path: root/fs/fuse
2006-10-01[PATCH] r/o bind mounts: monitor zeroing of i_nlinkDave Hansen
Some filesystems, instead of simply decrementing i_nlink, simply zero it during an unlink operation. We need to catch these in addition to the decrement operations. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mount prepwork: inc_nlink() helperDave Hansen
This is mostly included for parity with dec_nlink(), where we will have some more hooks. This one should stay pretty darn straightforward for now. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Remove readv/writev methods and use aio_read/aio_write insteadBadari Pulavarty
This patch removes readv() and writev() methods and replaces them with aio_read()/aio_write() methods. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] vfs: define new lookup flag for chdirMiklos Szeredi
In the "operation does permission checking" model used by fuse, chdir permission is not checked, since there's no chdir method. For this case set a lookup flag, which will be passed to ->permission(), so fuse can distinguish it from permission checks for other operations. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] fuse: use dentry in statfsMiklos Szeredi
Some filesystems may want to report different values depending on the path within the filesystem, i.e. one mount is actually several filesystems. This can be the case for a network filesystem exported by an unprivileged server (e.g. sshfs). This is now possible, thanks to David Howells "VFS: Permit filesystem to perform statfs with a known root dentry" patch. This change is backward compatible, so no need to change interface version. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] fuse: add lock annotations to request_end and fuse_read_interruptJosh Triplett
request_end and fuse_read_interrupt release fc->lock. Add lock annotations to these two functions so that sparse can check callers for lock pairing, and so that sparse will not complain about these functions since they intentionally use locks in this manner. Signed-off-by: Josh Triplett <josh@freedesktop.org> Acked-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] inode_diet: Replace inode.u.generic_ip with inode.i_privateTheodore Ts'o
The following patches reduce the size of the VFS inode structure by 28 bytes on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction in the inode size on a UP kernel that is configured in a production mode (i.e., with no spinlock or other debugging functions enabled; if you want to save memory taken up by in-core inodes, the first thing you should do is disable the debugging options; they are responsible for a huge amount of bloat in the VFS inode structure). This patch: The filesystem or device-specific pointer in the inode is inside a union, which is pretty pointless given that all 30+ users of this field have been using the void pointer. Get rid of the union and rename it to i_private, with a comment to explain who is allowed to use the void pointer. This is just a cleanup, but it allows us to reuse the union 'u' for something something where the union will actually be used. [judith@osdl.org: powerpc build fix] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Judith Lebzelter <judith@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-14[PATCH] fuse: fix error case in fuse_readpagesAlexander Zarochentsev
Don't let fuse_readpages leave the @pages list not empty when exiting on error. [akpm@osdl.org: kernel-doc fixes] Signed-off-by: Alexander Zarochentsev <zam@namesys.com> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-31[PATCH] fuse: fix typoMiklos Szeredi
2006-07-31[PATCH] fuse: use jiffies_64Miklos Szeredi
It is entirely possible (though rare) that jiffies half-wraps around, while a dentry/inode remains in the cache. This could mean that the dentry/inode is not invalidated for another half wraparound-time. To get around this problem, use 64-bit jiffies. The only problem with this is that dentry->d_time is 32 bits on 32-bit archs. So use d_fsdata as the high 32 bits. This is an ugly hack, but far simpler, than having to allocate private data just for this purpose. Since 64-bit jiffies can be assumed never to wrap around, simple comparison can be used, and a zero time value can represent "invalid". Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-31[PATCH] fuse: fix zero timeoutMiklos Szeredi
An attribute and entry timeout of zero should mean, that the entity is invalidated immediately after the operation. Previously invalidation only happened at the next clock tick. Reported and tested by Craig Davies. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (51 commits) nfs: remove nfs_put_link() nfs-build-fix-99 git-nfs-build-fixes Merge branch 'odirect' NFS: alloc nfs_read/write_data as direct I/O is scheduled NFS: Eliminate nfs_get_user_pages() NFS: refactor nfs_direct_free_user_pages NFS: remove user_addr, user_count, and pos from nfs_direct_req NFS: "open code" the NFS direct write rescheduler NFS: Separate functions for counting outstanding NFS direct I/Os NLM: Fix reclaim races NLM: sem to mutex conversion locks.c: add the fl_owner to nlm_compare_locks NFS: Display the chosen RPCSEC_GSS security flavour in /proc/mounts NFS: Split fs/nfs/inode.c NFS: Fix typo in nfs_do_clone_mount() NFS: Fix compile errors introduced by referrals patches NFSv4: Ensure that referral mounts bind to a reserved port NFSv4: A root pathname is sent as a zero component4 NFSv4: Follow a referral ...
2006-06-25[PATCH] fuse: scramble lock owner IDMiklos Szeredi
VFS uses current->files pointer as lock owner ID, and it wouldn't be prudent to expose this value to userspace. So scramble it with XTEA using a per connection random key, known only to the kernel. Only one direction needs to be implemented, since the ID is never sent in the reverse direction. The XTEA algorithm is implemented inline since it's simple enough to do so, and this adds less complexity than if the crypto API were used. Thanks to Jesper Juhl for the idea. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] fuse: add request interruptionMiklos Szeredi
Add synchronous request interruption. This is needed for file locking operations which have to be interruptible. However filesystem may implement interruptibility of other operations (e.g. like NFS 'intr' mount option). Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] fuse: rename the interrupted flagMiklos Szeredi
Rename the 'interrupted' flag to 'aborted', since it indicates exactly that, and next patch will introduce an 'interrupted' flag for a Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] fuse: ensure FLUSH reaches userspaceMiklos Szeredi
All POSIX locks owned by the current task are removed on close(). If the FLUSH request resulting initiated by close() fails to reach userspace, there might be locks remaining, which cannot be removed. The only reason it could fail, is if allocating the request fails. In this case use the request reserved for RELEASE, or if that is currently used by another FLUSH, wait for it to become available. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] fuse: add POSIX file locking supportMiklos Szeredi
This patch adds POSIX file locking support to the fuse interface. This implementation doesn't keep any locking state in kernel. Unlocking on close() is handled by the FLUSH message, which now contains the lock owner id. Mandatory locking is not supported. The filesystem may enfoce mandatory locking in userspace if needed. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] fuse: add control filesystemMiklos Szeredi
Add a control filesystem to fuse, replacing the attributes currently exported through sysfs. An empty directory '/sys/fs/fuse/connections' is still created in sysfs, and mounting the control filesystem here provides backward compatibility. Advantages of the control filesystem over the previous solution: - allows the object directory and the attributes to be owned by the filesystem owner, hence letting unpriviled users abort the filesystem connection - does not suffer from module unload race [akpm@osdl.org: fix this fs for recent dhowells depredations] [akpm@osdl.org: fix 64-bit printk warnings] Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] fuse: no backgrounding on interruptMiklos Szeredi
Don't put requests into the background when a fatal interrupt occurs while the request is in userspace. This removes a major wart from the implementation. Backgrounding of requests was introduced to allow breaking of deadlocks. However now the same can be achieved by aborting the filesystem through the 'abort' sysfs attribute. This is a change in the interface, but should not cause problems, since these kinds of deadlocks never happen during normal operation. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-24Merge branch 'master' of /home/trondmy/kernel/linux-2.6/Trond Myklebust
Conflicts: fs/nfs/inode.c fs/super.c Fix conflicts between patch 'NFS: Split fs/nfs/inode.c' and patch 'VFS: Permit filesystem to override root dentry on mount'
2006-06-23[PATCH] vfs: add lock owner argument to flush operationMiklos Szeredi
Pass the POSIX lock owner ID to the flush operation. This is useful for filesystems which don't want to store any locking state in inode->i_flock but want to handle locking/unlocking POSIX locks internally. FUSE is one such filesystem but I think it possible that some network filesystems would need this also. Also add a flag to indicate that a POSIX locking request was generated by close(), so filesystems using the above feature won't send an extra locking request in this case. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-09VFS: Remove dependency of ->umount_begin() call on MNT_FORCETrond Myklebust
Allow filesystems to decide to perform pre-umount processing whether or not MNT_FORCE is set. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-04-26[fuse] fix race between checking and setting file->private_dataMiklos Szeredi
BKL does not protect against races if the task may sleep between checking and setting a value. So move checking of file->private_data near to setting it in fuse_fill_super(). Found by Al Viro. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
2006-04-26[fuse] fix deadlock between fuse_put_super() and request_end(), try #2Miklos Szeredi
A deadlock was possible, when the last reference to the superblock was held due to a background request containing a file reference. Releasing the file would release the vfsmount which in turn would release the superblock. Since sbput_sem is held during the fput() and fuse_put_super() tries to acquire this same semaphore, a deadlock results. The solution is to move the fput() outside the region protected by sbput_sem. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
2006-04-26Revert "[fuse] fix deadlock between fuse_put_super() and request_end()"Miklos Szeredi
This reverts 73ce8355c243a434524a34c05cc417dd0467996e commit. It was wrong, because it didn't take into account the requirement, that iput() for background requests must be performed synchronously with ->put_super(), otherwise active inodes may remain after unmount. The right solution is to keep the sbput_sem and perform iput() within the locked region, but move fput() outside sbput_sem. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
2006-04-11[fuse] Direct I/O should not use fuse_reset_requestMiklos Szeredi
It's cleaner to allocate a new request, otherwise the uid/gid/pid fields of the request won't be filled in. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
2006-04-11[fuse] Don't init request twiceMiklos Szeredi
Request is already initialized in fuse_request_alloc() so no need to do it again in fuse_get_req(). Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
2006-04-11[fuse] Fix accounting the number of waiting requestsMiklos Szeredi
Properly accounting the number of waiting requests was forgotten in "clean up request accounting" patch. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
2006-04-11[fuse] fix deadlock between fuse_put_super() and request_end()Miklos Szeredi
A deadlock was possible, when the last reference to the superblock was held due to a background request containing a file reference. Releasing the file would release the vfsmount which in turn would release the superblock. Since sbput_sem is held during the fput() and fuse_put_super() tries to acquire this same semaphore, a deadlock results. The chosen soltuion is to get rid of sbput_sem, and instead use the spinlock to ensure the referenced inodes/file are released only once. Since the actual release may sleep, defer these outside the locked region, but using local variables instead of the structure members. This is a much more rubust solution. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
2006-04-11[PATCH] fuse: account background requestsMiklos Szeredi
The previous patch removed limiting the number of outstanding requests. This patch adds a much simpler limiting, that is also compatible with file locking operations. A task may have at most one synchronous request allocated. So these requests need not be otherwise limited. However the number of background requests (release, forget, asynchronous reads, interrupted requests) can grow indefinitely. This can be used by a malicous user to cause FUSE to allocate arbitrary amounts of unswappable kernel memory, denying service. For this reason add a limit for the number of background requests, and block allocations of new requests until the number goes bellow the limit. Also use this mechanism to block all requests until the INIT reply is received. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] fuse: clean up request accountingMiklos Szeredi
FUSE allocated most requests from a fixed size pool filled at mount time. However in some cases (release/forget) non-pool requests were used. File locking operations aren't well served by the request pool, since they may block indefinetly thus exhausting the pool. This patch removes the request pool and always allocates requests on demand. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] fuse: consolidate device errorsMiklos Szeredi
Return consistent error values for the case when the opened device file has no mount associated yet. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] fuse: use a per-mount spinlockMiklos Szeredi
Remove the global spinlock in favor of a per-mount one. This patch is basically find & replace. The difficult part has already been done by the previous patch. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] fuse: simplify lockingMiklos Szeredi
This is in preparation for removing the global spinlock in favor of a per-mount one. The only critical part is the interaction between fuse_dev_release() and fuse_fill_super(): fuse_dev_release() must see the assignment to file->private_data, otherwise it will leak the reference to fuse_conn. This is ensured by the fput() operation, which will synchronize the assignment with other CPU's that may do a final fput() soon after this. Also redundant locking is removed from fuse_fill_super(), where exclusion is already ensured by the BKL held for this function by the VFS. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] fuse: add O_NONBLOCK support to FUSE deviceJeff Dike
I don't like duplicating the connected and list_empty tests in fuse_dev_readv, but this seemed cleaner than adding the f_flags test to request_wait. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] fuse: add O_ASYNC support to FUSE deviceJeff Dike
This adds asynchronous notification to FUSE - a FUSE server can request O_ASYNC on a /dev/fuse file descriptor and receive SIGIO when there is input available. One subtlety - fuse_dev_fasync, which is called when O_ASYNC is requested, does no locking, unlink the other methods. I think it's unnecessary, as the fuse_conn.fasync list is manipulated only by fasync_helper and kill_fasync, which provide their own locking. It would also be wrong to use the fuse_lock, as it's a spin lock and fasync_helper can sleep. My one concern with this is the fuse_conn going away underneath fuse_dev_fasync - sys_fcntl takes a reference on the file struct, so this seems not to be a problem. Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] fuse: fix fuse_dev_poll() return valueMiklos Szeredi
fuse_dev_poll() returned an error value instead of a poll mask. Luckily (or unluckily) -ENODEV does contain the POLLERR bit. There's also a race if filesystem is unmounted between fuse_get_conn() and spin_lock(), in which case this event will be missed by poll(). Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] fuse: fix oops in fuse_send_readpages()Miklos Szeredi
During heavy parallel filesystem activity it was possible to Oops the kernel. The reason is that read_cache_pages() could skip pages which have already been inserted into the cache by another task. Occasionally this may result in zero pages actually being sent, while fuse_send_readpages() relies on at least one page being in the request. So check this corner case and just free the request instead of trying to send it. Reported and tested by Konstantin Isakov. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-28[PATCH] fuse: fix bug in negative lookupMiklos Szeredi
If negative entries (nodeid == 0) were sent in reply to LOOKUP requests, two bugs could be triggered: - looking up a negative entry would return -EIO, - revaildate on an entry which turned negative would send a FORGET request with zero nodeid, which would cause an abort() in the library. The above would only happen if the 'negative_timeout=N' option was used, otherwise lookups reply -ENOENT, which worked correctly. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-17[PATCH] fuse: fix bug in aborted fuse_release_end()Miklos Szeredi
There's a rather theoretical case of the BUG triggering in fuse_reset_request(): - iget() fails because of OOM after a successful CREATE_OPEN request - during IO on the resulting RELEASE request the connection is aborted Fix and add warning to fuse_reset_request(). Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-05[PATCH] fuse: fix request_end() vs fuse_reset_request() raceMiklos Szeredi
The last fix for this function in fact opened up a much more often triggering race. It was uncommented tricky code, that was buggy. Add comment, make it less tricky and fix bug. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] fuse: fix async read for legacy filesystemsMiklos Szeredi
While asynchronous reads mean a performance improvement in most cases, if the filesystem assumed that reads are synchronous, then async reads may degrade performance (filesystem may receive reads out of order, which can confuse it's own readahead logic). With sshfs a 1.5 to 4 times slowdown can be measured. There's also a need for userspace filesystems to know whether asynchronous reads are supported by the kernel or not. To achive these, negotiate in the INIT request whether async reads will be used and the maximum readahead value. Update interface version to 7.6 If userspace uses a version earlier than 7.6, then disable async reads, and set maximum readahead value to the maximum read size, as done in previous versions. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-16[PATCH] fuse: fix bitfield raceMiklos Szeredi
Fix race in setting bitfields of fuse_conn. Spotted by Andrew Morton. The two fields ->connected and ->mounted were always changed with the fuse_lock held. But other bitfields in the same structure were changed without the lock. In theory this could lead to losing the assignment of even the ones under lock. The chosen solution is to change these two fields to be a full unsigned type. The other bitfields aren't "important" enough to warrant the extra complexity of full locking or changing them to bitops. For all bitfields document why they are safe wrt. concurrent assignments. Also make the initialization of the 'num_waiting' atomic counter explicit. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-16[PATCH] fuse: use asynchronous READ requests for readpagesMiklos Szeredi
This patch changes fuse_readpages() to send READ requests asynchronously. This makes it possible for userspace filesystems to utilize the kernel readahead logic instead of having to implement their own (resulting in double caching). Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
