path: root/fs/ext2
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-23userns: rename is_owner_or_cap to inode_owner_or_capableSerge E. Hallyn
And give it a kernel-doc comment. [akpm@linux-foundation.org: btrfs changed in linux-next] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: remove ext2 non-atomic bitops from asm/bitops.hAkinobu Mita
As the result of conversions, there are no users of ext2 non-atomic bit operations except for ext2 filesystem itself. Now we can put them into architecture independent code in ext2 filesystem, and remove from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-08Merge branch 'master' of git://git.infradead.org/users/eparis/selinux into nextJames Morris
2011-03-02ext2: Fix link count corruption under heavy link+rename loadJosh Hunt
vfs_rename_other() does not lock renamed inode with i_mutex. Thus changing i_nlink in a non-atomic manner (which happens in ext2_rename()) can corrupt it as reported and analyzed by Josh. In fact, there is no good reason to mess with i_nlink of the moved file. We did it presumably to simulate linking into the new directory and unlinking from an old one. But the practical effect of this is disputable because fsck can possibly treat file as being properly linked into both directories without writing any error which is confusing. So we just stop increment-decrement games with i_nlink which also fixes the corruption. CC: stable@kernel.org CC: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Josh Hunt <johunt@akamai.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-02-01fs/vfs/security: pass last path component to LSM on inode creationEric Paris
SELinux would like to implement a new labeling behavior of newly created inodes. We currently label new inodes based on the parent and the creating process. This new behavior would also take into account the name of the new object when deciding the new label. This is not the (supposed) full path, just the last component of the path. This is very useful because creating /etc/shadow is different than creating /etc/passwd but the kernel hooks are unable to differentiate these operations. We currently require that userspace realize it is doing some difficult operation like that and than userspace jumps through SELinux hoops to get things set up correctly. This patch does not implement new behavior, that is obviously contained in a seperate SELinux patch, but it does pass the needed name down to the correct LSM hook. If no such name exists it is fine to pass NULL. Signed-off-by: Eric Paris <eparis@redhat.com>
2011-01-11Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (44 commits) ext4: fix trimming starting with block 0 with small blocksize ext4: revert buggy trim overflow patch ext4: don't pass entire map to check_eofblocks_fl ext4: fix memory leak in ext4_free_branches ext4: remove ext4_mb_return_to_preallocation() ext4: flush the i_completed_io_list during ext4_truncate ext4: add error checking to calls to ext4_handle_dirty_metadata() ext4: fix trimming of a single group ext4: fix uninitialized variable in ext4_register_li_request ext4: dynamically allocate the jbd2_inode in ext4_inode_info as necessary ext4: drop i_state_flags on architectures with 64-bit longs ext4: reorder ext4_inode_info structure elements to remove unneeded padding ext4: drop ec_type from the ext4_ext_cache structure ext4: use ext4_lblk_t instead of sector_t for logical blocks ext4: replace i_delalloc_reserved_flag with EXT4_STATE_DELALLOC_RESERVED ext4: fix 32bit overflow in ext4_ext_find_goal() ext4: add more error checks to ext4_mkdir() ext4: ext4_ext_migrate should use NULL not 0 ext4: Use ext4_error_file() to print the pathname to the corrupted inode ext4: use IS_ERR() to check for errors in ext4_error_file ...
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: ext2: Resolve 'dereferencing pointer to incomplete type' when enabling EXT2_XATTR_DEBUG ext3: Remove redundant unlikely() ext2: Remove redundant unlikely() ext3: speed up file creates by optimizing rec_len functions ext2: speed up file creates by optimizing rec_len functions ext3: Add more journal error check ext3: Add journal error check in resize.c quota: Use %pV and __attribute__((format (printf in __quota_error and fix fallout ext3: Add FITRIM handling ext3: Add batched discard support for ext3 ext3: Add journal error check into ext3_rename() ext3: Use search_dirblock() in ext3_dx_find_entry() ext3: Avoid uninitialized memory references with a corrupted htree directory ext3: Return error code from generic_check_addressable ext3: Add journal error check into ext3_delete_entry() ext3: Add error check in ext3_mkdir() fs/ext3/super.c: Use printf extension %pV fs/ext2/super.c: Use printf extension %pV ext3: don't update sb journal_devnum when RO dev
2011-01-10ext2: Remove redundant unlikely()Tobias Klauser
IS_ERR() already implies unlikely(), so it can be omitted here. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-10ext2: speed up file creates by optimizing rec_len functionsEric Sandeen
The addition of 64k block capability in the rec_len_from_disk and rec_len_to_disk functions added a bit of math overhead which slows down file create workloads needlessly when the architecture cannot even support 64k blocks, thanks to page size limits. The directory entry checking can also be optimized a bit by sprinkling in some unlikely() conditions to move the error handling out of line. bonnie++ sequential file creates on a 512MB ramdisk speeds up from about 2200/s to about 2500/s, about a 14% improvement. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-10ext2: remove dead code in ext2_xattr_getWang Sheng-Hui
Reviewed-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Wang Sheng-Hui <crosslonelyover@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext2,ext3,ext4: clarify comment for extN_xattr_set_handleWang Sheng-Hui
2011-01-07ext2,3,4: provide simple rcu-walk ACL implementationNick Piggin
This simple implementation just checks for no ACLs on the inode, and if so, then the rcu-walk may proceed, otherwise fail it. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: provide rcu-walk aware permission i_opsNick Piggin
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-06fs/ext2/super.c: Use printf extension %pVJoe Perches
Using %pV reduces the number of printk calls and eliminates any possible message interleaving from other printk calls. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-27Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (24 commits) quota: Fix possible oops in __dquot_initialize() ext3: Update kernel-doc comments jbd/2: fixed typos ext2: fixed typo. ext3: Fix debug messages in ext3_group_extend() jbd: Convert atomic_inc() to get_bh() ext3: Remove misplaced BUFFER_TRACE() in ext3_truncate() jbd: Fix debug message in do_get_write_access() jbd: Check return value of __getblk() ext3: Use DIV_ROUND_UP() on group desc block counting ext3: Return proper error code on ext3_fill_super() ext3: Remove unnecessary casts on bh->b_data ext3: Cleanup ext3_setup_super() quota: Fix issuing of warnings from dquot_transfer quota: fix dquot_disable vs dquot_transfer race v2 jbd: Convert bitops to buffer fns ext3/jbd: Avoid WARN() messages when failing to write the superblock jbd: Use offset_in_page() instead of manual calculation jbd: Remove unnecessary goto statement jbd: Use printk_ratelimited() in journal_alloc_journal_head() ...
2010-10-28ext2: fixed typo.Andrea Gelmini
"excpet" Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-28ext2: fix comment on ext2_try_to_allocate()Namhyung Kim
@handle doesn't exist in ext2. Remove it. Also, fit comment header into kernel-doc format. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25ext2_remount: don't bother with invalidate_inodes()Al Viro
It's pointless - we *do* have busy inodes (root directory, for one), so that call will fail and attempt to change XIP flag will be ignored. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: add sync_inode_metadataChristoph Hellwig
Add a new helper to write out the inode using the writeback code, that is including the correct dirty bit and list manipulation. A few of filesystems already opencode this, and a lot of others should be using it instead of using write_inode_now which also writes out the data. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-04BKL: Remove BKL from ext2 filesystemJan Blunck
The BKL is still used in ext2_put_super(), ext2_fill_super(), ext2_sync_fs() ext2_remount() and ext2_write_inode(). From these calls ext2_put_super(), ext2_fill_super() and ext2_remount() are protected against each other by the struct super_block s_umount rw semaphore. The call in ext2_write_inode() could only protect the modification of the ext2_sb_info through ext2_update_dynamic_rev() against concurrent ext2_sync_fs() or ext2_remount(). ext2_fill_super() and ext2_put_super() can be left out because you need a valid filesystem reference in all three cases, which you do not have when you are one of these functions. If the BKL is only protecting the modification of the ext2_sb_info it can safely be removed since this is protected by the struct ext2_sb_info s_lock. Signed-off-by: Jan Blunck <jblunck@infradead.org> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-04BKL: Explicitly add BKL around get_sb/fill_superJan Blunck
This patch is a preparation necessary to remove the BKL from do_new_mount(). It explicitly adds calls to lock_kernel()/unlock_kernel() around get_sb/fill_super operations for filesystems that still uses the BKL. I've read through all the code formerly covered by the BKL inside do_kern_mount() and have satisfied myself that it doesn't need the BKL any more. do_kern_mount() is already called without the BKL when mounting the rootfs and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called from various places without BKL: simple_pin_fs(), nfs_do_clone_mount() through nfs_follow_mountpoint(), afs_mntpt_do_automount() through afs_mntpt_follow_link(). Both later functions are actually the filesystems follow_link inode operation. vfs_kern_mount() is calling the specified get_sb function and lets the filesystem do its job by calling the given fill_super function. Therefore I think it is safe to push down the BKL from the VFS to the low-level filesystems get_sb/fill_super operation. [arnd: do not add the BKL to those file systems that already don't use it elsewhere] Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Christoph Hellwig <hch@infradead.org>
2010-09-23ext2: fix a typo on comment in ext2/inode.cNamhyung Kim
'excpet' should be 'except'. 'ext3_get_branch' should be 'ext2_get_branch'. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-09mbcache: Remove unused featuresAndreas Gruenbacher
The mbcache code was written to support a variable number of indexes, but all the existing users use exactly one index. Simplify to code to support only that case. There are also no users of the cache entry free operation, and none of the users keep extra data in cache entries. Remove those features as well. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09merge ext2 delete_inode and clear_inode, switch to ->evict_inode()Al Viro
2010-08-09Don't dirty the victim in ext2_xattr_delete_inode()Al Viro
... it's beyond fs-writeback reach already - writeback won't be started at that point. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09Take dirtying the inode to callers of ext2_free_blocks()Al Viro
2010-08-09ext2: switch to dquot_free_block_nodirty()Al Viro
brute-force conversion Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09check ATTR_SIZE contraints in inode_change_okChristoph Hellwig
Make sure we check the truncate constraints early on in ->setattr by adding those checks to inode_change_ok. Also clean up and document inode_change_ok to make this obvious. As a fallout we don't have to call inode_newsize_ok from simple_setsize and simplify it down to a truncate_setsize which doesn't return an error. This simplifies a lot of setattr implementations and means we use truncate_setsize almost everywhere. Get rid of fat_setsize now that it's trivial and mark ext2_setsize static to make the calling convention obvious. Keep the inode_newsize_ok in vmtruncate for now as all callers need an audit for its removal anyway. Note: setattr code in ecryptfs doesn't call inode_change_ok at all and needs a deeper audit, but that is left for later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09rename generic_setattrChristoph Hellwig
Despite its name it's now a generic implementation of ->setattr, but rather a helper to copy attributes from a struct iattr to the inode. Rename it to setattr_copy to reflect this fact. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09get rid of block_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in preparation of the new truncate sequence and rename the non-truncating version to block_write_begin. While we're at it also remove several unused arguments to block_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09introduce __block_write_beginChristoph Hellwig
Split up the block_write_begin implementation - __block_write_begin is a new trivial wrapper for block_prepare_write that always takes an already allocated page and can be either called from block_write_begin or filesystem code that already has a page allocated. Remove the handling of already allocated pages from block_write_begin after switching all callers that do it to __block_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09clean up write_begin usage for directories in pagecacheChristoph Hellwig
For filesystem that implement directories in pagecache we call block_write_begin with an already allocated page for this code, while the normal regular file write path uses the default block_write_begin behaviour. Get rid of the __foofs_write_begin helper and opencode the normal write_begin call in foofs_write_begin, while adding a new foofs_prepare_chunk helper for the directory code. The added benefit is that foofs_prepare_chunk has a much saner calling convention. Note that the interruptible flag passed into block_write_begin is always ignored if we already pass in a page (see next patch for details), and we never were doing truncations of exessive blocks for this case either so we can switch directly to block_write_begin_newtrunc. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09get rid of nobh_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the only remaining caller and rename the non-truncating version to nobh_write_begin. Get rid of the superflous file argument to it while we're at it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09sort out blockdev_direct_IO variantsChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in prepearation of the new truncate calling sequence. This was only done for DIO_LOCKING filesystems, so the __blockdev_direct_IO_newtrunc variant was not needed anyway. Get rid of blockdev_direct_IO_no_locking and its _newtrunc variant while at it as just opencoding the two additional paramters is shorted than the name suffix. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-06-25ext2: update ctime when changing the file's permission by setfaclJan Kara
ext2 didn't update the ctime of the file when its permission was changed. Steps to reproduce: # touch aaa # stat -c %Z aaa 1275289822 # setfacl -m 'u::x,g::x,o::x' aaa # stat -c %Z aaa 1275289822 <- unchanged But, according to the spec of the ctime, ext2 must update it. Port of ext3 patch by Miao Xie <miaox@cn.fujitsu.com>. Signed-off-by: Jan Kara <jack@suse.cz>
2010-06-04fix truncate inode time modification breakageNick Piggin
mtime and ctime should be changed only if the file size has actually changed. Patches changing ext2 and tmpfs from vmtruncate to new truncate sequence has caused regressions where they always update timestamps. There is some strange cases in POSIX where truncate(2) must not update times unless the size has acutally changed, see 6e656be89. This area is all still rather buggy in different ways in a lot of filesystems and needs a cleanup and audit (ideally the vfs will provide a simple attribute or call to direct all filesystems exactly which attributes to change). But coming up with the best solution will take a while and is not appropriate for rc anyway. So fix recent regression for now. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-30Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: quota: Convert quota statistics to generic percpu_counter ext3 uses rb_node = NULL; to zero rb_root. quota: Fixup dquot_transfer reiserfs: Fix resuming of quotas on remount read-write pohmelfs: Remove dead quota code ufs: Remove dead quota code udf: Remove dead quota code quota: rename default quotactl methods to dquot_ quota: explicitly set ->dq_op and ->s_qcop quota: drop remount argument to ->quota_on and ->quota_off quota: move unmount handling into the filesystem quota: kill the vfs_dq_off and vfs_dq_quota_on_remount wrappers quota: move remount handling into the filesystem ocfs2: Fix use after free on remount read-only Fix up conflicts in fs/ext4/super.c and fs/ufs/file.c
2010-05-27ext2: convert to use the new truncate convention.npiggin@suse.de
I also have commented a possible bug in existing ext2 code, marked with XXX. Cc: linux-ext4@vger.kernel.org Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
2010-05-24quota: rename default quotactl methods to dquot_Christoph Hellwig
Follow the dquot_* style used elsewhere in dquot.c. [Jan Kara: Fixed up missing conversion of ext2] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: explicitly set ->dq_op and ->s_qcopChristoph Hellwig
Only set the quota operation vectors if the filesystem actually supports quota instead of doing it for all filesystems in alloc_super(). [Jan Kara: Export dquot_operations and vfs_quotactl_ops] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: move unmount handling into the filesystemChristoph Hellwig
Currently the VFS calls into the quotactl interface for unmounting filesystems. This means filesystems with their own quota handling can't easily distinguish between user-space originating quotaoff and an unount. Instead move the responsibily of the unmount handling into the filesystem to be consistent with all other dquot handling. Note that we do call dquot_disable a lot later now, e.g. after a sync_filesystem. But this is fine as the quota code does all its writes via blockdev's mapping and that is synced even later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: kill the vfs_dq_off and vfs_dq_quota_on_remount wrappersChristoph Hellwig
Instead of having wrappers in the VFS namespace export the dquot_suspend and dquot_resume helpers directly. Also rename vfs_quota_disable to dquot_disable while we're at it. [Jan Kara: Moved dquot_suspend to quotaops.h and made it inline] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
