path: root/fs/ext2
2011-08-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: xfs: Fix build breakage in xfs_iops.c when CONFIG_FS_POSIX_ACL is not set VFS: Reorganise shrink_dcache_for_umount_subtree() after demise of dcache_lock VFS: Remove dentry->d_lock locking from shrink_dcache_for_umount_subtree() VFS: Remove detached-dentry counter from shrink_dcache_for_umount_subtree() switch posix_acl_chmod() to umode_t switch posix_acl_from_mode() to umode_t switch posix_acl_equiv_mode() to umode_t * switch posix_acl_create() to umode_t * block: initialise bd_super in bdget() vfs: avoid call to inode_lru_list_del() if possible vfs: avoid taking inode_hash_lock on pipes and sockets vfs: conditionally call inode_wb_list_del() VFS: Fix automount for negative autofs dentries Btrfs: load the key from the dir item in readdir into a fake dentry devtmpfs: missing initialialization in never-hit case hppfs: missing include
2011-08-01switch posix_acl_equiv_mode() to umode_t *Al Viro
... so that &inode->i_mode could be passed to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-08-01switch posix_acl_create() to umode_t *Al Viro
so we can pass &inode->i_mode to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-29ext2: remove duplicate 'ext2_get_acl()' defineLinus Torvalds
When commit 4e34e719e457 ("fs: take the ACL checks to common code") changed the xyz_check_acl() functions into the more natural xyz_get_acl() interface, we grew two copies of the #define ext2_get_acl NULL define for the non-acl case. Remove the extra one. Reported-by: Marco Stornelli <marco.stornelli@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: jbd: change the field "b_cow_tid" of struct journal_head from type unsigned to tid_t ext3.txt: update the links in the section "useful links" to the latest ones ext3: Fix data corruption in inodes with journalled data ext2: check xattr name_len before acquiring xattr_sem in ext2_xattr_get ext3: Fix compilation with -DDX_DEBUG quota: Remove unused declaration jbd: Use WRITE_SYNC in journal checkpoint. jbd: Fix oops in journal_remove_journal_head() ext3: Return -EINVAL when start is beyond the end of fs in ext3_trim_fs() ext3/ioctl.c: silence sparse warnings about different address spaces ext3/ext4 Documentation: remove bh/nobh since it has been deprecated ext3: Improve truncate error handling ext3: use proper little-endian bitops ext2: include fs.h into ext2_fs.h ext3: Fix oops in ext3_try_to_allocate_with_rsv() jbd: fix a bug of leaking jh->b_jcount jbd: remove dependency on __GFP_NOFAIL ext3: Convert ext3 to new truncate calling convention jbd: Add fixed tracepoints ext3: Add fixed tracepoints Resolve conflicts in fs/ext3/fsync.c due to fsync locking push-down and new fixed tracepoints.
2011-07-25fs: take the ACL checks to common codeChristoph Hellwig
Replace the ->check_acl method with a ->get_acl method that simply reads an ACL from disk after having a cache miss. This means we can replace the ACL checking boilerplate code with a single implementation in namei.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplates around posix_acl_create_masq()Al Viro
new helper: posix_acl_create(&acl, gfp, mode_p). Replaces acl with modified clone, on failure releases acl and replaces with NULL. Returns 0 or -ve on error. All callers of posix_acl_create_masq() switched. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplate around posix_acl_chmod_masq()Al Viro
new helper: posix_acl_chmod(&acl, gfp, mode). Replaces acl with modified clone or with NULL if that has failed; returns 0 or -ve on error. All callers of posix_acl_chmod_masq() switched to that - they'd been doing exactly the same thing. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25vfs: move ACL cache lookup into generic codeLinus Torvalds
This moves logic for checking the cached ACL values from low-level filesystems into generic code. The end result is a streamlined ACL check that doesn't need to load the inode->i_op->check_acl pointer at all for the common cached case. The filesystems also don't need to check for a non-blocking RCU walk case in their acl_check() functions, because that is all handled at a VFS layer. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-22ext2: check xattr name_len before acquiring xattr_sem in ext2_xattr_getWang Sheng-Hui
In ext2_xattr_get(), the code will acquire xattr_sem first, later checks the length of xattr name_len > 255. It's unnecessarily time consuming and also ext2_xattr_set() checks the length before other checks. So move the check before acquiring xattr_sem to make these two functions consistent. Signed-off-by: Wang Sheng-Hui <shhuiw@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: simplify the blockdev_direct_IO prototypeChristoph Hellwig
Simple filesystems always pass inode->i_sb_bdev as the block device argument, and never need a end_io handler. Let's simply things for them and for my grepping activity by dropping these arguments. The only thing not falling into that scheme is ext4, which passes and end_io handler without needing special flags (yet), but given how messy the direct I/O code there is use of __blockdev_direct_IO in one instead of two out of three cases isn't going to make a large difference anyway. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: move inode_dio_wait calls into ->setattrChristoph Hellwig
Let filesystems handle waiting for direct I/O requests themselves instead of doing it beforehand. This means filesystem-specific locks to prevent new dio referenes from appearing can be held. This is important to allow generalizing i_dio_count to non-DIO_LOCKING filesystems. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20make d_splice_alias(ERR_PTR(err), dentry) = ERR_PTR(err)Al Viro
... and simplify the living hell out of callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to ->check_acl()Al Viro
not used in the instances anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: pass MAY_NOT_BLOCK to ->check_acl()Al Viro
2011-05-17ext2: fix error msg when mounting fs with too-large blocksizeRobin Dong
When ext2 mounts a filesystem, it attempts to set the block device blocksize with a call to sb_set_blocksize, which can fail for several reasons. The current failure message in ext2 prints: EXT2-fs (loop1): error: blocksize is too small which is not correct in all cases. This can be demonstrated by creating a filesystem with # mkfs.ext2 -b 8192 on a 4k page system, and attempting to mount it. Change the error message to a more generic: EXT2-fs (loop1): bad blocksize 8192 to match the error message in ext3. Signed-off-by: Robin Dong <sanbai@taobao.com> Reviewed-by: Coly Li <bosong.ly@taobao.com> Reviewed-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-23userns: rename is_owner_or_cap to inode_owner_or_capableSerge E. Hallyn
And give it a kernel-doc comment. [akpm@linux-foundation.org: btrfs changed in linux-next] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: remove ext2 non-atomic bitops from asm/bitops.hAkinobu Mita
As the result of conversions, there are no users of ext2 non-atomic bit operations except for ext2 filesystem itself. Now we can put them into architecture independent code in ext2 filesystem, and remove from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-08Merge branch 'master' of git://git.infradead.org/users/eparis/selinux into nextJames Morris
2011-03-02ext2: Fix link count corruption under heavy link+rename loadJosh Hunt
vfs_rename_other() does not lock renamed inode with i_mutex. Thus changing i_nlink in a non-atomic manner (which happens in ext2_rename()) can corrupt it as reported and analyzed by Josh. In fact, there is no good reason to mess with i_nlink of the moved file. We did it presumably to simulate linking into the new directory and unlinking from an old one. But the practical effect of this is disputable because fsck can possibly treat file as being properly linked into both directories without writing any error which is confusing. So we just stop increment-decrement games with i_nlink which also fixes the corruption. CC: stable@kernel.org CC: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Josh Hunt <johunt@akamai.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-02-01fs/vfs/security: pass last path component to LSM on inode creationEric Paris
SELinux would like to implement a new labeling behavior of newly created inodes. We currently label new inodes based on the parent and the creating process. This new behavior would also take into account the name of the new object when deciding the new label. This is not the (supposed) full path, just the last component of the path. This is very useful because creating /etc/shadow is different than creating /etc/passwd but the kernel hooks are unable to differentiate these operations. We currently require that userspace realize it is doing some difficult operation like that and than userspace jumps through SELinux hoops to get things set up correctly. This patch does not implement new behavior, that is obviously contained in a seperate SELinux patch, but it does pass the needed name down to the correct LSM hook. If no such name exists it is fine to pass NULL. Signed-off-by: Eric Paris <eparis@redhat.com>
2011-01-11Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (44 commits) ext4: fix trimming starting with block 0 with small blocksize ext4: revert buggy trim overflow patch ext4: don't pass entire map to check_eofblocks_fl ext4: fix memory leak in ext4_free_branches ext4: remove ext4_mb_return_to_preallocation() ext4: flush the i_completed_io_list during ext4_truncate ext4: add error checking to calls to ext4_handle_dirty_metadata() ext4: fix trimming of a single group ext4: fix uninitialized variable in ext4_register_li_request ext4: dynamically allocate the jbd2_inode in ext4_inode_info as necessary ext4: drop i_state_flags on architectures with 64-bit longs ext4: reorder ext4_inode_info structure elements to remove unneeded padding ext4: drop ec_type from the ext4_ext_cache structure ext4: use ext4_lblk_t instead of sector_t for logical blocks ext4: replace i_delalloc_reserved_flag with EXT4_STATE_DELALLOC_RESERVED ext4: fix 32bit overflow in ext4_ext_find_goal() ext4: add more error checks to ext4_mkdir() ext4: ext4_ext_migrate should use NULL not 0 ext4: Use ext4_error_file() to print the pathname to the corrupted inode ext4: use IS_ERR() to check for errors in ext4_error_file ...
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: ext2: Resolve 'dereferencing pointer to incomplete type' when enabling EXT2_XATTR_DEBUG ext3: Remove redundant unlikely() ext2: Remove redundant unlikely() ext3: speed up file creates by optimizing rec_len functions ext2: speed up file creates by optimizing rec_len functions ext3: Add more journal error check ext3: Add journal error check in resize.c quota: Use %pV and __attribute__((format (printf in __quota_error and fix fallout ext3: Add FITRIM handling ext3: Add batched discard support for ext3 ext3: Add journal error check into ext3_rename() ext3: Use search_dirblock() in ext3_dx_find_entry() ext3: Avoid uninitialized memory references with a corrupted htree directory ext3: Return error code from generic_check_addressable ext3: Add journal error check into ext3_delete_entry() ext3: Add error check in ext3_mkdir() fs/ext3/super.c: Use printf extension %pV fs/ext2/super.c: Use printf extension %pV ext3: don't update sb journal_devnum when RO dev
2011-01-10ext2: Remove redundant unlikely()Tobias Klauser
IS_ERR() already implies unlikely(), so it can be omitted here. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-10ext2: speed up file creates by optimizing rec_len functionsEric Sandeen
The addition of 64k block capability in the rec_len_from_disk and rec_len_to_disk functions added a bit of math overhead which slows down file create workloads needlessly when the architecture cannot even support 64k blocks, thanks to page size limits. The directory entry checking can also be optimized a bit by sprinkling in some unlikely() conditions to move the error handling out of line. bonnie++ sequential file creates on a 512MB ramdisk speeds up from about 2200/s to about 2500/s, about a 14% improvement. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-10ext2: remove dead code in ext2_xattr_getWang Sheng-Hui
Reviewed-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Wang Sheng-Hui <crosslonelyover@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext2,ext3,ext4: clarify comment for extN_xattr_set_handleWang Sheng-Hui
2011-01-07ext2,3,4: provide simple rcu-walk ACL implementationNick Piggin
This simple implementation just checks for no ACLs on the inode, and if so, then the rcu-walk may proceed, otherwise fail it. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: provide rcu-walk aware permission i_opsNick Piggin
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-06fs/ext2/super.c: Use printf extension %pVJoe Perches
Using %pV reduces the number of printk calls and eliminates any possible message interleaving from other printk calls. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-27Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (24 commits) quota: Fix possible oops in __dquot_initialize() ext3: Update kernel-doc comments jbd/2: fixed typos ext2: fixed typo. ext3: Fix debug messages in ext3_group_extend() jbd: Convert atomic_inc() to get_bh() ext3: Remove misplaced BUFFER_TRACE() in ext3_truncate() jbd: Fix debug message in do_get_write_access() jbd: Check return value of __getblk() ext3: Use DIV_ROUND_UP() on group desc block counting ext3: Return proper error code on ext3_fill_super() ext3: Remove unnecessary casts on bh->b_data ext3: Cleanup ext3_setup_super() quota: Fix issuing of warnings from dquot_transfer quota: fix dquot_disable vs dquot_transfer race v2 jbd: Convert bitops to buffer fns ext3/jbd: Avoid WARN() messages when failing to write the superblock jbd: Use offset_in_page() instead of manual calculation jbd: Remove unnecessary goto statement jbd: Use printk_ratelimited() in journal_alloc_journal_head() ...
2010-10-28ext2: fixed typo.Andrea Gelmini
"excpet" Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-28ext2: fix comment on ext2_try_to_allocate()Namhyung Kim
@handle doesn't exist in ext2. Remove it. Also, fit comment header into kernel-doc format. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25ext2_remount: don't bother with invalidate_inodes()Al Viro
It's pointless - we *do* have busy inodes (root directory, for one), so that call will fail and attempt to change XIP flag will be ignored. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: add sync_inode_metadataChristoph Hellwig
Add a new helper to write out the inode using the writeback code, that is including the correct dirty bit and list manipulation. A few of filesystems already opencode this, and a lot of others should be using it instead of using write_inode_now which also writes out the data. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-04BKL: Remove BKL from ext2 filesystemJan Blunck
The BKL is still used in ext2_put_super(), ext2_fill_super(), ext2_sync_fs() ext2_remount() and ext2_write_inode(). From these calls ext2_put_super(), ext2_fill_super() and ext2_remount() are protected against each other by the struct super_block s_umount rw semaphore. The call in ext2_write_inode() could only protect the modification of the ext2_sb_info through ext2_update_dynamic_rev() against concurrent ext2_sync_fs() or ext2_remount(). ext2_fill_super() and ext2_put_super() can be left out because you need a valid filesystem reference in all three cases, which you do not have when you are one of these functions. If the BKL is only protecting the modification of the ext2_sb_info it can safely be removed since this is protected by the struct ext2_sb_info s_lock. Signed-off-by: Jan Blunck <jblunck@infradead.org> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-04BKL: Explicitly add BKL around get_sb/fill_superJan Blunck
This patch is a preparation necessary to remove the BKL from do_new_mount(). It explicitly adds calls to lock_kernel()/unlock_kernel() around get_sb/fill_super operations for filesystems that still uses the BKL. I've read through all the code formerly covered by the BKL inside do_kern_mount() and have satisfied myself that it doesn't need the BKL any more. do_kern_mount() is already called without the BKL when mounting the rootfs and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called from various places without BKL: simple_pin_fs(), nfs_do_clone_mount() through nfs_follow_mountpoint(), afs_mntpt_do_automount() through afs_mntpt_follow_link(). Both later functions are actually the filesystems follow_link inode operation. vfs_kern_mount() is calling the specified get_sb function and lets the filesystem do its job by calling the given fill_super function. Therefore I think it is safe to push down the BKL from the VFS to the low-level filesystems get_sb/fill_super operation. [arnd: do not add the BKL to those file systems that already don't use it elsewhere] Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Christoph Hellwig <hch@infradead.org>
2010-09-23ext2: fix a typo on comment in ext2/inode.cNamhyung Kim
'excpet' should be 'except'. 'ext3_get_branch' should be 'ext2_get_branch'. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-09mbcache: Remove unused featuresAndreas Gruenbacher
The mbcache code was written to support a variable number of indexes, but all the existing users use exactly one index. Simplify to code to support only that case. There are also no users of the cache entry free operation, and none of the users keep extra data in cache entries. Remove those features as well. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09merge ext2 delete_inode and clear_inode, switch to ->evict_inode()Al Viro
2010-08-09Don't dirty the victim in ext2_xattr_delete_inode()Al Viro
... it's beyond fs-writeback reach already - writeback won't be started at that point. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09Take dirtying the inode to callers of ext2_free_blocks()Al Viro
