commit 5a0dc7365c240795bf190766eba7a27600be3b3e upstream.
We need to zero out part of a page which beyond EOF before setting uptodate,
otherwise, mapread or write will see non-zero data beyond EOF.
Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 13a79a4741d37fda2fbafb953f0f301dc007928f upstream.
If there is an unwritten but clean buffer in a page and there is a
dirty buffer after the buffer, then mpage_submit_io does not write the
dirty buffer out. As a result, da_writepages loops forever.
This patch fixes the problem by checking dirty flag.
commit ea51d132dbf9b00063169c1159bee253d9649224 upstream.
If the pte mapping in generic_perform_write() is unmapped between
iov_iter_fault_in_readable() and iov_iter_copy_from_user_atomic(), the
"copied" parameter to ->end_write can be zero. ext4 couldn't cope with
it with delayed allocations enabled. This skips the i_disksize
enlargement logic if copied is zero and no new data was appeneded to
the inode.
gdb> bt
#0 0xffffffff811afe80 in ext4_da_should_update_i_disksize (file=0xffff88003f606a80, mapping=0xffff88001d3824e0, pos=0x1\
08000, len=0x1000, copied=0x0, page=0xffffea0000d792e8, fsdata=0x0) at fs/ext4/inode.c:2467
#1 ext4_da_write_end (file=0xffff88003f606a80, mapping=0xffff88001d3824e0, pos=0x108000, len=0x1000, copied=0x0, page=0\
xffffea0000d792e8, fsdata=0x0) at fs/ext4/inode.c:2512
#2 0xffffffff810d97f1 in generic_perform_write (iocb=<value optimized out>, iov=<value optimized out>, nr_segs=<value o\
ptimized out>, pos=0x108000, ppos=0xffff88001e26be40, count=<value optimized out>, written=0x0) at mm/filemap.c:2440
#3 generic_file_buffered_write (iocb=<value optimized out>, iov=<value optimized out>, nr_segs=<value optimized out>, p\
os=0x108000, ppos=0xffff88001e26be40, count=<value optimized out>, written=0x0) at mm/filemap.c:2482
#4 0xffffffff810db5d1 in __generic_file_aio_write (iocb=0xffff88001e26bde8, iov=0xffff88001e26bec8, nr_segs=0x1, ppos=0\
xffff88001e26be40) at mm/filemap.c:2600
#5 0xffffffff810db853 in generic_file_aio_write (iocb=0xffff88001e26bde8, iov=0xffff88001e26bec8, nr_segs=<value optimi\
zed out>, pos=<value optimized out>) at mm/filemap.c:2632
#6 0xffffffff811a71aa in ext4_file_write (iocb=0xffff88001e26bde8, iov=0xffff88001e26bec8, nr_segs=0x1, pos=0x108000) a\
t fs/ext4/file.c:136
#7 0xffffffff811375aa in do_sync_write (filp=0xffff88003f606a80, buf=<value optimized out>, len=<value optimized out>, \
ppos=0xffff88001e26bf48) at fs/read_write.c:406
#8 0xffffffff81137e56 in vfs_write (file=0xffff88003f606a80, buf=0x1ec2960 <Address 0x1ec2960 out of bounds>, count=0x4\
000, pos=0xffff88001e26bf48) at fs/read_write.c:435
#9 0xffffffff8113816c in sys_write (fd=<value optimized out>, buf=0x1ec2960 <Address 0x1ec2960 out of bounds>, count=0x\
4000) at fs/read_write.c:487
#10 <signal handler called>
#11 0x00007f120077a390 in __brk_reservation_fn_dmi_alloc__ ()
#12 0x0000000000000000 in ?? ()
gdb> print offset
$22 = 0xffffffffffffffff
gdb> print idx
$23 = 0xffffffff
gdb> print inode->i_blkbits
$24 = 0xc
gdb> up
2512 if (ext4_da_should_update_i_disksize(page, end)) {
gdb> print start
$25 = 0x0
gdb> print end
$26 = 0xffffffffffffffff
gdb> print pos
$27 = 0x108000
gdb> print new_i_size
$28 = 0x108000
gdb> print ((struct ext4_inode_info *)((char *)inode-((int)(&((struct ext4_inode_info *)0)->vfs_inode))))->i_disksize
$29 = 0xd9000
gdb> down
2467 for (i = 0; i < idx; i++)
gdb> print i
$30 = 0xd44acbee
This is 100% reproducible with some autonuma development code tuned in
a very aggressive manner (not normal way even for knumad) which does
"exotic" changes to the ptes. It wouldn't normally trigger but I don't
see why it can't happen normally if the page is added to swap cache in
between the two faults leading to "copied" being zero (which then
hangs in ext4). So it should be fixed. Especially possible with lumpy
reclaim (albeit disabled if compaction is enabled) as that would
ignore the young bits in the ptes.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
commit fc6cb1cda5db7b2d24bf32890826214b857c728e upstream.
/proc/mounts was showing the mount option [no]init_inode_table when
the correct mount option that will be accepted by parse_options() is
[no]init_itable.
commit b5a7e97039a80fae673ccc115ce595d5b88fb4ee upstream.
We need to make sure iocb->private is cleared *before* we put the
io_end structure on i_completed_io_list. Otherwise fsync() could
potentially run on another CPU and free the iocb structure out from
under us.
Reported-by: Kent Overstreet <koverstreet@google.com>
commit 4c81f045c0bd2cbb78cc6446a4cd98038fe11a2e upstream.
ext4_end_io_dio() queues io_end->work and then clears iocb->private;
however, io_end->work calls aio_complete() which frees the iocb
object. If that slab object gets reallocated, then ext4_end_io_dio()
can end up clearing someone else's iocb->private, this use-after-free
can cause a leak of a struct ext4_io_end_t structure.
Detected and tested with slab poisoning.
[ Note: Can also reproduce using 12 fio's against 12 file systems with the
following configuration file:
[global]
direct=1
ioengine=libaio
iodepth=1
bs=4k
ba=4k
size=128m
[create]
filename=${TESTDIR}
rw=write
-- tytso ]
Google-Bug-Id: 5354697
Tested-by: Kent Overstreet <koverstreet@google.com>
commit 6d6a435190bdf2e04c9465cde5bdc3ac68cf11a4 upstream.
Ceph users reported that when using Ceph on ext4, the filesystem
would often become corrupted, containing inodes with incorrect
i_blocks counters.
I managed to reproduce this with a very hacked-up "streamtest"
binary from the Ceph tree.
Ceph is doing a lot of xattr writes, to out-of-inode blocks.
There is also another thread which does sync_file_range and close,
of the same files. The problem appears to happen due to this race:
sync/flush thread xattr-set thread
do_writepages ext4_xattr_set
ext4_da_writepages ext4_xattr_set_handle
mpage_da_map_blocks ext4_xattr_block_set
set DELALLOC_RESERVE
ext4_new_meta_blocks
ext4_mb_new_blocks
if (!i_delalloc_reserved_flag)
vfs_dq_alloc_block
ext4_get_blocks
down_write(i_data_sem)
set i_delalloc_reserved_flag
up_write(i_data_sem)
if (i_delalloc_reserved_flag)
vfs_dq_alloc_block_nofail
In other words, the sync/flush thread pops in and sets
i_delalloc_reserved_flag on the inode, which makes the xattr thread
think that it's in a delalloc path in ext4_new_meta_blocks(),
and add the block for a second time, after already having added
it once in the !i_delalloc_reserved_flag case in ext4_mb_new_blocks
The real problem is that we shouldn't be using the DELALLOC_RESERVED
state flag, and instead we should be passing
EXT4_GET_BLOCKS_DELALLOC_RESERVE down to ext4_map_blocks() instead of
using an inode state flag. We'll fix this for now with using
i_data_sem to prevent this race, but this is really not the right way
to fix things.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
commit fcbb5515825f1bb20b7a6f75ec48bee61416f879 upstream.
The started journal handle should be stopped in failure case.
Acked-by: Jan Kara <jack@suse.cz>
commit 5930ea643805feb50a2f8383ae12eb6f10935e49 upstream.
ext4_dx_add_entry manipulates bh2 and frames[0].bh, which are two buffer_heads
that point to directory blocks assigned to the directory inode. However, the
function calls ext4_handle_dirty_metadata with the inode of the file that's
being added to the directory, not the directory inode itself. Therefore,
correct the code to dirty the directory buffers with the directory inode, not
the file inode.
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
commit f9287c1f2d329f4d78a3bbc9cf0db0ebae6f146a upstream.
ext4_mkdir calls ext4_handle_dirty_metadata with dir_block and the inode "dir".
Unfortunately, dir_block belongs to the newly created directory (which is
"inode"), not the parent directory (which is "dir"). Fix the incorrect
association.
commit bcaa992975041e40449be8c010c26192b8c8b409 upstream.
When ext4_rename performs a directory rename (move), dir_bh is a
buffer that is modified to update the '..' link in the directory being
moved (old_inode). However, ext4_handle_dirty_metadata is called with
the old parent directory inode (old_dir) and dir_bh, which is
incorrect because dir_bh does not belong to the parent inode. Fix
this error.
commit 1cd9f0976aa4606db8d6e3dc3edd0aca8019372a upstream.
This doesn't make much sense, and it exposes a bug in the kernel where
attempts to create a new file in an append-only directory using
O_CREAT will fail (but still leave a zero-length file). This was
discovered when xfstests #79 was generalized so it could run on all
file systems.
* 'for-linus' of git://git.kernel.dk/linux-block:
floppy: use del_timer_sync() in init cleanup
blk-cgroup: be able to remove the record of unplugged device
block: Don't check QUEUE_FLAG_SAME_COMP in __blk_complete_request
mm: Add comment explaining task state setting in bdi_forker_thread()
mm: Cleanup clearing of BDI_pending bit in bdi_forker_thread()
block: simplify force plug flush code a little bit
block: change force plug flush call order
block: Fix queue_flag update when rq_affinity goes from 2 to 1
block: separate priority boosting from REQ_META
block: remove READ_META and WRITE_META
xen-blkback: fixed indentation and comments
xen-blkback: Don't disconnect backend until state switched to XenbusStateClosed.
The i_mutex lock and flush_completed_IO() added by commit 2581fdc810
in ext4_evict_inode() causes lockdep complaining about potential
deadlock in several places. In most/all of these LOCKDEP complaints
it looks like it's a false positive, since many of the potential
circular locking cases can't take place by the time the
ext4_evict_inode() is called; but since at the very least it may mask
real problems, we need to address this.
This change removes the flush_completed_IO() and i_mutex lock in
ext4_evict_inode(). Instead, we take a different approach to resolve
the software lockup that commit 2581fdc810 intends to fix. Rather
than having ext4-dio-unwritten thread wait for grabing the i_mutex
lock of an inode, we use mutex_trylock() instead, and simply requeue
the work item if we fail to grab the inode's i_mutex lock.
This should speed up work queue processing in general and also
prevents the following deadlock scenario: During page fault,
shrink_icache_memory is called that in turn evicts another inode B.
Inode B has some pending io_end work so it calls ext4_ioend_wait()
that waits for inode B's i_ioend_count to become zero. However, inode
B's ioend work was queued behind some of inode A's ioend work on the
same cpu's ext4-dio-unwritten workqueue. As the ext4-dio-unwritten
thread on that cpu is processing inode A's ioend work, it tries to
grab inode A's i_mutex lock. Since the i_mutex lock of inode A is
still hold before the page fault happened, we enter a deadlock.
Signed-off-by: Jiaying Zhang <jiayingz@google.com>
Add a new REQ_PRIO to let requests preempt others in the cfq I/O schedule,
and lave REQ_META purely for marking requests as metadata in blktrace.
All existing callers of REQ_META except for XFS are updated to also
set REQ_PRIO for now.
Reviewed-by: Namhyung Kim <namhyung@gmail.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Replace all occurnanced of the undocumented READ_META with READ | REQ_META
and remove the unused WRITE_META define.
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: flush any pending end_io requests before DIO reads w/dioread_nolock
ext4: fix nomblk_io_submit option so it correctly converts uninit blocks
ext4: Resolve the hang of direct i/o read in handling EXT4_IO_END_UNWRITTEN.
ext4: call ext4_ioend_wait and ext4_flush_completed_IO in ext4_evict_inode
ext4: Fix ext4_should_writeback_data() for no-journal mode
There is a race between ext4 buffer write and direct_IO read with
dioread_nolock mount option enabled. The problem is that we clear
PageWriteback flag during end_io time but will do
uninitialized-to-initialized extent conversion later with dioread_nolock.
If an O_direct read request comes in during this period, ext4 will return
zero instead of the recently written data.
This patch checks whether there are any pending uninitialized-to-initialized
extent conversion requests before doing O_direct read to close the race.
Note that this is just a bandaid fix. The fundamental issue is that we
clear PageWriteback flag before we really complete an IO, which is
problem-prone. To fix the fundamental issue, we may need to implement an
extent tree cache that we can use to look up pending to-be-converted extents.
Cc: stable@kernel.org
Bug discovered by Jan Kara:
Finally, commit 1449032be17abb69116dbc393f67ceb8bd034f92 returned back
the old IO submission code but apparently it forgot to return the old
handling of uninitialized buffers so we unconditionnaly call
block_write_full_page() without specifying end_io function. So AFAICS
we never convert unwritten extents to written in some cases. For
example when I mount the fs as: mount -t ext4 -o
nomblk_io_submit,dioread_nolock /dev/ubdb /mnt and do
int fd = open(argv[1], O_RDWR | O_CREAT | O_TRUNC, 0600);
char buf[1024];
memset(buf, 'a', sizeof(buf));
fallocate(fd, 0, 0, 16384);
write(fd, buf, sizeof(buf));
I get a file full of zeros (after remounting the filesystem so that
pagecache is dropped) instead of seeing the first KB contain 'a's.
EXT4_IO_END_UNWRITTEN flag set and the increase of i_aiodio_unwritten
should be done simultaneously since ext4_end_io_nolock always clear
the flag and decrease the counter in the same time.
We don't increase i_aiodio_unwritten when setting
EXT4_IO_END_UNWRITTEN so it will go nagative and causes some process
to wait forever.
Part of the patch came from Eric in his e-mail, but it doesn't fix the
problem met by Michael actually.
http://marc.info/?l=linux-ext4&m=131316851417460&w=2
Reported-and-Tested-by: Michael Tokarev<mjt@tls.msk.ru>
Signed-off-by: Tao Ma <boyu.mt@taobao.com>
Flush inode's i_completed_io_list before calling ext4_io_wait to
prevent the following deadlock scenario: A page fault happens while
some process is writing inode A. During page fault,
B. Inode B has some pending io_end work so it calls ext4_ioend_wait()
Also moves ext4_flush_completed_IO and ext4_ioend_wait from
ext4_destroy_inode() to ext4_evict_inode(). During inode deleteion,
ext4_evict_inode() is called before ext4_destroy_inode() and in
ext4_evict_inode(), we may call ext4_truncate() without holding
i_mutex lock. As a result, there is a race between flush_completed_IO
that is called from ext4_ext_truncate() and ext4_end_io_work, which
may cause corruption on an io_end structure. This change moves
ext4_flush_completed_IO and ext4_ioend_wait from ext4_destroy_inode()
to ext4_evict_inode() to resolve the race between ext4_truncate() and
ext4_end_io_work during inode deletion.
ext4_should_writeback_data() had an incorrect sequence of
tests to determine if it should return 0 or 1: in
particular, even in no-journal mode, 0 was being returned
for a non-regular-file inode.
This meant that, in non-journal mode, we would use
ext4_journalled_aops for directories, symlinks, and other
non-regular files. However, calling journalled aop
callbacks when there is no valid handle, can cause problems.
This would cause a kernel crash with Jan Kara's commit
2d859db3e4 ("ext4: fix data corruption in inodes with
journalled data"), because we now dereference 'handle' in
ext4_journalled_write_end().
I also added BUG_ONs to check for a valid handle in the
obviously journal-only aops callbacks.
I tested this running xfstests with a scratch device in
these modes:
- no-journal
- data=ordered
- data=writeback
- data=journal
All work fine; the data=journal run has many failures and a
crash in xfstests 074, but this is no different from a
vanilla kernel.
Signed-off-by: Curt Wohlgemuth <curtw@google.com>
Commit df5e6223407e ("ext4: fix deadlock in ext4_symlink() in ENOSPC
conditions") recalculated the number of credits needed for a long
symlink, in the process of splitting it into two transactions. However,
the first credit calculation under-counted because if selinux is
enabled, credits are needed to create the selinux xattr as well.
Overrunning the reservation will result in an OOPS in
jbd2_journal_dirty_metadata() due to this assert:
J_ASSERT_JH(jh, handle->h_buffer_credits > 0);
Fix this by increasing the reservation size.
Acked-by: "Theodore Ts'o" <tytso@mit.edu>
Commit 9933fc0i (ext4: introduce ext4_kvmalloc(), ext4_kzalloc(), and
ext4_kvfree()) intruduced wrappers around k*alloc/vmalloc but introduced
a typo for ext4_kzalloc() by not using kzalloc() but kmalloc().
Signed-off-by: Mathias Krause <minipli@googlemail.com>
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (60 commits)
ext4: prevent memory leaks from ext4_mb_init_backend() on error path
ext4: use EXT4_BAD_INO for buddy cache to avoid colliding with valid inode #
ext4: use ext4_msg() instead of printk in mballoc
ext4: use ext4_kvzalloc()/ext4_kvmalloc() for s_group_desc and s_group_info
ext4: introduce ext4_kvmalloc(), ext4_kzalloc(), and ext4_kvfree()
ext4: use the correct error exit path in ext4_init_inode_table()
ext4: add missing kfree() on error return path in add_new_gdb()
ext4: change umode_t in tracepoint headers to be an explicit __u16
ext4: fix races in ext4_sync_parent()
ext4: Fix overflow caused by missing cast in ext4_fallocate()
ext4: add action of moving index in ext4_ext_rm_idx for Punch Hole
ext4: simplify parameters of reserve_backup_gdb()
ext4: simplify parameters of add_new_gdb()
ext4: remove lock_buffer in bclean() and setup_new_group_blocks()
ext4: simplify journal handling in setup_new_group_blocks()
ext4: let setup_new_group_blocks() set multiple bits at a time
ext4: fix a typo in ext4_group_extend()
ext4: let ext4_group_add_blocks() handle 0 blocks quickly
ext4: let ext4_group_add_blocks() return an error code
ext4: rename ext4_add_groupblocks() to ext4_group_add_blocks()
Fix up conflict in fs/ext4/inode.c: commit aacfc19c626e ("fs: simplify
the blockdev_direct_IO prototype") had changed the ext4_ind_direct_IO()
function for the new simplified calling convention, while commit
dae1e52cb126 ("ext4: move ext4_ind_* functions from inode.c to
indirect.c") moved the function to another file.
In ext4_mb_init(), if the s_locality_group allocation fails it will
currently cause the allocations made in ext4_mb_init_backend() to
be leaked. Moving the ext4_mb_init_backend() allocation after the
s_locality_group allocation avoids that problem.
Signed-off-by: Yu Jian <yujian@whamcloud.com>
Signed-off-by: Andreas Dilger <adilger@whamcloud.com>
Introduce new helper functions which try kmalloc, and then fall back
to vmalloc if necessary, and use them for allocating and deallocating
s_flex_groups.
This patch lets ext4_init_inode_table() handle errors right.
ext4_init_inode_table() should down_write() alloc_sem which
has been up_write()ed and stop the started journal handle.
... so that &inode->i_mode could be passed to it
so we can pass &inode->i_mode to it
We added some more error handling in b40971426a "ext4: add error
checking to calls to ext4_handle_dirty_metadata()". But we need to
call kfree() as well to avoid a memory leak.
Fix problems if fsync() races against a rename of a parent directory
as pointed out by Al Viro in his own inimitable way:
>While we are at it, could somebody please explain what the hell is ext4
>doing in
>static int ext4_sync_parent(struct inode *inode)
> struct writeback_control wbc;
> struct dentry *dentry = NULL;
> int ret = 0;
> while (inode && ext4_test_inode_state(inode, EXT4_STATE_NEWENTRY)) {
> ext4_clear_inode_state(inode, EXT4_STATE_NEWENTRY);
> dentry = list_entry(inode->i_dentry.next,
> struct dentry, d_alias);
> if (!dentry || !dentry->d_parent || !dentry->d_parent->d_inode)
> break;
> inode = dentry->d_parent->d_inode;
> ret = sync_mapping_buffers(inode->i_mapping);
>Note that dentry obviously can't be NULL there. dentry->d_parent is never
>NULL. And dentry->d_parent would better not be negative, for crying out
>loud! What's worse, there's no guarantees that dentry->d_parent will
>remain our parent over that sync_mapping_buffers() *and* that inode won't
>just be freed under us (after rename() and memory pressure leading to
>eviction of what used to be our dentry->d_parent)......
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
The logical block number in map.l_blk is a __u32, and so before we
shift it left, by the block size, we neeed cast it to a 64-bit size.
Otherwise i_size can be corrupted on an ENOSPC.
# df -T /mnt/mp1
Filesystem Type 1K-blocks Used Available Use% Mounted on
/dev/sda6 ext4 9843276 153056 9190200 2% /mnt/mp1
# fallocate -o 0 -l 2199023251456 /mnt/mp1/testfile
fallocate: /mnt/mp1/testfile: fallocate failed: No space left on device
# stat /mnt/mp1/testfile
File: `/mnt/mp1/testfile'
Size: 4293656576 Blocks: 19380440 IO Block: 4096 regular file
Device: 806h/2054d Inode: 12 Links: 1
Access: (0644/-rw-r--r--) Uid: ( 0/ root) Gid: ( 0/ root)
Access: 2011-07-25 13:01:31.414490496 +0900
Modify: 2011-07-25 13:01:31.414490496 +0900
Change: 2011-07-25 13:01:31.454490495 +0900
Signed-off-by: Utako Kusaka <u-kusaka@wm.jp.nec.com>
fs/ext4/extents.c | 2 +-
1 files changed, 1 insertions(+), 1 deletions(-)
The old function ext4_ext_rm_idx is used only for truncate case
because it just remove last index in extent-index-block. When punching
hole, it usually needed to remove "middle" index, therefore we must
move indexes which after it forward.
(I create a file with 1 depth extent tree and punch hole in the middle
of it, the last index in index-block strangly gone, so I find out this
bug)
Signed-off-by: Robin Dong <sanbai@taobao.com>
The reserve_backup_gdb() function only needs the block group number;
there's no need to pass a pointer to struct ext4_new_group_data to it.
add_new_gdb() only needs the block group number; there is no need to
pass a pointer to struct ext4_new_group_data to add_new_gdb().
Instead of filling in a pointer the struct buffer_head in
add_new_gdb(), it's simpler to have the caller fetch it from the
s_group_desc[] array.
[Fixed error path to handle the case where struct buffer_head *primary
hasn't been set yet. -- Ted]
There is no need to lock the buffers since no one else should be
touching these buffers besides the file system.
This patch simplifies journal handling in setup_new_group_blocks().
In previous code, block bitmap is modified everywhere in
setup_new_group_blocks(), ext4_get_write_access() in
extend_or_restart_transaction() is used to guarantee that the block
bitmap stays in the new handle, this makes things complicated.
The previous commit changed things so that the modifications on the
block bitmap are batched and done by ext4_set_bits() at the end of the
for loop. This allows us to simplify things.
Rename mb_set_bits() to ext4_set_bits() and make it a global function
so that setup_new_group_blocks() can use it.
If ext4_group_add_blocks() is called with 0 block, make it return 0
without doing any extra work.
This patch lets ext4_group_add_blocks() return an error code if it
fails, so that upper functions can handle error correctly.
A filesystem with errors is not allowed to being resized, otherwise,
it is easy to destroy the filesystem.
Before this patch, parallel resizers are allowed and protected by a
mutex lock, actually, there is no need to support parallel resizer, so
this patch prevents parallel resizers by atmoic bit ops, like
lock_page() and unlock_page() do.
To do this, the patch removed the mutex lock s_resize_lock from struct
ext4_sb_info and added a unsigned long field named s_resize_flags
which inidicates if there is a resizer.
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback: (27 commits)
mm: properly reflect task dirty limits in dirty_exceeded logic
writeback: don't busy retry writeback on new/freeing inodes
writeback: scale IO chunk size up to half device bandwidth
writeback: trace global_dirty_state
writeback: introduce max-pause and pass-good dirty limits
writeback: introduce smoothed global dirty limit
writeback: consolidate variable names in balance_dirty_pages()
writeback: show bdi write bandwidth in debugfs
writeback: bdi write bandwidth estimation
writeback: account per-bdi accumulated written pages
writeback: make writeback_control.nr_to_write straight
writeback: skip tmpfs early in balance_dirty_pages_ratelimited_nr()
writeback: trace event writeback_queue_io
writeback: trace event writeback_single_inode
writeback: remove .nonblocking and .encountered_congestion
writeback: remove writeback_control.more_io
writeback: skip balance_dirty_pages() for in-memory fs
writeback: add bdi_dirty_limit() kernel-doc
writeback: avoid extra sync work at enqueue time
writeback: elevate queue_io() into wb_writeback()
Fix up trivial conflicts in fs/fs-writeback.c and mm/filemap.c
When journalling data for an inode (either because it is a symlink or
because the filesystem is mounted in data=journal mode), ext4_evict_inode()
can discard unwritten data by calling truncate_inode_pages(). This is
because we don't mark the buffer / page dirty when journalling data but only
add the buffer to the running transaction and thus mm does not know there
are still unwritten data.
Fix the problem by carefully tracking transaction containing inode's data,
committing this transaction, and writing uncheckpointed buffers when inode
should be reaped.
