path: root/fs/ext3/fsync.c
2011-07-26Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: jbd: change the field "b_cow_tid" of struct journal_head from type unsigned to tid_t ext3.txt: update the links in the section "useful links" to the latest ones ext3: Fix data corruption in inodes with journalled data ext2: check xattr name_len before acquiring xattr_sem in ext2_xattr_get ext3: Fix compilation with -DDX_DEBUG quota: Remove unused declaration jbd: Use WRITE_SYNC in journal checkpoint. jbd: Fix oops in journal_remove_journal_head() ext3: Return -EINVAL when start is beyond the end of fs in ext3_trim_fs() ext3/ioctl.c: silence sparse warnings about different address spaces ext3/ext4 Documentation: remove bh/nobh since it has been deprecated ext3: Improve truncate error handling ext3: use proper little-endian bitops ext2: include fs.h into ext2_fs.h ext3: Fix oops in ext3_try_to_allocate_with_rsv() jbd: fix a bug of leaking jh->b_jcount jbd: remove dependency on __GFP_NOFAIL ext3: Convert ext3 to new truncate calling convention jbd: Add fixed tracepoints ext3: Add fixed tracepoints Resolve conflicts in fs/ext3/fsync.c due to fsync locking push-down and new fixed tracepoints.
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-25ext3: Add fixed tracepointsLukas Czerner
This commit adds fixed tracepoints to the ext3 code. It is based on ext4 tracepoints, however due to the differences of both file systems, there are some tracepoints missing (those for delaloc and for multi-block allocator) and there are some ext3 specific as well (for reservation windows). Here is a list: ext3_free_inode ext3_request_inode ext3_allocate_inode ext3_evict_inode ext3_drop_inode ext3_mark_inode_dirty ext3_write_begin ext3_ordered_write_end ext3_writeback_write_end ext3_journalled_write_end ext3_ordered_writepage ext3_writeback_writepage ext3_journalled_writepage ext3_readpage ext3_releasepage ext3_invalidatepage ext3_discard_blocks ext3_request_blocks ext3_allocate_blocks ext3_free_blocks ext3_sync_file_enter ext3_sync_file_exit ext3_sync_fs ext3_rsv_window_add ext3_discard_reservation ext3_alloc_new_reservation ext3_reserved ext3_forget ext3_read_block_bitmap ext3_direct_IO_enter ext3_direct_IO_exit ext3_unlink_enter ext3_unlink_exit ext3_truncate_enter ext3_truncate_exit ext3_get_blocks_enter ext3_get_blocks_exit ext3_load_inode Signed-off-by: Lukas Czerner <lczerner@redhat.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Jan Kara <jack@suse.cz>
2010-09-16block: remove BLKDEV_IFL_WAITChristoph Hellwig
All the blkdev_issue_* helpers can only sanely be used for synchronous caller. To issue cache flushes or barriers asynchronously the caller needs to set up a bio by itself with a completion callback to move the asynchronous state machine ahead. So drop the BLKDEV_IFL_WAIT flag that is always specified when calling blkdev_issue_* and also remove the now unused flags argument to blkdev_issue_flush and blkdev_issue_zeroout. For blkdev_issue_discard we need to keep it for the secure discard flag, which gains a more descriptive name and loses the bitops vs flag confusion. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21Merge branch 'master' into for-2.6.35Jens Axboe
Conflicts: fs/ext3/fsync.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-21ext3: Fix waiting on transaction during fsyncJan Kara
log_start_commit() returns 1 only when it started a transaction commit. Thus in case transaction commit is already running, we fail to wait for the commit to finish. Fix the issue by always waiting for the commit regardless of the log_start_commit return value. Signed-off-by: Jan Kara <jack@suse.cz>
2010-04-28blkdev: generalize flags for blkdev_issue_fn functionsDmitry Monakhov
The patch just convert all blkdev_issue_xxx function to common set of flags. Wait/allocation semantics preserved. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-11-11ext3: Wait for proper transaction commit on fsyncJan Kara
We cannot rely on buffer dirty bits during fsync because pdflush can come before fsync is called and clear dirty bits without forcing a transaction commit. What we do is that we track which transaction has last changed the inode and which transaction last changed allocation and force it to disk on fsync. Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2009-09-16ext3: Flush disk caches on fsync when neededJan Kara
In case we fsync() a file and inode is not dirty, we don't force a transaction to disk and hence don't flush disk caches. Thus file data could be just in disk caches and not on persistent storage. Fix the problem by flushing disk caches if we didn't force a transaction commit. Signed-off-by: Jan Kara <jack@suse.cz>
2008-04-28ext3: fdatasync should skip metadata writeout when overwritingHisashi Hifumi
Currently fdatasync is identical to fsync in ext3. I think fdatasync should skip journal flush in data=ordered and data=writeback mode when it overwrites to already-instantiated blocks on HDD. When I_DIRTY_DATASYNC flag is not set, fdatasync should skip journal writeout because this indicates only atime or/and mtime updates. Following patch is the same approach of ext2's fsync code(ext2_sync_file). I did a performance test using the sysbench. #sysbench --num-threads=128 --max-requests=50000 --test=fileio --file-total-size=128G --file-test-mode=rndwr --file-fsync-mode=fdatasync run The result on ext3 was: -2.6.24 Operations performed: 0 Read, 50080 Write, 59600 Other = 109680 Total Read 0b Written 782.5Mb Total transferred 782.5Mb (12.116Mb/sec) 775.45 Requests/sec executed Test execution summary: total time: 64.5814s total number of events: 50080 total time taken by event execution: 3713.9836 per-request statistics: min: 0.0000s avg: 0.0742s max: 0.9375s approx. 95 percentile: 0.2901s Threads fairness: events (avg/stddev): 391.2500/23.26 execution time (avg/stddev): 29.0155/1.99 -2.6.24-patched Operations performed: 0 Read, 50009 Write, 61596 Other = 111605 Total Read 0b Written 781.39Mb Total transferred 781.39Mb (16.419Mb/sec) 1050.83 Requests/sec executed Test execution summary: total time: 47.5900s total number of events: 50009 total time taken by event execution: 2934.5768 per-request statistics: min: 0.0000s avg: 0.0587s max: 0.8938s approx. 95 percentile: 0.1993s Threads fairness: events (avg/stddev): 390.6953/22.64 execution time (avg/stddev): 22.9264/1.17 Filesystem I/O throughput was improved. Signed-off-by :Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Acked-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18sparse pointer use of zero as nullStephen Hemminger
Get rid of sparse related warnings from places that use integer as NULL pointer. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Andi Kleen <ak@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Ian Kent <raven@themaw.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-27[PATCH] ext3 and jbd cleanup: remove whitespaceMingming Cao
Remove whitespace from ext3 and jbd, before we clone ext4. Signed-off-by: Mingming Cao<cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
