Add missing dentry initialization to root dentry.
Fixes: f75fdf22b0a8 ("fuse: don't use ->d_time")
Reported-by: Andreas Reis <andreas.reis@gmail.com>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
Only two flags: "default_permissions" and "allow_other". All other flags
are handled via bitfields. So convert these two as well. They don't
change during the lifetime of the filesystem, so this is quite safe.
Add a new INIT flag, FUSE_POSIX_ACL, for negotiating ACL support with
userspace. When it is set in the INIT response, ACL support will be
enabled. ACL support also implies "default_permissions".
When ACL support is enabled, the kernel will cache and have responsibility
for enforcing ACLs. ACL xattrs will be passed to userspace, which is
responsible for updating the ACLs in the filesystem, keeping the file mode
in sync, and inheritance of default ACLs when new filesystem nodes are
created.
Signed-off-by: Seth Forshee <seth.forshee@canonical.com>
Only userspace filesystem can do the killing of suid/sgid without races.
So introduce an INIT flag and negotiate support for this.
In preparation for posix acl support, rework fuse to use xattr handlers and
the generic setxattr/getxattr/listxattr callbacks. Split the xattr code
out into it's own file, and promote symbols to module-global scope as
needed.
Functionally these changes have no impact, as fuse still uses a single
handler for all xattrs which uses the old callbacks.
Pull qstr constification updates from Al Viro:
"Fairly self-contained bunch - surprising lot of places passes struct
qstr * as an argument when const struct qstr * would suffice; it
complicates analysis for no good reason.
I'd prefer to feed that separately from the assorted fixes (those are
in #for-linus and with somewhat trickier topology)"
* 'work.const-qstr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
qstr: constify instances in adfs
qstr: constify instances in lustre
qstr: constify instances in f2fs
qstr: constify instances in ext2
qstr: constify instances in vfat
qstr: constify instances in procfs
qstr: constify instances in fuse
qstr constify instances in fs/dcache.c
qstr: constify instances in nfs
qstr: constify instances in ocfs2
qstr: constify instances in autofs4
qstr: constify instances in hfs
qstr: constify instances in hfsplus
qstr: constify instances in logfs
qstr: constify dentry_init_security
FUSE_HAS_IOCTL_DIR should be assigned to ->flags, it may be a typo.
Signed-off-by: Wei Fang <fangwei1@huawei.com>
Fixes: 69fe05c90ed5 ("fuse: add missing INIT flags")
Cc: <stable@vger.kernel.org>
Negotiate with userspace filesystems whether they support parallel readdir
and lookup. Disable parallelism by default for fear of breaking fuse
filesystems.
Fixes: 9902af79c01a ("parallel lookups: actual switch to rwsem")
Fixes: d9b3dbdcfd62 ("fuse: switch to ->iterate_shared()")
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
Mark those kmem allocations that are known to be easily triggered from
userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to
memcg. For the list, see below:
- threadinfo
- task_struct
- task_delay_info
- pid
- cred
- mm_struct
- vm_area_struct and vm_region (nommu)
- anon_vma and anon_vma_chain
- signal_struct
- sighand_struct
- fs_struct
- files_struct
- fdtable and fdtable->full_fds_bits
- dentry and external_name
- inode for all filesystems. This is the most tedious part, because
most filesystems overwrite the alloc_inode method.
The list is far from complete, so feel free to add more objects.
Nevertheless, it should be close to "account everything" approach and
keep most workloads within bounds. Malevolent users will be able to
breach the limit, but this was possible even with the former "account
everything" approach (simply because it did not account everything in
fact).
Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace updates from Eric Biederman:
"Long ago and far away when user namespaces where young it was realized
that allowing fresh mounts of proc and sysfs with only user namespace
permissions could violate the basic rule that only root gets to decide
if proc or sysfs should be mounted at all.
Some hacks were put in place to reduce the worst of the damage could
be done, and the common sense rule was adopted that fresh mounts of
proc and sysfs should allow no more than bind mounts of proc and
sysfs. Unfortunately that rule has not been fully enforced.
There are two kinds of gaps in that enforcement. Only filesystems
mounted on empty directories of proc and sysfs should be ignored but
the test for empty directories was insufficient. So in my tree
directories on proc, sysctl and sysfs that will always be empty are
created specially. Every other technique is imperfect as an ordinary
directory can have entries added even after a readdir returns and
shows that the directory is empty. Special creation of directories
for mount points makes the code in the kernel a smidge clearer about
it's purpose. I asked container developers from the various container
projects to help test this and no holes were found in the set of mount
points on proc and sysfs that are created specially.
This set of changes also starts enforcing the mount flags of fresh
mounts of proc and sysfs are consistent with the existing mount of
proc and sysfs. I expected this to be the boring part of the work but
unfortunately unprivileged userspace winds up mounting fresh copies of
proc and sysfs with noexec and nosuid clear when root set those flags
on the previous mount of proc and sysfs. So for now only the atime,
read-only and nodev attributes which userspace happens to keep
consistent are enforced. Dealing with the noexec and nosuid
attributes remains for another time.
This set of changes also addresses an issue with how open file
descriptors from /proc/<pid>/ns/* are displayed. Recently readlink of
/proc/<pid>/fd has been triggering a WARN_ON that has not been
meaningful since it was added (as all of the code in the kernel was
converted) and is not now actively wrong.
There is also a short list of issues that have not been fixed yet that
I will mention briefly.
It is possible to rename a directory from below to above a bind mount.
At which point any directory pointers below the renamed directory can
be walked up to the root directory of the filesystem. With user
namespaces enabled a bind mount of the bind mount can be created
allowing the user to pick a directory whose children they can rename
to outside of the bind mount. This is challenging to fix and doubly
so because all obvious solutions must touch code that is in the
performance part of pathname resolution.
As mentioned above there is also a question of how to ensure that
developers by accident or with purpose do not introduce exectuable
files on sysfs and proc and in doing so introduce security regressions
in the current userspace that will not be immediately obvious and as
such are likely to require breaking userspace in painful ways once
they are recognized"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
vfs: Remove incorrect debugging WARN in prepend_path
mnt: Update fs_fully_visible to test for permanently empty directories
sysfs: Create mountpoints with sysfs_create_mount_point
sysfs: Add support for permanently empty directories to serve as mount points.
kernfs: Add support for always empty directories.
proc: Allow creating permanently empty directories that serve as mount points
sysctl: Allow creating permanently empty directories that serve as mountpoints.
fs: Add helper functions for permanently empty directories.
vfs: Ignore unlocked mounts in fs_fully_visible
mnt: Modify fs_fully_visible to deal with locked ro nodev and atime
mnt: Refactor the logic for mounting sysfs and proc in a user namespace
This allows for better documentation in the code and
it allows for a simpler and fully correct version of
fs_fully_visible to be written.
The mount points converted and their filesystems are:
/sys/hypervisor/s390/ s390_hypfs
/sys/kernel/config/ configfs
/sys/kernel/debug/ debugfs
/sys/firmware/efi/efivars/ efivarfs
/sys/fs/fuse/connections/ fusectl
/sys/fs/pstore/ pstore
/sys/kernel/tracing/ tracefs
/sys/fs/cgroup/ cgroup
/sys/kernel/security/ securityfs
/sys/fs/selinux/ selinuxfs
/sys/fs/smackfs/ smackfs
Cc: stable@vger.kernel.org
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Make each fuse device clone refer to a separate processing queue. The only
constraint on userspace code is that the request answer must be written to
the same device clone as it was read off.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Allow fuse device clones to refer to be distinguished. This patch just
adds the infrastructure by associating a separate "struct fuse_dev" with
each clone.
Reviewed-by: Ashish Samant <ashish.samant@oracle.com>
Add a fpq->lock for protecting members of struct fuse_pqueue and FR_LOCKED
request flag.
This will allow checking ->connected just with the processing queue lock.
This is just two fields: fc->io and fc->processing.
This patch just rearranges the fields, no functional change.
This will allow checking ->connected just with the input queue lock.
The input queue contains normal requests (fc->pending), forgets
(fc->forget_*) and interrupts (fc->interrupts). There's also fc->waitq and
fc->fasync for waking up the readers of the fuse device when a request is
available.
The fc->reqctr is also moved to the input queue (assigned to the request
when the request is added to the input queue.
Since it's a 64bit counter, it's never gonna wrap around. Remove code
dealing with that possibility.
Finer grained locking will mean there's no single lock to protect
modification of bitfileds in fuse_req.
So move to using bitops. Can use the non-atomic variants for those which
happen while the request definitely has only one reference.
fc->release is called from fuse_conn_put() which was used in the error
cleanup before fc->release was initialized.
[Jeremiah Mahler <jmmahler@gmail.com>: assign fc->release after calling
fuse_conn_init(fc) instead of before.]
Fixes: a325f9b92273 ("fuse: update fuse_conn_init() and separate out fuse_conn_kill()")
Cc: <stable@vger.kernel.org> #v2.6.31+
that's the bulk of filesystem drivers dealing with inodes of their own
Now that we never use the backing_dev_info pointer in struct address_space
we can simply remove it and save 4 to 8 bytes in every inode.
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Reviewed-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Jens Axboe <axboe@fb.com>
Theoretically we need to order setting of various fields in fc with
fc->initialized.
No known bug reports related to this yet.
Analysis from Marc:
"Commit 7078187a795f ("fuse: introduce fuse_simple_request() helper")
from the above pull request triggers some EIO errors for me in some tests
that rely on fuse
Looking at the code changes and a bit of debugging info I think there's a
general problem here that fuse_get_req checks and possibly waits for
fc->initialized, and this was always called first. But this commit
changes the ordering and in many places fc->minor is now possibly used
before fuse_get_req, and we can't be sure that fc has been initialized.
In my case fuse_lookup_init sets req->out.args[0].size to the wrong size
because fc->minor at that point is still 0, leading to the EIO error."
Fix by moving the compat adjustments into fuse_simple_request() to after
fuse_get_req().
This is also more readable than the original, since now compatibility is
handled in a single function instead of cluttering each operation.
Reported-by: Marc Dionne <marc.c.dionne@gmail.com>
Tested-by: Marc Dionne <marc.c.dionne@gmail.com>
Fixes: 7078187a795f ("fuse: introduce fuse_simple_request() helper")
The following pattern is repeated many times:
req = fuse_get_req_nopages(fc);
/* Initialize req->(in|out).args */
fuse_request_send(fc, req);
err = req->out.h.error;
fuse_put_request(req);
Create a new replacement helper:
/* Initialize args */
err = fuse_simple_request(fc, &args);
In addition to reducing the code size, this will ease moving from the
complex arg-based to a simpler page-based I/O on the fuse device.
Use fuse_abort_conn() instead of fuse_conn_kill() in fuse_put_super().
This flushes and aborts requests still on any queues. But since we've
already reset fc->connected, those requests would not be useful anyway and
would be flushed when the fuse device is closed.
Next patches will rely on requests being flushed before the superblock is
destroyed.
Use fuse_abort_conn() in cuse_process_init_reply() too, since it makes no
difference there, and we can get rid of fuse_conn_kill().
Waking up reserved_req_waitq from fuse_conn_kill() doesn't make sense since
we aren't chaging ff->reserved_req here, which is what this waitqueue
signals.
Here some additional changes to set a capability flag so that clients can
detect when it's appropriate to return -ENOSYS from open.
This amends the following commit introduced in 3.14:
7678ac50615d fuse: support clients that don't implement 'open'
However we can only add the flag to 3.15 and later since there was no
protocol version update in 3.14.
Cc: <stable@vger.kernel.org> # v3.15+
Default s_time_gran is 1, don't overwrite that if userspace didn't
explicitly specify one.
If the number in "user_id=N" or "group_id=N" mount options was larger than
INT_MAX then fuse returned EINVAL.
Fix this to handle all valid uid/gid values.
This patch removes the cast on data of type void * as it is not needed.
The following Coccinelle semantic patch was used for making the change:
@r@
expression x;
void* e;
type T;
identifier f;
*((T *)e)
((T *)x)[...]
((T *)x)->f
- (T *)
e
Signed-off-by: Himangi Saraogi <himangi774@gmail.com>
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
Fuse doesn't support i_version (yet).
Let the kernel maintain i_ctime locally: update i_ctime explicitly on
truncate, fallocate, open(O_TRUNC), setxattr, removexattr, link, rename,
unlink.
The inode flag I_DIRTY_SYNC serves as indication that local i_ctime should
be flushed to the server eventually. The patch sets the flag and updates
i_ctime in course of operations listed above.
Signed-off-by: Maxim Patlasov <MPatlasov@parallels.com>
Allow userspace fs to specify time granularity.
This is needed because with writeback_cache mode the kernel is responsible
for generating mtime and ctime, but if the underlying filesystem doesn't
support nanosecond granularity then the cache will contain a different
value from the one stored on the filesystem resulting in a change of times
after a cache flush.
Make the default granularity 1s.
...and flush mtime from this. This allows us to use the kernel
infrastructure for writing out dirty metadata (mtime at this point, but
ctime in the next patches and also maybe atime).
When inode is in I_NEW state, inode->i_mode is not initialized yet. Do not
use it before fuse_init_inode() is called.
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"Major changes for 3.14 include support for the newly added ZERO_RANGE
and COLLAPSE_RANGE fallocate operations, and scalability improvements
in the jbd2 layer and in xattr handling when the extended attributes
spill over into an external block.
Other than that, the usual clean ups and minor bug fixes"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (42 commits)
ext4: fix premature freeing of partial clusters split across leaf blocks
ext4: remove unneeded test of ret variable
ext4: fix comment typo
ext4: make ext4_block_zero_page_range static
ext4: atomically set inode->i_flags in ext4_set_inode_flags()
ext4: optimize Hurd tests when reading/writing inodes
ext4: kill i_version support for Hurd-castrated file systems
ext4: each filesystem creates and uses its own mb_cache
fs/mbcache.c: doucple the locking of local from global data
fs/mbcache.c: change block and index hash chain to hlist_bl_node
ext4: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate
ext4: refactor ext4_fallocate code
ext4: Update inode i_size after the preallocation
ext4: fix partial cluster handling for bigalloc file systems
ext4: delete path dealloc code in ext4_ext_handle_uninitialized_extents
ext4: only call sync_filesystm() when remounting read-only
fs: push sync_filesystem() down to the file system's remount_fs()
jbd2: improve error messages for inconsistent journal heads
jbd2: minimize region locked by j_list_lock in jbd2_journal_forget()
jbd2: minimize region locked by j_list_lock in journal_get_create_access()
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
Pull fuse update from Miklos Szeredi:
"This series adds cached writeback support to fuse, improving write
throughput"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
fuse: fix "uninitialized variable" warning
fuse: Turn writeback cache on
fuse: Fix O_DIRECT operations vs cached writeback misorder
fuse: fuse_flush() should wait on writeback
fuse: Implement write_begin/write_end callbacks
fuse: restructure fuse_readpage()
fuse: Flush files on wb close
fuse: Trust kernel i_mtime only
fuse: Trust kernel i_size only
fuse: Connection bit for enabling writeback
fuse: Prepare to handle short reads
fuse: Linking file to inode helper
Reclaim will be leaving shadow entries in the page cache radix tree upon
evicting the real page. As those pages are found from the LRU, an
iput() can lead to the inode being freed concurrently. At this point,
reclaim must no longer install shadow pages because the inode freeing
code needs to ensure the page tree is really empty.
Add an address_space flag, AS_EXITING, that the inode freeing code sets
under the tree lock before doing the final truncate. Reclaim will check
for this flag before installing shadow pages.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Metin Doslu <metin@citusdata.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Ozgun Erdogan <ozgun@citusdata.com>
Cc: Roman Gushchin <klamm@yandex-team.ru>
Cc: Ryan Mallon <rmallon@gmail.com>
Introduce a bit kernel and userspace exchange between each-other on
the init stage and turn writeback on if the userspace want this and
mount option 'allow_wbcache' is present (controlled by fusermount).
Also add each writable file into per-inode write list and call the
generic_file_aio_write to make use of the Linux page cache engine.
Let the kernel maintain i_mtime locally:
- clear S_NOCMTIME
- implement i_op->update_time()
- flush mtime on fsync and last close
- update i_mtime explicitly on truncate and fallocate
Fuse inode flag FUSE_I_MTIME_DIRTY serves as indication that local i_mtime
should be flushed to the server eventually.
Make fuse think that when writeback is on the inode's i_size is always
up-to-date and not update it with the value received from the userspace.
This is done because the page cache code may update i_size without letting
the FS know.
This assumption implies fixing the previously introduced short-read helper --
when a short read occurs the 'hole' is filled with zeroes.
fuse_file_fallocate() is also fixed because now we should keep i_size up to
date, so it must be updated if FUSE_FALLOCATE request succeeded.
Signed-off-by: Maxim V. Patlasov <MPatlasov@parallels.com>
Previously, the no-op "mount -o mount /dev/xxx" operation when the
file system is already mounted read-write causes an implied,
unconditional syncfs(). This seems pretty stupid, and it's certainly
documented or guaraunteed to do this, nor is it particularly useful,
except in the case where the file system was mounted rw and is getting
remounted read-only.
However, it's possible that there might be some file systems that are
actually depending on this behavior. In most file systems, it's
probably fine to only call sync_filesystem() when transitioning from
read-write to read-only, and there are some file systems where this is
not needed at all (for example, for a pseudo-filesystem or something
like romfs).
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Cc: linux-fsdevel@vger.kernel.org
Cc: Artem Bityutskiy <dedekind1@gmail.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Evgeniy Dushistov <dushistov@mail.ru>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Anders Larsen <al@alarsen.net>
Cc: Phillip Lougher <phillip@squashfs.org.uk>
Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
Cc: Petr Vandrovec <petr@vandrovec.name>
Cc: xfs@oss.sgi.com
Cc: linux-btrfs@vger.kernel.org
Cc: linux-cifs@vger.kernel.org
Cc: samba-technical@lists.samba.org
Cc: codalist@coda.cs.cmu.edu
Cc: linux-ext4@vger.kernel.org
Cc: linux-f2fs-devel@lists.sourceforge.net
Cc: fuse-devel@lists.sourceforge.net
Cc: cluster-devel@redhat.com
Cc: linux-mtd@lists.infradead.org
Cc: jfs-discussion@lists.sourceforge.net
Cc: linux-nfs@vger.kernel.org
Cc: linux-nilfs@vger.kernel.org
Cc: linux-ntfs-dev@lists.sourceforge.net
Cc: ocfs2-devel@oss.oracle.com
Cc: reiserfs-devel@vger.kernel.org
makes ->permission() and ->d_revalidate() safety in RCU mode independent
from vfsmount_lock.
...which just returns -EBUSY if a directory alias would be created.
This is to be used by fuse mkdir to make sure that a buggy or malicious
userspace filesystem doesn't do anything nasty. Previously fuse used a
private mutex for this purpose, which can now go away.
truncate_pagecache() doesn't care about old size since commit
cedabed49b39 ("vfs: Fix vmtruncate() regression"). Let's drop it.
The feature prevents mistrusted filesystems (ie: FUSE mounts created by
unprivileged users) to grow a large number of dirty pages before
throttling. For such filesystems balance_dirty_pages always check bdi
counters against bdi limits. I.e. even if global "nr_dirty" is under
"freerun", it's not allowed to skip bdi checks. The only use case for now
is fuse: it sets bdi max_ratio to 1% by default and system administrators
are supposed to expect that this limit won't be exceeded.
The feature is on if a BDI is marked by BDI_CAP_STRICTLIMIT flag. A
filesystem may set the flag when it initializes its BDI.
The problematic scenario comes from the fact that nobody pays attention to
the NR_WRITEBACK_TEMP counter (i.e. number of pages under fuse
writeback). The implementation of fuse writeback releases original page
(by calling end_page_writeback) almost immediately. A fuse request queued
for real processing bears a copy of original page. Hence, if userspace
fuse daemon doesn't finalize write requests in timely manner, an
aggressive mmap writer can pollute virtually all memory by those temporary
fuse page copies. They are carefully accounted in NR_WRITEBACK_TEMP, but
nobody cares.
To make further explanations shorter, let me use "NR_WRITEBACK_TEMP
problem" as a shortcut for "a possibility of uncontrolled grow of amount
of RAM consumed by temporary pages allocated by kernel fuse to process
writeback".
The problem was very easy to reproduce. There is a trivial example
filesystem implementation in fuse userspace distribution: fusexmp_fh.c. I
added "sleep(1);" to the write methods, then recompiled and mounted it.
Then created a huge file on the mount point and run a simple program which
mmap-ed the file to a memory region, then wrote a data to the region. An
hour later I observed almost all RAM consumed by fuse writeback. Since
then some unrelated changes in kernel fuse made it more difficult to
reproduce, but it is still possible now.
Putting this theoretical happens-in-the-lab thing aside, there is another
thing that really hurts real world (FUSE) users. This is write-through
page cache policy FUSE currently uses. I.e. handling write(2), kernel
fuse populates page cache and flushes user data to the server
synchronously. This is excessively suboptimal. Pavel Emelyanov's patches
("writeback cache policy") solve the problem, but they also make resolving
NR_WRITEBACK_TEMP problem absolutely necessary. Otherwise, simply copying
a huge file to a fuse mount would result in memory starvation. Miklos,
the maintainer of FUSE, believes strictlimit feature the way to go.
And eventually putting FUSE topics aside, there is one more use-case for
strictlimit feature. Using a slow USB stick (mass storage) in a machine
with huge amount of RAM installed is a well-known pain. Let's make simple
computations. Assuming 64GB of RAM installed, existing implementation of
balance_dirty_pages will start throttling only after 9.6GB of RAM becomes
dirty (freerun == 15% of total RAM). So, the command "cp 9GB_file
/media/my-usb-storage/" may return in a few seconds, but subsequent
"umount /media/my-usb-storage/" will take more than two hours if effective
throughput of the storage is, to say, 1MB/sec.
After inclusion of strictlimit feature, it will be trivial to add a knob
(e.g. /sys/devices/virtual/bdi/x:y/strictlimit) to enable it on demand.
Manually or via udev rule. May be I'm wrong, but it seems to be quite a
natural desire to limit the amount of dirty memory for some devices we are
not fully trust (in the sense of sustainable throughput).
[akpm@linux-foundation.org: fix warning in page-writeback.c]
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
