path: root/fs/freevxfs/vxfs_olt.c
2016-06-01freevxfs: handle big endian HP-UX file systemsKrzysztof Błaszkowski
To support VxFS filesystems from HP-UX on x86 systems we need to implement byte swapping, and to keep support for Unixware filesystems it needs to be the complicated dual-endian kind ala sysvfs. To do this properly we have to split the on disk and in-core inode so that we can keep the in-core one in native endianness. All other structures are byteswapped on demand. Signed-off-by: Krzysztof Błaszkowski <kb@sysmikro.com.pl> [hch: make spare happy] Signed-off-by: Christoph Hellwig <hch@lst.de>
2006-04-02BUG_ON() Conversion in fs/freevxfs/Eric Sesterhenn
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-11-08fs/freevxfs/: add #include'sAdrian Bunk
Every file should #include the headers containing the prototypes for it's global functions. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-06-30[PATCH] freevxfs: minor cleanupsPekka Enberg
This patch addresses the following minor issues: - Typo in printk - Redundant casts - Use C99 struct initializers instead of memset - Parenthesis around return value - Use inline instead of __inline__ Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
