Signed-off-by: Brian Swetland <swetland@google.com>
Btrfs needs to be able to control how filemap_write_and_wait_range() is called
in fsync to make it less of a painful operation, so push down taking i_mutex and
the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some
file systems can drop taking the i_mutex altogether it seems, like ext3 and
ocfs2. For correctness sake I just pushed everything down in all cases to make
sure that we keep the current behavior the same for everybody, and then each
individual fs maintainer can make up their mind about what to do from there.
Thanks,
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Josef Bacik <josef@redhat.com>
Add a new rw_semaphore to protect bmap against truncate. Previous
i_alloc_sem was abused for this, but it's going away in this series.
Note that we can't simply use i_mutex, given that the swapon code
calls ->bmap under it.
Add fat_msg() to replace not cosequent used printk() in fs/fat/*
New message format should be as fallow:
FAT-fs (sda1): some thing happened.
Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
- convert fat_fs_error to use %pV
- be consequent and use "supor_block *sb" instead of "supor_block *s"
- use devise name in each message.
don't bother with lock_super() in fat_fill_super() callers, while
we are at it - there won't be any concurrency anyway.
Make sure we check the truncate constraints early on in ->setattr by adding
those checks to inode_change_ok. Also clean up and document inode_change_ok
to make this obvious.
As a fallout we don't have to call inode_newsize_ok from simple_setsize and
simplify it down to a truncate_setsize which doesn't return an error. This
simplifies a lot of setattr implementations and means we use truncate_setsize
almost everywhere. Get rid of fat_setsize now that it's trivial and mark
ext2_setsize static to make the calling convention obvious.
Keep the inode_newsize_ok in vmtruncate for now as all callers need an
audit for its removal anyway.
Note: setattr code in ecryptfs doesn't call inode_change_ok at all and
needs a deeper audit, but that is left for later.
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Signed-off-by: Nick Piggin <npiggin@suse.de>
FAT does not require the BKL in its ioctl function, which is already serialized
through a mutex. Since we're already touching the ioctl code, also fix the
missing handling of FAT_IOCTL_GET_ATTRIBUTES in the compat code.
Currently shipping discard capable SSDs and arrays have rather sub-optimal
implementations of the command and can the use of it can cause massive
slowdowns. Make issueing these commands option as it's already in btrfs
and gfs2.
[hirofumi@mail.parknet.co.jp: tweaks, and add "discard" to fat_show_options]
If we didn't check sb->s_dirt, it will update the FSINFO
unconditionally. It will reduce the filetime of flash base device.
So, this checks sb->s_dirt. sb->s_dirt is racy, however FSINFO is just
hint. So even if there is race, and we hit it, it would not become big
problem.
And this also is as workaround of suspend problem.
* git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6:
fat: split fat_generic_ioctl
FAT: add 'errors' mount option
* mark directory data blocks as assoc. metadata
* add new inode to deal with FAT, mark FAT blocks as assoc. metadata of that
* now ->fsync() is trivial both for files and directories
On severe errors FAT remounts itself in read-only mode. Allow to
specify FAT fs desired behavior through 'errors' mount option:
panic, continue or remount read-only.
`mount -t [fat|vfat] -o errors=[panic,remount-ro,continue] \
<bdev> <mount point>`
This is analog to ext2 fs 'errors' mount option.
Signed-off-by: Denis Karpov <ext-denis.2.karpov@nokia.com>
blkcnt_t type depends on CONFIG_LSF. Use unsigned long long always for
printk(). But lazy to type it, so add "llu" and use it.
mmu_private is 64bits value, hence it's not atomic to update.
So, the access rule for mmu_private is we must hold ->i_mutex. But,
fat_get_block() path doesn't follow the rule on non-allocation path.
This fixes by using i_size instead if non-allocation path.
FAT has the ATTR_RO (read-only) attribute. But on Windows, the ATTR_RO
of the directory will be just ignored actually, and is used by only
applications as flag. E.g. it's setted for the customized folder by
Explorer.
http://msdn2.microsoft.com/en-us/library/aa969337.aspx
This adds "rodir" option. If user specified it, ATTR_RO is used as
read-only flag even if it's the directory. Otherwise, inode->i_mode
is not used to hold ATTR_RO (i.e. fat_mode_can_save_ro() returns 0).
If inode->i_mode doesn't have S_WUGO, current code assumes it means
ATTR_RO. However, if (~[ufd]mask & S_WUGO) == 0, inode->i_mode can't
hold S_WUGO. Therefore the updated directory entry will always have
ATTR_RO.
This adds fat_mode_can_hold_ro() to check it. And if inode->i_mode
can't hold, uses -i_attrs to hold ATTR_RO instead.
With this, we don't set ATTR_RO unless users change it via ioctl() if
(~[ufd]mask & S_WUGO) == 0.
And on FAT_IOCTL_GET_ATTRIBUTES path, this adds ->i_mutex to it for
not returning the partially updated attributes by FAT_IOCTL_SET_ATTRIBUTES
to userland.
This adds three helpers:
fat_make_attrs() - makes FAT attributes from inode.
fat_make_mode() - makes mode_t from FAT attributes.
fat_save_attrs() - saves FAT attributes to inode.
Then this replaces: MSDOS_MKMODE() by fat_make_mode(), fat_attr() by
fat_make_attrs(), ->i_attrs = attr & ATTR_UNUSED by fat_save_attrs().
And for root inode, those is used with ATTR_DIR instead of bogus
ATTR_NONE.
fat_hash() is using the algorithm known as bad. Instead of it, this
uses hash_32(). The following is the summary of test.
old hash:
hash func (1000 times): 33489 cycles
total inodes in hash table: 70926
largest bucket contains: 696
smallest bucket contains: 54
new hash:
hash func (1000 times): 33129 cycles
largest bucket contains: 315
smallest bucket contains: 236
This cleans date_dos2unix()/fat_date_unix2dos() up. New code should be
much more readable.
And this fixes those old functions. Those doesn't handle 2100
correctly. 2100 isn't leap year, but old one handles it as leap year.
Also, with this, centi sec is handled and is fixed.
This splits __KERNEL__ stuff in include/msdos_fs.h into fs/fat/fat.h.
