[ Upstream commit 5704a06810682683355624923547b41540e2801a ]
(Taken from https://bugzilla.kernel.org/show_bug.cgi?id=200647)
'get_unused_fd_flags' in kthread cause kernel crash. It works fine on
4.1, but causes crash after get 64 fds. It also cause crash on
ubuntu1404/1604/1804, centos7.5, and the crash messages are almost the
same.
The crash message on centos7.5 shows below:
start fd 61
start fd 62
start fd 63
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: __wake_up_common+0x2e/0x90
PGD 0
Oops: 0000 [#1] SMP
Modules linked in: test(OE) xt_CHECKSUM iptable_mangle ipt_MASQUERADE nf_nat_masquerade_ipv4 iptable_nat nf_nat_ipv4 nf_nat nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_conntrack ipt_REJECT nf_reject_ipv4 tun bridge stp llc ebtable_filter ebtables ip6table_filter ip6_tables iptable_filter devlink sunrpc kvm_intel kvm irqbypass crc32_pclmul ghash_clmulni_intel aesni_intel lrw gf128mul glue_helper ablk_helper cryptd sg ppdev pcspkr virtio_balloon parport_pc parport i2c_piix4 joydev ip_tables xfs libcrc32c sr_mod cdrom sd_mod crc_t10dif crct10dif_generic ata_generic pata_acpi virtio_scsi virtio_console virtio_net cirrus drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ttm crct10dif_pclmul crct10dif_common crc32c_intel drm ata_piix serio_raw libata virtio_pci virtio_ring i2c_core
virtio floppy dm_mirror dm_region_hash dm_log dm_mod
CPU: 2 PID: 1820 Comm: test_fd Kdump: loaded Tainted: G OE ------------ 3.10.0-862.3.3.el7.x86_64 #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.10.2-0-g5f4c7b1-prebuilt.qemu-project.org 04/01/2014
task: ffff8e92b9431fa0 ti: ffff8e94247a0000 task.ti: ffff8e94247a0000
RIP: 0010:__wake_up_common+0x2e/0x90
RSP: 0018:ffff8e94247a2d18 EFLAGS: 00010086
RAX: 0000000000000000 RBX: ffffffff9d09daa0 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 0000000000000003 RDI: ffffffff9d09daa0
RBP: ffff8e94247a2d50 R08: 0000000000000000 R09: ffff8e92b95dfda8
R10: 0000000000000000 R11: 0000000000000000 R12: ffffffff9d09daa8
R13: 0000000000000003 R14: 0000000000000000 R15: 0000000000000003
FS: 0000000000000000(0000) GS:ffff8e9434e80000(0000) knlGS:0000000000000000
CR2: 0000000000000000 CR3: 000000017c686000 CR4: 00000000000207e0
Call Trace:
__wake_up+0x39/0x50
expand_files+0x131/0x250
__alloc_fd+0x47/0x170
get_unused_fd_flags+0x30/0x40
test_fd+0x12a/0x1c0 [test]
kthread+0xd1/0xe0
ret_from_fork_nospec_begin+0x21/0x21
Code: 66 90 55 48 89 e5 41 57 41 89 f7 41 56 41 89 ce 41 55 41 54 49 89 fc 49 83 c4 08 53 48 83 ec 10 48 8b 47 08 89 55 cc 4c 89 45 d0 <48> 8b 08 49 39 c4 48 8d 78 e8 4c 8d 69 e8 75 08 eb 3b 4c 89 ef
RIP __wake_up_common+0x2e/0x90
RSP <ffff8e94247a2d18>
This issue exists since CentOS 7.5 3.10.0-862 and CentOS 7.4
(3.10.0-693.21.1 ) is ok. Root cause: the item 'resize_wait' is not
initialized before being used.
Reported-by: Richard Zhang <zhang.zijian@h3c.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
There is no real reason to duplicate kvmalloc* helpers so drop
alloc_fdmem and replace it with the appropriate library function.
Link: http://lkml.kernel.org/r/20170531155145.17111-2-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
__vmalloc* allows users to provide gfp flags for the underlying
allocation. This API is quite popular
$ git grep "=[[:space:]]__vmalloc\|return[[:space:]]*__vmalloc" | wc -l
77
The only problem is that many people are not aware that they really want
to give __GFP_HIGHMEM along with other flags because there is really no
reason to consume precious lowmemory on CONFIG_HIGHMEM systems for pages
which are mapped to the kernel vmalloc space. About half of users don't
use this flag, though. This signals that we make the API unnecessarily
too complex.
This patch simply uses __GFP_HIGHMEM implicitly when allocating pages to
be mapped to the vmalloc space. Current users which add __GFP_HIGHMEM
are simplified and drop the flag.
Link: http://lkml.kernel.org/r/20170307141020.29107-1-mhocko@kernel.org
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Cristopher Lameter <cl@linux.com>
<linux/sched/signal.h>
We are going to split <linux/sched/signal.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/signal.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Propagate unsignedness for grand total of 149 bytes:
$ ./scripts/bloat-o-meter ../vmlinux-000 ../obj/vmlinux
add/remove: 0/0 grow/shrink: 0/10 up/down: 0/-149 (-149)
function old new delta
set_close_on_exec 99 98 -1
put_files_struct 201 200 -1
get_close_on_exec 59 58 -1
do_prlimit 498 497 -1
do_execveat_common.isra 1662 1661 -1
__close_fd 178 173 -5
do_dup2 219 204 -15
seq_show 685 660 -25
__alloc_fd 384 357 -27
dup_fd 718 646 -72
It mostly comes from converting "unsigned int" to "long" for bit operations.
same as read() on regular files has, and for the same reason.
Mark those kmem allocations that are known to be easily triggered from
userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to
memcg. For the list, see below:
- threadinfo
- task_struct
- task_delay_info
- pid
- cred
- mm_struct
- vm_area_struct and vm_region (nommu)
- anon_vma and anon_vma_chain
- signal_struct
- sighand_struct
- fs_struct
- files_struct
- fdtable and fdtable->full_fds_bits
- dentry and external_name
- inode for all filesystems. This is the most tedious part, because
most filesystems overwrite the alloc_inode method.
The list is far from complete, so feel free to add more objects.
Nevertheless, it should be close to "account everything" approach and
keep most workloads within bounds. Malevolent users will be able to
breach the limit, but this was possible even with the former "account
everything" approach (simply because it did not account everything in
fact).
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
7f4b36f9bb930 "get rid of files_defer_init()" inexplicably changed a
min() to a __const_max() - but the __const_max macro actually gives
the minimum... So no functional change, just less confusing naming.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
This fixes a bug from commit f3f86e33dc3d ("vfs: Fix pathological
performance case for __alloc_fd()").
v2: refactor to share fd bitmap copying code
Signed-off-by: Eric Biggers <ebiggers3@gmail.com>
We clear the close-on-exec flag when opening and closing files, and the
bit was almost always already clear before. Avoid dirtying the
cacheline if the clearning isn't necessary. That avoids unnecessary
cacheline dirtying and bouncing in multi-socket environments.
Eric Dumazet has a file descriptor benchmark that goes 4% faster from
this on his two-socket machine. It's probably partly superlinear
improvement due to getting slightly less spinlock contention on the
file_lock spinlock due to less work in the critical section.
Tested-by: Eric Dumazet <eric.dumazet@gmail.com>
Al Viro points out that:
> > * [Linux-specific aside] our __alloc_fd() can degrade quite badly
> > with some use patterns. The cacheline pingpong in the bitmap is probably
> > inevitable, unless we accept considerably heavier memory footprint,
> > but we also have a case when alloc_fd() takes O(n) and it's _not_ hard
> > to trigger - close(3);open(...); will have the next open() after that
> > scanning the entire in-use bitmap.
And Eric Dumazet has a somewhat realistic multithreaded microbenchmark
that opens and closes a lot of sockets with minimal work per socket.
This patch largely fixes it. We keep a 2nd-level bitmap of the open
file bitmaps, showing which words are already full. So then we can
traverse that second-level bitmap to efficiently skip already allocated
file descriptors.
On his benchmark, this improves performance by up to an order of
magnitude, by avoiding the excessive open file bitmap scanning.
Tested-and-acked-by: Eric Dumazet <edumazet@google.com>
__fget() does lockless fetch of pointer from the descriptor
table, attempts to grab a reference and treats "it was already
zero" as "it's already gone from the table, we just hadn't
seen the store, let's fail". Unfortunately, that breaks the
atomicity of dup2() - __fget() might see the old pointer,
notice that it's been already dropped and treat that as
"it's closed". What we should be getting is either the
old file or new one, depending whether we come before or after
dup2().
Dmitry had following test failing sometimes :
int fd;
void *Thread(void *x) {
char buf;
int n = read(fd, &buf, 1);
if (n != 1)
exit(printf("read failed: n=%d errno=%d\n", n, errno));
return 0;
int main()
fd = open("/dev/urandom", O_RDONLY);
int fd2 = open("/dev/urandom", O_RDONLY);
if (fd == -1 || fd2 == -1)
exit(printf("open failed\n"));
pthread_t th;
pthread_create(&th, 0, Thread, 0);
if (dup2(fd2, fd) == -1)
exit(printf("dup2 failed\n"));
pthread_join(th, 0);
if (close(fd) == -1)
exit(printf("close failed\n"));
if (close(fd2) == -1)
printf("DONE\n");
return 0;
Mateusz Guzik reported :
Currently obtaining a new file descriptor results in locking fdtable
twice - once in order to reserve a slot and second time to fill it.
Holding the spinlock in __fd_install() is needed in case a resize is
done, or to prevent a resize.
Mateusz provided an RFC patch and a micro benchmark :
http://people.redhat.com/~mguzik/pipebench.c
A resize is an unlikely operation in a process lifetime,
as table size is at least doubled at every resize.
We can use RCU instead of the spinlock.
__fd_install() must wait if a resize is in progress.
The resize must block new __fd_install() callers from starting,
and wait that ongoing install are finished (synchronize_sched())
resize should be attempted by a single thread to not waste resources.
rcu_sched variant is used, as __fd_install() and expand_fdtable() run
from process context.
It gives us a ~30% speedup using pipebench on a dual Intel(R) Xeon(R)
CPU E5-2696 v2 @ 2.50GHz
Reported-by: Mateusz Guzik <mguzik@redhat.com>
Acked-by: Mateusz Guzik <mguzik@redhat.com>
Tested-by: Mateusz Guzik <mguzik@redhat.com>
This patch removes mm->mmap_sem from mm->exe_file read side.
Also it kills dup_mm_exe_file() and moves exe_file duplication into
dup_mmap() where both mmap_sems are locked.
[akpm@linux-foundation.org: fix comment typo]
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Cc: Davidlohr Bueso <dbueso@suse.de>
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
This patch replaces calls to get_unused_fd() with equivalent call to
get_unused_fd_flags(0) to preserve current behavor for existing code.
In a further patch, get_unused_fd() will be removed so that new code
start using get_unused_fd_flags(), with the hope O_CLOEXEC could be
used, either by default or choosen by userspace.
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
Pull RCU updates from Ingo Molnar:
"The main changes in this cycle were:
- changes related to No-CBs CPUs and NO_HZ_FULL
- RCU-tasks implementation
- torture-test updates
- miscellaneous fixes
- locktorture updates
- RCU documentation updates"
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (81 commits)
workqueue: Use cond_resched_rcu_qs macro
workqueue: Add quiescent state between work items
locktorture: Cleanup header usage
locktorture: Cannot hold read and write lock
locktorture: Fix __acquire annotation for spinlock irq
locktorture: Support rwlocks
rcu: Eliminate deadlock between CPU hotplug and expedited grace periods
locktorture: Document boot/module parameters
rcutorture: Rename rcutorture_runnable parameter
locktorture: Add test scenario for rwsem_lock
locktorture: Add test scenario for mutex_lock
locktorture: Make torture scripting account for new _runnable name
locktorture: Introduce torture context
locktorture: Support rwsems
locktorture: Add infrastructure for torturing read locks
torture: Address race in module cleanup
locktorture: Make statistics generic
locktorture: Teach about lock debugging
locktorture: Support mutexes
locktorture: Add documentation
RCU-tasks requires the occasional voluntary context switch
from CPU-bound in-kernel tasks. In some cases, this requires
instrumenting cond_resched(). However, there is some reluctance
to countenance unconditionally instrumenting cond_resched() (see
http://lwn.net/Articles/603252/), so this commit creates a separate
cond_resched_rcu_qs() that may be used in place of cond_resched() in
locations prone to long-duration in-kernel looping.
This commit currently instruments only RCU-tasks. Future possibilities
include also instrumenting RCU, RCU-bh, and RCU-sched in order to reduce
IPI usage.
Pull vfs updates from Al Viro:
"The first vfs pile, with deep apologies for being very late in this
window.
Assorted cleanups and fixes, plus a large preparatory part of iov_iter
work. There's a lot more of that, but it'll probably go into the next
merge window - it *does* shape up nicely, removes a lot of
boilerplate, gets rid of locking inconsistencie between aio_write and
splice_write and I hope to get Kent's direct-io rewrite merged into
the same queue, but some of the stuff after this point is having
(mostly trivial) conflicts with the things already merged into
mainline and with some I want more testing.
This one passes LTP and xfstests without regressions, in addition to
usual beating. BTW, readahead02 in ltp syscalls testsuite has started
giving failures since "mm/readahead.c: fix readahead failure for
memoryless NUMA nodes and limit readahead pages" - might be a false
positive, might be a real regression..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
missing bits of "splice: fix racy pipe->buffers uses"
cifs: fix the race in cifs_writev()
ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure
kill generic_file_buffered_write()
ocfs2_file_aio_write(): switch to generic_perform_write()
ceph_aio_write(): switch to generic_perform_write()
xfs_file_buffered_aio_write(): switch to generic_perform_write()
export generic_perform_write(), start getting rid of generic_file_buffer_write()
generic_file_direct_write(): get rid of ppos argument
btrfs_file_aio_write(): get rid of ppos
kill the 5th argument of generic_file_buffered_write()
kill the 4th argument of __generic_file_aio_write()
lustre: don't open-code kernel_recvmsg()
ocfs2: don't open-code kernel_recvmsg()
drbd: don't open-code kernel_recvmsg()
constify blk_rq_map_user_iov() and friends
lustre: switch to kernel_sendmsg()
ocfs2: don't open-code kernel_sendmsg()
take iov_iter stuff to mm/iov_iter.c
process_vm_access: tidy up a bit
the only thing it's doing these days is calculation of
upper limit for fs.nr_open sysctl and that can be done
statically
"Main changes:
- Torture-test changes, including refactoring of rcutorture and
introduction of a vestigial locktorture.
- Real-time latency fixes.
- Documentation updates.
- Miscellaneous fixes"
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (77 commits)
rcu: Provide grace-period piggybacking API
rcu: Ensure kernel/rcu/rcu.h can be sourced/used stand-alone
rcu: Fix sparse warning for rcu_expedited from kernel/ksysfs.c
notifier: Substitute rcu_access_pointer() for rcu_dereference_raw()
Documentation/memory-barriers.txt: Clarify release/acquire ordering
rcutorture: Save kvm.sh output to log
rcutorture: Add a lock_busted to test the test
rcutorture: Place kvm-test-1-run.sh output into res directory
rcutorture: Rename TREE_RCU-Kconfig.txt
locktorture: Add kvm-recheck.sh plug-in for locktorture
rcutorture: Gracefully handle NULL cleanup hooks
locktorture: Add vestigial locktorture configuration
rcutorture: Introduce "rcu" directory level underneath configs
rcutorture: Rename kvm-test-1-rcu.sh
rcutorture: Remove RCU dependencies from ver_functions.sh API
rcutorture: Create CFcommon file for common Kconfig parameters
rcutorture: Create config files for scripted test-the-test testing
rcutorture: Add an rcu_busted to test the test
locktorture: Add a lock-torture kernel module
rcutorture: Abstract kvm-recheck.sh
Commit bd2a31d522344 ("get rid of fget_light()") introduced the
__fdget_pos() function, which returns the resulting file pointer and
fdput flags combined in an 'unsigned long'. However, it also changed the
behavior to return files with FMODE_PATH set, which shouldn't happen
because read(), write(), lseek(), etc. aren't allowed on such files.
This commit restores the old behavior.
This regression actually had no effect on read() and write() since
FMODE_READ and FMODE_WRITE are not set on file descriptors opened with
O_PATH, but it did cause lseek() on a file descriptor opened with O_PATH
to fail with ESPIPE rather than EBADF.
instead of returning the flags by reference, we can just have the
low-level primitive return those in lower bits of unsigned long,
with struct file * derived from the rest.
(Trivial patch.)
If the code is looking at the RCU-protected pointer itself, but not
dereferencing it, the rcu_dereference() functions can be downgraded to
rcu_access_pointer(). This commit makes this downgrade in __alloc_fd(),
which simply compares the RCU-protected pointer against NULL with no
dereferencing.
Cc: linux-fsdevel@vger.kernel.org
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Recently due to a spike in connections per second memcached on 3
separate boxes triggered the OOM killer from accept. At the time the
OOM killer was triggered there was 4GB out of 36GB free in zone 1. The
problem was that alloc_fdtable was allocating an order 3 page (32KiB) to
hold a bitmap, and there was sufficient fragmentation that the largest
page available was 8KiB.
I find the logic that PAGE_ALLOC_COSTLY_ORDER can't fail pretty dubious
but I do agree that order 3 allocations are very likely to succeed.
There are always pathologies where order > 0 allocations can fail when
there are copious amounts of free memory available. Using the pigeon
hole principle it is easy to show that it requires 1 page more than 50%
of the pages being free to guarantee an order 1 (8KiB) allocation will
succeed, 1 page more than 75% of the pages being free to guarantee an
order 2 (16KiB) allocation will succeed and 1 page more than 87.5% of
the pages being free to guarantee an order 3 allocate will succeed.
A server churning memory with a lot of small requests and replies like
memcached is a common case that if anything can will skew the odds
against large pages being available.
Therefore let's not give external applications a practical way to kill
linux server applications, and specify __GFP_NORETRY to the kmalloc in
alloc_fdmem. Unless I am misreading the code and by the time the code
reaches should_alloc_retry in __alloc_pages_slowpath (where
__GFP_NORETRY becomes signification). We have already tried everything
reasonable to allocate a page and the only thing left to do is wait. So
not waiting and falling back to vmalloc immediately seems like the
reasonable thing to do even if there wasn't a chance of triggering the
OOM killer.
Acked-by: David Rientjes <rientjes@google.com>
Cc: Cong Wang <cwang@twopensource.com>
Cc: <stable@vger.kernel.org>
The slow path in __fget_light() can use __fget() to avoid the
code duplication. Saves 232 bytes.
Apart from FMODE_PATH check fget_light() and fget_raw_light() are
identical, shift the code into the new helper, __fget_light(fd, mask).
Saves 208 bytes.
Apart from FMODE_PATH check fget() and fget_raw() are identical,
shift the code into the new simple helper, __fget(fd, mask). Saves
160 bytes.
put_files_struct() and close_files() do rcu_read_lock() to make
rcu_dereference_check_fdtable() happy.
This looks a bit ugly, files_fdtable() just reads the pointer,
we can simply use rcu_dereference_raw() to avoid the warning.
The patch also changes close_files() to return fdt, this avoids
another rcu_read_lock()/files_fdtable() in put_files_struct().
I think close_files() needs more cleanups:
- we do not need xchg() exactly because we are the last
user of this files_struct
- "if (file)" should be turned into WARN_ON(!file)
rcu_my_thread_group_empty()
rcu_dereference_check_fdtable() looks very wrong,
1. rcu_my_thread_group_empty() was added by 844b9a8707f1 "vfs: fix
RCU-lockdep false positive due to /proc" but it doesn't really
fix the problem. A CLONE_THREAD (without CLONE_FILES) task can
hit the same race with get_files_struct().
And otoh rcu_my_thread_group_empty() can suppress the correct
warning if the caller is the CLONE_FILES (without CLONE_THREAD)
task.
2. files->count == 1 check is not really right too. Even if this
files_struct is not shared it is not safe to access it lockless
unless the caller is the owner.
Otoh, this check is sub-optimal. files->count == 0 always means
it is safe to use it lockless even if files != current->files,
but put_files_struct() has to take rcu_read_lock(). See the next
patch.
This patch removes the buggy checks and turns fcheck_files() into
__fcheck_files() which uses rcu_dereference_raw(), the "unshared"
callers, fget_light() and fget_raw_light(), can use it to avoid
the warning from RCU-lockdep.
fcheck_files() is trivially reimplemented as rcu_lockdep_assert()
plus __fcheck_files().
The static lock initializers want to be fed the proper name of the
lock and not some random string. In mainline random strings are
obfuscating the readability of debug output, but for RT they prevent
the spinlock substitution. Fix it up.
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the last of the __dev* markings from the kernel from
a variety of different, tiny, places.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull big execve/kernel_thread/fork unification series from Al Viro:
"All architectures are converted to new model. Quite a bit of that
stuff is actually shared with architecture trees; in such cases it's
literally shared branch pulled by both, not a cherry-pick.
A lot of ugliness and black magic is gone (-3KLoC total in this one):
- kernel_thread()/kernel_execve()/sys_execve() redesign.
We don't do syscalls from kernel anymore for either kernel_thread()
or kernel_execve():
kernel_thread() is essentially clone(2) with callback run before we
return to userland, the callbacks either never return or do
successful do_execve() before returning.
kernel_execve() is a wrapper for do_execve() - it doesn't need to
do transition to user mode anymore.
As a result kernel_thread() and kernel_execve() are
arch-independent now - they live in kernel/fork.c and fs/exec.c
resp. sys_execve() is also in fs/exec.c and it's completely
architecture-independent.
- daemonize() is gone, along with its parts in fs/*.c
- struct pt_regs * is no longer passed to do_fork/copy_process/
copy_thread/do_execve/search_binary_handler/->load_binary/do_coredump.
- sys_fork()/sys_vfork()/sys_clone() unified; some architectures
still need wrappers (ones with callee-saved registers not saved in
pt_regs on syscall entry), but the main part of those suckers is in
kernel/fork.c now."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (113 commits)
do_coredump(): get rid of pt_regs argument
print_fatal_signal(): get rid of pt_regs argument
ptrace_signal(): get rid of unused arguments
get rid of ptrace_signal_deliver() arguments
new helper: signal_pt_regs()
unify default ptrace_signal_deliver
flagday: kill pt_regs argument of do_fork()
death to idle_regs()
don't pass regs to copy_process()
flagday: don't pass regs to copy_thread()
bfin: switch to generic vfork, get rid of pointless wrappers
xtensa: switch to generic clone()
openrisc: switch to use of generic fork and clone
unicore32: switch to generic clone(2)
score: switch to generic fork/vfork/clone
c6x: sanitize copy_thread(), get rid of clone(2) wrapper, switch to generic clone()
take sys_fork/sys_vfork/sys_clone prototypes to linux/syscalls.h
mn10300: switch to generic fork/vfork/clone
h8300: switch to generic fork/vfork/clone
tile: switch to generic clone()
arch/microblaze/include/asm/Kbuild
Noticed by Pavel Roskin; the thing in his patch I disagree with
was compensating for that shite in callbacks instead of fixing
it once in the iterator itself.
Pull misc VFS fixes from Al Viro:
"Remove a bogus BUG_ON() that can trigger spuriously + alpha bits of
do_mount() constification I'd missed during the merge window."
This pull request came in a week ago, I missed it for some reason.
kill bogus BUG_ON() in do_close_on_exec()
missing const in alpha callers of do_mount()
It can be legitimately triggered via procfs access. Now, at least
2 of 3 of get_files_struct() callers in procfs are useless, but
when and if we get rid of those we can always add WARN_ON() here.
BUG_ON() at that spot is simply wrong.
Jack Lin reports that the error return from dup3() for the RLIMIT_NOFILE
case changed incorrectly after 3.6.
The culprit is commit f33ff9927f42 ("take rlimit check to callers of
expand_files()") which when it moved the "return -EMFILE" out to the
caller, didn't notice that the dup3() had special code to turn the
EMFILE return into EBADF.
The replace_fd() helper that got added later then inherited the bug too.
Reported-by: Jack Lin <linliangjie@huawei.com>
[ Noted more bugs, wrote proper changelog, fixed up typos - Linus ]
I have tested the attached patch to fix the dup3 regression.
Rich.
From 0944e30e12dec6544b3602626b60ff412375c78f Mon Sep 17 00:00:00 2001
Date: Tue, 9 Oct 2012 14:42:45 +0100
Subject: [PATCH] dup3: Return an error when oldfd == newfd.
The following commit:
commit fe17f22d7fd0e344ef6447238f799bb49f670c6f
Author: Al Viro <viro@zeniv.linux.org.uk>
Date: Tue Aug 21 11:48:11 2012 -0400
take purely descriptor-related stuff from fcntl.c to file.c
was supposed to be just code motion, but it dropped the following two
lines:
if (unlikely(oldfd == newfd))
return -EINVAL;
from the dup3 system call. dup3 is not specified by POSIX, so Linux
can do what it likes. However the POSIX proposal for dup3 [1] states
that it should return an error if oldfd == newfd.
[1] http://austingroupbugs.net/view.php?id=411
Signed-off-by: Richard W.M. Jones <rjones@redhat.com>
Tested-by: Richard W.M. Jones <rjones@redhat.com>
descriptor-related parts of daemonize, done right. As the
result we simplify the locking rules for ->files - we
hold task_lock in *all* cases when we modify ->files.
iterates through the opened files in given descriptor table,
calling a supplied function; we stop once non-zero is returned.
Callback gets struct file *, descriptor number and const void *
argument passed to iterator. It is called with files->file_lock
held, so it is not allowed to block.
tty_io, netprio_cgroup and selinux flush_unauthorized_files()
converted to its use.
no callers outside of fs/file.c left
nobody uses those outside anymore.
analog of dup2(), except that it takes struct file * as source.
... and add cond_resched() there, while we are at it. We can
get large latencies as is...
