path: root/fs/fat
2011-11-30FAT: Add new ioctl VFAT_IOCTL_GET_VOLUME_ID for reading the volume ID.Mike Lockwood
Signed-off-by: Brian Swetland <swetland@google.com>
2011-08-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6: fat: fat16 support maximum 4GB file/vol size as WinXP or 7. fat: fix utf8 iocharset warning message fat: fix build warning
2011-08-17fat: fat16 support maximum 4GB file/vol size as WinXP or 7.Namjae Jeon
FAT16 support maximum 4GB vol/file size with 64KB cluster size. Win NT/XP/7 increased the maximum cluster size to 64KB, and file/vol size increased 4GB also. Although increasing, the file size of linux FAT is still limited at 2GB. I found that it is limited by sb->maxbytes(0x7fffffff) when partition is formatted by FAT16. sb->s_maxbytes in fill_super should be set to 0xffffffff like fat32. Signed-off-by: Namjae Jeon <linkinjeon@gmail.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-08-17fat: fix utf8 iocharset warning messageMihai Moldovan
The fat_msg function already formats the given message and appends a newline to it - we don't need to do this in the passed message string as well, or will end up with a blank line printed in the kernel log ring buffer. Also change the loglevel from error to warning. Signed-off-by: Mihai Moldovan <ionic@ionic.de> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-08-17fat: fix build warningJonas Aberg
This fixes a compile warning (unititialized variable) in the fat filesystem code. Signed-off-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: simplify the blockdev_direct_IO prototypeChristoph Hellwig
Simple filesystems always pass inode->i_sb_bdev as the block device argument, and never need a end_io handler. Let's simply things for them and for my grepping activity by dropping these arguments. The only thing not falling into that scheme is ext4, which passes and end_io handler without needing special flags (yet), but given how messy the direct I/O code there is use of __blockdev_direct_IO in one instead of two out of three cases isn't going to make a large difference anyway. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: move inode_dio_wait calls into ->setattrChristoph Hellwig
Let filesystems handle waiting for direct I/O requests themselves instead of doing it beforehand. This means filesystem-specific locks to prevent new dio referenes from appearing can be held. This is important to allow generalizing i_dio_count to non-DIO_LOCKING filesystems. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fat: remove i_alloc_sem abuseChristoph Hellwig
Add a new rw_semaphore to protect bmap against truncate. Previous i_alloc_sem was abused for this, but it's going away in this series. Note that we can't simply use i_mutex, given that the swapon code calls ->bmap under it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20make d_splice_alias(ERR_PTR(err), dentry) = ERR_PTR(err)Al Viro
... and simplify the living hell out of callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20LOOKUP_CREATE and LOOKUP_RENAME_TARGET can be set only on the last stepAl Viro
2011-05-31fat: Fix corrupt inode flags when remove ATTR_SYS flagOGAWA Hirofumi
We are clearly missing '~' in fat_ioctl_set_attributes(). Cc: <stable@kernel.org> Reported-by: Dmitry Dmitriev <dimondmm@yandex.ru> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-05-28fat: remove unnecessary dentry_unhash on rmdir, dir renameSage Weil
fat does not have problems with references to unlinked directories. CC: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (25 commits) cifs: remove unnecessary dentry_unhash on rmdir/rename_dir ocfs2: remove unnecessary dentry_unhash on rmdir/rename_dir exofs: remove unnecessary dentry_unhash on rmdir/rename_dir nfs: remove unnecessary dentry_unhash on rmdir/rename_dir ext2: remove unnecessary dentry_unhash on rmdir/rename_dir ext3: remove unnecessary dentry_unhash on rmdir/rename_dir ext4: remove unnecessary dentry_unhash on rmdir/rename_dir btrfs: remove unnecessary dentry_unhash in rmdir/rename_dir ceph: remove unnecessary dentry_unhash calls vfs: clean up vfs_rename_other vfs: clean up vfs_rename_dir vfs: clean up vfs_rmdir vfs: fix vfs_rename_dir for FS_RENAME_DOES_D_MOVE filesystems libfs: drop unneeded dentry_unhash vfs: update dentry_unhash() comment vfs: push dentry_unhash on rename_dir into file systems vfs: push dentry_unhash on rmdir into file systems vfs: remove dget() from dentry_unhash() vfs: dentry_unhash immediately prior to rmdir vfs: Block mmapped writes while the fs is frozen ...
2011-05-26vfs: push dentry_unhash on rename_dir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each rename method (except gfs2 and xfs) so that it can be dealt with on a per-fs basis. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rmdir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs basis. This does not change behavior for any in-tree file systems. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-04-12fat: Fix statfs->f_namelenOGAWA Hirofumi
pathconf(, _PC_NAME_MAX) is too small for long Unicode filename on fat. 255 as max filename size on fat is Unicode UTF-16 characters. it's not byte size. https://bugzilla.kernel.org/show_bug.cgi?id=16469 To fix it, this returns "len * NLS_MAX_CHARSET_SIZE" instead. Reported-by: Takumi Asaki <takumi.asaki@nokia.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-04-12fat: Replace all printk with fat_msg()Alexey Fisher
Replace all printk with fat_msg() Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-04-12fat: Add fat_msg() function for preformated FAT messagesAlexey Fisher
Add fat_msg() to replace not cosequent used printk() in fs/fat/* New message format should be as fallow: FAT-fs (sda1): some thing happened. Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-04-12fat: Convert fat_fs_error to use %pVAlexey Fisher
- convert fat_fs_error to use %pV - be consequent and use "supor_block *sb" instead of "supor_block *s" - use devise name in each message. Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-04-12fat: Fix possible null deref in fat_cache_add()OGAWA Hirofumi
Reported-by: <dame_eugene@mail.ru> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2011-04-12fat: use new setup() for ->dir_ops tooOGAWA Hirofumi
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-14exportfs: Return the minimum required handle sizeAneesh Kumar K.V
The exportfs encode handle function should return the minimum required handle size. This helps user to find out the handle size by passing 0 handle size in the first step and then redoing to the call again with the returned handle size value. Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10fat: fix d_revalidate oopsen on NFS exportsAl Viro
can't blindly check nd->flags in ->d_revalidate() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-12switch fat to ->s_d_op, close exportfs races thereAl Viro
don't bother with lock_super() in fat_fill_super() callers, while we are at it - there won't be any concurrency anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-07fs: rcu-walk aware d_revalidate methodNick Piggin
Require filesystems be aware of .d_revalidate being called in rcu-walk mode (nd->flags & LOOKUP_RCU). For now do a simple push down, returning -ECHILD from all implementations. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_hash for rcu-walkNick Piggin
Change d_hash so it may be called from lock-free RCU lookups. See similar patch for d_compare for details. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_compare for rcu-walkNick Piggin
Change d_compare so it may be called from lock-free RCU lookups. This does put significant restrictions on what may be done from the callback, however there don't seem to have been any problems with in-tree fses. If some strange use case pops up that _really_ cannot cope with the rcu-walk rules, we can just add new rcu-unaware callbacks, which would cause name lookup to drop out of rcu-walk mode. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-22Merge branch 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits) xen-blkfront: disable barrier/flush write support Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c block: remove BLKDEV_IFL_WAIT aic7xxx_old: removed unused 'req' variable block: remove the BH_Eopnotsupp flag block: remove the BLKDEV_IFL_BARRIER flag block: remove the WRITE_BARRIER flag swap: do not send discards as barriers fat: do not send discards as barriers ext4: do not send discards as barriers jbd2: replace barriers with explicit flush / FUA usage jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier jbd: replace barriers with explicit flush / FUA usage nilfs2: replace barriers with explicit flush / FUA usage reiserfs: replace barriers with explicit flush / FUA usage gfs2: replace barriers with explicit flush / FUA usage btrfs: replace barriers with explicit flush / FUA usage xfs: replace barriers with explicit flush / FUA usage block: pass gfp_mask and flags to sb_issue_discard dm: convey that all flushes are processed as empty ...
2010-10-04BKL: Remove BKL from fatArnd Bergmann
The lock_kernel in fat_put_super is not needed because it only protects the super block itself and we know that no other thread can reach it because we are about to kfree the object. In the two fill_super functions, this converts the locking to use lock_super like elsewhere in the fat code. This is probably not needed either, but is consistent and puts us on the safe side. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Jan Blunck <jblunck@infradead.org>
2010-10-04BKL: Explicitly add BKL around get_sb/fill_superJan Blunck
This patch is a preparation necessary to remove the BKL from do_new_mount(). It explicitly adds calls to lock_kernel()/unlock_kernel() around get_sb/fill_super operations for filesystems that still uses the BKL. I've read through all the code formerly covered by the BKL inside do_kern_mount() and have satisfied myself that it doesn't need the BKL any more. do_kern_mount() is already called without the BKL when mounting the rootfs and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called from various places without BKL: simple_pin_fs(), nfs_do_clone_mount() through nfs_follow_mountpoint(), afs_mntpt_do_automount() through afs_mntpt_follow_link(). Both later functions are actually the filesystems follow_link inode operation. vfs_kern_mount() is calling the specified get_sb function and lets the filesystem do its job by calling the given fill_super function. Therefore I think it is safe to push down the BKL from the VFS to the low-level filesystems get_sb/fill_super operation. [arnd: do not add the BKL to those file systems that already don't use it elsewhere] Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Christoph Hellwig <hch@infradead.org>
2010-09-16block: remove BLKDEV_IFL_WAITChristoph Hellwig
All the blkdev_issue_* helpers can only sanely be used for synchronous caller. To issue cache flushes or barriers asynchronously the caller needs to set up a bio by itself with a completion callback to move the asynchronous state machine ahead. So drop the BLKDEV_IFL_WAIT flag that is always specified when calling blkdev_issue_* and also remove the now unused flags argument to blkdev_issue_flush and blkdev_issue_zeroout. For blkdev_issue_discard we need to keep it for the secure discard flag, which gains a more descriptive name and loses the bitops vs flag confusion. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: remove the BH_Eopnotsupp flagChristoph Hellwig
This flag was only set for barrier buffers, which we don't submit anymore. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10fat: do not send discards as barriersChristoph Hellwig
fat already uses synchronous discards, no need to add I/O barriers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10block: pass gfp_mask and flags to sb_issue_discardChristoph Hellwig
We'll need to get rid of the BLKDEV_IFL_BARRIER flag, and to facilitate that and to make the interface less confusing pass all flags explicitly. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-18remove SWRITE* I/O typesChristoph Hellwig
These flags aren't real I/O types, but tell ll_rw_block to always lock the buffer instead of giving up on a failed trylock. Instead add a new write_dirty_buffer helper that implements this semantic and use it from the existing SWRITE* callers. Note that the ll_rw_block code had a bug where it didn't promote WRITE_SYNC_PLUG properly, which this patch fixes. In the ufs code clean up the helper that used to call ll_rw_block to mirror sync_dirty_buffer, which is the function it implements for compound buffers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09covert fatfs to ->evict_inode()Al Viro
2010-08-09check ATTR_SIZE contraints in inode_change_okChristoph Hellwig
Make sure we check the truncate constraints early on in ->setattr by adding those checks to inode_change_ok. Also clean up and document inode_change_ok to make this obvious. As a fallout we don't have to call inode_newsize_ok from simple_setsize and simplify it down to a truncate_setsize which doesn't return an error. This simplifies a lot of setattr implementations and means we use truncate_setsize almost everywhere. Get rid of fat_setsize now that it's trivial and mark ext2_setsize static to make the calling convention obvious. Keep the inode_newsize_ok in vmtruncate for now as all callers need an audit for its removal anyway. Note: setattr code in ecryptfs doesn't call inode_change_ok at all and needs a deeper audit, but that is left for later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09always call inode_change_ok early in ->setattrChristoph Hellwig
Make sure we call inode_change_ok before doing any changes in ->setattr, and make sure to call it even if our fs wants to ignore normal UNIX permissions, but use the ATTR_FORCE to skip those. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09rename generic_setattrChristoph Hellwig
Despite its name it's now a generic implementation of ->setattr, but rather a helper to copy attributes from a struct iattr to the inode. Rename it to setattr_copy to reflect this fact. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09get rid of cont_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in preparation of the new truncate sequence and rename the non-truncating version to cont_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09sort out blockdev_direct_IO variantsChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in prepearation of the new truncate calling sequence. This was only done for DIO_LOCKING filesystems, so the __blockdev_direct_IO_newtrunc variant was not needed anyway. Get rid of blockdev_direct_IO_no_locking and its _newtrunc variant while at it as just opencoding the two additional paramters is shorted than the name suffix. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27fat: convert to use the new truncate convention.npiggin@suse.de
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
