drivers/usb/gadget/composite.c
Change-Id: I1a332ec21da62aea98912df9a01cf0282ed50ee1
commit a1c6c5698d53db4c47a25c3a8d11731a4d7b8370 upstream.
Fix NULL pointer dereference in print_daily_error_info, when
called on unmounted fs (EXT4_SB(sb) returns NULL), by removing error
reporting timer in ext4_put_super.
Google-Bug-Id: 3017663
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Cc: Thomas Meyer <thomas@m3y3r.de>
We now initialize the percpu counters before replaying the journal,
but after the journal, we recalculate the global counters, to deal
with the possibility of the per-blockgroup counts getting updated by
the journal replay.
Commit 84061e0 fixed an accounting bug only to introduce the
possibility of a kernel OOPS if the journal has a non-zero j_errno
field indicating that the file system had detected a fs inconsistency.
After the journal replay, if the journal superblock indicates that the
file system has an error, this indication is transfered to the file
system and then ext4_commit_super() is called to write this to the
disk.
But since the percpu counters are now initialized after the journal
replay, the call to ext4_commit_super() will cause a kernel oops since
it needs to use the percpu counters the ext4 superblock structure.
The fix is to skip setting the ext4 free block and free inode fields
if the percpu counter has not been set.
Thanks to Ken Sumrall for reporting and analyzing the root causes of
this bug.
Addresses-Google-Bug: #3054080
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits)
no need for list_for_each_entry_safe()/resetting with superblock list
Fix sget() race with failing mount
vfs: don't hold s_umount over close_bdev_exclusive() call
sysv: do not mark superblock dirty on remount
sysv: do not mark superblock dirty on mount
btrfs: remove junk sb_dirt change
BFS: clean up the superblock usage
AFFS: wait for sb synchronization when needed
AFFS: clean up dirty flag usage
cifs: truncate fallout
mbcache: fix shrinker function return value
mbcache: Remove unused features
add f_flags to struct statfs(64)
pass a struct path to vfs_statfs
update VFS documentation for method changes.
All filesystems that need invalidate_inode_buffers() are doing that explicitly
convert remaining ->clear_inode() to ->evict_inode()
Make ->drop_inode() just return whether inode needs to be dropped
fs/inode.c:clear_inode() is gone
fs/inode.c:evict() doesn't care about delete vs. non-delete paths now
Fix up trivial conflicts in fs/nilfs2/super.c
The mbcache code was written to support a variable number of indexes,
but all the existing users use exactly one index. Simplify to code to
support only that case.
There are also no users of the cache entry free operation, and none of
the users keep extra data in cache entries. Remove those features as
well.
Signed-off-by: Andreas Gruenbacher <agruen@suse.de>
pretty much brute-force...
Replace inode_setattr with opencoded variants of it in all callers. This
moves the remaining call to vmtruncate into the filesystem methods where it
can be replaced with the proper truncate sequence.
In a few cases it was obvious that we would never end up calling vmtruncate
so it was left out in the opencoded variant:
spufs: explicitly checks for ATTR_SIZE earlier
btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier
ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above
In addition to that ncpfs called inode_setattr with handcrafted iattrs,
which allowed to trim down the opencoded variant.
Split up the block_write_begin implementation - __block_write_begin is a new
trivial wrapper for block_prepare_write that always takes an already
allocated page and can be either called from block_write_begin or filesystem
code that already has a page allocated. Remove the handling of already
allocated pages from block_write_begin after switching all callers that
do it to __block_write_begin.
Move the call to vmtruncate to get rid of accessive blocks to the callers
in prepearation of the new truncate calling sequence. This was only done
for DIO_LOCKING filesystems, so the __blockdev_direct_IO_newtrunc variant
was not needed anyway. Get rid of blockdev_direct_IO_no_locking and
its _newtrunc variant while at it as just opencoding the two additional
paramters is shorted than the name suffix.
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (40 commits)
ext4: Adding error check after calling ext4_mb_regular_allocator()
ext4: Fix dirtying of journalled buffers in data=journal mode
ext4: re-inline ext4_rec_len_(to|from)_disk functions
jbd2: Remove t_handle_lock from start_this_handle()
jbd2: Change j_state_lock to be a rwlock_t
jbd2: Use atomic variables to avoid taking t_handle_lock in jbd2_journal_stop
ext4: Add mount options in superblock
ext4: force block allocation on quota_off
ext4: fix freeze deadlock under IO
ext4: drop inode from orphan list if ext4_delete_inode() fails
ext4: check to make make sure bd_dev is set before dereferencing it
jbd2: Make barrier messages less scary
ext4: don't print scary messages for allocation failures post-abort
ext4: fix EFBIG edge case when writing to large non-extent file
ext4: fix ext4_get_blocks references
ext4: Always journal quota file modifications
ext4: Fix potential memory leak in ext4_fill_super
ext4: Don't error out the fs if the user tries to make a file too big
ext4: allocate stripe-multiple IOs on stripe boundaries
ext4: move aio completion after unwritten extent conversion
Fix up conflicts in fs/ext4/inode.c as per Ted.
Fix up xfs conflicts as per earlier xfs merge.
If the bitmap block on disk is bad, ext4_mb_load_buddy() returns an
error. This error is returned to the caller,
ext4_mb_regular_allocator() and then to ext4_mb_new_blocks(). But
ext4_mb_new_blocks() did not check for the return value of
ext4_mb_regular_allocator() and would repeatedly try to load the
bitmap block. The fix simply catches the return value and exits out of
the 'repeat' loop after cleanup.
We also take the opportunity to clean up the error handling in
Google-Bug-Id: 2853530
Signed-off-by: Aditya Kali <adityakali@google.com>
In data=journal mode, we still use block_write_begin() to prepare
page for writing. This function can occasionally mark buffer dirty
which violates journalling assumptions - when a buffer is part of
a transaction, it should be dirty and a buffer can be already part
of a forget list of some transaction when block_write_begin()
gets called. This violation of journalling assumptions then results
in "JBD: Spotted dirty metadata buffer..." warnings.
In fact, temporary dirtying the buffer while the page is still locked
does not really cause problems to the journalling because we won't write
the buffer until the page gets unlocked. So we just have to make sure
to clear dirty bits before unlocking the page.
commit 3d0518f4, "ext4: New rec_len encoding for very
large blocksizes" made several changes to this path, but from
a perf perspective, un-inlining ext4_rec_len_from_disk() seems
most significant. This function is called from ext4_check_dir_entry(),
which on a file-creation workload is called extremely often.
I tested this with bonnie:
# bonnie++ -u root -s 0 -f -x 200 -d /mnt/test -n 32
(this does 200 iterations) and got this for the file creations:
ext4 stock: Average = 21206.8 files/s
ext4 inlined: Average = 22346.7 files/s (+5%)
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Lockstat reports have shown that j_state_lock is a major source of
lock contention, especially on systems with more than 4 CPU cores. So
change it to be a read/write spinlock.
Allow mount options to be stored in the superblock. Also add default
mount option bits for nobarrier, block_validity, discard, and nodelalloc.
Perform full sync procedure so that any delayed allocation blocks are
allocated so quota will be consistent.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Commit 6b0310fbf087ad6 caused a regression resulting in deadlocks
when freezing a filesystem which had active IO; the vfs_check_frozen
level (SB_FREEZE_WRITE) did not let the freeze-related IO syncing
through. Duh.
Changing the test to FREEZE_TRANS should let the normal freeze
syncing get through the fs, but still block any transactions from
starting once the fs is completely frozen.
I tested this by running fsstress in the background while periodically
snapshotting the fs and running fsck on the result. I ran into
occasional deadlocks, but different ones. I think this is a
fine fix for the problem at hand, and the other deadlocky things
will need more investigation.
Reported-by: Phillip Susi <psusi@cfl.rr.com>
There were some error paths in ext4_delete_inode() which was not
dropping the inode from the orphan list. This could lead to a BUG_ON
on umount when the orphan list is discovered to be non-empty.
There are some drivers which may not set bdev->bd_dev. So make sure
it is non-NULL before dereferencing it.
Google-Bug-Id: 1773557
I often get emails containing the "This should not happen!!" message,
conveniently trimmed to remove things like:
sd 0:0:0:0: [sda] Unhandled error code
sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_TIMEOUT
sd 0:0:0:0: [sda] CDB: Write(10): 2a 00 03 13 c9 70 00 00 28 00
end_request: I/O error, dev sda, sector 51628400
Aborting journal on device dm-0-8.
EXT4-fs error (device dm-0): ext4_journal_start_sb: Detected aborted journal
EXT4-fs (dm-0): Remounting filesystem read-only
I don't think there is any value to the verbosity if the reason is
due to a filesystem abort; it just obfuscates the root cause.
By running the following reproducer, we can confirm that the write
system call returns with 0 when it should return the error EFBIG.
#!/bin/sh
/bin/dd if=/dev/zero of=./img bs=1k count=1 seek=1024k > /dev/null 2>&1
/sbin/mkfs.ext3 -Fq ./img
/bin/mount -o loop -t ext4 ./img /mnt
/bin/touch /mnt/file
strace /bin/dd if=/dev/zero of=/mnt/file conv=notrunc bs=1k count=1 seek=$((2194719883264/1024)) 2>&1 | /bin/egrep "write.* 1024\) = "
/bin/umount /mnt
exit
Signed-off-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
Cc: Eric Sandeen <sandeen@redhat.com>
ext4_get_blocks got renamed to ext4_map_blocks, but left stale
comments and a prototype littered around.
When journaled quota options are not specified, we do writes
to quota files just in data=ordered mode. This actually causes
warnings from JBD2 about dirty journaled buffer because ext4_getblk
unconditionally treats a block allocated by it as metadata. Since
quota actually is filesystem metadata, the easiest way to get rid
of the warning is to always treat quota writes as metadata...
Under heavy memory pressure we may hit out of memory
situation and as result kstrdup'ed options will not be
freed. Fix it.
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
If the user attempts to make a non-extent-mapped file to be too large,
return EFBIG, but don't call ext4_std_err() which will end up marking
the file system as containing an error.
Thanks to Toshiyuki Okajima-san at Fujitsu for pointing this out.
For some reason, today mballoc only allocates IOs which are exactly
stripe-sized on a stripe boundary. If you have a multiple (say, a
128k IO on a 64k stripe) you may end up unaligned.
It seems to me that a simple change to align stripe-multiple IOs
on stripe boundaries would be a very good idea, unless this breaks
some other mballoc heuristic for some reason...
Reported-by: Mike Snitzer <snitzer@redhat.com>
This patch is to be applied upon Christoph's "direct-io: move aio_complete
into ->end_io" patch. It adds iocb and result fields to struct ext4_io_end_t,
so that we can call aio_complete from ext4_end_io_nolock() after the extent
conversion has finished.
I have verified with Christoph's aio-dio test that used to fail after a few
runs on an original kernel but now succeeds on the patched kernel.
See http://thread.gmane.org/gmane.comp.file-systems.ext4/19659 for details.
Signed-off-by: Jiaying Zhang <jiayingz@google.com>
Filesystems with unwritten extent support must not complete an AIO request
until the transaction to convert the extent has been commited. That means
the aio_complete calls needs to be moved into the ->end_io callback so
that the filesystem can control when to call it exactly.
This makes a bit of a mess out of dio_complete and the ->end_io callback
prototype even more complicated.
Issue discard request in ext4_free_blocks() when ext4 has no journal and
is mounted with discard option.
We have experienced bitmap inconsistencies after crash during file
delete under heavy load. The crash is not file system related and I
the following patch in ext4_free_branches() fixes the recovery
problem.
If the transaction is restarted and there is a crash before the new
transaction is committed, then after recovery, the blocks that this
indirect block points to have been freed, but the indirect block
itself has not been freed and may still point to some of the free
blocks (because of the ext4_forget()).
So ext4_forget() should be called inside ext4_free_blocks() to avoid
this problem.
Signed-off-by: Amir Goldstein <amir73il@users.sf.net>
The allocation_context pointer can be NULL.
This has been in use by e2fsprogs for a while; define it to keep the
super block fields in sync.
This allows us to grab any file system error messages by scraping
/var/log/messages. This will make it easy for us to do error analysis
across the very large number of machines as we deploy ext4 across the
fleet.
Save number of file system errors, and the time function name, line
number, block number, and inode number of the first and most recent
errors reported on the file system in the superblock.
Also start passing the line number to ext4_check_dir since we're going
to need it in upcoming patch.
Signed-off-by: Alex Elder <aelder@sgi.com>
This allows the error messages to include the line number
Also use a macro definition so that __func__ and __LINE__ is implicit.
Use a macro definition for ext4_abort() to clean up the .c files a wee
bit.
ext4 didn't update the ctime of the file when its permission was
changed.
Steps to reproduce:
# touch aaa
# stat -c %Z aaa
1275289822
# setfacl -m 'u::x,g::x,o::x' aaa
# stat -c %Z aaa
1275289822 <- unchanged
But, according to the spec of the ctime, ext4 must update it.
Port of ext3 patch by Miao Xie <miaox@cn.fujitsu.com>.
CC: linux-ext4@vger.kernel.org
The nobh option was only supported for writeback mode, but given that all
write paths actually create buffer heads it effectively was a no-op already.
No real bugs found, just removed some dead code.
Found by gcc 4.6's new warnings.
