path: root/fs/ext3/namei.h
2005-10-30[PATCH] ext3: sparse fixesBen Dooks
Fix warnings from sparse due to un-declared functions that should either have a header file or have been declared static fs/ext2/bitmap.c:14:15: warning: symbol 'ext2_count_free' was not declared. Should it be static? fs/ext2/namei.c:92:15: warning: symbol 'ext2_get_parent' was not declared. Should it be static? fs/ext3/bitmap.c:15:15: warning: symbol 'ext3_count_free' was not declared. Should it be static? fs/ext3/namei.c:1013:15: warning: symbol 'ext3_get_parent' was not declared. Should it be static? fs/ext3/xattr.c:214:1: warning: symbol 'ext3_xattr_block_get' was not declared. Should it be static? fs/ext3/xattr.c:358:1: warning: symbol 'ext3_xattr_block_list' was not declared. Should it be static? fs/ext3/xattr.c:630:1: warning: symbol 'ext3_xattr_block_find' was not declared. Should it be static? fs/ext3/xattr.c:863:1: warning: symbol 'ext3_xattr_ibody_find' was not declared. Should it be static? Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
