commit 565333a1554d704789e74205989305c811fd9c7a upstream.
No need to wait for any commit once the page is fully truncated.
Besides, it may confuse e.g. concurrent ext4_writepage() with the page
still be dirty (will be cleared by truncate_pagecache() in
ext4_setattr()) but buffers has been freed; and then trigger a bug
show as below:
[ 26.057508] ------------[ cut here ]------------
[ 26.058531] kernel BUG at fs/ext4/inode.c:2134!
[ 26.088130] Call trace:
[ 26.088695] ext4_writepage+0x914/0xb28
[ 26.089541] writeout.isra.4+0x1b4/0x2b8
[ 26.090409] move_to_new_page+0x3b0/0x568
[ 26.091338] __unmap_and_move+0x648/0x988
[ 26.092241] unmap_and_move+0x48c/0xbb8
[ 26.093096] migrate_pages+0x220/0xb28
[ 26.093945] kernel_mbind+0x828/0xa18
[ 26.094791] __arm64_sys_mbind+0xc8/0x138
[ 26.095716] el0_svc_common+0x190/0x490
[ 26.096571] el0_svc_handler+0x60/0xd0
[ 26.097423] el0_svc+0x8/0xc
Run the procedure (generate by syzkaller) parallel with ext3.
void main()
int fd, fd1, ret;
void *addr;
size_t length = 4096;
int flags;
off_t offset = 0;
char *str = "12345";
fd = open("a", O_RDWR | O_CREAT);
assert(fd >= 0);
/* Truncate to 4k */
ret = ftruncate(fd, length);
assert(ret == 0);
/* Journal data mode */
flags = 0xc00f;
ret = ioctl(fd, _IOW('f', 2, long), &flags);
assert(ret == 0);
/* Truncate to 0 */
fd1 = open("a", O_TRUNC | O_NOATIME);
assert(fd1 >= 0);
addr = mmap(NULL, length, PROT_WRITE | PROT_READ,
MAP_SHARED, fd, offset);
assert(addr != (void *)-1);
memcpy(addr, str, 5);
mbind(addr, length, 0, 0, 0, MPOL_MF_MOVE);
And the bug will be triggered once we seen the below order.
reproduce1 reproduce2
truncate to 4k |
change to journal data mode |
| memcpy(set page dirty)
truncate to 0: |
ext4_setattr: |
ext4_wait_for_tail_page_commit |
| mbind(trigger bug)
truncate_pagecache(clean dirty)| ...
mbind will call ext4_writepage() since the page still be dirty, and then
report the bug since the buffers has been free. Fix it by return
directly once offset equals to 0 which means the page has been fully
truncated.
Signed-off-by: yangerkun <yangerkun@huawei.com>
Link: https://lore.kernel.org/r/20190919063508.1045-1-yangerkun@huawei.com
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit 65db869c754e7c271691dd5feabf884347e694f5 upstream.
Estimate for the number of credits needed for final freeing of inode in
ext4_evict_inode() was to small. We may modify 4 blocks (inode & sb for
orphan deletion, bitmap & group descriptor for inode freeing) and not
just 3.
[ Fixed minor whitespace nit. -- TYT ]
Fixes: e50e5129f384 ("ext4: xattr-in-inode support")
CC: stable@vger.kernel.org
Link: https://lore.kernel.org/r/20191105164437.32602-6-jack@suse.cz
commit 4ea99936a1630f51fc3a2d61a58ec4a1c4b7d55a upstream.
It's possible to specify a non-zero s_want_extra_isize via debugging
option, and this can cause bad things(tm) to happen when using a file
system with an inode size of 128 bytes.
Add better checking when the file system is mounted, as well as when
we are actually doing the trying to do the inode expansion.
Link: https://lore.kernel.org/r/20191110121510.GH23325@mit.edu
Reported-by: syzbot+f8d6f8386ceacdbfff57@syzkaller.appspotmail.com
Reported-by: syzbot+33d7ea72e47de3bdf4e1@syzkaller.appspotmail.com
Reported-by: syzbot+44b6763edfc17144296f@syzkaller.appspotmail.com
Cc: stable@kernel.org
commit c1e8220bd316d8ae8e524df39534b8a412a45d5e upstream.
If a program attempts to punch a hole on an inline data file, we need
to convert it to a normal file first.
This was detected using ext4/032 using the adv configuration. Simple
reproducer:
mke2fs -Fq -t ext4 -O inline_data /dev/vdc
mount /vdc
echo "" > /vdc/testfile
xfs_io -c 'truncate 33554432' /vdc/testfile
xfs_io -c 'fpunch 0 1048576' /vdc/testfile
umount /vdc
e2fsck -fy /dev/vdc
Cc: stable@vger.kernel.org
commit 73131fbb003b3691cfcf9656f234b00da497fcd6 upstream.
Use the newly introduced jbd2_inode dirty range scoping to prevent us
from waiting forever when trying to complete a journal transaction.
Signed-off-by: Ross Zwisler <zwisler@google.com>
commit 02b016ca7f99229ae6227e7b2fc950c4e140d74a upstream.
According to the chattr man page, "a file with the 'i' attribute
cannot be modified..." Historically, this was only enforced when the
file was opened, per the rest of the description, "... and the file
can not be opened in write mode".
There is general agreement that we should standardize all file systems
to prevent modifications even for files that were opened at the time
the immutable flag is set. Eventually, a change to enforce this at
the VFS layer should be landing in mainline. Until then, enforce this
at the ext4 level to prevent xfstests generic/553 from failing.
Cc: "Darrick J. Wong" <darrick.wong@oracle.com>
commit ee0ed02ca93ef1ecf8963ad96638795d55af2c14 upstream.
It is possible that unlinked inode enters ext4_setattr() (e.g. if
somebody calls ftruncate(2) on unlinked but still open file). In such
case we should not delete the inode from the orphan list if truncate
fails. Note that this is mostly a theoretical concern as filesystem is
corrupted if we reach this path anyway but let's be consistent in our
orphan handling.
Reviewed-by: Ira Weiny <ira.weiny@intel.com>
commit ddccb6dbe780d68133191477571cb7c69e17bb8c upstream.
Fix compile error below when using BUFFER_TRACE.
fs/ext4/inode.c: In function ‘ext4_expand_extra_isize’:
fs/ext4/inode.c:5979:19: error: request for member ‘bh’ in something not a structure or union
BUFFER_TRACE(iloc.bh, "get_write_access");
Fixes: c03b45b853f58 ("ext4, project: expand inode extra size if possible")
Signed-off-by: zhangyi (F) <yi.zhang@huawei.com>
commit 812c0cab2c0dfad977605dbadf9148490ca5d93f upstream.
There are enough credits reserved for most dioread_nolock writes;
however, if the extent tree is sufficiently deep, and/or quota is
enabled, the code was not allowing for all eventualities when
reserving journal credits for the unwritten extent conversion.
This problem can be seen using xfstests ext4/034:
WARNING: CPU: 1 PID: 257 at fs/ext4/ext4_jbd2.c:271 __ext4_handle_dirty_metadata+0x10c/0x180
Workqueue: ext4-rsv-conversion ext4_end_io_rsv_work
RIP: 0010:__ext4_handle_dirty_metadata+0x10c/0x180
EXT4-fs: ext4_free_blocks:4938: aborting transaction: error 28 in __ext4_handle_dirty_metadata
EXT4: jbd2_journal_dirty_metadata failed: handle type 11 started at line 4921, credits 4/0, errcode -28
EXT4-fs error (device dm-1) in ext4_free_blocks:4950: error 28
commit 18f2c4fcebf2582f96cbd5f2238f4f354a0e4847 upstream.
If the file system has been shut down or is read-only, then
ext4_write_inode() needs to bail out early.
Also use jbd2_complete_transaction() instead of ext4_force_commit() so
we only force a commit if it is needed.
commit a6758309a005060b8297a538a457c88699cb2520 upstream.
ext4_mark_iloc_dirty() callers expect that it releases iloc->bh
even if it returns an error.
Fixes: 0db1ff222d40 ("ext4: add shutdown bit and check for it")
Signed-off-by: Vasily Averin <vvs@virtuozzo.com>
Cc: stable@kernel.org # 4.11
commit bcd8e91f98c156f4b1ebcfacae675f9cfd962441 upstream.
A maliciously crafted file system can cause an overflow when the
results of a 64-bit calculation is stored into a 32-bit length
parameter.
https://bugzilla.kernel.org/show_bug.cgi?id=200623
Reported-by: Wen Xu <wen.xu@gatech.edu>
commit 362eca70b53389bddf3143fe20f53dcce2cfdf61 upstream.
The inline data code was updating the raw inode directly; this is
problematic since if metadata checksums are enabled,
ext4_mark_inode_dirty() must be called to update the inode's checksum.
In addition, the jbd2 layer requires that get_write_access() be called
before the metadata buffer is modified. Fix both of these problems.
https://bugzilla.kernel.org/show_bug.cgi?id=200443
commit c37e9e013469521d9adb932d17a1795c139b36db upstream.
If there is a directory entry pointing to a system inode (such as a
journal inode), complain and declare the file system to be corrupted.
Also, if the superblock's first inode number field is too small,
refuse to mount the file system.
This addresses CVE-2018-10882.
https://bugzilla.kernel.org/show_bug.cgi?id=200069
commit bdbd6ce01a70f02e9373a584d0ae9538dcf0a121 upstream.
commit eb9b5f01c33adebc31cbc236c02695f605b0e417 upstream.
If ext4_find_inline_data_nolock() returns an error it needs to get
reflected up to ext4_iget(). In order to fix this,
ext4_iget_extra_inode() needs to return an error (and not return
void).
This is related to "ext4: do not allow external inodes for inline
data" (which fixes CVE-2018-11412) in that in the errors=continue
case, it would be useful to for userspace to receive an error
indicating that file system is corrupted.
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
commit eee597ac931305eff3d3fd1d61d6aae553bc0984 upstream.
Currently in ext4_punch_hole we're going to skip the mtime update if
there are no actual blocks to release. However we've actually modified
the file by zeroing the partial block so the mtime should be updated.
Moreover the sync and datasync handling is skipped as well, which is
also wrong. Fix it.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Reported-by: Joe Habermann <joe.habermann@quantum.com>
Cc: <stable@vger.kernel.org>
commit 8e4b5eae5decd9dfe5a4ee369c22028f90ab4c44 upstream.
If the root directory has an i_links_count of zero, then when the file
system is mounted, then when ext4_fill_super() notices the problem and
tries to call iput() the root directory in the error return path,
ext4_evict_inode() will try to free the inode on disk, before all of
the file system structures are set up, and this will result in an OOPS
caused by a NULL pointer dereference.
This issue has been assigned CVE-2018-1092.
https://bugzilla.kernel.org/show_bug.cgi?id=199179
https://bugzilla.redhat.com/show_bug.cgi?id=1560777
commit 73fdad00b208b139cf43f3163fbc0f67e4c6047c upstream.
i_disksize update should be protected by i_data_sem, by either taking
the lock explicitly or by using ext4_update_i_disksize() helper. But the
i_disksize updates in ext4_direct_IO_write() are not protected at all,
which may be racing with i_disksize updates in writeback path in
delalloc buffer write path.
This is found by code inspection, and I didn't hit any i_disksize
corruption due to this bug. Thanks to Jan Kara for catching this bug and
suggesting the fix!
Reported-by: Jan Kara <jack@suse.cz>
Suggested-by: Jan Kara <jack@suse.cz>
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
commit abbc3f9395c76d554a9ed27d4b1ebfb5d9b0e4ca upstream.
This patch fixes a race between the shutdown path and bio completion
handling. In the ext4 direct io path with async io, after submitting a
bio to the block layer, if journal starting fails,
ext4_direct_IO_write() would bail out pretending that the IO
failed. The caller would have had no way of knowing whether or not the
IO was successfully submitted. So instead, we return -EIOCBQUEUED in
this case. Now, the caller knows that the IO was submitted. The bio
completion handler takes care of the error.
Tested: Ran the shutdown xfstest test 461 in loop for over 2 hours across
4 machines resulting in over 400 runs. Verified that the race didn't
occur. Usually the race was seen in about 20-30 iterations.
Signed-off-by: Harshad Shirwadkar <harshads@google.com>
commit fc82228a5e3860502dbf3bfa4a9570cb7093cf7f upstream.
407cd7fb83c0 (ext4: change fast symlink test to not rely on i_blocks)
broke ~10 years old ext3 file systems created by 2.6.17. Any ELF
executable fails because the /lib/ld-linux.so.2 fast symlink
cannot be read anymore.
The patch assumed fast symlinks were created in a specific way,
but that's not true on these really old file systems.
The new behavior is apparently needed only with the large EA inode
feature.
Revert to the old behavior if the large EA inode feature is not set.
This makes my old VM boot again.
Fixes: 407cd7fb83c0 (ext4: change fast symlink test to not rely on i_blocks)
commit e9072d859df3e0f2c3ba450f0d1739595c2d5d13 upstream.
The current code has the potential for data corruption when changing an
inode's journaling mode, as that can result in a subsequent unsafe change
in S_DAX.
I've captured an instance of this data corruption in the following fstest:
https://patchwork.kernel.org/patch/9948377/
Prevent this data corruption from happening by disallowing changes to the
journaling mode if the '-o dax' mount option was used. This means that for
a given filesystem we could have a mix of inodes using either DAX or
data journaling, but whatever state the inodes are in will be held for the
duration of the mount.
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull libnvdimm from Dan Williams:
"A rework of media error handling in the BTT driver and other updates.
It has appeared in a few -next releases and collected some late-
breaking build-error and warning fixups as a result.
Summary:
- Media error handling support in the Block Translation Table (BTT)
driver is reworked to address sleeping-while-atomic locking and
memory-allocation-context conflicts.
- The dax_device lookup overhead for xfs and ext4 is moved out of the
iomap hot-path to a mount-time lookup.
- A new 'ecc_unit_size' sysfs attribute is added to advertise the
read-modify-write boundary property of a persistent memory range.
- Preparatory fix-ups for arm and powerpc pmem support are included
along with other miscellaneous fixes"
* tag 'libnvdimm-for-4.14' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (26 commits)
libnvdimm, btt: fix format string warnings
libnvdimm, btt: clean up warning and error messages
ext4: fix null pointer dereference on sbi
libnvdimm, nfit: move the check on nd_reserved2 to the endpoint
dax: fix FS_DAX=n BLOCK=y compilation
libnvdimm: fix integer overflow static analysis warning
libnvdimm, nd_blk: remove mmio_flush_range()
libnvdimm, btt: rework error clearing
libnvdimm: fix potential deadlock while clearing errors
libnvdimm, btt: cache sector_size in arena_info
libnvdimm, btt: ensure that flags were also unchanged during a map_read
libnvdimm, btt: refactor map entry operations with macros
libnvdimm, btt: fix a missed NVDIMM_IO_ATOMIC case in the write path
libnvdimm, nfit: export an 'ecc_unit_size' sysfs attribute
ext4: perform dax_device lookup at mount
ext2: perform dax_device lookup at mount
xfs: perform dax_device lookup at mount
dax: introduce a fs_dax_get_by_bdev() helper
libnvdimm, btt: check memory allocation failure
libnvdimm, label: fix index block size calculation
Merge updates from Andrew Morton:
- various misc bits
- DAX updates
- OCFS2
- most of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (119 commits)
mm,fork: introduce MADV_WIPEONFORK
x86,mpx: make mpx depend on x86-64 to free up VMA flag
mm: add /proc/pid/smaps_rollup
mm: hugetlb: clear target sub-page last when clearing huge page
mm: oom: let oom_reap_task and exit_mmap run concurrently
swap: choose swap device according to numa node
mm: replace TIF_MEMDIE checks by tsk_is_oom_victim
mm, oom: do not rely on TIF_MEMDIE for memory reserves access
z3fold: use per-cpu unbuddied lists
mm, swap: don't use VMA based swap readahead if HDD is used as swap
mm, swap: add sysfs interface for VMA based swap readahead
mm, swap: VMA based swap readahead
mm, swap: fix swap readahead marking
mm, swap: add swap readahead hit statistics
mm/vmalloc.c: don't reinvent the wheel but use existing llist API
mm/vmstat.c: fix wrong comment
selftests/memfd: add memfd_create hugetlbfs selftest
mm/shmem: add hugetlbfs support to memfd_create()
mm, devm_memremap_pages: use multi-order radix for ZONE_DEVICE lookups
mm/vmalloc.c: halve the number of comparisons performed in pcpu_get_vm_areas()
All users of pagevec_lookup() and pagevec_lookup_range() now pass
PAGEVEC_SIZE as a desired number of pages.
Just drop the argument.
Link: http://lkml.kernel.org/r/20170726114704.7626-11-jack@suse.cz
Both occurences of pagevec_lookup() actually want only pages from a
given range. Use pagevec_lookup_range() for the lookup.
Link: http://lkml.kernel.org/r/20170726114704.7626-7-jack@suse.cz
Cc: "Theodore Ts'o" <tytso@mit.edu>
Make pagevec_lookup() (and underlying find_get_pages()) update index to
the next page where iteration should continue. Most callers want this
and also pagevec_lookup_tag() already does this.
Link: http://lkml.kernel.org/r/20170726114704.7626-3-jack@suse.cz
The ->iomap_begin() operation is a hot path, so cache the
fs_dax_get_by_host() result at mount time to avoid the incurring the
hash lookup overhead on a per-i/o basis.
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Reported-by: Christoph Hellwig <hch@lst.de>
Original Lustre ea_inode feature did not have ref counts on xattr inodes
because there was always one parent that referenced it. New
implementation expects ref count to be initialized which is not true for
Lustre case. Handle this by detecting Lustre created xattr inode and set
its ref count to 1.
The quota handling of xattr inodes have also changed with deduplication
support. New implementation manually manages quotas to support sharing
across multiple users. A consequence is that, a referencing inode
incorporates the blocks of xattr inode into its own i_block field.
We need to know how a xattr inode was created so that we can reverse the
block charges during reference removal. This is handled by introducing a
EXT4_STATE_LUSTRE_EA_INODE flag. The flag is set on a xattr inode if
inode appears to have been created by Lustre. During xattr inode reference
removal, the manual quota uncharge is skipped if the flag is set.
Signed-off-by: Tahsin Erdogan <tahsin@google.com>
When upgrading from old format, try to set project id
to old file first time, it will return EOVERFLOW, but if
that file is dirtied(touch etc), changing project id will
be allowed, this might be confusing for users, we could
try to expand @i_extra_isize here too.
Reported-by: Zhang Yi <yi.zhang@huawei.com>
Signed-off-by: Miao Xie <miaoxie@huawei.com>
Signed-off-by: Wang Shilong <wshilong@ddn.com>
Current ext4_expand_extra_isize just tries to expand extra isize, if
someone is holding xattr lock or some check fails, it will give up.
So rename its name to ext4_try_to_expand_extra_isize.
Besides that, we clean up unnecessary check and move some relative checks
into it.
Reviewed-by: Wang Shilong <wshilong@ddn.com>
We should avoid the contention between the i_extra_isize update and
the inline data insertion, so move the xattr trylock in front of
i_extra_isize update.
ext4_xattr_inode_read() currently reads each block sequentially while
waiting for io operation to complete before moving on to the next
block. This prevents request merging in block layer.
Add a ext4_bread_batch() function that starts reads for all blocks
then optionally waits for them to complete. A similar logic is used
in ext4_find_entry(), so update that code to use the new function.
Commit 914f82a32d0268847 "ext4: refactor direct IO code" deleted
ext4_ext_direct_IO(), but references to that function remain in
comments. Update them to refer to ext4_direct_IO_write().
Signed-off-by: Eric Whitney <enwlinux@gmail.com>
ext4_inode_info->i_data is the storage area for 4 types of data:
a) Extents data
b) Inline data
c) Block map
d) Fast symlink data (symlink length < 60)
Extents data case is positively identified by EXT4_INODE_EXTENTS flag.
Inline data case is also obvious because of EXT4_INODE_INLINE_DATA
flag.
Distinguishing c) and d) however requires additional logic. This
currently relies on i_blocks count. After subtracting external xattr
block from i_blocks, if it is greater than 0 then we know that some
data blocks exist, so there must be a block map.
This logic got broken after ea_inode feature was added. That feature
charges the data blocks of external xattr inodes to the referencing
inode and so adds them to the i_blocks. To fix this, we could subtract
ea_inode blocks by iterating through all xattr entries and then check
whether remaining i_blocks count is zero. Besides being complicated,
this won't change the fact that the current way of distinguishing
between c) and d) is fragile.
The alternative solution is to test whether i_size is less than 60 to
determine fast symlink case. ext4_symlink() uses the same test to decide
whether to store the symlink in i_data. There is one caveat to address
before this can work though.
If an inode's i_nlink is zero during eviction, its i_size is set to
zero and its data is truncated. If system crashes before inode is removed
from the orphan list, next boot orphan cleanup may find the inode with
zero i_size. So, a symlink that had its data stored in a block may now
appear to be a fast symlink. The solution used in this patch is to treat
i_size = 0 as a non-fast symlink case. A zero sized symlink is not legal
so the only time this can happen is the mentioned scenario. This is also
logically correct because a i_size = 0 symlink has no data stored in
i_data.
Suggested-by: Andreas Dilger <adilger@dilger.ca>
Currently, filesystems allow truncate(2) on an encrypted file without
the encryption key. However, it's impossible to correctly handle the
case where the size being truncated to is not a multiple of the
filesystem block size, because that would require decrypting the final
block, zeroing the part beyond i_size, then encrypting the block.
As other modifications to encrypted file contents are prohibited without
the key, just prohibit truncate(2) as well, making it fail with ENOKEY.
These days inode reclaim calls evict_inode() only when it has no pages
in the mapping. In that case it is not necessary to wait for transaction
commit in ext4_evict_inode() as there can be no pages waiting to be
committed. So avoid unnecessary transaction waiting in that case.
We still have to keep the check for the case where ext4_evict_inode()
gets called from other paths (e.g. umount) where inode still can have
some page cache pages.
Reported-by: Johannes Weiner <hannes@cmpxchg.org>
Ext4 ea_inode feature allows storing xattr values in external inodes to
be able to store values that are bigger than a block in size. Ext4 also
has deduplication support for these type of inodes. With deduplication,
the actual storage waste is eliminated but the users of such inodes are
still charged full quota for the inodes as if there was no sharing
happening in the background.
This design requires ext4 to manually charge the users because the
inodes are shared.
An implication of this is that, if someone calls chown on a file that
has such references we need to transfer the quota for the file and xattr
inodes. Current dquot_transfer() function implicitly transfers one inode
charge. With ea_inode feature, we would like to transfer multiple inode
charges.
Add get_inode_usage callback which can interrogate the total number of
inodes that were charged for a given inode.
[ Applied fix from Colin King to make sure the 'ret' variable is
initialized on the successful return path. Detected by
CoverityScan, CID#1446616 ("Uninitialized scalar variable") --tytso]
Acked-by: Jan Kara <jack@suse.cz>
Ext4 now supports xattr values that are up to 64k in size (vfs limit).
Large xattr values are stored in external inodes each one holding a
single value. Once written the data blocks of these inodes are immutable.
The real world use cases are expected to have a lot of value duplication
such as inherited acls etc. To reduce data duplication on disk, this patch
implements a deduplicator that allows sharing of xattr inodes.
The deduplication is based on an in-memory hash lookup that is a best
effort sharing scheme. When a xattr inode is read from disk (i.e.
getxattr() call), its crc32c hash is added to a hash table. Before
creating a new xattr inode for a value being set, the hash table is
checked to see if an existing inode holds an identical value. If such an
inode is found, the ref count on that inode is incremented. On value
removal the ref count is decremented and if it reaches zero the inode is
deleted.
The quota charging for such inodes is manually managed. Every reference
holder is charged the full size as if there was no sharing happening.
This is consistent with how xattr blocks are also charged.
[ Fixed up journal credits calculation to handle inline data and the
rare case where an shared xattr block can get freed when two thread
race on breaking the xattr block sharing. --tytso ]
During inode deletion, the number of journal credits that will be
needed is hard to determine. For that reason we have journal
extend/restart calls in several places. Whenever a transaction is
restarted, filesystem must be in a consistent state because there is
no atomicity guarantee beyond a restart call.
Add ext4_xattr_ensure_credits() helper function which takes care of
journal extend/restart logic. It also handles getting jbd2 write
access and dirty metadata calls. This function is called at every
iteration of handling an ea_inode reference.
IS_NOQUOTA() indicates whether quota is disabled for an inode. Ext4
also uses it to check whether an inode is for a quota file. The
distinction currently doesn't matter because quota is disabled only
for the quota files. When we start disabling quota for other inodes
in the future, we will want to make the distinction clear.
Replace IS_NOQUOTA() call with ext4_is_quota_file() at places where
we are checking for quota files.
Tracking struct inode * rather than the inode number eliminates the
repeated ext4_xattr_inode_iget() call later. The second call cannot
fail in practice but still requires explanation when it wants to ignore
the return value. Avoid the trouble and make things simple.
Setting a large xattr value may require writing the attribute contents
to an external inode. In this case we may need to lock the xattr inode
along with the parent inode. This doesn't pose a deadlock risk because
xattr inodes are not directly visible to the user and their access is
restricted.
Assign a lockdep subclass to xattr inode's lock.
WARNING: possible recursive locking detected
4.12.0-rc1+ #740 Not tainted
python/1822 is trying to acquire lock:
(&sb->s_type->i_mutex_key#15){+.+...}, at: [<ffffffff804912ca>] ext4_xattr_set_entry+0x65a/0x7b0
but task is already holding lock:
(&sb->s_type->i_mutex_key#15){+.+...}, at: [<ffffffff803d6687>] vfs_setxattr+0x57/0xb0
Possible unsafe locking scenario:
CPU0
lock(&sb->s_type->i_mutex_key#15);
*** DEADLOCK ***
May be due to missing lock nesting notation
4 locks held by python/1822:
#0: (sb_writers#10){.+.+.+}, at: [<ffffffff803d0eef>] mnt_want_write+0x1f/0x50
#1: (&sb->s_type->i_mutex_key#15){+.+...}, at: [<ffffffff803d6687>] vfs_setxattr+0x57/0xb0
#2: (jbd2_handle){.+.+..}, at: [<ffffffff80493f40>] start_this_handle+0xf0/0x420
#3: (&ei->xattr_sem){++++..}, at: [<ffffffff804920ba>] ext4_xattr_set_handle+0x9a/0x4f0
stack backtrace:
CPU: 0 PID: 1822 Comm: python Not tainted 4.12.0-rc1+ #740
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
dump_stack+0x67/0x9e
__lock_acquire+0x5f3/0x1750
lock_acquire+0xb5/0x1d0
down_write+0x2c/0x60
ext4_xattr_block_set+0x1b2/0x9b0
ext4_xattr_set_handle+0x322/0x4f0
ext4_xattr_set+0x144/0x1a0
ext4_xattr_user_set+0x34/0x40
__vfs_setxattr+0x66/0x80
__vfs_setxattr_noperm+0x69/0x1c0
vfs_setxattr+0xa2/0xb0
setxattr+0x12e/0x150
path_setxattr+0x87/0xb0
SyS_setxattr+0xf/0x20
entry_SYSCALL_64_fastpath+0x18/0xad
Large xattr support is implemented for EXT4_FEATURE_INCOMPAT_EA_INODE.
If the size of an xattr value is larger than will fit in a single
external block, then the xattr value will be saved into the body
of an external xattr inode.
The also helps support a larger number of xattr, since only the headers
will be stored in the in-inode space or the single external block.
The inode is referenced from the xattr header via "e_value_inum",
which was formerly "e_value_block", but that field was never used.
The e_value_size still contains the xattr size so that listing
xattrs does not need to look up the inode if the data is not accessed.
struct ext4_xattr_entry {
__u8 e_name_len; /* length of name */
__u8 e_name_index; /* attribute name index */
__le16 e_value_offs; /* offset in disk block of value */
__le32 e_value_inum; /* inode in which value is stored */
__le32 e_value_size; /* size of attribute value */
__le32 e_hash; /* hash value of name and value */
char e_name[0]; /* attribute name */
The xattr inode is marked with the EXT4_EA_INODE_FL flag and also
holds a back-reference to the owning inode in its i_mtime field,
allowing the ext4/e2fsck to verify the correct inode is accessed.
[ Applied fix by Dan Carpenter to avoid freeing an ERR_PTR. ]
Lustre-Jira: https://jira.hpdd.intel.com/browse/LU-80
Lustre-bugzilla: https://bugzilla.lustre.org/show_bug.cgi?id=4424
Signed-off-by: Kalpak Shah <kalpak.shah@sun.com>
Signed-off-by: James Simmons <uja.ornl@gmail.com>
Signed-off-by: Andreas Dilger <andreas.dilger@intel.com>
This INCOMPAT_LARGEDIR feature allows larger directories to be created
in ldiskfs, both with directory sizes over 2GB and and a maximum htree
depth of 3 instead of the current limit of 2. These features are needed
in order to exceed the current limit of approximately 10M entries in a
single directory.
This patch was originally written by Yang Sheng to support the Lustre server.
[ Bumped the credits needed to update an indexed directory -- tytso ]
Signed-off-by: Liang Zhen <liang.zhen@intel.com>
Signed-off-by: Yang Sheng <yang.sheng@intel.com>
Signed-off-by: Artem Blagodarenko <artem.blagodarenko@seagate.com>
Reviewed-by: Andreas Dilger <andreas.dilger@intel.com>
Currently, extent manipulation operations such as hole punch, range
zeroing, or extent shifting do not record the fact that file data has
changed and thus fdatasync(2) has a work to do. As a result if we crash
e.g. after a punch hole and fdatasync, user can still possibly see the
punched out data after journal replay. Test generic/392 fails due to
these problems.
Fix the problem by properly marking that file data has changed in these
operations.
Fixes: a4bb6b64e39abc0e41ca077725f2a72c868e7622
mpage_submit_page() can race with another process growing i_size and
writing data via mmap to the written-back page. As mpage_submit_page()
samples i_size too early, it may happen that ext4_bio_write_page()
zeroes out too large tail of the page and thus corrupts user data.
Fix the problem by sampling i_size only after the page has been
write-protected in page tables by clear_page_dirty_for_io() call.
Reported-by: Michael Zimmer <michael@swarm64.com>
Fixes: cb20d5188366f04d96d2e07b1240cc92170ade40
Currently we don't allow direct I/O on encrypted regular files, so in
such cases we return 0 early in ext4_direct_IO(). There was also an
additional BUG_ON() check in ext4_direct_IO_write(), but it can never be
hit because of the earlier check for the exact same condition in
ext4_direct_IO(). There was also no matching check on the read path,
which made the write path specific check seem very ad-hoc.
Just remove the unnecessary BUG_ON().
Reviewed-by: David Gstir <david@sigma-star.at>
The 'lend' argument of filemap_write_and_wait_range() is inclusive, so
we need to subtract 1 from pos + count.
Note that 'count' is guaranteed to be nonzero since
ext4_file_read_iter() returns early when given a 0 count.
Fixes: 16c54688592c ("ext4: Allow parallel DIO reads")
