commit e3d550c2c4f2f3dba469bc3c4b83d9332b4e99e1 upstream.
Really enable warning when CONFIG_EXT4_DEBUG is set and fix missing
first argument. This was introduced in commit ff95ec22cd7f ("ext4:
add warning to ext4_convert_unwritten_extents_endio") and splitting
extents inside endio would trigger it.
Fixes: ff95ec22cd7f ("ext4: add warning to ext4_convert_unwritten_extents_endio")
Signed-off-by: Rakesh Pandit <rakesh@tuxera.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Cc: stable@kernel.org
commit 592acbf16821288ecdc4192c47e3774a4c48bb64 upstream.
This commit zeroes out the unused memory region in the buffer_head
corresponding to the extent metablock after writing the extent header
and the corresponding extent node entries.
This is done to prevent random uninitialized data from getting into
the filesystem when the extent block is synced.
This fixes CVE-2019-11833.
Signed-off-by: Sriram Rajagopalan <sriramr@arista.com>
commit bc890a60247171294acc0bd67d211fa4b88d40ba upstream.
If there is a corupted file system where the claimed depth of the
extent tree is -1, this can cause a massive buffer overrun leading to
sadness.
This addresses CVE-2018-10877.
https://bugzilla.kernel.org/show_bug.cgi?id=199417
commit 349fa7d6e1935f49bf4161c4900711b2989180a9 upstream.
During the "insert range" fallocate operation, extents starting at the
range offset are shifted "right" (to a higher file offset) by the range
length. But, as shown by syzbot, it's not validated that this doesn't
cause extents to be shifted beyond EXT_MAX_BLOCKS. In that case
->ee_block can wrap around, corrupting the extent tree.
Fix it by returning an error if the space between the end of the last
extent and EXT4_MAX_BLOCKS is smaller than the range being inserted.
This bug can be reproduced by running the following commands when the
current directory is on an ext4 filesystem with a 4k block size:
fallocate -l 8192 file
fallocate --keep-size -o 0xfffffffe000 -l 4096 -n file
fallocate --insert-range -l 8192 file
Then after unmounting the filesystem, e2fsck reports corruption.
Reported-by: syzbot+06c885be0edcdaeab40c@syzkaller.appspotmail.com
Fixes: 331573febb6a ("ext4: Add support FALLOC_FL_INSERT_RANGE for fallocate")
Cc: stable@vger.kernel.org # v4.2+
commit c894aa97577e47d3066b27b32499ecf899bfa8b0 upstream.
Currently, fallocate(2) with KEEP_SIZE followed by a fdatasync(2)
then crash, we'll see wrong allocated block number (stat -c %b), the
blocks allocated beyond EOF are all lost. fstests generic/468
exposes this bug.
Commit 67a7d5f561f4 ("ext4: fix fdatasync(2) after extent
manipulation operations") fixed all the other extent manipulation
operation paths such as hole punch, zero range, collapse range etc.,
but forgot the fallocate case.
So similarly, fix it by recording the correct journal tid in ext4
inode in fallocate(2) path, so that ext4_sync_file() will wait for
the right tid to be committed on fdatasync(2).
This addresses the test failure in xfstests test generic/468.
Signed-off-by: Eryu Guan <eguan@redhat.com>
commit 51e3ae81ec58e95f10a98ef3dd6d7bce5d8e35a2 upstream.
If there are pending writes subject to delayed allocation, then i_size
will show size after the writes have completed, while i_disksize
contains the value of i_size on the disk (since the writes have not
been persisted to disk).
If fallocate(2) is called with the FALLOC_FL_KEEP_SIZE flag, either
with or without the FALLOC_FL_ZERO_RANGE flag set, and the new size
after the fallocate(2) is between i_size and i_disksize, then after a
crash, if a journal commit has resulted in the changes made by the
fallocate() call to be persisted after a crash, but the delayed
allocation write has not resolved itself, i_size would not be updated,
and this would cause the following e2fsck complaint:
Inode 12, end of extent exceeds allowed value
(logical block 33, physical block 33441, len 7)
This can only take place on a sparse file, where the fallocate(2) call
is allocating blocks in a range which is before a pending delayed
allocation write which is extending i_size. Since this situation is
quite rare, and the window in which the crash must take place is
typically < 30 seconds, in practice this condition will rarely happen.
Nevertheless, it can be triggered in testing, and in particular by
xfstests generic/456.
Reported-by: Amir Goldstein <amir73il@gmail.com>
This bug was found by a static code checker tool for copy paste
problems.
Signed-off-by: Maninder Singh <maninder1.s@samsung.com>
Signed-off-by: Vaneet Narang <v.narang@samsung.com>
ext4_alloc_file_blocks() does not use its mode parameter. Remove it.
Signed-off-by: Tahsin Erdogan <tahsin@google.com>
ea_inode contents are treated as metadata, that's why it is journaled
during initial writes. Failing to call revoke during freeing could cause
user data to be overwritten with original ea_inode contents during journal
replay.
Currently, extent manipulation operations such as hole punch, range
zeroing, or extent shifting do not record the fact that file data has
changed and thus fdatasync(2) has a work to do. As a result if we crash
e.g. after a punch hole and fdatasync, user can still possibly see the
punched out data after journal replay. Test generic/392 fails due to
these problems.
Fix the problem by properly marking that file data has changed in these
operations.
CC: stable@vger.kernel.org
Fixes: a4bb6b64e39abc0e41ca077725f2a72c868e7622
When ext4_map_blocks() is called with EXT4_GET_BLOCKS_ZERO to zero-out
allocated blocks and these blocks are actually converted from unwritten
extent the following race can happen:
CPU0 CPU1
page fault page fault
ext4_map_blocks()
ext4_ext_map_blocks()
ext4_ext_handle_unwritten_extents()
ext4_ext_convert_to_initialized()
- zero out converted extent
ext4_zeroout_es()
- inserts extent as initialized in status tree
ext4_map_blocks()
ext4_es_lookup_extent()
- finds initialized extent
write data
ext4_issue_zeroout()
- zeroes out new extent overwriting data
This problem can be reproduced by generic/340 for the fallocated case
for the last block in the file.
Fix the problem by avoiding zeroing out the area we are mapping with
ext4_map_blocks() in ext4_ext_convert_to_initialized(). It is pointless
to zero out this area in the first place as the caller asked us to
convert the area to initialized because he is just going to write data
there before the transaction finishes. To achieve this we delete the
special case of zeroing out full extent as that will be handled by the
cases below zeroing only the part of the extent that needs it. We also
instruct ext4_split_extent() that the middle of extent being split
contains data so that ext4_split_extent_at() cannot zero out full extent
in case of ENOSPC.
Fixes: 12735f881952c32b31bc4e433768f18489f79ec9
Inside ext4_ext_shift_extents() function ext4_find_extent() is called
without EXT4_EX_NOCACHE flag, which should prevent cache population.
This leads to oudated offsets in the extents tree and wrong blocks
afterwards.
Patch fixes the problem providing EXT4_EX_NOCACHE flag for each
ext4_find_extents() call inside ext4_ext_shift_extents function.
Fixes: 331573febb6a2
Signed-off-by: Roman Pen <roman.penyaev@profitbricks.com>
Cc: Namjae Jeon <namjae.jeon@samsung.com>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
While doing 'insert range' start block should be also shifted right.
The bug can be easily reproduced by the following test:
ptr = malloc(4096);
assert(ptr);
fd = open("./ext4.file", O_CREAT | O_TRUNC | O_RDWR, 0600);
assert(fd >= 0);
rc = fallocate(fd, 0, 0, 8192);
assert(rc == 0);
for (i = 0; i < 2048; i++)
*((unsigned short *)ptr + i) = 0xbeef;
rc = pwrite(fd, ptr, 4096, 0);
assert(rc == 4096);
rc = pwrite(fd, ptr, 4096, 4096);
assert(rc == 4096);
for (block = 2; block < 1000; block++) {
rc = fallocate(fd, FALLOC_FL_INSERT_RANGE, 4096, 4096);
assert(rc == 0);
*((unsigned short *)ptr + i) = block;
assert(rc == 4096);
Because start block is not included in the range the hole appears at
the wrong offset (just after the desired offset) and the following
pwrite() overwrites already existent block, keeping hole untouched.
Simple way to verify wrong behaviour is to check zeroed blocks after
the test:
$ hexdump ./ext4.file | grep '0000 0000'
The root cause of the bug is a wrong range (start, stop], where start
should be inclusive, i.e. [start, stop].
This patch fixes the problem by including start into the range. But
not to break left shift (range collapse) stop points to the beginning
of the a block, not to the end.
The other not obvious change is an iterator check on validness in a
main loop. Because iterator is unsigned the following corner case
should be considered with care: insert a block at 0 offset, when stop
variables overflows and never becomes less than start, which is 0.
To handle this special case iterator is set to NULL to indicate that
end of the loop is reached.
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
Pull fs meta data unmap optimization from Jens Axboe:
"A series from Jan Kara, providing a more efficient way for unmapping
meta data from in the buffer cache than doing it block-by-block.
Provide a general helper that existing callers can use"
* 'for-4.10/fs-unmap' of git://git.kernel.dk/linux-block:
fs: Remove unmap_underlying_metadata
fs: Add helper to clean bdev aliases under a bh and use it
ext2: Use clean_bdev_aliases() instead of iteration
ext4: Use clean_bdev_aliases() instead of iteration
direct-io: Use clean_bdev_aliases() instead of handmade iteration
fs: Provide function to unmap metadata for a range of blocks
Before commit c3fe493ccdb1 ('ext4: remove unneeded test in
ext4_alloc_file_blocks()') then it was possible for "depth" to be -1
but now, it's not possible that it is negative.
CURRENT_TIME_SEC and CURRENT_TIME are not y2038 safe.
current_time() will be transitioned to be y2038 safe
along with vfs.
current_time() returns timestamps according to the
granularities set in the super_block.
The granularity check in ext4_current_time() to call
current_time() or CURRENT_TIME_SEC is not required.
Use current_time() directly to obtain timestamps
unconditionally, and remove ext4_current_time().
Quota files are assumed to be on the same filesystem.
Hence, use current_time() for these files as well.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Return errors to the caller instead of declaring the file system
corrupted.
Use clean_bdev_aliases() instead of iterating through blocks one by one.
Signed-off-by: Jens Axboe <axboe@fb.com>
Create a macro to calculate length + offset -> maximum blocks
This adds more readability.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
ext4_alloc_file_blocks() is called from ext4_zero_range() and
ext4_fallocate() both already testing EXT4_INODE_EXTENTS
We can call ext_depth(inode) unconditionnally.
[ Added BUG_ON check to make sure ext4_alloc_file_blocks() won't get
called for a indirect-mapped inode in the future. -- tytso ]
Running xfstests generic/013 with kmemleak gives the following:
unreferenced object 0xffff8801d3d27de0 (size 96):
comm "fsstress", pid 4941, jiffies 4294860168 (age 53.485s)
hex dump (first 32 bytes):
00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff818eaaf3>] kmemleak_alloc+0x23/0x40
[<ffffffff81179805>] __kmalloc+0xf5/0x1d0
[<ffffffff8122ef5c>] ext4_find_extent+0x1ec/0x2f0
[<ffffffff8123530c>] ext4_insert_range+0x34c/0x4a0
[<ffffffff81235942>] ext4_fallocate+0x4e2/0x8b0
[<ffffffff81181334>] vfs_fallocate+0x134/0x210
[<ffffffff8118203f>] SyS_fallocate+0x3f/0x60
[<ffffffff818efa9b>] entry_SYSCALL_64_fastpath+0x13/0x8f
[<ffffffffffffffff>] 0xffffffffffffffff
Problem seems mitigated by dropping refs and freeing path
when there's no path[depth].p_ext
Although the extent tree depth of 5 should enough be for the worst
case of 2*32 extents of length 1, the extent tree code does not
currently to merge nodes which are less than half-full with a sibling
node, or to shrink the tree depth if possible. So it's possible, at
least in theory, for the tree depth to be greater than 5. However,
even in the worst case, a tree depth of 32 is highly unlikely, and if
the file system is maliciously corrupted, an insanely large eh_depth
can cause memory allocation failures that will trigger kernel warnings
(here, eh_depth = 65280):
JBD2: ext4.exe wants too many credits credits:195849 rsv_credits:0 max:256
WARNING: CPU: 0 PID: 50 at fs/jbd2/transaction.c:293 start_this_handle+0x569/0x580
CPU: 0 PID: 50 Comm: ext4.exe Not tainted 4.7.0-rc5+ #508
Stack:
604a8947 625badd8 0002fd09 00000000
60078643 00000000 62623910 601bf9bc
62623970 6002fc84 626239b0 900000125
Call Trace:
[<6001c2dc>] show_stack+0xdc/0x1a0
[<601bf9bc>] dump_stack+0x2a/0x2e
[<6002fc84>] __warn+0x114/0x140
[<6002fdff>] warn_slowpath_null+0x1f/0x30
[<60165829>] start_this_handle+0x569/0x580
[<60165d4e>] jbd2__journal_start+0x11e/0x220
[<60146690>] __ext4_journal_start_sb+0x60/0xa0
[<60120a81>] ext4_truncate+0x131/0x3a0
[<60123677>] ext4_setattr+0x757/0x840
[<600d5d0f>] notify_change+0x16f/0x2a0
[<600b2b16>] do_truncate+0x76/0xc0
[<600c3e56>] path_openat+0x806/0x1300
[<600c55c9>] do_filp_open+0x89/0xf0
[<600b4074>] do_sys_open+0x134/0x1e0
[<600b4140>] SyS_open+0x20/0x30
[<6001ea68>] handle_syscall+0x88/0x90
[<600295fd>] userspace+0x3fd/0x500
[<6001ac55>] fork_handler+0x85/0x90
---[ end trace 08b0b88b6387a244 ]---
[ Commit message modified and the extent tree depath check changed
from 5 to 32 -- tytso ]
Cc: Darrick J. Wong <darrick.wong@oracle.com>
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
An extent with lblock = 4294967295 and len = 1 will pass the
ext4_valid_extent() test:
ext4_lblk_t last = lblock + len - 1;
if (len == 0 || lblock > last)
return 0;
since last = 4294967295 + 1 - 1 = 4294967295. This would later trigger
the BUG_ON(es->es_lblk + es->es_len < es->es_lblk) in ext4_es_end().
We can simplify it by removing the - 1 altogether and changing the test
to use lblock + len <= lblock, since now if len = 0, then lblock + 0 ==
lblock and it fails, and if len > 0 then lblock + len > lblock in order
to pass (i.e. it doesn't overflow).
Fixes: 5946d0893 ("ext4: check for overlapping extents in ext4_valid_extent_entries()")
Fixes: 2f974865f ("ext4: check for zero length extent explicitly")
Cc: Eryu Guan <guaneryu@gmail.com>
Signed-off-by: Phil Turnbull <phil.turnbull@oracle.com>
ext4_find_extent(), stripped down to the parts relevant to this patch,
reads as
ppos = 0;
i = depth;
while (i) {
--i;
++ppos;
if (unlikely(ppos > depth)) {
ret = -EFSCORRUPTED;
goto err;
Due to the loop's bounds, the condition ppos > depth can never be met.
Remove this dead code.
Signed-off-by: Nicolai Stange <nicstange@gmail.com>
Messages passed to ext4_warning() or ext4_error() don't need trailing
newlines, because these function add the newlines themselves.
Signed-off-by: Jakub Wilk <jwilk@jwilk.net>
The function jbd2_journal_extend() takes as its argument the number of
new credits to be added to the handle. We weren't taking into account
the currently unused handle credits; worse, we would try to extend the
handle by N credits when it had N credits available.
In the case where jbd2_journal_extend() fails because the transaction
is too large, when jbd2_journal_restart() gets called, the N credits
owned by the handle gets returned to the transaction, and the
transaction commit is asynchronously requested, and then
start_this_handle() will be able to successfully attach the handle to
the current transaction since the required credits are now available.
This is mostly harmless, but since ext4_ext_truncate_extend_restart()
returns EAGAIN, the truncate machinery will once again try to call
ext4_ext_truncate_extend_restart(), which will do the above sequence
over and over again until the transaction has committed.
This was found while I was debugging a lockup in caused by running
xfstests generic/074 in the data=journal case. I'm still not sure why
we ended up looping forever, which suggests there may still be another
bug hiding in the transaction accounting machinery, but this commit
prevents us from looping in the first place.
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
Currently, ext4_map_blocks() just returns 0 when it finds a hole and
allocation is not requested. However we have all the information
available to tell how large the hole actually is and there are callers
of ext4_map_blocks() which would save some block-by-block hole iteration
if they knew this information. So fill in struct ext4_map_blocks even
for holes with the information we have. We keep returning 0 for holes to
maintain backward compatibility of the function.
ext4_ext_put_gap_in_cache() determines hole size in the extent tree,
then trims this with possible delayed allocated blocks, and inserts the
result into the extent status tree. Factor out determination of the size
of the hole in the extent tree as we will need this information in
ext4_ext_map_blocks() as well.
When mapping blocks for direct IO, we allocate io_end structure before
mapping blocks and store pointer to it in the inode. This creates a
requirement that any AIO DIO using io_end must be protected by i_mutex.
This created problems in the past with dioread_nolock mode which was
corrupting io_end pointers. Also io_end is allocated unnecessarily in
case where we don't need to convert any extents (which is a common case
for example when overwriting file).
We fix the problem by allocating io_end only once we return unwritten
extent from block mapping function for AIO DIO (so we can save some
pointless io_end allocations) and we pass pointer to it in bh->b_private
which generic DIO code later passes to our end IO callback. That way we
remove any need for global pointer to io_end structure and thus fix the
races.
The downside of this change is that the checking for unwritten IO in
flight in ext4_extents_can_be_merged() is more racy since we now
increment i_unwritten / set EXT4_STATE_DIO_UNWRITTEN only after dropping
i_data_sem. However the check has been racy already before because
ext4_writepages() already increment i_unwritten after dropping
i_data_sem and reserved blocks save us from hitting ENOSPC in the worst
case.
The flags parameter is also unused.
Signed-off-by: Eric Whitney <enwlinux@gmail.com>
The "newblock" parameter is not used in convert_initialized_extent(),
remove it.
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested},
inode_foo(inode) being mutex_foo(&inode->i_mutex).
Please, use those for access to ->i_mutex; over the coming cycle
->i_mutex will become rwsem, with ->lookup() done with it held
only shared.
DAX page fault path needs to get blocks that are pre-zeroed to avoid
races when two concurrent page faults happen in the same block of a
file. Implement support for this in ext4_map_blocks().
Signed-off-by: Jan Kara <jack@suse.com>
Create new function ext4_issue_zeroout() to zeroout contiguous (both
logically and physically) part of inode data. We will need to issue
zeroout when extent structure is not readily available and this function
will allow us to do it without making up fake extent structures.
When doing delayed allocation, update of on-disk inode size is postponed
until IO submission time. However hole punch or zero range fallocate
calls can end up discarding the tail page cache page and thus on-disk
inode size would never be properly updated.
Make sure the on-disk inode size is updated before truncating page
cache.
Current code implementing FALLOC_FL_COLLAPSE_RANGE and
FALLOC_FL_INSERT_RANGE is prone to races with buffered writes and page
faults. If buffered write or write via mmap manages to squeeze between
filemap_write_and_wait_range() and truncate_pagecache() in the fallocate
implementations, the written data is simply discarded by
truncate_pagecache() although it should have been shifted.
Fix the problem by moving filemap_write_and_wait_range() call inside
i_mutex and i_mmap_sem. That way we are protected against races with
both buffered writes and page faults.
Currently ext4_alloc_file_blocks() was handling protection against
unlocked DIO. However we now need to sometimes call it under i_mmap_sem
and sometimes not and DIO protection ranks above it (although strictly
speaking this cannot currently create any deadlocks). Also
ext4_zero_range() was actually getting & releasing unlocked DIO
protection twice in some cases. Luckily it didn't introduce any real bug
but it was a land mine waiting to be stepped on. So move DIO protection
out from ext4_alloc_file_blocks() into the two callsites.
Currently, page faults and hole punching are completely unsynchronized.
This can result in page fault faulting in a page into a range that we
are punching after truncate_pagecache_range() has been called and thus
we can end up with a page mapped to disk blocks that will be shortly
freed. Filesystem corruption will shortly follow. Note that the same
race is avoided for truncate by checking page fault offset against
i_size but there isn't similar mechanism available for punching holes.
Fix the problem by creating new rw semaphore i_mmap_sem in inode and
grab it for writing over truncate, hole punching, and other functions
removing blocks from extent tree and for read over page faults. We
cannot easily use i_data_sem for this since that ranks below transaction
start and we need something ranking above it so that it can be held over
the whole truncate / hole punching operation. Also remove various
workarounds we had in the code to reduce race window when page fault
could have created pages with stale mapping information.
Pull trivial updates from Jiri Kosina:
"Trivial stuff from trivial tree that can be trivially summed up as:
- treewide drop of spurious unlikely() before IS_ERR() from Viresh
Kumar
- cosmetic fixes (that don't really affect basic functionality of the
driver) for pktcdvd and bcache, from Julia Lawall and Petr Mladek
- various comment / printk fixes and updates all over the place"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial:
bcache: Really show state of work pending bit
hwmon: applesmc: fix comment typos
Kconfig: remove comment about scsi_wait_scan module
class_find_device: fix reference to argument "match"
debugfs: document that debugfs_remove*() accepts NULL and error values
net: Drop unlikely before IS_ERR(_OR_NULL)
mm: Drop unlikely before IS_ERR(_OR_NULL)
fs: Drop unlikely before IS_ERR(_OR_NULL)
drivers: net: Drop unlikely before IS_ERR(_OR_NULL)
drivers: misc: Drop unlikely before IS_ERR(_OR_NULL)
UBI: Update comments to reflect UBI_METAONLY flag
pktcdvd: drop null test before destroy functions
Create separate predicate functions to test/set/clear feature flags,
thereby replacing the wordy old macros. Furthermore, clean out the
places where we open-coded feature tests.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Instead of overloading EIO for CRC errors and corrupt structures,
return the same error codes that XFS returns for the same issues.
Fix multiple bugs in ext4_encrypted_zeroout(), including one that
could cause us to write an encrypted zero page to the wrong location
on disk, potentially causing data and file system corruption.
Fortunately, this tends to only show up in stress tests, but even with
these fixes, we are seeing some test failures with generic/127 --- but
these are now caused by data failures instead of metadata corruption.
Since ext4_encrypted_zeroout() is only used for some optimizations to
keep the extent tree from being too fragmented, and
ext4_encrypted_zeroout() itself isn't all that optimized from a time
or IOPS perspective, disable the extent tree optimization for
encrypted inodes for now. This prevents the data corruption issues
reported by generic/127 until we can figure out what's going wrong.
IS_ERR(_OR_NULL) already contain an 'unlikely' compiler flag and there
is no need to do that again from its callers. Drop it.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Reviewed-by: Jeff Layton <jlayton@poochiereds.net>
Reviewed-by: David Howells <dhowells@redhat.com>
Reviewed-by: Steve French <smfrench@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 bugfixes from Ted Ts'o:
"Bug fixes (all for stable kernels) for ext4:
- address corner cases for indirect blocks->extent migration
- fix reserved block accounting invalidate_page when
page_size != block_size (i.e., ppc or 1k block size file systems)
- fix deadlocks when a memcg is under heavy memory pressure
- fix fencepost error in lazytime optimization"
* tag 'ext4_for_linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: replace open coded nofail allocation in ext4_free_blocks()
ext4: correctly migrate a file with a hole at the beginning
ext4: be more strict when migrating to non-extent based file
ext4: fix reservation release on invalidatepage for delalloc fs
ext4: avoid deadlocks in the writeback path by using sb_getblk_gfp
bufferhead: Add _gfp version for sb_getblk()
ext4: fix fencepost error in lazytime optimization
Switch ext4 to using sb_getblk_gfp with GFP_NOFS added to fix possible
deadlocks in the page writeback path.
Signed-off-by: Nikolay Borisov <kernel@kyup.com>
Pull cgroup writeback support from Jens Axboe:
"This is the big pull request for adding cgroup writeback support.
This code has been in development for a long time, and it has been
simmering in for-next for a good chunk of this cycle too. This is one
of those problems that has been talked about for at least half a
decade, finally there's a solution and code to go with it.
Also see last weeks writeup on LWN:
http://lwn.net/Articles/648292/"
* 'for-4.2/writeback' of git://git.kernel.dk/linux-block: (85 commits)
writeback, blkio: add documentation for cgroup writeback support
vfs, writeback: replace FS_CGROUP_WRITEBACK with SB_I_CGROUPWB
writeback: do foreign inode detection iff cgroup writeback is enabled
v9fs: fix error handling in v9fs_session_init()
bdi: fix wrong error return value in cgwb_create()
buffer: remove unusued 'ret' variable
writeback: disassociate inodes from dying bdi_writebacks
writeback: implement foreign cgroup inode bdi_writeback switching
writeback: add lockdep annotation to inode_to_wb()
writeback: use unlocked_inode_to_wb transaction in inode_congested()
writeback: implement unlocked_inode_to_wb transaction and use it for stat updates
writeback: implement [locked_]inode_to_wb_and_lock_list()
writeback: implement foreign cgroup inode detection
writeback: make writeback_control track the inode being written back
writeback: relocate wb[_try]_get(), wb_put(), inode_{attach|detach}_wb()
mm: vmscan: disable memcg direct reclaim stalling if cgroup writeback support is in use
writeback: implement memcg writeback domain based throttling
writeback: reset wb_domain->dirty_limit[_tstmp] when memcg domain size changes
writeback: implement memcg wb_domain
writeback: update wb_over_bg_thresh() to use wb_domain aware operations
In order to prevent quota block tracking to be inaccurate when
ext4_quota_write() fails with ENOSPC, we make two changes. The quota
file can now use the reserved block (since the quota file is arguably
file system metadata), and ext4_quota_write() now uses
ext4_should_retry_alloc() to retry the block allocation after a commit
has completed and released some blocks for allocation.
This fixes failures of xfstests generic/270:
Quota error (device vdc): write_blk: dquota write failed
Quota error (device vdc): qtree_write_dquot: Error -28 occurred while creating quota
Currently existing dio workers can jump in and potentially increase
extent tree depth while we're allocating blocks in
ext4_alloc_file_blocks(). This may cause us to underestimate the
number of credits needed for the transaction because the extent tree
depth can change after our estimation.
Fix this by waiting for all the existing dio workers in the same way
as we do it in ext4_punch_hole. We've seen errors caused by this in
xfstest generic/299, however it's really hard to reproduce.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
