path: root/fs/ext4/mballoc.c
2011-08-01ext4: prevent memory leaks from ext4_mb_init_backend() on error pathYu Jian
In ext4_mb_init(), if the s_locality_group allocation fails it will currently cause the allocations made in ext4_mb_init_backend() to be leaked. Moving the ext4_mb_init_backend() allocation after the s_locality_group allocation avoids that problem. Signed-off-by: Yu Jian <yujian@whamcloud.com> Signed-off-by: Andreas Dilger <adilger@whamcloud.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-08-01ext4: use EXT4_BAD_INO for buddy cache to avoid colliding with valid inode #Yu Jian
2011-08-01ext4: use ext4_msg() instead of printk in mballocTheodore Ts'o
2011-08-01ext4: use ext4_kvzalloc()/ext4_kvmalloc() for s_group_desc and s_group_infoTheodore Ts'o
2011-07-26ext4: let setup_new_group_blocks() set multiple bits at a timeYongqiang Yang
Rename mb_set_bits() to ext4_set_bits() and make it a global function so that setup_new_group_blocks() can use it. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-26ext4: let ext4_group_add_blocks() handle 0 blocks quicklyYongqiang Yang
If ext4_group_add_blocks() is called with 0 block, make it return 0 without doing any extra work. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-26ext4: let ext4_group_add_blocks() return an error codeYongqiang Yang
This patch lets ext4_group_add_blocks() return an error code if it fails, so that upper functions can handle error correctly. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-26ext4: rename ext4_add_groupblocks() to ext4_group_add_blocks()Yongqiang Yang
2011-07-23ext4: don't increment s_mb_buddies_generated in ext4_mb_releaseTao Ma
In ext4_mb_release, we use s_mb_buddies_generated++. Although the output is OK, but I don't think we need this extra ++. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-23ext4: remove unnecessary ext4_get_group_info in ext4_mb_load_buddyTao Ma
ext4_mb_load_buddy() calls ext4_get_group_info() for setting both "grp" and "e4b->bd_info", but it could do "e4b->bd_info = grp". Reported-by: Andreas Dilger <adilger@whamcloud.com> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-17ext4: make the preallocation size be a multiple of stripe sizeDan Ehrenberg
Previously, if a stripe width was provided, then it would be used as the preallocation granularity, with no santiy checking and no way to override this. Now, mb_prealloc_size defaults to the smallest multiple of stripe size that is greater than or equal to the old default mb_prealloc_size, and this can be overridden with the sysfs interface. Signed-off-by: Dan Ehrenberg <dehrenberg@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-11ext4: Fix a double free of sbi->s_group_info in ext4_mb_init_backendTao Ma
If we meet with an error in ext4_mb_add_groupinfo, we kfree sbi->s_group_info[group >> EXT4_DESC_PER_BLOCK_BITS(sb)], but fail to reset it to NULL. So the caller ext4_mb_init_backend will try to kfree it again and causes a double free. So fix it by resetting it to NULL. Some typo in comments of mballoc.c are also changed. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-11ext4: fix a race which could leak memory in ext4_groupinfo_create_slab()Tao Ma
In ext4_groupinfo_create_slab, we create ext4_groupinfo_caches within ext4_grpinfo_slab_create_mutex, but set it outside the lock, and there does exist some case that we may create it twice and causes a memory leak. So set it before we call mutex_unlock. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-11ext4: Change the wrong param comment for ext4_trim_all_freeTao Ma
at ext4_trim_all_free() comment, there is no longer an @e4b parameter, instead it is @group. Reported-by: Andreas Dilger <adilger@dilger.ca> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-11ext4: Speed up FITRIM by recording flags in ext4_group_infoTao Ma
In ext4, when FITRIM is called every time, we iterate all the groups and do trim one by one. It is a bit time wasting if the group has been trimmed and there is no change since the last trim. So this patch adds a new flag in ext4_group_info->bb_state to indicate that the group has been trimmed, and it will be cleared if some blocks is freed(in release_blocks_on_commit). Another trim_minlen is added in ext4_sb_info to record the last minlen we use to trim the volume, so that if the caller provide a small one, we will go on the trim regardless of the bb_state. A simple test with my intel x25m ssd: df -h shows: /dev/sdb1 40G 21G 17G 56% /mnt/ext4 Block size: 4096 run the FITRIM with the following parameter: range.start = 0; range.len = UINT64_MAX; range.minlen = 1048576; without the patch: [root@boyu-tm linux-2.6]# time ./ftrim /mnt/ext4/a real 0m5.505s user 0m0.000s sys 0m1.224s [root@boyu-tm linux-2.6]# time ./ftrim /mnt/ext4/a real 0m5.359s user 0m0.000s sys 0m1.178s [root@boyu-tm linux-2.6]# time ./ftrim /mnt/ext4/a real 0m5.228s user 0m0.000s sys 0m1.151s with the patch: [root@boyu-tm linux-2.6]# time ./ftrim /mnt/ext4/a real 0m5.625s user 0m0.000s sys 0m1.269s [root@boyu-tm linux-2.6]# time ./ftrim /mnt/ext4/a real 0m0.002s user 0m0.000s sys 0m0.001s [root@boyu-tm linux-2.6]# time ./ftrim /mnt/ext4/a real 0m0.002s user 0m0.000s sys 0m0.001s A big improvement for the 2nd and 3rd run. Even after I delete some big image files, it is still much faster than iterating the whole disk. [root@boyu-tm test]# time ./ftrim /mnt/ext4/a real 0m1.217s user 0m0.000s sys 0m0.196s Cc: Lukas Czerner <lczerner@redhat.com> Reviewed-by: Andreas Dilger <adilger.kernel@dilger.ca> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-11ext4: Add new ext4 trim tracepointsTao Ma
Add ext4_trim_extent and ext4_trim_all_free. Reviewed-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-11ext4: speed up group trim with the right free block countTao Ma
When we trim some free blocks in a group of ext4, we need to calculate the free blocks properly and check whether there are enough freed blocks left for us to trim. Current solution will only calculate free spaces if they are large for a trim which isn't appropriate. Let us see a small example: a group has 1.5M free which are 300k, 300k, 300k, 300k, 300k. And minblocks is 1M. With current solution, we have to iterate the whole group since these 300k will never be subtracted from 1.5M. But actually we should exit after we find the first 2 free spaces since the left 3 chunks only sum up to 900K if we subtract the first 600K although they can't be trimed. Reviewed-by: Andreas Dilger <adilger@dilger.ca> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-10ext4: fix trim length underflow with small trim lengthTao Ma
In 0f0a25b, we adjust 'len' with s_first_data_block - start, but it could underflow in case blocksize=1K, fstrim_range.len=512 and fstrim_range.start = 0. In this case, when we run the code: len -= first_data_blk - start; len will be underflow to -1ULL. In the end, although we are safe that last_group check later will limit the trim to the whole volume, but that isn't what the user really want. So this patch fix it. It also adds the check for 'start' like ext3 so that we can break immediately if the start is invalid. Cc: Lukas Czerner <lczerner@redhat.com> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-10ext4: fix i_blocks/quota accounting when extent insertion failsMaxim Patlasov
The current implementation of ext4_free_blocks() always calls dquot_free_block This looks quite sensible in the most cases: blocks to be freed are associated with inode and were accounted in quota and i_blocks some time ago. However, there is a case when blocks to free were not accounted by the time calling ext4_free_blocks() yet: 1. delalloc is on, write_begin pre-allocated some space in quota 2. write-back happens, ext4 allocates some blocks in ext4_ext_map_blocks() 3. then ext4_ext_map_blocks() gets an error (e.g. ENOSPC) from ext4_ext_insert_extent() and calls ext4_free_blocks(). In this scenario, ext4_free_blocks() calls dquot_free_block() who, in turn, decrements i_blocks for blocks which were not accounted yet (due to delalloc) After clean umount, e2fsck reports something like: > Inode 21, i_blocks is 5080, should be 5128. Fix<y>? because i_blocks was erroneously decremented as explained above. The patch fixes the problem by passing the new flag EXT4_FREE_BLOCKS_NO_QUOT_UPDATE to ext4_free_blocks(), to request that the dquot_free_block() call be skipped. Signed-off-by: Maxim Patlasov <maxim.patlasov@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2011-06-28ext4: quiet 'unused variables' compile warningsYongqiang Yang
Unused variables was deleted. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-06-06ext4: fixed tracepoints cleanupLukas Czerner
While creating fixed tracepoints for ext3, basically by porting them from ext4, I found a lot of useless retyping, wrong type usage, useless variable passing and other inconsistencies in the ext4 fixed tracepoint code. This patch cleans the fixed tracepoint code for ext4 and also simplify some of them. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-06-05ext4: correct comments for ext4_free_blocks()Yongqiang Yang
metadata is not parameter of ext4_free_blocks() any more. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-25ext4: add flag to ext4_has_free_blocksAllison Henderson
This patch adds an allocation request flag to the ext4_has_free_blocks function which enables the use of reserved blocks. This will allow a punch hole to proceed even if the disk is full. Punching a hole may require additional blocks to first split the extents. Because ext4_has_free_blocks is a low level function, the flag needs to be passed down through several functions listed below: ext4_ext_insert_extent ext4_ext_create_new_leaf ext4_ext_grow_indepth ext4_ext_split ext4_ext_new_meta_block ext4_mb_new_blocks ext4_claim_free_blocks ext4_has_free_blocks [ext4 punch hole patch series 1/5 v7] Signed-off-by: Allison Henderson <achender@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Mingming Cao <cmm@us.ibm.com>
2011-05-24ext4: protect bb_first_free in ext4_trim_all_free() with group lockLukas Czerner
We should protect reading bd_info->bb_first_free with the group lock because otherwise we might miss some free blocks. This is not a big deal at all, but the change to do right thing is really simple, so lets do that. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-24ext4: only load buddy bitmap in ext4_trim_fs() when it is neededLukas Czerner
Currently we are loading buddy ext4_mb_load_buddy() for every block group we are going through in ext4_trim_fs() in many cases just to find out that there is not enough space to be bothered with. As Amir Goldstein suggested we can use bb_free information directly from ext4_group_info. This commit removes ext4_mb_load_buddy() from ext4_trim_fs() and rather get the ext4_group_info via ext4_get_group_info() and use the bb_free information directly from that. This avoids unnecessary call to load buddy in the case the group does not have enough free space to trim. Loading buddy is now moved to ext4_trim_all_free(). Tested by me with xfstests 251. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-09ext4: remove alloc_sempAmir Goldstein
After taking care of all group init races, all that remains is to remove alloc_semp from ext4_allocation_context and ext4_buddy structs. Signed-off-by: Amir Goldstein <amir73il@users.sf.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-09ext4: teach ext4_mb_init_cache() to skip uptodate buddy cachesAmir Goldstein
After online resize which adds new groups, some of the groups in a buddy page may be initialized and uptodate, while other (new ones) may be uninitialized. The indication for init of new block groups is when ext4_mb_init_cache() is called with an uptodate buddy page. In this case, initialized groups on that buddy page must be skipped when initializing the buddy cache. Signed-off-by: Amir Goldstein <amir73il@users.sf.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-09ext4: synchronize ext4_mb_init_group() with buddy page lockAmir Goldstein
The old routines ext4_mb_[get|put]_buddy_cache_lock(), which used to take grp->alloc_sem for all groups on the buddy page have been replaced with the routines ext4_mb_[get|put]_buddy_page_lock(). The new routines take both buddy and bitmap page locks to protect against concurrent init of groups on the same buddy page. The GROUP_NEED_INIT flag is tested again under page lock to check if the group was initialized by another caller. Signed-off-by: Amir Goldstein <amir73il@users.sf.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-09ext4: implement ext4_add_groupblocks() by freeing blocksAmir Goldstein
The old imlementation used to take grp->alloc_sem and set the GROUP_NEED_INIT flag, so that the buddy cache would be reloaded. The new implementation updates the buddy cache by freeing the added blocks and making them available for use, so there is no need to reload the buddy cache and there is no need to take grp->alloc_sem. Signed-off-by: Amir Goldstein <amir73il@users.sf.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-09ext4: remove unneeded ext4_journal_get_undo_accessTheodore Ts'o
The block allocation code used to use jbd2_journal_get_undo_access as a way to make changes that wouldn't show up until the commit took place. The new multi-block allocation code has a its own way of preventing newly freed blocks from getting reused until the commit takes place (it avoids updating the buddy bitmaps until the commit is done), so we don't need to use jbd2_journal_get_undo_access(), which has extra overhead compared to jbd2_journal_get_write_access(). There was one last vestigal use of ext4_journal_get_undo_access() in ext4_add_groupblocks(); change it to use ext4_journal_get_write_access() and then remove the ext4_journal_get_undo_access() support. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-09ext4: move ext4_add_groupblocks() to mballoc.cAmir Goldstein
In preparation for the next patch, the function ext4_add_groupblocks() is moved to mballoc.c, where it could use some static functions. Signed-off-by: Amir Goldstein <amir73il@users.sf.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-04-30ext4: ignore errors when issuing discardsTheodore Ts'o
This is an effective revert of commit a30eec2a8: "ext4: stop issuing discards if not supported by device". The problem is that there are some devices that may return errors in response to a discard request some times but not others. (One example would be a hybrid dm device which concatenates an SSD and an HDD device). By this logic, I also removed the error checking from ext4's FITRIM code; so that an error from a discard will not stop the FITRIM from trying to trim the rest of the file system. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-04-16ext4: release page cache in ext4_mb_load_buddy error pathYang Ruirui
Add missing page_cache_release in the error path of ext4_mb_load_buddy Signed-off-by: Yang Ruirui <ruirui.r.yang@tieto.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2011-03-23ext4: fix a BUG in mb_mark_used during trim.Tao Ma
In a bs=4096 volume, if we call FITRIM with the following parameter as fstrim_range(start = 102400, len = 134144000, minlen = 10240), we will trigger this BUG_ON: BUG_ON(start + len > (e4b->bd_sb->s_blocksize << 3)); Mar 4 00:55:52 boyu-tm kernel: ------------[ cut here ]------------ Mar 4 00:55:52 boyu-tm kernel: kernel BUG at fs/ext4/mballoc.c:1506! Mar 4 01:21:09 boyu-tm kernel: Code: d4 00 00 00 00 49 89 fe 8b 56 0c 44 8b 7e 04 89 55 c4 48 8b 4f 28 89 d6 44 01 fe 48 63 d6 48 8b 41 18 48 c1 e0 03 48 39 c2 76 04 <0f> 0b eb fe 48 8b 55 b0 8b 47 34 3b 42 08 74 04 0f 0b eb fe 48 Mar 4 01:21:09 boyu-tm kernel: RIP [<ffffffffa053eb42>] mb_mark_used+0x47/0x26c [ext4] Mar 4 01:21:09 boyu-tm kernel: RSP <ffff880121e45c38> Mar 4 01:21:09 boyu-tm kernel: ---[ end trace 9f461696f6a9dcf2 ]--- Fix this bug by doing the accounting correctly. Cc: Lukas Czerner <lczerner@redhat.com> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-03-21ext4: don't kfree uninitialized s_group_info membersEric Sandeen
We can call kfree on uninitialized members of the s_group_info array on an the error path. We can avoid this by kzalloc'ing the array. This doesn't entirely solve the oops on mount if we fail down this path; failed_mount4: frees the sbi, for one, which gets referenced later in the failed mount paths - I haven't worked that out yet. https://bugzilla.kernel.org/show_bug.cgi?id=30872 Reported-by: Eugene A. Shatokhin <dame_eugene@mail.ru> Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-02-27ext4: suppress verbose debugging information if malloc-debug is offTheodore Ts'o
If CONFIG_EXT4_DEBUG is enabled, then if a block allocation fails due to disk being full, a verbose debugging message is printed, even if the malloc-debug switch has not been enabled. Suppress the debugging message so that nothing is printed unless malloc-debug has been turned on. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-02-24ext4: mballoc: don't replace the current preallocation group unnecessarilyColy Li
In ext4_mb_check_group_pa(), the current preallocation space is replaced with a new preallocation space when the two have the same distance from the goal block. This doesn't actually gain us anything, so change things so that the function only switches to the new preallocation group if its distance from the goal block is strictly smaller than the current preallocaiton group's distance from the goal block. Signed-off-by: Coly Li <bosong.ly@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-02-24mballoc: add comments to ext4_mb_mark_free_simple()Coly Li
This patch adds comments to ext4_mb_mark_free_simple to make it more understandable. Signed-off-by: Coly Li <bosong.ly@taobao.com> Cc: Alex Tomas <alex@clusterfs.com> Cc: Theodore Tso <tytso@google.com>
2011-02-24ext4: remove unncessary call mb_find_buddy() in debugging codeColy Li
In __mb_check_buddy(), look at the code below: 591 fstart = -1; 592 buddy = mb_find_buddy(e4b, 0, &max); 593 for (i = 0; i < max; i++) { 594 if (!mb_test_bit(i, buddy)) { 595 MB_CHECK_ASSERT(i >= e4b->bd_info->bb_first_free); 596 if (fstart == -1) { 597 fragments++; 598 fstart = i; 599 } 600 continue; 601 } 602 fstart = -1; 603 /* check used bits only */ 604 for (j = 0; j < e4b->bd_blkbits + 1; j++) { 605 buddy2 = mb_find_buddy(e4b, j, &max2); 606 k = i >> j; 607 MB_CHECK_ASSERT(k < max2); 608 MB_CHECK_ASSERT(mb_test_bit(k, buddy2)); 609 } 610 } 611 MB_CHECK_ASSERT(!EXT4_MB_GRP_NEED_INIT(e4b->bd_info)); 612 MB_CHECK_ASSERT(e4b->bd_info->bb_fragments == fragments); 613 614 grp = ext4_get_group_info(sb, e4b->bd_group); 615 buddy = mb_find_buddy(e4b, 0, &max); On line 592, buddy is fetched by mb_find_buddy() with order 0, between line 593 to line 615, buddy is not changed, therefore there is no need to fetch buddy again from mb_find_buddy() with order 0 again. We can safely remove the second mb_find_buddy() on line 615. Signed-off-by: Coly Li <bosong.ly@taobao.com> Cc: Alex Tomas <alex@clusterfs.com> Cc: Theodore Tso <tytso@google.com>
2011-02-24ext4: code cleanup in mb_find_buddy()Coly Li
Current code calculate max no matter whether order is zero, it's unnecessary. This cleanup patch sets max to "1 << (e4b->bd_blkbits + 3)" only when order == 0. Signed-off-by: Coly Li <bosong.ly@taobao.com> Cc: Alex Tomas <alex@clusterfs.com> Cc: Theodore Tso <tytso@google.com>
2011-02-23ext4: mark file-local functions and variables as staticLukas Czerner
2011-02-12ext4: make grpinfo slab cache names staticEric Sandeen
In 2.6.37 I was running into oopses with repeated module loads & unloads. I tracked this down to: fb1813f4 ext4: use dedicated slab caches for group_info structures (this was in addition to the features advert unload problem) The kstrdup & subsequent kfree of the cache name was causing a double free. In slub, at least, if I read it right it allocates & frees the name itself, slab seems to do something different... so in slub I think we were leaking -our- cachep->name, and double freeing the one allocated by slub. After getting lost in slab/slub/slob a bit, I just looked at other sized-caches that get allocated. jbd2, biovec, sgpool all do it more or less the way jbd2 does. Below patch follows the jbd2 method of dynamically allocating a cache at mount time from a list of static names. (This might also possibly fix a race creating the caches with parallel mounts running). [Folded in a fix from Dan Carpenter which fixed an off-by-one error in the original patch] Cc: stable@kernel.org Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-11ext4: fix trimming starting with block 0 with small blocksizeJan Kara
When s_first_data_block is not zero (which happens e.g. when block size is 1KB) and trim ioctl is called to start trimming from block 0, the math in ext4_get_group_no_and_offset() overflows. The overall result is that ioctl returns EINVAL which is kind of unexpected and we probably don't want userspace tools to bother with internal details of filesystem structure. So just silently increase starting offset (and shorten length) when starting block is below s_first_data_block. CC: Lukas Czerner <lczerner@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-11ext4: revert buggy trim overflow patchTheodore Ts'o
This reverts commit 4f531501e44: ext4: fix possible overflow in ext4_trim_fs() Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext4: remove ext4_mb_return_to_preallocation()Theodore Ts'o
This function was never implemented, except for a BUG_ON which was tripping when ext4 is run without a journal. The problem is that although the comment asserts that "truncate (which is the only way to free block) discards all preallocations", ext4_free_blocks() is also called in various error recovery paths when blocks have been allocated, but for various reasons, we were not able to use those data blocks (for example, because we ran out of memory while trying to manipulate the extent tree, or some other similar situation). In addition to the fact that this function isn't implemented except for the incorrect BUG_ON, the single caller of this function, ext4_free_blocks(), doesn't use it all if the journal is enabled. So remove the (stub) function entirely for now. If we decide it's better to add it back, it's only going to be useful with a relatively large number of code changes anyway. Google-Bug-Id: 3236408 Cc: Jiaying Zhang <jiayingz@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext4: fix trimming of a single groupJan Kara
When ext4_trim_fs() is called to trim a part of a single group, the logic will wrongly set last block of the interval to 'len' instead of 'first_block + len'. Thus a shorter interval is possibly trimmed. Fix it. CC: Lukas Czerner <lczerner@redhat.com> Cc: stable@kernel.org Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext4: replace i_delalloc_reserved_flag with EXT4_STATE_DELALLOC_RESERVEDTheodore Ts'o
Remove the short element i_delalloc_reserved_flag from the ext4_inode_info structure and replace it a new bit in i_state_flags. Since we have an ext4_inode_info for every ext4 inode cached in the inode cache, any savings we can produce here is a very good thing from a memory utilization perspective. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext4: remove warning message from ext4_issue_discard helperLukas Czerner
ext4_issue_discard is supposed to be helper for calling discard, however in case that underlying device does not support discard it prints out the warning message and clears the DISCARD t_mount_opt flag. Since it can be (and is) used by others, it should not do anything and let the caller to handle the error case. This commit removes warning message and flag setting from ext4_issue_discard and use it just in place where it is really needed (release_blocks_on_commit). FITRIM ioctl should not set any flags nor it should print out warning messages, so get rid of the warning as well. Signed-off-by: Lukas Czerner <lczerner@redhat.com>
2011-01-10ext4: fix possible overflow in ext4_trim_fs()Lukas Czerner
When determining last group through ext4_get_group_no_and_offset() the result may be wrong in cases when range->start and range-len are too big, because it may overflow when summing up those two numbers. Fix that by checking range->len and limit its value to ext4_blocks_count(). This commit was tested by myself with expected result. Signed-off-by: Lukas Czerner <lczerner@redhat.com>
