path: root/fs/fat
2011-06-23fat: Fix corrupt inode flags when remove ATTR_SYS flagOGAWA Hirofumi
commit 1adffbae22332bb558c2a29de19d9aca391869f6 upstream. We are clearly missing '~' in fat_ioctl_set_attributes(). Reported-by: Dmitry Dmitriev <dimondmm@yandex.ru> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-26fat: fix buffer overflow in vfat_create_shortname()Nikolaus Schulz
commit 30d1872d9eb3663b4cf7bdebcbf5cd465674cced upstream. When using the string representation of a random counter as part of the base name, ensure that it is no longer than 4 bytes. Since we are repeatedly decrementing the counter in a loop until we have found a unique base name, the counter may wrap around zero; therefore, it is not enough to mask its higher bits before entering the loop, this must be done inside the loop. [hirofumi@mail.parknet.co.jp: use snprintf()] Signed-off-by: Nikolaus Schulz <microschulz@web.de> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6: fat: Check s_dirt in fat_sync_fs() vfat: change the default from shortname=lower to shortname=mixed fat/nls: Fix handling of utf8 invalid char
2009-09-24fs: Make unload_nls() NULL pointer safeThomas Gleixner
Most call sites of unload_nls() do: if (nls) unload_nls(nls); Check the pointer inside unload_nls() like we do in kfree() and simplify the call sites. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Steve French <sfrench@us.ibm.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-20fat: Check s_dirt in fat_sync_fs()OGAWA Hirofumi
If we didn't check sb->s_dirt, it will update the FSINFO unconditionally. It will reduce the filetime of flash base device. So, this checks sb->s_dirt. sb->s_dirt is racy, however FSINFO is just hint. So even if there is race, and we hit it, it would not become big problem. And this also is as workaround of suspend problem. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2009-09-14fat: Opencode sync_page_range_nolock()Jan Kara
fat_cont_expand() is the only user of sync_page_range_nolock(). It's also the only user of generic_osync_inode() which does not have a file open. So opencode needed actions for FAT so that we can convert generic_osync_inode() to a standard syncing path. Update a comment about generic_osync_inode(). CC: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Jan Kara <jack@suse.cz>
2009-08-01vfat: change the default from shortname=lower to shortname=mixedPaul Wise
Because, with "shortname=lower", copying one FAT filesystem tree to another FAT filesystem tree using Linux results in semantically different filesystems. (E.g.: Filenames which were once "all uppercase" are now "all lowercase"). So, this changes the default of "shortname=lower" to "shortname=mixed". Signed-off-by: Paul Wise <pabs3@bonedaddy.net> [change fat_show_options()] Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2009-08-01fat/nls: Fix handling of utf8 invalid charOGAWA Hirofumi
With utf8 option, vfat allowed the duplicated filenames. Normal nls returns -EINVAL for invalid char. But utf8s_to_utf16s() skipped the invalid char historically. So, this changes the utf8s_to_utf16s() directly to return -EINVAL for invalid char, because vfat is only user of it. mkdir /mnt/fatfs FILENAME=`echo -ne "invalidutf8char_\\0341_endofchar"` echo "Using filename: $FILENAME" dd if=/dev/zero of=fatfs bs=512 count=128 mkdosfs -F 32 fatfs mount -o loop,utf8 fatfs /mnt/fatfs touch "/mnt/fatfs/$FILENAME" umount /mnt/fatfs mount -o loop,utf8 fatfs /mnt/fatfs touch "/mnt/fatfs/$FILENAME" ls -l /mnt/fatfs umount /mnt/fatfs ---- And the output is: Using filename: invalidutf8char_\0341_endofchar 128+0 records in 128+0 records out 65536 bytes (66 kB) copied, 0.000388118 s, 169 MB/s mkdosfs 2.11 (12 Mar 2005) total 0 -rwxr-xr-x 1 root root 0 Jun 28 19:46 invalidutf8char__endofchar -rwxr-xr-x 1 root root 0 Jun 28 19:46 invalidutf8char__endofchar Tested-by: Marton Balint <cus@fazekas.hu> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-10Fix congestion_wait() sync/async vs read/write confusionJens Axboe
Commit 1faa16d22877f4839bd433547d770c676d1d964c accidentally broke the bdi congestion wait queue logic, causing us to wait on congestion for WRITE (== 1) when we really wanted BLK_RW_ASYNC (== 0) instead. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-20fat: Fix the removal of opts->fs_dmaskOGAWA Hirofumi
(ce3b0f8d5c2203301fc87f3aaaed73e5819e2a48: New helper - current_umask()) is removing the opts->fs_dmask, probably it's a cut-and-paste miss or something. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2009-06-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (143 commits) USB: xhci depends on PCI. USB: xhci: Add Makefile, MAINTAINERS, and Kconfig entries. USB: xhci: Respect critical sections. USB: xHCI: Fix interrupt moderation. USB: xhci: Remove packed attribute from structures. usb; xhci: Fix TRB offset calculations. USB: xhci: replace if-elseif-else with switch-case USB: xhci: Make xhci-mem.c include linux/dmapool.h USB: xhci: drop spinlock in xhci_urb_enqueue() error path. USB: Change names of SuperSpeed ep companion descriptor structs. USB: xhci: Avoid compiler reordering in Link TRB giveback. USB: xhci: Clean up xhci_irq() function. USB: xhci: Avoid global namespace pollution. USB: xhci: Fix Link TRB handoff bit twiddling. USB: xhci: Fix register write order. USB: xhci: fix some compiler warnings in xhci.h USB: xhci: fix lots of compiler warnings. USB: xhci: use xhci_handle_event instead of handle_event USB: xhci: URB cancellation support. USB: xhci: Scatter gather list support for bulk transfers. ...
2009-06-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6: fat: split fat_generic_ioctl FAT: add 'errors' mount option
2009-06-15NLS: update handling of UnicodeAlan Stern
This patch (as1239) updates the kernel's treatment of Unicode. The character-set conversion routines are well behind the current state of the Unicode specification: They don't recognize the existence of code points beyond plane 0 or of surrogate pairs in the UTF-16 encoding. The old wchar_t 16-bit type is retained because it's still used in lots of places. This shouldn't cause any new problems; if a conversion now results in an invalid 16-bit code then before it must have yielded an undefined code. Difficult-to-read names like "utf_mbstowcs" are replaced with more transparent names like "utf8s_to_utf16s" and the ordering of the parameters is rationalized (buffer lengths come immediate after the pointers they refer to, and the inputs precede the outputs). Fortunately the low-level conversion routines are used in only a few places; the interfaces to the higher-level uni2char and char2uni methods have been left unchanged. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-11fat: add ->sync_fsChristoph Hellwig
Add a ->sync_fs method for data integrity syncs. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11Sanitize ->fsync() for FATAl Viro
* mark directory data blocks as assoc. metadata * add new inode to deal with FAT, mark FAT blocks as assoc. metadata of that * now ->fsync() is trivial both for files and directories Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11->write_super lock_super pushdownChristoph Hellwig
Push down lock_super into ->write_super instances and remove it from the caller. Following filesystem don't need ->s_lock in ->write_super and are skipped: * bfs, nilfs2 - no other uses of s_lock and have internal locks in ->write_super * ext2 - uses BKL in ext2_write_super and has internal calls without s_lock * reiserfs - no other uses of s_lock as has reiserfs_write_lock (BKL) in ->write_super * xfs - no other uses of s_lock and uses internal lock (buffer lock on superblock buffer) to serialize ->write_super. Also xfs_fs_write_super is superflous and will go away in the next merge window Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11push BKL down into ->put_superChristoph Hellwig
Move BKL into ->put_super from the only caller. A couple of filesystems had trivial enough ->put_super (only kfree and NULLing of s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs, hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most of them probably don't need it, but I'd rather sort that out individually. Preferably after all the other BKL pushdowns in that area. [AV: original used to move lock_super() down as well; these changes are removed since we don't do lock_super() at all in generic_shutdown_super() now] [AV: fuse, btrfs and xfs are known to need no damn BKL, exempt] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11remove ->write_super call in generic_shutdown_superChristoph Hellwig
We just did a full fs writeout using sync_filesystem before, and if that's not enough for the filesystem it can perform it's own writeout in ->put_super, which many filesystems already do. Move a call to foofs_write_super into every foofs_put_super for now to guarantee identical behaviour until it's cleaned up by the individual filesystem maintainers. Exceptions: - affs already has identical copy & pasted code at the beginning of affs_put_super so no need to do it twice. - xfs does the right thing without it and I have changes pending for the xfs tree touching this are so I don't really need conflicts here.. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-08fat: split fat_generic_ioctlChristoph Hellwig
Split up fat_generic_ioctl and add separate functions for the two implemented ioctls. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2009-06-04FAT: add 'errors' mount optionDenis Karpov
On severe errors FAT remounts itself in read-only mode. Allow to specify FAT fs desired behavior through 'errors' mount option: panic, continue or remount read-only. `mount -t [fat|vfat] -o errors=[panic,remount-ro,continue] \ <bdev> <mount point>` This is analog to ext2 fs 'errors' mount option. Signed-off-by: Denis Karpov <ext-denis.2.karpov@nokia.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2009-04-17vfat: Note the NLS requirementAlan Cox
Close bug #4754. Stop people getting into a situation where they can't get their FAT filesystems to mount as they expect. Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: Remove two unneeded exports and make two symbols static in fs/mpage.c Cleanup after commit 585d3bc06f4ca57f975a5a1f698f65a45ea66225 Trim includes of fdtable.h Don't crap into descriptor table in binfmt_som Trim includes in binfmt_elf Don't mess with descriptor table in load_elf_binary() Get rid of indirect include of fs_struct.h New helper - current_umask() check_unsafe_exec() doesn't care about signal handlers sharing New locking/refcounting for fs_struct Take fs_struct handling to new file (fs/fs_struct.c) Get rid of bumping fs_struct refcount in pivot_root(2) Kill unsharing fs_struct in __set_personality()
2009-04-02fs/fat: return f_fsid for statfs(2)Coly Li
Make fat return f_fsid info for statfs(2). Signed-off-by: Coly Li <coly.li@suse.de> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31New helper - current_umask()Al Viro
current->fs->umask is what most of fs_struct users are doing. Put that into a helper function. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27constify dentry_operations: FATAl Viro
2009-03-11Fix _fat_bmap() lockingOGAWA Hirofumi
On swapon() path, it has already i_mutex. So, this uses i_alloc_sem instead of it. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Reported-by: Laurent GUERBY <laurent@guerby.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-22fs/Kconfig: move fat outAlexey Dobriyan
2008-12-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/hirofumi/fatfs-2.6: fat: make sure to set d_ops in fat_get_parent fat: fix duplicate addition of ->llseek handler fat: drop negative dentry on rename() path
2008-11-14Merge branch 'master' into nextJames Morris
Conflicts: security/keys/internal.h security/keys/process_keys.c security/keys/request_key.c Fixed conflicts above by using the non 'tsk' versions. Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the FAT filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-12fat: make sure to set d_ops in fat_get_parentChristoph Hellwig
fat_get_parent needs to setup the dentry operations, otherwise we might lose them when the NFS server needs to reconnect out of cache inodes. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2008-11-12fat: fix duplicate addition of ->llseek handlerOGAWA Hirofumi
2008-11-12fat: drop negative dentry on rename() pathOGAWA Hirofumi
Drop the negative dentry on rename() path, in order to make sure to use the case sensitive name which is specified by user if this is for creation. For it, this uses newly added LOOKUP_RENAME_TARGET like LOOKUP_CREATE. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
2008-11-06fat: i_blocks warning fixOGAWA Hirofumi
blkcnt_t type depends on CONFIG_LSF. Use unsigned long long always for printk(). But lazy to type it, so add "llu" and use it. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: ->i_pos race fixOGAWA Hirofumi
i_pos is 64bits value, hence it's not atomic to update. Important place is fat_write_inode() only, other places without lock are just for printk(). This adds lock for "BITS_PER_LONG == 32" kernel. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: mmu_private race fixOGAWA Hirofumi
mmu_private is 64bits value, hence it's not atomic to update. So, the access rule for mmu_private is we must hold ->i_mutex. But, fat_get_block() path doesn't follow the rule on non-allocation path. This fixes by using i_size instead if non-allocation path. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: Add printf attribute to fat_fs_panic()OGAWA Hirofumi
2008-11-06fat: Fix _fat_bmap() raceOGAWA Hirofumi
fat_get_cluster() assumes the requested blocknr isn't truncated during read. _fat_bmap() doesn't follow this rule. This protects it by ->i_mutex. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: Fix ATTR_RO for directoryOGAWA Hirofumi
FAT has the ATTR_RO (read-only) attribute. But on Windows, the ATTR_RO of the directory will be just ignored actually, and is used by only applications as flag. E.g. it's setted for the customized folder by Explorer. http://msdn2.microsoft.com/en-us/library/aa969337.aspx This adds "rodir" option. If user specified it, ATTR_RO is used as read-only flag even if it's the directory. Otherwise, inode->i_mode is not used to hold ATTR_RO (i.e. fat_mode_can_save_ro() returns 0). Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: Fix ATTR_RO in the case of (~umask & S_WUGO) == 0OGAWA Hirofumi
If inode->i_mode doesn't have S_WUGO, current code assumes it means ATTR_RO. However, if (~[ufd]mask & S_WUGO) == 0, inode->i_mode can't hold S_WUGO. Therefore the updated directory entry will always have ATTR_RO. This adds fat_mode_can_hold_ro() to check it. And if inode->i_mode can't hold, uses -i_attrs to hold ATTR_RO instead. With this, we don't set ATTR_RO unless users change it via ioctl() if (~[ufd]mask & S_WUGO) == 0. And on FAT_IOCTL_GET_ATTRIBUTES path, this adds ->i_mutex to it for not returning the partially updated attributes by FAT_IOCTL_SET_ATTRIBUTES to userland. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: Cleanup FAT attribute stuffOGAWA Hirofumi
This adds three helpers: fat_make_attrs() - makes FAT attributes from inode. fat_make_mode() - makes mode_t from FAT attributes. fat_save_attrs() - saves FAT attributes to inode. Then this replaces: MSDOS_MKMODE() by fat_make_mode(), fat_attr() by fat_make_attrs(), ->i_attrs = attr & ATTR_UNUSED by fat_save_attrs(). And for root inode, those is used with ATTR_DIR instead of bogus ATTR_NONE. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: Cleanup msdos_lookup()OGAWA Hirofumi
Use same style with vfat_lookup(). Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: Kill d_invalidate() in vfat_lookup()OGAWA Hirofumi
d_invalidate() for positive dentry doesn't work in some cases (vfsmount, nfsd, and maybe others). shrink_dcache_parent() by d_invalidate() is pointless for vfat usage at all. So, this kills it, and intead of it uses d_move(). To save old behavior, this returns alias simply for directory (don't change pwd, etc..). the directory lookup shouldn't be important for performance. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: Fix/Cleanup dcache handling for vfatOGAWA Hirofumi
- Add comments for handling dcache of vfat. - Separate case-sensitive case and case-insensitive to vfat_revalidate() and vfat_ci_revalidate(). vfat_revalidate() doesn't need to drop case-insensitive negative dentry on creation path. - Current code is missing to set ->d_revalidate to the negative dentry created by unlink/etc.. This sets ->d_revalidate always, and returns 1 for positive dentry. Now, we don't need to change ->d_op dynamically anymore, so this just uses sb->s_root->d_op to set ->d_op. - d_find_alias() may return DCACHE_DISCONNECTED dentry. It's not the interesting dentry there. This checks it. - Add missing LOOKUP_PARENT check. We don't need to drop the valid negative dentry for (LOOKUP_CREATE | LOOKUP_PARENT) lookup. - For consistent filename on creation path, this drops negative dentry if we can't see intent. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06vfat: Fix vfat_find() error path in vfat_lookup()OGAWA Hirofumi
Current vfat_lookup() creates negetive dentry blindly if vfat_find() returned a error. It's wrong. If the error isn't -ENOENT, just return error. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: use fat_detach() in fat_clear_inode()OGAWA Hirofumi
Use fat_detach() instead of opencoding it. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: Fix fat_ent_update_ptr() for FAT12OGAWA Hirofumi
This fixes the missing update for bhs/nr_bhs in case the caller accessed from block boundary to first block of boundary. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: improve fat_hash()OGAWA Hirofumi
fat_hash() is using the algorithm known as bad. Instead of it, this uses hash_32(). The following is the summary of test. old hash: hash func (1000 times): 33489 cycles total inodes in hash table: 70926 largest bucket contains: 696 smallest bucket contains: 54 new hash: hash func (1000 times): 33129 cycles total inodes in hash table: 70926 largest bucket contains: 315 smallest bucket contains: 236 Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06fat: cleanup fat_parse_long() error handlingDarren Jenkins
Coverity CID 2332 & 2333 RESOURCE_LEAK In fat_search_long() if fat_parse_long() returns a -ve value we return without first freeing unicode. This patch free's them on this error path. The above was false positive on current tree, but this change is more clean, so apply as cleanup. [hirofumi@mail.parknet.co.jp: fix coding style] Signed-off-by: Darren Jenkins <darrenrjenkins@gmail.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
