Signed-off-by: Brian Swetland <swetland@google.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6:
fat: fat16 support maximum 4GB file/vol size as WinXP or 7.
fat: fix utf8 iocharset warning message
fat: fix build warning
FAT16 support maximum 4GB vol/file size with 64KB cluster size.
Win NT/XP/7 increased the maximum cluster size to 64KB, and file/vol
size increased 4GB also. Although increasing, the file size of linux
FAT is still limited at 2GB.
I found that it is limited by sb->maxbytes(0x7fffffff) when partition
is formatted by FAT16. sb->s_maxbytes in fill_super should be set to
0xffffffff like fat32.
Signed-off-by: Namjae Jeon <linkinjeon@gmail.com>
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
The fat_msg function already formats the given message and appends
a newline to it - we don't need to do this in the passed message
string as well, or will end up with a blank line printed in the
kernel log ring buffer.
Also change the loglevel from error to warning.
Signed-off-by: Mihai Moldovan <ionic@ionic.de>
Simple filesystems always pass inode->i_sb_bdev as the block device
argument, and never need a end_io handler. Let's simply things for
them and for my grepping activity by dropping these arguments. The
only thing not falling into that scheme is ext4, which passes and
end_io handler without needing special flags (yet), but given how
messy the direct I/O code there is use of __blockdev_direct_IO
in one instead of two out of three cases isn't going to make a large
difference anyway.
Add a new rw_semaphore to protect bmap against truncate. Previous
i_alloc_sem was abused for this, but it's going away in this series.
Note that we can't simply use i_mutex, given that the swapon code
calls ->bmap under it.
pathconf(, _PC_NAME_MAX) is too small for long Unicode filename on fat.
255 as max filename size on fat is Unicode UTF-16 characters.
it's not byte size.
https://bugzilla.kernel.org/show_bug.cgi?id=16469
To fix it, this returns "len * NLS_MAX_CHARSET_SIZE" instead.
Reported-by: Takumi Asaki <takumi.asaki@nokia.com>
Replace all printk with fat_msg()
Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net>
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits)
Documentation/iostats.txt: bit-size reference etc.
cfq-iosched: removing unnecessary think time checking
cfq-iosched: Don't clear queue stats when preempt.
blk-throttle: Reset group slice when limits are changed
blk-cgroup: Only give unaccounted_time under debug
cfq-iosched: Don't set active queue in preempt
block: fix non-atomic access to genhd inflight structures
block: attempt to merge with existing requests on plug flush
block: NULL dereference on error path in __blkdev_get()
cfq-iosched: Don't update group weights when on service tree
fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away
block: Require subsystems to explicitly allocate bio_set integrity mempool
jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
fs: make fsync_buffers_list() plug
mm: make generic_writepages() use plugging
blk-cgroup: Add unaccounted time to timeslice_used.
block: fixup plugging stubs for !CONFIG_BLOCK
block: remove obsolete comments for blkdev_issue_zeroout.
blktrace: Use rq->cmd_flags directly in blk_add_trace_rq.
Fix up conflicts in fs/{aio.c,super.c}
The exportfs encode handle function should return the minimum required
handle size. This helps user to find out the handle size by passing 0
handle size in the first step and then redoing to the call again with
the returned handle size value.
Acked-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
don't bother with lock_super() in fat_fill_super() callers, while
we are at it - there won't be any concurrency anyway.
Reduce some branches and memory accesses in dcache lookup by adding dentry
flags to indicate common d_ops are set, rather than having to check them.
This saves a pointer memory access (dentry->d_op) in common path lookup
situations, and saves another pointer load and branch in cases where we
have d_op but not the particular operation.
Patched with:
git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
RCU free the struct inode. This will allow:
- Subsequent store-free path walking patch. The inode must be consulted for
permissions when walking, so an RCU inode reference is a must.
- sb_inode_list_lock to be moved inside i_lock because sb list walkers who want
to take i_lock no longer need to take sb_inode_list_lock to walk the list in
the first place. This will simplify and optimize locking.
- Could remove some nested trylock loops in dcache code
- Could potentially simplify things a bit in VM land. Do not need to take the
page lock to follow page->mapping.
The downsides of this is the performance cost of using RCU. In a simple
creat/unlink microbenchmark, performance drops by about 10% due to inability to
reuse cache-hot slab objects. As iterations increase and RCU freeing starts
kicking over, this increases to about 20%.
In cases where inode lifetimes are longer (ie. many inodes may be allocated
during the average life span of a single inode), a lot of this cache reuse is
not applicable, so the regression caused by this patch is smaller.
The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU,
however this adds some complexity to list walking and store-free path walking,
so I prefer to implement this at a later date, if it is shown to be a win in
real situations. I haven't found a regression in any non-micro benchmark so I
doubt it will be a problem.
The lock_kernel in fat_put_super is not needed because
it only protects the super block itself and we know that
no other thread can reach it because we are about to
kfree the object.
In the two fill_super functions, this converts the locking
to use lock_super like elsewhere in the fat code. This
is probably not needed either, but is consistent and puts
us on the safe side.
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Jan Blunck <jblunck@infradead.org>
Move the call to vmtruncate to get rid of accessive blocks to the callers
in preparation of the new truncate sequence and rename the non-truncating
version to cont_write_begin.
in prepearation of the new truncate calling sequence. This was only done
for DIO_LOCKING filesystems, so the __blockdev_direct_IO_newtrunc variant
was not needed anyway. Get rid of blockdev_direct_IO_no_locking and
its _newtrunc variant while at it as just opencoding the two additional
paramters is shorted than the name suffix.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Other users doesn't check NULL explicitly. So, these doesn't also
check to remove inconsistency.
fat: Fix stat->f_namelen
fat: Fix vfat_lookup()
This gives the filesystem more information about the writeback that
is happening. Trond requested this for the NFS unstable write handling,
and other filesystems might benefit from this too by beeing able to
distinguish between the different callers in more detail.
I found that the length of a file name when created cannot exceed 255
characters, yet, pathconf(), via statfs(), returns the maximum as 260.
Signed-off-by: Kevin Dankwardt <k@kcomputing.com>
Currently shipping discard capable SSDs and arrays have rather sub-optimal
implementations of the command and can the use of it can cause massive
slowdowns. Make issueing these commands option as it's already in btrfs
and gfs2.
[hirofumi@mail.parknet.co.jp: tweaks, and add "discard" to fat_show_options]
fat: Check s_dirt in fat_sync_fs()
vfat: change the default from shortname=lower to shortname=mixed
fat/nls: Fix handling of utf8 invalid char
Most call sites of unload_nls() do:
if (nls)
unload_nls(nls);
Check the pointer inside unload_nls() like we do in kfree() and
simplify the call sites.
Cc: Steve French <sfrench@us.ibm.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Cc: Petr Vandrovec <vandrove@vc.cvut.cz>
Cc: Anton Altaparmakov <aia21@cantab.net>
If we didn't check sb->s_dirt, it will update the FSINFO
unconditionally. It will reduce the filetime of flash base device.
So, this checks sb->s_dirt. sb->s_dirt is racy, however FSINFO is just
hint. So even if there is race, and we hit it, it would not become big
problem.
And this also is as workaround of suspend problem.
Because, with "shortname=lower", copying one FAT filesystem tree to
another FAT filesystem tree using Linux results in semantically
different filesystems. (E.g.: Filenames which were once "all
uppercase" are now "all lowercase").
So, this changes the default of "shortname=lower" to "shortname=mixed".
Signed-off-by: Paul Wise <pabs3@bonedaddy.net>
[change fat_show_options()]
(ce3b0f8d5c2203301fc87f3aaaed73e5819e2a48: New helper - current_umask())
is removing the opts->fs_dmask, probably it's a cut-and-paste
miss or something.
fat: split fat_generic_ioctl
FAT: add 'errors' mount option
Add a ->sync_fs method for data integrity syncs.
* mark directory data blocks as assoc. metadata
* add new inode to deal with FAT, mark FAT blocks as assoc. metadata of that
* now ->fsync() is trivial both for files and directories
Push down lock_super into ->write_super instances and remove it from the
caller.
Following filesystem don't need ->s_lock in ->write_super and are skipped:
* bfs, nilfs2 - no other uses of s_lock and have internal locks in
->write_super
* ext2 - uses BKL in ext2_write_super and has internal calls without s_lock
* reiserfs - no other uses of s_lock as has reiserfs_write_lock (BKL) in
->write_super
* xfs - no other uses of s_lock and uses internal lock (buffer lock on
superblock buffer) to serialize ->write_super. Also xfs_fs_write_super
is superflous and will go away in the next merge window
Move BKL into ->put_super from the only caller. A couple of
filesystems had trivial enough ->put_super (only kfree and NULLing of
s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs,
hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most
of them probably don't need it, but I'd rather sort that out individually.
Preferably after all the other BKL pushdowns in that area.
[AV: original used to move lock_super() down as well; these changes are
removed since we don't do lock_super() at all in generic_shutdown_super()
now]
[AV: fuse, btrfs and xfs are known to need no damn BKL, exempt]
We just did a full fs writeout using sync_filesystem before, and if
that's not enough for the filesystem it can perform it's own writeout
in ->put_super, which many filesystems already do.
Move a call to foofs_write_super into every foofs_put_super for now to
guarantee identical behaviour until it's cleaned up by the individual
filesystem maintainers.
Exceptions:
- affs already has identical copy & pasted code at the beginning of
affs_put_super so no need to do it twice.
- xfs does the right thing without it and I have changes pending for
the xfs tree touching this are so I don't really need conflicts
here..
On severe errors FAT remounts itself in read-only mode. Allow to
specify FAT fs desired behavior through 'errors' mount option:
panic, continue or remount read-only.
`mount -t [fat|vfat] -o errors=[panic,remount-ro,continue] \
<bdev> <mount point>`
This is analog to ext2 fs 'errors' mount option.
Signed-off-by: Denis Karpov <ext-denis.2.karpov@nokia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
Remove two unneeded exports and make two symbols static in fs/mpage.c
Cleanup after commit 585d3bc06f4ca57f975a5a1f698f65a45ea66225
Trim includes of fdtable.h
Don't crap into descriptor table in binfmt_som
Trim includes in binfmt_elf
Don't mess with descriptor table in load_elf_binary()
Get rid of indirect include of fs_struct.h
check_unsafe_exec() doesn't care about signal handlers sharing
New locking/refcounting for fs_struct
Take fs_struct handling to new file (fs/fs_struct.c)
Get rid of bumping fs_struct refcount in pivot_root(2)
Kill unsharing fs_struct in __set_personality()
Make fat return f_fsid info for statfs(2).
Signed-off-by: Coly Li <coly.li@suse.de>
Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
current->fs->umask is what most of fs_struct users are doing.
Put that into a helper function.
On swapon() path, it has already i_mutex. So, this uses i_alloc_sem
instead of it.
Reported-by: Laurent GUERBY <laurent@guerby.net>
fat: make sure to set d_ops in fat_get_parent
fat: fix duplicate addition of ->llseek handler
fat: drop negative dentry on rename() path
security/keys/internal.h
security/keys/process_keys.c
security/keys/request_key.c
Fixed conflicts above by using the non 'tsk' versions.
Signed-off-by: James Morris <jmorris@namei.org>
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Reviewed-by: James Morris <jmorris@namei.org>
fat_get_parent needs to setup the dentry operations, otherwise we might
lose them when the NFS server needs to reconnect out of cache inodes.
i_pos is 64bits value, hence it's not atomic to update.
Important place is fat_write_inode() only, other places without lock
are just for printk().
This adds lock for "BITS_PER_LONG == 32" kernel.
mmu_private is 64bits value, hence it's not atomic to update.
So, the access rule for mmu_private is we must hold ->i_mutex. But,
fat_get_block() path doesn't follow the rule on non-allocation path.
This fixes by using i_size instead if non-allocation path.
fat_get_cluster() assumes the requested blocknr isn't truncated during
read. _fat_bmap() doesn't follow this rule.
This protects it by ->i_mutex.
FAT has the ATTR_RO (read-only) attribute. But on Windows, the ATTR_RO
of the directory will be just ignored actually, and is used by only
applications as flag. E.g. it's setted for the customized folder by
Explorer.
http://msdn2.microsoft.com/en-us/library/aa969337.aspx
This adds "rodir" option. If user specified it, ATTR_RO is used as
read-only flag even if it's the directory. Otherwise, inode->i_mode
is not used to hold ATTR_RO (i.e. fat_mode_can_save_ro() returns 0).
