path: root/fs/fat/dir.c
2011-04-12fat: Replace all printk with fat_msg()Alexey Fisher
Replace all printk with fat_msg() Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2010-05-17fat: convert to unlocked_ioctlArnd Bergmann
FAT does not require the BKL in its ioctl function, which is already serialized through a mutex. Since we're already touching the ioctl code, also fix the missing handling of FAT_IOCTL_GET_ATTRIBUTES in the compat code. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2010-03-16fat: use pack_hex_byte() instead of custom oneAndy Shevchenko
Signed-off-by: Andy Shevchenko <ext-andriy.shevchenko@nokia.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (143 commits) USB: xhci depends on PCI. USB: xhci: Add Makefile, MAINTAINERS, and Kconfig entries. USB: xhci: Respect critical sections. USB: xHCI: Fix interrupt moderation. USB: xhci: Remove packed attribute from structures. usb; xhci: Fix TRB offset calculations. USB: xhci: replace if-elseif-else with switch-case USB: xhci: Make xhci-mem.c include linux/dmapool.h USB: xhci: drop spinlock in xhci_urb_enqueue() error path. USB: Change names of SuperSpeed ep companion descriptor structs. USB: xhci: Avoid compiler reordering in Link TRB giveback. USB: xhci: Clean up xhci_irq() function. USB: xhci: Avoid global namespace pollution. USB: xhci: Fix Link TRB handoff bit twiddling. USB: xhci: Fix register write order. USB: xhci: fix some compiler warnings in xhci.h USB: xhci: fix lots of compiler warnings. USB: xhci: use xhci_handle_event instead of handle_event USB: xhci: URB cancellation support. USB: xhci: Scatter gather list support for bulk transfers. ...
2009-06-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6: fat: split fat_generic_ioctl FAT: add 'errors' mount option
2009-06-15NLS: update handling of UnicodeAlan Stern
This patch (as1239) updates the kernel's treatment of Unicode. The character-set conversion routines are well behind the current state of the Unicode specification: They don't recognize the existence of code points beyond plane 0 or of surrogate pairs in the UTF-16 encoding. The old wchar_t 16-bit type is retained because it's still used in lots of places. This shouldn't cause any new problems; if a conversion now results in an invalid 16-bit code then before it must have yielded an undefined code. Difficult-to-read names like "utf_mbstowcs" are replaced with more transparent names like "utf8s_to_utf16s" and the ordering of the parameters is rationalized (buffer lengths come immediate after the pointers they refer to, and the inputs precede the outputs). Fortunately the low-level conversion routines are used in only a few places; the interfaces to the higher-level uni2char and char2uni methods have been left unchanged. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11Sanitize ->fsync() for FATAl Viro
* mark directory data blocks as assoc. metadata * add new inode to deal with FAT, mark FAT blocks as assoc. metadata of that * now ->fsync() is trivial both for files and directories Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-04FAT: add 'errors' mount optionDenis Karpov
On severe errors FAT remounts itself in read-only mode. Allow to specify FAT fs desired behavior through 'errors' mount option: panic, continue or remount read-only. `mount -t [fat|vfat] -o errors=[panic,remount-ro,continue] \ <bdev> <mount point>` This is analog to ext2 fs 'errors' mount option. Signed-off-by: Denis Karpov <ext-denis.2.karpov@nokia.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2008-11-12fat: fix duplicate addition of ->llseek handlerOGAWA Hirofumi
2008-11-06fat: i_blocks warning fixOGAWA Hirofumi
blkcnt_t type depends on CONFIG_LSF. Use unsigned long long always for printk(). But lazy to type it, so add "llu" and use it. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: mmu_private race fixOGAWA Hirofumi
mmu_private is 64bits value, hence it's not atomic to update. So, the access rule for mmu_private is we must hold ->i_mutex. But, fat_get_block() path doesn't follow the rule on non-allocation path. This fixes by using i_size instead if non-allocation path. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: cleanup fat_parse_long() error handlingDarren Jenkins
Coverity CID 2332 & 2333 RESOURCE_LEAK In fat_search_long() if fat_parse_long() returns a -ve value we return without first freeing unicode. This patch free's them on this error path. The above was false positive on current tree, but this change is more clean, so apply as cleanup. [hirofumi@mail.parknet.co.jp: fix coding style] Signed-off-by: Darren Jenkins <darrenrjenkins@gmail.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: use generic_file_llseek() for directoryOGAWA Hirofumi
Since fat_dir_ioctl() was already fixed (i.e. called under ->i_mutex), and __fat_readdir() doesn't take BKL anymore. So, BKL for ->llseek() is pointless, and we have to use generic_file_llseek(). Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: Fix and cleanup timestamp conversionOGAWA Hirofumi
This cleans date_dos2unix()/fat_date_unix2dos() up. New code should be much more readable. And this fixes those old functions. Those doesn't handle 2100 correctly. 2100 isn't leap year, but old one handles it as leap year. Also, with this, centi sec is handled and is fixed. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: split include/msdos_fs.hOGAWA Hirofumi
This splits __KERNEL__ stuff in include/msdos_fs.h into fs/fat/fat.h. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-23[PATCH] fix ->llseek for more directoriesChristoph Hellwig
With this patch all directory fops instances that have a readdir that doesn't take the BKL are switched to generic_file_llseek. Signed-off-by: Christoph Hellwig <hch@lst.de>
2008-07-25fatfs: add UTC timestamp optionJoe Peterson
Provide a new mount option ("tz=UTC") for DOS (vfat/msdos) filesystems, allowing timestamps to be in coordinated universal time (UTC) rather than local time in applications where doing this is advantageous. In particular, portable devices that use fat/vfat (such as digital cameras) can benefit from using UTC in their internal clocks, thus avoiding daylight saving time errors and general time ambiguity issues. The user of the device does not have to worry about changing the time when moving from place or when daylight saving changes. The new mount option, when set, disables the counter-adjustment that Linux currently makes to FAT timestamp info in anticipation of the normal userspace time zone correction. When used in this new mode, all daylight saving time and time zone handling is done in userspace as is normal for many other filesystems (like ext3). The default mode, which remains unchanged, is still appropriate when mounting volumes written in Windows (because of its use of local time). I originally based this patch on one submitted last year by Paul Collins, but I updated it to work with current source and changed variable/option naming. Ogawa Hirofumi (who maintains these filesystems) and I discussed this patch at length on lkml, and he suggested using the option name in the attached version of the patch. Barry Bouwsma pointed out a good addition to the patch as well. Signed-off-by: Joe Peterson <joe@skyrush.com> Signed-off-by: Paul Collins <paul@ondioline.org> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Barry Bouwsma <free_beer_for_all@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25fat: small optimization to __fat_readdir()OGAWA Hirofumi
This removes unnecessary parsing for directory entries. If short_only, we don't need to parse longname. And if !both and it found the longname, we don't need shortname. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25fat: use same logic in fat_search_long() and __fat_readdir()OGAWA Hirofumi
This uses uses stack for shortname, and uses __getname() for longname in fat_search_long() and __fat_readdir(). By this, it removes unneeded __getname() for shortname. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25fat: cleanup fs/fat/dir.cOGAWA Hirofumi
This is no logic changes, just cleans fs/fat/dir.c up. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25fat/dir.c: switch to struct __fat_direntAdrian Bunk
struct __fat_dirent is what was formerly the kernel struct dirent (that was different from the userspace struct dirent). Converting all fat users to struct __fat_dirent will allow us to get rid of the conflicting struct dirent definition. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-20Replace BKL with superblock lock in fat/msdos/vfatLinus Torvalds
This replaces the use of the BKL in the FAT family of filesystems with the existing superblock lock instead. The code already appears to do mostly proper locking with its own private spinlocks (and mutexes), but while the BKL could possibly have been dropped entirely, converting it to use the superblock lock (which is just a regular mutex) is the conservative thing to do. As a per-filesystem mutex, it not only won't have any of the possible latency issues related to the BKL, but the lock is obviously private to the particular filesystem instance and will thus not cause problems for entirely unrelated users like the BKL can. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-04-28fat: use __getname()OGAWA Hirofumi
__getname() is faster than __get_free_page(). Use it. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28vfat: bug fix for vfat cannot handle filename with 255Keith Mok
This patch fix the problem that the buffer allocated for convert of unicode to utf8 in fat/dir.c is too small. And cannot handle filename with 255 asian characters when mounted with utf8 options. Also it fix the filename length limitation checking in vfat/namei.c that the filename length should be checked against the number of converted unicode characters. Not the length before NLS/UTF8 converted. Signed-off-by: Keith Mok <ek9852@gmail.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16fat: gcc 4.3 warning fixOGAWA Hirofumi
This patch fixes the following warnings. fs/fat/dir.c: In function 'fat_parse_long': include/linux/msdos_fs.h:294: warning: array subscript is above array bounds include/linux/msdos_fs.h:295: warning: array subscript is above array bounds include/linux/msdos_fs.h:295: warning: array subscript is above array bounds The ->name is defined as "name[8], ext[3]", but fat_checksum() uses those as name[11]. There is no actual problem, but it's not a good manner. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fat: fix VFAT compat ioctls on 64-bit systemsOGAWA Hirofumi
If you compile and run the below test case in an msdos or vfat directory on an x86-64 system with -m32 you'll get garbage in the kernel_dirent struct followed by a SIGSEGV. The patch fixes this. Reported and initial fix by Bart Oldeman #include <sys/types.h> #include <sys/ioctl.h> #include <dirent.h> #include <stdio.h> #include <unistd.h> #include <fcntl.h> struct kernel_dirent { long d_ino; long d_off; unsigned short d_reclen; char d_name[256]; /* We must not include limits.h! */ }; #define VFAT_IOCTL_READDIR_BOTH _IOR('r', 1, struct kernel_dirent [2]) #define VFAT_IOCTL_READDIR_SHORT _IOR('r', 2, struct kernel_dirent [2]) int main(void) { int fd = open(".", O_RDONLY); struct kernel_dirent de[2]; while (1) { int i = ioctl(fd, VFAT_IOCTL_READDIR_BOTH, (long)de); if (i == -1) break; if (de[0].d_reclen == 0) break; printf("SFN: reclen=%2d off=%d ino=%d, %-12s", de[0].d_reclen, de[0].d_off, de[0].d_ino, de[0].d_name); if (de[1].d_reclen) printf("\tLFN: reclen=%2d off=%d ino=%d, %s", de[1].d_reclen, de[1].d_off, de[1].d_ino, de[1].d_name); printf("\n"); } return 0; } Signed-off-by: Bart Oldeman <bartoldeman@users.sourceforge.net> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] fat: change uses of f_{dentry,vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the fat filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] VFS: Make filldir_t and struct kstat deal in 64-bit inode numbersDavid Howells
These patches make the kernel pass 64-bit inode numbers internally when communicating to userspace, even on a 32-bit system. They are required because some filesystems have intrinsic 64-bit inode numbers: NFS3+ and XFS for example. The 64-bit inode numbers are then propagated to userspace automatically where the arch supports it. Problems have been seen with userspace (eg: ld.so) using the 64-bit inode number returned by stat64() or getdents64() to differentiate files, and failing because the 64-bit inode number space was compressed to 32-bits, and so overlaps occur. This patch: Make filldir_t take a 64-bit inode number and struct kstat carry a 64-bit inode number so that 64-bit inode numbers can be passed back to userspace. The stat functions then returns the full 64-bit inode number where available and where possible. If it is not possible to represent the inode number supplied by the filesystem in the field provided by userspace, then error EOVERFLOW will be issued. Similarly, the getdents/readdir functions now pass the full 64-bit inode number to userspace where possible, returning EOVERFLOW instead when a directory entry is encountered that can't be properly represented. Note that this means that some inodes will not be stat'able on a 32-bit system with old libraries where they were before - but it does mean that there will be no ambiguity over what a 32-bit inode number refers to. Note similarly that directory scans may be cut short with an error on a 32-bit system with old libraries where the scan would work before for the same reasons. It is judged unlikely that this situation will occur because modern glibc uses 64-bit capable versions of stat and getdents class functions exclusively, and that older systems are unlikely to encounter unrepresentable inode numbers anyway. [akpm: alpha build fix] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Move the msdos device ioctl compat stuff to the msdos driver ↵David Howells
[try #6] Move the msdos device ioctl compat stuff from fs/compat_ioctl.c to the msdos driver so that the msdos header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22It's UTF-8Alexey Dobriyan
Fix some comments to "UTF-8". Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-08[PATCH] fat: support ->direct_IO()OGAWA Hirofumi
This patch add to support of ->direct_IO() for mostly read. The user of this seems to want to use for streaming read. So, current direct I/O has limitation, it can only overwrite. (For write operation, mainly we need to handle the hole etc..) Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] fat: s/EXPORT_SYMBOL/EXPORT_SYMBOL_GPL/OGAWA Hirofumi
All EXPORT_SYMBOL of fatfs is only for vfat/msdos. _GPL would be proper. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] fat: use sb_find_get_block() instead of sb_getblk()OGAWA Hirofumi
We don't need to allocate buffer for checking the buffer is uptodate. This use sb_find_get_block() instead, and if it returns NULL it's not uptodate. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] fat: Remove duplicate directory scanning codePekka Enberg
This patch removes duplicate directory scanning code from fs/fat/dir.c. The two functions that share identical code are fat_readdirx() and fat_search_long(). This patch also renames fat_readdirx to __fat_readdir(). Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] fat: cleanup and optimization of checksumOGAWA Hirofumi
2005-09-07[PATCH] Speedup FAT filesystem directory readsKarsten Wiese
OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> This speeds up directory reads for large FAT partitions, if the buffercache has to be filled from the drive. Following values were taken from: $ time find path_to_freshly_mounted_fat > /dev/null on an otherwise idle system. FAT with 16KB Clusters on IDE attached drive: Factor 2 FAT with 32KB Clusters on USB2 attached drive: Factor 10 (!) Its less than 1/10 slower, if the buffercache is uptodate. The patch introduces the new function fat_dir_readahead(). fat_dir_readahead() calls sb_breadahead() to readahead a whole cluster, if the requested sector is the first one in a cluster. It is usefull to do this, because on FAT directories occupy whole clusters, with the exception of FAT12/FAT16 root dirs. Readahead is only done, if the cluster's first sector is not uptodate to avoid overhead, when the buffer cache is already uptodate. Note that under memory pressure, the maximal byte count wasted (read: has to be red from disk twice) is 1 cluster's size. Thats 64KB. fat_dir_readahead() is called from fat__get_entry(). There is also an unrelated cleanup at one spot: if (bh) brelse(bh); is replaced with: brelse(bh); brelse() can handle NULL pointer arguments by itself. Signed-off-by: Karsten Wiese <annabellesgarden@yahoo.de> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
