commit 2562515f0ad7342bde6456602c491b64c63fe950 upstream.
__setattr_copy() was copied from setattr_copy() in fs/attr.c, there is
two missing patches doesn't cover this inner function, fix it.
Commit 7fa294c8991c ("userns: Allow chown and setgid preservation")
Commit 23adbe12ef7d ("fs,userns: Change inode_capable to capable_wrt_inode_uidgid")
Fixes: fbfa2cc58d53 ("f2fs: add file operations")
Cc: stable@vger.kernel.org
Signed-off-by: Chao Yu <yuchao0@huawei.com>
Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
[ Upstream commit b61ac5b720146c619c7cdf17eff2551b934399e5 ]
This patch move dir data flush to write checkpoint process, by
doing this, it may reduce some time for dir fsync.
pre:
-f2fs_do_sync_file enter
-file_write_and_wait_range <- flush & wait
-write_checkpoint
-do_checkpoint <- wait all
-f2fs_do_sync_file exit
now:
-write_checkpoint
-block_operations <- flush dir & no wait
Signed-off-by: Yunlei He <heyunlei@huawei.com>
commit c9b60788fc760d136211853f10ce73dc152d1f4a upstream.
This patch add to do sanity check with below field:
- cp_pack_total_block_count
- blkaddr of data/node
- extent info
- Overview
BUG() in verify_block_addr() when writing to a corrupted f2fs image
- Reproduce (4.18 upstream kernel)
- POC (poc.c)
static void activity(char *mpoint) {
char *foo_bar_baz;
int err;
static int buf[8192];
memset(buf, 0, sizeof(buf));
err = asprintf(&foo_bar_baz, "%s/foo/bar/baz", mpoint);
int fd = open(foo_bar_baz, O_RDWR | O_TRUNC, 0777);
if (fd >= 0) {
write(fd, (char *)buf, sizeof(buf));
fdatasync(fd);
close(fd);
int main(int argc, char *argv[]) {
activity(argv[1]);
return 0;
- Kernel message
[ 689.349473] F2FS-fs (loop0): Mounted with checkpoint version = 3
[ 699.728662] WARNING: CPU: 0 PID: 1309 at fs/f2fs/segment.c:2860 f2fs_inplace_write_data+0x232/0x240
[ 699.728670] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hwdep snd_hda_core snd_pcm snd_timer snd mac_hid i2c_piix4 soundcore ib_iser rdma_cm iw_cm ib_cm ib_core iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear 8139too crct10dif_pclmul crc32_pclmul qxl drm_kms_helper syscopyarea aesni_intel sysfillrect sysimgblt fb_sys_fops ttm drm aes_x86_64 crypto_simd cryptd 8139cp glue_helper mii pata_acpi floppy
[ 699.729056] CPU: 0 PID: 1309 Comm: a.out Not tainted 4.18.0-rc1+ #4
[ 699.729064] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 699.729074] RIP: 0010:f2fs_inplace_write_data+0x232/0x240
[ 699.729076] Code: ff e9 cf fe ff ff 49 8d 7d 10 e8 39 45 ad ff 4d 8b 7d 10 be 04 00 00 00 49 8d 7f 48 e8 07 49 ad ff 45 8b 7f 48 e9 fb fe ff ff <0f> 0b f0 41 80 4d 48 04 e9 65 fe ff ff 90 66 66 66 66 90 55 48 8d
[ 699.729130] RSP: 0018:ffff8801f43af568 EFLAGS: 00010202
[ 699.729139] RAX: 000000000000003f RBX: ffff8801f43af7b8 RCX: ffffffffb88c9113
[ 699.729142] RDX: 0000000000000003 RSI: dffffc0000000000 RDI: ffff8802024e5540
[ 699.729144] RBP: ffff8801f43af590 R08: 0000000000000009 R09: ffffffffffffffe8
[ 699.729147] R10: 0000000000000001 R11: ffffed0039b0596a R12: ffff8802024e5540
[ 699.729149] R13: ffff8801f0335500 R14: ffff8801e3e7a700 R15: ffff8801e1ee4450
[ 699.729154] FS: 00007f9bf97f5700(0000) GS:ffff8801f6e00000(0000) knlGS:0000000000000000
[ 699.729156] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 699.729159] CR2: 00007f9bf925d170 CR3: 00000001f0c34000 CR4: 00000000000006f0
[ 699.729171] Call Trace:
[ 699.729192] f2fs_do_write_data_page+0x2e2/0xe00
[ 699.729203] ? f2fs_should_update_outplace+0xd0/0xd0
[ 699.729238] ? memcg_drain_all_list_lrus+0x280/0x280
[ 699.729269] ? __radix_tree_replace+0xa3/0x120
[ 699.729276] __write_data_page+0x5c7/0xe30
[ 699.729291] ? kasan_check_read+0x11/0x20
[ 699.729310] ? page_mapped+0x8a/0x110
[ 699.729321] ? page_mkclean+0xe9/0x160
[ 699.729327] ? f2fs_do_write_data_page+0xe00/0xe00
[ 699.729331] ? invalid_page_referenced_vma+0x130/0x130
[ 699.729345] ? clear_page_dirty_for_io+0x332/0x450
[ 699.729351] f2fs_write_cache_pages+0x4ca/0x860
[ 699.729358] ? __write_data_page+0xe30/0xe30
[ 699.729374] ? percpu_counter_add_batch+0x22/0xa0
[ 699.729380] ? kasan_check_write+0x14/0x20
[ 699.729391] ? _raw_spin_lock+0x17/0x40
[ 699.729403] ? f2fs_mark_inode_dirty_sync.part.18+0x16/0x30
[ 699.729413] ? iov_iter_advance+0x113/0x640
[ 699.729418] ? f2fs_write_end+0x133/0x2e0
[ 699.729423] ? balance_dirty_pages_ratelimited+0x239/0x640
[ 699.729428] f2fs_write_data_pages+0x329/0x520
[ 699.729433] ? generic_perform_write+0x250/0x320
[ 699.729438] ? f2fs_write_cache_pages+0x860/0x860
[ 699.729454] ? current_time+0x110/0x110
[ 699.729459] ? f2fs_preallocate_blocks+0x1ef/0x370
[ 699.729464] do_writepages+0x37/0xb0
[ 699.729468] ? f2fs_write_cache_pages+0x860/0x860
[ 699.729472] ? do_writepages+0x37/0xb0
[ 699.729478] __filemap_fdatawrite_range+0x19a/0x1f0
[ 699.729483] ? delete_from_page_cache_batch+0x4e0/0x4e0
[ 699.729496] ? __vfs_write+0x2b2/0x410
[ 699.729501] file_write_and_wait_range+0x66/0xb0
[ 699.729506] f2fs_do_sync_file+0x1f9/0xd90
[ 699.729511] ? truncate_partial_data_page+0x290/0x290
[ 699.729521] ? __sb_end_write+0x30/0x50
[ 699.729526] ? vfs_write+0x20f/0x260
[ 699.729530] f2fs_sync_file+0x9a/0xb0
[ 699.729534] ? f2fs_do_sync_file+0xd90/0xd90
[ 699.729548] vfs_fsync_range+0x68/0x100
[ 699.729554] ? __fget_light+0xc9/0xe0
[ 699.729558] do_fsync+0x3d/0x70
[ 699.729562] __x64_sys_fdatasync+0x24/0x30
[ 699.729585] do_syscall_64+0x78/0x170
[ 699.729595] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 699.729613] RIP: 0033:0x7f9bf930d800
[ 699.729615] Code: 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 83 3d 49 bf 2c 00 00 75 10 b8 4b 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8 be 78 01 00 48 89 04 24
[ 699.729668] RSP: 002b:00007ffee3606c68 EFLAGS: 00000246 ORIG_RAX: 000000000000004b
[ 699.729673] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f9bf930d800
[ 699.729675] RDX: 0000000000008000 RSI: 00000000006010a0 RDI: 0000000000000003
[ 699.729678] RBP: 00007ffee3606ca0 R08: 0000000001503010 R09: 0000000000000000
[ 699.729680] R10: 00000000000002e8 R11: 0000000000000246 R12: 0000000000400610
[ 699.729683] R13: 00007ffee3606da0 R14: 0000000000000000 R15: 0000000000000000
[ 699.729687] ---[ end trace 4ce02f25ff7d3df5 ]---
[ 699.729782] ------------[ cut here ]------------
[ 699.729785] kernel BUG at fs/f2fs/segment.h:654!
[ 699.731055] invalid opcode: 0000 [#1] SMP KASAN PTI
[ 699.732104] CPU: 0 PID: 1309 Comm: a.out Tainted: G W 4.18.0-rc1+ #4
[ 699.733684] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 699.735611] RIP: 0010:f2fs_submit_page_bio+0x29b/0x730
[ 699.736649] Code: 54 49 8d bd 18 04 00 00 e8 b2 59 af ff 41 8b 8d 18 04 00 00 8b 45 b8 41 d3 e6 44 01 f0 4c 8d 73 14 41 39 c7 0f 82 37 fe ff ff <0f> 0b 65 8b 05 2c 04 77 47 89 c0 48 0f a3 05 52 c1 d5 01 0f 92 c0
[ 699.740524] RSP: 0018:ffff8801f43af508 EFLAGS: 00010283
[ 699.741573] RAX: 0000000000000000 RBX: ffff8801f43af7b8 RCX: ffffffffb88a7cef
[ 699.743006] RDX: 0000000000000007 RSI: dffffc0000000000 RDI: ffff8801e3e7a64c
[ 699.744426] RBP: ffff8801f43af558 R08: ffffed003e066b55 R09: ffffed003e066b55
[ 699.745833] R10: 0000000000000001 R11: ffffed003e066b54 R12: ffffea0007876940
[ 699.747256] R13: ffff8801f0335500 R14: ffff8801e3e7a600 R15: 0000000000000001
[ 699.748683] FS: 00007f9bf97f5700(0000) GS:ffff8801f6e00000(0000) knlGS:0000000000000000
[ 699.750293] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 699.751462] CR2: 00007f9bf925d170 CR3: 00000001f0c34000 CR4: 00000000000006f0
[ 699.752874] Call Trace:
[ 699.753386] ? f2fs_inplace_write_data+0x93/0x240
[ 699.754341] f2fs_inplace_write_data+0xd2/0x240
[ 699.755271] f2fs_do_write_data_page+0x2e2/0xe00
[ 699.756214] ? f2fs_should_update_outplace+0xd0/0xd0
[ 699.757215] ? memcg_drain_all_list_lrus+0x280/0x280
[ 699.758209] ? __radix_tree_replace+0xa3/0x120
[ 699.759164] __write_data_page+0x5c7/0xe30
[ 699.760002] ? kasan_check_read+0x11/0x20
[ 699.760823] ? page_mapped+0x8a/0x110
[ 699.761573] ? page_mkclean+0xe9/0x160
[ 699.762345] ? f2fs_do_write_data_page+0xe00/0xe00
[ 699.763332] ? invalid_page_referenced_vma+0x130/0x130
[ 699.764374] ? clear_page_dirty_for_io+0x332/0x450
[ 699.765347] f2fs_write_cache_pages+0x4ca/0x860
[ 699.766276] ? __write_data_page+0xe30/0xe30
[ 699.767161] ? percpu_counter_add_batch+0x22/0xa0
[ 699.768112] ? kasan_check_write+0x14/0x20
[ 699.768951] ? _raw_spin_lock+0x17/0x40
[ 699.769739] ? f2fs_mark_inode_dirty_sync.part.18+0x16/0x30
[ 699.770885] ? iov_iter_advance+0x113/0x640
[ 699.771743] ? f2fs_write_end+0x133/0x2e0
[ 699.772569] ? balance_dirty_pages_ratelimited+0x239/0x640
[ 699.773680] f2fs_write_data_pages+0x329/0x520
[ 699.774603] ? generic_perform_write+0x250/0x320
[ 699.775544] ? f2fs_write_cache_pages+0x860/0x860
[ 699.776510] ? current_time+0x110/0x110
[ 699.777299] ? f2fs_preallocate_blocks+0x1ef/0x370
[ 699.778279] do_writepages+0x37/0xb0
[ 699.779026] ? f2fs_write_cache_pages+0x860/0x860
[ 699.779978] ? do_writepages+0x37/0xb0
[ 699.780755] __filemap_fdatawrite_range+0x19a/0x1f0
[ 699.781746] ? delete_from_page_cache_batch+0x4e0/0x4e0
[ 699.782820] ? __vfs_write+0x2b2/0x410
[ 699.783597] file_write_and_wait_range+0x66/0xb0
[ 699.784540] f2fs_do_sync_file+0x1f9/0xd90
[ 699.785381] ? truncate_partial_data_page+0x290/0x290
[ 699.786415] ? __sb_end_write+0x30/0x50
[ 699.787204] ? vfs_write+0x20f/0x260
[ 699.787941] f2fs_sync_file+0x9a/0xb0
[ 699.788694] ? f2fs_do_sync_file+0xd90/0xd90
[ 699.789572] vfs_fsync_range+0x68/0x100
[ 699.790360] ? __fget_light+0xc9/0xe0
[ 699.791128] do_fsync+0x3d/0x70
[ 699.791779] __x64_sys_fdatasync+0x24/0x30
[ 699.792614] do_syscall_64+0x78/0x170
[ 699.793371] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 699.794406] RIP: 0033:0x7f9bf930d800
[ 699.795134] Code: 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 83 3d 49 bf 2c 00 00 75 10 b8 4b 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 31 c3 48 83 ec 08 e8 be 78 01 00 48 89 04 24
[ 699.798960] RSP: 002b:00007ffee3606c68 EFLAGS: 00000246 ORIG_RAX: 000000000000004b
[ 699.800483] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f9bf930d800
[ 699.801923] RDX: 0000000000008000 RSI: 00000000006010a0 RDI: 0000000000000003
[ 699.803373] RBP: 00007ffee3606ca0 R08: 0000000001503010 R09: 0000000000000000
[ 699.804798] R10: 00000000000002e8 R11: 0000000000000246 R12: 0000000000400610
[ 699.806233] R13: 00007ffee3606da0 R14: 0000000000000000 R15: 0000000000000000
[ 699.807667] Modules linked in: snd_hda_codec_generic snd_hda_intel snd_hda_codec snd_hwdep snd_hda_core snd_pcm snd_timer snd mac_hid i2c_piix4 soundcore ib_iser rdma_cm iw_cm ib_cm ib_core iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx raid1 raid0 multipath linear 8139too crct10dif_pclmul crc32_pclmul qxl drm_kms_helper syscopyarea aesni_intel sysfillrect sysimgblt fb_sys_fops ttm drm aes_x86_64 crypto_simd cryptd 8139cp glue_helper mii pata_acpi floppy
[ 699.817079] ---[ end trace 4ce02f25ff7d3df6 ]---
[ 699.818068] RIP: 0010:f2fs_submit_page_bio+0x29b/0x730
[ 699.819114] Code: 54 49 8d bd 18 04 00 00 e8 b2 59 af ff 41 8b 8d 18 04 00 00 8b 45 b8 41 d3 e6 44 01 f0 4c 8d 73 14 41 39 c7 0f 82 37 fe ff ff <0f> 0b 65 8b 05 2c 04 77 47 89 c0 48 0f a3 05 52 c1 d5 01 0f 92 c0
[ 699.822919] RSP: 0018:ffff8801f43af508 EFLAGS: 00010283
[ 699.823977] RAX: 0000000000000000 RBX: ffff8801f43af7b8 RCX: ffffffffb88a7cef
[ 699.825436] RDX: 0000000000000007 RSI: dffffc0000000000 RDI: ffff8801e3e7a64c
[ 699.826881] RBP: ffff8801f43af558 R08: ffffed003e066b55 R09: ffffed003e066b55
[ 699.828292] R10: 0000000000000001 R11: ffffed003e066b54 R12: ffffea0007876940
[ 699.829750] R13: ffff8801f0335500 R14: ffff8801e3e7a600 R15: 0000000000000001
[ 699.831192] FS: 00007f9bf97f5700(0000) GS:ffff8801f6e00000(0000) knlGS:0000000000000000
[ 699.832793] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 699.833981] CR2: 00007f9bf925d170 CR3: 00000001f0c34000 CR4: 00000000000006f0
[ 699.835556] ==================================================================
[ 699.837029] BUG: KASAN: stack-out-of-bounds in update_stack_state+0x38c/0x3e0
[ 699.838462] Read of size 8 at addr ffff8801f43af970 by task a.out/1309
[ 699.840086] CPU: 0 PID: 1309 Comm: a.out Tainted: G D W 4.18.0-rc1+ #4
[ 699.841603] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 699.843475] Call Trace:
[ 699.843982] dump_stack+0x7b/0xb5
[ 699.844661] print_address_description+0x70/0x290
[ 699.845607] kasan_report+0x291/0x390
[ 699.846351] ? update_stack_state+0x38c/0x3e0
[ 699.853831] __asan_load8+0x54/0x90
[ 699.854569] update_stack_state+0x38c/0x3e0
[ 699.855428] ? __read_once_size_nocheck.constprop.7+0x20/0x20
[ 699.856601] ? __save_stack_trace+0x5e/0x100
[ 699.857476] unwind_next_frame.part.5+0x18e/0x490
[ 699.858448] ? unwind_dump+0x290/0x290
[ 699.859217] ? clear_page_dirty_for_io+0x332/0x450
[ 699.860185] __unwind_start+0x106/0x190
[ 699.860974] __save_stack_trace+0x5e/0x100
[ 699.861808] ? __save_stack_trace+0x5e/0x100
[ 699.862691] ? unlink_anon_vmas+0xba/0x2c0
[ 699.863525] save_stack_trace+0x1f/0x30
[ 699.864312] save_stack+0x46/0xd0
[ 699.864993] ? __alloc_pages_slowpath+0x1420/0x1420
[ 699.865990] ? flush_tlb_mm_range+0x15e/0x220
[ 699.866889] ? kasan_check_write+0x14/0x20
[ 699.867724] ? __dec_node_state+0x92/0xb0
[ 699.868543] ? lock_page_memcg+0x85/0xf0
[ 699.869350] ? unlock_page_memcg+0x16/0x80
[ 699.870185] ? page_remove_rmap+0x198/0x520
[ 699.871048] ? mark_page_accessed+0x133/0x200
[ 699.871930] ? _cond_resched+0x1a/0x50
[ 699.872700] ? unmap_page_range+0xcd4/0xe50
[ 699.873551] ? rb_next+0x58/0x80
[ 699.874217] ? rb_next+0x58/0x80
[ 699.874895] __kasan_slab_free+0x13c/0x1a0
[ 699.875734] ? unlink_anon_vmas+0xba/0x2c0
[ 699.876563] kasan_slab_free+0xe/0x10
[ 699.877315] kmem_cache_free+0x89/0x1e0
[ 699.878095] unlink_anon_vmas+0xba/0x2c0
[ 699.878913] free_pgtables+0x101/0x1b0
[ 699.879677] exit_mmap+0x146/0x2a0
[ 699.880378] ? __ia32_sys_munmap+0x50/0x50
[ 699.881214] ? kasan_check_read+0x11/0x20
[ 699.882052] ? mm_update_next_owner+0x322/0x380
[ 699.882985] mmput+0x8b/0x1d0
[ 699.883602] do_exit+0x43a/0x1390
[ 699.884288] ? mm_update_next_owner+0x380/0x380
[ 699.885212] ? f2fs_sync_file+0x9a/0xb0
[ 699.885995] ? f2fs_do_sync_file+0xd90/0xd90
[ 699.886877] ? vfs_fsync_range+0x68/0x100
[ 699.887694] ? __fget_light+0xc9/0xe0
[ 699.888442] ? do_fsync+0x3d/0x70
[ 699.889118] ? __x64_sys_fdatasync+0x24/0x30
[ 699.889996] rewind_stack_do_exit+0x17/0x20
[ 699.890860] RIP: 0033:0x7f9bf930d800
[ 699.891585] Code: Bad RIP value.
[ 699.892268] RSP: 002b:00007ffee3606c68 EFLAGS: 00000246 ORIG_RAX: 000000000000004b
[ 699.893781] RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00007f9bf930d800
[ 699.895220] RDX: 0000000000008000 RSI: 00000000006010a0 RDI: 0000000000000003
[ 699.896643] RBP: 00007ffee3606ca0 R08: 0000000001503010 R09: 0000000000000000
[ 699.898069] R10: 00000000000002e8 R11: 0000000000000246 R12: 0000000000400610
[ 699.899505] R13: 00007ffee3606da0 R14: 0000000000000000 R15: 0000000000000000
[ 699.901241] The buggy address belongs to the page:
[ 699.902215] page:ffffea0007d0ebc0 count:0 mapcount:0 mapping:0000000000000000 index:0x0
[ 699.903811] flags: 0x2ffff0000000000()
[ 699.904585] raw: 02ffff0000000000 0000000000000000 ffffffff07d00101 0000000000000000
[ 699.906125] raw: 0000000000000000 0000000000240000 00000000ffffffff 0000000000000000
[ 699.907673] page dumped because: kasan: bad access detected
[ 699.909108] Memory state around the buggy address:
[ 699.910077] ffff8801f43af800: 00 f1 f1 f1 f1 00 f4 f4 f4 f3 f3 f3 f3 00 00 00
[ 699.911528] ffff8801f43af880: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 699.912953] >ffff8801f43af900: 00 00 00 00 00 00 00 00 f1 01 f4 f4 f4 f2 f2 f2
[ 699.914392] ^
[ 699.915758] ffff8801f43af980: f2 00 f4 f4 00 00 00 00 f2 00 00 00 00 00 00 00
[ 699.917193] ffff8801f43afa00: 00 00 00 00 00 00 00 00 00 f3 f3 f3 00 00 00 00
[ 699.918634] ==================================================================
- Location
https://elixir.bootlin.com/linux/v4.18-rc1/source/fs/f2fs/segment.h#L644
Reported-by Wen Xu <wen.xu@gatech.edu>
[bwh: Backported to 4.4:
- CoW is not implemented so check f2fs_io_info::blk_addr instead of
f2fs_io_info::{old,new}_blkaddr
- Operation code is f2fs_io_info::rw instead of f2fs_io_info::op
- f2fs_stop_checkpoint() only takes one argument
- In f2fs_map_blocks(), validate dn.data_blkaddr instead of blkaddr
- Adjust context]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit e1da7872f6eda977bd812346bf588c35e4495a1e upstream.
This patch introduces verify_blkaddr to check meta/data block address
with valid range to detect bug earlier.
In addition, once we encounter an invalid blkaddr, notice user to run
fsck to fix, and let the kernel panic.
- I skipped an earlier renaming of is_valid_meta_blkaddr() to
f2fs_is_valid_meta_blkaddr()
- Drop inapplicable change to check on f2fs_fio_info::old_blkaddr
- Adjust context]
commit 7b525dd01365c6764018e374d391c92466be1b7a upstream.
- rename is_valid_blkaddr() to is_valid_meta_blkaddr() for readability.
- introduce is_valid_blkaddr() for cleanup.
No logic change in this patch.
- Adjust context]
commit ba63f23d69a3a10e7e527a02702023da68ef8a6d upstream.
[Please apply to 4.4-stable. Note: this was already backported, but
only to ext4; it was missed that it should go to f2fs as well. This is
needed to make xfstest generic/395 pass on f2fs.]
Since setting an encryption policy requires writing metadata to the
filesystem, it should be guarded by mnt_want_write/mnt_drop_write.
Otherwise, a user could cause a write to a frozen or readonly
filesystem. This was handled correctly by f2fs but not by ext4. Make
fscrypt_process_policy() handle it rather than relying on the filesystem
to get it right.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Acked-by: Jaegeuk Kim <jaegeuk@kernel.org>
commit 8906a8223ad4909b391c5628f7991ebceda30e52 upstream.
i_rwsem needs to be acquired while setting an encryption policy so that
concurrent calls to FS_IOC_SET_ENCRYPTION_POLICY are correctly
serialized (especially the ->get_context() + ->set_context() pair), and
so that new files cannot be created in the directory during or after the
->empty_dir() check.
Reviewed-by: Richard Weinberger <richard@nod.at>
If we got failure during commit_atomic_write, abort_volatile_write will be
called, but will not drop the inmemory pages due to no FI_ATOMIC_FILE.
Actually, there is no reason to check the flag in abort_volatile_write.
different competitors
Since we use different page cache (normally inode's page cache for R/W
and meta inode's page cache for GC) to cache the same physical block
which is belong to an encrypted inode. Writeback of these two page
cache should be exclusive, but now we didn't handle writeback state
well, so there may be potential racing problem:
a)
kworker: f2fs_gc:
- f2fs_write_data_pages
- do_write_data_page
- write_data_page
- f2fs_submit_page_mbio
(page#1 in inode's page cache was queued
in f2fs bio cache, and be ready to write
to new blkaddr)
- gc_data_segment
- move_encrypted_block
- pagecache_get_page
(page#2 in meta inode's page cache
was cached with the invalid datas
of physical block located in new
blkaddr)
(page#1 was submitted, later, page#2
with invalid data will be submitted)
b)
f2fs_gc:
- gc_data_segment
(page#1 in meta inode's page cache was
queued in f2fs bio cache, and be ready
to write to new blkaddr)
user thread:
- f2fs_write_begin
- f2fs_submit_page_bio
(we submit the request to block layer
to update page#2 in inode's page cache
with physical block located in new
blkaddr, so here we may read gabbage
data from new blkaddr since GC hasn't
writebacked the page#1 yet)
This patch fixes above potential racing problem for encrypted inode.
Signed-off-by: Chao Yu <chao2.yu@samsung.com>
For normal inodes, their pages are allocated with __GFP_FS, which can cause
filesystem calls when reclaiming memory.
This can incur a dead lock condition accordingly.
So, this patch addresses this problem by introducing
f2fs_grab_cache_page(.., bool for_write), which calls
grab_cache_page_write_begin() with AOP_FLAG_NOFS.
The f2fs_collapse_range and f2fs_insert_range changes the block addresses
directly. But that can cause uncovered SSA updates.
In that case, we need to give up to change the block addresses and do buffered
writes to keep filesystem consistency.
This patch introduces F2FS_GOING_DOWN_METAFLUSH which flushes meta pages like
SSA blocks and then blocks all the writes.
This can be used by power-failure tests.
Reviewed-by: Chao Yu <chao2.yu@samsung.com>
This patch introduce a new ioctl for those users who want to trigger
checkpoint from userspace through ioctl.
This patch drops in batches gc triggered through ioctl, since user
can easily control the gc by designing the loop around the ->ioctl.
We support synchronous gc by forcing using FG_GC in f2fs_gc, so with
it, user can make sure that in this round all blocks gced were
persistent in the device until ioctl returned.
This patch fixes to update ctime and atime correctly when truncating
larger in ->setattr.
The bug is reported by xfstest generic/313 as below:
generic/313 2s ... - output mismatch (see ./results/generic/313.out.bad)
--- tests/generic/313.out 2015-08-04 15:28:53.430798882 +0800
+++ results/generic/313.out.bad 2015-09-28 17:04:27.294278016 +0800
@@ -1,2 +1,4 @@
QA output created by 313
Silence is golden
+ctime not updated after truncate up
+mtime not updated after truncate up
(Run 'diff -u tests/generic/313.out tests/generic/313.out.bad' to see the entire diff)
Ran: generic/313
Failures: generic/313
Failed 1 of 1 tests
truncate_data_blocks_range can do in batches truncation which makes all
changes in dnode page content, dnode page status, extent cache, block
count updating together.
But previously, truncate_hole() always truncates one block in dnode page
at a time by invoking truncate_data_blocks_range(,1), which make thing
slow.
This patch changes truncate_hole() to do in batches truncation for all
target blocks in one direct node inside truncate_data_blocks_range, which
can make our punch hole operation in ->fallocate more efficent.
We have potential overflow issue when calculating size of object, when
we left shift index with PAGE_CACHE_SHIFT bits, if type of index has only
32-bits space in 32-bit architecture, left shifting will incur overflow,
i.e:
pgoff_t index = 0xFFFFFFFF;
loff_t size = index << PAGE_CACHE_SHIFT;
So we should cast index with 64-bits type to avoid this issue.
This patch changes to verify file type early in f2fs_fallocate for
cleanup, meanwhile this also fixes to add missing verification for
expand_inode_data.
f2fs_ioc_release_volatile_write
This fixes the incorrect return statement at the end of the function
f2fs_ioc_release_volatile_write's body for returning zero as this is
incorrect due to the function call before this return statement to
the function punch_hole being able to fail and we should return this
function's return fail directly in order to signal to callers of the
function f2fs_ioc_release_volatile if a failure arises with this call
to punch_hole fails.
Signed-off-by: Nicholas Krause <xerofoify@gmail.com>
This patch introduce a new helper f2fs_update_extent_tree_range which can
do extent mapping update at a specified range.
The main idea is:
1) punch all mapping info in extent node(s) which are at a specified range;
2) try to merge new extent mapping with adjacent node, or failing that,
insert the mapping into extent tree as a new node.
In order to see the benefit, I add a function for stating time stamping
count as below:
uint64_t rdtsc(void)
uint32_t lo, hi;
__asm__ __volatile__ ("rdtsc" : "=a" (lo), "=d" (hi));
return (uint64_t)hi << 32 | lo;
My test environment is: ubuntu, intel i7-3770, 16G memory, 256g micron ssd.
truncation path: update extent cache from truncate_data_blocks_range
non-truncataion path: update extent cache from other paths
total: all update paths
a) Removing 128MB file which has one extent node mapping whole range of
file:
1. dd if=/dev/zero of=/mnt/f2fs/128M bs=1M count=128
2. sync
3. rm /mnt/f2fs/128M
Before:
total count average
truncation: 7651022 32768 233.49
Patched:
total count average
truncation: 3321 33 100.64
b) fsstress:
fsstress -d /mnt/f2fs -l 5 -n 100 -p 20
Test times: 5 times.
Before:
total count average
truncation: 5812480.6 20911.6 277.95
non-truncation: 7783845.6 13440.8 579.12
total: 13596326.2 34352.4 395.79
Patched:
total count average
truncation: 1281283.0 3041.6 421.25
non-truncation: 7355844.4 13662.8 538.38
total: 8637127.4 16704.4 517.06
1) For the updates in truncation path:
- we can see updating in batches leads total tsc and update count reducing
explicitly;
- besides, for a single batched updating, punching multiple extent nodes
in a loop, result in executing more operations, so our average tsc
increase intensively.
2) For the updates in non-truncation path:
- there is a little improvement, that is because for the scenario that we
just need to update in the head or tail of extent node, new interface
optimize to update info in extent node directly, rather than removing
original extent node for updating and then inserting that updated one
into cache as new node.
This patch fixes to return error number of f2fs_truncate, so that we
can handle the error correctly in callers.
Previously, update_inode_page is not called under f2fs_lock_op.
Instead we should call with f2fs_write_inode.
fill_zero can fail due to a lot of reason, but previously we do not handle
its return value, so its callers such as punch_hole/f2fs_zero_range may
report success, but actually can fail because of error occurs inside
fill_zero.
This patch fixes to report correct return value of fill_zero.
This patch adds to handle error cases in commit_inmem_pages.
If an error occurs, it stops to write the pages and return the error right
away.
In f2fs_ioc_start_{atomic,volatile}_write, if we failed in converting
inline data, we will report error to user, but still remain atomic/volatile
flag in inode, it will impact further writes for this file. Fix it.
This patch fixes the incorrect range (0, LONG_MAX) which is used
in ranged fsync. If we use LONG_MAX as the parameter for indicating
the end of file we want to synchronize, in 32-bits architecture
machine, these datas after 4GB offset may not be persisted in
storage after ->fsync returned.
Here, we alter LONG_MAX to LLONG_MAX to fix this issue.
In handle_failed_inode, there is a potential deadlock which can happen
in below call path:
- f2fs_create
- f2fs_lock_op down_read(cp_rwsem)
- f2fs_add_link
- __f2fs_add_link
- init_inode_metadata
- f2fs_init_security failed
- truncate_blocks failed
- handle_failed_inode
- f2fs_truncate
- truncate_blocks(..,true)
- write_checkpoint
- block_operations
- f2fs_lock_all down_write(cp_rwsem)
So in this path, we pass parameter to f2fs_truncate to make sure
cp_rwsem in truncate_blocks will not be locked again.
In f2fs_do_collapse, region cp_rwsem covered is large, since it will be
held until all blocks are left shifted, so if we try to collapse small
area at the beginning of large file, checkpoint who want to grab writer's
lock of cp_rwsem will be delayed for long time.
In order to avoid this condition, altering to lock/unlock cp_rwsem each
shift operation.
With cost-benifit method, background gc will consider old section with
fewer valid blocks as candidate victim, these old blocks in section will
be treated as cold data, and laterly will be moved into cold segment.
But if the gcing page is attached by user through buffered or mmaped
write, we should reset the page as non-cold one, because this page may
have more opportunity for further updating.
So fix to add clearing code for the missed 'mmap' case.
When background gc is off, the only way to trigger gc is executing
a force gc in some operations who wants to grab space in disk.
The executing condition is limited: to execute force gc, we should
wait for the time when there is almost no more free section for LFS
allocation. This seems not reasonable for our user who wants to
control triggering gc by himself.
This patch introduces F2FS_IOC_GARBAGE_COLLECT interface for
triggering garbage collection by using ioctl. It provides our users
one more option to trigger gc.
For newly added fallocate types, it should convert inline_data before handling
block swapping.
The cgroup attaches inode->i_wb via mark_inode_dirty and when set_page_writeback
is called, __inc_wb_stat() updates i_wb's stat.
So, we need to explicitly call set_page_dirty->__mark_inode_dirty in prior to
any writebacking pages.
This patch should resolve the following kernel panic reported by Andreas Reis.
https://bugzilla.kernel.org/show_bug.cgi?id=101801
--- Comment #2 from Andreas Reis <andreas.reis@gmail.com> ---
BUG: unable to handle kernel NULL pointer dereference at 00000000000000a8
IP: [<ffffffff8149deea>] __percpu_counter_add+0x1a/0x90
PGD 2951ff067 PUD 2df43f067 PMD 0
Oops: 0000 [#1] PREEMPT SMP
Modules linked in:
CPU: 7 PID: 10356 Comm: gcc Tainted: G W 4.2.0-1-cu #1
Hardware name: Gigabyte Technology Co., Ltd. G1.Sniper M5/G1.Sniper M5, BIOS
T01 02/03/2015
task: ffff880295044f80 ti: ffff880295140000 task.ti: ffff880295140000
RIP: 0010:[<ffffffff8149deea>] [<ffffffff8149deea>]
RSP: 0018:ffff880295143ac8 EFLAGS: 00010082
RAX: 0000000000000003 RBX: ffffea000a526d40 RCX: 0000000000000001
RDX: 0000000000000020 RSI: 0000000000000001 RDI: 0000000000000088
RBP: ffff880295143ae8 R08: 0000000000000000 R09: ffff88008f69bb30
R10: 00000000fffffffa R11: 0000000000000000 R12: 0000000000000088
R13: 0000000000000001 R14: ffff88041d099000 R15: ffff880084a205d0
FS: 00007f8549374700(0000) GS:ffff88042f3c0000(0000) knlGS:0000000000000000
CR2: 00000000000000a8 CR3: 000000033e1d5000 CR4: 00000000001406e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Stack:
0000000000000000 ffffea000a526d40 ffff880084a20738 ffff880084a20750
ffff880295143b48 ffffffff811cc91e ffff880000000000 0000000000000296
0000000000000000 ffff880417090198 0000000000000000 ffffea000a526d40
Call Trace:
[<ffffffff811cc91e>] __test_set_page_writeback+0xde/0x1d0
[<ffffffff813fee87>] do_write_data_page+0xe7/0x3a0
[<ffffffff813faeea>] gc_data_segment+0x5aa/0x640
[<ffffffff813fb0b8>] do_garbage_collect+0x138/0x150
[<ffffffff813fb3fe>] f2fs_gc+0x1be/0x3e0
[<ffffffff81405541>] f2fs_balance_fs+0x81/0x90
[<ffffffff813ee357>] f2fs_unlink+0x47/0x1d0
[<ffffffff81239329>] vfs_unlink+0x109/0x1b0
[<ffffffff8123e3d7>] do_unlinkat+0x287/0x2c0
[<ffffffff8123ebc6>] SyS_unlink+0x16/0x20
[<ffffffff81942e2e>] entry_SYSCALL_64_fastpath+0x12/0x71
Code: 41 5e 5d c3 0f 1f 00 66 2e 0f 1f 84 00 00 00 00 00 55 48 89 e5 41 55 49
89 f5 41 54 49 89 fc 53 48 83 ec 08 65 ff 05 e6 d9 b6 7e <48> 8b 47 20 48 63 ca
65 8b 18 48 63 db 48 01 f3 48 39 cb 7d 0a
RIP [<ffffffff8149deea>] __percpu_counter_add+0x1a/0x90
RSP <ffff880295143ac8>
---[ end trace 5132449a58ed93a3 ]---
note: gcc[10356] exited with preempt_count 2
When we perform generic/092 in xfstests, output is like below:
XXX Bytes, X ops; XX:XX:XX.X (XXX YYY/sec and XXX ops/sec)
0: [0..10239]: data
0: [0..10239]: data
-1: [10240..20479]: unwritten
+1: [10240..14335]: unwritten
This is because with this testcase, we redefine the regulation for
truncate in perallocated space past i_size as below:
"There was some confused about what the fs was supposed to do when you
truncate at i_size with preallocated space past i_size. We decided on the
following things.
1) truncate(i_size) will trim all blocks past i_size.
2) truncate(x) where x > i_size will not trim all blocks past i_size.
This method is used in xfs, and then ext4/btrfs will follow the rule.
This patch fixes to follow the new rule for f2fs.
When aborting volatile_writes, let's drop its flag and give up any further
volatile_writes.
In recovery procedure for superblock, we try to write data of valid
superblock into invalid one for recovery, work should be finished here,
but then still we will write the valid one with its original data.
This operation is not needed. Let's skip doing this unnecessary work.
FALLOC_FL_INSERT_RANGE flag for ->fallocate was introduced in commit
dd46c787788d ("fs: Add support FALLOC_FL_INSERT_RANGE for fallocate").
The effect of FALLOC_FL_INSERT_RANGE command is the opposite of
FALLOC_FL_COLLAPSE_RANGE, if this command was performed, all data from
offset to EOF in our file will be shifted to right as given length, and
then range [offset, offset + length] becomes a hole.
This command is useful for our user who wants to add some data in the
middle of the file, for example: video/music editor will insert a keyframe
in specified position of media file, with this command we can easily create
a hole for inserting without removing original data.
This patch introduces f2fs_insert_range() to support FALLOC_FL_INSERT_RANGE.
Signed-off-by: Yuan Zhong <yuan.mark.zhong@samsung.com>
This patch clean up codes through:
1.rename f2fs_replace_block to __f2fs_replace_block().
2.introduce new f2fs_replace_block() to include __f2fs_replace_block()
and some common related codes around __f2fs_replace_block().
Then, newly introduced function f2fs_replace_block can be used by
following patch.
Encryption policy should only be set to an empty directory through ioctl,
This patch add a judgement condition to verify type of the target inode
to avoid incorrectly configuring for non-directory.
Additionally, remove unneeded inline data conversion since regular or symlink
file should not be processed here.
This patch adds a bit flag to indicate whether or not i_name in the inode
is encrypted.
If this name is encrypted, we can't do recover_dentry during roll-forward.
So, f2fs_sync_file() needs to do checkpoint, if this will be needed in future.
This patch adds encryption support in read and write paths.
Note that, in f2fs, we need to consider cleaning operation.
In cleaning procedure, we must avoid encrypting and decrypting written blocks.
So, this patch implements move_encrypted_block().
This patch activates the following APIs for encryption support.
The rules quoted by ext4 are:
- An unencrypted directory may contain encrypted or unencrypted files
or directories.
- All files or directories in a directory must be protected using the
same key as their containing directory.
- Encrypted inode for regular file should not have inline_data.
- Encrypted symlink and directory may have inline_data and inline_dentry.
This patch activates the following APIs.
1. f2fs_link : validate context
2. f2fs_lookup : ''
3. f2fs_rename : ''
4. f2fs_create/f2fs_mkdir : inherit its dir's context
5. f2fs_direct_IO : do buffered io for regular files
6. f2fs_open : check encryption info
7. f2fs_file_mmap : ''
8. f2fs_setattr : ''
9. f2fs_file_write_iter : '' (Called by sys_io_submit)
10. f2fs_fallocate : do not support fcollapse
11. f2fs_evict_inode : free_encryption_info
Signed-off-by: Michael Halcrow <mhalcrow@google.com>
This patch adds encryption policy and password salt support through ioctl
implementation.
It adds three ioctls:
F2FS_IOC_SET_ENCRYPTION_POLICY,
F2FS_IOC_GET_ENCRYPTION_POLICY,
F2FS_IOC_GET_ENCRYPTION_PWSALT, which use xattr operations.
Note that, these definition and codes are taken from ext4 crypto support.
For f2fs, xattr operations and on-disk flags for superblock and inode were
changed.
Signed-off-by: Ildar Muslukhov <muslukhovi@gmail.com>
Now, FALLOC_FL_ZERO_RANGE flag in ->fallocate is supported in ext4/xfs.
In commit, the semantics of this flag is descripted as following:"
1) Make sure that both offset and len are block size aligned.
2) Update the i_size of inode by len bytes.
3) Compute the file's logical block number against offset. If the computed
block number is not the starting block of the extent, split the extent
such that the block number is the starting block of the extent.
4) Shift all the extents which are lying between
[offset, last allocated extent] towards right by len bytes. This step
will make a hole of len bytes at offset."
This patch implements fallocate's FALLOC_FL_ZERO_RANGE for f2fs.
Now, FALLOC_FL_COLLAPSE_RANGE flag in ->fallocate is supported in ext4/xfs.
1) It collapses the range lying between offset and length by removing any
data blocks which are present in this range and than updates all the
logical offsets of extents beyond "offset + len" to nullify the hole
created by removing blocks. In short, it does not leave a hole.
2) It should be used exclusively. No other fallocate flag in combination.
3) Offset and length supplied to fallocate should be fs block size aligned
in case of xfs and ext4.
4) Collaspe range does not work beyond i_size."
This patch implements fallocate's FALLOC_FL_COLLAPSE_RANGE for f2fs.
This patch splits find_data_page as follows.
1. f2fs_gc
- use get_read_data_page() with read only
2. find_in_level
- use find_data_page without locked page
3. truncate_partial_page
- In the case cache_only mode, just drop cached page.
- Ohterwise, use get_lock_data_page() and guarantee to truncate
This patch adds f2fs_sb_info and page pointers in f2fs_io_info structure.
With this change, we can reduce a lot of parameters for IO functions.
This patch adds f2fs_may_inline_data and f2fs_may_inline_dentry.
In the punch_hole(), if offset bigger than inode size, it returns SUCCESS.
Then f2fs_fallocate() will update time and dirty mark.
In that case, inode has not been modified actually.
So I have added offset check routine that prevent to call the punch_hole().
Signed-off-by: Taehee Yoo <ap420073@gmail.com>
Pull fourth vfs update from Al Viro:
"d_inode() annotations from David Howells (sat in for-next since before
the beginning of merge window) + four assorted fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
RCU pathwalk breakage when running into a symlink overmounting something
fix I_DIO_WAKEUP definition
direct-io: only inc/dec inode->i_dio_count for file systems
fs/9p: fix readdir()
VFS: assorted d_backing_inode() annotations
VFS: fs/inode.c helpers: d_inode() annotations
VFS: fs/cachefiles: d_backing_inode() annotations
VFS: fs library helpers: d_inode() annotations
VFS: assorted weird filesystems: d_inode() annotations
VFS: normal filesystems (and lustre): d_inode() annotations
VFS: security/: d_inode() annotations
VFS: security/: d_backing_inode() annotations
VFS: net/: d_inode() annotations
VFS: net/unix: d_backing_inode() annotations
VFS: kernel/: d_inode() annotations
VFS: audit: d_backing_inode() annotations
VFS: Fix up some ->d_inode accesses in the chelsio driver
VFS: Cachefiles should perform fs modifications on the top layer only
VFS: AF_UNIX sockets should call mknod on the top layer only
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs
Pull f2fs updates from Jaegeuk Kim:
"New features:
- in-memory extent_cache
- fs_shutdown to test power-off-recovery
- use inline_data to store symlink path
- show f2fs as a non-misc filesystem
Major fixes:
- avoid CPU stalls on sync_dirty_dir_inodes
- fix some power-off-recovery procedure
- fix handling of broken symlink correctly
- fix missing dot and dotdot made by sudden power cuts
- handle wrong data index during roll-forward recovery
- preallocate data blocks for direct_io
... and a bunch of minor bug fixes and cleanups"
* tag 'for-f2fs-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (71 commits)
f2fs: pass checkpoint reason on roll-forward recovery
f2fs: avoid abnormal behavior on broken symlink
f2fs: flush symlink path to avoid broken symlink after POR
f2fs: change 0 to false for bool type
f2fs: do not recover wrong data index
f2fs: do not increase link count during recovery
f2fs: assign parent's i_mode for empty dir
f2fs: add F2FS_INLINE_DOTS to recover missing dot dentries
f2fs: fix mismatching lock and unlock pages for roll-forward recovery
f2fs: fix sparse warnings
f2fs: limit b_size of mapped bh in f2fs_map_bh
f2fs: persist system.advise into on-disk inode
f2fs: avoid NULL pointer dereference in f2fs_xattr_advise_get
f2fs: preallocate fallocated blocks for direct IO
f2fs: enable inline data by default
f2fs: preserve extent info for extent cache
f2fs: initialize extent tree with on-disk extent info of inode
f2fs: introduce __{find,grab}_extent_tree
f2fs: split set_data_blkaddr from f2fs_update_extent_cache
f2fs: enable fast symlink by utilizing inline data
