path: root/fs/ext3/resize.c
2015-07-23fs: Remove ext3 filesystem driverJan Kara
The functionality of ext3 is fully supported by ext4 driver. Major distributions (SUSE, RedHat) already use ext4 driver to handle ext3 filesystems for quite some time. There is some ugliness in mm resulting from jbd cleaning buffers in a dirty page without cleaning page dirty bit and also support for buffer bouncing in the block layer when stable pages are required is there only because of jbd. So let's remove the ext3 driver. This saves us some 28k lines of duplicated code. Acked-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Jan Kara <jack@suse.cz>
2013-01-21Ext3: return ENOMEM rather than EIO if sb_getblk failsWang Shilong
It will be better to use ENOMEM rather than EIO, because the only reason that sb_getblk fails is that allocation fails. Signed-off-by: Wang Shilong <wangsl-fnst@cn.fujitsu.com> Signed-off-by: Jan Kara <jack@suse.cz>
2013-01-21Ext3: use unlikely to improve the efficiency of the kernelWang Shilong
Because the function 'sb_getblk' seldomly fails to return NULL value,it will be better to use unlikely to check it. Signed-off-by: Wang Shilong <wangsl-fnst@cn.fujitsu.com> Signed-off-by: Jan Kara <jack@suse.cz>
2012-03-31ext3: move headers to fs/ext3/Al Viro
2011-01-10ext3: Add journal error check in resize.cNamhyung Kim
Check return value of ext3_journal_get_write_access() and ext3_journal_dirty_metadata(). Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-28ext3: Fix debug messages in ext3_group_extend()Namhyung Kim
Fix a typo, break long lines and use E3FSBLK on ext3_fsblk_t. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-07-21ext3: Fix set but unused variablesAndi Kleen
[tytso@mit.edu: Fix compilation with CONFIG_JBD_DEBUG enabled] Acked-by: tytso@mit.edu cc: linux-ext4@vger.kernel.org Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-23ext3: Replace lock/unlock_super() with an explicit lock for resizingEric Sandeen
Use a separate lock to protect s_groups_count and the other block group descriptors which get changed via an on-line resize operation, so we can stop overloading the use of lock_super(). Port of ext4 commit 32ed5058ce90024efcd811254b4b1de0468099df by Theodore Ts'o <tytso@mit.edu>. CC: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-10ext3: PTR_ERR return of wrong pointer in setup_new_group_blocks()Roel Kluin
Return the PTR_ERR of the correct pointer. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2009-06-19block: rename CONFIG_LBD to CONFIG_LBDAFBartlomiej Zolnierkiewicz
Follow-up to "block: enable by default support for large devices and files on 32-bit archs". Rename CONFIG_LBD to CONFIG_LBDAF to: - allow update of existing [def]configs for "default y" change - reflect that it is used also for large files support nowadays Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-11ext3: remove ->write_super and stop maintaining ->s_dirtChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-20ext3: don't try to resize if there are no reserved gdt blocks leftJosef Bacik
When trying to resize a ext3 fs and you run out of reserved gdt blocks, you get an error that doesn't actually tell you what went wrong, it just says that the gdb it picked is not correct, which is the case since you don't have any reserved gdt blocks left. This patch adds a check to make sure you have reserved gdt blocks to use, and if not prints out a more relevant error. Signed-off-by: Josef Bacik <jbacik@redhat.com> Cc: <linux-ext4@vger.kernel.org> Cc: Andreas Dilger <adilger@sun.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-06ext3: fix online resize bugJosef Bacik
There is a bug when we are trying to verify that the reserve inode's double indirect blocks point back to the primary gdt blocks. The fix is obvious, we need to mod the gdb count by the addr's per block. You can verify this with the following test case dd if=/dev/zero of=disk1 seek=1024 count=1 bs=100M losetup /dev/loop1 disk1 pvcreate /dev/loop1 vgcreate loopvg1 /dev/loop1 lvcreate -l 100%VG loopvg1 -n looplv1 mkfs.ext3 -J size=64 -b 1024 /dev/loopvg1/looplv1 mount /dev/loopvg1/looplv1 /mnt/loop dd if=/dev/zero of=disk2 seek=1024 count=1 bs=50M losetup /dev/loop2 disk2 pvcreate /dev/loop2 vgextend loopvg1 /dev/loop2 lvextend -l 100%VG /dev/loopvg1/looplv1 resize2fs /dev/loopvg1/looplv1 without this patch the resize2fs fails, with it the resize2fs succeeds. Signed-off-by: Josef Bacik <jbacik@redhat.com> Acked-by: Andreas Dilger <adilger@sun.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ext3: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28ext3: add missing ext3_journal_stop()Akinobu Mita
Add missing ext3_journal_stop() in error handling. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19ext3: fix wrong gfp type under transactionJosef Bacik
There are several places where we make allocations with GFP_KERNEL while under a transaction, which could lead to an assertion panic or lockup if under memory pressure. This patch switches these problem areas to use GFP_NOFS to keep these problems from happening. Signed-off-by: Josef Bacik <jbacik@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08ext3: replace all adds to little endians variables with le*_add_cpuMarcin Slusarz
replace all: little_endian_variable = cpu_to_leX(leX_to_cpu(little_endian_variable) + expression_in_cpu_byteorder); with: leX_add_cpu(&little_endian_variable, expression_in_cpu_byteorder); sparse didn't generate any new warning with this patch Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop EXT3 from using iget() and read_inode()David Howells
Stop the EXT3 filesystem from using iget() and read_inode(). Replace ext3_read_inode() with ext3_iget(), and call that instead of iget(). ext3_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. ext3_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Acked-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18ext3: fix setup_new_group_blocks lockingEric Sandeen
setup_new_group_blocks() manipulates the group descriptor block bh under the block_bitmap bh's lock. It shouldn't matter since nobody but resize should be touching these blocks, but it's worth fixing up. Signed-off-by: Eric Sandeen <sandeen@redhat.com> C: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ext3: lighten up resize transaction requirementsEric Sandeen
When resizing online, setup_new_group_blocks attempts to reserve a potentially very large transaction, depending on the current filesystem geometry. For some journal sizes, there may not be enough room for this transaction, and the online resize will fail. The patch below resizes & restarts the transaction as necessary while setting up the new group, and should work with even the smallest journal. Tested with something like: [root@newbox ~]# dd if=/dev/zero of=fsfile bs=1024 count=32768 [root@newbox ~]# mkfs.ext3 -b 1024 fsfile 16384 [root@newbox ~]# mount -o loop fsfile mnt/ [root@newbox ~]# resize2fs /dev/loop0 resize2fs 1.40.2 (12-Jul-2007) Filesystem at /dev/loop0 is mounted on /root/mnt; on-line resizing required old desc_blocks = 1, new_desc_blocks = 1 Performing an on-line resize of /dev/loop0 to 32768 (1k) blocks. resize2fs: No space left on device While trying to add group #2 [root@newbox ~]# dmesg | tail -n 1 JBD: resize2fs wants too many credits (258 > 256) [root@newbox ~]# With the below change, it works. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Eric Sandeen <sandeen@redhat.com> Acked-by: Andreas Dilger <adilger@clusterfs.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_counter_addPeter Zijlstra
s/percpu_counter_mod/percpu_counter_add/ Because its a better name, _mod implies modulo. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-27[PATCH] fs: Removing useless castsPanagiotis Issaris
* Removing useless casts * Removing useless wrapper * Conversion from kmalloc+memset to kzalloc Signed-off-by: Panagiotis Issaris <takis@issaris.org> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] more ext3 16T overflow fixesEric Sandeen
Some of the changes in balloc.c are just cosmetic, as Andreas pointed out - if they overflow they'll then underflow and things are fine. 5th hunk actually fixes an overflow problem. Also check for potential overflows in inode & block counts when resizing. Signed-off-by: Eric Sandeen <esandeen@redhat.com> Cc: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] ext3: Fix sparse warningsDave Kleikamp
Fixing up some endian-ness warnings in preparation to clone ext4 from ext3. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ext3_fsblk_t: the rest of in-kernel filesystem blocks conversionMingming Cao
Convert the ext3 in-kernel filesystem blocks to ext3_fsblk_t. Convert the rest of all unsigned long type in-kernel filesystem blocks to ext3_fsblk_t, and replace the printk format string respondingly. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ext3_fsblk_t: filesystem, group blocks and bug fixesMingming Cao
Some of the in-kernel ext3 block variable type are treated as signed 4 bytes int type, thus limited ext3 filesystem to 8TB (4kblock size based). While trying to fix them, it seems quite confusing in the ext3 code where some blocks are filesystem-wide blocks, some are group relative offsets that need to be signed value (as -1 has special meaning). So it seem saner to define two types of physical blocks: one is filesystem wide blocks, another is group-relative blocks. The following patches clarify these two types of blocks in the ext3 code, and fix the type bugs which limit current 32 bit ext3 filesystem limit to 8TB. With this series of patches and the percpu counter data type changes in the mm tree, we are able to extend exts filesystem limit to 16TB. This work is also a pre-request for the recent >32 bit ext3 work, and makes the kernel to able to address 48 bit ext3 block a lot easier: Simply redefine ext3_fsblk_t from unsigned long to sector_t and redefine the format string for ext3 filesystem block corresponding. Two RFC with a series patches have been posted to ext2-devel list and have been reviewed and discussed: http://marc.theaimsgroup.com/?l=ext2-devel&m=114722190816690&w=2 http://marc.theaimsgroup.com/?l=ext2-devel&m=114784919525942&w=2 Patches are tested on both 32 bit machine and 64 bit machine, <8TB ext3 and >8TB ext3 filesystem(with the latest to be released e2fsprogs-1.39). Tests includes overnight fsx, tiobench, dbench and fsstress. This patch: Defines ext3_fsblk_t and ext3_grpblk_t, and the printk format string for filesystem wide blocks. This patch classifies all block group relative blocks, and ext3_fsblk_t blocks occurs in the same function where used to be confusing before. Also include kernel bug fixes for filesystem wide in-kernel block variables. There are some fileystem wide blocks are treated as int/unsigned int type in the kernel currently, especially in ext3 block allocation and reservation code. This patch fixed those bugs by converting those variables to ext3_fsblk_t(unsigned long) type. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Avoid disk sector_t overflow for >2TB ext3 filesystemMingming Cao
If ext3 filesystem is larger than 2TB, and sector_t is a u32 (i.e. CONFIG_LBD not defined in the kernel), the calculation of the disk sector will overflow. Add check at ext3_fill_super() and ext3_group_extend() to prevent mount/remount/resize >2TB ext3 filesystem if sector_t size is 4 bytes. Verified this patch on a 32 bit platform without CONFIG_LBD defined (sector_t is 32 bits long), mount refuse to mount a 10TB ext3. Signed-off-by: Mingming Cao<cmm@us.ibm.com> Acked-by: Andreas Dilger <adilger@clusterfs.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-31[PATCH] ext3 resize: fix double unlock_super()Andrew Morton
From: Andrew Morton <akpm@osdl.org> Spotted by Jan Capek <jca@sysgo.com> Cc: "Stephen C. Tweedie" <sct@redhat.com> Cc: Andreas Dilger <adilger@clusterfs.com> Cc: Jan Capek <jca@sysgo.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26[PATCH] forgotten ->b_data in memcpy() call in ext3/resize.c (oopsable)Al Viro
sbi->s_group_desc is an array of pointers to buffer_head. memcpy() of buffer size from address of buffer_head is a bad idea - it will generate junk in any case, may oops if buffer_head is close to the end of slab page and next page is not mapped and isn't what was intended there. IOW, ->b_data is missing in that call. Fortunately, result doesn't go into the primary on-disk data structures, so only backup ones get crap written to them; that had allowed this bug to remain unnoticed until now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-17[PATCH] ext3: Fix missed mutex unlockAnaniev, Leonid I
Missed unlock_super()call is added in error condition code path. Signed-off-by: Leonid Ananiev <leonid.i.ananiev@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-11[PATCH] ext3: Fix missed mutex unlockAnaniev, Leonid I
Missed unlock_super()call is added in error condition code path. Signed-off-by: Leonid Ananiev <leonid.i.ananiev@intel.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] ext3: use sbi instead of EXT3_SB() in resize code.Glauber de Oliveira Costa
There are places in the resize code in which EXT3_SB() macro is used after an statement like sbi = EXT3_SB(sb) is done. Inside the same function, both sbi and EXT3_SB() are used to reference the super block Altough it is not wrong, keeping it coherent increases legibility, IMHO. Signed-off-by: Glauber de Oliveira Costa <glommer@br.ibm.com> Cc: "Stephen C. Tweedie" <sct@redhat.com> Cc: Andreas Dilger <adilger@clusterfs.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] ext3: remove trailing newlines from ext3_warning() callsGlauber de Oliveira Costa
Remove the trailing newlines in calls to ext3_warning(). This function already adds a trailing newline to the end of messages. Signed-off-by: Glauber de Oliveira Costa <glommer@br.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-28[PATCH] ext3: Wrong return value for EXT3_IOC_GROUP_ADDGlauber de Oliveira Costa
This patch corrects the return value for the EXT3_IOC_GROUP_ADD in case it fails due to the presence of multiple resizers at the filesystem. The problem is a little bit more serious than a wrong return value in this case, since the clause err=0 in the exit_journal path will lead to a call to update_backups which in turns causes a NULL pointer dereference. Signed-off-by: Glauber de Oliveira Costa <glommer@br.ibm.com> Cc: "Stephen C. Tweedie" <sct@redhat.com> Cc: Andreas Dilger <adilger@clusterfs.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] Test for sb_getblk return valueGlauber de Oliveira Costa
This patch adds tests for the return value of sb_getblk() in the ext2/3 filesystems. In fs/buffer.c it is stated that the getblk() function never fails. However, it does can return NULL in some situations due to I/O errors, which may lead us to NULL pointer dereferences Signed-off-by: Glauber de Oliveira Costa <glommer@br.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] ext3: EXT3_DEBUG build fixesGlauber de Oliveira Costa
Fix some warnings and a build error when EXT3_DEBUG is enabled. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
