path: root/fs/fat
2013-10-24fat: rcu-delay unloading nls and freeing sbiAl Viro
makes ->d_hash() and ->d_compare() safety in RCU mode independent from vfsmount_lock. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-09-12truncate: drop 'oldsize' truncate_pagecache() parameterKirill A. Shutemov
truncate_pagecache() doesn't care about old size since commit cedabed49b39 ("vfs: Fix vmtruncate() regression"). Let's drop it. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-09fatfs: add FAT_IOCTL_GET_VOLUME_IDMike Lockwood
This patch, originally from Android kernel, adds vfat ioctl command FAT_IOCTL_GET_VOLUME_ID, with this command we can get the vfat volume ID using following code: ioctl(fd, FAT_IOCTL_GET_VOLUME_ID, &volume_ID) This patch is a modified version of the patch by Mike Lockwood, with changes from Dmitry Pervushin, who noticed the original patch makes some volume IDs abiguous with error returns: for example, if volume id is 0xFFFFFDAD, that matches -ENOIOCTLCMD, we get "FFFFFFFF" from the user space. So add a parameter to ioctl to get the correct volume ID. Android uses vfat volume ID to identify different sd card, when a new sd card is inserted to device, android can scan the media on it and pop up new contents. Signed-off-by: Bintian Wang <bintian.wang@linaro.org> Cc: dmitry pervushin <dpervushin@gmail.com> Cc: Mike Lockwood <lockwood@android.com> Cc: Colin Cross <ccross@android.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: John Stultz <john.stultz@linaro.org> Cc: Sean McNeil <sean@mcneil.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03fs/fat: use fat_msg() to replace printk() in __fat_fs_error()Gu Zheng
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-29Don't pass inode to ->d_hash() and ->d_compare()Linus Torvalds
Instances either don't look at it at all (the majority of cases) or only want it to find the superblock (which can be had as dentry->d_sb). A few cases that want more are actually safe with dentry->d_inode - the only precaution needed is the check that it hadn't been replaced with NULL by rmdir() or by overwriting rename(), which case should be simply treated as cache miss. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-29[readdir] convert fatfsAl Viro
... pox upon the idiotic ioctls; life would be much easier without those. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-24fat: fix possible overflow for fat_clustersOGAWA Hirofumi
Intermediate value of fat_clusters can be overflowed on 32bits arch. Reported-by: Krzysztof Strasburger <strasbur@chkw386.ch.pwr.wroc.pl> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29fat (exportfs): rebuild directory-inode if fat_dget()Namjae Jeon
This patch enables rebuilding of directory inodes which are not present in the cache.This is done by traversing the disk clusters to find the directory entry of the parent directory and using its i_pos to build the inode. The traversal is done by fat_scan_logstart() which is similar to fat_scan() but matches i_pos values instead of names.fat_scan_logstart() needs an inode parameter to work, for which a dummy inode is created by it's caller fat_rebuild_parent(). This dummy inode is destroyed after the traversal completes. All this is done only if the nostale_ro nfs mount option is specified. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Ravishankar N <ravi.n1@samsung.com> Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29fat (exportfs): rebuild inode if ilookup() failsNamjae Jeon
If the cache lookups fail,use the i_pos value to find the directory entry of the inode and rebuild the inode.Since this involves accessing the FAT media, do this only if the nostale_ro nfs mount option is specified. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Ravishankar N <ravi.n1@samsung.com> Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29fat: restructure export_operationsNamjae Jeon
Define two nfs export_operation structures,one for 'stale_rw' mounts and the other for 'nostale_ro'. The latter uses i_pos as a basis for encoding and decoding file handles. Also, assign i_pos to kstat->ino. The logic for rebuilding the inode is added in the subsequent patches. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Ravishankar N <ravi.n1@samsung.com> Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29fat: introduce a helper fat_get_blknr_offset()Namjae Jeon
Introduce helper function to get the block number and offset for a given i_pos value. Use it in __fat_write_inode() now and later on in nfs.c Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Ravishankar N <ravi.n1@samsung.com> Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29fat: move fat_i_pos_read to fat.hNamjae Jeon
Move fat_i_pos_read to fat.h so that it can be called from nfs.c in the subsequent patches to encode the file handle. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Ravishankar N <ravi.n1@samsung.com> Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29fat: introduce 2 new values for the -o nfs mount optionNamjae Jeon
This patchset eliminates the client side ESTALE errors when a FAT partition exported over NFS has its dentries evicted from the cache. The idea is to find the on-disk location_'i_pos' of the dirent of the inode that has been evicted and use it to rebuild the inode. This patch: Provide two possible values 'stale_rw' and 'nostale_ro' for the -o nfs mount option.The first one allows all file operations but does not reduce ESTALE errors on memory constrained systems. The second one eliminates ESTALE errors but mounts the filesystem as read-only. Not specifying a value defaults to 'stale_rw'. Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com> Signed-off-by: Ravishankar N <ravi.n1@samsung.com> Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27fat: mark fs as dirty on mount and clean on umountOleksij Rempel
There is no documented methods to mark FAT as dirty. Unofficially MS started to use reserved Byte in boot sector for this purpose, at least since Win 2000. With Win 7 user is warned if fs is dirty and asked to clean it. Different versions of Win, handle it in different ways, but always have same meaning: - Win 2000 and XP, set it on write operations and remove it after operation was finnished - Win 7, set dirty flag on first write and remove it on umount. We will do it as follows: - set dirty flag on mount. If fs was initially dirty, warn user, remember it and do not do any changes to boot sector. - clean it on umount. If fs was initially dirty, leave it dirty. - do not do any thing if fs mounted read-only. - TODO: leave fs dirty if we found some error after mount. Signed-off-by: Oleksij Rempel <bug-track@fisher-privat.net> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27fat: add extended fileds to struct fat_boot_sectorOleksij Rempel
Later we will need "state" field to check if volume was cleanly unmounted. Signed-off-by: Oleksij Rempel <bug-track@fisher-privat.net> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-22new helper: file_inode(file)Al Viro
2012-12-20fat: fix incorrect function commentRavishankar N
fat_search_long() returns 0 on success, -ENOENT/ENOMEM on failure. Change the function comment accordingly. While at it, fix some trivial typos. Signed-off-by: Ravishankar N <cyberax82@gmail.com> Signed-off-by: Namjae Jeon <linkinjeon@gmail.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17fs/fat: strip "cp" prefix from codepage in displayDave Reisner
Option parsing code expects an unsigned integer for the codepage option, but prefixes and stores this option with "cp" before passing to load_nls(). This makes the displayed option in /proc an invalid one. Strip the prefix when printing so that the displayed option is valid for reuse. Signed-off-by: Dave Reisner <dreisner@archlinux.org> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17fat: ix mount option parsingJan Kara
parse_options() is supposed to return value < 0 on error however we returned 0 (success) in a lot of cases. This actually was not a problem in practice because match_token() used by parse_options() is clever and catches most of the problems for us. Signed-off-by: Jan Kara <jack@suse.cz> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17fat: provide option for setting timezone offsetJan Kara
So far FAT either offsets time stamps by sys_tz.minuteswest or leaves them as they are (when tz=UTC mount option is used). However in some cases it is useful if one can specify time stamp offset on his own (e.g. when time zone of the camera connected is different from time zone of the computer, or when HW clock is in UTC and thus sys_tz.minuteswest == 0). So provide a mount option time_offset= which allows user to specify offset in minutes that should be applied to time stamps on the filesystem. akpm: this code would work incorrectly when used via `mount -o remount', because cached inodes would not be updated. But fatfs's fat_remount() is basically a no-op anyway. Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17fat: notify when discard is not supportedNamjae Jeon
Change fatfs so that a warning is emitted when an attempt is made to mount a filesystem with the unsupported `discard' option. ext4 aready does this: http://patchwork.ozlabs.org/patch/192668/ Signed-off-by: Namjae Jeon <linkinjeon@gmail.com> Signed-off-by: Amit Sahrawat <amit.sahrawat83@gmail.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-09fat: drop lock/unlock superMarco Stornelli
Removed lock/unlock super. Added a new private s_lock mutex. Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-06fat: simplify writeback_inode()Namjae Jeon
[akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Namjae Jeon <linkinjeon@gmail.com> Signed-off-by: Amit Sahrawat <amit.sahrawat83@gmail.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06fat: no need to reset EOF in ent_put for FAT32Namjae Jeon
#define FAT_ENT_EOF(EOF_FAT32) there is no need to reset value of 'new' for FAT32 as the values is already correct Signed-off-by: Namjae Jeon <linkinjeon@gmail.com> Signed-off-by: Amit Sahrawat <amit.sahrawat83@gmail.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06fs/fat: fix checkpatch issues in fatent.cCruz Julian Bishop
1: Stop any lines going over 80 characters 2: Remove a blank line before EXPORT_SYMBOL_GPL Signed-off-by: Cruz Julian Bishop <cruzjbishop@gmail.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06fs/fat: fix all other checkpatch issues in dir.cCruz Julian Bishop
1: Import linux/uaccess.h instead of asm.uaccess.h 2: Stop any lines going over 80 characters 3: Stopped setting any variables in if statements 4: Stopped splitting quoted strings 5: Removed unneeded parentheses Signed-off-by: Cruz Julian Bishop <cruzjbishop@gmail.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06fs/fat: fix some small checkpatch issues in dir.cCruz Julian Bishop
Simply remove the spacing between function definitions and EXPORT_SYMBOL_GPL calls, which were previously generating warnings. Signed-off-by: Cruz Julian Bishop <cruzjbishop@gmail.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06fs/fat: fix two checkpatch issues in cache.cCruz Julian Bishop
This does the following: 1: Splits the arguments of a function call to stop it from exceeding 80 characters 2: Re-indents the arguments of another function call to prevent the splitting of a quoted string. Signed-off-by: Cruz Julian Bishop <cruzjbishop@gmail.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06fs/fat: chang indentation of some comments in fat.hCruz Julian Bishop
The comments were not lined up properly, so I just re-indented them. This also fixes a stupid checkpatch issue unknowingly Signed-off-by: Cruz Julian Bishop <cruzjbishop@gmail.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06fs/fat: fix some checkpatch issues in fat.hCruz Julian Bishop
Mainly fix spacing issues such as "foo * bar" and "foo= bar" Signed-off-by: Cruz Julian Bishop <cruzjbishop@gmail.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06fs/fat: fix a checkpatch issue in namei_msdos.cCruz Julian Bishop
Add a space before an equals sign/operator in line 410. Signed-off-by: Cruz Julian Bishop <cruzjbishop@gmail.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06fat (exportfs): fix dentry reconnectionSteven J. Magnani
Maintain an index of directory inodes by starting cluster, so that fat_get_parent() can return the proper cached inode rather than inventing one that cannot be traced back to the filesystem root. Add a new msdos/vfat binary mount option "nfs" so that FAT filesystems that are _not_ exported via NFS are not saddled with maintenance of an index they will never use. Finally, simplify NFS file handle generation and lookups. An ext2-congruent implementation is adequate for FAT needs. Signed-off-by: Steven J. Magnani <steve@digidescorp.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06fat (exportfs): move NFS support codeSteven J. Magnani
Under memory pressure, the system may evict dentries from cache. When the FAT driver receives a NFS request involving an evicted dentry, it is unable to reconnect it to the filesystem root. This causes the request to fail, often with ENOENT. This is partially due to ineffectiveness of the current FAT NFS implementation, and partially due to an unimplemented fh_to_parent method. The latter can cause file accesses to fail on shares exported with subtree_check. This patch set provides the FAT driver with the ability to reconnect dentries. NFS file handle generation and lookups are simplified and made congruent with ext2. Testing has involved a memory-starved virtual machine running 3.5-rc5 that exports a ~2 GB vfat filesystem containing a kernel tree (~770 MB, ~40000 files, 9 levels). Both 'cp -r' and 'ls -lR' operations were performed from a client, some overlapping, some consecutive. Exports with 'subtree_check' and 'no_subtree_check' have been tested. Note that while this patch set improves FAT's NFS support, it does not eliminate ESTALE errors completely. The following should be considered for NFS clients who are sensitive to ESTALE: * Mounting with lookupcache=none Unfortunately this can degrade performance severely, particularly for deep filesystems. * Incorporating VFS patches to retry ESTALE failures on the client-side, such as https://lkml.org/lkml/2012/6/29/381 * Handling ESTALE errors in client application code This patch: Move NFS-related code into its own C file. No functional changes. Signed-off-by: Steven J. Magnani <steve@digidescorp.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06fat: use accessor function for msdos_dir_entry 'start'Namjae Jeon
Use accessor function for msdos_dir_entry 'start' Signed-off-by: Namjae Jeon <linkinjeon@gmail.com> Signed-off-by: Amit Sahrawat <amit.sahrawat83@gmail.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-10-02fs: push rcu_barrier() from deactivate_locked_super() to filesystemsKirill A. Shutemov
There's no reason to call rcu_barrier() on every deactivate_locked_super(). We only need to make sure that all delayed rcu free inodes are flushed before we destroy related cache. Removing rcu_barrier() from deactivate_locked_super() affects some fast paths. E.g. on my machine exit_group() of a last process in IPC namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-20userns: Convert fat to use kuid/kgid where appropriateEric W. Biederman
Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-08-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull second vfs pile from Al Viro: "The stuff in there: fsfreeze deadlock fixes by Jan (essentially, the deadlock reproduced by xfstests 068), symlink and hardlink restriction patches, plus assorted cleanups and fixes. Note that another fsfreeze deadlock (emergency thaw one) is *not* dealt with - the series by Fernando conflicts a lot with Jan's, breaks userland ABI (FIFREEZE semantics gets changed) and trades the deadlock for massive vfsmount leak; this is going to be handled next cycle. There probably will be another pull request, but that stuff won't be in it." Fix up trivial conflicts due to unrelated changes next to each other in drivers/{staging/gdm72xx/usb_boot.c, usb/gadget/storage_common.c} * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (54 commits) delousing target_core_file a bit Documentation: Correct s_umount state for freeze_fs/unfreeze_fs fs: Remove old freezing mechanism ext2: Implement freezing btrfs: Convert to new freezing mechanism nilfs2: Convert to new freezing mechanism ntfs: Convert to new freezing mechanism fuse: Convert to new freezing mechanism gfs2: Convert to new freezing mechanism ocfs2: Convert to new freezing mechanism xfs: Convert to new freezing code ext4: Convert to new freezing mechanism fs: Protect write paths by sb_start_write - sb_end_write fs: Skip atime update on frozen filesystem fs: Add freezing handling to mnt_want_write() / mnt_drop_write() fs: Improve filesystem freezing handling switch the protection of percpu_counter list to spinlock nfsd: Push mnt_want_write() outside of i_mutex btrfs: Push mnt_want_write() outside of i_mutex fat: Push mnt_want_write() outside of i_mutex ...
2012-07-30fat: refactor shortname parsingSteven J. Magnani
Nearly identical shortname parsing is performed in fat_search_long() and __fat_readdir(). Extract this code into a function that may be called by both. Signed-off-by: Steven J. Magnani <steve@digidescorp.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30fat: accessors for msdos_dir_entry 'start' fieldsSteven J. Magnani
Simplify code by providing accessor functions for the directory entry start cluster fields. Signed-off-by: Steven J. Magnani <steve@digidescorp.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31fat: Push mnt_want_write() outside of i_mutexJan Kara
When mnt_want_write() starts to handle freezing it will get a full lock semantics requiring proper lock ordering. So push mnt_want_write() call outside of i_mutex as in other places. CC: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14don't pass nameidata to ->create()Al Viro
boolean "does it have to be exclusive?" flag is passed instead; Local filesystem should just ignore it - the object is guaranteed not to be there yet. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata * to ->d_revalidate()Al Viro
Just the lookup flags. Die, bastard, die... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-11fat: fix non-atomic NFS i_pos readSteven J. Magnani
fat_encode_fh() can fetch an invalid i_pos value on systems where 64-bit accesses are not atomic. Make it use the same accessor as the rest of the FAT code. Signed-off-by: Steven J. Magnani <steve@digidescorp.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs changes from Al Viro. "A lot of misc stuff. The obvious groups: * Miklos' atomic_open series; kills the damn abuse of ->d_revalidate() by NFS, which was the major stumbling block for all work in that area. * ripping security_file_mmap() and dealing with deadlocks in the area; sanitizing the neighborhood of vm_mmap()/vm_munmap() in general. * ->encode_fh() switched to saner API; insane fake dentry in mm/cleancache.c gone. * assorted annotations in fs (endianness, __user) * parts of Artem's ->s_dirty work (jff2 and reiserfs parts) * ->update_time() work from Josef. * other bits and pieces all over the place. Normally it would've been in two or three pull requests, but signal.git stuff had eaten a lot of time during this cycle ;-/" Fix up trivial conflicts in Documentation/filesystems/vfs.txt (the 'truncate_range' inode method was removed by the VM changes, the VFS update adds an 'update_time()' method), and in fs/btrfs/ulist.[ch] (due to sparse fix added twice, with other changes nearby). * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (95 commits) nfs: don't open in ->d_revalidate vfs: retry last component if opening stale dentry vfs: nameidata_to_filp(): don't throw away file on error vfs: nameidata_to_filp(): inline __dentry_open() vfs: do_dentry_open(): don't put filp vfs: split __dentry_open() vfs: do_last() common post lookup vfs: do_last(): add audit_inode before open vfs: do_last(): only return EISDIR for O_CREAT vfs: do_last(): check LOOKUP_DIRECTORY vfs: do_last(): make ENOENT exit RCU safe vfs: make follow_link check RCU safe vfs: do_last(): use inode variable vfs: do_last(): inline walk_component() vfs: do_last(): make exit RCU safe vfs: split do_lookup() Btrfs: move over to use ->update_time fs: introduce inode operation ->update_time reiserfs: get rid of resierfs_sync_super reiserfs: mark the superblock as dirty a bit later ...
2012-05-31fat: use fat_msg_ratelimit() in fat__get_entry()Namjae Jeon
If an application tries to lookup (opendir/readdir/stat) 5000 files on a fatfs USB device and the device is unplugged, many message occur, shown below. This makes the application slow. So use the new fat_msg_ratelimit() decrease the messaging rate. #> ./file_lookup_testcase ./files_directory/ usb 2-1.4: USB disconnect, device number 4 FAT-fs (sda1): FAT read failed (blocknr 2631) FAT-fs (sda1): Directory bread(block 396816) failed FAT-fs (sda1): Directory bread(block 396817) failed FAT-fs (sda1): Directory bread(block 396818) failed FAT-fs (sda1): Directory bread(block 396819) failed FAT-fs (sda1): Directory bread(block 396820) failed FAT-fs (sda1): Directory bread(block 396821) failed FAT-fs (sda1): Directory bread(block 396822) failed FAT-fs (sda1): Directory bread(block 396823) failed FAT-fs (sda1): Directory bread(block 406824) failed FAT-fs (sda1): Directory bread(block 406825) failed FAT-fs (sda1): Directory bread(block 406826) failed FAT-fs (sda1): Directory bread(block 406827) failed FAT-fs (sda1): Directory bread(block 406828) failed FAT-fs (sda1): Directory bread(block 406829) failed FAT-fs (sda1): Directory bread(block 406830) failed FAT-fs (sda1): Directory bread(block 406831) failed FAT-fs (sda1): Directory bread(block 417696) failed FAT-fs (sda1): Directory bread(block 417697) failed FAT-fs (sda1): Directory bread(block 417698) failed FAT-fs (sda1): Directory bread(block 417699) failed FAT-fs (sda1): Directory bread(block 417700) failed FAT-fs (sda1): Directory bread(block 417701) failed FAT-fs (sda1): Directory bread(block 417702) failed FAT-fs (sda1): Directory bread(block 417703) failed FAT-fs (sda1): FAT read failed (blocknr 2631) FAT-fs (sda1): Directory bread(block 396816) failed FAT-fs (sda1): Directory bread(block 396817) failed FAT-fs (sda1): Directory bread(block 396818) failed FAT-fs (sda1): Directory bread(block 396819) failed FAT-fs (sda1): Directory bread(block 396820) failed FAT-fs (sda1): Directory bread(block 396821) failed Signed-off-by: Namjae Jeon <linkinjeon@gmail.com> Signed-off-by: Amit Sahrawat <amit.sahrawat83@gmail.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
