commit 565333a1554d704789e74205989305c811fd9c7a upstream.
No need to wait for any commit once the page is fully truncated.
Besides, it may confuse e.g. concurrent ext4_writepage() with the page
still be dirty (will be cleared by truncate_pagecache() in
ext4_setattr()) but buffers has been freed; and then trigger a bug
show as below:
[ 26.057508] ------------[ cut here ]------------
[ 26.058531] kernel BUG at fs/ext4/inode.c:2134!
[ 26.088130] Call trace:
[ 26.088695] ext4_writepage+0x914/0xb28
[ 26.089541] writeout.isra.4+0x1b4/0x2b8
[ 26.090409] move_to_new_page+0x3b0/0x568
[ 26.091338] __unmap_and_move+0x648/0x988
[ 26.092241] unmap_and_move+0x48c/0xbb8
[ 26.093096] migrate_pages+0x220/0xb28
[ 26.093945] kernel_mbind+0x828/0xa18
[ 26.094791] __arm64_sys_mbind+0xc8/0x138
[ 26.095716] el0_svc_common+0x190/0x490
[ 26.096571] el0_svc_handler+0x60/0xd0
[ 26.097423] el0_svc+0x8/0xc
Run the procedure (generate by syzkaller) parallel with ext3.
void main()
int fd, fd1, ret;
void *addr;
size_t length = 4096;
int flags;
off_t offset = 0;
char *str = "12345";
fd = open("a", O_RDWR | O_CREAT);
assert(fd >= 0);
/* Truncate to 4k */
ret = ftruncate(fd, length);
assert(ret == 0);
/* Journal data mode */
flags = 0xc00f;
ret = ioctl(fd, _IOW('f', 2, long), &flags);
assert(ret == 0);
/* Truncate to 0 */
fd1 = open("a", O_TRUNC | O_NOATIME);
assert(fd1 >= 0);
addr = mmap(NULL, length, PROT_WRITE | PROT_READ,
MAP_SHARED, fd, offset);
assert(addr != (void *)-1);
memcpy(addr, str, 5);
mbind(addr, length, 0, 0, 0, MPOL_MF_MOVE);
And the bug will be triggered once we seen the below order.
reproduce1 reproduce2
truncate to 4k |
change to journal data mode |
| memcpy(set page dirty)
truncate to 0: |
ext4_setattr: |
ext4_wait_for_tail_page_commit |
| mbind(trigger bug)
truncate_pagecache(clean dirty)| ...
mbind will call ext4_writepage() since the page still be dirty, and then
report the bug since the buffers has been free. Fix it by return
directly once offset equals to 0 which means the page has been fully
truncated.
Signed-off-by: yangerkun <yangerkun@huawei.com>
Link: https://lore.kernel.org/r/20190919063508.1045-1-yangerkun@huawei.com
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit c7df4a1ecb8579838ec8c56b2bb6a6716e974f37 upstream.
If the file system is corrupted such that a file's i_links_count is
too small, then it's possible that when unlinking that file, i_nlink
will already be zero. Previously we were working around this kind of
corruption by forcing i_nlink to one; but we were doing this before
trying to delete the directory entry --- and if the file system is
corrupted enough that ext4_delete_entry() fails, then we exit with
i_nlink elevated, and this causes the orphan inode list handling to be
FUBAR'ed, such that when we unmount the file system, the orphan inode
list can get corrupted.
A better way to fix this is to simply skip trying to call drop_nlink()
if i_nlink is already zero, thus moving the check to the place where
it makes the most sense.
https://bugzilla.kernel.org/show_bug.cgi?id=205433
Link: https://lore.kernel.org/r/20191112032903.8828-1-tytso@mit.edu
Cc: stable@kernel.org
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
commit 65db869c754e7c271691dd5feabf884347e694f5 upstream.
Estimate for the number of credits needed for final freeing of inode in
ext4_evict_inode() was to small. We may modify 4 blocks (inode & sb for
orphan deletion, bitmap & group descriptor for inode freeing) and not
just 3.
[ Fixed minor whitespace nit. -- TYT ]
Fixes: e50e5129f384 ("ext4: xattr-in-inode support")
CC: stable@vger.kernel.org
Link: https://lore.kernel.org/r/20191105164437.32602-6-jack@suse.cz
commit 4ea99936a1630f51fc3a2d61a58ec4a1c4b7d55a upstream.
It's possible to specify a non-zero s_want_extra_isize via debugging
option, and this can cause bad things(tm) to happen when using a file
system with an inode size of 128 bytes.
Add better checking when the file system is mounted, as well as when
we are actually doing the trying to do the inode expansion.
Link: https://lore.kernel.org/r/20191110121510.GH23325@mit.edu
Reported-by: syzbot+f8d6f8386ceacdbfff57@syzkaller.appspotmail.com
Reported-by: syzbot+33d7ea72e47de3bdf4e1@syzkaller.appspotmail.com
Reported-by: syzbot+44b6763edfc17144296f@syzkaller.appspotmail.com
[ Upstream commit 799578ab16e86b074c184ec5abbda0bc698c7b0b ]
Enabling DX_DEBUG triggers the build error below. info is an attribute
of the dxroot structure.
linux/fs/ext4/namei.c:2264:12: error: ‘info’
undeclared (first use in this function); did you mean ‘insl’?
info->indirect_levels));
Fixes: e08ac99fa2a2 ("ext4: add largedir feature")
Signed-off-by: Gabriel Krisman Bertazi <krisman@collabora.co.uk>
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
commit c1e8220bd316d8ae8e524df39534b8a412a45d5e upstream.
If a program attempts to punch a hole on an inline data file, we need
to convert it to a normal file first.
This was detected using ext4/032 using the adv configuration. Simple
reproducer:
mke2fs -Fq -t ext4 -O inline_data /dev/vdc
mount /vdc
echo "" > /vdc/testfile
xfs_io -c 'truncate 33554432' /vdc/testfile
xfs_io -c 'fpunch 0 1048576' /vdc/testfile
umount /vdc
e2fsck -fy /dev/vdc
Cc: stable@vger.kernel.org
commit e3d550c2c4f2f3dba469bc3c4b83d9332b4e99e1 upstream.
Really enable warning when CONFIG_EXT4_DEBUG is set and fix missing
first argument. This was introduced in commit ff95ec22cd7f ("ext4:
add warning to ext4_convert_unwritten_extents_endio") and splitting
extents inside endio would trigger it.
Fixes: ff95ec22cd7f ("ext4: add warning to ext4_convert_unwritten_extents_endio")
Signed-off-by: Rakesh Pandit <rakesh@tuxera.com>
commit 4e19d6b65fb4fc42e352ce9883649e049da14743 upstream.
The largedir feature was intended to allow ext4 directories to have
unmapped directory blocks (e.g., directory holes). And so the
released e2fsprogs no longer enforces this for largedir file systems;
however, the corresponding change to the kernel-side code was not made.
This commit fixes this oversight.
commit 73131fbb003b3691cfcf9656f234b00da497fcd6 upstream.
Use the newly introduced jbd2_inode dirty range scoping to prevent us
from waiting forever when trying to complete a journal transaction.
Signed-off-by: Ross Zwisler <zwisler@google.com>
commit 02b016ca7f99229ae6227e7b2fc950c4e140d74a upstream.
According to the chattr man page, "a file with the 'i' attribute
cannot be modified..." Historically, this was only enforced when the
file was opened, per the rest of the description, "... and the file
can not be opened in write mode".
There is general agreement that we should standardize all file systems
to prevent modifications even for files that were opened at the time
the immutable flag is set. Eventually, a change to enforce this at
the VFS layer should be landing in mainline. Until then, enforce this
at the ext4 level to prevent xfstests generic/553 from failing.
Cc: "Darrick J. Wong" <darrick.wong@oracle.com>
commit 2e53840362771c73eb0a5ff71611507e64e8eecd upstream.
Don't allow any modifications to a file that's marked immutable, which
means that we have to flush all the writable pages to make the readonly
and we have to check the setattr/setflags parameters more closely.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
commit ee0ed02ca93ef1ecf8963ad96638795d55af2c14 upstream.
It is possible that unlinked inode enters ext4_setattr() (e.g. if
somebody calls ftruncate(2) on unlinked but still open file). In such
case we should not delete the inode from the orphan list if truncate
fails. Note that this is mostly a theoretical concern as filesystem is
corrupted if we reach this path anyway but let's be consistent in our
orphan handling.
Reviewed-by: Ira Weiny <ira.weiny@intel.com>
commit ddccb6dbe780d68133191477571cb7c69e17bb8c upstream.
Fix compile error below when using BUFFER_TRACE.
fs/ext4/inode.c: In function ‘ext4_expand_extra_isize’:
fs/ext4/inode.c:5979:19: error: request for member ‘bh’ in something not a structure or union
BUFFER_TRACE(iloc.bh, "get_write_access");
Fixes: c03b45b853f58 ("ext4, project: expand inode extra size if possible")
Signed-off-by: zhangyi (F) <yi.zhang@huawei.com>
commit 08fc98a4d6424af66eb3ac4e2cedd2fc927ed436 upstream.
The buffer_head (frames[0].bh) and it's corresping page can be
potentially free'd once brelse() is done inside the for loop
but before the for loop exits in dx_release(). It can be free'd
in another context, when the page cache is flushed via
drop_caches_sysctl_handler(). This results into below data abort
when accessing info->indirect_levels in dx_release().
Unable to handle kernel paging request at virtual address ffffffc17ac3e01e
Call trace:
dx_release+0x70/0x90
ext4_htree_fill_tree+0x2d4/0x300
ext4_readdir+0x244/0x6f8
iterate_dir+0xbc/0x160
SyS_getdents64+0x94/0x174
Signed-off-by: Sahitya Tummala <stummala@codeaurora.org>
commit 57a0da28ced8707cb9f79f071a016b9d005caf5a upstream.
Unaligned AIO must be serialized because the zeroing of partial blocks
of unaligned AIO can result in data corruption in case it's overlapping
another in flight IO.
Currently we wait for all unwritten extents before we submit unaligned
AIO which protects data in case of unaligned AIO is following overlapping
IO. However if a unaligned AIO is followed by overlapping aligned AIO we
can still end up corrupting data.
To fix this, we must make sure that the unaligned AIO is the only IO in
flight by waiting for unwritten extents conversion not just before the
IO submission, but right after it as well.
This problem can be reproduced by xfstest generic/538
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
commit 592acbf16821288ecdc4192c47e3774a4c48bb64 upstream.
This commit zeroes out the unused memory region in the buffer_head
corresponding to the extent metablock after writing the extent header
and the corresponding extent node entries.
This is done to prevent random uninitialized data from getting into
the filesystem when the extent block is synced.
This fixes CVE-2019-11833.
Signed-off-by: Sriram Rajagopalan <sriramr@arista.com>
commit 50b29d8f033a7c88c5bc011abc2068b1691ab755 upstream.
Instead of removing EXT4_MOUNT_JOURNAL_CHECKSUM from s_def_mount_opt as
I assume was intended, all other options were blown away leading to
_ext4_show_options() output being incorrect.
Fixes: 1e381f60dad9 ("ext4: do not allow journal_opts for fs w/o journal")
Signed-off-by: Debabrata Banerjee <dbanerje@akamai.com>
commit 310a997fd74de778b9a4848a64be9cda9f18764a upstream.
It is never possible, that number of block groups decreases,
since only online grow is supported.
But after a growing occured, we have to zero inode tables
for just created new block groups.
Fixes: 19c5246d2516 ("ext4: add new online resize interface")
Signed-off-by: Kirill Tkhai <ktkhai@virtuozzo.com>
commit 7bc04c5c2cc467c5b40f2b03ba08da174a0d5fa7 upstream.
When remounting with debug_want_extra_isize, we were not performing the
same checks that we do during a normal mount. That allowed us to set a
value for s_want_extra_isize that reached outside the s_inode_size.
Fixes: e2b911c53584 ("ext4: clean up feature test macros with predicate functions")
Reported-by: syzbot+f584efa0ac7213c226b7@syzkaller.appspotmail.com
Signed-off-by: Barret Rhoden <brho@google.com>
commit 8c380ab4b7b59c0c602743810be1b712514eaebc upstream.
The reference to iloc.bh has been dropped in ext4_mark_iloc_dirty.
However, the reference is dropped again if error occurs during
ext4_handle_dirty_metadata, which may result in use-after-free bugs.
Fixes: fb265c9cb49e("ext4: add ext4_sb_bread() to disambiguate ENOMEM cases")
Signed-off-by: Pan Bian <bianpan2016@163.com>
commit e5d01196c0428a206f307e9ee5f6842964098ff0 upstream.
In other places in fs/ext4/xattr.c, if e_value_inum is non-zero, the
code ignores the value in e_value_offs. The e_value_offs *should* be
zero, but we shouldn't depend upon it, since it might not be true in a
corrupted/fuzzed file system.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=202897
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=202877
commit 31562b954b60f02acb91b7349dc6432d3f8c3c5f upstream.
The sanity check in mb_find_extent() only checked that returned extent
does not extend past blocksize * 8, however it should not extend past
EXT4_CLUSTERS_PER_GROUP(sb). This can happen when clusters_per_group <
blocksize * 8 and the tail of the bitmap is not properly filled by 1s
which happened e.g. when ancient kernels have grown the filesystem.
commit 7159a986b4202343f6cca3bb8079ecace5816fd6 upstream.
We can't pass error pointers to brelse().
Fixes: fb265c9cb49e ("ext4: add ext4_sb_bread() to disambiguate ENOMEM cases")
[ Upstream commit 18915b5873f07e5030e6fb108a050fa7c71c59fb ]
The ext4 fstrim implementation uses the block bitmaps to find free space
that can be discarded. If we haven't replayed the journal, the bitmaps
will be stale and we absolutely *cannot* use stale metadata to zap the
underlying storage.
[ Upstream commit 6c7328400e0488f7d49e19e02290ba343b6811b2 ]
Currently when the file system resize using ext4_resize_fs() fails it
will report into log that "resized filesystem to <requested block
count>". However this may not be true in the case of failure. Use the
current block count as returned by ext4_blocks_count() to report the
block count.
Additionally, report a warning that "error occurred during file system
resize"
[ Upstream commit d64264d6218e6892edd832dc3a5a5857c2856c53 ]
Currently in add_new_gdb_meta_bg() there is a missing brelse of gdb_bh
in case ext4_journal_get_write_access() fails.
Additionally kvfree() is missing in the same error path. Fix it by
moving the ext4_journal_get_write_access() before the ext4 sb update as
Ted suggested and release n_group_desc and gdb_bh in case it fails.
Fixes: 61a9c11e5e7a ("ext4: add missing brelse() add_new_gdb_meta_bg()'s error path")
commit 5e86bdda41534e17621d5a071b294943cae4376e upstream.
Currently, we are releasing the indirect buffer where we are done with
it in ext4_ind_remove_space(), so we can see the brelse() and
BUFFER_TRACE() everywhere. It seems fragile and hard to read, and we
may probably forget to release the buffer some day. This patch cleans
up the code by putting of the code which releases the buffers to the
end of the function.
Cc: Jari Ruusu <jari.ruusu@gmail.com>
commit 674a2b27234d1b7afcb0a9162e81b2e53aeef217 upstream.
All indirect buffers get by ext4_find_shared() should be released no
mater the branch should be freed or not. But now, we forget to release
the lower depth indirect buffers when removing space from the same
higher depth indirect block. It will lead to buffer leak and futher
more, it may lead to quota information corruption when using old quota,
consider the following case.
- Create and mount an empty ext4 filesystem without extent and quota
features,
- quotacheck and enable the user & group quota,
- Create some files and write some data to them, and then punch hole
to some files of them, it may trigger the buffer leak problem
mentioned above.
- Disable quota and run quotacheck again, it will create two new
aquota files and write the checked quota information to them, which
probably may reuse the freed indirect block(the buffer and page
cache was not freed) as data block.
- Enable quota again, it will invoke
vfs_load_quota_inode()->invalidate_bdev() to try to clean unused
buffers and pagecache. Unfortunately, because of the buffer of quota
data block is still referenced, quota code cannot read the up to date
quota info from the device and lead to quota information corruption.
This problem can be reproduced by xfstests generic/231 on ext3 file
system or ext4 file system without extent and quota features.
This patch fix this problem by releasing the missing indirect buffers,
in ext4_ind_remove_space().
commit 372a03e01853f860560eade508794dd274e9b390 upstream.
Ext4 needs to serialize unaligned direct AIO because the zeroing of
partial blocks of two competing unaligned AIOs can result in data
corruption.
However it decides not to serialize if the potentially unaligned aio is
past i_size with the rationale that no pending writes are possible past
i_size. Unfortunately if the i_size is not block aligned and the second
unaligned write lands past i_size, but still into the same block, it has
the potential of corrupting the previous unaligned write to the same
block.
This is (very simplified) reproducer from Frank
// 41472 = (10 * 4096) + 512
// 37376 = 41472 - 4096
ftruncate(fd, 41472);
io_prep_pwrite(iocbs[0], fd, buf[0], 4096, 37376);
io_prep_pwrite(iocbs[1], fd, buf[1], 4096, 41472);
io_submit(io_ctx, 1, &iocbs[1]);
io_submit(io_ctx, 1, &iocbs[2]);
io_getevents(io_ctx, 2, 2, events, NULL);
Without this patch the 512B range from 40960 up to the start of the
second unaligned write (41472) is going to be zeroed overwriting the data
written by the first write. This is a data corruption.
00000000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00009200 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30 30
0000a000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0000a200 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31
With this patch the data corruption is avoided because we will recognize
the unaligned_aio and wait for the unwritten extent conversion.
0000b200
Reported-by: Frank Sorenson <fsorenso@redhat.com>
Fixes: e9e3bcecf44c ("ext4: serialize unaligned asynchronous DIO")
commit fa30dde38aa8628c73a6dded7cb0bba38c27b576 upstream.
We see the following NULL pointer dereference while running xfstests
generic/475:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
PGD 8000000c84bad067 P4D 8000000c84bad067 PUD c84e62067 PMD 0
Oops: 0000 [#1] SMP PTI
CPU: 7 PID: 9886 Comm: fsstress Kdump: loaded Not tainted 5.0.0-rc8 #10
RIP: 0010:ext4_do_update_inode+0x4ec/0x760
Call Trace:
? jbd2_journal_get_write_access+0x42/0x50
? __ext4_journal_get_write_access+0x2c/0x70
? ext4_truncate+0x186/0x3f0
ext4_mark_iloc_dirty+0x61/0x80
ext4_mark_inode_dirty+0x62/0x1b0
? unmap_mapping_pages+0x56/0x100
ext4_setattr+0x817/0x8b0
notify_change+0x1df/0x430
do_truncate+0x5e/0x90
? generic_permission+0x12b/0x1a0
This is triggered because the NULL pointer handle->h_transaction was
dereferenced in function ext4_update_inode_fsync_trans().
I found that the h_transaction was set to NULL in jbd2__journal_restart
but failed to attached to a new transaction while the journal is aborted.
Fix this by checking the handle before updating the inode.
Fixes: b436b9bef84d ("ext4: Wait for proper transaction commit on fsync")
Signed-off-by: Jiufei Xue <jiufei.xue@linux.alibaba.com>
Reviewed-by: Joseph Qi <joseph.qi@linux.alibaba.com>
commit f96c3ac8dfc24b4e38fc4c2eba5fea2107b929d1 upstream.
When computing maximum size of filesystem possible with given number of
group descriptor blocks, we forget to include s_first_data_block into
the number of blocks. Thus for filesystems with non-zero
s_first_data_block it can happen that computed maximum filesystem size
is actually lower than current filesystem size which confuses the code
and eventually leads to a BUG_ON in ext4_alloc_group_tables() hitting on
flex_gd->count == 0. The problem can be reproduced like:
truncate -s 100g /tmp/image
mkfs.ext4 -b 1024 -E resize=262144 /tmp/image 32768
mount -t ext4 -o loop /tmp/image /mnt
resize2fs /dev/loop0 262145
resize2fs /dev/loop0 300000
Fix the problem by properly including s_first_data_block into the
computed number of filesystem blocks.
Fixes: 1c6bd7173d66 "ext4: convert file system to meta_bg if needed..."
commit abdc644e8cbac2e9b19763680e5a7cf9bab2bee7 upstream.
The reason is that while swapping two inode, we swap the flags too.
Some flags such as EXT4_JOURNAL_DATA_FL can really confuse the things
since we're not resetting the address operations structure. The
simplest way to keep things sane is to restrict the flags that can be
swapped.
commit 8fdd60f2ae3682caf2a7258626abc21eb4711892 upstream.
This reverts commit ad211f3e94b314a910d4af03178a0b52a7d1ee0a.
As Jan Kara pointed out, this change was unsafe since it means we lose
the call to sync_mapping_buffers() in the nojournal case. The
original point of the commit was avoid taking the inode mutex (since
it causes a lockdep warning in generic/113); but we need the mutex in
order to call sync_mapping_buffers().
The real fix to this problem was discussed here:
https://lore.kernel.org/lkml/20181025150540.259281-4-bvanassche@acm.org
The proposed patch was to fix a syzbot complaint, but the problem can
also demonstrated via "kvm-xfstests -c nojournal generic/113".
Multiple solutions were discused in the e-mail thread, but none have
landed in the kernel as of this writing. Anyway, commit
ad211f3e94b314 is absolutely the wrong way to suppress the lockdep, so
revert it.
Fixes: ad211f3e94b314a910d4af03178a0b52a7d1ee0a ("ext4: use ext4_write_inode() when fsyncing w/o a journal")
Reported: Jan Kara <jack@suse.cz>
commit 95cb67138746451cc84cf8e516e14989746e93b0 upstream.
We already using mapping_set_error() in fs/ext4/page_io.c, so all we
need to do is to use file_check_and_advance_wb_err() when handling
fsync() requests in ext4_sync_file().
commit ad211f3e94b314a910d4af03178a0b52a7d1ee0a upstream.
In no-journal mode, we previously used __generic_file_fsync() in
no-journal mode. This triggers a lockdep warning, and in addition,
it's not safe to depend on the inode writeback mechanism in the case
ext4. We can solve both problems by calling ext4_write_inode()
directly.
commit e86807862e6880809f191c4cea7f88a489f0ed34 upstream.
The xfstests generic/475 test switches the underlying device with
dm-error while running a stress test. This results in a large number
of file system errors, and since we can't lock the buffer head when
marking the superblock dirty in the ext4_grp_locked_error() case, it's
possible the superblock to be !buffer_uptodate() without
buffer_write_io_error() being true.
We need to set buffer_uptodate() before we call mark_buffer_dirty() or
this will trigger a WARN_ON. It's safe to do this since the
superblock must have been properly read into memory or the mount would
have been successful. So if buffer_uptodate() is not set, we can
safely assume that this happened due to a failed attempt to write the
superblock.
commit 2b08b1f12cd664dc7d5c84ead9ff25ae97ad5491 upstream.
The ext4_inline_data_fiemap() function calls fiemap_fill_next_extent()
while still holding the xattr semaphore. This is not necessary and it
triggers a circular lockdep warning. This is because
fiemap_fill_next_extent() could trigger a page fault when it writes
into page which triggers a page fault. If that page is mmaped from
the inline file in question, this could very well result in a
deadlock.
This problem can be reproduced using generic/519 with a file system
configuration which has the inline_data feature enabled.
commit 812c0cab2c0dfad977605dbadf9148490ca5d93f upstream.
There are enough credits reserved for most dioread_nolock writes;
however, if the extent tree is sufficiently deep, and/or quota is
enabled, the code was not allowing for all eventualities when
reserving journal credits for the unwritten extent conversion.
This problem can be seen using xfstests ext4/034:
WARNING: CPU: 1 PID: 257 at fs/ext4/ext4_jbd2.c:271 __ext4_handle_dirty_metadata+0x10c/0x180
Workqueue: ext4-rsv-conversion ext4_end_io_rsv_work
RIP: 0010:__ext4_handle_dirty_metadata+0x10c/0x180
EXT4-fs: ext4_free_blocks:4938: aborting transaction: error 28 in __ext4_handle_dirty_metadata
EXT4: jbd2_journal_dirty_metadata failed: handle type 11 started at line 4921, credits 4/0, errcode -28
EXT4-fs error (device dm-1) in ext4_free_blocks:4950: error 28
commit 18f2c4fcebf2582f96cbd5f2238f4f354a0e4847 upstream.
If the file system has been shut down or is read-only, then
ext4_write_inode() needs to bail out early.
Also use jbd2_complete_transaction() instead of ext4_force_commit() so
we only force a commit if it is needed.
commit fde872682e175743e0c3ef939c89e3c6008a1529 upstream.
Some time back, nfsd switched from calling vfs_fsync() to using a new
commit_metadata() hook in export_operations(). If the file system did
not provide a commit_metadata() hook, it fell back to using
sync_inode_metadata(). Unfortunately doesn't work on all file
systems. In particular, it doesn't work on ext4 due to how the inode
gets journalled --- the VFS writeback code will not always call
ext4_write_inode().
So we need to provide our own ext4_nfs_commit_metdata() method which
calls ext4_write_inode() directly.
Google-Bug-Id: 121195940
commit a805622a757b6d7f65def4141d29317d8e37b8a1 upstream.
In ext4_expand_extra_isize_ea(), we calculate the total size of the
xattr header, plus the xattr entries so we know how much of the
beginning part of the xattrs to move when expanding the inode extra
size. We need to include the terminating u32 at the end of the xattr
entries, or else if there is uninitialized, non-zero bytes after the
xattr entries and before the xattr values, the list of xattr entries
won't be properly terminated.
Reported-by: Steve Graham <stgraham2000@gmail.com>
commit e647e29196b7f802f8242c39ecb7cc937f5ef217 upstream.
Commit e2b911c53584 ("ext4: clean up feature test macros with
predicate functions") broke the EXT4_IOC_GROUP_ADD ioctl. This was
not noticed since only very old versions of resize2fs (before
e2fsprogs 1.42) use this ioctl. However, using a new kernel with an
enterprise Linux userspace will cause attempts to use online resize to
fail with "No reserved GDT blocks".
Fixes: e2b911c53584 ("ext4: clean up feature test macros with predicate...")
Cc: stable@kernel.org # v4.4
Signed-off-by: ruippan (潘睿) <ruippan@tencent.com>
commit 132d00becb31e88469334e1e62751c81345280e0 upstream.
In case of error, ext4_try_to_write_inline_data() should unlock
and release the page it holds.
Fixes: f19d5870cbf7 ("ext4: add normal write support for inline data")
Cc: stable@kernel.org # 3.8
Signed-off-by: Maurizio Lombardi <mlombard@redhat.com>
commit 61157b24e60fb3cd1f85f2c76a7b1d628f970144 upstream.
The function frees qf_inode via iput but then pass qf_inode to
lockdep_set_quota_inode on the failure path. This may result in a
use-after-free bug. The patch frees df_inode only when it is never used.
Fixes: daf647d2dd5 ("ext4: add lockdep annotations for i_data_sem")
Cc: stable@kernel.org # 4.6
commit fb265c9cb49e2074ddcdd4de99728aefdd3b3592 upstream.
Today, when sb_bread() returns NULL, this can either be because of an
I/O error or because the system failed to allocate the buffer. Since
it's an old interface, changing would require changing many call
sites.
So instead we create our own ext4_sb_bread(), which also allows us to
set the REQ_META flag.
Also fixed a problem in the xattr code where a NULL return in a
function could also mean that the xattr was not found, which could
lead to the wrong error getting returned to userspace.
Fixes: ac27a0ec112a ("ext4: initial copy of files from ext3")
Cc: stable@kernel.org # 2.6.19
commit de59fae0043f07de5d25e02ca360f7d57bfa5866 upstream.
Fixes: dc6982ff4db1 ("ext4: refactor code to read directory blocks ...")
Signed-off-by: Vasily Averin <vvs@virtuozzo.com>
Cc: stable@kernel.org # 3.9
commit 53692ec074d00589c2cf1d6d17ca76ad0adce6ec upstream.
Fixes: de05ca852679 ("ext4: move call to ext4_error() into ...")
Cc: stable@kernel.org # 4.17
commit 6bdc9977fcdedf47118d2caf7270a19f4b6d8a8f upstream.
Fixes: 3f2571c1f91f ("ext4: factor out xattr moving")
Fixes: 6dd4ee7cab7e ("ext4: Expand extra_inodes space per ...")
Cc: stable@kernel.org # 2.6.23
commit 45ae932d246f721e6584430017176cbcadfde610 upstream.
bs.bh was taken in previous ext4_xattr_block_find() call,
it should be released before re-using
Fixes: 7e01c8e5420b ("ext3/4: fix uninitialized bs in ...")
Cc: stable@kernel.org # 2.6.26
commit ecaaf408478b6fb4d9986f9b6652f3824e374f4c upstream.
Fixes: dec214d00e0d ("ext4: xattr inode deduplication")
Cc: stable@kernel.org # 4.13
