path: root/fs/ext4/balloc.c
2011-06-28ext4: refactor duplicated block placement codeEric Sandeen
I found that ext4_ext_find_goal() and ext4_find_near() share the same code for returning a coloured start block based on i_block_group. We can refactor this into a common function so that they don't diverge in the future. Thanks to adilger for suggesting the new function name. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-25ext4: add flag to ext4_has_free_blocksAllison Henderson
This patch adds an allocation request flag to the ext4_has_free_blocks function which enables the use of reserved blocks. This will allow a punch hole to proceed even if the disk is full. Punching a hole may require additional blocks to first split the extents. Because ext4_has_free_blocks is a low level function, the flag needs to be passed down through several functions listed below: ext4_ext_insert_extent ext4_ext_create_new_leaf ext4_ext_grow_indepth ext4_ext_split ext4_ext_new_meta_block ext4_mb_new_blocks ext4_claim_free_blocks ext4_has_free_blocks [ext4 punch hole patch series 1/5 v7] Signed-off-by: Allison Henderson <achender@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Mingming Cao <cmm@us.ibm.com>
2011-05-09ext4: move ext4_add_groupblocks() to mballoc.cAmir Goldstein
In preparation for the next patch, the function ext4_add_groupblocks() is moved to mballoc.c, where it could use some static functions. Signed-off-by: Amir Goldstein <amir73il@users.sf.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-01ext4: remove dead code in ext4_has_free_blocks()Shaohua Li
percpu_counter_sum_positive() never returns a negative value. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-03-21ext4: add more tracepoints and use dev_t in the trace bufferJiaying Zhang
- Add more ext4 tracepoints. - Change ext4 tracepoints to use dev_t field with MAJOR/MINOR macros so that we can save 4 bytes in the ring buffer on some platforms. - Add sync_mode to ext4_da_writepages, ext4_da_write_pages, and ext4_da_writepages_result tracepoints. Also remove for_reclaim field from ext4_da_writepages since it is usually not very useful. Signed-off-by: Jiaying Zhang <jiayingz@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext4: replace i_delalloc_reserved_flag with EXT4_STATE_DELALLOC_RESERVEDTheodore Ts'o
Remove the short element i_delalloc_reserved_flag from the ext4_inode_info structure and replace it a new bit in i_state_flags. Since we have an ext4_inode_info for every ext4 inode cached in the inode cache, any savings we can produce here is a very good thing from a memory utilization perspective. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: rename mark_bitmap_end() to ext4_mark_bitmap_end()Theodore Ts'o
Fix a namespace leak from fs/ext4 Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27ext4: make various ext4 functions be staticTheodore Ts'o
These functions have no need to be exported beyond file context. No functions needed to be moved for this commit; just some function declarations changed to be static and removed from header files. (A similar patch was submitted by Eric Sandeen, but I wanted to handle code movement in separate patches to make sure code changes didn't accidentally get dropped.) Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-06-11ext4: Clean up s_dirt handlingTheodore Ts'o
We don't need to set s_dirt in most of the ext4 code when journaling is enabled. In ext3/4 some of the summary statistics for # of free inodes, blocks, and directories are calculated from the per-block group statistics when the file system is mounted or unmounted. As a result the superblock doesn't have to be updated, either via the journal or by setting s_dirt. There are a few exceptions, most notably when resizing the file system, where the superblock needs to be modified --- and in that case it should be done as a journalled operation if possible, and s_dirt set only in no-journal mode. This patch will optimize out some unneeded disk writes when using ext4 with a journal. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-05-16ext4: don't use quota reservation for speculative metadataEric Sandeen
Because we can badly over-reserve metadata when we calculate worst-case, it complicates things for quota, since we must reserve and then claim later, retry on EDQUOT, etc. Quota is also a generally smaller pool than fs free blocks, so this over-reservation hurts more, and more often. I'm of the opinion that it's not the worst thing to allow metadata to push a user slightly over quota. This simplifies the code and avoids the false quota rejections that result from worst-case speculation. This patch stops the speculative quota-charging for worst-case metadata requirements, and just charges quota when the blocks are allocated at writeout. It also is able to remove the try-again loop on EDQUOT. This patch has been tested indirectly by running the xfstests suite with a hack to mount & enable quota prior to the test. I also did a more specific test of fragmenting freespace and then doing a large delalloc write under quota; quota stopped me at the right amount of file IO, and then the writeout generated enough metadata (due to the fragmentation) that it put me slightly over quota, as expected. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-03-03ext4: consolidate in_range() definitionsAkinobu Mita
There are duplicate macro definitions of in_range() in mballoc.h and balloc.c. This consolidates these two definitions into ext4.h, and changes extents.c to use in_range() as well. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger@sun.com>
2010-03-03ext4: cleanup to use ext4_group_first_block_no()Akinobu Mita
This is a cleanup and simplification patch which takes some open-coded calculations to calculate the first block number of a group and converts them to use the (already defined) ext4_group_first_block_no() function. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger@sun.com>
2010-02-15ext4: move __func__ into a macro for ext4_warning, ext4_errorEric Sandeen
Just a pet peeve of mine; we had a mishash of calls with either __func__ or "function_name" and the latter tends to get out of sync. I think it's easier to just hide the __func__ in a macro, and it'll be consistent from then on. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-11-22ext4: fold ext4_free_blocks() and ext4_mb_free_blocks()Theodore Ts'o
ext4_mb_free_blocks() is only called by ext4_free_blocks(), and the latter function doesn't really do much. So merge the two functions together, such that ext4_free_blocks() is now found in fs/ext4/mballoc.c. This saves about 200 bytes of compiled text space. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-11-23ext4: fix uninit block bitmap initialization when s_meta_first_bg is non-zeroTheodore Ts'o
The number of old-style block group descriptor blocks is s_meta_first_bg when the meta_bg feature flag is set. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2009-08-17ext4: open-code ext4_mb_update_group_infoEric Sandeen
ext4_mb_update_group_info is only called in one place, and it's extremely simple. There's no reason to have it in a separate function in a separate file as far as I can tell, it just obfuscates what's really going on. Perhaps it was intended to keep the grp->bb_* manipulation local to mballoc.c but we're already accessing other grp-> fields in balloc.c directly so this seems ok. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-05-02ext4: Convert ext4_lock_group to use sb_bgl_lockAneesh Kumar K.V
We have sb_bgl_lock() and ext4_group_info.bb_state bit spinlock to protech group information. The later is only used within mballoc code. Consolidate them to use sb_bgl_lock(). This makes the mballoc.c code much simpler and also avoid confusion with two locks protecting same info. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-05-01ext4: Move fs/ext4/group.h into ext4.hTheodore Ts'o
Move the function prototypes in group.h into ext4.h so they are all defined in one place. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-05-01ext4: Avoid races caused by on-line resizing and SMP memory reorderingTheodore Ts'o
Ext4's on-line resizing adds a new block group and then, only at the last step adjusts s_groups_count. However, it's possible on SMP systems that another CPU could see the updated the s_group_count and not see the newly initialized data structures for the just-added block group. For this reason, it's important to insert a SMP read barrier after reading s_groups_count and before reading any (for example) the new block group descriptors allowed by the increased value of s_groups_count. Unfortunately, we rather blatently violate this locking protocol documented in fs/ext4/resize.c. Fortunately, (1) on-line resizes happen relatively rarely, and (2) it seems rare that the filesystem code will immediately try to use just-added block group before any memory ordering issues resolve themselves. So apparently problems here are relatively hard to hit, since ext3 has been vulnerable to the same issue for years with no one apparently complaining. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-03-04ext4: Use atomic_t's in struct flex_groupsTheodore Ts'o
Reduce pressure on the sb_bgl_lock family of locks by using atomic_t's to track the number of free blocks and inodes in each flex_group. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-02-06ext4: remove call to ext4_group_desc() in ext4_group_used_meta_blocks()Theodore Ts'o
The static function ext4_group_used_meta_blocks() only has one caller, who already has access to the block group's group descriptor. So it's better to have ext4_init_block_bitmap() pass the group descriptor to ext4_group_used_meta_blocks(), so it doesn't need to call ext4_group_desc(). Previously this function did not check if ext4_group_desc() returned NULL due to an error, potentially causing a kernel OOPS report. This avoids the issue entirely. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-03-26ext4: Use lowercase names of quota functionsJan Kara
Use lowercase names of quota functions instead of old uppercase ones. Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Mingming Cao <cmm@us.ibm.com> CC: linux-ext4@vger.kernel.org
2009-02-26ext4: don't call jbd2_journal_force_commit_nested without journalEric Sandeen
Running without a journal, I oopsed when I ran out of space, because we called jbd2_journal_force_commit_nested() from ext4_should_retry_alloc() without a journal. This should take care of it, I think. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-01-26ext4: Fix building with EXT4FS_DEBUGThadeu Lima de Souza Cascardo
When bg_free_blocks_count was renamed to bg_free_blocks_count_lo in 560671a0, its uses under EXT4FS_DEBUG were not changed to the helper ext4_free_blks_count. Another commit, 498e5f24, also did not change everything needed under EXT4FS_DEBUG, thus making it spill some warnings related to printing format. This commit fixes both issues and makes ext4 build again when EXT4FS_DEBUG is enabled. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-01-05ext4: Use new buffer_head flag to check uninit group bitmaps initializationAneesh Kumar K.V
For uninit block group, the on-disk bitmap is not initialized. That implies we cannot depend on the uptodate flag on the bitmap buffer_head to find bitmap validity. Use a new buffer_head flag which would be set after we properly initialize the bitmap. This also prevents (re-)initializing the uninit group bitmap every time we call ext4_read_block_bitmap(). Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2009-01-03ext4: code cleanupAneesh Kumar K.V
Rename some variables. We also unlock locks in the reverse order we acquired as a part of cleanup. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-01-05ext4: Use high 16 bits of the block group descriptor's free counts fieldsAneesh Kumar K.V
Rename the lower bits with suffix _lo and add helper to access the values. Also rename bg_itable_unused_hi to bg_pad as in e2fsprogs. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-01-05ext4: Use EXT4_GROUP_INFO_NEED_INIT_BIT during resizeAneesh Kumar K.V
The new groups added during resize are flagged as need_init group. Make sure we properly initialize these groups. When we have block size < page size and we are adding new groups the page may still be marked uptodate even though we haven't initialized the group. While forcing the init of buddy cache we need to make sure other groups part of the same page of buddy cache is not using the cache. group_info->alloc_sem is added to ensure the same. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> cc: stable@kernel.org
2009-01-05ext4: Add blocks added during resize to bitmapAneesh Kumar K.V
With this change new blocks added during resize are marked as free in the block bitmap and the group is flagged with EXT4_GROUP_INFO_NEED_INIT_BIT flag. This makes sure when mballoc tries to allocate blocks from the new group we would reload the buddy information using the bitmap present in the disk. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2008-11-05ext4: Change unsigned long to unsigned intTheodore Ts'o
Convert the unsigned longs that are most responsible for bloating the stack usage on 64-bit systems. Nearly all places in the ext3/4 code which uses "unsigned long" is probably a bug, since on 32-bit systems a ulong a 32-bits, which means we are wasting stack space on 64-bit systems. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-01-05ext4: Make ext4_group_t be an unsigned intTheodore Ts'o
2009-01-05ext4: remove extraneous newlines from calls to ext4_error() and ext4_warning()Theodore Ts'o
This removes annoying blank syslog entries emitted by ext4_error() or ext4_warning(), since these functions add their own newline. Signed-off-by: Nick Warne <nick@ukfsn.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-01-07ext4: Allow ext4 to run without a journalFrank Mayhar
A few weeks ago I posted a patch for discussion that allowed ext4 to run without a journal. Since that time I've integrated the excellent comments from Andreas and fixed several serious bugs. We're currently running with this patch and generating some performance numbers against both ext2 (with backported reservations code) and ext4 with and without a journal. It just so happens that running without a journal is slightly faster for most everything. We did iozone -T -t 4 s 2g -r 256k -T -I -i0 -i1 -i2 which creates 4 threads, each of which create and do reads and writes on a 2G file, with a buffer size of 256K, using O_DIRECT for all file opens to bypass the page cache. Results: ext2 ext4, default ext4, no journal initial writes 13.0 MB/s 15.4 MB/s 15.7 MB/s rewrites 13.1 MB/s 15.6 MB/s 15.9 MB/s reads 15.2 MB/s 16.9 MB/s 17.2 MB/s re-reads 15.3 MB/s 16.9 MB/s 17.2 MB/s random readers 5.6 MB/s 5.6 MB/s 5.7 MB/s random writers 5.1 MB/s 5.3 MB/s 5.4 MB/s So it seems that, so far, this was a useful exercise. Signed-off-by: Frank Mayhar <fmayhar@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-12-12ext4: remove do_blk_alloc()Theodore Ts'o
The convenience function do_blk_alloc() is a static function with only one caller, so fold it into ext4_new_meta_blocks() to simplify the code and to make it easier to understand. To save more stack space, if count is a null pointer in ext4_new_meta_blocks() assume that caller wanted a single block (and if there is an error, no blocks were allocated). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-12-07ext4: remove ext4_new_meta_block()Theodore Ts'o
There were only two one callers of the function ext4_new_meta_block(), which just a very simpler wrapper function around ext4_new_meta_blocks(). Change those two functions to call ext4_new_meta_blocks() directly, to save code and stack space usage. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-01-01ext4: remove ext4_new_blocks() and call ext4_mb_new_blocks() directlyTheodore Ts'o
There was only one caller of the compatibility function ext4_new_blocks(), in balloc.c's ext4_alloc_blocks(). Change it to call ext4_mb_new_blocks() directly, and remove ext4_new_blocks() altogether. This cleans up the code, by removing two extra functions from the call chain, and hopefully saving some stack usage. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-10-29ext4: fix printk format warningAlexander Beregalov
fs/ext4/balloc.c:607: warning: format '%lld' expects type 'long long int', but argument 2 has type 's64' fs/ext4/inode.c:1822: warning: format '%lld' expects type 'long long int', but argument 2 has type 's64' fs/ext4/inode.c:1824: warning: format '%lld' expects type 'long long int', but argument 2 has type 's64' Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2008-12-25Merge branch 'next' into for-linusJames Morris
2008-12-10revert "percpu_counter: new function percpu_counter_sum_and_set"Andrew Morton
Revert commit e8ced39d5e8911c662d4d69a342b9d053eaaac4e Author: Mingming Cao <cmm@us.ibm.com> Date: Fri Jul 11 19:27:31 2008 -0400 percpu_counter: new function percpu_counter_sum_and_set As described in revert "percpu counter: clean up percpu_counter_sum_and_set()" the new percpu_counter_sum_and_set() is racy against updates to the cpu-local accumulators on other CPUs. Revert that change. This means that ext4 will be slow again. But correct. Reported-by: Eric Dumazet <dada1@cosmosbay.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mingming Cao <cmm@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Cc: <stable@kernel.org> [2.6.27.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-10revert "percpu counter: clean up percpu_counter_sum_and_set()"Andrew Morton
Revert commit 1f7c14c62ce63805f9574664a6c6de3633d4a354 Author: Mingming Cao <cmm@us.ibm.com> Date: Thu Oct 9 12:50:59 2008 -0400 percpu counter: clean up percpu_counter_sum_and_set() Before this patch we had the following: percpu_counter_sum(): return the percpu_counter's value percpu_counter_sum_and_set(): return the percpu_counter's value, copying that value into the central value and zeroing the per-cpu counters before returning. After this patch, percpu_counter_sum_and_set() has gone, and percpu_counter_sum() gets the old percpu_counter_sum_and_set() functionality. Problem is, as Eric points out, the old percpu_counter_sum_and_set() functionality was racy and wrong. It zeroes out counters on "other" cpus, without holding any locks which will prevent races agaist updates from those other CPUS. This patch reverts 1f7c14c62ce63805f9574664a6c6de3633d4a354. This means that percpu_counter_sum_and_set() still has the race, but percpu_counter_sum() does not. Note that this is not a simple revert - ext4 has since started using percpu_counter_sum() for its dirty_blocks counter as well. Note that this revert patch changes percpu_counter_sum() semantics. Before the patch, a call to percpu_counter_sum() will bring the counter's central counter mostly up-to-date, so a following percpu_counter_read() will return a close value. After this patch, a call to percpu_counter_sum() will leave the counter's central accumulator unaltered, so a subsequent call to percpu_counter_read() can now return a significantly inaccurate result. If there is any code in the tree which was introduced after e8ced39d5e8911c662d4d69a342b9d053eaaac4e was merged, and which depends upon the new percpu_counter_sum() semantics, that code will break. Reported-by: Eric Dumazet <dada1@cosmosbay.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mingming Cao <cmm@us.ibm.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-14CRED: Wrap task credential accesses in the Ext4 filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Stephen Tweedie <sct@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: adilger@sun.com Cc: linux-ext4@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2008-10-28delay capable() check in ext4_has_free_blocks()Eric Sandeen
As reported by Eric Paris, the capable() check in ext4_has_free_blocks() sometimes causes SELinux denials. We can rearrange the logic so that we only try to use the root-reserved blocks when necessary, and even then we can move the capable() test to last, to avoid the check most of the time. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-10-28merge ext4_claim_free_blocks & ext4_has_free_blocksEric Sandeen
Mingming pointed out that ext4_claim_free_blocks & ext4_has_free_blocks are largely cut & pasted; they can be collapsed/merged as follows. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-10-10ext4: Don't reuse released data blocks until transaction commitsAneesh Kumar K.V
We need to make sure we don't reuse the data blocks released during the transaction untill the transaction commits. We force this mode only for ordered and journalled mode. Writeback mode already don't provided data consistency. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2008-10-10ext4: fix initialization of UNINIT bitmap blocksFrederic Bohe
This fixes a bug which caused on-line resizing of filesystems with a 1k blocksize to fail. The root cause of this bug was the fact that if an uninitalized bitmap block gets read in by userspace (which e2fsprogs does try to avoid, but can happen when the blocksize is less than the pagesize and an adjacent blocks is read into memory) ext4_read_block_bitmap() was erroneously depending on the buffer uptodate flag to decide whether it needed to initialize the bitmap block in memory --- i.e., to set the standard set of blocks in use by a block group (superblock, bitmaps, inode table, etc.). Essentially, ext4_read_block_bitmap() assumed it was the only routine that might try to read a block containing a block bitmap, which is simply not true. To fix this, ext4_read_block_bitmap() and ext4_read_inode_bitmap() must always initialize uninitialized bitmap blocks. Once a block or inode is allocated out of that bitmap, it will be marked as initialized in the block group descriptor, so in general this won't result any extra unnecessary work. Signed-off-by: Frederic Bohe <frederic.bohe@bull.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-10-10ext4: Remove old legacy block allocatorTheodore Ts'o
2008-09-08ext4: Don't add the inode to journal handle until after the block is allocatedAneesh Kumar K.V
Make sure we don't add the inode to the journal handle until after the block allocation, so that a journal commit will not include the inode in case of block allocation failure. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-09-08ext4: Fix ext4 nomballoc allocator for ENOSPCAneesh Kumar K.V
We run into ENOSPC error on nonmballoc ext4, even when there is free blocks on the filesystem. The patch includes two changes: a) Set reservation to NULL if we trying to allocate near group_target_block from the goal group if the free block in the group is less than windows. This should give us a better chance to allocate near group_target_block. This also ensures that if we are not allocating near group_target_block then we don't trun off reservation. This should enable us to allocate with reservation from other groups that have large free blocks count. b) we don't need to check the window size if the block reservation is off. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-10-08ext4: Signed arithmetic fixAneesh Kumar K.V
This patch converts some usage of ext4_fsblk_t to s64. This is needed so that some of the sign conversion works as expected in if loops. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
