keep filesystems from being remounted r/o between the time that this i_nlink decrement and that write occurs. So, add a little helper function to do the decrements. We'll tie into it in a bit to note when i_nlink hits zero. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] ext2: switch to inode_inc_count, inode_dec_countAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] ext2: remove d_splice_alias NULL check from ext2_lookupPekka Enberg
Remove redundant NULL check in ext2_lookup() as d_splice_alias() can take NULL inode as input. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] xip: ext2: execute in placeCarsten Otte
These are the ext2 related parts. Ext2 now uses the xip_* file operations along with the get_xip_page aop when mounted with -o xip. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
