path: root/fs/file_table.c
2015-08-07fs, file table: reinit files_stat.max_files after deferred memory initialisationMel Gorman
Dave Hansen reported the following; My laptop has been behaving strangely with 4.2-rc2. Once I log in to my X session, I start getting all kinds of strange errors from applications and see this in my dmesg: VFS: file-max limit 8192 reached The problem is that the file-max is calculated before memory is fully initialised and miscalculates how much memory the kernel is using. This patch recalculates file-max after deferred memory initialisation. Note that using memory hotplug infrastructure would not have avoided this problem as the value is not recalculated after memory hot-add. 4.1: files_stat.max_files = 6582781 4.2-rc2: files_stat.max_files = 8192 4.2-rc2 patched: files_stat.max_files = 6562467 Small differences with the patch applied and 4.1 but not enough to matter. Signed-off-by: Mel Gorman <mgorman@suse.de> Reported-by: Dave Hansen <dave.hansen@intel.com> Cc: Nicolai Stange <nicstange@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Alex Ng <alexng@microsoft.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-23remove the pointless include of lglock.hAl Viro
2015-04-11->aio_read and ->aio_write removedAl Viro
no remaining users Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "The big thing in this pile is Eric's unmount-on-rmdir series; we finally have everything we need for that. The final piece of prereqs is delayed mntput() - now filesystem shutdown always happens on shallow stack. Other than that, we have several new primitives for iov_iter (Matt Wilcox, culled from his XIP-related series) pushing the conversion to ->read_iter()/ ->write_iter() a bit more, a bunch of fs/dcache.c cleanups and fixes (including the external name refcounting, which gives consistent behaviour of d_move() wrt procfs symlinks for long and short names alike) and assorted cleanups and fixes all over the place. This is just the first pile; there's a lot of stuff from various people that ought to go in this window. Starting with unionmount/overlayfs mess... ;-/" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (60 commits) fs/file_table.c: Update alloc_file() comment vfs: Deduplicate code shared by xattr system calls operating on paths reiserfs: remove pointless forward declaration of struct nameidata don't need that forward declaration of struct nameidata in dcache.h anymore take dname_external() into fs/dcache.c let path_init() failures treated the same way as subsequent link_path_walk() fix misuses of f_count() in ppp and netlink ncpfs: use list_for_each_entry() for d_subdirs walk vfs: move getname() from callers to do_mount() gfs2_atomic_open(): skip lookups on hashed dentry [infiniband] remove pointless assignments gadgetfs: saner API for gadgetfs_create_file() f_fs: saner API for ffs_sb_create_file() jfs: don't hash direct inode [s390] remove pointless assignment of ->f_op in vmlogrdr ->open() ecryptfs: ->f_op is never NULL android: ->f_op is never NULL nouveau: __iomem misannotations missing annotation in fs/file.c fs: namespace: suppress 'may be used uninitialized' warnings ...
2014-10-12fs/file_table.c: Update alloc_file() commentEric Biggers
This comment is 5 years outdated; init_file() no longer exists. Signed-off-by: Eric Biggers <ebiggers3@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-08percpu_counter: add @gfp to percpu_counter_init()Tejun Heo
Percpu allocator now supports allocation mask. Add @gfp to percpu_counter_init() so that !GFP_KERNEL allocation masks can be used with percpu_counters too. We could have left percpu_counter_init() alone and added percpu_counter_init_gfp(); however, the number of users isn't that high and introducing _gfp variants to all percpu data structures would be quite ugly, so let's just do the conversion. This is the one with the most users. Other percpu data structures are a lot easier to convert. This patch doesn't make any functional difference. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Jan Kara <jack@suse.cz> Acked-by: "David S. Miller" <davem@davemloft.net> Cc: x86@kernel.org Cc: Jens Axboe <axboe@kernel.dk> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org>
2014-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "This the bunch that sat in -next + lock_parent() fix. This is the minimal set; there's more pending stuff. In particular, I really hope to get acct.c fixes merged this cycle - we need that to deal sanely with delayed-mntput stuff. In the next pile, hopefully - that series is fairly short and localized (kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more iov_iter work. Most of prereqs for ->splice_write with sane locking order are there and Kent's dio rewrite would also fit nicely on top of this pile" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits) lock_parent: don't step on stale ->d_parent of all-but-freed one kill generic_file_splice_write() ceph: switch to iter_file_splice_write() shmem: switch to iter_file_splice_write() nfs: switch to iter_splice_write_file() fs/splice.c: remove unneeded exports ocfs2: switch to iter_file_splice_write() ->splice_write() via ->write_iter() bio_vec-backed iov_iter optimize copy_page_{to,from}_iter() bury generic_file_aio_{read,write} lustre: get rid of messing with iovecs ceph: switch to ->write_iter() ceph_sync_direct_write: stop poking into iov_iter guts ceph_sync_read: stop poking into iov_iter guts new helper: copy_page_from_iter() fuse: switch to ->write_iter() btrfs: switch to ->write_iter() ocfs2: switch to ->write_iter() xfs: switch to ->write_iter() ...
2014-06-06fs: convert use of typedef ctl_table to struct ctl_tableJoe Perches
This typedef is unnecessary and should just be removed. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-06new methods: ->read_iter() and ->write_iter()Al Viro
Beginning to introduce those. Just the callers for now, and it's clumsier than it'll eventually become; once we finish converting aio_read and aio_write instances, the things will get nicer. For now, these guys are in parallel to ->aio_read() and ->aio_write(); they take iocb and iov_iter, with everything in iov_iter already validated. File offset is passed in iocb->ki_pos, iov/nr_segs - in iov_iter. Main concerns in that series are stack footprint and ability to split the damn thing cleanly. [fix from Peter Ujfalusi <peter.ujfalusi@ti.com> folded] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06replace checking for ->read/->aio_read presence with check in ->f_modeAl Viro
Since we are about to introduce new methods (read_iter/write_iter), the tests in a bunch of places would have to grow inconveniently. Check once (at open() time) and store results in ->f_mode as FMODE_CAN_READ and FMODE_CAN_WRITE resp. It might end up being a temporary measure - once everything switches from ->aio_{read,write} to ->{read,write}_iter it might make sense to return to open-coded checks. We'll see... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "The first vfs pile, with deep apologies for being very late in this window. Assorted cleanups and fixes, plus a large preparatory part of iov_iter work. There's a lot more of that, but it'll probably go into the next merge window - it *does* shape up nicely, removes a lot of boilerplate, gets rid of locking inconsistencie between aio_write and splice_write and I hope to get Kent's direct-io rewrite merged into the same queue, but some of the stuff after this point is having (mostly trivial) conflicts with the things already merged into mainline and with some I want more testing. This one passes LTP and xfstests without regressions, in addition to usual beating. BTW, readahead02 in ltp syscalls testsuite has started giving failures since "mm/readahead.c: fix readahead failure for memoryless NUMA nodes and limit readahead pages" - might be a false positive, might be a real regression..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) missing bits of "splice: fix racy pipe->buffers uses" cifs: fix the race in cifs_writev() ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure kill generic_file_buffered_write() ocfs2_file_aio_write(): switch to generic_perform_write() ceph_aio_write(): switch to generic_perform_write() xfs_file_buffered_aio_write(): switch to generic_perform_write() export generic_perform_write(), start getting rid of generic_file_buffer_write() generic_file_direct_write(): get rid of ppos argument btrfs_file_aio_write(): get rid of ppos kill the 5th argument of generic_file_buffered_write() kill the 4th argument of __generic_file_aio_write() lustre: don't open-code kernel_recvmsg() ocfs2: don't open-code kernel_recvmsg() drbd: don't open-code kernel_recvmsg() constify blk_rq_map_user_iov() and friends lustre: switch to kernel_sendmsg() ocfs2: don't open-code kernel_sendmsg() take iov_iter stuff to mm/iov_iter.c process_vm_access: tidy up a bit ...
2014-04-04Merge branch 'locks-3.15' of git://git.samba.org/jlayton/linuxLinus Torvalds
Pull file locking updates from Jeff Layton: "Highlights: - maintainership change for fs/locks.c. Willy's not interested in maintaining it these days, and is OK with Bruce and I taking it. - fix for open vs setlease race that Al ID'ed - cleanup and consolidation of file locking code - eliminate unneeded BUG() call - merge of file-private lock implementation" * 'locks-3.15' of git://git.samba.org/jlayton/linux: locks: make locks_mandatory_area check for file-private locks locks: fix locks_mandatory_locked to respect file-private locks locks: require that flock->l_pid be set to 0 for file-private locks locks: add new fcntl cmd values for handling file private locks locks: skip deadlock detection on FL_FILE_PVT locks locks: pass the cmd value to fcntl_getlk/getlk64 locks: report l_pid as -1 for FL_FILE_PVT locks locks: make /proc/locks show IS_FILE_PVT locks as type "FLPVT" locks: rename locks_remove_flock to locks_remove_file locks: consolidate checks for compatible filp->f_mode values in setlk handlers locks: fix posix lock range overflow handling locks: eliminate BUG() call when there's an unexpected lock on file close locks: add __acquires and __releases annotations to locks_start and locks_stop locks: remove "inline" qualifier from fl_link manipulation functions locks: clean up comment typo locks: close potential race between setlease and open MAINTAINERS: update entry for fs/locks.c
2014-04-01get rid of files_defer_init()Al Viro
the only thing it's doing these days is calculation of upper limit for fs.nr_open sysctl and that can be done statically Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01mark struct file that had write access grabbed by open()Al Viro
new flag in ->f_mode - FMODE_WRITER. Set by do_dentry_open() in case when it has grabbed write access, checked by __fput() to decide whether it wants to drop the sucker. Allows to stop bothering with mnt_clone_write() in alloc_file(), along with fewer special_file() checks. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01get rid of DEBUG_WRITECOUNTAl Viro
it only makes control flow in __fput() and friends more convoluted. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-01don't bother with {get,put}_write_access() on non-regular filesAl Viro
it's pointless and actually leads to wrong behaviour in at least one moderately convoluted case (pipe(), close one end, try to get to another via /proc/*/fd and run into ETXTBUSY). Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-03-31locks: rename locks_remove_flock to locks_remove_fileJeff Layton
This function currently removes leases in addition to flock locks and in a later patch we'll have it deal with file-private locks too. Rename it to locks_remove_file to indicate that it removes locks that are associated with a particular struct file, and not just flock locks. Acked-by: J. Bruce Fields <bfields@fieldses.org> Signed-off-by: Jeff Layton <jlayton@redhat.com>
2014-03-10vfs: atomic f_pos accesses as per POSIXLinus Torvalds
Our write() system call has always been atomic in the sense that you get the expected thread-safe contiguous write, but we haven't actually guaranteed that concurrent writes are serialized wrt f_pos accesses, so threads (or processes) that share a file descriptor and use "write()" concurrently would quite likely overwrite each others data. This violates POSIX.1-2008/SUSv4 Section XSI 2.9.7 that says: "2.9.7 Thread Interactions with Regular File Operations All of the following functions shall be atomic with respect to each other in the effects specified in POSIX.1-2008 when they operate on regular files or symbolic links: [...]" and one of the effects is the file position update. This unprotected file position behavior is not new behavior, and nobody has ever cared. Until now. Yongzhi Pan reported unexpected behavior to Michael Kerrisk that was due to this. This resolves the issue with a f_pos-specific lock that is taken by read/write/lseek on file descriptors that may be shared across threads or processes. Reported-by: Yongzhi Pan <panyongzhi@gmail.com> Reported-by: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-11-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "All kinds of stuff this time around; some more notable parts: - RCU'd vfsmounts handling - new primitives for coredump handling - files_lock is gone - Bruce's delegations handling series - exportfs fixes plus misc stuff all over the place" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (101 commits) ecryptfs: ->f_op is never NULL locks: break delegations on any attribute modification locks: break delegations on link locks: break delegations on rename locks: helper functions for delegation breaking locks: break delegations on unlink namei: minor vfs_unlink cleanup locks: implement delegations locks: introduce new FL_DELEG lock flag vfs: take i_mutex on renamed file vfs: rename I_MUTEX_QUOTA now that it's not used for quotas vfs: don't use PARENT/CHILD lock classes for non-directories vfs: pull ext4's double-i_mutex-locking into common code exportfs: fix quadratic behavior in filehandle lookup exportfs: better variable name exportfs: move most of reconnect_path to helper function exportfs: eliminate unused "noprogress" counter exportfs: stop retrying once we race with rename/remove exportfs: clear DISCONNECTED on all parents sooner exportfs: more detailed comment for path_reconnect ...
2013-11-09get rid of s_files and files_lockAl Viro
The only thing we need it for is alt-sysrq-r (emergency remount r/o) and these days we can do just as well without going through the list of files. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-10-24file->f_op is never NULL...Al Viro
2013-10-20nfsd regression since delayed fput()Al Viro
Background: nfsd v[23] had throughput regression since delayed fput went in; every read or write ends up doing fput() and we get a pair of extra context switches out of that (plus quite a bit of work in queue_work itselfi, apparently). Use of schedule_delayed_work() gives it a chance to accumulate a bit before we do __fput() on all of them. I'm not too happy about that solution, but... on at least one real-world setup it reverts about 10% throughput loss we got from switch to delayed fput. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-09-11fs/file_table.c:fput(): make comment more truthfulAndrew Morton
Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Andrey Vagin <avagin@openvz.org> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-03only regular files with FMODE_WRITE need to be on s_filesAl Viro
2013-07-13fput: turn "list_head delayed_fput_list" into llist_headOleg Nesterov
fput() and delayed_fput() can use llist and avoid the locking. This is unlikely path, it is not that this change can improve the performance, but this way the code looks simpler. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrey Vagin <avagin@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: David Howells <dhowells@redhat.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-13fs/file_table.c:fput(): add commentAndrew Morton
A missed update to "fput: task_work_add() can fail if the caller has passed exit_task_work()". Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrey Vagin <avagin@openvz.org> Cc: David Howells <dhowells@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-29Replace a bunch of file->dentry->d_inode refs with file_inode()David Howells
Replace a bunch of file->dentry->d_inode refs with file_inode(). In __fput(), use file->f_inode instead so as not to be affected by any tricks that file_inode() might grow. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-15fput: task_work_add() can fail if the caller has passed exit_task_work()Oleg Nesterov
fput() assumes that it can't be called after exit_task_work() but this is not true, for example free_ipc_ns()->shm_destroy() can do this. In this case fput() silently leaks the file. Change it to fallback to delayed_fput_work if task_work_add() fails. The patch looks complicated but it is not, it changes the code from if (PF_KTHREAD) { schedule_work(...); return; } task_work_add(...) to if (!PF_KTHREAD) { if (!task_work_add(...)) return; /* fallback */ } schedule_work(...); As for shm_destroy() in particular, we could make another fix but I think this change makes sense anyway. There could be another similar user, it is not safe to assume that task_work_add() can't fail. Reported-by: Andrey Vagin <avagin@openvz.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-03-01cache the value of file_inode() in struct fileAl Viro
Note that this thing does *not* contribute to inode refcount; it's pinned down by dentry. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-22fs: Preserve error code in get_empty_filp(), part 2Anatol Pomozov
Allocating a file structure in function get_empty_filp() might fail because of several reasons: - not enough memory for file structures - operation is not allowed - user is over its limit Currently the function returns NULL in all cases and we loose the exact reason of the error. All callers of get_empty_filp() assume that the function can fail with ENFILE only. Return error through pointer. Change all callers to preserve this error code. [AV: cleaned up a bit, carved the get_empty_filp() part out into a separate commit (things remaining here deal with alloc_file()), removed pipe(2) behaviour change] Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-22propagate error from get_empty_filp() to its callersAl Viro
Based on parts from Anatol's patch (the rest is the next commit). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-22new helper: file_inode(file)Al Viro
2012-12-20fs: Fix imbalance in freeze protection in mark_files_ro()Jan Kara
File descriptors (even those for writing) do not hold freeze protection. Thus mark_files_ro() must call __mnt_drop_write() to only drop protection against remount read-only. Calling mnt_drop_write_file() as we do now results in: [ BUG: bad unlock balance detected! ] 3.7.0-rc6-00028-g88e75b6 #101 Not tainted ------------------------------------- kworker/1:2/79 is trying to release lock (sb_writers) at: [<ffffffff811b33b4>] mnt_drop_write+0x24/0x30 but there are no more locks to release! Reported-by: Zdenek Kabelac <zkabelac@redhat.com> CC: stable@vger.kernel.org Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-10lglock: add DEFINE_STATIC_LGLOCK()Lai Jiangshan
When the lglock doesn't need to be exported we can use DEFINE_STATIC_LGLOCK(). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-02Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "Highlights: - Integrity: add local fs integrity verification to detect offline attacks - Integrity: add digital signature verification - Simple stacking of Yama with other LSMs (per LSS discussions) - IBM vTPM support on ppc64 - Add new driver for Infineon I2C TIS TPM - Smack: add rule revocation for subject labels" Fixed conflicts with the user namespace support in kernel/auditsc.c and security/integrity/ima/ima_policy.c. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (39 commits) Documentation: Update git repository URL for Smack userland tools ima: change flags container data type Smack: setprocattr memory leak fix Smack: implement revoking all rules for a subject label Smack: remove task_wait() hook. ima: audit log hashes ima: generic IMA action flag handling ima: rename ima_must_appraise_or_measure audit: export audit_log_task_info tpm: fix tpm_acpi sparse warning on different address spaces samples/seccomp: fix 31 bit build on s390 ima: digital signature verification support ima: add support for different security.ima data types ima: add ima_inode_setxattr/removexattr function and calls ima: add inode_post_setattr call ima: replace iint spinblock with rwlock/read_lock ima: allocating iint improvements ima: add appraise action keywords and default rules ima: integrity appraisal extension vfs: move ima_file_free before releasing the file ...
2012-09-26take fget() and friends to fs/file.cAl Viro
2012-09-07vfs: move ima_file_free before releasing the fileMimi Zohar
ima_file_free(), called on __fput(), currently flags files that have changed, so that the file is re-measured. For appraising a files's integrity, the file's hash must be re-calculated and stored in the 'security.ima' xattr to reflect any changes. This patch moves the ima_file_free() call to before releasing the file in preparation of ima-appraisal measuring the file and updating the 'security.ima' xattr. Signed-off-by: Mimi Zohar <zohar@us.ibm.com> Acked-by: Serge Hallyn <serge.hallyn@ubuntu.com> Acked-by: Dmitry Kasatkin <dmitry.kasatkin@intel.com>
2012-07-31fs: Add freezing handling to mnt_want_write() / mnt_drop_write()Jan Kara
Most of places where we want freeze protection coincides with the places where we also have remount-ro protection. So make mnt_want_write() and mnt_drop_write() (and their _file alternative) prevent freezing as well. For the few cases that are really interested only in remount-ro protection provide new function variants. BugLink: https://bugs.launchpad.net/bugs/897421 Tested-by: Kamal Mostafa <kamal@canonical.com> Tested-by: Peter M. Petrakis <peter.petrakis@canonical.com> Tested-by: Dann Frazier <dann.frazier@canonical.com> Tested-by: Massimo Morana <massimo.morana@canonical.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-29uninline file_free_rcu()Al Viro
What inline? Its only use is passing its address to call_rcu(), for fuck sake! Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-22switch fput to task_work_addAl Viro
... and schedule_work() for interrupt/kernel_thread callers (and yes, now it *is* OK to call from interrupt). We are guaranteed that __fput() will be done before we return to userland (or exit). Note that for fput() from a kernel thread we get an async behaviour; it's almost always OK, but sometimes you might need to have __fput() completed before you do anything else. There are two mechanisms for that - a general barrier (flush_delayed_fput()) and explicit __fput_sync(). Both should be used with care (as was the case for fput() from kernel threads all along). See comments in fs/file_table.c for details. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14mark_files_ro(): don't bother with mntget/mntputAl Viro
mnt_drop_write_file() is safe under any lock Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-29brlocks/lglocks: API cleanupsAndi Kleen
lglocks and brlocks are currently generated with some complicated macros in lglock.h. But there's no reason to not just use common utility functions and put all the data into a common data structure. In preparation, this patch changes the API to look more like normal function calls with pointers, not magic macros. The patch is rather large because I move over all users in one go to keep it bisectable. This impacts the VFS somewhat in terms of lines changed. But no actual behaviour change. [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-29brlocks/lglocks: turn into functionsAndi Kleen
lglocks and brlocks are currently generated with some complicated macros in lglock.h. But there's no reason to not just use common utility functions and put all the data into a common data structure. Since there are at least two users it makes sense to share this code in a library. This is also easier maintainable than a macro forest. This will also make it later possible to dynamically allocate lglocks and also use them in modules (this would both still need some additional, but now straightforward, code) [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-20vfs: drop_file_write_access() made staticAl Viro
2012-01-06vfs: prevent remount read-only if pending removesMiklos Szeredi
If there are any inodes on the super block that have been unlinked (i_nlink == 0) but have not yet been deleted then prevent the remounting the super block read-only. Reported-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: fix cdev leak on O_PATH final fput()
2011-03-16fix cdev leak on O_PATH final fput()Miklos Szeredi
__fput doesn't need a cdev_put() for O_PATH handles. Signed-off-by: mszeredi@suse.cz Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (33 commits) AppArmor: kill unused macros in lsm.c AppArmor: cleanup generated files correctly KEYS: Add an iovec version of KEYCTL_INSTANTIATE KEYS: Add a new keyctl op to reject a key with a specified error code KEYS: Add a key type op to permit the key description to be vetted KEYS: Add an RCU payload dereference macro AppArmor: Cleanup make file to remove cruft and make it easier to read SELinux: implement the new sb_remount LSM hook LSM: Pass -o remount options to the LSM SELinux: Compute SID for the newly created socket SELinux: Socket retains creator role and MLS attribute SELinux: Auto-generate security_is_socket_class TOMOYO: Fix memory leak upon file open. Revert "selinux: simplify ioctl checking" selinux: drop unused packet flow permissions selinux: Fix packet forwarding checks on postrouting selinux: Fix wrong checks for selinux_policycap_netpeer selinux: Fix check for xfrm selinux context algorithm ima: remove unnecessary call to ima_must_measure IMA: remove IMA imbalance checking ...
2011-03-15Allow passing O_PATH descriptors via SCM_RIGHTS datagramsAl Viro
Just need to make sure that AF_UNIX garbage collector won't confuse O_PATHed socket on filesystem for real AF_UNIX opened socket. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
