commit d9d318d39dd5cb686660504a3565aac453709ccc upstream.
If a 32bit CUSE server is run on 64bit this results in EIO being
returned to the caller.
The reason is that FUSE_IOCTL_RETRY reply was defined to use 'struct
iovec', which is different on 32bit and 64bit archs.
Work around this by looking at the size of the reply to determine
which struct was used. This is only needed if CONFIG_COMPAT is
defined.
A more permanent fix for the interface will be to use the same struct
on both 32bit and 64bit.
Reported-by: "ccmail111" <ccmail111@yahoo.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
CC: Tejun Heo <tj@kernel.org>
commit 7572777eef78ebdee1ecb7c258c0ef94d35bad16 upstream.
Verify that the total length of the iovec returned in FUSE_IOCTL_RETRY
doesn't overflow iov_length().
commit a0822c55779d9319939eac69f00bb729ea9d23da upstream.
The attribute cache for a file was not being cleared when a file is opened
with O_TRUNC.
If the filesystem's open operation truncates the file ("atomic_o_trunc"
feature flag is set) then the kernel should invalidate the cached st_mtime
and st_ctime attributes.
Also i_size should be explicitly be set to zero as it is used sometimes
without refreshing the cache.
Signed-off-by: Ken Sumrall <ksumrall@android.com>
Cc: Anfei <anfei.zhou@gmail.com>
Cc: "Anand V. Avati" <avati@gluster.com>
Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
fs/fuse/dev.c:1357: warning: ‘total_len’ may be used uninitialized in this
function
Initialize total_len to zero, else its value will be undefined.
Sparse doesn't understand lock annotations of the form
__releases(&foo->lock). Change them to __releases(foo->lock). Same
for __acquires().
David Bartly reported that fuse can hang in fuse_get_req_nofail() when
the connection to the filesystem server is no longer active.
If bg_queue is not empty then flush_bg_queue() called from
request_end() can put more requests on to the pending queue. If this
happens while ending requests on the processing queue then those
background requests will be queued to the pending list and never
ended.
Another problem is that fuse_dev_release() didn't wake up processes
sleeping on blocked_waitq.
Solve this by:
a) flushing the background queue before calling end_requests() on the
pending and processing queues
b) setting blocked = 0 and waking up processes waiting on
blocked_waitq()
Thanks to David for an excellent bug report.
Reported-by: David Bartley <andareed@gmail.com>
CC: stable@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits)
no need for list_for_each_entry_safe()/resetting with superblock list
Fix sget() race with failing mount
vfs: don't hold s_umount over close_bdev_exclusive() call
sysv: do not mark superblock dirty on remount
sysv: do not mark superblock dirty on mount
btrfs: remove junk sb_dirt change
BFS: clean up the superblock usage
AFFS: wait for sb synchronization when needed
AFFS: clean up dirty flag usage
cifs: truncate fallout
mbcache: fix shrinker function return value
mbcache: Remove unused features
add f_flags to struct statfs(64)
pass a struct path to vfs_statfs
update VFS documentation for method changes.
All filesystems that need invalidate_inode_buffers() are doing that explicitly
convert remaining ->clear_inode() to ->evict_inode()
Make ->drop_inode() just return whether inode needs to be dropped
fs/inode.c:clear_inode() is gone
fs/inode.c:evict() doesn't care about delete vs. non-delete paths now
Fix up trivial conflicts in fs/nilfs2/super.c
Make sure we check the truncate constraints early on in ->setattr by adding
those checks to inode_change_ok. Also clean up and document inode_change_ok
to make this obvious.
As a fallout we don't have to call inode_newsize_ok from simple_setsize and
simplify it down to a truncate_setsize which doesn't return an error. This
simplifies a lot of setattr implementations and means we use truncate_setsize
almost everywhere. Get rid of fat_setsize now that it's trivial and mark
ext2_setsize static to make the calling convention obvious.
Keep the inode_newsize_ok in vmtruncate for now as all callers need an
audit for its removal anyway.
Note: setattr code in ecryptfs doesn't call inode_change_ok at all and
needs a deeper audit, but that is left for later.
Make sure we call inode_change_ok before doing any changes in ->setattr,
and make sure to call it even if our fs wants to ignore normal UNIX
permissions, but use the ATTR_FORCE to skip those.
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
fuse: add retrieve request
fuse: add store request
fuse: don't use atomic kmap
Currently MAY_ACCESS means that filesystems must check the permissions
right then and not rely on cached results or the results of future
operations on the object. This can be because of a call to sys_access() or
because of a call to chdir() which needs to check search without relying on
any future operations inside that dir. I plan to use MAY_ACCESS for other
purposes in the security system, so I split the MAY_ACCESS and the
MAY_CHDIR cases.
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov>
Signed-off-by: James Morris <jmorris@namei.org>
Userspace filesystem can request data to be retrieved from the inode's
mapping. This request is synchronous and the retrieved data is queued
as a new request. If the write to the fuse device returns an error
then the retrieve request was not completed and a reply will not be
sent.
Only present pages are returned in the retrieve reply. Retrieving
stops when it finds a non-present page and only data prior to that is
returned.
This request doesn't change the dirty state of pages.
Userspace filesystem can request data to be stored in the inode's
mapping. This request is synchronous and has no reply. If the write
to the fuse device returns an error then the store request was not
fully completed (but may have updated some pages).
If the stored data overflows the current file size, then the size is
extended, similarly to a write(2) on the filesystem.
Pages which have been completely stored are marked uptodate.
Don't use atomic kmap for mapping userspace buffers in device
read/write/splice.
This is necessary because the next patch (adding store notify)
requires that caller of fuse_copy_page() may sleep between
invocations. The simplest way to ensure this is to change the atomic
kmaps to non-atomic ones.
Thankfully architectures where kmap() is not a no-op are going out of
fashion, so we can ignore the (probably negligible) performance impact
of this change.
mm: export generic_pipe_buf_*() to modules
fuse: support splice() reading from fuse device
fuse: allow splice to move pages
mm: export remove_from_page_cache() to modules
mm: export lru_cache_add_*() to modules
fuse: support splice() writing to fuse device
fuse: get page reference for readpages
fuse: use get_user_pages_fast()
fuse: remove unneeded variable
This adds:
alias: devname:<name>
to some common kernel modules, which will allow the on-demand loading
of the kernel module when the device node is accessed.
Ideally all these modules would be compiled-in, but distros seems too
much in love with their modularization that we need to cover the common
cases with this new facility. It will allow us to remove a bunch of pretty
useless init scripts and modprobes from init scripts.
The static device node aliases will be carried in the module itself. The
program depmod will extract this information to a file in the module directory:
$ cat /lib/modules/2.6.34-00650-g537b60d-dirty/modules.devname
# Device nodes to trigger on-demand module loading.
microcode cpu/microcode c10:184
fuse fuse c10:229
ppp_generic ppp c108:0
tun net/tun c10:200
dm_mod mapper/control c10:235
Udev will pick up the depmod created file on startup and create all the
static device nodes which the kernel modules specify, so that these modules
get automatically loaded when the device node is accessed:
$ /sbin/udevd --debug
static_dev_create_from_modules: mknod '/dev/cpu/microcode' c10:184
static_dev_create_from_modules: mknod '/dev/fuse' c10:229
static_dev_create_from_modules: mknod '/dev/ppp' c108:0
static_dev_create_from_modules: mknod '/dev/net/tun' c10:200
static_dev_create_from_modules: mknod '/dev/mapper/control' c10:235
udev_rules_apply_static_dev_perms: chmod '/dev/net/tun' 0666
udev_rules_apply_static_dev_perms: chmod '/dev/fuse' 0666
A few device nodes are switched to statically allocated numbers, to allow
the static nodes to work. This might also useful for systems which still run
a plain static /dev, which is completely unsafe to use with any dynamic minor
numbers.
Note:
The devname aliases must be limited to the *common* and *single*instance*
device nodes, like the misc devices, and never be used for conceptually limited
systems like the loop devices, which should rather get fixed properly and get a
control node for losetup to talk to, instead of creating a random number of
device nodes in advance, regardless if they are ever used.
This facility is to hide the mess distros are creating with too modualized
kernels, and just to hide that these modules are not compiled-in, and not to
paper-over broken concepts. Thanks! :)
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Alasdair G Kergon <agk@redhat.com>
Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk>
Cc: Ian Kent <raven@themaw.net>
Signed-Off-By: Kay Sievers <kay.sievers@vrfy.org>
Allow userspace filesystem implementation to use splice() to read from
the fuse device.
The userspace filesystem can now transfer data coming from a WRITE
request to an arbitrary file descriptor (regular file, block device or
socket) without having to go through a userspace buffer.
The semantics of using splice() to read messages are:
1) with a single splice() call move the whole message from the fuse
device to a temporary pipe
2) read the header from the pipe and determine the message type
3a) if message is a WRITE then splice data from pipe to destination
3b) else read rest of message to userspace buffer
When splicing buffers to the fuse device with SPLICE_F_MOVE, try to
move pages from the pipe buffer into the page cache. This allows
populating the fuse filesystem's cache without ever touching the page
contents, i.e. zero copy read capability.
The following steps are performed when trying to move a page into the
page cache:
- buf->ops->confirm() to make sure the new page is uptodate
- buf->ops->steal() to try to remove the new page from it's previous place
- remove_from_page_cache() on the old page
- add_to_page_cache_locked() on the new page
If any of the above steps fail (non fatally) then the code falls back
to copying the page. In particular ->steal() will fail if there are
external references (other than the page cache and the pipe buffer) to
the page.
Also since the remove_from_page_cache() + add_to_page_cache_locked()
are non-atomic it is possible that the page cache is repopulated in
between the two and add_to_page_cache_locked() will fail. This could
be fixed by creating a new atomic replace_page_cache_page() function.
fuse_readpages_end() needed to be reworked so it works even if
page->mapping is NULL for some or all pages which can happen if the
add_to_page_cache_locked() failed.
A number of sanity checks were added to make sure the stolen pages
don't have weird flags set, etc... These could be moved into generic
splice/steal code.
Allow userspace filesystem implementation to use splice() to write to
the fuse device. The semantics of using splice() are:
1) buffer the message header and data in a temporary pipe
2) with a *single* splice() call move the message from the temporary pipe
to the fuse device
The READ reply message has the most interesting use for this, since
now the data from an arbitrary file descriptor (which could be a
regular file, a block device or a socket) can be tranferred into the
fuse device without having to go through a userspace buffer. It will
also allow zero copy moving of pages.
One caveat is that the protocol on the fuse device requires the length
of the whole message to be written into the header. But the length of
the data transferred into the temporary pipe may not be known in
advance. The current library implementation works around this by
using vmplice to write the header and modifying the header after
splicing the data into the pipe (error handling omitted):
struct fuse_out_header out;
iov.iov_base = &out;
iov.iov_len = sizeof(struct fuse_out_header);
vmsplice(pip[1], &iov, 1, 0);
len = splice(input_fd, input_offset, pip[1], NULL, len, 0);
/* retrospectively modify the header: */
out.len = len + sizeof(struct fuse_out_header);
splice(pip[0], NULL, fuse_chan_fd(req->ch), NULL, out.len, flags);
This works since vmsplice only saves a pointer to the data, it does
not copy the data itself.
Since pipes are currently limited to 16 pages and messages need to be
spliced atomically, the length of the data is limited to 15 pages (or
60kB for 4k pages).
Acquire a page ref on pages in ->readpages() and release them when the
read has finished. Not acquiring a reference didn't seem to cause any
trouble since the page is locked and will not be kicked out of the
page cache during the read.
However the following patches will want to remove the page from the
cache so a separate ref is needed. Making the reference in req->pages
explicit also makes the code easier to understand.
Replace uses of get_user_pages() with get_user_pages_fast(). It looks
nicer and should be faster in most cases.
"map" isn't needed any more after: 0bd87182d3ab18 "fuse: fix kunmap in
fuse_ioctl_copy_user"
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
fuse: fix large stack use
fuse: cleanup in fuse_notify_inval_...()
In particular, several occurances of funny versions of 'success',
'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address',
'beginning', 'desirable', 'separate' and 'necessary' are fixed.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Joe Perches <joe@perches.com>
Cc: Junio C Hamano <gitster@pobox.com>
gcc 4.4 warns about:
fs/fuse/dev.c: In function ‘fuse_notify_inval_entry’:
fs/fuse/dev.c:925: warning: the frame size of 1060 bytes is larger than 1024 bytes
The problem is we declare two structures and a large array on the stack,
I move the array alway from the stack and allocate memory for it dynamically.
Signed-off-by: Fang Wenqi <antonf@turbolinux.com.cn>
Small cleanup in fuse_notify_inval_inode() and
fuse_notify_inval_entry().
The cache alias problem will happen if the changes of user shared mapping
is not flushed before copying, then user and kernel mapping may be mapped
into two different cache line, it is impossible to guarantee the coherence
after iov_iter_copy_from_user_atomic. So the right steps should be:
flush_dcache_page(page);
kmap_atomic(page);
write to page;
kunmap_atomic(page);
More precisely, we might create two new APIs flush_dcache_user_page and
flush_dcache_kern_page to replace the two flush_dcache_page accordingly.
Here is a snippet tested on omap2430 with VIPT cache, and I think it is
not ARM-specific:
int val = 0x11111111;
fd = open("abc", O_RDWR);
addr = mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0);
*(addr+0) = 0x44444444;
tmp = *(addr+0);
*(addr+1) = 0x77777777;
write(fd, &val, sizeof(int));
close(fd);
The results are not always 0x11111111 0x77777777 at the beginning as expected. Sometimes we see 0x44444444 0x77777777.
Signed-off-by: Anfei <anfei.zhou@gmail.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: <linux-arch@vger.kernel.org>
Cc: <stable@kernel.org>
The comment in fuse_open about O_DIRECT:
"VFS checks this, but only _after_ ->open()"
also holds for fuse_create, however, the same kind of check was missing there.
As an impact of this bug, open(newfile, O_RDWR|O_CREAT|O_DIRECT) fails, but a
stub newfile will remain if the fuse server handled the implied FUSE_CREATE
request appropriately.
Other impact: in the above situation ima_file_free() will complain to open/free
imbalance if CONFIG_IMA is set.
Signed-off-by: Csaba Henk <csaba@gluster.com>
Cc: Harshavardhana <harsha@gluster.com>
Cc: stable@kernel.org
Invalidate the target's attributes, which may have changed (such as
nlink, change time) so that they are refreshed on the next getattr().
Looks like another victim of the confusing kmap() vs kmap_atomic() API
differences.
Reported-by: Todor Gyumyushev <yodor1@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
fuse_direct_io() has a loop where requests are allocated in each
iteration. if allocation fails, the loop is broken out and follows
into an unconditional fuse_put_request() on that invalid pointer.
Signed-off-by: Anand V. Avati <avati@gluster.com>
* mark struct vm_area_struct::vm_ops as const
* mark vm_ops in AGP code
But leave TTM code alone, something is fishy there with global vm_ops
being used.
Update some fs code to make use of new helper functions introduced
in the previous patch. Should be no significant change in behaviour
(except CIFS now calls send_sig under i_lock, via inode_newsize_ok).
Acked-by: Miklos Szeredi <miklos@szeredi.hu>
Cc: linux-nfs@vger.kernel.org
Cc: Trond.Myklebust@netapp.com
Cc: linux-cifs-client@lists.samba.org
Cc: sfrench@samba.org
Signed-off-by: Nick Piggin <npiggin@suse.de>
fuse: add fusectl interface to max_background
fuse: limit user-specified values of max background requests
fuse: use drop_nlink() instead of direct nlink manipulation
fuse: document protocol version negotiation
fuse: make the number of max background requests and congestion threshold tunable
We do this automatically in get_sb_bdev() from the set_bdev_super()
callback. Filesystems that have their own private backing_dev_info
must assign that in ->fill_super().
Note that ->s_bdi assignment is required for proper writeback!
Acked-by: Christoph Hellwig <hch@infradead.org>
Make the max_background and congestion_threshold parameters of a FUSE
mount tunable at runtime by adding the respective knobs to its directory
within the fusectl filesystem.
An untrusted user could DoS the system if s/he were allowed to accumulate an
arbitrary number of pending background requests by setting the above limits
to extremely high values in INIT. This patch excludes this possibility by
imposing global upper limits on the possible values of per-mount "max
background requests" and "congestion threshold" parameters for unprivileged
FUSE filesystems.
These global limits are implemented as module parameters.
drop_nlink() is the API function to decrease the link count of an inode.
However, at a place the control filesystem used the decrement operator
on i_nlink directly. Fix this.
Cc: Anand Avati <avati@gluster.com>
This enables us to track who does what and print info. Its main use
is catching dirty inodes on the default_backing_dev_info, so we can
fix that up.
This reverts commit 097041e576ee3a50d92dd643ee8ca65bf6a62e21.
Trond had a better fix, which is the parent of this one ("Fix compile
error due to congestion_wait() changes")
Requested-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
When building v2.6.31-rc2-344-g69ca06c, the following build errors are
found due to missing includes:
CC [M] fs/fuse/dev.o
fs/fuse/dev.c: In function ‘request_end’:
fs/fuse/dev.c:289: error: ‘BLK_RW_SYNC’ undeclared (first use in this function)
fs/nfs/write.c: In function ‘nfs_set_page_writeback’:
fs/nfs/write.c:207: error: ‘BLK_RW_ASYNC’ undeclared (first use in this function)
Signed-off-by: Larry Finger@lwfinger.net>
Commit 1faa16d22877f4839bd433547d770c676d1d964c accidentally broke
the bdi congestion wait queue logic, causing us to wait on congestion
for WRITE (== 1) when we really wanted BLK_RW_ASYNC (== 0) instead.
tunable
The practical values for these limits depend on the design of the
filesystem server so let userspace set them at initialization time.
Add notification messages that allow the filesystem to invalidate VFS
caches.
Two notifications are added:
1) inode invalidation
- invalidate cached attributes
- invalidate a range of pages in the page cache (this is optional)
2) dentry invalidation
- try to invalidate a subtree in the dentry cache
Care must be taken while accessing the 'struct super_block' for the
mount, as it can go away while an invalidation is in progress. To
prevent this, introduce a rw-semaphore, that is taken for read during
the invalidation and taken for write in the ->kill_sb callback.
Cc: Csaba Henk <csaba@gluster.com>
Cc: Anand Avati <avati@zresearch.com>
This patch lets filesystems handle masking the file mode on creation.
This is needed if filesystem is using ACLs.
- The CREATE, MKDIR and MKNOD requests are extended with a "umask"
parameter.
- A new FUSE_DONT_MASK flag is added to the INIT request/reply. With
this the filesystem may request that the create mode is not masked.
CC: Jean-Pierre André <jean-pierre.andre@wanadoo.fr>
Fix fuse_file_poll() which returned a -errno value instead of a poll
mask.
