path: root/fs/ext4/Makefile
2011-06-27ext4: move ext4_ind_* functions from inode.c to indirect.cAmir Goldstein
This patch moves functions from inode.c to indirect.c. The moved functions are ext4_ind_* functions and their helpers. Functions called from inode.c are declared extern. Signed-off-by: Amir Goldstein <amir73il@users.sf.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-24ext4: add support for multiple mount protectionJohann Lombardi
Prevent an ext4 filesystem from being mounted multiple times. A sequence number is stored on disk and is periodically updated (every 5 seconds by default) by a mounted filesystem. At mount time, we now wait for s_mmp_update_interval seconds to make sure that the MMP sequence does not change. In case of failure, the nodename, bdevname and the time at which the MMP block was last updated is displayed. Signed-off-by: Andreas Dilger <adilger@whamcloud.com> Signed-off-by: Johann Lombardi <johann@whamcloud.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: use bio layer instead of buffer layer in mpage_da_submit_ioTheodore Ts'o
Call the block I/O layer directly instad of going through the buffer layer. This should give us much better performance and scalability, as well as lowering our CPU utilization when doing buffered writeback. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-06-17ext4: online defrag -- Add EXT4_IOC_MOVE_EXT ioctlAkira Fujita
The EXT4_IOC_MOVE_EXT exchanges the blocks between orig_fd and donor_fd, and then write the file data of orig_fd to donor_fd. ext4_mext_move_extent() is the main fucntion of ext4 online defrag, and this patch includes all functions related to ext4 online defrag. Signed-off-by: Akira Fujita <a-fujita@rs.jp.nec.com> Signed-off-by: Takashi Sato <t-sato@yk.jp.nec.com> Signed-off-by: Kazuya Mio <k-mio@sx.jp.nec.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-05-17ext4: Add a comprehensive block validity check to ext4_get_blocks()Theodore Ts'o
To catch filesystem bugs or corruption which could lead to the filesystem getting severly damaged, this patch adds a facility for tracking all of the filesystem metadata blocks by contiguous regions in a red-black tree. This allows quick searching of the tree to locate extents which might overlap with filesystem metadata blocks. This facility is also used by the multi-block allocator to assure that it is not allocating blocks out of the system zone, as well as by the routines used when reading indirect blocks and extents information from disk to make sure their contents are valid. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-10-10ext4: Rename ext4dev to ext4Theodore Ts'o
The ext4 filesystem is getting stable enough that it's time to drop the "dev" prefix. Also remove the requirement for the TEST_FILESYS flag. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-01-29ext4: Add multi block allocator for ext4Alex Tomas
Signed-off-by: Alex Tomas <alex@clusterfs.com> Signed-off-by: Andreas Dilger <adilger@clusterfs.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-01-28ext4: Add EXT4_IOC_MIGRATE ioctlAneesh Kumar K.V
The below patch add ioctl for migrating ext3 indirect block mapped inode to ext4 extent mapped inode. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2006-12-07[PATCH] ext4: uninline large functionsAndrew Morton
Saves nearly 4kbytes on x86. Cc: Arnaldo Carvalho de Melo <acme@mandriva.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext3: add extent map supportAlex Tomas
On disk extents format: /* * this is extent on-disk structure * it's used at the bottom of the tree */ struct ext3_extent { __le32 ee_block; /* first logical block extent covers */ __le16 ee_len; /* number of blocks covered by extent */ __le16 ee_start_hi; /* high 16 bits of physical block */ __le32 ee_start; /* low 32 bigs of physical block */ }; Signed-off-by: Alex Tomas <alex@clusterfs.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: rename ext4 symbols to avoid duplication of ext3 symbolsMingming Cao
Mingming Cao originally did this work, and Shaggy reproduced it using some scripts from her. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: initial copy of files from ext3Dave Kleikamp
Start of the ext4 patch series. See Documentation/filesystems/ext4.txt for details. This is a simple copy of the files in fs/ext3 to fs/ext4 and /usr/incude/linux/ext3* to /usr/include/ex4* Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
