path: root/fs/ext3/ioctl.c
2011-06-25ext3/ioctl.c: silence sparse warnings about different address spacesH Hartley Sweeten
The 'from' argument for copy_from_user and the 'to' argument for copy_to_user should both be tagged as __user address space. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Signed-off-by: Jan Kara <jack@suse.cz>
2011-03-23userns: rename is_owner_or_cap to inode_owner_or_capableSerge E. Hallyn
And give it a kernel-doc comment. [akpm@linux-foundation.org: btrfs changed in linux-next] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-10ext3: Add FITRIM handlingLukas Czerner
The ioctl takes fstrim_range structure (defined in include/linux/fs.h) as an argument specifying a range of filesystem to trim and the minimum size of an continguous extent to trim. After the FITRIM is done, the number of bytes passed from the filesystem down the block stack to the device for potential discard is stored in fstrim_range.len. This number is a maximum discard amount from the storage device's perspective, because FITRIM called repeatedly will keep sending the same sectors for discard. fstrim_range.len will report the same potential discard bytes each time, but only sectors which had been written to between the discards would actually be discarded by the storage device. Further, the kernel block layer reserves the right to adjust the discard ranges to fit raid stripe geometry, non-trim capable devices in a LVM setup, etc. These reductions would not be reflected in fstrim_range.len. Thus fstrim_range.len can give the user better insight on how much storage space has potentially been released for wear-leveling, but it needs to be one of only one criteria the userspace tools take into account when trying to optimize calls to FITRIM. Thanks to Greg Freemyer <greg.freemyer@gmail.com> for better commit message. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-04-02ext3: remove the BKL in ext3/ioctl.cCyrus Massoumi
Reformat ext3/ioctl.c to make it look more like ext4/ioctl.c and remove the BKL around ext3_ioctl(). Signed-off-by: Cyrus Massoumi <cyrusm@gmx.net> Cc: <linux-ext4@vger.kernel.org> Acked-by: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08ext3: tighten restrictions on inode flagsDuane Griffin
At the moment there are few restrictions on which flags may be set on which inodes. Specifically DIRSYNC may only be set on directories and IMMUTABLE and APPEND may not be set on links. Tighten that to disallow TOPDIR being set on non-directories and only NODUMP and NOATIME to be set on non-regular file, non-directories. Introduces a flags masking function which masks flags based on mode and use it during inode creation and when flags are set via the ioctl to facilitate future consistency. Signed-off-by: Duane Griffin <duaneg@dghda.com> Acked-by: Andreas Dilger <adilger@sun.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23ext3: add checks for errors from jbdHidehiro Kawai
If the journal has aborted due to a checkpointing failure, we have to keep the contents of the journal space. Otherwise, the filesystem will lose uncheckpointed metadata completely and become inconsistent. To avoid this, we need to keep needs_recovery flag if checkpoint has failed. With this patch, ext3_put_super() detects a checkpointing failure from the return value of journal_destroy(), then it invokes ext3_abort() to make the filesystem read only and keep needs_recovery flag. Errors from journal_flush() are also handled by this patch in some places. Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Jan Kara <jack@ucw.cz> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19[PATCH] r/o bind mounts: elevate write count for ioctls()Dave Hansen
Some ioctl()s can cause writes to the filesystem. Take these, and make them use mnt_want/drop_write() instead. [AV: updated] Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-11-14Forbid user to change file flags on quota filesJan Kara
Forbid user from changing file flags on quota files. User has no bussiness in playing with these flags when quota is on. Furthermore there is a remote possibility of deadlock due to a lock inversion between quota file's i_mutex and transaction's start (i_mutex for quota file is locked only when trasaction is started in quota operations) in ext3 and ext4. Signed-off-by: Jan Kara <jack@suse.cz> Cc: LIOU Payphone <lioupayphone@gmail.com> Cc: <linux-ext4@vger.kernel.org> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Introduce is_owner_or_cap() to wrap CAP_FOWNER use with fsuid checkSatyam Sharma
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant users to it. This is done because we want to avoid bugs in the future where we check for only effective fsuid of the current task against a file's owning uid, without simultaneously checking for CAP_FOWNER as well, thus violating its semantics. [ XFS uses special macros and structures, and in general looked ... untouchable, so we leave it alone -- but it has been looked over. ] The (current->fsuid != inode->i_uid) check in generic_permission() and exec_permission_lite() is left alone, because those operations are covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08ext3: copy i_flags to inode flags on writeJan Kara
A patch that stores inode flags such as S_IMMUTABLE, S_APPEND, etc. from i_flags to EXT3_I(inode)->i_flags when inode is written to disk. The same thing is done on GETFLAGS ioctl. Quota code changes these flags on quota files (to make it harder for sysadmin to screw himself) and these changes were not correctly propagated into the filesystem (especially, lsattr did not show them and users were wondering...). Propagate flags such as S_APPEND, S_IMMUTABLE, etc. from i_flags into ext3-specific i_flags. Hence, when someone sets these flags via a different interface than ioctl, they are stored correctly. Signed-off-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] ext3: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the ext3 filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Move the Ext3 device ioctl compat stuff to the Ext3 driver ↵David Howells
[try #6] Move the Ext3 device ioctl compat stuff from fs/compat_ioctl.c to the Ext3 driver so that the Ext3 header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-06-25[PATCH] ext3_fsblk_t: the rest of in-kernel filesystem blocks conversionMingming Cao
Convert the ext3 in-kernel filesystem blocks to ext3_fsblk_t. Convert the rest of all unsigned long type in-kernel filesystem blocks to ext3_fsblk_t, and replace the printk format string respondingly. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26[PATCH] protect ext3 ioctl modifying append_only, immutable, etc. with i_mutexAl Viro
All modifications of ->i_flags in inodes that might be visible to somebody else must be under ->i_mutex. That patch fixes ext3 ioctl() setting S_APPEND and friends. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] convert ext3's truncate_sem to a mutexArjan van de Ven
ext3's truncate_sem is always released in the same function it's taken and it otherwise is a mutex as well.. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
