path: root/fs/ext2/super.c
2011-01-11Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: ext2: Resolve 'dereferencing pointer to incomplete type' when enabling EXT2_XATTR_DEBUG ext3: Remove redundant unlikely() ext2: Remove redundant unlikely() ext3: speed up file creates by optimizing rec_len functions ext2: speed up file creates by optimizing rec_len functions ext3: Add more journal error check ext3: Add journal error check in resize.c quota: Use %pV and __attribute__((format (printf in __quota_error and fix fallout ext3: Add FITRIM handling ext3: Add batched discard support for ext3 ext3: Add journal error check into ext3_rename() ext3: Use search_dirblock() in ext3_dx_find_entry() ext3: Avoid uninitialized memory references with a corrupted htree directory ext3: Return error code from generic_check_addressable ext3: Add journal error check into ext3_delete_entry() ext3: Add error check in ext3_mkdir() fs/ext3/super.c: Use printf extension %pV fs/ext2/super.c: Use printf extension %pV ext3: don't update sb journal_devnum when RO dev
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-06fs/ext2/super.c: Use printf extension %pVJoe Perches
Using %pV reduces the number of printk calls and eliminates any possible message interleaving from other printk calls. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25ext2_remount: don't bother with invalidate_inodes()Al Viro
It's pointless - we *do* have busy inodes (root directory, for one), so that call will fail and attempt to change XIP flag will be ignored. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-04BKL: Remove BKL from ext2 filesystemJan Blunck
The BKL is still used in ext2_put_super(), ext2_fill_super(), ext2_sync_fs() ext2_remount() and ext2_write_inode(). From these calls ext2_put_super(), ext2_fill_super() and ext2_remount() are protected against each other by the struct super_block s_umount rw semaphore. The call in ext2_write_inode() could only protect the modification of the ext2_sb_info through ext2_update_dynamic_rev() against concurrent ext2_sync_fs() or ext2_remount(). ext2_fill_super() and ext2_put_super() can be left out because you need a valid filesystem reference in all three cases, which you do not have when you are one of these functions. If the BKL is only protecting the modification of the ext2_sb_info it can safely be removed since this is protected by the struct ext2_sb_info s_lock. Signed-off-by: Jan Blunck <jblunck@infradead.org> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-04BKL: Explicitly add BKL around get_sb/fill_superJan Blunck
This patch is a preparation necessary to remove the BKL from do_new_mount(). It explicitly adds calls to lock_kernel()/unlock_kernel() around get_sb/fill_super operations for filesystems that still uses the BKL. I've read through all the code formerly covered by the BKL inside do_kern_mount() and have satisfied myself that it doesn't need the BKL any more. do_kern_mount() is already called without the BKL when mounting the rootfs and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called from various places without BKL: simple_pin_fs(), nfs_do_clone_mount() through nfs_follow_mountpoint(), afs_mntpt_do_automount() through afs_mntpt_follow_link(). Both later functions are actually the filesystems follow_link inode operation. vfs_kern_mount() is calling the specified get_sb function and lets the filesystem do its job by calling the given fill_super function. Therefore I think it is safe to push down the BKL from the VFS to the low-level filesystems get_sb/fill_super operation. [arnd: do not add the BKL to those file systems that already don't use it elsewhere] Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Christoph Hellwig <hch@infradead.org>
2010-08-09merge ext2 delete_inode and clear_inode, switch to ->evict_inode()Al Viro
2010-05-24quota: rename default quotactl methods to dquot_Christoph Hellwig
Follow the dquot_* style used elsewhere in dquot.c. [Jan Kara: Fixed up missing conversion of ext2] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: explicitly set ->dq_op and ->s_qcopChristoph Hellwig
Only set the quota operation vectors if the filesystem actually supports quota instead of doing it for all filesystems in alloc_super(). [Jan Kara: Export dquot_operations and vfs_quotactl_ops] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: move unmount handling into the filesystemChristoph Hellwig
Currently the VFS calls into the quotactl interface for unmounting filesystems. This means filesystems with their own quota handling can't easily distinguish between user-space originating quotaoff and an unount. Instead move the responsibily of the unmount handling into the filesystem to be consistent with all other dquot handling. Note that we do call dquot_disable a lot later now, e.g. after a sync_filesystem. But this is fine as the quota code does all its writes via blockdev's mapping and that is synced even later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: kill the vfs_dq_off and vfs_dq_quota_on_remount wrappersChristoph Hellwig
Instead of having wrappers in the VFS namespace export the dquot_suspend and dquot_resume helpers directly. Also rename vfs_quota_disable to dquot_disable while we're at it. [Jan Kara: Moved dquot_suspend to quotaops.h and made it inline] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: move remount handling into the filesystemChristoph Hellwig
Currently do_remount_sb calls into the dquot code to tell it about going from rw to ro and ro to rw. Move this code into the filesystem to not depend on the dquot code in the VFS - note ocfs2 already ignores these calls and handles remount by itself. This gets rid of overloading the quotactl calls and allows to unify the VFS and XFS codepaths in that area later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21BKL: Remove BKL from ext2 filesystemJan Blunck
The BKL is still used in ext2_put_super(), ext2_fill_super(), ext2_sync_fs() ext2_remount() and ext2_write_inode(). From these calls ext2_put_super(), ext2_fill_super() and ext2_remount() are protected against each other by the struct super_block s_umount rw semaphore. The call in ext2_write_inode() could only protect the modification of the ext2_sb_info through ext2_update_dynamic_rev() against concurrent ext2_sync_fs() or ext2_remount(). ext2_fill_super() and ext2_put_super() can be left out because you need a valid filesystem reference in all three cases, which you do not have when you are one of these functions. If the BKL is only protecting the modification of the ext2_sb_info it can safely be removed since this is protected by the struct ext2_sb_info s_lock. Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21ext2: Add ext2_sb_info s_lock spinlockJan Blunck
Add a spinlock that protects against concurrent modifications of s_mount_state, s_blocks_last, s_overhead_last and the content of the superblock's buffer pointed to by sbi->s_es. The spinlock is now used in ext2_xattr_update_super_block() which was setting the EXT2_FEATURE_COMPAT_EXT_ATTR flag on the superblock without protection before. Likewise the spinlock is used in ext2_show_options() to have a consistent view of the mount options. This is a preparation patch for removing the BKL from ext2 in the next patch. Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: Jan Kara <jack@suse.cz> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21ext2: Move ext2_write_super() out of ext2_setup_super()Jan Blunck
Move ext2_write_super() out of ext2_setup_super() as a preparation for the next patch that adds a new lock for superblock fields. Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21ext2: Fold ext2_commit_super() into ext2_sync_super()Jan Blunck
Both function originally did similar things except that ext2_sync_super() is returning after the call to sync_dirty_buffer(sbh). Therefore this patch adds a wait flag to tell ext2_sync_super() if it has to call sync_dirty_buffer() to wait for in-progress I/O to finish. Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21ext2: Remove duplicate code from ext2_sync_fs()Jan Blunck
Depending in the state (valid or unchecked) of the filesystem either ext2_sync_super() or ext2_commit_super() is called. If the filesystem is currently valid (it is checked), we first mark it unchecked and afterwards duplicate the work that ext2_sync_super() is doing later. Therefore this patch removes the duplicate code and calls ext2_sync_super() directly after marking the filesystem unchecked. Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21ext2: Set the write time in ext2_sync_fs()Jan Blunck
This is probably a typo since the write time should actually be updated by ext2_sync_fs() instead of the mount time. Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21ext2: Use ext2_clear_super_error() in ext2_sync_fs()Jan Blunck
ext2_sync_fs() used to duplicate the code from ext2_clear_super_error(). Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: cleanup dquot drop routineChristoph Hellwig
Get rid of the drop dquot operation - it is now always called from the filesystem and if a filesystem really needs it's own (which none currently does) it can just call into it's own routine directly. Rename the now static low-level dquot_drop helper to __dquot_drop and vfs_dq_drop to dquot_drop to have a consistent namespace. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: move dquot drop responsibility into the filesystemChristoph Hellwig
Currently clear_inode calls vfs_dq_drop directly. This means we tie the quota code into the VFS. Get rid of that and make the filesystem responsible for the drop inside the ->clear_inode superblock operation. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-16ext2: avoid WARN() messages when failing to write to the superblockTheodore Ts'o
This fixes a common warning reported by kerneloops.org [Kernel summit hacking hour] [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-10ext2: clear uptodate flag on super block I/O errorStephen Hemminger
This fixes a WARN backtrace in mark_buffer_dirty() that occurs during unmount when a USB or floppy device is removed. I reported this a kernel regression, but looks like it might have been there for longer than that. The super block update from a previous operation has marked the buffer as in error, and the flag has to be cleared before doing the update. (Similar code already exists in ext4). Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-10ext2: Unify log messages in ext2Alexey Fisher
make messages produced by ext2 more unified. It should be easy to parse. dmesg before patch: [ 4893.684892] reservations ON [ 4893.684896] xip option not supported [ 4893.684961] EXT2-fs warning: mounting ext3 filesystem as ext2 [ 4893.684964] EXT2-fs warning: maximal mount count reached, running e2fsck is recommended [ 4893.684990] EXT II FS: 0.5b, 95/08/09, bs=1024, fs=1024, gc=2, bpg=8192, ipg=1280, mo=80010] dmesg after patch: [ 4893.684892] EXT2-fs (loop0): reservations ON [ 4893.684896] EXT2-fs (loop0): xip option not supported [ 4893.684961] EXT2-fs (loop0): warning: mounting ext3 filesystem as ext2 [ 4893.684964] EXT2-fs (loop0): warning: maximal mount count reached, running e2fsck is recommended [ 4893.684990] EXT2-fs (loop0): 0.5b, 95/08/09, bs=1024, fs=1024, gc=2, bpg=8192, ipg=1280, mo=80010] Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net> Reviewed-by: Andreas Dilger <adilger@sun.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-06-24switch ext2 to inode->i_aclAl Viro
2009-06-11ext2: add ->sync_fsChristoph Hellwig
Add a ->sync_fs method for data integrity syncs, and reimplement ->write_super ontop of it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11Push BKL down into ->remount_fs()Alessio Igor Bogani
[xfs, btrfs, capifs, shmem don't need BKL, exempt] Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11push BKL down into ->put_superChristoph Hellwig
Move BKL into ->put_super from the only caller. A couple of filesystems had trivial enough ->put_super (only kfree and NULLing of s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs, hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most of them probably don't need it, but I'd rather sort that out individually. Preferably after all the other BKL pushdowns in that area. [AV: original used to move lock_super() down as well; these changes are removed since we don't do lock_super() at all in generic_shutdown_super() now] [AV: fuse, btrfs and xfs are known to need no damn BKL, exempt] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11remove ->write_super call in generic_shutdown_superChristoph Hellwig
We just did a full fs writeout using sync_filesystem before, and if that's not enough for the filesystem it can perform it's own writeout in ->put_super, which many filesystems already do. Move a call to foofs_write_super into every foofs_put_super for now to guarantee identical behaviour until it's cleaned up by the individual filesystem maintainers. Exceptions: - affs already has identical copy & pasted code at the beginning of affs_put_super so no need to do it twice. - xfs does the right thing without it and I have changes pending for the xfs tree touching this are so I don't really need conflicts here.. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-17ext2: Fix memory leak in ext2_fill_super() in case of a failed mountManish Katiyar
Signed-off-by: Manish Katiyar <mkatiyar@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-04-27ext2: missing unlock in ext2_quota_write()Dan Carpenter
The inode->i_mutex should be unlocked. Found by smatch (http://repo.or.cz/w/smatch.git). Compile tested. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-03-26ext2: Zero our b_size in ext2_quota_read()Manish Katiyar
ext2_quota_read() doesn't initialize tmp_bh.b_size before calling ext2_get_block() where we access it. Since it is a local variable it might contain some garbage. Make sure it is filled with reasonable value before passing. Signed-off-by: Manish Katiyar <mkatiyar@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-02-11ext2/xip: refuse to change xip flag during remount with busy inodesCarsten Otte
For a reason that I was unable to understand in three months of debugging, mount ext2 -o remount stopped working properly when remounting from regular operation to xip, or the other way around. According to a git bisect search, the problem was introduced with the VM_MIXEDMAP/PTE_SPECIAL rework in the vm: commit 70688e4dd1647f0ceb502bbd5964fa344c5eb411 Author: Nick Piggin <npiggin@suse.de> Date: Mon Apr 28 02:13:02 2008 -0700 xip: support non-struct page backed memory In the failing scenario, the filesystem is mounted read only via root= kernel parameter on s390x. During remount (in rc.sysinit), the inodes of the bash binary and its libraries are busy and cannot be invalidated (the bash which is running rc.sysinit resides on subject filesystem). Afterwards, another bash process (running ifup-eth) recurses into a subshell, runs dup_mm (via fork). Some of the mappings in this bash process were created from inodes that could not be invalidated during remount. Both parent and child process crash some time later due to inconsistencies in their address spaces. The issue seems to be timing sensitive, various attempts to recreate it have failed. This patch refuses to change the xip flag during remount in case some inodes cannot be invalidated. This patch keeps users from running into that issue. [akpm@linux-foundation.org: cleanup] Signed-off-by: Carsten Otte <cotte@de.ibm.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Jared Hulbert <jaredeh@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08ext2: allocate ->s_blockgroup_lock separatelyPekka J Enberg
As spotted by kmemtrace, struct ext2_sb_info is 17024 bytes on 64-bit which makes it a very bad fit for SLAB allocators. The culprit of the wasted memory is ->s_blockgroup_lock which can be as big as 16 KB when NR_CPUS >= 32. To fix that, allocate ->s_blockgroup_lock, which fits nicely in a order 2 page in the worst case, separately. This shinks down struct ext2_sb_info enough to fit a 1 KB slab cache so now we allocate 16 KB + 1 KB instead of 32 KB saving 15 KB of memory. Acked-by: Andreas Dilger <adilger@sun.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13vfs: Use const for kernel parser tableSteven Whitehouse
This is a much better version of a previous patch to make the parser tables constant. Rather than changing the typedef, we put the "const" in all the various places where its required, allowing the __initconst exception for nfsroot which was the cause of the previous trouble. This was posted for review some time ago and I believe its been in -mm since then. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Alexander Viro <aviro@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25quota: move function-macros from quota.h to quotaops.hJan Kara
Move declarations of some macros, which should be in fact functions to quotaops.h. This way they can be later converted to inline functions because we can now use declarations from quota.h. Also add necessary includes of quotaops.h to a few files. [akpm@linux-foundation.org: fix JFS build] [akpm@linux-foundation.org: fix UFS build] [vegard.nossum@gmail.com: fix QUOTA=n build] Signed-off-by: Jan Kara <jack@suse.cz> Cc: Vegard Nossum <vegard.nossum@gmail.com> Cc: Arjen Pool <arjenpool@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ext2: replace remaining __FUNCTION__ occurrencesHarvey Harrison
2008-04-28ext2: use ext2_group_first_block_no()Akinobu Mita
Use ext2_group_first_block_no() and assign the return values to ext2_fsblk_t variables. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ext2: convert byte order of constant instead of variableMarcin Slusarz
Convert byte order of constant instead of variable which can be done at compile time (vs run time). Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ext2: le*_add_cpu conversionMarcin Slusarz
replace all: little_endian_variable = cpu_to_leX(leX_to_cpu(little_endian_variable) + expression_in_cpu_byteorder); with: leX_add_cpu(&little_endian_variable, expression_in_cpu_byteorder); generated with semantic patch Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08mount options: fix ext2Miklos Szeredi
Add noreservation option to /proc/mounts for ext2 filesystems. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop EXT2 from using iget() and read_inode()David Howells
Stop the EXT2 filesystem from using iget() and read_inode(). Replace ext2_read_inode() with ext2_iget(), and call that instead of iget(). ext2_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. ext2_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Cc: <linux-ext4@vger.kernel.org> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06ext[234]: use ext[234]_get_group_desc()Akinobu Mita
Use ext[234]_get_group_desc() to get group descriptor from group number. Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06ext2: xip check fixNick Piggin
ext2 should not worry about checking sb->s_blocksize for XIP before the sb's blocksize actually gets set. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06ext2: change the default behaviour on errorAneesh Kumar K.V
ext2 file system was by default ignoring errors and continuing. This is not a good default as continuing on error could lead to file system corruption. Change the default to mark the file system readonly. Debian and ubuntu already does this as the default in their fstab. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: <linux-ext4@vger.kernel.org> Cc: Eric Sandeen <sandeen@redhat.com> Cc: Jan Kara <jack@ucw.cz> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28ext2: Fix the max file size for ext2 file system.Aneesh Kumar K.V
The max file size for ext2 file system is now calculated with hardcoded 4K block size. The patch fixes it to be calculated with the right block size. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2007-10-22exportfs: make struct export_operations constChristoph Hellwig
Now that nfsd has stopped writing to the find_exported_dentry member we an mark the export_operations const Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22ext2: new export opsChristoph Hellwig
Trivial switch over to the new generic helpers. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
