commit 15d3042a937c13f5d9244241c7a9c8416ff6e82a upstream.
Make sure segno and blkoff read from raw image are valid.
Cc: stable@vger.kernel.org
Signed-off-by: Jin Qian <jinqian@google.com>
[Jaegeuk Kim: adjust minor coding style]
Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org>
[AmitP: Found in Android Security bulletin for Aug'17, fixes CVE-2017-10663]
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit b9dd46188edc2f0d1f37328637860bb65a771124 upstream.
F2FS uses 4 bytes to represent block address. As a result, supported
size of disk is 16 TB and it equals to 16 * 1024 * 1024 / 2 segments.
commit 9a59b62fd88196844cee5fff851bee2cfd7afb6e upstream.
Do more sanity check for superblock during ->mount.
Signed-off-by: Chao Yu <chao2.yu@samsung.com>
After finishing building free nid cache, we will try to readahead
asynchronously 4 more pages for the next reloading, the count of
readahead nid pages is fixed.
In some case, like SMR drive, read less sectors with fixed count
each time we trigger RA may be low efficient, since we will face
high seeking overhead, so we'd better let user to configure this
parameter from sysfs in specific workload.
This patch introduces a periodic checkpoint feature.
Note that, this is not enforcing to conduct checkpoints very strictly in terms
of trigger timing, instead just hope to help user experiences.
The default value is 60 seconds.
Reviewed-by: Chao Yu <chao2.yu@samsung.com>
This patch introduce background_gc=sync enabling synchronous cleaning in
background.
Swith extent_cache option dynamically when remount may casue consistency
issue between extent cache and dnode page. Fix in this patch to avoid
that condition.
upset segment_info like this:
276000|161 0|0 4|70 3|0 3|0 0|0 0|91 4|0 4|232 4|39
276104|0 4|0 4|1 4|0 4|0 4|280 4|0 4|42 4|262 4|38
276204|179 4|89 4|39 4|24 4|0 4|96 4|3 4|428 4|0 4|118
276304|112 4|97 4|0 4|0 4|0 4|68 4|0 4|0 4|86 4|138
276404|0 4|0 0|166 5|39 4|101 0|111
Signed-off-by: Yunlei He <heyunlei@huawei.com>
We should not write node pages when deleting orphan inodes.
In order to do that, we can eaisly set POR_DOING flag earlier before entering
orphan inode routine.
In recover_orphan_inode, whenever f2fs_iget fail, we will make kernel panic,
but it's not reasonable, because f2fs_iget can fail due to a lot of reasons
including out of memory.
So we change error handling method as below:
a) when finding no entry for the orphan inode, bug_on for catching bugs;
b) for other reasons, report it to caller.
Previously, we use radix tree to index all registered page entries for
atomic file, but now we only use radix tree to see whether current page
is indexed or not, since the other user of radix tree is gone in commit
042b7816aaeb ("f2fs: remove unnecessary call to invalidate inmemory pages").
So in this patch, we try to use one more efficient way:
Introducing a macro ATOMIC_WRITTEN_PAGE, and setting it as page private
value to indicate page indexing status. By using this way, we can save
memory and lookup time.
In handle_failed_inode, there is a potential deadlock which can happen
in below call path:
- f2fs_create
- f2fs_lock_op down_read(cp_rwsem)
- f2fs_add_link
- __f2fs_add_link
- init_inode_metadata
- f2fs_init_security failed
- truncate_blocks failed
- handle_failed_inode
- f2fs_truncate
- truncate_blocks(..,true)
- write_checkpoint
- block_operations
- f2fs_lock_all down_write(cp_rwsem)
So in this path, we pass parameter to f2fs_truncate to make sure
cp_rwsem in truncate_blocks will not be locked again.
We don't need to handle the duplicate extent information.
The integrated rule is:
- update on-disk extent with largest one tracked by in-memory extent_cache
- destroy extent_tree for the truncation case
- drop per-inode extent_cache by shrinker
This patch adds noextent_cache mount option.
This patch introduces a shrinker targeting to reduce memory footprint consumed
by a number of in-memory f2fs data structures.
In addition, it newly adds:
- sbi->umount_mutex to avoid data races on shrinker and put_super
- sbi->shruinker_run_no to not revisit objects
Note that the basic implementation was copied from fs/ubifs/shrinker.c
The write_checkpoint can update stat information, so we should destroy the stat
structure after it.
In recovery procedure for superblock, we try to write data of valid
superblock into invalid one for recovery, work should be finished here,
but then still we will write the valid one with its original data.
This operation is not needed. Let's skip doing this unnecessary work.
For the first mount of f2fs image with realtime discard option, we will
disable discard option if device is not supported, but for remount
operation, our discard option can still be set, this should be avoided.
This patch moves configuring of discard option to parse_options() to fix
this issue.
Current f2fs check the whether the blk device can support discard.
However, the code will cause the discard option cannot be enabled.
Because the clear_opt(sbi, DISCARD) will be invoked forever.
This patch can fix this issue.
Jaegeuk Kim:
The original patch was intended to disable the discard option when device
does not support trim command.
Rather than remaining the buggy patch, let's replace with this patch as
an integrated one.
Signed-off-by: Chenxi Mao <chenxi.mao2013@gmail.com>
This patch applies the following ext4 patch:
ext4 crypto: use per-inode tfm structure
As suggested by Herbert Xu, we shouldn't allocate a new tfm each time
we read or write a page. Instead we can use a single tfm hanging off
the inode's crypt_info structure for all of our encryption needs for
that inode, since the tfm can be used by multiple crypto requests in
parallel.
Also use cmpxchg() to avoid races that could result in crypt_info
structure getting doubly allocated or doubly freed.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
This patch recovers a broken superblock with the other valid one.
Signed-off-by: hujianyang <hujianyang@huawei.com>
[Jaegeuk Kim: reinitialize local variables in f2fs_fill_super for retrial]
This patch splits f2fs_crypto_init/exit with two parts: base initialization and
memory allocation.
Firstly, f2fs module declares the base encryption memory pointers.
Then, allocating internal memories is done at the first encrypted inode access.
As Hu reported, F2FS has a space leak problem, when conducting:
1) format a 4GB f2fs partition
2) dd a 3G file,
3) unlink it.
So, when doing f2fs_drop_inode(), we need to truncate data blocks
before skipping it.
We can also drop unused caches assigned to each inode.
Reported-by: hujianyang <hujianyang@huawei.com>
I use f2fs filesystem with /data partition on my Android phone
by the default mount options. When I remount /data in order to
adding discard option to run some benchmarks, I find the default
options such as background_gc, user_xattr and acl turned off.
So I introduce a function named default_options in super.c. It do
some default setting, and both mount and remount operations will
call this function to complete default setting.
Most of parts were copied from ext4, except:
- add f2fs_restore_and_release_control_page which returns control page and
restore control page
- remove ext4_encrypted_zeroout()
- remove sbi->s_file_encryption_mode & sbi->s_dir_encryption_mode
- add f2fs_end_io_crypto_work for mpage_end_io
Signed-off-by: Michael Halcrow <mhalcrow@google.com>
Signed-off-by: Ildar Muslukhov <ildarm@google.com>
This patch adds f2fs_sb_info and page pointers in f2fs_io_info structure.
With this change, we can reduce a lot of parameters for IO functions.
This patch introduces f2fs_commit_super to write updated superblock.
This reports performance regression by Yuanhan Liu.
The basic idea was to reduce one-point mutex, but it turns out this causes
another contention like context swithes.
https://lkml.org/lkml/2015/4/21/11
Until finishing the analysis on this issue, I'd like to revert this for a while.
This reverts commit 78373b7319abdf15050af5b1632c4c8b8b398f33.
in the f2fs_fill_super function, variable "retry" is bool type
i think that it should be set as false.
Signed-off-by: Taehee Yoo <ap420073@gmail.com>
Enable inline_data feature by default since it brings us better
performance and space utilization and now has already stable.
Add another option noinline_data to disable it during mount.
Suggested-by: Jaegeuk Kim <jaegeuk@kernel.org>
Suggested-by: Chao Yu <chao2.yu@samsung.com>
Signed-off-by: Wanpeng Li <wanpeng.li@linux.intel.com>
Previously, f2fs_write_data_pages has a mutex, sbi->writepages, to serialize
data writes to maximize write bandwidth, while sacrificing multi-threads
performance.
Practically, however, multi-threads environment is much more important for
users. So this patch tries to remove the mutex.
This patch tries to set SBI_NEED_FSCK flag into sbi only when we fail to recover
in fill_super, so we could skip fscking image when we fail to fill super for
other reason.
extent tree/node slab cache is created during f2fs insmod,
how, it isn't destroyed during f2fs rmmod, this patch fix
it by destroy extent tree/node slab cache once rmmod f2fs.
This patch enables rb-tree based extent cache in f2fs.
When we mount with "-o extent_cache", f2fs will try to add recently accessed
page-block mappings into rb-tree based extent cache as much as possible, instead
of original one extent info cache.
By this way, f2fs can support more effective cache between dnode page cache and
disk. It will supply high hit ratio in the cache with fewer memory when dnode
page cache are reclaimed in environment of low memory.
Storage: Sandisk sd card 64g
1.append write file (offset: 0, size: 128M);
2.override write file (offset: 2M, size: 1M);
3.override write file (offset: 4M, size: 1M);
4.override write file (offset: 48M, size: 1M);
5.override write file (offset: 112M, size: 1M);
6.sync
7.echo 3 > /proc/sys/vm/drop_caches
8.read file (size:128M, unit: 4k, count: 32768)
(time dd if=/mnt/f2fs/128m bs=4k count=32768)
Extent Hit Ratio:
before patched
Hit Ratio 121 / 1071 1071 / 1071
Performance:
before patched
real 0m37.051s 0m35.556s
user 0m0.040s 0m0.026s
sys 0m2.990s 0m2.251s
Memory Cost:
before patched
Tree Count: 0 1 (size: 24 bytes)
Node Count: 0 45 (size: 1440 bytes)
v3:
o retest and given more details of test result.
This patch adds a mount option 'extent_cache' in f2fs.
It is try to use a rb-tree based extent cache to cache more mapping information
with less memory if this option is set, otherwise we will use the original one
extent info cache.
Suggested-by: Changman Lee <cm224.lee@samsung.com>
Move ext_lock out of struct extent_info, then in the following patches we can
use variables with struct extent_info type as a parameter to pass pure data.
This patch introduces a batched trimming feature, which submits split discard
commands.
This is to avoid long latency due to huge trim commands.
If fstrim was triggered ranging from 0 to the end of device, we should lock
all the checkpoint-related mutexes, resulting in very long latency.
If device is read-only, we should not proceed data recovery.
But, if the previous checkpoint was done by normal clean shutdown, it's safe to
proceed the recovery, since there will be no data to be recovered.
This patch adds FASTBOOT flag into checkpoint as follows.
- CP_UMOUNT_FLAG is set when system is umounted.
- CP_FASTBOOT_FLAG is set when intermediate checkpoint having node summaries
was done.
So, if you get CP_UMOUNT_FLAG from checkpoint, the system was umounted cleanly.
Instead, if there was sudden-power-off, you can get CP_FASTBOOT_FLAG or nothing.
This patch adds a mount option, norecovery, which is mostly same as
disable_roll_forward. The only difference is that norecovery should be activated
with read-only mount option.
This can be used when user wants to check whether f2fs is mountable or not
without any recovery process. (e.g., xfstests/200)
If wrong mount option was requested, f2fs tries to fill_super again.
But, during the next trial, f2fs has no valid mount options, since
parse_options deleted all the separators in the original string.
Currently, there are several variables with Boolean type as below:
struct f2fs_sb_info {
int s_dirty;
bool need_fsck;
bool s_closing;
bool por_doing;
For this there are some issues:
1. there are some space of f2fs_sb_info is wasted due to aligning after Boolean
type variables by compiler.
2. if we continuously add new flag into f2fs_sb_info, structure will be messed
up.
So in this patch, we try to:
1. switch s_dirty to Boolean type variable since it has two status 0/1.
2. merge s_dirty/need_fsck/s_closing/por_doing variables into s_flag.
3. introduce an enum type which can indicate different states of sbi.
4. use new introduced universal interfaces is_sbi_flag_set/{set,clear}_sbi_flag
to operate flags for sbi.
After that, above issues will be fixed.
If the previous checkpoint was done without CP_UMOUNT flag, it needs to do
checkpoint with CP_UMOUNT for the next fast boot.
This patch fixes to trigger checkpoint with umount flag when kill_sb was called.
In kill_sb, f2fs_sync_fs was finally called, but at this time, f2fs can't do
checkpoint with CP_UMOUNT.
After then, f2fs_put_super is not doing checkpoint, since it is not dirty.
So, this patch adds a flag to indicate f2fs_sync_fs is called during umount.
This patch removes radix tree after finishing tracing IOs.
This patch adds spin_lock to cover radix tree operations in IO tracer.
There are two slab cache inode_entry_slab and winode_slab using the same
structure as below:
struct dir_inode_entry {
struct list_head list; /* list head */
struct inode *inode; /* vfs inode pointer */
struct inode_entry {
It's a little waste that the two cache can not share their memory space for each
other.
So in this patch we remove one redundant winode_slab slab cache, then use more
universal name struct inode_entry as remaining data structure name of slab,
finally we reuse the inode_entry_slab to store dirty dir item and gc item for
more effective.
This patch activates f2fs_trace_ios.
Because we have checked the contrary condition in case of "if" judgment, we do
not need to check the condition again in case of "else" judgment. Let's remove
it.
In f2fs_remount, we will stop gc thread and set need_restart_gc as true when new
option is set without BG_GC, then if any error occurred in the following
procedure, we can restore to start the gc thread.
But after that, We will fail to restore gc thread in start_gc_thread as BG_GC is
not set in new option, so we'd better move this condition judgment out of
start_gc_thread to fix this issue.
