commit 1f0d5c911b64165c9754139a26c8c2fad352c132 upstream.
We expect 64-bit calculation result from below statement, however
in 32-bit machine, looped left shift operation on pgoff_t type
variable may cause overflow issue, fix it by forcing type cast.
page->index << PAGE_SHIFT;
Fixes: 26de9b117130 ("f2fs: avoid unnecessary updating inode during fsync")
Fixes: 0a2aa8fbb969 ("f2fs: refactor __exchange_data_block for speed up")
Signed-off-by: Chao Yu <yuchao0@huawei.com>
Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
[ Upstream commit 2baf07818549c8bb8d7b3437e889b86eab56d38e ]
We need to drop PG_checked flag on page as well when we clear PG_uptodate
flag, in order to avoid treating the page as GCing one later.
Signed-off-by: Weichao Guo <guoweichao@huawei.com>
commit 91291e9998d208370eb8156c760691b873bd7522 upstream.
This patch adds f2fs_is_valid_blkaddr() in below functions to do sanity
check with block address to avoid pentential panic:
- f2fs_grab_read_bio()
- __written_first_block()
https://bugzilla.kernel.org/show_bug.cgi?id=200465
- Reproduce
- POC (poc.c)
#define _GNU_SOURCE
#include <sys/types.h>
#include <sys/mount.h>
#include <sys/mman.h>
#include <sys/stat.h>
#include <sys/xattr.h>
#include <dirent.h>
#include <errno.h>
#include <error.h>
#include <fcntl.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <linux/falloc.h>
#include <linux/loop.h>
static void activity(char *mpoint) {
char *xattr;
int err;
err = asprintf(&xattr, "%s/foo/bar/xattr", mpoint);
char buf2[113];
memset(buf2, 0, sizeof(buf2));
listxattr(xattr, buf2, sizeof(buf2));
int main(int argc, char *argv[]) {
activity(argv[1]);
return 0;
- kernel message
[ 844.718738] F2FS-fs (loop0): Mounted with checkpoint version = 2
[ 846.430929] F2FS-fs (loop0): access invalid blkaddr:1024
[ 846.431058] WARNING: CPU: 1 PID: 1249 at fs/f2fs/checkpoint.c:154 f2fs_is_valid_blkaddr+0x10f/0x160
[ 846.431059] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_timer snd input_leds joydev soundcore serio_raw i2c_piix4 mac_hid ib_iser rdma_cm iw_cm ib_cm ib_core configfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi autofs4 raid10 raid456 libcrc32c async_raid6_recov async_memcpy async_pq async_xor xor async_tx raid6_pq raid1 raid0 multipath linear qxl ttm crct10dif_pclmul crc32_pclmul drm_kms_helper ghash_clmulni_intel syscopyarea sysfillrect sysimgblt fb_sys_fops pcbc drm 8139too aesni_intel 8139cp floppy psmouse mii aes_x86_64 crypto_simd pata_acpi cryptd glue_helper
[ 846.431310] CPU: 1 PID: 1249 Comm: a.out Not tainted 4.18.0-rc3+ #1
[ 846.431312] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 846.431315] RIP: 0010:f2fs_is_valid_blkaddr+0x10f/0x160
[ 846.431316] Code: 00 eb ed 31 c0 83 fa 05 75 ae 48 83 ec 08 48 8b 3f 89 f1 48 c7 c2 fc 0b 0f 8b 48 c7 c6 8b d7 09 8b 88 44 24 07 e8 61 8b ff ff <0f> 0b 0f b6 44 24 07 48 83 c4 08 eb 81 4c 8b 47 10 8b 8f 38 04 00
[ 846.431347] RSP: 0018:ffff961c414a7bc0 EFLAGS: 00010282
[ 846.431349] RAX: 0000000000000000 RBX: ffffc5f787b8ea80 RCX: 0000000000000000
[ 846.431350] RDX: 0000000000000000 RSI: ffff89dfffd165d8 RDI: ffff89dfffd165d8
[ 846.431351] RBP: ffff961c414a7c20 R08: 0000000000000001 R09: 0000000000000248
[ 846.431353] R10: 0000000000000000 R11: 0000000000000248 R12: 0000000000000007
[ 846.431369] R13: ffff89dff5492800 R14: ffff89dfae3aa000 R15: ffff89dff4ff88d0
[ 846.431372] FS: 00007f882e2fb700(0000) GS:ffff89dfffd00000(0000) knlGS:0000000000000000
[ 846.431373] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 846.431374] CR2: 0000000001a88008 CR3: 00000001eb572000 CR4: 00000000000006e0
[ 846.431384] Call Trace:
[ 846.431426] f2fs_iget+0x6f4/0xe70
[ 846.431430] ? f2fs_find_entry+0x71/0x90
[ 846.431432] f2fs_lookup+0x1aa/0x390
[ 846.431452] __lookup_slow+0x97/0x150
[ 846.431459] lookup_slow+0x35/0x50
[ 846.431462] walk_component+0x1c6/0x470
[ 846.431479] ? memcg_kmem_charge_memcg+0x70/0x90
[ 846.431488] ? page_add_file_rmap+0x13/0x200
[ 846.431491] path_lookupat+0x76/0x230
[ 846.431501] ? __alloc_pages_nodemask+0xfc/0x280
[ 846.431504] filename_lookup+0xb8/0x1a0
[ 846.431534] ? _cond_resched+0x16/0x40
[ 846.431541] ? kmem_cache_alloc+0x160/0x1d0
[ 846.431549] ? path_listxattr+0x41/0xa0
[ 846.431551] path_listxattr+0x41/0xa0
[ 846.431570] do_syscall_64+0x55/0x100
[ 846.431583] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 846.431607] RIP: 0033:0x7f882de1c0d7
[ 846.431607] Code: f0 ff ff 73 01 c3 48 8b 0d be dd 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 b8 c2 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 91 dd 2b 00 f7 d8 64 89 01 48
[ 846.431639] RSP: 002b:00007ffe8e66c238 EFLAGS: 00000202 ORIG_RAX: 00000000000000c2
[ 846.431641] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f882de1c0d7
[ 846.431642] RDX: 0000000000000071 RSI: 00007ffe8e66c280 RDI: 0000000001a880c0
[ 846.431643] RBP: 00007ffe8e66c300 R08: 0000000001a88010 R09: 0000000000000000
[ 846.431645] R10: 00000000000001ab R11: 0000000000000202 R12: 0000000000400550
[ 846.431646] R13: 00007ffe8e66c400 R14: 0000000000000000 R15: 0000000000000000
[ 846.431648] ---[ end trace abca54df39d14f5c ]---
[ 846.431651] F2FS-fs (loop0): invalid blkaddr: 1024, type: 5, run fsck to fix.
[ 846.431762] WARNING: CPU: 1 PID: 1249 at fs/f2fs/f2fs.h:2697 f2fs_iget+0xd17/0xe70
[ 846.431763] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_timer snd input_leds joydev soundcore serio_raw i2c_piix4 mac_hid ib_iser rdma_cm iw_cm ib_cm ib_core configfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi autofs4 raid10 raid456 libcrc32c async_raid6_recov async_memcpy async_pq async_xor xor async_tx raid6_pq raid1 raid0 multipath linear qxl ttm crct10dif_pclmul crc32_pclmul drm_kms_helper ghash_clmulni_intel syscopyarea sysfillrect sysimgblt fb_sys_fops pcbc drm 8139too aesni_intel 8139cp floppy psmouse mii aes_x86_64 crypto_simd pata_acpi cryptd glue_helper
[ 846.431797] CPU: 1 PID: 1249 Comm: a.out Tainted: G W 4.18.0-rc3+ #1
[ 846.431798] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 846.431800] RIP: 0010:f2fs_iget+0xd17/0xe70
[ 846.431801] Code: ff ff 48 63 d8 e9 e1 f6 ff ff 48 8b 45 c8 41 b8 05 00 00 00 48 c7 c2 d8 e8 0e 8b 48 c7 c6 1d b0 0a 8b 48 8b 38 e8 f9 b4 00 00 <0f> 0b 48 8b 45 c8 f0 80 48 48 04 e9 d8 f9 ff ff 0f 0b 48 8b 43 18
[ 846.431832] RSP: 0018:ffff961c414a7bd0 EFLAGS: 00010282
[ 846.431834] RAX: 0000000000000000 RBX: ffffc5f787b8ea80 RCX: 0000000000000006
[ 846.431835] RDX: 0000000000000000 RSI: 0000000000000096 RDI: ffff89dfffd165d0
[ 846.431836] RBP: ffff961c414a7c20 R08: 0000000000000000 R09: 0000000000000273
[ 846.431837] R10: 0000000000000000 R11: ffff89dfad50ca60 R12: 0000000000000007
[ 846.431838] R13: ffff89dff5492800 R14: ffff89dfae3aa000 R15: ffff89dff4ff88d0
[ 846.431840] FS: 00007f882e2fb700(0000) GS:ffff89dfffd00000(0000) knlGS:0000000000000000
[ 846.431841] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 846.431842] CR2: 0000000001a88008 CR3: 00000001eb572000 CR4: 00000000000006e0
[ 846.431846] Call Trace:
[ 846.431850] ? f2fs_find_entry+0x71/0x90
[ 846.431853] f2fs_lookup+0x1aa/0x390
[ 846.431856] __lookup_slow+0x97/0x150
[ 846.431858] lookup_slow+0x35/0x50
[ 846.431874] walk_component+0x1c6/0x470
[ 846.431878] ? memcg_kmem_charge_memcg+0x70/0x90
[ 846.431880] ? page_add_file_rmap+0x13/0x200
[ 846.431882] path_lookupat+0x76/0x230
[ 846.431884] ? __alloc_pages_nodemask+0xfc/0x280
[ 846.431886] filename_lookup+0xb8/0x1a0
[ 846.431890] ? _cond_resched+0x16/0x40
[ 846.431891] ? kmem_cache_alloc+0x160/0x1d0
[ 846.431894] ? path_listxattr+0x41/0xa0
[ 846.431896] path_listxattr+0x41/0xa0
[ 846.431898] do_syscall_64+0x55/0x100
[ 846.431901] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 846.431902] RIP: 0033:0x7f882de1c0d7
[ 846.431903] Code: f0 ff ff 73 01 c3 48 8b 0d be dd 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 b8 c2 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 91 dd 2b 00 f7 d8 64 89 01 48
[ 846.431934] RSP: 002b:00007ffe8e66c238 EFLAGS: 00000202 ORIG_RAX: 00000000000000c2
[ 846.431936] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f882de1c0d7
[ 846.431937] RDX: 0000000000000071 RSI: 00007ffe8e66c280 RDI: 0000000001a880c0
[ 846.431939] RBP: 00007ffe8e66c300 R08: 0000000001a88010 R09: 0000000000000000
[ 846.431940] R10: 00000000000001ab R11: 0000000000000202 R12: 0000000000400550
[ 846.431941] R13: 00007ffe8e66c400 R14: 0000000000000000 R15: 0000000000000000
[ 846.431943] ---[ end trace abca54df39d14f5d ]---
[ 846.432033] F2FS-fs (loop0): access invalid blkaddr:1024
[ 846.432051] WARNING: CPU: 1 PID: 1249 at fs/f2fs/checkpoint.c:154 f2fs_is_valid_blkaddr+0x10f/0x160
[ 846.432051] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_timer snd input_leds joydev soundcore serio_raw i2c_piix4 mac_hid ib_iser rdma_cm iw_cm ib_cm ib_core configfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi autofs4 raid10 raid456 libcrc32c async_raid6_recov async_memcpy async_pq async_xor xor async_tx raid6_pq raid1 raid0 multipath linear qxl ttm crct10dif_pclmul crc32_pclmul drm_kms_helper ghash_clmulni_intel syscopyarea sysfillrect sysimgblt fb_sys_fops pcbc drm 8139too aesni_intel 8139cp floppy psmouse mii aes_x86_64 crypto_simd pata_acpi cryptd glue_helper
[ 846.432085] CPU: 1 PID: 1249 Comm: a.out Tainted: G W 4.18.0-rc3+ #1
[ 846.432086] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 846.432089] RIP: 0010:f2fs_is_valid_blkaddr+0x10f/0x160
[ 846.432089] Code: 00 eb ed 31 c0 83 fa 05 75 ae 48 83 ec 08 48 8b 3f 89 f1 48 c7 c2 fc 0b 0f 8b 48 c7 c6 8b d7 09 8b 88 44 24 07 e8 61 8b ff ff <0f> 0b 0f b6 44 24 07 48 83 c4 08 eb 81 4c 8b 47 10 8b 8f 38 04 00
[ 846.432120] RSP: 0018:ffff961c414a7900 EFLAGS: 00010286
[ 846.432122] RAX: 0000000000000000 RBX: 0000000000000400 RCX: 0000000000000006
[ 846.432123] RDX: 0000000000000000 RSI: 0000000000000096 RDI: ffff89dfffd165d0
[ 846.432124] RBP: ffff89dff5492800 R08: 0000000000000001 R09: 000000000000029d
[ 846.432125] R10: ffff961c414a7820 R11: 000000000000029d R12: 0000000000000400
[ 846.432126] R13: 0000000000000000 R14: ffff89dff4ff88d0 R15: 0000000000000000
[ 846.432128] FS: 00007f882e2fb700(0000) GS:ffff89dfffd00000(0000) knlGS:0000000000000000
[ 846.432130] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 846.432131] CR2: 0000000001a88008 CR3: 00000001eb572000 CR4: 00000000000006e0
[ 846.432135] Call Trace:
[ 846.432151] f2fs_wait_on_block_writeback+0x20/0x110
[ 846.432158] f2fs_grab_read_bio+0xbc/0xe0
[ 846.432161] f2fs_submit_page_read+0x21/0x280
[ 846.432163] f2fs_get_read_data_page+0xb7/0x3c0
[ 846.432165] f2fs_get_lock_data_page+0x29/0x1e0
[ 846.432167] f2fs_get_new_data_page+0x148/0x550
[ 846.432170] f2fs_add_regular_entry+0x1d2/0x550
[ 846.432178] ? __switch_to+0x12f/0x460
[ 846.432181] f2fs_add_dentry+0x6a/0xd0
[ 846.432184] f2fs_do_add_link+0xe9/0x140
[ 846.432186] __recover_dot_dentries+0x260/0x280
[ 846.432189] f2fs_lookup+0x343/0x390
[ 846.432193] __lookup_slow+0x97/0x150
[ 846.432195] lookup_slow+0x35/0x50
[ 846.432208] walk_component+0x1c6/0x470
[ 846.432212] ? memcg_kmem_charge_memcg+0x70/0x90
[ 846.432215] ? page_add_file_rmap+0x13/0x200
[ 846.432217] path_lookupat+0x76/0x230
[ 846.432219] ? __alloc_pages_nodemask+0xfc/0x280
[ 846.432221] filename_lookup+0xb8/0x1a0
[ 846.432224] ? _cond_resched+0x16/0x40
[ 846.432226] ? kmem_cache_alloc+0x160/0x1d0
[ 846.432228] ? path_listxattr+0x41/0xa0
[ 846.432230] path_listxattr+0x41/0xa0
[ 846.432233] do_syscall_64+0x55/0x100
[ 846.432235] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 846.432237] RIP: 0033:0x7f882de1c0d7
[ 846.432237] Code: f0 ff ff 73 01 c3 48 8b 0d be dd 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 b8 c2 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 91 dd 2b 00 f7 d8 64 89 01 48
[ 846.432269] RSP: 002b:00007ffe8e66c238 EFLAGS: 00000202 ORIG_RAX: 00000000000000c2
[ 846.432271] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f882de1c0d7
[ 846.432272] RDX: 0000000000000071 RSI: 00007ffe8e66c280 RDI: 0000000001a880c0
[ 846.432273] RBP: 00007ffe8e66c300 R08: 0000000001a88010 R09: 0000000000000000
[ 846.432274] R10: 00000000000001ab R11: 0000000000000202 R12: 0000000000400550
[ 846.432275] R13: 00007ffe8e66c400 R14: 0000000000000000 R15: 0000000000000000
[ 846.432277] ---[ end trace abca54df39d14f5e ]---
[ 846.432279] F2FS-fs (loop0): invalid blkaddr: 1024, type: 5, run fsck to fix.
[ 846.432376] WARNING: CPU: 1 PID: 1249 at fs/f2fs/f2fs.h:2697 f2fs_wait_on_block_writeback+0xb1/0x110
[ 846.432376] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_timer snd input_leds joydev soundcore serio_raw i2c_piix4 mac_hid ib_iser rdma_cm iw_cm ib_cm ib_core configfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi autofs4 raid10 raid456 libcrc32c async_raid6_recov async_memcpy async_pq async_xor xor async_tx raid6_pq raid1 raid0 multipath linear qxl ttm crct10dif_pclmul crc32_pclmul drm_kms_helper ghash_clmulni_intel syscopyarea sysfillrect sysimgblt fb_sys_fops pcbc drm 8139too aesni_intel 8139cp floppy psmouse mii aes_x86_64 crypto_simd pata_acpi cryptd glue_helper
[ 846.432410] CPU: 1 PID: 1249 Comm: a.out Tainted: G W 4.18.0-rc3+ #1
[ 846.432411] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 846.432413] RIP: 0010:f2fs_wait_on_block_writeback+0xb1/0x110
[ 846.432414] Code: 66 90 f0 ff 4b 34 74 59 5b 5d c3 48 8b 7d 00 41 b8 05 00 00 00 89 d9 48 c7 c2 d8 e8 0e 8b 48 c7 c6 1d b0 0a 8b e8 df bc fd ff <0f> 0b f0 80 4d 48 04 e9 67 ff ff ff 48 8b 03 48 c1 e8 37 83 e0 07
[ 846.432445] RSP: 0018:ffff961c414a7910 EFLAGS: 00010286
[ 846.432447] RAX: 0000000000000000 RBX: 0000000000000400 RCX: 0000000000000006
[ 846.432448] RDX: 0000000000000000 RSI: 0000000000000092 RDI: ffff89dfffd165d0
[ 846.432449] RBP: ffff89dff5492800 R08: 0000000000000000 R09: 00000000000002d1
[ 846.432450] R10: ffff961c414a7820 R11: ffff89dfad50cf80 R12: 0000000000000400
[ 846.432451] R13: 0000000000000000 R14: ffff89dff4ff88d0 R15: 0000000000000000
[ 846.432453] FS: 00007f882e2fb700(0000) GS:ffff89dfffd00000(0000) knlGS:0000000000000000
[ 846.432454] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 846.432455] CR2: 0000000001a88008 CR3: 00000001eb572000 CR4: 00000000000006e0
[ 846.432459] Call Trace:
[ 846.432463] f2fs_grab_read_bio+0xbc/0xe0
[ 846.432464] f2fs_submit_page_read+0x21/0x280
[ 846.432466] f2fs_get_read_data_page+0xb7/0x3c0
[ 846.432468] f2fs_get_lock_data_page+0x29/0x1e0
[ 846.432470] f2fs_get_new_data_page+0x148/0x550
[ 846.432473] f2fs_add_regular_entry+0x1d2/0x550
[ 846.432475] ? __switch_to+0x12f/0x460
[ 846.432477] f2fs_add_dentry+0x6a/0xd0
[ 846.432480] f2fs_do_add_link+0xe9/0x140
[ 846.432483] __recover_dot_dentries+0x260/0x280
[ 846.432485] f2fs_lookup+0x343/0x390
[ 846.432488] __lookup_slow+0x97/0x150
[ 846.432490] lookup_slow+0x35/0x50
[ 846.432505] walk_component+0x1c6/0x470
[ 846.432509] ? memcg_kmem_charge_memcg+0x70/0x90
[ 846.432511] ? page_add_file_rmap+0x13/0x200
[ 846.432513] path_lookupat+0x76/0x230
[ 846.432515] ? __alloc_pages_nodemask+0xfc/0x280
[ 846.432517] filename_lookup+0xb8/0x1a0
[ 846.432520] ? _cond_resched+0x16/0x40
[ 846.432522] ? kmem_cache_alloc+0x160/0x1d0
[ 846.432525] ? path_listxattr+0x41/0xa0
[ 846.432526] path_listxattr+0x41/0xa0
[ 846.432529] do_syscall_64+0x55/0x100
[ 846.432531] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 846.432533] RIP: 0033:0x7f882de1c0d7
[ 846.432533] Code: f0 ff ff 73 01 c3 48 8b 0d be dd 2b 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 66 90 b8 c2 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 91 dd 2b 00 f7 d8 64 89 01 48
[ 846.432565] RSP: 002b:00007ffe8e66c238 EFLAGS: 00000202 ORIG_RAX: 00000000000000c2
[ 846.432567] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f882de1c0d7
[ 846.432568] RDX: 0000000000000071 RSI: 00007ffe8e66c280 RDI: 0000000001a880c0
[ 846.432569] RBP: 00007ffe8e66c300 R08: 0000000001a88010 R09: 0000000000000000
[ 846.432570] R10: 00000000000001ab R11: 0000000000000202 R12: 0000000000400550
[ 846.432571] R13: 00007ffe8e66c400 R14: 0000000000000000 R15: 0000000000000000
[ 846.432573] ---[ end trace abca54df39d14f5f ]---
[ 846.434280] BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
[ 846.434424] PGD 80000001ebd3a067 P4D 80000001ebd3a067 PUD 1eb1ae067 PMD 0
[ 846.434551] Oops: 0000 [#1] SMP PTI
[ 846.434697] CPU: 0 PID: 44 Comm: kworker/u5:0 Tainted: G W 4.18.0-rc3+ #1
[ 846.434805] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 846.435000] Workqueue: fscrypt_read_queue decrypt_work
[ 846.435174] RIP: 0010:fscrypt_do_page_crypto+0x6e/0x2d0
[ 846.435351] Code: 00 65 48 8b 04 25 28 00 00 00 48 89 84 24 88 00 00 00 31 c0 e8 43 c2 e0 ff 49 8b 86 48 02 00 00 85 ed c7 44 24 70 00 00 00 00 <48> 8b 58 08 0f 84 14 02 00 00 48 8b 78 10 48 8b 0c 24 48 c7 84 24
[ 846.435696] RSP: 0018:ffff961c40f9bd60 EFLAGS: 00010206
[ 846.435870] RAX: 0000000000000000 RBX: ffffc5f787719b80 RCX: ffffc5f787719b80
[ 846.436051] RDX: ffffffff8b9f4b88 RSI: ffffffff8b0ae622 RDI: ffff961c40f9bdb8
[ 846.436261] RBP: 0000000000001000 R08: ffffc5f787719b80 R09: 0000000000001000
[ 846.436433] R10: 0000000000000018 R11: fefefefefefefeff R12: ffffc5f787719b80
[ 846.436562] R13: ffffc5f787719b80 R14: ffff89dff4ff88d0 R15: 0ffff89dfaddee60
[ 846.436658] FS: 0000000000000000(0000) GS:ffff89dfffc00000(0000) knlGS:0000000000000000
[ 846.436758] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 846.436898] CR2: 0000000000000008 CR3: 00000001eddd0000 CR4: 00000000000006f0
[ 846.437001] Call Trace:
[ 846.437181] ? check_preempt_wakeup+0xf2/0x230
[ 846.437276] ? check_preempt_curr+0x7c/0x90
[ 846.437370] fscrypt_decrypt_page+0x48/0x4d
[ 846.437466] __fscrypt_decrypt_bio+0x5b/0x90
[ 846.437542] decrypt_work+0x12/0x20
[ 846.437651] process_one_work+0x15e/0x3d0
[ 846.437740] worker_thread+0x4c/0x440
[ 846.437848] kthread+0xf8/0x130
[ 846.437938] ? rescuer_thread+0x350/0x350
[ 846.438022] ? kthread_associate_blkcg+0x90/0x90
[ 846.438117] ret_from_fork+0x35/0x40
[ 846.438201] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep snd_pcm snd_timer snd input_leds joydev soundcore serio_raw i2c_piix4 mac_hid ib_iser rdma_cm iw_cm ib_cm ib_core configfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi autofs4 raid10 raid456 libcrc32c async_raid6_recov async_memcpy async_pq async_xor xor async_tx raid6_pq raid1 raid0 multipath linear qxl ttm crct10dif_pclmul crc32_pclmul drm_kms_helper ghash_clmulni_intel syscopyarea sysfillrect sysimgblt fb_sys_fops pcbc drm 8139too aesni_intel 8139cp floppy psmouse mii aes_x86_64 crypto_simd pata_acpi cryptd glue_helper
[ 846.438653] CR2: 0000000000000008
[ 846.438713] ---[ end trace abca54df39d14f60 ]---
[ 846.438796] RIP: 0010:fscrypt_do_page_crypto+0x6e/0x2d0
[ 846.438844] Code: 00 65 48 8b 04 25 28 00 00 00 48 89 84 24 88 00 00 00 31 c0 e8 43 c2 e0 ff 49 8b 86 48 02 00 00 85 ed c7 44 24 70 00 00 00 00 <48> 8b 58 08 0f 84 14 02 00 00 48 8b 78 10 48 8b 0c 24 48 c7 84 24
[ 846.439084] RSP: 0018:ffff961c40f9bd60 EFLAGS: 00010206
[ 846.439176] RAX: 0000000000000000 RBX: ffffc5f787719b80 RCX: ffffc5f787719b80
[ 846.440927] RDX: ffffffff8b9f4b88 RSI: ffffffff8b0ae622 RDI: ffff961c40f9bdb8
[ 846.442083] RBP: 0000000000001000 R08: ffffc5f787719b80 R09: 0000000000001000
[ 846.443284] R10: 0000000000000018 R11: fefefefefefefeff R12: ffffc5f787719b80
[ 846.444448] R13: ffffc5f787719b80 R14: ffff89dff4ff88d0 R15: 0ffff89dfaddee60
[ 846.445558] FS: 0000000000000000(0000) GS:ffff89dfffc00000(0000) knlGS:0000000000000000
[ 846.446687] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 846.447796] CR2: 0000000000000008 CR3: 00000001eddd0000 CR4: 00000000000006f0
- Location
https://elixir.bootlin.com/linux/v4.18-rc4/source/fs/crypto/crypto.c#L149
struct crypto_skcipher *tfm = ci->ci_ctfm;
Here ci can be NULL
Note that this issue maybe require CONFIG_F2FS_FS_ENCRYPTION=y to reproduce.
Reported-by Wen Xu <wen.xu@gatech.edu>
[bwh: Backported to 4.9: adjust context]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit c9b60788fc760d136211853f10ce73dc152d1f4a upstream.
This patch add to do sanity check with below field:
- cp_pack_total_block_count
- blkaddr of data/node
- extent info
- Overview
BUG() in verify_block_addr() when writing to a corrupted f2fs image
- Reproduce (4.18 upstream kernel)
- POC (poc.c)
char *foo_bar_baz;
int err;
static int buf[8192];
memset(buf, 0, sizeof(buf));
err = asprintf(&foo_bar_baz, "%s/foo/bar/baz", mpoint);
int fd = open(foo_bar_baz, O_RDWR | O_TRUNC, 0777);
if (fd >= 0) {
write(fd, (char *)buf, sizeof(buf));
fdatasync(fd);
close(fd);
activity(argv[1]);
return 0;
- Kernel message
[ 689.349473] F2FS-fs (loop0): Mounted with checkpoint version = 3
[ 699.728662] WARNING: CPU: 0 PID: 1309 at fs/f2fs/segment.c:2860 f2fs_inplace_write_data+0x232/0x240
[ 699.728670] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hwdep snd_hda_core snd_pcm snd_timer snd mac_hid i2c_piix4 soundcore ib_iser rdma_cm iw_cm ib_cm ib_core iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear 8139too crct10dif_pclmul crc32_pclmul qxl drm_kms_helper syscopyarea aesni_intel sysfillrect sysimgblt fb_sys_fops ttm drm aes_x86_64 crypto_simd cryptd 8139cp glue_helper mii pata_acpi floppy
[ 699.729056] CPU: 0 PID: 1309 Comm: a.out Not tainted 4.18.0-rc1+ #4
[ 699.729064] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 699.729074] RIP: 0010:f2fs_inplace_write_data+0x232/0x240
[ 699.729076] Code: ff e9 cf fe ff ff 49 8d 7d 10 e8 39 45 ad ff 4d 8b 7d 10 be 04 00 00 00 49 8d 7f 48 e8 07 49 ad ff 45 8b 7f 48 e9 fb fe ff ff <0f> 0b f0 41 80 4d 48 04 e9 65 fe ff ff 90 66 66 66 66 90 55 48 8d
[ 699.729130] RSP: 0018:ffff8801f43af568 EFLAGS: 00010202
[ 699.729139] RAX: 000000000000003f RBX: ffff8801f43af7b8 RCX: ffffffffb88c9113
[ 699.729142] RDX: 0000000000000003 RSI: dffffc0000000000 RDI: ffff8802024e5540
[ 699.729144] RBP: ffff8801f43af590 R08: 0000000000000009 R09: ffffffffffffffe8
[ 699.729147] R10: 0000000000000001 R11: ffffed0039b0596a R12: ffff8802024e5540
[ 699.729149] R13: ffff8801f0335500 R14: ffff8801e3e7a700 R15: ffff8801e1ee4450
[ 699.729154] FS: 00007f9bf97f5700(0000) GS:ffff8801f6e00000(0000) knlGS:0000000000000000
[ 699.729156] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 699.729159] CR2: 00007f9bf925d170 CR3: 00000001f0c34000 CR4: 00000000000006f0
[ 699.729171] Call Trace:
[ 699.729192] f2fs_do_write_data_page+0x2e2/0xe00
[ 699.729203] ? f2fs_should_update_outplace+0xd0/0xd0
[ 699.729238] ? memcg_drain_all_list_lrus+0x280/0x280
[ 699.729269] ? __radix_tree_replace+0xa3/0x120
[ 699.729276] __write_data_page+0x5c7/0xe30
[ 699.729291] ? kasan_check_read+0x11/0x20
[ 699.729310] ? page_mapped+0x8a/0x110
[ 699.729321] ? page_mkclean+0xe9/0x160
[ 699.729327] ? f2fs_do_write_data_page+0xe00/0xe00
[ 699.729331] ? invalid_page_referenced_vma+0x130/0x130
[ 699.729345] ? clear_page_dirty_for_io+0x332/0x450
[ 699.729351] f2fs_write_cache_pages+0x4ca/0x860
[ 699.729358] ? __write_data_page+0xe30/0xe30
[ 699.729374] ? percpu_counter_add_batch+0x22/0xa0
[ 699.729380] ? kasan_check_write+0x14/0x20
[ 699.729391] ? _raw_spin_lock+0x17/0x40
[ 699.729403] ? f2fs_mark_inode_dirty_sync.part.18+0x16/0x30
[ 699.729413] ? iov_iter_advance+0x113/0x640
[ 699.729418] ? f2fs_write_end+0x133/0x2e0
[ 699.729423] ? balance_dirty_pages_ratelimited+0x239/0x640
[ 699.729428] f2fs_write_data_pages+0x329/0x520
[ 699.729433] ? generic_perform_write+0x250/0x320
[ 699.729438] ? f2fs_write_cache_pages+0x860/0x860
[ 699.729454] ? current_time+0x110/0x110
[ 699.729459] ? f2fs_preallocate_blocks+0x1ef/0x370
[ 699.729464] do_writepages+0x37/0xb0
[ 699.729468] ? f2fs_write_cache_pages+0x860/0x860
[ 699.729472] ? do_writepages+0x37/0xb0
[ 699.729478] __filemap_fdatawrite_range+0x19a/0x1f0
[ 699.729483] ? delete_from_page_cache_batch+0x4e0/0x4e0
[ 699.729496] ? __vfs_write+0x2b2/0x410
[ 699.729501] file_write_and_wait_range+0x66/0xb0
[ 699.729506] f2fs_do_sync_file+0x1f9/0xd90
[ 699.729511] ? truncate_partial_data_page+0x290/0x290
[ 699.729521] ? __sb_end_write+0x30/0x50
[ 699.729526] ? vfs_write+0x20f/0x260
[ 699.729530] f2fs_sync_file+0x9a/0xb0
[ 699.729534] ? f2fs_do_sync_file+0xd90/0xd90
[ 699.729548] vfs_fsync_range+0x68/0x100
[ 699.729554] ? __fget_light+0xc9/0xe0
[ 699.729558] do_fsync+0x3d/0x70
[ 699.729562] __x64_sys_fdatasync+0x24/0x30
[ 699.729585] do_syscall_64+0x78/0x170
[ 699.729595] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 699.729613] RIP: 0033:0x7f9bf930d800
[ 699.729615] Code: 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 83 3d 49 bf 2c 00 00 75 10 b8 4b 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8 be 78 01 00 48 89 04 24
[ 699.729668] RSP: 002b:00007ffee3606c68 EFLAGS: 00000246 ORIG_RAX: 000000000000004b
[ 699.729673] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f9bf930d800
[ 699.729675] RDX: 0000000000008000 RSI: 00000000006010a0 RDI: 0000000000000003
[ 699.729678] RBP: 00007ffee3606ca0 R08: 0000000001503010 R09: 0000000000000000
[ 699.729680] R10: 00000000000002e8 R11: 0000000000000246 R12: 0000000000400610
[ 699.729683] R13: 00007ffee3606da0 R14: 0000000000000000 R15: 0000000000000000
[ 699.729687] ---[ end trace 4ce02f25ff7d3df5 ]---
[ 699.729782] ------------[ cut here ]------------
[ 699.729785] kernel BUG at fs/f2fs/segment.h:654!
[ 699.731055] invalid opcode: 0000 [#1] SMP KASAN PTI
[ 699.732104] CPU: 0 PID: 1309 Comm: a.out Tainted: G W 4.18.0-rc1+ #4
[ 699.733684] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 699.735611] RIP: 0010:f2fs_submit_page_bio+0x29b/0x730
[ 699.736649] Code: 54 49 8d bd 18 04 00 00 e8 b2 59 af ff 41 8b 8d 18 04 00 00 8b 45 b8 41 d3 e6 44 01 f0 4c 8d 73 14 41 39 c7 0f 82 37 fe ff ff <0f> 0b 65 8b 05 2c 04 77 47 89 c0 48 0f a3 05 52 c1 d5 01 0f 92 c0
[ 699.740524] RSP: 0018:ffff8801f43af508 EFLAGS: 00010283
[ 699.741573] RAX: 0000000000000000 RBX: ffff8801f43af7b8 RCX: ffffffffb88a7cef
[ 699.743006] RDX: 0000000000000007 RSI: dffffc0000000000 RDI: ffff8801e3e7a64c
[ 699.744426] RBP: ffff8801f43af558 R08: ffffed003e066b55 R09: ffffed003e066b55
[ 699.745833] R10: 0000000000000001 R11: ffffed003e066b54 R12: ffffea0007876940
[ 699.747256] R13: ffff8801f0335500 R14: ffff8801e3e7a600 R15: 0000000000000001
[ 699.748683] FS: 00007f9bf97f5700(0000) GS:ffff8801f6e00000(0000) knlGS:0000000000000000
[ 699.750293] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 699.751462] CR2: 00007f9bf925d170 CR3: 00000001f0c34000 CR4: 00000000000006f0
[ 699.752874] Call Trace:
[ 699.753386] ? f2fs_inplace_write_data+0x93/0x240
[ 699.754341] f2fs_inplace_write_data+0xd2/0x240
[ 699.755271] f2fs_do_write_data_page+0x2e2/0xe00
[ 699.756214] ? f2fs_should_update_outplace+0xd0/0xd0
[ 699.757215] ? memcg_drain_all_list_lrus+0x280/0x280
[ 699.758209] ? __radix_tree_replace+0xa3/0x120
[ 699.759164] __write_data_page+0x5c7/0xe30
[ 699.760002] ? kasan_check_read+0x11/0x20
[ 699.760823] ? page_mapped+0x8a/0x110
[ 699.761573] ? page_mkclean+0xe9/0x160
[ 699.762345] ? f2fs_do_write_data_page+0xe00/0xe00
[ 699.763332] ? invalid_page_referenced_vma+0x130/0x130
[ 699.764374] ? clear_page_dirty_for_io+0x332/0x450
[ 699.765347] f2fs_write_cache_pages+0x4ca/0x860
[ 699.766276] ? __write_data_page+0xe30/0xe30
[ 699.767161] ? percpu_counter_add_batch+0x22/0xa0
[ 699.768112] ? kasan_check_write+0x14/0x20
[ 699.768951] ? _raw_spin_lock+0x17/0x40
[ 699.769739] ? f2fs_mark_inode_dirty_sync.part.18+0x16/0x30
[ 699.770885] ? iov_iter_advance+0x113/0x640
[ 699.771743] ? f2fs_write_end+0x133/0x2e0
[ 699.772569] ? balance_dirty_pages_ratelimited+0x239/0x640
[ 699.773680] f2fs_write_data_pages+0x329/0x520
[ 699.774603] ? generic_perform_write+0x250/0x320
[ 699.775544] ? f2fs_write_cache_pages+0x860/0x860
[ 699.776510] ? current_time+0x110/0x110
[ 699.777299] ? f2fs_preallocate_blocks+0x1ef/0x370
[ 699.778279] do_writepages+0x37/0xb0
[ 699.779026] ? f2fs_write_cache_pages+0x860/0x860
[ 699.779978] ? do_writepages+0x37/0xb0
[ 699.780755] __filemap_fdatawrite_range+0x19a/0x1f0
[ 699.781746] ? delete_from_page_cache_batch+0x4e0/0x4e0
[ 699.782820] ? __vfs_write+0x2b2/0x410
[ 699.783597] file_write_and_wait_range+0x66/0xb0
[ 699.784540] f2fs_do_sync_file+0x1f9/0xd90
[ 699.785381] ? truncate_partial_data_page+0x290/0x290
[ 699.786415] ? __sb_end_write+0x30/0x50
[ 699.787204] ? vfs_write+0x20f/0x260
[ 699.787941] f2fs_sync_file+0x9a/0xb0
[ 699.788694] ? f2fs_do_sync_file+0xd90/0xd90
[ 699.789572] vfs_fsync_range+0x68/0x100
[ 699.790360] ? __fget_light+0xc9/0xe0
[ 699.791128] do_fsync+0x3d/0x70
[ 699.791779] __x64_sys_fdatasync+0x24/0x30
[ 699.792614] do_syscall_64+0x78/0x170
[ 699.793371] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 699.794406] RIP: 0033:0x7f9bf930d800
[ 699.795134] Code: 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 83 3d 49 bf 2c 00 00 75 10 b8 4b 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8 be 78 01 00 48 89 04 24
[ 699.798960] RSP: 002b:00007ffee3606c68 EFLAGS: 00000246 ORIG_RAX: 000000000000004b
[ 699.800483] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f9bf930d800
[ 699.801923] RDX: 0000000000008000 RSI: 00000000006010a0 RDI: 0000000000000003
[ 699.803373] RBP: 00007ffee3606ca0 R08: 0000000001503010 R09: 0000000000000000
[ 699.804798] R10: 00000000000002e8 R11: 0000000000000246 R12: 0000000000400610
[ 699.806233] R13: 00007ffee3606da0 R14: 0000000000000000 R15: 0000000000000000
[ 699.807667] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hwdep snd_hda_core snd_pcm snd_timer snd mac_hid i2c_piix4 soundcore ib_iser rdma_cm iw_cm ib_cm ib_core iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear 8139too crct10dif_pclmul crc32_pclmul qxl drm_kms_helper syscopyarea aesni_intel sysfillrect sysimgblt fb_sys_fops ttm drm aes_x86_64 crypto_simd cryptd 8139cp glue_helper mii pata_acpi floppy
[ 699.817079] ---[ end trace 4ce02f25ff7d3df6 ]---
[ 699.818068] RIP: 0010:f2fs_submit_page_bio+0x29b/0x730
[ 699.819114] Code: 54 49 8d bd 18 04 00 00 e8 b2 59 af ff 41 8b 8d 18 04 00 00 8b 45 b8 41 d3 e6 44 01 f0 4c 8d 73 14 41 39 c7 0f 82 37 fe ff ff <0f> 0b 65 8b 05 2c 04 77 47 89 c0 48 0f a3 05 52 c1 d5 01 0f 92 c0
[ 699.822919] RSP: 0018:ffff8801f43af508 EFLAGS: 00010283
[ 699.823977] RAX: 0000000000000000 RBX: ffff8801f43af7b8 RCX: ffffffffb88a7cef
[ 699.825436] RDX: 0000000000000007 RSI: dffffc0000000000 RDI: ffff8801e3e7a64c
[ 699.826881] RBP: ffff8801f43af558 R08: ffffed003e066b55 R09: ffffed003e066b55
[ 699.828292] R10: 0000000000000001 R11: ffffed003e066b54 R12: ffffea0007876940
[ 699.829750] R13: ffff8801f0335500 R14: ffff8801e3e7a600 R15: 0000000000000001
[ 699.831192] FS: 00007f9bf97f5700(0000) GS:ffff8801f6e00000(0000) knlGS:0000000000000000
[ 699.832793] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 699.833981] CR2: 00007f9bf925d170 CR3: 00000001f0c34000 CR4: 00000000000006f0
[ 699.835556] ==================================================================
[ 699.837029] BUG: KASAN: stack-out-of-bounds in update_stack_state+0x38c/0x3e0
[ 699.838462] Read of size 8 at addr ffff8801f43af970 by task a.out/1309
[ 699.840086] CPU: 0 PID: 1309 Comm: a.out Tainted: G D W 4.18.0-rc1+ #4
[ 699.841603] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 699.843475] Call Trace:
[ 699.843982] dump_stack+0x7b/0xb5
[ 699.844661] print_address_description+0x70/0x290
[ 699.845607] kasan_report+0x291/0x390
[ 699.846351] ? update_stack_state+0x38c/0x3e0
[ 699.853831] __asan_load8+0x54/0x90
[ 699.854569] update_stack_state+0x38c/0x3e0
[ 699.855428] ? __read_once_size_nocheck.constprop.7+0x20/0x20
[ 699.856601] ? __save_stack_trace+0x5e/0x100
[ 699.857476] unwind_next_frame.part.5+0x18e/0x490
[ 699.858448] ? unwind_dump+0x290/0x290
[ 699.859217] ? clear_page_dirty_for_io+0x332/0x450
[ 699.860185] __unwind_start+0x106/0x190
[ 699.860974] __save_stack_trace+0x5e/0x100
[ 699.861808] ? __save_stack_trace+0x5e/0x100
[ 699.862691] ? unlink_anon_vmas+0xba/0x2c0
[ 699.863525] save_stack_trace+0x1f/0x30
[ 699.864312] save_stack+0x46/0xd0
[ 699.864993] ? __alloc_pages_slowpath+0x1420/0x1420
[ 699.865990] ? flush_tlb_mm_range+0x15e/0x220
[ 699.866889] ? kasan_check_write+0x14/0x20
[ 699.867724] ? __dec_node_state+0x92/0xb0
[ 699.868543] ? lock_page_memcg+0x85/0xf0
[ 699.869350] ? unlock_page_memcg+0x16/0x80
[ 699.870185] ? page_remove_rmap+0x198/0x520
[ 699.871048] ? mark_page_accessed+0x133/0x200
[ 699.871930] ? _cond_resched+0x1a/0x50
[ 699.872700] ? unmap_page_range+0xcd4/0xe50
[ 699.873551] ? rb_next+0x58/0x80
[ 699.874217] ? rb_next+0x58/0x80
[ 699.874895] __kasan_slab_free+0x13c/0x1a0
[ 699.875734] ? unlink_anon_vmas+0xba/0x2c0
[ 699.876563] kasan_slab_free+0xe/0x10
[ 699.877315] kmem_cache_free+0x89/0x1e0
[ 699.878095] unlink_anon_vmas+0xba/0x2c0
[ 699.878913] free_pgtables+0x101/0x1b0
[ 699.879677] exit_mmap+0x146/0x2a0
[ 699.880378] ? __ia32_sys_munmap+0x50/0x50
[ 699.881214] ? kasan_check_read+0x11/0x20
[ 699.882052] ? mm_update_next_owner+0x322/0x380
[ 699.882985] mmput+0x8b/0x1d0
[ 699.883602] do_exit+0x43a/0x1390
[ 699.884288] ? mm_update_next_owner+0x380/0x380
[ 699.885212] ? f2fs_sync_file+0x9a/0xb0
[ 699.885995] ? f2fs_do_sync_file+0xd90/0xd90
[ 699.886877] ? vfs_fsync_range+0x68/0x100
[ 699.887694] ? __fget_light+0xc9/0xe0
[ 699.888442] ? do_fsync+0x3d/0x70
[ 699.889118] ? __x64_sys_fdatasync+0x24/0x30
[ 699.889996] rewind_stack_do_exit+0x17/0x20
[ 699.890860] RIP: 0033:0x7f9bf930d800
[ 699.891585] Code: Bad RIP value.
[ 699.892268] RSP: 002b:00007ffee3606c68 EFLAGS: 00000246 ORIG_RAX: 000000000000004b
[ 699.893781] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f9bf930d800
[ 699.895220] RDX: 0000000000008000 RSI: 00000000006010a0 RDI: 0000000000000003
[ 699.896643] RBP: 00007ffee3606ca0 R08: 0000000001503010 R09: 0000000000000000
[ 699.898069] R10: 00000000000002e8 R11: 0000000000000246 R12: 0000000000400610
[ 699.899505] R13: 00007ffee3606da0 R14: 0000000000000000 R15: 0000000000000000
[ 699.901241] The buggy address belongs to the page:
[ 699.902215] page:ffffea0007d0ebc0 count:0 mapcount:0 mapping:0000000000000000 index:0x0
[ 699.903811] flags: 0x2ffff0000000000()
[ 699.904585] raw: 02ffff0000000000 0000000000000000 ffffffff07d00101 0000000000000000
[ 699.906125] raw: 0000000000000000 0000000000240000 00000000ffffffff 0000000000000000
[ 699.907673] page dumped because: kasan: bad access detected
[ 699.909108] Memory state around the buggy address:
[ 699.910077] ffff8801f43af800: 00 f1 f1 f1 f1 00 f4 f4 f4 f3 f3 f3 f3 00 00 00
[ 699.911528] ffff8801f43af880: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 699.912953] >ffff8801f43af900: 00 00 00 00 00 00 00 00 f1 01 f4 f4 f4 f2 f2 f2
[ 699.914392] ^
[ 699.915758] ffff8801f43af980: f2 00 f4 f4 00 00 00 00 f2 00 00 00 00 00 00 00
[ 699.917193] ffff8801f43afa00: 00 00 00 00 00 00 00 00 00 f3 f3 f3 00 00 00 00
[ 699.918634] ==================================================================
- Location
https://elixir.bootlin.com/linux/v4.18-rc1/source/fs/f2fs/segment.h#L644
- Error label is different in validate_checkpoint() due to the earlier
backport of "f2fs: fix invalid memory access"
- Adjust context]
commit e1da7872f6eda977bd812346bf588c35e4495a1e upstream.
This patch introduces verify_blkaddr to check meta/data block address
with valid range to detect bug earlier.
In addition, once we encounter an invalid blkaddr, notice user to run
fsck to fix, and let the kernel panic.
- I skipped an earlier renaming of is_valid_meta_blkaddr() to
f2fs_is_valid_meta_blkaddr()
- Adjust context]
commit 7b525dd01365c6764018e374d391c92466be1b7a upstream.
- rename is_valid_blkaddr() to is_valid_meta_blkaddr() for readability.
- introduce is_valid_blkaddr() for cleanup.
No logic change in this patch.
commit 0833721ec3658a4e9d5e58b6fa82cf9edc431e59 upstream.
This patch check blkaddr more accuratly before issue a
write or read bio.
Signed-off-by: Yunlei He <heyunlei@huawei.com>
Reviewed-by: Chao Yu <yuchao0@huawei.com>
commit b86e33075ed1909d8002745b56ecf73b833db143 upstream.
A dead loop can be triggered in f2fs_fiemap() using the test case
as below:
fd = open();
fallocate(fd, 0, 0, 4294967296);
ioctl(fd, FS_IOC_FIEMAP, fiemap_buf);
It's caused by an overflow in __get_data_block():
bh->b_size = map.m_len << inode->i_blkbits;
map.m_len is an unsigned int, and bh->b_size is a size_t which is 64 bits
on 64 bits archtecture, type conversion from an unsigned int to a size_t
will result in an overflow.
In the above-mentioned case, bh->b_size will be zero, and f2fs_fiemap()
will call get_data_block() at block 0 again an again.
Fix this by adding a force conversion before left shift.
Signed-off-by: Wei Fang <fangwei1@huawei.com>
Acked-by: Chao Yu <yuchao0@huawei.com>
[ Upstream commit 86d54795c94532075d862aa0a79f0c981dab4bdd ]
Otherwise we can get livelock like below.
[79880.428136] dbench D 0 18405 18404 0x00000000
[79880.428139] Call Trace:
[79880.428142] __schedule+0x219/0x6b0
[79880.428144] schedule+0x36/0x80
[79880.428147] schedule_timeout+0x243/0x2e0
[79880.428152] ? update_sd_lb_stats+0x16b/0x5f0
[79880.428155] ? ktime_get+0x3c/0xb0
[79880.428157] io_schedule_timeout+0xa6/0x110
[79880.428161] __lock_page+0xf7/0x130
[79880.428164] ? unlock_page+0x30/0x30
[79880.428167] pagecache_get_page+0x16b/0x250
[79880.428171] grab_cache_page_write_begin+0x20/0x40
[79880.428182] f2fs_write_begin+0xa2/0xdb0 [f2fs]
[79880.428192] ? f2fs_mark_inode_dirty_sync+0x16/0x30 [f2fs]
[79880.428197] ? kmem_cache_free+0x79/0x200
[79880.428203] ? __mark_inode_dirty+0x17f/0x360
[79880.428206] generic_perform_write+0xbb/0x190
[79880.428213] ? file_update_time+0xa4/0xf0
[79880.428217] __generic_file_write_iter+0x19b/0x1e0
[79880.428226] f2fs_file_write_iter+0x9c/0x180 [f2fs]
[79880.428231] __vfs_write+0xc5/0x140
[79880.428235] vfs_write+0xb2/0x1b0
[79880.428238] SyS_write+0x46/0xa0
[79880.428242] entry_SYSCALL_64_fastpath+0x1e/0xad
Fixes: cae96a5c8ab6 ("f2fs: check io submission more precisely")
commit 230436b3ef3fd7d4a1da19edf5e87bb2d74e0fc2 upstream.
gcc is unsure about the use of last_ofs_in_node, which might happen
without a prior initialization:
fs/f2fs//git/arm-soc/fs/f2fs/data.c: In function ‘f2fs_map_blocks’:
fs/f2fs/data.c:799:54: warning: ‘last_ofs_in_node’ may be used uninitialized in this function [-Wmaybe-uninitialized]
if (prealloc && dn.ofs_in_node != last_ofs_in_node + 1) {
As pointed out by Chao Yu, the code is actually correct as 'prealloc'
is only set if the last_ofs_in_node has been set, the two always
get updated together.
This initializes last_ofs_in_node to dn.ofs_in_node for each
new dnode at the start of the 'next_block' loop, which at that
point is a correct initialization as well. I assume that compilers
that correctly track the contents of the variables and do not
warn about the condition also figure out that they can eliminate
the extra assignment here.
Fixes: 46008c6d4232 ("f2fs: support in batch multi blocks preallocation")
The mapping_set_error() helper sets the correct AS_ flag for the mapping
so there is no reason to open code it. Use the helper directly.
[akpm@linux-foundation.org: be honest about conversion from -ENXIO to -EIO]
Link: http://lkml.kernel.org/r/20160912111608.2588-2-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
While we call ->writepages, there are two cases:
a. we didn't writeout any dirty pages, since they are writebacked by other
thread concurrently.
b. we writeout dirty pages, and have already submitted bio to block layer.
In these cases, we don't need to do additional bio flushing unnecessarily,
it may split bio in cache into smaller one.
Previously, we only support global fault injection configuration, so that
when we configure type/rate of fault injection through sysfs, mount
option, it will influence all f2fs partition which is being used.
It is not make sence, since it will be not convenient if developer want
to test separated partitions with different fault injection rate/type
simultaneously, also it's not possible to enable fault injection in one
partition and disable fault injection in other one.
>From now on, we move global configuration of fault injection in module
into per-superblock, hence injection testing can be more flexible.
This patch improves the migration of dirty pages and allows migrating atomic
written pages that F2FS uses in Page Cache. Instead of the fallback releasing
page path, it provides better performance for memory compaction, CMA and other
users of memory page migrating. For dirty pages, there is no need to write back
first when migrating. For an atomic written page before committing, we can
migrate the page and update the related 'inmem_pages' list at the same time.
[Jaegeuk Kim: fix some coding style]
This patch allow preallocates data blocks for buffered aio writes
in encrypted file.
[Jaegeuk Kim: fix to avoid BUG_ON]
This patch adds to support IO error injection for testing IO error
tolerance of f2fs.
Previously, f2fs_write_begin sets PageUptodate all the time. But, when user
tries to update the entire page (i.e., len == PAGE_SIZE), we need to consider
that the page is able to be copied partially afterwards. In such the case,
we will lose the remaing region in the page.
This patch fixes this by setting PageUptodate in f2fs_write_end as given copied
result. In the short copy case, it returns zero to let generic_perform_write
retry copying user data again.
As a result, f2fs_write_end() works:
PageUptodate len copied return retry
1. no 4096 4096 4096 false -> return 4096
2. no 4096 1024 0 true -> goto #1 case
3. yes 2048 2048 2048 false -> return 2048
4. yes 2048 1024 1024 false -> return 1024
Suggested-by: Al Viro <viro@zeniv.linux.org.uk>
Fix wrong condition check for defragmentation of a file.
We don't need to make zeros beyond i_size, since we already wrote that through
NEW_ADDR case.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
In write_begin(), we skip checking dnode block for preallocating block
when whole block needs to be updated since we preallocated its block in
f2fs_preallocate_blocks, for partial updated block, we will still try
to lock its node and do preallocation in write_begin(), so in
f2fs_preallocate_blocks we should not preallocate its block.
But previously, the calculation of preallocating block number is
incorrect, fix it.
[Jaegeuk Kim: fix a bug]
Fixes the following sparse warning:
fs/f2fs/data.c:969:12: warning:
symbol 'f2fs_grab_bio' was not declared. Should it be static?
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
If we preallocate blocks with f2fs_reserve_blocks in f2fs_map_blocks, we
should call f2fs_balance_fs for checking and reclaiming space, fix it.
This reverts commit a2ee0a300344a6da76186129b078113354fe13d2.
When testing with generic/032 of xfstest suit, failure message will be
reported as below:
generic/032 8s ... [failed, exit status 1] - output mismatch (see results/generic/032.out.bad)
--- tests/generic/032.out 2015-01-11 16:52:27.643681072 +0800
+++ results/generic/032.out.bad 2016-08-06 13:44:43.861330500 +0800
@@ -1,5 +1,5 @@
QA output created by 032
-100 iterations
-0000000 cdcd cdcd cdcd cdcd cdcd cdcd cdcd cdcd
-0100000
+1: [768..775]: unwritten
+Unwritten extents found!
(Run 'diff -u tests/generic/032.out results/generic/032.out.bad' to see the entire diff)
Ran: generic/032
Failures: generic/032
Failed 1 of 1 tests
In write_end(), we should update i_size of inode before unlock page,
otherwise, we will lose newly updated data in following race condition.
Thread A Thread B
- write_end
- unlock page
- writepages
- lock_page
- writepage
if page is out-of-range of file size,
we will skip writting the page.
- update i_size
Merge 4fc29c1aa375 included this extra line, but it's not needed (or
useful) since we'll bio_set_op_attrs() right after to properly set
the op and flags for the bio.
Signed-off-by: Jens Axboe <axboe@fb.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs
Pull f2fs updates from Jaegeuk Kim:
"The major change in this version is mitigating cpu overheads on write
paths by replacing redundant inode page updates with mark_inode_dirty
calls. And we tried to reduce lock contentions as well to improve
filesystem scalability. Other feature is setting F2FS automatically
when detecting host-managed SMR.
Enhancements:
- ioctl to move a range of data between files
- inject orphan inode errors
- avoid flush commands congestion
- support lazytime
Bug fixes:
- return proper results for some dentry operations
- fix deadlock in add_link failure
- disable extent_cache for fcollapse/finsert"
* tag 'for-f2fs-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (68 commits)
f2fs: clean up coding style and redundancy
f2fs: get victim segment again after new cp
f2fs: handle error case with f2fs_bug_on
f2fs: avoid data race when deciding checkpoin in f2fs_sync_file
f2fs: support an ioctl to move a range of data blocks
f2fs: fix to report error number of f2fs_find_entry
f2fs: avoid memory allocation failure due to a long length
f2fs: reset default idle interval value
f2fs: use blk_plug in all the possible paths
f2fs: fix to avoid data update racing between GC and DIO
f2fs: add maximum prefree segments
f2fs: disable extent_cache for fcollapse/finsert inodes
f2fs: fix ERR_PTR returned by bio
f2fs: avoid mark_inode_dirty
f2fs: move i_size_write in f2fs_write_end
f2fs: fix to avoid redundant discard during fstrim
f2fs: avoid mismatching block range for discard
f2fs: fix incorrect f_bfree calculation in ->statfs
f2fs: use percpu_rw_semaphore
Merge updates from Andrew Morton:
- a few misc bits
- ocfs2
- most(?) of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (125 commits)
thp: fix comments of __pmd_trans_huge_lock()
cgroup: remove unnecessary 0 check from css_from_id()
cgroup: fix idr leak for the first cgroup root
mm: memcontrol: fix documentation for compound parameter
mm: memcontrol: remove BUG_ON in uncharge_list
mm: fix build warnings in <linux/compaction.h>
mm, thp: convert from optimistic swapin collapsing to conservative
mm, thp: fix comment inconsistency for swapin readahead functions
thp: update Documentation/{vm/transhuge,filesystems/proc}.txt
shmem: split huge pages beyond i_size under memory pressure
thp: introduce CONFIG_TRANSPARENT_HUGE_PAGECACHE
khugepaged: add support of collapse for tmpfs/shmem pages
shmem: make shmem_inode_info::lock irq-safe
khugepaged: move up_read(mmap_sem) out of khugepaged_alloc_page()
thp: extract khugepaged from mm/huge_memory.c
shmem, thp: respect MADV_{NO,}HUGEPAGE for file mappings
shmem: add huge pages support
shmem: get_unmapped_area align huge page
shmem: prepare huge= mount option and sysfs knob
mm, rmap: account shmem thp pages
Vladimir has noticed that we might declare memcg oom even during
readahead because read_pages only uses GFP_KERNEL (with mapping_gfp
restriction) while __do_page_cache_readahead uses
page_cache_alloc_readahead which adds __GFP_NORETRY to prevent from
OOMs. This gfp mask discrepancy is really unfortunate and easily
fixable. Drop page_cache_alloc_readahead() which only has one user and
outsource the gfp_mask logic into readahead_gfp_mask and propagate this
mask from __do_page_cache_readahead down to read_pages.
This alone would have only very limited impact as most filesystems are
implementing ->readpages and the common implementation mpage_readpages
does GFP_KERNEL (with mapping_gfp restriction) again. We can tell it to
use readahead_gfp_mask instead as this function is called only during
readahead as well. The same applies to read_cache_pages.
ext4 has its own ext4_mpage_readpages but the path which has pages !=
NULL can use the same gfp mask. Btrfs, cifs, f2fs and orangefs are
doing a very similar pattern to mpage_readpages so the same can be
applied to them as well.
[mhocko@suse.com: restrict gfp mask in mpage_alloc]
Link: http://lkml.kernel.org/r/20160610074223.GC32285@dhcp22.suse.cz
Link: http://lkml.kernel.org/r/1465301556-26431-1-git-send-email-mhocko@kernel.org
Cc: Vladimir Davydov <vdavydov@parallels.com>
Cc: Chris Mason <clm@fb.com>
Cc: Steve French <sfrench@samba.org>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Jan Kara <jack@suse.cz>
Cc: Mike Marshall <hubcap@omnibond.com>
Cc: Jaegeuk Kim <jaegeuk@kernel.org>
Cc: Changman Lee <cm224.lee@samsung.com>
Cc: Chao Yu <yuchao0@huawei.com>
This patch includes minor clean-ups.
This patch reverts 19a5f5e2ef37 (f2fs: drop any block plugging),
and adds blk_plug in write paths additionally.
The main reason is that blk_start_plug can be used to wake up from low-power
mode before submitting further bios.
Datas in file can be operated by GC and DIO simultaneously, so we will
face race case as below:
For write case:
Thread A Thread B
- generic_file_direct_write
- invalidate_inode_pages2_range
- f2fs_direct_IO
- do_blockdev_direct_IO
- do_direct_IO
- get_more_blocks
- f2fs_gc
- do_garbage_collect
- gc_data_segment
- move_data_page
- do_write_data_page
migrate data block to new block address
- dio_bio_submit
update user data to old block address
For read case:
Thread A Thread B
- f2fs_direct_IO
- do_direct_IO
- get_more_blocks
- f2fs_balance_fs
- f2fs_gc
- gc_data_segment
- move_data_page
- write_checkpoint
- do_checkpoint
- clear_prefree_segments
- f2fs_issue_discard
discard old block adress
- dio_bio_submit
update user buffer from obsolete block address
In order to fix this, for one file, we should let DIO and GC getting exclusion
against with each other.
This is to fix wrong error pointer handling flow reported by Dan.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Chao Yu <chao@kernel.org>
We don't need to do i_size_write under page lock.
SetPageUptodate() issues memory barrier, resulting in performance degrdation.
Let's avoid that.
This patch adds f2fs_set_page_dirty_nobuffer() copied from __set_page_dirty_buffer.
When appending 4KB blocks in f2fs on pmem with multiple cores, this improves the
overall performance.
In procedure of synchonized read, after sending out the read request, reader
will try to lock the page for waiting device to finish the read jobs and
unlock the page, but meanwhile, truncater will race with reader, so after
reader get lock of the page, it should check page's mapping to detect
whether someone has truncated the page in advance, then reader has the
chance to do the retry if truncation was done, otherwise read can be failed
due to previous condition check.
For encrypted inode, if user overwrites data of the inode, f2fs will read
encrypted data into page cache, and then do the decryption.
However reader can race with overwriter, and it will see encrypted data
which has not been decrypted by overwriter yet. Fix it by moving decrypting
work to background and keep page non-uptodated until data is decrypted.
Thread A Thread B
- f2fs_file_write_iter
- __generic_file_write_iter
- generic_perform_write
- f2fs_write_begin
- f2fs_submit_page_bio
- generic_file_read_iter
- do_generic_file_read
- lock_page_killable
- unlock_page
- copy_page_to_iter
hit the encrypted data in updated page
- lock_page
- fscrypt_decrypt_page
The f2fs_map_blocks is very related to the performance, so let's avoid any
latency to read ahead node pages.
If mkfs.f2fs gives a feature flag for host-managed SMR, we can set mode=lfs
by default.
This mount option is to enable original log-structured filesystem forcefully.
So, there should be no random writes for main area.
Especially, this supports host-managed SMR device.
In f2fs, we don't need to keep block plugging for NODE and DATA writes, since
we already merged bios as much as possible.
If EIO occurred, we need to set all the mapping to avoid any further IOs.
Separate the op from the rq_flag_bits and have f2fs
set/get the bio using bio_set_op_attrs/bio_op.
Signed-off-by: Mike Christie <mchristi@redhat.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
This has callers of submit_bio/submit_bio_wait set the bio->bi_rw
instead of passing it in. This makes that use the same as
generic_make_request and how we set the other bio fields.
Fixed up fs/ext4/crypto.c
Previously, f2fs_write_data_pages() calls __f2fs_writepage() which calls
f2fs_write_data_page().
If f2fs_write_data_page() returns AOP_WRITEPAGE_ACTIVATE, __f2fs_writepage()
calls mapping_set_error(). But, this should not happen at every time, since
sometimes f2fs_write_data_page() tries to skip writing pages without error.
For example, volatile_write() gives EIO all the time, as Shuoran Liu pointed
out.
Reported-by: Shuoran Liu <liushuoran@huawei.com>
If there is no cold page, we don't need to do a loop to flush dirty
data pages.
On /dev/pmem0,
1. dd if=/dev/zero of=/mnt/test/testfile bs=1M count=2048 conv=fsync
Before : 1.1 GB/s
After : 1.2 GB/s
2. dd if=/dev/zero of=/mnt/test/testfile bs=1M count=2048
Before : 2.2 GB/s
After : 2.3 GB/s
For data pages, let's try to flush as much as possible in background.
On /dev/pmem0,
Before : 800 MB/s
After : 1.1 GB/s
Before : 1.3 GB/s
After : 2.2 GB/s
This patch removes writepages lock.
We can improve multi-threading performance.
tiobench, 32 threads, 4KB write per fsync on SSD
Before: 25.88 MB/s
After: 28.03 MB/s
If roll-forward recovery can recover i_size, we don't need to update inode's
metadata during fsync.
This patch reduces to call them across the whole tree.
- sync_inode_page()
- update_inode_page()
- update_inode()
- f2fs_write_inode()
Instead, checkpoint will flush all the dirty inode metadata before syncing
node pages.
Note that, this is doable, since we call mark_inode_dirty_sync() for all
inode's field change which needs to update on-disk inode as well.
This patch introduces f2fs_i_blocks_write() to call mark_inode_dirty_sync() when
changing inode->i_blocks.
