path: root/fs/ext4
2012-01-24Merge branch 'linux-3.1.y' into android-tegra-nv-3.1Varun Wadekar
Linux 3.1.10 Change-Id: I465d184c492e8041dd0cd90f2cb70fde17ba7118 Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-18ext4: fix undefined behavior in ext4_fill_flex_info()Xi Wang
commit d50f2ab6f050311dbf7b8f5501b25f0bf64a439b upstream. Commit 503358ae01b70ce6909d19dd01287093f6b6271c ("ext4: avoid divide by zero when trying to mount a corrupted file system") fixes CVE-2009-4307 by performing a sanity check on s_log_groups_per_flex, since it can be set to a bogus value by an attacker. sbi->s_log_groups_per_flex = sbi->s_es->s_log_groups_per_flex; groups_per_flex = 1 << sbi->s_log_groups_per_flex; if (groups_per_flex < 2) { ... } This patch fixes two potential issues in the previous commit. 1) The sanity check might only work on architectures like PowerPC. On x86, 5 bits are used for the shifting amount. That means, given a large s_log_groups_per_flex value like 36, groups_per_flex = 1 << 36 is essentially 1 << 4 = 16, rather than 0. This will bypass the check, leaving s_log_groups_per_flex and groups_per_flex inconsistent. 2) The sanity check relies on undefined behavior, i.e., oversized shift. A standard-confirming C compiler could rewrite the check in unexpected ways. Consider the following equivalent form, assuming groups_per_flex is unsigned for simplicity. groups_per_flex = 1 << sbi->s_log_groups_per_flex; if (groups_per_flex == 0 || groups_per_flex == 1) { We compile the code snippet using Clang 3.0 and GCC 4.6. Clang will completely optimize away the check groups_per_flex == 0, leaving the patched code as vulnerable as the original. GCC keeps the check, but there is no guarantee that future versions will do the same. Signed-off-by: Xi Wang <xi.wang@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-05Linux 3.1.7Varun Wadekar
Change-Id: I99507d7cfdcee064f808856dc2ce99d806fd864f
2011-12-21ext4: handle EOF correctly in ext4_bio_write_page()Yongqiang Yang
commit 5a0dc7365c240795bf190766eba7a27600be3b3e upstream. We need to zero out part of a page which beyond EOF before setting uptodate, otherwise, mapread or write will see non-zero data beyond EOF. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-21ext4: avoid potential hang in mpage_submit_io() when blocksize < pagesizeYongqiang Yang
commit 13a79a4741d37fda2fbafb953f0f301dc007928f upstream. If there is an unwritten but clean buffer in a page and there is a dirty buffer after the buffer, then mpage_submit_io does not write the dirty buffer out. As a result, da_writepages loops forever. This patch fixes the problem by checking dirty flag. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-21ext4: avoid hangs in ext4_da_should_update_i_disksize()Andrea Arcangeli
commit ea51d132dbf9b00063169c1159bee253d9649224 upstream. If the pte mapping in generic_perform_write() is unmapped between iov_iter_fault_in_readable() and iov_iter_copy_from_user_atomic(), the "copied" parameter to ->end_write can be zero. ext4 couldn't cope with it with delayed allocations enabled. This skips the i_disksize enlargement logic if copied is zero and no new data was appeneded to the inode. gdb> bt #0 0xffffffff811afe80 in ext4_da_should_update_i_disksize (file=0xffff88003f606a80, mapping=0xffff88001d3824e0, pos=0x1\ 08000, len=0x1000, copied=0x0, page=0xffffea0000d792e8, fsdata=0x0) at fs/ext4/inode.c:2467 #1 ext4_da_write_end (file=0xffff88003f606a80, mapping=0xffff88001d3824e0, pos=0x108000, len=0x1000, copied=0x0, page=0\ xffffea0000d792e8, fsdata=0x0) at fs/ext4/inode.c:2512 #2 0xffffffff810d97f1 in generic_perform_write (iocb=<value optimized out>, iov=<value optimized out>, nr_segs=<value o\ ptimized out>, pos=0x108000, ppos=0xffff88001e26be40, count=<value optimized out>, written=0x0) at mm/filemap.c:2440 #3 generic_file_buffered_write (iocb=<value optimized out>, iov=<value optimized out>, nr_segs=<value optimized out>, p\ os=0x108000, ppos=0xffff88001e26be40, count=<value optimized out>, written=0x0) at mm/filemap.c:2482 #4 0xffffffff810db5d1 in __generic_file_aio_write (iocb=0xffff88001e26bde8, iov=0xffff88001e26bec8, nr_segs=0x1, ppos=0\ xffff88001e26be40) at mm/filemap.c:2600 #5 0xffffffff810db853 in generic_file_aio_write (iocb=0xffff88001e26bde8, iov=0xffff88001e26bec8, nr_segs=<value optimi\ zed out>, pos=<value optimized out>) at mm/filemap.c:2632 #6 0xffffffff811a71aa in ext4_file_write (iocb=0xffff88001e26bde8, iov=0xffff88001e26bec8, nr_segs=0x1, pos=0x108000) a\ t fs/ext4/file.c:136 #7 0xffffffff811375aa in do_sync_write (filp=0xffff88003f606a80, buf=<value optimized out>, len=<value optimized out>, \ ppos=0xffff88001e26bf48) at fs/read_write.c:406 #8 0xffffffff81137e56 in vfs_write (file=0xffff88003f606a80, buf=0x1ec2960 <Address 0x1ec2960 out of bounds>, count=0x4\ 000, pos=0xffff88001e26bf48) at fs/read_write.c:435 #9 0xffffffff8113816c in sys_write (fd=<value optimized out>, buf=0x1ec2960 <Address 0x1ec2960 out of bounds>, count=0x\ 4000) at fs/read_write.c:487 #10 <signal handler called> #11 0x00007f120077a390 in __brk_reservation_fn_dmi_alloc__ () #12 0x0000000000000000 in ?? () gdb> print offset $22 = 0xffffffffffffffff gdb> print idx $23 = 0xffffffff gdb> print inode->i_blkbits $24 = 0xc gdb> up #1 ext4_da_write_end (file=0xffff88003f606a80, mapping=0xffff88001d3824e0, pos=0x108000, len=0x1000, copied=0x0, page=0\ xffffea0000d792e8, fsdata=0x0) at fs/ext4/inode.c:2512 2512 if (ext4_da_should_update_i_disksize(page, end)) { gdb> print start $25 = 0x0 gdb> print end $26 = 0xffffffffffffffff gdb> print pos $27 = 0x108000 gdb> print new_i_size $28 = 0x108000 gdb> print ((struct ext4_inode_info *)((char *)inode-((int)(&((struct ext4_inode_info *)0)->vfs_inode))))->i_disksize $29 = 0xd9000 gdb> down 2467 for (i = 0; i < idx; i++) gdb> print i $30 = 0xd44acbee This is 100% reproducible with some autonuma development code tuned in a very aggressive manner (not normal way even for knumad) which does "exotic" changes to the ptes. It wouldn't normally trigger but I don't see why it can't happen normally if the page is added to swap cache in between the two faults leading to "copied" being zero (which then hangs in ext4). So it should be fixed. Especially possible with lumpy reclaim (albeit disabled if compaction is enabled) as that would ignore the young bits in the ptes. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-21ext4: display the correct mount option in /proc/mounts for [no]init_itableTheodore Ts'o
commit fc6cb1cda5db7b2d24bf32890826214b857c728e upstream. /proc/mounts was showing the mount option [no]init_inode_table when the correct mount option that will be accepted by parse_options() is [no]init_itable. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-21ext4: fix ext4_end_io_dio() racing against fsync()Theodore Ts'o
commit b5a7e97039a80fae673ccc115ce595d5b88fb4ee upstream. We need to make sure iocb->private is cleared *before* we put the io_end structure on i_completed_io_list. Otherwise fsync() could potentially run on another CPU and free the iocb structure out from under us. Reported-by: Kent Overstreet <koverstreet@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-14Merge branch 'linux-3.1.5' into android-tegra-nv-3.1Varun Wadekar
Conflicts: arch/arm/Kconfig Change-Id: If8aaaf3efcbbf6c9017b38efb6d76ef933f147fa Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2011-12-09ext4: fix racy use-after-free in ext4_end_io_dio()Tejun Heo
commit 4c81f045c0bd2cbb78cc6446a4cd98038fe11a2e upstream. ext4_end_io_dio() queues io_end->work and then clears iocb->private; however, io_end->work calls aio_complete() which frees the iocb object. If that slab object gets reallocated, then ext4_end_io_dio() can end up clearing someone else's iocb->private, this use-after-free can cause a leak of a struct ext4_io_end_t structure. Detected and tested with slab poisoning. [ Note: Can also reproduce using 12 fio's against 12 file systems with the following configuration file: [global] direct=1 ioengine=libaio iodepth=1 bs=4k ba=4k size=128m [create] filename=${TESTDIR} rw=write -- tytso ] Google-Bug-Id: 5354697 Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reported-by: Kent Overstreet <koverstreet@google.com> Tested-by: Kent Overstreet <koverstreet@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-30fs: ext4: Fix computation of inodes per block groupColin Cross
857ac889cce8a486d47874db4d2f9620e7e9e5de (ext4: add interface to advertise ext4 features in sysfs) added an error check that exposes a bug in the computation of sbi->s_itb_per_group. If the number of inodes per group is not a multiple of the number of inodes per block, Original-Change-Id: I8c60817dbb6feb43535b567ec7ea5ee0af709c37 Signed-off-by: Colin Cross <ccross@android.com> (cherry picked from commit 8703a0ccb0135ae0de0d7011f29eeb6dc1caa486) Rebase-Id: R7fc03850010d565447bb8702710040f112705738
2011-11-11ext4: fix race in xattr block allocation pathEric Sandeen
commit 6d6a435190bdf2e04c9465cde5bdc3ac68cf11a4 upstream. Ceph users reported that when using Ceph on ext4, the filesystem would often become corrupted, containing inodes with incorrect i_blocks counters. I managed to reproduce this with a very hacked-up "streamtest" binary from the Ceph tree. Ceph is doing a lot of xattr writes, to out-of-inode blocks. There is also another thread which does sync_file_range and close, of the same files. The problem appears to happen due to this race: sync/flush thread xattr-set thread ----------------- ---------------- do_writepages ext4_xattr_set ext4_da_writepages ext4_xattr_set_handle mpage_da_map_blocks ext4_xattr_block_set set DELALLOC_RESERVE ext4_new_meta_blocks ext4_mb_new_blocks if (!i_delalloc_reserved_flag) vfs_dq_alloc_block ext4_get_blocks down_write(i_data_sem) set i_delalloc_reserved_flag ... up_write(i_data_sem) if (i_delalloc_reserved_flag) vfs_dq_alloc_block_nofail In other words, the sync/flush thread pops in and sets i_delalloc_reserved_flag on the inode, which makes the xattr thread think that it's in a delalloc path in ext4_new_meta_blocks(), and add the block for a second time, after already having added it once in the !i_delalloc_reserved_flag case in ext4_mb_new_blocks The real problem is that we shouldn't be using the DELALLOC_RESERVED state flag, and instead we should be passing EXT4_GET_BLOCKS_DELALLOC_RESERVE down to ext4_map_blocks() instead of using an inode state flag. We'll fix this for now with using i_data_sem to prevent this race, but this is really not the right way to fix things. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11ext4: let ext4_page_mkwrite stop started handle in failureYongqiang Yang
commit fcbb5515825f1bb20b7a6f75ec48bee61416f879 upstream. The started journal handle should be stopped in failure case. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11ext4: call ext4_handle_dirty_metadata with correct inode in ext4_dx_add_entryTheodore Ts'o
commit 5930ea643805feb50a2f8383ae12eb6f10935e49 upstream. ext4_dx_add_entry manipulates bh2 and frames[0].bh, which are two buffer_heads that point to directory blocks assigned to the directory inode. However, the function calls ext4_handle_dirty_metadata with the inode of the file that's being added to the directory, not the directory inode itself. Therefore, correct the code to dirty the directory buffers with the directory inode, not the file inode. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11ext4: ext4_mkdir should dirty dir_block with newly created directory inodeDarrick J. Wong
commit f9287c1f2d329f4d78a3bbc9cf0db0ebae6f146a upstream. ext4_mkdir calls ext4_handle_dirty_metadata with dir_block and the inode "dir". Unfortunately, dir_block belongs to the newly created directory (which is "inode"), not the parent directory (which is "dir"). Fix the incorrect association. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11ext4: ext4_rename should dirty dir_bh with the correct directoryDarrick J. Wong
commit bcaa992975041e40449be8c010c26192b8c8b409 upstream. When ext4_rename performs a directory rename (move), dir_bh is a buffer that is modified to update the '..' link in the directory being moved (old_inode). However, ext4_handle_dirty_metadata is called with the old parent directory inode (old_dir) and dir_bh, which is incorrect because dir_bh does not belong to the parent inode. Fix this error. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-11ext2,ext3,ext4: don't inherit APPEND_FL or IMMUTABLE_FL for new inodesTheodore Ts'o
commit 1cd9f0976aa4606db8d6e3dc3edd0aca8019372a upstream. This doesn't make much sense, and it exposes a bug in the kernel where attempts to create a new file in an append-only directory using O_CREAT will fail (but still leave a zero-length file). This was discovered when xfstests #79 was generalized so it could run on all file systems. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-09-21Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-block: floppy: use del_timer_sync() in init cleanup blk-cgroup: be able to remove the record of unplugged device block: Don't check QUEUE_FLAG_SAME_COMP in __blk_complete_request mm: Add comment explaining task state setting in bdi_forker_thread() mm: Cleanup clearing of BDI_pending bit in bdi_forker_thread() block: simplify force plug flush code a little bit block: change force plug flush call order block: Fix queue_flag update when rq_affinity goes from 2 to 1 block: separate priority boosting from REQ_META block: remove READ_META and WRITE_META xen-blkback: fixed indentation and comments xen-blkback: Don't disconnect backend until state switched to XenbusStateClosed.
2011-08-31ext4: remove i_mutex lock in ext4_evict_inode to fix lockdep complainingJiaying Zhang
The i_mutex lock and flush_completed_IO() added by commit 2581fdc810 in ext4_evict_inode() causes lockdep complaining about potential deadlock in several places. In most/all of these LOCKDEP complaints it looks like it's a false positive, since many of the potential circular locking cases can't take place by the time the ext4_evict_inode() is called; but since at the very least it may mask real problems, we need to address this. This change removes the flush_completed_IO() and i_mutex lock in ext4_evict_inode(). Instead, we take a different approach to resolve the software lockup that commit 2581fdc810 intends to fix. Rather than having ext4-dio-unwritten thread wait for grabing the i_mutex lock of an inode, we use mutex_trylock() instead, and simply requeue the work item if we fail to grab the inode's i_mutex lock. This should speed up work queue processing in general and also prevents the following deadlock scenario: During page fault, shrink_icache_memory is called that in turn evicts another inode B. Inode B has some pending io_end work so it calls ext4_ioend_wait() that waits for inode B's i_ioend_count to become zero. However, inode B's ioend work was queued behind some of inode A's ioend work on the same cpu's ext4-dio-unwritten workqueue. As the ext4-dio-unwritten thread on that cpu is processing inode A's ioend work, it tries to grab inode A's i_mutex lock. Since the i_mutex lock of inode A is still hold before the page fault happened, we enter a deadlock. Signed-off-by: Jiaying Zhang <jiayingz@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-08-23block: separate priority boosting from REQ_METAChristoph Hellwig
Add a new REQ_PRIO to let requests preempt others in the cfq I/O schedule, and lave REQ_META purely for marking requests as metadata in blktrace. All existing callers of REQ_META except for XFS are updated to also set REQ_PRIO for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-08-23block: remove READ_META and WRITE_METAChristoph Hellwig
Replace all occurnanced of the undocumented READ_META with READ | REQ_META and remove the unused WRITE_META define. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-08-21Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: flush any pending end_io requests before DIO reads w/dioread_nolock ext4: fix nomblk_io_submit option so it correctly converts uninit blocks ext4: Resolve the hang of direct i/o read in handling EXT4_IO_END_UNWRITTEN. ext4: call ext4_ioend_wait and ext4_flush_completed_IO in ext4_evict_inode ext4: Fix ext4_should_writeback_data() for no-journal mode
2011-08-19ext4: flush any pending end_io requests before DIO reads w/dioread_nolockJiaying Zhang
There is a race between ext4 buffer write and direct_IO read with dioread_nolock mount option enabled. The problem is that we clear PageWriteback flag during end_io time but will do uninitialized-to-initialized extent conversion later with dioread_nolock. If an O_direct read request comes in during this period, ext4 will return zero instead of the recently written data. This patch checks whether there are any pending uninitialized-to-initialized extent conversion requests before doing O_direct read to close the race. Note that this is just a bandaid fix. The fundamental issue is that we clear PageWriteback flag before we really complete an IO, which is problem-prone. To fix the fundamental issue, we may need to implement an extent tree cache that we can use to look up pending to-be-converted extents. Signed-off-by: Jiaying Zhang <jiayingz@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2011-08-13ext4: fix nomblk_io_submit option so it correctly converts uninit blocksTheodore Ts'o
Bug discovered by Jan Kara: Finally, commit 1449032be17abb69116dbc393f67ceb8bd034f92 returned back the old IO submission code but apparently it forgot to return the old handling of uninitialized buffers so we unconditionnaly call block_write_full_page() without specifying end_io function. So AFAICS we never convert unwritten extents to written in some cases. For example when I mount the fs as: mount -t ext4 -o nomblk_io_submit,dioread_nolock /dev/ubdb /mnt and do int fd = open(argv[1], O_RDWR | O_CREAT | O_TRUNC, 0600); char buf[1024]; memset(buf, 'a', sizeof(buf)); fallocate(fd, 0, 0, 16384); write(fd, buf, sizeof(buf)); I get a file full of zeros (after remounting the filesystem so that pagecache is dropped) instead of seeing the first KB contain 'a's. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2011-08-13ext4: Resolve the hang of direct i/o read in handling EXT4_IO_END_UNWRITTEN.Tao Ma
EXT4_IO_END_UNWRITTEN flag set and the increase of i_aiodio_unwritten should be done simultaneously since ext4_end_io_nolock always clear the flag and decrease the counter in the same time. We don't increase i_aiodio_unwritten when setting EXT4_IO_END_UNWRITTEN so it will go nagative and causes some process to wait forever. Part of the patch came from Eric in his e-mail, but it doesn't fix the problem met by Michael actually. http://marc.info/?l=linux-ext4&m=131316851417460&w=2 Reported-and-Tested-by: Michael Tokarev<mjt@tls.msk.ru> Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2011-08-13ext4: call ext4_ioend_wait and ext4_flush_completed_IO in ext4_evict_inodeJiaying Zhang
Flush inode's i_completed_io_list before calling ext4_io_wait to prevent the following deadlock scenario: A page fault happens while some process is writing inode A. During page fault, shrink_icache_memory is called that in turn evicts another inode B. Inode B has some pending io_end work so it calls ext4_ioend_wait() that waits for inode B's i_ioend_count to become zero. However, inode B's ioend work was queued behind some of inode A's ioend work on the same cpu's ext4-dio-unwritten workqueue. As the ext4-dio-unwritten thread on that cpu is processing inode A's ioend work, it tries to grab inode A's i_mutex lock. Since the i_mutex lock of inode A is still hold before the page fault happened, we enter a deadlock. Also moves ext4_flush_completed_IO and ext4_ioend_wait from ext4_destroy_inode() to ext4_evict_inode(). During inode deleteion, ext4_evict_inode() is called before ext4_destroy_inode() and in ext4_evict_inode(), we may call ext4_truncate() without holding i_mutex lock. As a result, there is a race between flush_completed_IO that is called from ext4_ext_truncate() and ext4_end_io_work, which may cause corruption on an io_end structure. This change moves ext4_flush_completed_IO and ext4_ioend_wait from ext4_destroy_inode() to ext4_evict_inode() to resolve the race between ext4_truncate() and ext4_end_io_work during inode deletion. Signed-off-by: Jiaying Zhang <jiayingz@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2011-08-13ext4: Fix ext4_should_writeback_data() for no-journal modeCurt Wohlgemuth
ext4_should_writeback_data() had an incorrect sequence of tests to determine if it should return 0 or 1: in particular, even in no-journal mode, 0 was being returned for a non-regular-file inode. This meant that, in non-journal mode, we would use ext4_journalled_aops for directories, symlinks, and other non-regular files. However, calling journalled aop callbacks when there is no valid handle, can cause problems. This would cause a kernel crash with Jan Kara's commit 2d859db3e4 ("ext4: fix data corruption in inodes with journalled data"), because we now dereference 'handle' in ext4_journalled_write_end(). I also added BUG_ONs to check for a valid handle in the obviously journal-only aops callbacks. I tested this running xfstests with a scratch device in these modes: - no-journal - data=ordered - data=writeback - data=journal All work fine; the data=journal run has many failures and a crash in xfstests 074, but this is no different from a vanilla kernel. Signed-off-by: Curt Wohlgemuth <curtw@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2011-08-11ext4: Properly count journal credits for long symlinksEric Sandeen
Commit df5e6223407e ("ext4: fix deadlock in ext4_symlink() in ENOSPC conditions") recalculated the number of credits needed for a long symlink, in the process of splitting it into two transactions. However, the first credit calculation under-counted because if selinux is enabled, credits are needed to create the selinux xattr as well. Overrunning the reservation will result in an OOPS in jbd2_journal_dirty_metadata() due to this assert: J_ASSERT_JH(jh, handle->h_buffer_credits > 0); Fix this by increasing the reservation size. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Jan Kara <jack@suse.cz> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-03ext4: use kzalloc in ext4_kzalloc()Mathias Krause
Commit 9933fc0i (ext4: introduce ext4_kvmalloc(), ext4_kzalloc(), and ext4_kvfree()) intruduced wrappers around k*alloc/vmalloc but introduced a typo for ext4_kzalloc() by not using kzalloc() but kmalloc(). Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-08-01Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (60 commits) ext4: prevent memory leaks from ext4_mb_init_backend() on error path ext4: use EXT4_BAD_INO for buddy cache to avoid colliding with valid inode # ext4: use ext4_msg() instead of printk in mballoc ext4: use ext4_kvzalloc()/ext4_kvmalloc() for s_group_desc and s_group_info ext4: introduce ext4_kvmalloc(), ext4_kzalloc(), and ext4_kvfree() ext4: use the correct error exit path in ext4_init_inode_table() ext4: add missing kfree() on error return path in add_new_gdb() ext4: change umode_t in tracepoint headers to be an explicit __u16 ext4: fix races in ext4_sync_parent() ext4: Fix overflow caused by missing cast in ext4_fallocate() ext4: add action of moving index in ext4_ext_rm_idx for Punch Hole ext4: simplify parameters of reserve_backup_gdb() ext4: simplify parameters of add_new_gdb() ext4: remove lock_buffer in bclean() and setup_new_group_blocks() ext4: simplify journal handling in setup_new_group_blocks() ext4: let setup_new_group_blocks() set multiple bits at a time ext4: fix a typo in ext4_group_extend() ext4: let ext4_group_add_blocks() handle 0 blocks quickly ext4: let ext4_group_add_blocks() return an error code ext4: rename ext4_add_groupblocks() to ext4_group_add_blocks() ... Fix up conflict in fs/ext4/inode.c: commit aacfc19c626e ("fs: simplify the blockdev_direct_IO prototype") had changed the ext4_ind_direct_IO() function for the new simplified calling convention, while commit dae1e52cb126 ("ext4: move ext4_ind_* functions from inode.c to indirect.c") moved the function to another file.
2011-08-01ext4: prevent memory leaks from ext4_mb_init_backend() on error pathYu Jian
In ext4_mb_init(), if the s_locality_group allocation fails it will currently cause the allocations made in ext4_mb_init_backend() to be leaked. Moving the ext4_mb_init_backend() allocation after the s_locality_group allocation avoids that problem. Signed-off-by: Yu Jian <yujian@whamcloud.com> Signed-off-by: Andreas Dilger <adilger@whamcloud.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-08-01ext4: use EXT4_BAD_INO for buddy cache to avoid colliding with valid inode #Yu Jian
2011-08-01ext4: use ext4_msg() instead of printk in mballocTheodore Ts'o
2011-08-01ext4: use ext4_kvzalloc()/ext4_kvmalloc() for s_group_desc and s_group_infoTheodore Ts'o
2011-08-01ext4: introduce ext4_kvmalloc(), ext4_kzalloc(), and ext4_kvfree()Theodore Ts'o
Introduce new helper functions which try kmalloc, and then fall back to vmalloc if necessary, and use them for allocating and deallocating s_flex_groups. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-08-01ext4: use the correct error exit path in ext4_init_inode_table()Yongqiang Yang
This patch lets ext4_init_inode_table() handle errors right. ext4_init_inode_table() should down_write() alloc_sem which has been up_write()ed and stop the started journal handle. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-08-01switch posix_acl_equiv_mode() to umode_t *Al Viro
... so that &inode->i_mode could be passed to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-08-01switch posix_acl_create() to umode_t *Al Viro
so we can pass &inode->i_mode to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-30ext4: add missing kfree() on error return path in add_new_gdb()Dan Carpenter
We added some more error handling in b40971426a "ext4: add error checking to calls to ext4_handle_dirty_metadata()". But we need to call kfree() as well to avoid a memory leak. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-30ext4: fix races in ext4_sync_parent()Theodore Ts'o
Fix problems if fsync() races against a rename of a parent directory as pointed out by Al Viro in his own inimitable way: >While we are at it, could somebody please explain what the hell is ext4 >doing in >static int ext4_sync_parent(struct inode *inode) >{ > struct writeback_control wbc; > struct dentry *dentry = NULL; > int ret = 0; > > while (inode && ext4_test_inode_state(inode, EXT4_STATE_NEWENTRY)) { > ext4_clear_inode_state(inode, EXT4_STATE_NEWENTRY); > dentry = list_entry(inode->i_dentry.next, > struct dentry, d_alias); > if (!dentry || !dentry->d_parent || !dentry->d_parent->d_inode) > break; > inode = dentry->d_parent->d_inode; > ret = sync_mapping_buffers(inode->i_mapping); > ... >Note that dentry obviously can't be NULL there. dentry->d_parent is never >NULL. And dentry->d_parent would better not be negative, for crying out >loud! What's worse, there's no guarantees that dentry->d_parent will >remain our parent over that sync_mapping_buffers() *and* that inode won't >just be freed under us (after rename() and memory pressure leading to >eviction of what used to be our dentry->d_parent)...... Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-27ext4: Fix overflow caused by missing cast in ext4_fallocate()Utako Kusaka
The logical block number in map.l_blk is a __u32, and so before we shift it left, by the block size, we neeed cast it to a 64-bit size. Otherwise i_size can be corrupted on an ENOSPC. # df -T /mnt/mp1 Filesystem Type 1K-blocks Used Available Use% Mounted on /dev/sda6 ext4 9843276 153056 9190200 2% /mnt/mp1 # fallocate -o 0 -l 2199023251456 /mnt/mp1/testfile fallocate: /mnt/mp1/testfile: fallocate failed: No space left on device # stat /mnt/mp1/testfile File: `/mnt/mp1/testfile' Size: 4293656576 Blocks: 19380440 IO Block: 4096 regular file Device: 806h/2054d Inode: 12 Links: 1 Access: (0644/-rw-r--r--) Uid: ( 0/ root) Gid: ( 0/ root) Access: 2011-07-25 13:01:31.414490496 +0900 Modify: 2011-07-25 13:01:31.414490496 +0900 Change: 2011-07-25 13:01:31.454490495 +0900 Signed-off-by: Utako Kusaka <u-kusaka@wm.jp.nec.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> -- fs/ext4/extents.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
2011-07-27ext4: add action of moving index in ext4_ext_rm_idx for Punch HoleRobin Dong
The old function ext4_ext_rm_idx is used only for truncate case because it just remove last index in extent-index-block. When punching hole, it usually needed to remove "middle" index, therefore we must move indexes which after it forward. (I create a file with 1 depth extent tree and punch hole in the middle of it, the last index in index-block strangly gone, so I find out this bug) Signed-off-by: Robin Dong <sanbai@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-27ext4: simplify parameters of reserve_backup_gdb()Yongqiang Yang
The reserve_backup_gdb() function only needs the block group number; there's no need to pass a pointer to struct ext4_new_group_data to it. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com>
2011-07-27ext4: simplify parameters of add_new_gdb()Yongqiang Yang
add_new_gdb() only needs the block group number; there is no need to pass a pointer to struct ext4_new_group_data to add_new_gdb(). Instead of filling in a pointer the struct buffer_head in add_new_gdb(), it's simpler to have the caller fetch it from the s_group_desc[] array. [Fixed error path to handle the case where struct buffer_head *primary hasn't been set yet. -- Ted] Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-27ext4: remove lock_buffer in bclean() and setup_new_group_blocks()Yongqiang Yang
There is no need to lock the buffers since no one else should be touching these buffers besides the file system. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-26ext4: simplify journal handling in setup_new_group_blocks()Yongqiang Yang
This patch simplifies journal handling in setup_new_group_blocks(). In previous code, block bitmap is modified everywhere in setup_new_group_blocks(), ext4_get_write_access() in extend_or_restart_transaction() is used to guarantee that the block bitmap stays in the new handle, this makes things complicated. The previous commit changed things so that the modifications on the block bitmap are batched and done by ext4_set_bits() at the end of the for loop. This allows us to simplify things. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-26ext4: let setup_new_group_blocks() set multiple bits at a timeYongqiang Yang
Rename mb_set_bits() to ext4_set_bits() and make it a global function so that setup_new_group_blocks() can use it. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-26ext4: fix a typo in ext4_group_extend()Yongqiang Yang
2011-07-26ext4: let ext4_group_add_blocks() handle 0 blocks quicklyYongqiang Yang
If ext4_group_add_blocks() is called with 0 block, make it return 0 without doing any extra work. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-26ext4: let ext4_group_add_blocks() return an error codeYongqiang Yang
This patch lets ext4_group_add_blocks() return an error code if it fails, so that upper functions can handle error correctly. Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
