path: root/fs/ext3
2011-08-11ext3: Properly count journal credits for long symlinksEric Sandeen
Commit ae54870a1dc9 ("ext3: Fix lock inversion in ext3_symlink()") recalculated the number of credits needed for a long symlink, in the process of splitting it into two transactions. However, the first credit calculation under-counted because if selinux is enabled, credits are needed to create the selinux xattr as well. Overrunning the reservation will result in an OOPS in journal_dirty_metadata() due to this assert: J_ASSERT_JH(jh, handle->h_buffer_credits > 0); Fix this by increasing the reservation size. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Jan Kara <jack@suse.cz> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-01switch posix_acl_equiv_mode() to umode_t *Al Viro
... so that &inode->i_mode could be passed to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-08-01switch posix_acl_create() to umode_t *Al Viro
so we can pass &inode->i_mode to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-26Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: jbd: change the field "b_cow_tid" of struct journal_head from type unsigned to tid_t ext3.txt: update the links in the section "useful links" to the latest ones ext3: Fix data corruption in inodes with journalled data ext2: check xattr name_len before acquiring xattr_sem in ext2_xattr_get ext3: Fix compilation with -DDX_DEBUG quota: Remove unused declaration jbd: Use WRITE_SYNC in journal checkpoint. jbd: Fix oops in journal_remove_journal_head() ext3: Return -EINVAL when start is beyond the end of fs in ext3_trim_fs() ext3/ioctl.c: silence sparse warnings about different address spaces ext3/ext4 Documentation: remove bh/nobh since it has been deprecated ext3: Improve truncate error handling ext3: use proper little-endian bitops ext2: include fs.h into ext2_fs.h ext3: Fix oops in ext3_try_to_allocate_with_rsv() jbd: fix a bug of leaking jh->b_jcount jbd: remove dependency on __GFP_NOFAIL ext3: Convert ext3 to new truncate calling convention jbd: Add fixed tracepoints ext3: Add fixed tracepoints Resolve conflicts in fs/ext3/fsync.c due to fsync locking push-down and new fixed tracepoints.
2011-07-25fs: take the ACL checks to common codeChristoph Hellwig
Replace the ->check_acl method with a ->get_acl method that simply reads an ACL from disk after having a cache miss. This means we can replace the ACL checking boilerplate code with a single implementation in namei.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplates around posix_acl_create_masq()Al Viro
new helper: posix_acl_create(&acl, gfp, mode_p). Replaces acl with modified clone, on failure releases acl and replaces with NULL. Returns 0 or -ve on error. All callers of posix_acl_create_masq() switched. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplate around posix_acl_chmod_masq()Al Viro
new helper: posix_acl_chmod(&acl, gfp, mode). Replaces acl with modified clone or with NULL if that has failed; returns 0 or -ve on error. All callers of posix_acl_chmod_masq() switched to that - they'd been doing exactly the same thing. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25vfs: move ACL cache lookup into generic codeLinus Torvalds
This moves logic for checking the cached ACL values from low-level filesystems into generic code. The end result is a streamlined ACL check that doesn't need to load the inode->i_op->check_acl pointer at all for the common cached case. The filesystems also don't need to check for a non-blocking RCU walk case in their acl_check() functions, because that is all handled at a VFS layer. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-23ext3: Fix data corruption in inodes with journalled dataJan Kara
When journalling data for an inode (either because it is a symlink or because the filesystem is mounted in data=journal mode), ext3_evict_inode() can discard unwritten data by calling truncate_inode_pages(). This is because we don't mark the buffer / page dirty when journalling data but only add the buffer to the running transaction and thus mm does not know there are still unwritten data. Fix the problem by carefully tracking transaction containing inode's data, committing this transaction, and writing uncheckpointed buffers when inode should be reaped. Signed-off-by: Jan Kara <jack@suse.cz>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20ext3: make ext3 mount default to barrier=1Christoph Hellwig
This patch turns on barriers by default for ext3. mount -o barrier=0 will turn them off. Based on a patch from Chris Mason in the SuSE tree. Signed-off-by: Chris Mason <chris.mason@oracle.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Eric Sandeen <sandeen@redhat.com> Acked-by: Jan Kara <jack@suse.cz> Acked-by: Jeff Mahoney <jeffm@suse.com> Acked-by: Ted Ts'o <tytso@mit.edu> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: simplify the blockdev_direct_IO prototypeChristoph Hellwig
Simple filesystems always pass inode->i_sb_bdev as the block device argument, and never need a end_io handler. Let's simply things for them and for my grepping activity by dropping these arguments. The only thing not falling into that scheme is ext4, which passes and end_io handler without needing special flags (yet), but given how messy the direct I/O code there is use of __blockdev_direct_IO in one instead of two out of three cases isn't going to make a large difference anyway. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: move inode_dio_wait calls into ->setattrChristoph Hellwig
Let filesystems handle waiting for direct I/O requests themselves instead of doing it beforehand. This means filesystem-specific locks to prevent new dio referenes from appearing can be held. This is important to allow generalizing i_dio_count to non-DIO_LOCKING filesystems. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20ext3: Fix compilation with -DDX_DEBUGBernd Schubert
Compilation of ext3/namei.c brought up an error and warning messages when compiled with -DDX_DEBUG. Signed-off-by: Bernd Schubert<bernd.schubert@itwm.fraunhofer.de> Signed-off-by: Jan Kara <jack@suse.cz>
2011-07-20make d_splice_alias(ERR_PTR(err), dentry) = ERR_PTR(err)Al Viro
... and simplify the living hell out of callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to ->check_acl()Al Viro
not used in the instances anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: pass MAY_NOT_BLOCK to ->check_acl()Al Viro
2011-06-25ext3: Return -EINVAL when start is beyond the end of fs in ext3_trim_fs()Lukas Czerner
We should return -EINVAL when the FITRIM parameters are not sane, but currently we are exiting silently if start is beyond the end of the file system. This commit fixes this so we return -EINVAL as other file systems do. Signed-off-by: Lukas Czerner <lczerner@redhat.com> CC: Jan Kara <jack@suse.cz> Signed-off-by: Jan Kara <jack@suse.cz>
2011-06-25ext3/ioctl.c: silence sparse warnings about different address spacesH Hartley Sweeten
The 'from' argument for copy_from_user and the 'to' argument for copy_to_user should both be tagged as __user address space. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Signed-off-by: Jan Kara <jack@suse.cz>
2011-06-25ext3: Improve truncate error handlingJan Kara
New truncate calling convention allows us to handle errors from ext3_block_truncate_page(). So reorganize the code so that ext3_block_truncate_page() is called before we change inode size. This also removes unnecessary block zeroing from error recovery after failed buffered writes (zeroing isn't needed because we could have never written non-zero data to disk). We have to be careful and keep zeroing in direct IO write error recovery because there we might have already overwritten end of the last file block. Signed-off-by: Jan Kara <jack@suse.cz>
2011-06-25ext3: Fix oops in ext3_try_to_allocate_with_rsv()Jan Kara
Block allocation is called from two places: ext3_get_blocks_handle() and ext3_xattr_block_set(). These two callers are not necessarily synchronized because xattr code holds only xattr_sem and i_mutex, and ext3_get_blocks_handle() may hold only truncate_mutex when called from writepage() path. Block reservation code does not expect two concurrent allocations to happen to the same inode and thus assertions can be triggered or reservation structure corruption can occur. Fix the problem by taking truncate_mutex in xattr code to serialize allocations. CC: Sage Weil <sage@newdream.net> CC: stable@kernel.org Reported-by: Fyodor Ustinov <ufm@ufm.su> Signed-off-by: Jan Kara <jack@suse.cz>
2011-06-25ext3: Convert ext3 to new truncate calling conventionJan Kara
Mostly trivial conversion. We fix a bug that IS_IMMUTABLE and IS_APPEND files could not be truncated during failed writes as we change the code. In fact the test is not needed at all because both IS_IMMUTABLE and IS_APPEND is tested in upper layers in do_sys_[f]truncate(), may_write(), etc. Signed-off-by: Jan Kara <jack@suse.cz>
2011-06-25ext3: Add fixed tracepointsLukas Czerner
This commit adds fixed tracepoints to the ext3 code. It is based on ext4 tracepoints, however due to the differences of both file systems, there are some tracepoints missing (those for delaloc and for multi-block allocator) and there are some ext3 specific as well (for reservation windows). Here is a list: ext3_free_inode ext3_request_inode ext3_allocate_inode ext3_evict_inode ext3_drop_inode ext3_mark_inode_dirty ext3_write_begin ext3_ordered_write_end ext3_writeback_write_end ext3_journalled_write_end ext3_ordered_writepage ext3_writeback_writepage ext3_journalled_writepage ext3_readpage ext3_releasepage ext3_invalidatepage ext3_discard_blocks ext3_request_blocks ext3_allocate_blocks ext3_free_blocks ext3_sync_file_enter ext3_sync_file_exit ext3_sync_fs ext3_rsv_window_add ext3_discard_reservation ext3_alloc_new_reservation ext3_reserved ext3_forget ext3_read_block_bitmap ext3_direct_IO_enter ext3_direct_IO_exit ext3_unlink_enter ext3_unlink_exit ext3_truncate_enter ext3_truncate_exit ext3_get_blocks_enter ext3_get_blocks_exit ext3_load_inode Signed-off-by: Lukas Czerner <lczerner@redhat.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Jan Kara <jack@suse.cz>
2011-05-27fs: pass exact type of data dirties to ->dirty_inodeChristoph Hellwig
Tell the filesystem if we just updated timestamp (I_DIRTY_SYNC) or anything else, so that the filesystem can track internally if it needs to push out a transaction for fdatasync or not. This is just the prototype change with no user for it yet. I plan to push large XFS changes for the next merge window, and getting this trivial infrastructure in this window would help a lot to avoid tree interdependencies. Also remove incorrect comments that ->dirty_inode can't block. That has been changed a long time ago, and many implementations rely on it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem: xen: cleancache shim to Xen Transcendent Memory ocfs2: add cleancache support ext4: add cleancache support btrfs: add cleancache support ext3: add cleancache support mm/fs: add hooks to support cleancache mm: cleancache core ops functions and config fs: add field to superblock to support cleancache mm/fs: cleancache documentation Fix up trivial conflict in fs/btrfs/extent_io.c due to includes
2011-05-26ext3: add cleancache supportDan Magenheimer
This fifth patch of eight in this cleancache series "opts-in" cleancache for ext3. Filesystems must explicitly enable cleancache by calling cleancache_init_fs anytime an instance of the filesystem is mounted. For ext3, all other cleancache hooks are in the VFS layer including the matching cleancache_flush_fs hook which must be called on unmount. Details and a FAQ can be found in Documentation/vm/cleancache.txt [v6-v8: no changes] [v5: jeremy@goop.org: simplify init hook and any future fs init changes] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Andreas Dilger <adilger@sun.com> Cc: Ted Ts'o <tytso@mit.edu> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik Van Riel <riel@redhat.com> Cc: Jan Beulich <JBeulich@novell.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Nitin Gupta <ngupta@vflare.org>
2011-05-17ext3: Fix fs corruption when make_indexed_dir() failsJan Kara
When make_indexed_dir() fails (e.g. because of ENOSPC) after it has allocated block for index tree root, we did not properly mark all changed buffers dirty. This lead to only some of these buffers being written out and thus effectively corrupting the directory. Fix the issue by marking all changed data dirty even in the error failure case. CC: stable@kernel.org Signed-off-by: Jan Kara <jack@suse.cz>
2011-04-29ext3: Fix lock inversion in ext3_symlink()Jan Kara
ext3_symlink() cannot call __page_symlink() with transaction open. __page_symlink() calls ext3_write_begin() which gets page lock which ranks above transaction start (thus lock ordering is violated) and and also ext3_write_begin() waits for a transaction commit when we run out of space which never happens if we hold transaction open. Fix the problem by stopping a transaction before calling __page_symlink() (we have to be careful and put inode to orphan list so that it gets deleted in case of crash) and starting another one after __page_symlink() returns for addition of symlink into a directory. Signed-off-by: Jan Kara <jack@suse.cz>
2011-04-08Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: quota: Don't write quota info in dquot_commit() ext3: Fix writepage credits computation for ordered mode
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-24ext3: Fix writepage credits computation for ordered modeYongqiang Yang
Original computation forgets to count writes of indirect block themselves (it only counts with blocks necessary for their allocation) in ordered mode. Acked-by: Amir Goldstein <amir73il@users.sf.net> Signed-off-by:Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-03-23userns: rename is_owner_or_cap to inode_owner_or_capableSerge E. Hallyn
And give it a kernel-doc comment. [akpm@linux-foundation.org: btrfs changed in linux-next] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-17Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: ext3: Always set dx_node's fake_dirent explicitly. ext3: Fix an overflow in ext3_trim_fs. jbd: Remove one to many n's in a word. ext3: skip orphan cleanup on rocompat fs ext2: Fix link count corruption under heavy link+rename load ext3: speed up group trim with the right free block count. ext3: Adjust trim start with first_data_block. quota: return -ENOMEM when memory allocation fails
2011-03-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (33 commits) AppArmor: kill unused macros in lsm.c AppArmor: cleanup generated files correctly KEYS: Add an iovec version of KEYCTL_INSTANTIATE KEYS: Add a new keyctl op to reject a key with a specified error code KEYS: Add a key type op to permit the key description to be vetted KEYS: Add an RCU payload dereference macro AppArmor: Cleanup make file to remove cruft and make it easier to read SELinux: implement the new sb_remount LSM hook LSM: Pass -o remount options to the LSM SELinux: Compute SID for the newly created socket SELinux: Socket retains creator role and MLS attribute SELinux: Auto-generate security_is_socket_class TOMOYO: Fix memory leak upon file open. Revert "selinux: simplify ioctl checking" selinux: drop unused packet flow permissions selinux: Fix packet forwarding checks on postrouting selinux: Fix wrong checks for selinux_policycap_netpeer selinux: Fix check for xfrm selinux context algorithm ima: remove unnecessary call to ima_must_measure IMA: remove IMA imbalance checking ...
2011-03-15ext3: Copy fs UUID to superblock.Aneesh Kumar K.V
File system UUID is made available to application via /proc/<pid>/mountinfo Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-15fs: Remove i_nlink check from file system link callbackAneesh Kumar K.V
Now that VFS check for inode->i_nlink == 0 and returns proper error, remove similar check from file system Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-08Merge branch 'master' of git://git.infradead.org/users/eparis/selinux into nextJames Morris
2011-03-07ext3: Always set dx_node's fake_dirent explicitly.Eric Sandeen
(crossport of 1f7bebb9e911d870fa8f997ddff838e82b5715ea by Andreas Schlick <schlick@lavabit.com>) When ext3_dx_add_entry() has to split an index node, it has to ensure that name_len of dx_node's fake_dirent is also zero, because otherwise e2fsck won't recognise it as an intermediate htree node and consider the htree to be corrupted. CC: stable@kernel.org Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-03-04ext3: Fix an overflow in ext3_trim_fs.Tao Ma
In a bs=4096 volume, if we call FITRIM with the following parameter as fstrim_range(start = 102400, len = 134144000, minlen = 10240), with the following code: if (len >= EXT3_BLOCKS_PER_GROUP(sb)) len -= (EXT3_BLOCKS_PER_GROUP(sb) - first_block); else last_block = first_block + len; So if len < EXT3_BLOCKS_PER_GROUP while first_block + len > EXT3_BLOCKS_PER_GROUP, last_block will be set to an overflow value which exceeds EXT3_BLOCKS_PER_GROUP. This patch fixes it and adjusts len and last_block accordingly. Cc: Lukas Czerner <lczerner@redhat.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-02-28ext3: skip orphan cleanup on rocompat fsAmir Goldstein
Orphan cleanup is currently executed even if the file system has some number of unknown ROCOMPAT features, which deletes inodes and frees blocks, which could be very bad for some RO_COMPAT features. This patch skips the orphan cleanup if it contains readonly compatible features not known by this ext3 implementation, which would prevent the fs from being mounted (or remounted) readwrite. Signed-off-by: Amir Goldstein <amir73il@users.sf.net> Signed-off-by: Jan Kara <jack@suse.cz>
2011-02-24ext3: speed up group trim with the right free block count.Tao Ma
When we trim some free blocks in a group of ext3, we should calculate the free blocks properly and check whether there are enough freed blocks left for us to trim. Current solution will only calculate free spaces if they are large for a trim which is wrong. Let us see a small example: a group has 1.5M free which are 300k, 300k, 300k, 300k, 300k. And minblocks is 1M. With current solution, we have to iterate the whole group since these 300k will never be subtracted from 1.5M. But actually we should exit after we find the first 2 free spaces since the left 3 chunks only sum up to 900K if we subtract the first 600K although they can't be trimed. Cc: Jan Kara <jack@suse.cz> Cc: Lukas Czerner <lczerner@redhat.com> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-02-24ext3: Adjust trim start with first_data_block.Tao Ma
As we have make the consense in the e-mail[1], the trim start should be added with first_data_block. So this patch fulfill it and remove the check for start < first_data_block. [1] http://www.spinics.net/lists/linux-ext4/msg22737.html Cc: Jan Kara <jack@suse.cz> Cc: Lukas Czerner <lczerner@redhat.com> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-02-01fs/vfs/security: pass last path component to LSM on inode creationEric Paris
SELinux would like to implement a new labeling behavior of newly created inodes. We currently label new inodes based on the parent and the creating process. This new behavior would also take into account the name of the new object when deciding the new label. This is not the (supposed) full path, just the last component of the path. This is very useful because creating /etc/shadow is different than creating /etc/passwd but the kernel hooks are unable to differentiate these operations. We currently require that userspace realize it is doing some difficult operation like that and than userspace jumps through SELinux hoops to get things set up correctly. This patch does not implement new behavior, that is obviously contained in a seperate SELinux patch, but it does pass the needed name down to the correct LSM hook. If no such name exists it is fine to pass NULL. Signed-off-by: Eric Paris <eparis@redhat.com>
2011-01-21Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: quota: Fix deadlock during path resolution
2011-01-13Merge branch 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits) block: ensure that completion error gets properly traced blktrace: add missing probe argument to block_bio_complete block cfq: don't use atomic_t for cfq_group block cfq: don't use atomic_t for cfq_queue block: trace event block fix unassigned field block: add internal hd part table references block: fix accounting bug on cross partition merges kref: add kref_test_and_get bio-integrity: mark kintegrityd_wq highpri and CPU intensive block: make kblockd_workqueue smarter Revert "sd: implement sd_check_events()" block: Clean up exit_io_context() source code. Fix compile warnings due to missing removal of a 'ret' variable fs/block: type signature of major_to_index(int) to major_to_index(unsigned) block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p) cfq-iosched: don't check cfqg in choose_service_tree() fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors cdrom: export cdrom_check_events() sd: implement sd_check_events() sr: implement sr_check_events() ...
2011-01-12quota: Fix deadlock during path resolutionJan Kara
As Al Viro pointed out path resolution during Q_QUOTAON calls to quotactl is prone to deadlocks. We hold s_umount semaphore for reading during the path resolution and resolution itself may need to acquire the semaphore for writing when e. g. autofs mountpoint is passed. Solve the problem by performing the resolution before we get hold of the superblock (and thus s_umount semaphore). The whole thing is complicated by the fact that some filesystems (OCFS2) ignore the path argument. So to distinguish between filesystem which want the path and which do not we introduce new .quota_on_meta callback which does not get the path. OCFS2 then uses this callback instead of old .quota_on. CC: Al Viro <viro@ZenIV.linux.org.uk> CC: Christoph Hellwig <hch@lst.de> CC: Ted Ts'o <tytso@mit.edu> CC: Joel Becker <joel.becker@oracle.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-01-11Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (44 commits) ext4: fix trimming starting with block 0 with small blocksize ext4: revert buggy trim overflow patch ext4: don't pass entire map to check_eofblocks_fl ext4: fix memory leak in ext4_free_branches ext4: remove ext4_mb_return_to_preallocation() ext4: flush the i_completed_io_list during ext4_truncate ext4: add error checking to calls to ext4_handle_dirty_metadata() ext4: fix trimming of a single group ext4: fix uninitialized variable in ext4_register_li_request ext4: dynamically allocate the jbd2_inode in ext4_inode_info as necessary ext4: drop i_state_flags on architectures with 64-bit longs ext4: reorder ext4_inode_info structure elements to remove unneeded padding ext4: drop ec_type from the ext4_ext_cache structure ext4: use ext4_lblk_t instead of sector_t for logical blocks ext4: replace i_delalloc_reserved_flag with EXT4_STATE_DELALLOC_RESERVED ext4: fix 32bit overflow in ext4_ext_find_goal() ext4: add more error checks to ext4_mkdir() ext4: ext4_ext_migrate should use NULL not 0 ext4: Use ext4_error_file() to print the pathname to the corrupted inode ext4: use IS_ERR() to check for errors in ext4_error_file ...
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: ext2: Resolve 'dereferencing pointer to incomplete type' when enabling EXT2_XATTR_DEBUG ext3: Remove redundant unlikely() ext2: Remove redundant unlikely() ext3: speed up file creates by optimizing rec_len functions ext2: speed up file creates by optimizing rec_len functions ext3: Add more journal error check ext3: Add journal error check in resize.c quota: Use %pV and __attribute__((format (printf in __quota_error and fix fallout ext3: Add FITRIM handling ext3: Add batched discard support for ext3 ext3: Add journal error check into ext3_rename() ext3: Use search_dirblock() in ext3_dx_find_entry() ext3: Avoid uninitialized memory references with a corrupted htree directory ext3: Return error code from generic_check_addressable ext3: Add journal error check into ext3_delete_entry() ext3: Add error check in ext3_mkdir() fs/ext3/super.c: Use printf extension %pV fs/ext2/super.c: Use printf extension %pV ext3: don't update sb journal_devnum when RO dev
