Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
We added some more error handling in b40971426a "ext4: add error
checking to calls to ext4_handle_dirty_metadata()". But we need to
call kfree() as well to avoid a memory leak.
The reserve_backup_gdb() function only needs the block group number;
there's no need to pass a pointer to struct ext4_new_group_data to it.
Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com>
add_new_gdb() only needs the block group number; there is no need to
pass a pointer to struct ext4_new_group_data to add_new_gdb().
Instead of filling in a pointer the struct buffer_head in
add_new_gdb(), it's simpler to have the caller fetch it from the
s_group_desc[] array.
[Fixed error path to handle the case where struct buffer_head *primary
hasn't been set yet. -- Ted]
There is no need to lock the buffers since no one else should be
touching these buffers besides the file system.
This patch simplifies journal handling in setup_new_group_blocks().
In previous code, block bitmap is modified everywhere in
setup_new_group_blocks(), ext4_get_write_access() in
extend_or_restart_transaction() is used to guarantee that the block
bitmap stays in the new handle, this makes things complicated.
The previous commit changed things so that the modifications on the
block bitmap are batched and done by ext4_set_bits() at the end of the
for loop. This allows us to simplify things.
Rename mb_set_bits() to ext4_set_bits() and make it a global function
so that setup_new_group_blocks() can use it.
This patch lets ext4_group_add_blocks() return an error code if it
fails, so that upper functions can handle error correctly.
A filesystem with errors is not allowed to being resized, otherwise,
it is easy to destroy the filesystem.
Before this patch, parallel resizers are allowed and protected by a
mutex lock, actually, there is no need to support parallel resizer, so
this patch prevents parallel resizers by atmoic bit ops, like
lock_page() and unlock_page() do.
To do this, the patch removed the mutex lock s_resize_lock from struct
ext4_sb_info and added a unsigned long field named s_resize_flags
which inidicates if there is a resizer.
There are two wrapper functions which do exactly the same thing:
ext4_journal_release_buffer(), and ext4_handle_release_buffer(). In
addition, ext4_xattr_block_set() calls jbd2_journal_release_buffer()
directly.
Unify all of the code to use ext4_handle_release_buffer(), and get rid
of ext4_journal_release_buffer().
Signed-off-by: Amir Goldstein <amir73il@users.sf.net>
Compile 2.6.38-rc1 with turning EXT4FS_DEBUG on,
we get following compile warnings. This patch fixes them.
CC fs/ext4/hash.o
CC fs/ext4/resize.o
fs/ext4/resize.c: In function 'setup_new_group_blocks':
fs/ext4/resize.c:233:2: warning: format '%#04llx' expects type 'long long
unsigned int', but argument 3 has type 'long unsigned int'
fs/ext4/resize.c:251:2: warning: format '%#04llx' expects type 'long long
CC fs/ext4/extents.o
CC fs/ext4/ext4_jbd2.o
CC fs/ext4/migrate.o
Reported-by: Akira Fujita <a-fujita@rs.jp.nec.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (44 commits)
ext4: fix trimming starting with block 0 with small blocksize
ext4: revert buggy trim overflow patch
ext4: don't pass entire map to check_eofblocks_fl
ext4: fix memory leak in ext4_free_branches
ext4: remove ext4_mb_return_to_preallocation()
ext4: flush the i_completed_io_list during ext4_truncate
ext4: add error checking to calls to ext4_handle_dirty_metadata()
ext4: fix trimming of a single group
ext4: fix uninitialized variable in ext4_register_li_request
ext4: dynamically allocate the jbd2_inode in ext4_inode_info as necessary
ext4: drop i_state_flags on architectures with 64-bit longs
ext4: reorder ext4_inode_info structure elements to remove unneeded padding
ext4: drop ec_type from the ext4_ext_cache structure
ext4: use ext4_lblk_t instead of sector_t for logical blocks
ext4: replace i_delalloc_reserved_flag with EXT4_STATE_DELALLOC_RESERVED
ext4: fix 32bit overflow in ext4_ext_find_goal()
ext4: add more error checks to ext4_mkdir()
ext4: ext4_ext_migrate should use NULL not 0
ext4: Use ext4_error_file() to print the pathname to the corrupted inode
ext4: use IS_ERR() to check for errors in ext4_error_file
Call ext4_std_error() in various places when we can't bail out
cleanly, so the file system can be marked as in error.
https://bugzilla.kernel.org/show_bug.cgi?id=25352
This regression was caused by commit a31437b85: "ext4: use
sb_issue_zeroout in setup_new_group_blocks", by accidentally dropping
the code which reserved the block group descriptor and inode table
blocks.
fs/ext4/inode.c
fs/ext4/mballoc.c
include/trace/events/ext4.h
Fix a namespace leak from fs/ext4
Use sb_issue_zeroout to zero out inode table and descriptor table
blocks instead of old approach which involves journaling.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
No real bugs found, just removed some dead code.
Found by gcc 4.6's new warnings.
We don't need to set s_dirt in most of the ext4 code when journaling
is enabled. In ext3/4 some of the summary statistics for # of free
inodes, blocks, and directories are calculated from the per-block
group statistics when the file system is mounted or unmounted. As a
result the superblock doesn't have to be updated, either via the
journal or by setting s_dirt. There are a few exceptions, most
notably when resizing the file system, where the superblock needs to
be modified --- and in that case it should be done as a journalled
operation if possible, and s_dirt set only in no-journal mode.
This patch will optimize out some unneeded disk writes when using ext4
with a journal.
If groups_per_flex < 2, sbi->s_flex_groups[] doesn't get filled out,
and every other access to this first tests s_log_groups_per_flex;
same thing needs to happen in resize or we'll wander off into
a null pointer when doing an online resize of the file system.
Thanks to Christoph Biedl, who came up with the trivial testcase:
# truncate --size 128M fsfile
# mkfs.ext3 -F fsfile
# tune2fs -O extents,uninit_bg,dir_index,flex_bg,huge_file,dir_nlink,extra_isize fsfile
# e2fsck -yDf -C0 fsfile
# truncate --size 132M fsfile
# losetup /dev/loop0 fsfile
# mount /dev/loop0 mnt
# resize2fs -p /dev/loop0
https://bugzilla.kernel.org/show_bug.cgi?id=13549
Reported-by: Alessandro Polverini <alex@nibbles.it>
Test-case-by: Christoph Biedl <bugzilla.kernel.bpeb@manchmal.in-ulm.de>
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Just a pet peeve of mine; we had a mishash of calls with either __func__
or "function_name" and the latter tends to get out of sync.
I think it's easier to just hide the __func__ in a macro, and it'll
be consistent from then on.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
We don't need to take the alloc_sem lock when we are adding new
groups, since mballoc won't see the new group added until we bump
sbi->s_groups_count.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Follow-up to "block: enable by default support for large devices
and files on 32-bit archs".
Rename CONFIG_LBD to CONFIG_LBDAF to:
- allow update of existing [def]configs for "default y" change
- reflect that it is used also for large files support nowadays
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Move the function prototypes in group.h into ext4.h so they are all
defined in one place.
Use a separate lock to protect s_groups_count and the other block
group descriptors which get changed via an on-line resize operation,
so we can stop overloading the use of lock_super().
Reduce pressure on the sb_bgl_lock family of locks by using atomic_t's
to track the number of free blocks and inodes in each flex_group.
Make sure all of the fields of the group descriptor are properly
initialized. Previously, we allowed bg_flags field to be contain
random garbage, which could trigger non-deterministic behavior,
including a kernel OOPS.
http://bugzilla.kernel.org/show_bug.cgi?id=12433
Cc: stable@kernel.org
We need to mark the block/inode bitmap beyond the end of the group
with '1'.
Rename the lower bits with suffix _lo and add helper
to access the values. Also rename bg_itable_unused_hi
to bg_pad as in e2fsprogs.
The new groups added during resize are flagged as
need_init group. Make sure we properly initialize these
groups. When we have block size < page size and we are adding
new groups the page may still be marked uptodate even though
we haven't initialized the group. While forcing the init
of buddy cache we need to make sure other groups part of the
same page of buddy cache is not using the cache.
group_info->alloc_sem is added to ensure the same.
cc: stable@kernel.org
With this change new blocks added during resize
are marked as free in the block bitmap and the
group is flagged with EXT4_GROUP_INFO_NEED_INIT_BIT
flag. This makes sure when mballoc tries to allocate
blocks from the new group we would reload the
buddy information using the bitmap present in the disk.
Nearly all places in the ext3/4 code which uses "unsigned long" is
probably a bug, since on 32-bit systems a ulong a 32-bits, which means
we are wasting stack space on 64-bit systems.
This removes annoying blank syslog entries emitted by ext4_error() or
ext4_warning(), since these functions add their own newline.
Signed-off-by: Nick Warne <nick@ukfsn.org>
A few weeks ago I posted a patch for discussion that allowed ext4 to run
without a journal. Since that time I've integrated the excellent
comments from Andreas and fixed several serious bugs. We're currently
running with this patch and generating some performance numbers against
both ext2 (with backported reservations code) and ext4 with and without
a journal. It just so happens that running without a journal is
slightly faster for most everything.
We did
iozone -T -t 4 s 2g -r 256k -T -I -i0 -i1 -i2
which creates 4 threads, each of which create and do reads and writes on
a 2G file, with a buffer size of 256K, using O_DIRECT for all file opens
to bypass the page cache. Results:
ext2 ext4, default ext4, no journal
initial writes 13.0 MB/s 15.4 MB/s 15.7 MB/s
rewrites 13.1 MB/s 15.6 MB/s 15.9 MB/s
reads 15.2 MB/s 16.9 MB/s 17.2 MB/s
re-reads 15.3 MB/s 16.9 MB/s 17.2 MB/s
random readers 5.6 MB/s 5.6 MB/s 5.7 MB/s
random writers 5.1 MB/s 5.3 MB/s 5.4 MB/s
So it seems that, so far, this was a useful exercise.
Signed-off-by: Frank Mayhar <fmayhar@google.com>
The inode table has been zeroed in setup_new_group_blocks(). Mark it as
such in ext4_group_add(). Since we are currently clearing inode table
for the new block group, we should set the EXT4_BG_INODE_ZEROED flag.
If at some point in the future we don't immediately zero out the inode
table as part of the resize operation, then obviously we shouldn't do
this.
Signed-off-by: Solofo.Ramangalahy@bull.net
This fixes a bug which prevented the newly created inodes after a
resize from being used on filesystems with flex_bg.
Signed-off-by: Frederic Bohe <frederic.bohe@bull.net>
When trying to resize an ext4 fs and you run out of reserved gdt blocks,
you get an error that doesn't actually tell you what went wrong, it just
says that the gdb it picked is not correct, which is the case since you
don't have any reserved gdt blocks left. This patch adds a check to make
sure you have reserved gdt blocks to use, and if not prints out a more
relevant error.
Signed-off-by: Josef Bacik <jbacik@redhat.com>
Cc: <linux-ext4@vger.kernel.org>
Cc: Andreas Dilger <adilger@sun.com>
Update group infos when updating a group's descriptor.
Add group infos when adding a group's descriptor.
Refresh cache pages used by mb_alloc when changes occur.
This will probably need modifications when META_BG resizing will be allowed.
Signed-off-by: Mingming Cao <cmm@us.ibm.com>
This is the patch for the group descriptor table corruption during
online resize pointed out by Theodore Tso. The problem was caused by
the fact that the ext4 group descriptor can be either 32 or 64 bytes
long. Only the 64 bytes structure was taken into account.
There is a bug when we are trying to verify that the reserve inode's
double indirect blocks point back to the primary gdt blocks. The fix is
obvious, we need to mod the gdb count by the addr's per block. This was
verified using the same testcase as with the ext3 equivalent of this
patch.
Move ext4 headers out of include/linux. This is just the trivial move,
there's some more thing that could be done later.
This fixes the allocations with GFP_KERNEL while under a transaction problems
in ext4. This patch is the same as its ext3 counterpart, just switches these
to GFP_NOFS.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
