path: root/fs/f2fs
2013-05-08Merge tag 'f2fs-for-v3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs Pull f2fs updates from Jaegeuk Kim: "This patch-set includes the following major enhancement patches. - introduce a new gloabl lock scheme - add tracepoints on several major functions - fix the overall cleaning process focused on victim selection - apply the block plugging to merge IOs as much as possible - enhance management of free nids and its list - enhance the readahead mode for node pages - address several cretical deadlock conditions - reduce lock_page calls The other minor bug fixes and enhancements are as follows. - calculation mistakes: overflow - bio types: READ, READA, and READ_SYNC - fix the recovery flow, data races, and null pointer errors" * tag 'f2fs-for-v3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (68 commits) f2fs: cover free_nid management with spin_lock f2fs: optimize scan_nat_page() f2fs: code cleanup for scan_nat_page() and build_free_nids() f2fs: bugfix for alloc_nid_failed() f2fs: recover when journal contains deleted files f2fs: continue to mount after failing recovery f2fs: avoid deadlock during evict after f2fs_gc f2fs: modify the number of issued pages to merge IOs f2fs: remove useless #include <linux/proc_fs.h> as we're now using sysfs as debug entry. f2fs: fix inconsistent using of NM_WOUT_THRESHOLD f2fs: check truncation of mapping after lock_page f2fs: enhance alloc_nid and build_free_nids flows f2fs: add a tracepoint on f2fs_new_inode f2fs: check nid == 0 in add_free_nid f2fs: add REQ_META about metadata requests for submit f2fs: give a chance to merge IOs by IO scheduler f2fs: avoid frequent background GC f2fs: add tracepoints to debug checkpoint request f2fs: add tracepoints for write page operations f2fs: add tracepoints to debug the block allocation ...
2013-05-08f2fs: cover free_nid management with spin_lockJaegeuk Kim
After build_free_nids() searches free nid candidates from nat pages and current journal blocks, it checks all the candidates if they are allocated so that the nat cache has its nid with an allocated block address. In this procedure, previously we used list_for_each_entry_safe(fnid, next_fnid, &nm_i->free_nid_list, list). But, this is not covered by free_nid_list_lock, resulting in null pointer bug. This patch moves this checking routine inside add_free_nid() in order not to use the spin_lock. Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-05-08f2fs: optimize scan_nat_page()Haicheng Li
When nm_i->fcnt > 2 * MAX_FREE_NIDS, stop scanning other NAT entries. Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com> [Jaegeuk Kim: fix handling the return value of add_free_nid()] Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-05-08f2fs: code cleanup for scan_nat_page() and build_free_nids()Haicheng Li
This patch does two cleanups: 1. remove unused variable "fcnt" in build_free_nids(). 2. make scan_nat_page() as void type and remove useless variable "fcnt". Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-05-08f2fs: bugfix for alloc_nid_failed()Haicheng Li
Directly drop the free_nid cache when nm_i->fcnt > 2 * MAX_FREE_NIDS Since there is NOT nmi->free_nid_list_lock spinlock protection between a sequential calling of alloc_nid() and alloc_nid_failed(), some other threads may already add new free_nid to the free_nid_list during this period. We need to make sure nmi->fcnt is never > 2 * MAX_FREE_NIDS. Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com> [Jaegeuk Kim: fit the coding style] Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-05-08f2fs: recover when journal contains deleted filesChris Fries
When recovering a journal file with fsync data for files that have been deleted, don't bail out on recovery. Signed-off-by: Chris Fries <C.Fries@motorola.com> Reviewed-by: Russell Knize <rknize2@motorola.com> Reviewed-by: Jason Hrycay <jason.hrycay@motorola.com> [Jaegeuk Kim: fit the coding style] Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-05-08f2fs: continue to mount after failing recoveryChris Fries
When unable to roll forward the journal, we shouldn't bail out and not mount, we should continue to attempt the mount. Bad recovery data is likely unrecoverable at this point, and requiring the user to try to mount again doesn't solve any issues. Signed-off-by: Chris Fries <C.Fries@motorola.com> Reviewed-by: Russell Knize <rknize2@motorola.com> Reviewed-by: Jason Hrycay <jason.hrycay@motorola.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-05-08f2fs: avoid deadlock during evict after f2fs_gcJaegeuk Kim
o Deadlock case #1 Thread 1: - writeback_sb_inodes - do_writepages - f2fs_write_data_pages - write_cache_pages - f2fs_write_data_page - f2fs_balance_fs - wait mutex_lock(gc_mutex) Thread 2: - f2fs_balance_fs - mutex_lock(gc_mutex) - f2fs_gc - f2fs_iget - wait iget_locked(inode->i_lock) Thread 3: - do_unlinkat - iput - lock(inode->i_lock) - evict - inode_wait_for_writeback o Deadlock case #2 Thread 1: - __writeback_single_inode : set I_SYNC - do_writepages - f2fs_write_data_page - f2fs_balance_fs - f2fs_gc - iput - evict - inode_wait_for_writeback(I_SYNC) In order to avoid this, even though iput is called with the zero-reference count, we need to stop the eviction procedure if the inode is on writeback. So this patch links f2fs_drop_inode which checks the I_SYNC flag. Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-04-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual stuff, mostly comment fixes, typo fixes, printk fixes and small code cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (45 commits) mm: Convert print_symbol to %pSR gfs2: Convert print_symbol to %pSR m32r: Convert print_symbol to %pSR iostats.txt: add easy-to-find description for field 6 x86 cmpxchg.h: fix wrong comment treewide: Fix typo in printk and comments doc: devicetree: Fix various typos docbook: fix 8250 naming in device-drivers pata_pdc2027x: Fix compiler warning treewide: Fix typo in printks mei: Fix comments in drivers/misc/mei treewide: Fix typos in kernel messages pm44xx: Fix comment for "CONFIG_CPU_IDLE" doc: Fix typo "CONFIG_CGROUP_CGROUP_MEMCG_SWAP" mmzone: correct "pags" to "pages" in comment. kernel-parameters: remove outdated 'noresidual' parameter Remove spurious _H suffixes from ifdef comments sound: Remove stray pluses from Kconfig file radio-shark: Fix printk "CONFIG_LED_CLASS" doc: put proper reference to CONFIG_MODULE_SIG_ENFORCE ...
2013-04-30f2fs: modify the number of issued pages to merge IOsJaegeuk Kim
When testing f2fs on an SSD, I found some 128 page IOs followed by 1 page IO were issued by f2fs_write_node_pages. This means that there were some mishandling flows which degrades performance. Previous f2fs_write_node_pages determines the number of pages to be written, nr_to_write, as follows. 1. The bio_get_nr_vecs returns 129 pages. 2. The bio_alloc makes a room for 128 pages. 3. The initial 128 pages go into one bio. 4. The existing bio is submitted, and a new bio is prepared for the last 1 page. 5. Finally, sync_node_pages submits the last 1 page bio. The problem is from the use of bio_get_nr_vecs, so this patch replace it with max_hw_blocks using queue_max_sectors. Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-30f2fs: remove useless #include <linux/proc_fs.h> as we're now using sysfs as ↵Haicheng Li
debug entry. Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-30f2fs: fix inconsistent using of NM_WOUT_THRESHOLDHaicheng Li
try_to_free_nats() is usually called with parameter nr_shrink as "nm_i->nat_cnt - NM_WOUT_THRESHOLD" by flush_nat_entries() during checkpointing process. However, this is inconsistent with the actual threshold check as "if (nm_i->nat_cnt < 2 * NM_WOUT_THRESHOLD)" , which will ignore the free_nats requests when NM_WOUT_THRESHOLD < nm_i->nat_cnt < 2 * NM_WOUT_THRESHOLD So fix the threshold check condition. Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-29f2fs: check truncation of mapping after lock_pageJaegeuk Kim
We call lock_page when we need to update a page after readpage. Between grab and lock page, the page can be truncated by other thread. So, we should check the page after lock_page whether it was truncated or not. Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-29f2fs: enhance alloc_nid and build_free_nids flowsJaegeuk Kim
In order to avoid build_free_nid lock contention, let's change the order of function calls as follows. At first, check whether there is enough free nids. - If available, just get a free nid with spin_lock without any overhead. - Otherwise, conduct build_free_nids. : scan nat pages, journal nat entries, and nat cache entries. We should consider carefullly not to serve free nids intermediately made by build_free_nids. We can get stable free nids only after build_free_nids is done. Reviewed-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-29f2fs: add a tracepoint on f2fs_new_inodeJaegeuk Kim
This can help when debugging the free nid allocation flows. Reviewed-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-26f2fs: check nid == 0 in add_free_nidJaegeuk Kim
It is more obvious that add_free_nid checks whether the free nid is zero or not. Reviewed-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-26f2fs: add REQ_META about metadata requests for submitNamjae Jeon
Adding REQ_META for all the metadata requests can help in improving the FS performance, if the underlying device supports TAGGING. So, when considering the submit_bio path for all the f2fs requests. We can add REQ_META for all the META requests. As a precursor to this change we considered the commit 4265900e0be653f5b78baf2816857ef57cf1332f 'mmc: MMC-4.5 Data Tag Support' Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-26f2fs: give a chance to merge IOs by IO schedulerJaegeuk Kim
Previously, background GC submits many 4KB read requests to load victim blocks and/or its (i)node blocks. ... f2fs_gc : f2fs_readpage: ino = 1, page_index = 0xb61, blkaddr = 0x3b964ed f2fs_gc : block_rq_complete: 8,16 R () 499854968 + 8 [0] f2fs_gc : f2fs_readpage: ino = 1, page_index = 0xb6f, blkaddr = 0x3b964ee f2fs_gc : block_rq_complete: 8,16 R () 499854976 + 8 [0] f2fs_gc : f2fs_readpage: ino = 1, page_index = 0xb79, blkaddr = 0x3b964ef f2fs_gc : block_rq_complete: 8,16 R () 499854984 + 8 [0] ... However, by the fact that many IOs are sequential, we can give a chance to merge the IOs by IO scheduler. In order to do that, let's use blk_plug. ... f2fs_gc : f2fs_iget: ino = 143 f2fs_gc : f2fs_readpage: ino = 143, page_index = 0x1c6, blkaddr = 0x2e6ee f2fs_gc : f2fs_iget: ino = 143 f2fs_gc : f2fs_readpage: ino = 143, page_index = 0x1c7, blkaddr = 0x2e6ef <idle> : block_rq_complete: 8,16 R () 1519616 + 8 [0] <idle> : block_rq_complete: 8,16 R () 1519848 + 8 [0] <idle> : block_rq_complete: 8,16 R () 1520432 + 96 [0] <idle> : block_rq_complete: 8,16 R () 1520536 + 104 [0] <idle> : block_rq_complete: 8,16 R () 1521008 + 112 [0] <idle> : block_rq_complete: 8,16 R () 1521440 + 152 [0] <idle> : block_rq_complete: 8,16 R () 1521688 + 144 [0] <idle> : block_rq_complete: 8,16 R () 1522128 + 192 [0] <idle> : block_rq_complete: 8,16 R () 1523256 + 328 [0] ... Note that this issue should be addressed in checkpoint, and some readahead flows too. Reviewed-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-26f2fs: avoid frequent background GCJaegeuk Kim
If there is no victim segments selected by background GC, let's wait a little bit longer time to collect dirty segments. By default, let's give 5 minutes. Reviewed-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-23f2fs: add tracepoints to debug checkpoint requestNamjae Jeon
Add tracepoints to debug checkpoint request. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Pankaj Kumar <pankaj.km@samsung.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> [Jaegeuk: change expressions] Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-23f2fs: add tracepoints for write page operationsNamjae Jeon
Add tracepoints to debug the various page write operation like data pages, meta pages. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Pankaj Kumar <pankaj.km@samsung.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> [Jaegeuk: remove unnecessary tracepoints] Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-23f2fs: add tracepoints to debug the block allocationNamjae Jeon
Add tracepoints to debug the block allocation & fallocate. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Pankaj Kumar <pankaj.km@samsung.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> [Jaegeuk: enhance information] Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-23f2fs: add tracepoints for GC threadsNamjae Jeon
Add tracepoints for tracing the garbage collector threads in f2fs with status of collection & type. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Pankaj Kumar <pankaj.km@samsung.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> [Jaegeuk: modify slightly to show information] Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-23f2fs: add tracepoint for tracing the page i/oNamjae Jeon
Add tracepoints for page i/o operations and block allocation tracing during page read operation. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Pankaj Kumar <pankaj.km@samsung.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> [Jaegeuk: combine and modify the tracepoint structures] Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-23f2fs: add tracepoints for truncate operationNamjae Jeon
add tracepoints for tracing the truncate operations like truncate node/data blocks, f2fs_truncate etc. Tracepoints are added at entry and exit of operation to trace the success & failure of operation. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Pankaj Kumar <pankaj.km@samsung.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> [Jaegeuk: combine and modify the tracepoint structures] Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-23f2fs: add tracepoints for sync & inode operationsNamjae Jeon
Add tracepoints in f2fs for tracing the syncing operations like filesystem sync, file sync enter/exit. It will helf to trace the code under debugging scenarios. Also add tracepoints for tracing the various inode operations like building inode, eviction of inode, link/unlike of inodes. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Pankaj Kumar <pankaj.km@samsung.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> [Jaegeuk: combine and modify the tracepoint structures] Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-23f2fs: make is_multimedia_file code align with its nameNamjae Jeon
The code conditions put inside the function is_multimedia_file are reverse to the name i.e, we need to negate the return to actually check if the file is a multimedia file. So, change the code and usage path to align both the name and comparision conditions. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-22f2fs: fix error return code in f2fs_fill_super()Wei Yongjun
Fix to return a negative error code from the error handling case instead of 0, as returned elsewhere in this function. Introduce by commit c0d39e(f2fs: fix return values from validate superblock) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Acked-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-09mode_t, whack-a-mole at 11...Al Viro
2013-04-09f2fs: use mnt_want_write_file() in ioctlAl Viro
2013-04-09f2fs: fix typo mistakesNamjae Jeon
Fix typo mistakes. 1. I think that it should be 'L' instead of 'V'. 2. and try to fix 'Front' instead of 'Frone' Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-09f2fs: write checkpoint before starting FG_GCJaegeuk Kim
In order to be aware of prefree and free sections during FG_GC, let's start with write_checkpoint(). Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-09f2fs: fix the logic of IS_DNODE()Zhihui Zhang
If (ofs % (NIDS_PER_BLOCK + 1) == 0), the node is an indirect node block. Signed-off-by: Zhihui Zhang <zzhsuny@gmail.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-09f2fs: introduce a new global lock schemeJaegeuk Kim
In the previous version, f2fs uses global locks according to the usage types, such as directory operations, block allocation, block write, and so on. Reference the following lock types in f2fs.h. enum lock_type { RENAME, /* for renaming operations */ DENTRY_OPS, /* for directory operations */ DATA_WRITE, /* for data write */ DATA_NEW, /* for data allocation */ DATA_TRUNC, /* for data truncate */ NODE_NEW, /* for node allocation */ NODE_TRUNC, /* for node truncate */ NODE_WRITE, /* for node write */ NR_LOCK_TYPE, }; In that case, we lose the performance under the multi-threading environment, since every types of operations must be conducted one at a time. In order to address the problem, let's share the locks globally with a mutex array regardless of any types. So, let users grab a mutex and perform their jobs in parallel as much as possbile. For this, I propose a new global lock scheme as follows. 0. Data structure - f2fs_sb_info -> mutex_lock[NR_GLOBAL_LOCKS] - f2fs_sb_info -> node_write 1. mutex_lock_op(sbi) - try to get an avaiable lock from the array. - returns the index of the gottern lock variable. 2. mutex_unlock_op(sbi, index of the lock) - unlock the given index of the lock. 3. mutex_lock_all(sbi) - grab all the locks in the array before the checkpoint. 4. mutex_unlock_all(sbi) - release all the locks in the array after checkpoint. 5. block_operations() - call mutex_lock_all() - sync_dirty_dir_inodes() - grab node_write - sync_node_pages() Note that, the pairs of mutex_lock_op()/mutex_unlock_op() and mutex_lock_all()/mutex_unlock_all() should be used together. Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-09f2fs: move f2fs_balance_fs from truncate to punch_holeJason Hrycay
Move the f2fs_balance_fs out of the truncate_hole function and only perform that in punch_hole use case. The commit: ed60b1644e7f7e5dd67d21caf7e4425dff05dad0 intended to do this but moved it into truncate_hole to cover more cases. However, a deadlock scenario is possible when deleting an inode entry under specific conditions: f2fs_delete_entry() mutex_lock_op(sbi, DENTRY_OPS); truncate_hole() f2fs_balance_fs() mutex_lock(&sbi->gc_mutex); f2fs_gc() write_checkpoint() block_operations() mutex_lock_op(sbi, DENTRY_OPS); Lets move it into the punch_hole case to cover the original intent of avoiding it during fallocate's expand_inode_data case. Change-Id: I29f8ea1056b0b88b70ba8652d901b6e8431bb27e Signed-off-by: Jason Hrycay <jason.hrycay@motorola.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-03f2fs: reduce redundant spin_lock operationsJaegeuk Kim
This patch reduces redundant spin_lock operations in alloc_nid_failed(). The alloc_nid_failed() does not need to delete entry and add one again by triggering spin_lock and spin_unlock redundantly. Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-03f2fs: add NULL pointer checkP J P
Commit - fa9150a84c - replaces a call to generic_writepages() in f2fs_write_data_pages() with write_cache_pages(), with a function pointer argument pointing to routine: __f2fs_writepage. -> https://git.kernel.org/linus/fa9150a84ca333f68127097c4fa1eda4b3913a22 This patch adds a NULL pointer check in f2fs_write_data_pages() to avoid a possible NULL pointer dereference, in case if - mapping->a_ops->writepage - is NULL. Signed-off-by: P J P <ppandit@redhat.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-03f2fs: fix the bitmap consistency of dirty segmentsJaegeuk Kim
Like below, there are 8 segment bitmaps for SSR victim candidates. enum dirty_type { DIRTY_HOT_DATA, /* dirty segments assigned as hot data logs */ DIRTY_WARM_DATA, /* dirty segments assigned as warm data logs */ DIRTY_COLD_DATA, /* dirty segments assigned as cold data logs */ DIRTY_HOT_NODE, /* dirty segments assigned as hot node logs */ DIRTY_WARM_NODE, /* dirty segments assigned as warm node logs */ DIRTY_COLD_NODE, /* dirty segments assigned as cold node logs */ DIRTY, /* to count # of dirty segments */ PRE, /* to count # of entirely obsolete segments */ NR_DIRTY_TYPE }; The upper 6 bitmaps indicates segments dirtied by active log areas respectively. And, the DIRTY bitmap integrates all the 6 bitmaps. For example, o DIRTY_HOT_DATA : 1010000 o DIRTY_WARM_DATA: 0100000 o DIRTY_COLD_DATA: 0001000 o DIRTY_HOT_NODE : 0000010 o DIRTY_WARM_NODE: 0000001 o DIRTY_COLD_NODE: 0000000 In this case, o DIRTY : 1111011, which means that we should guarantee the consistency between DIRTY and other bitmaps concreately. However, the SSR mode selects victims freely from any log types, which can set multiple bits across the various bitmap types. So, this patch eliminates this inconsistency. Reviewed-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-03f2fs: avoid race for summary informationJaegeuk Kim
In order to do GC more reliably, I'd like to lock the vicitm summary page until its GC is completed, and also prevent any checkpoint process. Reviewed-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-03f2fs: allocate remained free segments in the LFS modeJaegeuk Kim
This patch adds a new condition that allocates free segments in the current active section even if SSR is needed. Otherwise, f2fs cannot allocate remained free segments in the section since SSR finds dirty segments only. Reviewed-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-03f2fs: check completion of foreground GCJaegeuk Kim
The foreground GCs are triggered under not enough free sections. So, we should not skip moving valid blocks in the victim segments. Reviewed-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-03f2fs: change GC bitmaps to apply the section granularityJaegeuk Kim
This patch removes a bitmap for victim segments selected by foreground GC, and modifies the other bitmap for victim segments selected by background GC. 1) foreground GC bitmap : We don't need to manage this, since we just only one previous victim section number instead of the whole victim history. The f2fs uses the victim section number in order not to allocate currently GC'ed section to current active logs. 2) background GC bitmap : This bitmap is used to avoid selecting victims repeatedly by background GCs. In addition, the victims are able to be selected by foreground GCs, since there is no need to read victim blocks during foreground GCs. By the fact that the foreground GC reclaims segments in a section unit, it'd be better to manage this bitmap based on the section granularity. Reviewed-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-03f2fs: allocate new segment aligned with sectionsJaegeuk Kim
When allocating a new segment under the LFS mode, we should keep the section boundary. Reviewed-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-03f2fs: remove redundant lock_page callsJaegeuk Kim
In get_node_page, we do not need to call lock_page all the time. If the node page is cached as uptodate, 1. grab_cache_page locks the page, 2. read_node_page unlocks the page, and 3. lock_page is called for further process. Let's avoid this. Reviewed-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-03f2fs: introduce TOTAL_SECS macroJaegeuk Kim
Let's use a macro to get the total number of sections. Reviewed-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-03f2fs: do not use duplicate names in a macroJaegeuk Kim
A macro should not use duplicate parameter names. Reviewed-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-03-31f2fs: use kmemdupAlexandru Gheorghiu
Use kmemdup instead of kzalloc and memcpy. Signed-off-by: Alexandru Gheorghiu <gheorghiuandru@gmail.com> Acked-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-03-27f2fs: fix to give correct parent inode number for roll forwardJaegeuk Kim
When we recover fsync'ed data after power-off-recovery, we should guarantee that any parent inode number should be correct for each direct inode blocks. So, let's make the following rules. - The fsync should do checkpoint to all the inodes that were experienced hard links. - So, the only normal files can be recovered by roll-forward. Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
