path: root/fs/fcntl.c
2011-03-23userns: rename is_owner_or_cap to inode_owner_or_capableSerge E. Hallyn
And give it a kernel-doc comment. [akpm@linux-foundation.org: btrfs changed in linux-next] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-15New kind of open files - "location only".Al Viro
New flag for open(2) - O_PATH. Semantics: * pathname is resolved, but the file itself is _NOT_ opened as far as filesystem is concerned. * almost all operations on the resulting descriptors shall fail with -EBADF. Exceptions are: 1) operations on descriptors themselves (i.e. close(), dup(), dup2(), dup3(), fcntl(fd, F_DUPFD), fcntl(fd, F_DUPFD_CLOEXEC, ...), fcntl(fd, F_GETFD), fcntl(fd, F_SETFD, ...)) 2) fcntl(fd, F_GETFL), for a common non-destructive way to check if descriptor is open 3) "dfd" arguments of ...at(2) syscalls, i.e. the starting points of pathname resolution * closing such descriptor does *NOT* affect dnotify or posix locks. * permissions are checked as usual along the way to file; no permission checks are applied to the file itself. Of course, giving such thing to syscall will result in permission checks (at the moment it means checking that starting point of ....at() is a directory and caller has exec permissions on it). fget() and fget_light() return NULL on such descriptors; use of fget_raw() and fget_raw_light() is needed to get them. That protects existing code from dealing with those things. There are two things still missing (they come in the next commits): one is handling of symlinks (right now we refuse to open them that way; see the next commit for semantics related to those) and another is descriptor passing via SCM_RIGHTS datagrams. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-02-02vfs: sparse: add __FMODE_EXECNamhyung Kim
FMODE_EXEC is a constant type of fmode_t but was used with normal integer constants. This results in following warnings from sparse. Fix it using new macro __FMODE_EXEC. fs/exec.c:116:58: warning: restricted fmode_t degrades to integer fs/exec.c:689:58: warning: restricted fmode_t degrades to integer fs/fcntl.c:777:9: warning: restricted fmode_t degrades to integer Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27fasync: Fix placement of FASYNC flag commentLinus Torvalds
In commit f7347ce4ee7c ("fasync: re-organize fasync entry insertion to allow it under a spinlock") Arnd took an earlier patch of mine that had the comment about the FASYNC flag above the wrong function. When the fasync_add_entry() function was split to introduce the new fasync_insert_entry() helper function, the code that actually cares about the FASYNC bit moved to that new helper. So just move the comment to the right point. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27fasync: re-organize fasync entry insertion to allow it under a spinlockLinus Torvalds
You currently cannot use "fasync_helper()" in an atomic environment to insert a new fasync entry, because it will need to allocate the new "struct fasync_struct". Yet fcntl_setlease() wants to call this under lock_flocks(), which is in the process of being converted from the BKL to a spinlock. In order to fix this, this abstracts out the actual fasync list insertion and the fasync allocations into functions of their own, and teaches fs/locks.c to pre-allocate the fasync_struct entry. That way the actual list insertion can happen while holding the required spinlock. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> [bfields@redhat.com: rebase on top of my changes to Arnd's patch] Tested-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-09-09vfs: take O_NONBLOCK out of the O_* uniqueness testJames Bottomley
O_NONBLOCK on parisc has a dual value: #define O_NONBLOCK 000200004 /* HPUX has separate NDELAY & NONBLOCK */ It is caught by the O_* bits uniqueness check and leads to a parisc compile error. The fix would be to take O_NONBLOCK out. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de> Cc: Jamie Lokier <jamie@shareable.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11vfs: O_* bit numbers uniqueness checkWu Fengguang
The O_* bit numbers are defined in 20+ arch/*, and can silently overlap. Add a compile time check to ensure the uniqueness as suggested by David Miller. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: David Miller <davem@davemloft.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Cc: Eric Paris <eparis@redhat.com> Cc: Roland Dreier <rdreier@cisco.com> Cc: Jamie Lokier <jamie@shareable.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-29fs/fcntl.c:kill_fasync_rcu() fa_lock must be IRQ-safeAndrew Morton
Fix a lockdep-splat-causing regression introduced by commit 989a2979205d ("fasync: RCU and fine grained locking"). kill_fasync() can be called from both process and hard-irq context, so fa_lock must be taken with IRQs disabled. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16230 Reported-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Reported-by: Dominik Brodowski <linux@dominikbrodowski.net> Tested-by: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Maciej Rutecki <maciej.rutecki@gmail.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-04fcntl: return -EFAULT if copy_to_user failsDan Carpenter
copy_to_user() returns the number of bytes remaining, but we want to return -EFAULT. ret = fcntl(fd, F_SETOWN_EX, NULL); With the original code ret would be 8 here. V2: Takuya Yoshikawa pointed out a similar issue in f_getown_ex() Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21Merge branch 'master' into for-2.6.35Jens Axboe
Conflicts: fs/ext3/fsync.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-21pipe: add support for shrinking and growing pipesJens Axboe
This patch adds F_GETPIPE_SZ and F_SETPIPE_SZ fcntl() actions for growing and shrinking the size of a pipe and adjusts pipe.c and splice.c (and relay and network splice) usage to work with these larger (or smaller) pipes. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-04-21fasync: RCU and fine grained lockingEric Dumazet
kill_fasync() uses a central rwlock, candidate for RCU conversion, to avoid cache line ping pongs on SMP. fasync_remove_entry() and fasync_add_entry() can disable IRQS on a short section instead during whole list scan. Use a spinlock per fasync_struct to synchronize kill_fasync_rcu() and fasync_{remove|add}_entry(). This spinlock is IRQ safe, so sock_fasync() doesnt need its own implementation and can use fasync_helper(), to reduce code size and complexity. We can remove __kill_fasync() direct use in net/socket.c, and rename it to kill_fasync_rcu(). Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-06fs: use rlimit helpersJiri Slaby
Make sure compiler won't do weird things with limits. E.g. fetching them twice may return 2 different values after writable limits are implemented. I.e. either use rlimit helpers added in commit 3e10e716abf3 ("resource: add helpers for fetching rlimits") or ACCESS_ONCE if not applicable. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-07Fix race in tty_fasync() properlyLinus Torvalds
This reverts commit 703625118069 ("tty: fix race in tty_fasync") and commit b04da8bfdfbb ("fnctl: f_modown should call write_lock_irqsave/ restore") that tried to fix up some of the fallout but was incomplete. It turns out that we really cannot hold 'tty->ctrl_lock' over calling __f_setown, because not only did that cause problems with interrupt disables (which the second commit fixed), it also causes a potential ABBA deadlock due to lock ordering. Thanks to Tetsuo Handa for following up on the issue, and running lockdep to show the problem. It goes roughly like this: - f_getown gets filp->f_owner.lock for reading without interrupts disabled, so an interrupt that happens while that lock is held can cause a lockdep chain from f_owner.lock -> sighand->siglock. - at the same time, the tty->ctrl_lock -> f_owner.lock chain that commit 703625118069 introduced, together with the pre-existing sighand->siglock -> tty->ctrl_lock chain means that we have a lock dependency the other way too. So instead of extending tty->ctrl_lock over the whole __f_setown() call, we now just take a reference to the 'pid' structure while holding the lock, and then release it after having done the __f_setown. That still guarantees that 'struct pid' won't go away from under us, which is all we really ever needed. Reported-and-tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Américo Wang <xiyou.wangcong@gmail.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-26fnctl: f_modown should call write_lock_irqsave/restoreGreg Kroah-Hartman
Commit 703625118069f9f8960d356676662d3db5a9d116 exposed that f_modown() should call write_lock_irqsave instead of just write_lock_irq so that because a caller could have a spinlock held and it would not be good to renable interrupts. Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Tavis Ormandy <taviso@google.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16fasync: split 'fasync_helper()' into separate add/remove functionsLinus Torvalds
Yes, the add and remove cases do share the same basic loop and the locking, but the compiler can inline and then CSE some of the end result anyway. And splitting it up makes the code way easier to follow, and makes it clearer exactly what the semantics are. In particular, we must make sure that the FASYNC flag in file->f_flags exactly matches the state of "is this file on any fasync list", since not only is that flag visible to user space (F_GETFL), but we also use that flag to check whether we need to remove any fasync entries on file close. We got that wrong for the case of a mixed use of file locking (which tries to remove any fasync entries for file leases) and fasync. Splitting the function up also makes it possible to do some future optimizations without making the function even messier. In particular, since the FASYNC flag has to match the state of "is this on a list", we can do the following future optimizations: - on remove, we don't even need to get the locks and traverse the list if FASYNC isn't set, since we can know a priori that there is no point (this is effectively the same optimization that we already do in __fput() wrt removing fasync on file close) - on add, we can use the FASYNC flag to decide whether we are changing an existing entry or need to allocate a new one. but this is just the cleanup + fix for the FASYNC flag. Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Tested-by: Tavis Ormandy <taviso@google.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Matt Mackall <mpm@selenic.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-17fcntl: rename F_OWNER_GID to F_OWNER_PGRPPeter Zijlstra
This is for consistency with various ioctl() operations that include the suffix "PGRP" in their names, and also for consistency with PRIO_PGRP, used with setpriority() and getpriority(). Also, using PGRP instead of GID avoids confusion with the common abbreviation of "group ID". I'm fine with anything that makes it more consistent, and if PGRP is what is the predominant abbreviation then I see no need to further confuse matters by adding a third one. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24fcntl: add F_[SG]ETOWN_EXPeter Zijlstra
In order to direct the SIGIO signal to a particular thread of a multi-threaded application we cannot, like suggested by the manpage, put a TID into the regular fcntl(F_SETOWN) call. It will still be send to the whole process of which that thread is part. Since people do want to properly direct SIGIO we introduce F_SETOWN_EX. The need to direct SIGIO comes from self-monitoring profiling such as with perf-counters. Perf-counters uses SIGIO to notify that new sample data is available. If the signal is delivered to the same task that generated the new sample it can augment that data by inspecting the task's user-space state right after it returns from the kernel. This is esp. convenient for interpreted or virtual machine driven environments. Both F_SETOWN_EX and F_GETOWN_EX take a pointer to a struct f_owner_ex as argument: struct f_owner_ex { int type; pid_t pid; }; Where type is one of F_OWNER_TID, F_OWNER_PID or F_OWNER_GID. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Tested-by: stephane eranian <eranian@googlemail.com> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Roland McGrath <roland@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24signals: send_sigio: use do_send_sig_info() to avoid check_kill_permission()Oleg Nesterov
group_send_sig_info()->check_kill_permission() assumes that current is the sender and uses current_cred(). This is not true in send_sigio_to_task() case. From the security pov the sender is not current, but the task which did fcntl(F_SETOWN), that is why we have sigio_perm() which uses the right creds to check. Fortunately, send_sigio() always sends either SEND_SIG_PRIV or SI_FROMKERNEL() signal, so check_kill_permission() does nothing. But still it would be tidier to avoid this bogus security check and save a couple of cycles. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: stephane eranian <eranian@googlemail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16send_sigio_to_task: sanitize the usage of fown->signumOleg Nesterov
send_sigio_to_task() reads fown->signum several times, we can race with F_SETSIG which changes ->signum lockless. In theory, this can fool security checks or we can call group_send_sig_info() with the wrong ->si_signo which does not match "int sig". Change the code to cache ->signum. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16shift current_cred() from __f_setown() to f_modown()Oleg Nesterov
Shift current_cred() from __f_setown() to f_modown(). This reduces the number of arguments and saves 48 bytes from fs/fcntl.o. [ Note: this doesn't clear euid/uid when pid is set to NULL. But if f_owner.pid == NULL we never use f_owner.uid/euid. Otherwise we'd have a bug anyway: we must not send signals if pid was reset to NULL. ] Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-11dup2: Fix return value with oldfd == newfd and invalid fdJeff Mahoney
The return value of dup2 when oldfd == newfd and the fd isn't valid is not getting properly sign extended. We end up with 4294967287 instead of -EBADF. I've reproduced this on SLE11 (2.6.27.21), openSUSE Factory (2.6.29-rc5), and Ubuntu 9.04 (2.6.28). This patch uses a signed int for the error value so it is properly extended. Commit 6c5d0512a091480c9f981162227fdb1c9d70e555 introduced this regression. Reported-by: Jiri Dluhos <jdluhos@novell.com> Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30Fix a lockdep warning in fasync_helper()Jonathan Corbet
Lockdep gripes if file->f_lock is taken in a no-IRQ situation, since that is not always the case. We don't really want to disable IRQs for every acquisition of f_lock; instead, just move it outside of fasync_lock. Reported-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Reported-by: Larry Finger <Larry.Finger@lwfinger.net> Reported-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-03-16Rationalize fasync return valuesJonathan Corbet
Most fasync implementations do something like: return fasync_helper(...); But fasync_helper() will return a positive value at times - a feature used in at least one place. Thus, a number of other drivers do: err = fasync_helper(...); if (err < 0) return err; return 0; In the interests of consistency and more concise code, it makes sense to map positive return values onto zero where ->fasync() is called. Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-03-16Move FASYNC bit handling to f_op->fasync()Jonathan Corbet
Removing the BKL from FASYNC handling ran into the challenge of keeping the setting of the FASYNC bit in filp->f_flags atomic with regard to calls to the underlying fasync() function. Andi Kleen suggested moving the handling of that bit into fasync(); this patch does exactly that. As a result, we have a couple of internal API changes: fasync() must now manage the FASYNC bit, and it will be called without the BKL held. As it happens, every fasync() implementation in the kernel with one exception calls fasync_helper(). So, if we make fasync_helper() set the FASYNC bit, we can avoid making any changes to the other fasync() functions - as long as those functions, themselves, have proper locking. Most fasync() implementations do nothing but call fasync_helper() - which has its own lock - so they are easily verified as correct. The BKL had already been pushed down into the rest. The networking code has its own version of fasync_helper(), so that code has been augmented with explicit FASYNC bit handling. Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: David Miller <davem@davemloft.net> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-03-16Use f_lock to protect f_flagsJonathan Corbet
Traditionally, changes to struct file->f_flags have been done under BKL protection, or with no protection at all. This patch causes all f_flags changes after file open/creation time to be done under protection of f_lock. This allows the removal of some BKL usage and fixes a number of longstanding (if microscopic) races. Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2009-01-14[CVE-2009-0029] System call wrappers part 15Heiko Carstens
2008-12-25Merge branch 'next' into for-linusJames Morris
2008-12-05Fix a race condition in FASYNC handlingJonathan Corbet
Changeset a238b790d5f99c7832f9b73ac8847025815b85f7 (Call fasync() functions without the BKL) introduced a race which could leave file->f_flags in a state inconsistent with what the underlying driver/filesystem believes. Revert that change, and also fix the same races in ioctl_fioasync() and ioctl_fionbio(). This is a minimal, short-term fix; the real fix will not involve the BKL. Reported-by: Oleg Nesterov <oleg@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@kernel.org Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-14CRED: Use RCU to access another task's creds and to release a task's own credsDavid Howells
Use RCU to access another task's creds and to release a task's own creds. This means that it will be possible for the credentials of a task to be replaced without another task (a) requiring a full lock to read them, and (b) seeing deallocated memory. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap current->cred and a few other accessorsDavid Howells
Wrap current->cred and a few other accessors to hide their actual implementation. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the filesystem subsystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Morris <jmorris@namei.org>
2008-08-01[PATCH] clean dup2() up a bitAl Viro
2008-08-01[PATCH] merge locate_fd() and get_unused_fd()Al Viro
New primitive: alloc_fd(start, flags). get_unused_fd() and get_unused_fd_flags() become wrappers on top of it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] fix RLIM_NOFILE handlingAl Viro
* dup2() should return -EBADF on exceeded sysctl_nr_open * dup() should *not* return -EINVAL even if you have rlimit set to 0; it should get -EMFILE instead. Check for orig_start exceeding rlimit taken to sys_fcntl(). Failing expand_files() in dup{2,3}() now gets -EMFILE remapped to -EBADF. Consequently, remaining checks for rlimit are taken to expand_files(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] get rid of corner case in dup3() entirelyAl Viro
Since Ulrich is OK with getting rid of dup3(fd, fd, flags) completely, to hell the damn thing goes. Corner case for dup2() is handled in sys_dup2() (complete with -EBADF if dup2(fd, fd) is called with fd that is not open), the rest is done in dup3(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] dup3 fixUlrich Drepper
Al Viro notice one cornercase that the new dup3() code. The dup2() function, as a special case, handles dup-ing to the same file descriptor. In this case the current dup3() code does nothing at all. I.e., it ingnores the flags parameter. This shouldn't happen, the close-on-exec flag should be set if requested. In case the O_CLOEXEC bit in the flags parameter is not set the dup3() function should behave in this respect identical to dup2(). This means dup3(fd, fd, 0) should not actively reset the c-o-e flag. The patch below implements this minor change. [AV: credits to Artur Grabowski for bringing that up as potential subtle point in dup2() behaviour] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-24flag parameters: dup2Ulrich Drepper
This patch adds the new dup3 syscall. It extends the old dup2 syscall by one parameter which is meant to hold a flag value. Support for the O_CLOEXEC flag is added in this patch. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <stdio.h> #include <time.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_dup3 # ifdef __x86_64__ # define __NR_dup3 292 # elif defined __i386__ # define __NR_dup3 330 # else # error "need __NR_dup3" # endif #endif int main (void) { int fd = syscall (__NR_dup3, 1, 4, 0); if (fd == -1) { puts ("dup3(0) failed"); return 1; } int coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if (coe & FD_CLOEXEC) { puts ("dup3(0) set close-on-exec flag"); return 1; } close (fd); fd = syscall (__NR_dup3, 1, 4, O_CLOEXEC); if (fd == -1) { puts ("dup3(O_CLOEXEC) failed"); return 1; } coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if ((coe & FD_CLOEXEC) == 0) { puts ("dup3(O_CLOEXEC) set close-on-exec flag"); return 1; } close (fd); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-02Call fasync() functions without the BKLJonathan Corbet
lock_kernel() calls have been pushed down into code which needs it, so there is no need to take the BKL at this level anymore. This work inspired and aided by Andi Kleen's unlocked_fasync() patches. Acked-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-05-01[PATCH] split linux/file.hAl Viro
Initial splitoff of the low-level stuff; taken to fdtable.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-25[PATCH] sanitize locate_fd()Al Viro
* 'file' argument is unused; lose it. * move setting flags from the caller (dupfd()) to locate_fd(); pass cloexec flag as new argument. Note that files_fdtable() that used to be in dupfd() isn't needed in the place in locate_fd() where the moved code ends up - we know that ->file_lock hadn't been dropped since the last time we calculated fdt because we can get there only if expand_files() returns 0 and it doesn't drop/reacquire in that case. * move getting/dropping ->file_lock into locate_fd(). Now the caller doesn't need to do anything with files_struct *files anymore and we can move that inside locate_fd() as well, killing the struct files_struct * argument. At that point locate_fd() is extremely similar to get_unused_fd_flags() and the next patches will merge those two. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-08fs: remove fastcall, it is always emptyHarvey Harrison
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08Pidns: make full use of xxx_vnr() callsPavel Emelyanov
Some time ago the xxx_vnr() calls (e.g. pid_vnr or find_task_by_vpid) were _all_ converted to operate on the current pid namespace. After this each call like xxx_nr_ns(foo, current->nsproxy->pid_ns) is nothing but a xxx_vnr(foo) one. Switch all the xxx_nr_ns() callers to use the xxx_vnr() calls where appropriate. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Reviewed-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: changes to show virtual ids to userPavel Emelyanov
This is the largest patch in the set. Make all (I hope) the places where the pid is shown to or get from user operate on the virtual pids. The idea is: - all in-kernel data structures must store either struct pid itself or the pid's global nr, obtained with pid_nr() call; - when seeking the task from kernel code with the stored id one should use find_task_by_pid() call that works with global pids; - when showing pid's numerical value to the user the virtual one should be used, but however when one shows task's pid outside this task's namespace the global one is to be used; - when getting the pid from userspace one need to consider this as the virtual one and use appropriate task/pid-searching functions. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: nuther build fix] [akpm@linux-foundation.org: yet nuther build fix] [akpm@linux-foundation.org: remove unneeded casts] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Paul Menage <menage@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17F_DUPFD_CLOEXEC implementationUlrich Drepper
One more small change to extend the availability of creation of file descriptors with FD_CLOEXEC set. Adding a new command to fcntl() requires no new system call and the overall impact on code size if minimal. If this patch gets accepted we will also add this change to the next revision of the POSIX spec. To test the patch, use the following little program. Adjust the value of F_DUPFD_CLOEXEC appropriately. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <errno.h> #include <fcntl.h> #include <stdio.h> #include <stdlib.h> #include <unistd.h> #ifndef F_DUPFD_CLOEXEC # define F_DUPFD_CLOEXEC 12 #endif int main (int argc, char *argv[]) { if (argc > 1) { if (fcntl (3, F_GETFD) == 0) { puts ("descriptor not closed"); exit (1); } if (errno != EBADF) { puts ("error not EBADF"); exit (1); } exit (0); } int fd = fcntl (STDOUT_FILENO, F_DUPFD_CLOEXEC, 0); if (fd == -1 && errno == EINVAL) { puts ("F_DUPFD_CLOEXEC not supported"); return 0; } if (fd != 3) { puts ("program called with descriptors other than 0,1,2"); return 1; } execl ("/proc/self/exe", "/proc/self/exe", "1", NULL); puts ("execl failed"); return 1; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Introduce is_owner_or_cap() to wrap CAP_FOWNER use with fsuid checkSatyam Sharma
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant users to it. This is done because we want to avoid bugs in the future where we check for only effective fsuid of the current task against a file's owning uid, without simultaneously checking for CAP_FOWNER as well, thus violating its semantics. [ XFS uses special macros and structures, and in general looked ... untouchable, so we leave it alone -- but it has been looked over. ] The (current->fsuid != inode->i_uid) check in generic_permission() and exec_permission_lite() is left alone, because those operations are covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-10[PATCH] fdtable: Make fdarray and fdsets equal in sizeVadim Lobanov
Currently, each fdtable supports three dynamically-sized arrays of data: the fdarray and two fdsets. The code allows the number of fds supported by the fdarray (fdtable->max_fds) to differ from the number of fds supported by each of the fdsets (fdtable->max_fdset). In practice, it is wasteful for these two sizes to differ: whenever we hit a limit on the smaller-capacity structure, we will reallocate the entire fdtable and all the dynamic arrays within it, so any delta in the memory used by the larger-capacity structure will never be touched at all. Rather than hogging this excess, we shouldn't even allocate it in the first place, and keep the capacities of the fdarray and the fdsets equal. This patch removes fdtable->max_fdset. As an added bonus, most of the supporting code becomes simpler. Signed-off-by: Vadim Lobanov <vlobanov@speakeasy.net> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Dipankar Sarma <dipankar@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
