commit 0ad0b3255a08020eaf50e34ef0d6df5bdf5e09ed upstream.
fc->release is called from fuse_conn_put() which was used in the error
cleanup before fc->release was initialized.
[Jeremiah Mahler <jmmahler@gmail.com>: assign fc->release after calling
fuse_conn_init(fc) instead of before.]
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Fixes: a325f9b92273 ("fuse: update fuse_conn_init() and separate out fuse_conn_kill()")
commit 0d2783626a53d4c922f82d51fa675cb5d13f0d36 upstream.
fuse_try_move_page() is not prepared for replacing pages that have already
been read.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
commit aa991b3b267e24f578bac7b09cc57579b660304b upstream.
Regular pipe buffers' ->steal method (generic_pipe_buf_steal()) doesn't set
PG_uptodate.
Don't warn on this condition, just set the uptodate flag.
possible
commit 2457aec63745e235bcafb7ef312b182d8682f0fc upstream.
aops->write_begin may allocate a new page and make it visible only to have
mark_page_accessed called almost immediately after. Once the page is
visible the atomic operations are necessary which is noticable overhead
when writing to an in-memory filesystem like tmpfs but should also be
noticable with fast storage. The objective of the patch is to initialse
the accessed information with non-atomic operations before the page is
visible.
The bulk of filesystems directly or indirectly use
grab_cache_page_write_begin or find_or_create_page for the initial
allocation of a page cache page. This patch adds an init_page_accessed()
helper which behaves like the first call to mark_page_accessed() but may
called before the page is visible and can be done non-atomically.
The primary APIs of concern in this care are the following and are used
by most filesystems.
find_get_page
find_lock_page
find_or_create_page
grab_cache_page_nowait
All of them are very similar in detail to the patch creates a core helper
pagecache_get_page() which takes a flags parameter that affects its
behavior such as whether the page should be marked accessed or not. Then
old API is preserved but is basically a thin wrapper around this core
function.
Each of the filesystems are then updated to avoid calling
mark_page_accessed when it is known that the VM interfaces have already
done the job. There is a slight snag in that the timing of the
mark_page_accessed() has now changed so in rare cases it's possible a page
gets to the end of the LRU as PageReferenced where as previously it might
have been repromoted. This is expected to be rare but it's worth the
filesystem people thinking about it in case they see a problem with the
timing change. It is also the case that some filesystems may be marking
pages accessed that previously did not but it makes sense that filesystems
have consistent behaviour in this regard.
The test case used to evaulate this is a simple dd of a large file done
multiple times with the file deleted on each iterations. The size of the
file is 1/10th physical memory to avoid dirty page balancing. In the
async case it will be possible that the workload completes without even
hitting the disk and will have variable results but highlight the impact
of mark_page_accessed for async IO. The sync results are expected to be
more stable. The exception is tmpfs where the normal case is for the "IO"
to not hit the disk.
The test machine was single socket and UMA to avoid any scheduling or NUMA
artifacts. Throughput and wall times are presented for sync IO, only wall
times are shown for async as the granularity reported by dd and the
variability is unsuitable for comparison. As async results were variable
do to writback timings, I'm only reporting the maximum figures. The sync
results were stable enough to make the mean and stddev uninteresting.
The performance results are reported based on a run with no profiling.
Profile data is based on a separate run with oprofile running.
async dd
3.15.0-rc3 3.15.0-rc3
vanilla accessed-v2
ext3 Max elapsed 13.9900 ( 0.00%) 11.5900 ( 17.16%)
tmpfs Max elapsed 0.5100 ( 0.00%) 0.4900 ( 3.92%)
btrfs Max elapsed 12.8100 ( 0.00%) 12.7800 ( 0.23%)
ext4 Max elapsed 18.6000 ( 0.00%) 13.3400 ( 28.28%)
xfs Max elapsed 12.5600 ( 0.00%) 2.0900 ( 83.36%)
The XFS figure is a bit strange as it managed to avoid a worst case by
sheer luck but the average figures looked reasonable.
samples percentage
ext3 86107 0.9783 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext3 23833 0.2710 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext3 5036 0.0573 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
ext4 64566 0.8961 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext4 5322 0.0713 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext4 2869 0.0384 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 62126 1.7675 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
xfs 1904 0.0554 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 103 0.0030 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
btrfs 10655 0.1338 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
btrfs 2020 0.0273 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
btrfs 587 0.0079 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
tmpfs 59562 3.2628 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
tmpfs 1210 0.0696 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
tmpfs 94 0.0054 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
[akpm@linux-foundation.org: don't run init_page_accessed() against an uninitialised pointer]
Cc: Jan Kara <jack@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Tested-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
commit b745bc85f21ea707e4ea1a91948055fa3e72c77b upstream.
cold is a bool, make it one. Make the likely case the "if" part of the
block instead of the else as according to the optimisation manual this is
preferred.
commit 9e8c2af96e0d2d5fe298dd796fb6bc16e888a48d upstream.
... it does that itself (via kmap_atomic())
commit 154210ccb3a871e631bf39fdeb7a8731d98af87b upstream.
The following test case demonstrates the bug:
sh# mount -t glusterfs localhost:meta-test /mnt/one
sh# mount -t glusterfs localhost:meta-test /mnt/two
sh# echo stuff > /mnt/one/file; rm -f /mnt/two/file; echo stuff > /mnt/one/file
bash: /mnt/one/file: Stale file handle
sh# echo stuff > /mnt/one/file; rm -f /mnt/two/file; sleep 1; echo stuff > /mnt/one/file
On the second open() on /mnt/one, FUSE would have used the old
nodeid (file handle) trying to re-open it. Gluster is returning
-ESTALE. The ESTALE propagates back to namei.c:filename_lookup()
where lookup is re-attempted with LOOKUP_REVAL. The right
behavior now, would be for FUSE to ignore the entry-timeout and
and do the up-call revalidation. Instead FUSE is ignoring
LOOKUP_REVAL, succeeding the revalidation (because entry-timeout
has not passed), and open() is again retried on the old file
handle and finally the ESTALE is going back to the application.
Fix: if revalidation is happening with LOOKUP_REVAL, then ignore
entry-timeout and always do the up-call.
Signed-off-by: Anand Avati <avati@redhat.com>
Reviewed-by: Niels de Vos <ndevos@redhat.com>
commit 233a01fa9c4c7c41238537e8db8434667ff28a2f upstream.
If the number in "user_id=N" or "group_id=N" mount options was larger than
INT_MAX then fuse returned EINVAL.
Fix this to handle all valid uid/gid values.
commit 126b9d4365b110c157bc4cbc32540dfa66c9c85a upstream.
As suggested by checkpatch.pl, use time_before64() instead of direct
comparison of jiffies64 values.
Pull vfs updates from Al Viro:
"Assorted stuff; the biggest pile here is Christoph's ACL series. Plus
assorted cleanups and fixes all over the place...
There will be another pile later this week"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (43 commits)
__dentry_path() fixes
vfs: Remove second variable named error in __dentry_path
vfs: Is mounted should be testing mnt_ns for NULL or error.
Fix race when checking i_size on direct i/o read
hfsplus: remove can_set_xattr
nfsd: use get_acl and ->set_acl
fs: remove generic_acl
nfs: use generic posix ACL infrastructure for v3 Posix ACLs
gfs2: use generic posix ACL infrastructure
jfs: use generic posix ACL infrastructure
xfs: use generic posix ACL infrastructure
reiserfs: use generic posix ACL infrastructure
ocfs2: use generic posix ACL infrastructure
jffs2: use generic posix ACL infrastructure
hfsplus: use generic posix ACL infrastructure
f2fs: use generic posix ACL infrastructure
ext2/3/4: use generic posix ACL infrastructure
btrfs: use generic posix ACL infrastructure
fs: make posix_acl_create more useful
fs: make posix_acl_chmod more useful
So far I've had one ACK for this, and no other comments. So I think it
is probably time to send this via some suitable tree. I'm guessing that
the vfs tree would be the most appropriate route, but not sure that
there is one at the moment (don't see anything recent at kernel.org)
so in that case I think -mm is the "back up plan". Al, please let me
know if you will take this?
Steve.
Following on from the "Re: [PATCH v3] vfs: fix a bug when we do some dio
reads with append dio writes" thread on linux-fsdevel, this patch is my
current version of the fix proposed as option (b) in that thread.
Removing the i_size test from the direct i/o read path at vfs level
means that filesystems now have to deal with requests which are beyond
i_size themselves. These I've divided into three sets:
a) Those with "no op" ->direct_IO (9p, cifs, ceph)
These are obviously not going to be an issue
b) Those with "home brew" ->direct_IO (nfs, fuse)
I've been told that NFS should not have any problem with the larger
i_size, however I've added an extra test to FUSE to duplicate the
original behaviour just to be on the safe side.
c) Those using __blockdev_direct_IO()
These call through to ->get_block() which should deal with the EOF
condition correctly. I've verified that with GFS2 and I believe that
Zheng has verified it for ext4. I've also run the test on XFS and it
passes both before and after this change.
The part of the patch in filemap.c looks a lot larger than it really is
- there are only two lines of real change. The rest is just indentation
of the contained code.
There remains a test of i_size though, which was added for btrfs. It
doesn't cause the other filesystems a problem as the test is performed
after ->direct_IO has been called. It is possible that there is a race
that does matter to btrfs, however this patch doesn't change that, so
its still an overall improvement.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
Reported-by: Zheng Liu <gnehzuil.liu@gmail.com>
Acked-by: Miklos Szeredi <miklos@szeredi.hu>
Cc: Chris Mason <clm@fb.com>
Cc: Josef Bacik <jbacik@fb.com>
open/release operations require userspace transitions to keep track
of the open count and to perform any FS-specific setup. However,
for some purely read-only FSs which don't need to perform any setup
at open/release time, we can avoid the performance overhead of
calling into userspace for open/release calls.
This patch adds the necessary support to the fuse kernel modules to prevent
open/release operations from hitting in userspace. When the client returns
ENOSYS, we avoid sending the subsequent release to userspace, and also
remember this so that future opens also don't trigger a userspace
operation.
Various read operations (e.g. readlink, readdir) invalidate the cached
attrs for atime changes. This patch adds a new function
'fuse_invalidate_atime', which checks for a read-only super block and
avoids the attr invalidation in that case.
Signed-off-by: Andrew Gallagher <andrewjcg@fb.com>
As noticed by Coverity the "num != 0" condition never triggers. Instead it
should check for a complete page.
Having this struct in module memory could Oops when if the module is
unloaded while the buffer still persists in a pipe.
Since sock_pipe_buf_ops is essentially the same as fuse_dev_pipe_buf_steal
merge them into nosteal_pipe_buf_ops (this is the same as
default_pipe_buf_ops except stealing the page from the buffer is not
allowed).
Cc: stable@vger.kernel.org
"All kinds of stuff this time around; some more notable parts:
- RCU'd vfsmounts handling
- new primitives for coredump handling
- files_lock is gone
- Bruce's delegations handling series
- exportfs fixes
plus misc stuff all over the place"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (101 commits)
ecryptfs: ->f_op is never NULL
locks: break delegations on any attribute modification
locks: break delegations on link
locks: break delegations on rename
locks: helper functions for delegation breaking
locks: break delegations on unlink
namei: minor vfs_unlink cleanup
locks: implement delegations
locks: introduce new FL_DELEG lock flag
vfs: take i_mutex on renamed file
vfs: rename I_MUTEX_QUOTA now that it's not used for quotas
vfs: don't use PARENT/CHILD lock classes for non-directories
vfs: pull ext4's double-i_mutex-locking into common code
exportfs: fix quadratic behavior in filehandle lookup
exportfs: better variable name
exportfs: move most of reconnect_path to helper function
exportfs: eliminate unused "noprogress" counter
exportfs: stop retrying once we race with rename/remove
exportfs: clear DISCONNECTED on all parents sooner
exportfs: more detailed comment for path_reconnect
All async fuse requests must be supplied with extra reference to a fuse
file. This is necessary to ensure that the fuse file is not released until
all in-flight requests are completed. Fuse secondary writeback requests
must obey this rule as well.
Signed-off-by: Maxim Patlasov <MPatlasov@parallels.com>
BDI_WRITTEN counter is used to estimate bdi bandwidth. It must be
incremented every time as bdi ends page writeback. No matter whether it
was fulfilled by actual write or by discarding the request (e.g. due to
shrunk i_size).
Note that even before writepages patches, the case "Got truncated off
completely" was handled in fuse_send_writepage() by calling
fuse_writepage_finish() which updated BDI_WRITTEN unconditionally.
If writeback happens while fuse is in FUSE_NOWRITE condition, the request
will be queued but not processed immediately (see fuse_flush_writepages()).
Until FUSE_NOWRITE becomes relaxed, more writebacks can happen. They will
be queued as "secondary" requests to that first ("primary") request.
Existing implementation crops only primary request. This is not correct
because a subsequent extending write(2) may increase i_size and then
secondary requests won't be cropped properly. The result would be stale
data written to the server to a file offset where zeros must be.
Similar problem may happen if secondary requests are attached to an
in-flight request that was already cropped.
The patch solves the issue by cropping all secondary requests in
fuse_writepage_end(). Thanks to Miklos for idea.
fuse_writepage_in_flight() returns false if it fails to find request with
given index in fi->writepages. Then the caller proceeds with populating
data->orig_pages[] and incrementing req->num_pages. Hence,
fuse_writepage_in_flight() must revert changes it made in request before
returning false.
makes ->permission() and ->d_revalidate() safety in RCU mode independent
from vfsmount_lock.
...which just returns -EBUSY if a directory alias would be created.
This is to be used by fuse mkdir to make sure that a buggy or malicious
userspace filesystem doesn't do anything nasty. Previously fuse used a
private mutex for this purpose, which can now go away.
This allows udev (or more recently systemd-tmpfiles) to create /dev/cuse on
boot, in the same way as /dev/fuse is currently created, and the corresponding
module to be loaded on first access.
The corresponding functionalty was introduced for fuse in commit 578454f.
Signed-off-by: Tom Gundersen <teg@jklm.no>
Cc: Kay Sievers <kay@vrfy.org>
If ->writepage() tries to write back a page whose copy is still in flight,
then just skip by calling redirty_page_for_writepage().
This is OK, since now ->writepage() should never be called for data
integrity sync.
As Maxim Patlasov pointed out, it's possible to get a dirty page while it's
copy is still under writeback, despite fuse_page_mkwrite() doing its thing
(direct IO).
This could result in two concurrent write request for the same offset, with
data corruption if they get mixed up.
To prevent this, fuse needs to check and delay such writes. This
implementation does this by:
1. check if page is still under writeout, if so create a new, single page
secondary request for it
2. chain this secondary request onto the in-flight request
2/a. if a seconday request for the same offset was already chained to the
in-flight request, then just copy the contents of the page and discard
the new secondary request. This makes sure that for each page will
have at most two requests associated with it
3. when the in-flight request finished, send off all secondary requests
chained onto it
Checking against tmp-page indexes is not very useful, and results in one
(or rarely two) page requests. Which is not much of an improvement...
The patch fixes a race between ftruncate(2), mmap-ed write and write(2):
1) An user makes a page dirty via mmap-ed write.
2) The user performs shrinking truncate(2) intended to purge the page.
3) Before fuse_do_setattr calls truncate_pagecache, the page goes to
writeback. fuse_writepages_fill attaches a new page to FUSE_WRITE request,
then releases the original page by end_page_writeback and unlock it.
4) fuse_do_setattr completes and successfully returns. Since now, i_mutex
is free.
5) Ordinary write(2) extends i_size back to cover the page. Note that
fuse_send_write_pages do wait for fuse writeback, but for another
page->index.
6) fuse_writepages_fill attaches more pages to the request (if any), then
fuse_writepages_send is eventually called. It is supposed to crop
inarg->size of the request, but it doesn't because i_size has already been
extended back.
Moving end_page_writeback behind fuse_writepages_send guarantees that
__fuse_release_nowrite (called from fuse_do_setattr) will crop inarg->size
of the request before write(2) gets the chance to extend i_size.
Signed-off-by: Maxim Patlasov <mpatlasov@parallels.com>
The .writepages one is required to make each writeback request carry more than
one page on it. The patch enables optimized behaviour unconditionally,
i.e. mmap-ed writes will benefit from the patch even if fc->writeback_cache=0.
[SzM: simplify, add comments]
Don't bug if there's no writable files found for page writeback. If ever
this is triggered, a WARN_ON helps debugging it much better then a BUG_ON.
Lock the page in fuse_page_mkwrite() to protect against a race with
fuse_writepage() where the page is redirtied before the actual writeback
begins.
The .writepages callback will issue writeback requests with more than one
page aboard. Make existing end/check code be aware of this.
There will be a .writepageS callback implementation which will need to
get a fuse_file out of a fuse_inode, thus make a helper for this.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
fuse_access() is never called in RCU walk, only on the final component of
access(2) and chdir(2)...
Doing dput(parent) is not valid in RCU walk mode. In RCU mode it would
probably be okay to update the parent flags, but it's actually not
necessary most of the time...
So only set the FUSE_I_ADVISE_RDPLUS flag on the parent when the entry was
recently initialized by READDIRPLUS.
This is achieved by setting FUSE_I_INIT_RDPLUS on entries added by
READDIRPLUS and only dropping out of RCU mode if this flag is set.
FUSE_I_INIT_RDPLUS is cleared once the FUSE_I_ADVISE_RDPLUS flag is set in
the parent.
If revalidate finds an invalid dentry in RCU walk mode, let the VFS deal
with it instead of calling check_submounts_and_drop() which is not prepared
for being called from RCU walk.
A former patch introducing FUSE_I_SIZE_UNSTABLE flag provided detailed
description of races between ftruncate and anyone who can extend i_size:
> 1. As in the previous scenario fuse_dentry_revalidate() discovered that i_size
> changed (due to our own fuse_do_setattr()) and is going to call
> truncate_pagecache() for some 'new_size' it believes valid right now. But by
> the time that particular truncate_pagecache() is called ...
> 2. fuse_do_setattr() returns (either having called truncate_pagecache() or
> not -- it doesn't matter).
> 3. The file is extended either by write(2) or ftruncate(2) or fallocate(2).
> 4. mmap-ed write makes a page in the extended region dirty.
This patch adds necessary bits to fuse_file_fallocate() to protect from that
race.
The patch fixes a race between mmap-ed write and fallocate(PUNCH_HOLE):
2) The user performs fallocate(2) with mode == PUNCH_HOLE|KEEP_SIZE
and <offset, size> covering the page.
3) Before truncate_pagecache_range call from fuse_file_fallocate,
the page goes to write-back. The page is fully processed by fuse_writepage
(including end_page_writeback on the page), but fuse_flush_writepages did
nothing because fi->writectr < 0.
4) truncate_pagecache_range is called and fuse_file_fallocate is finishing
by calling fuse_release_nowrite. The latter triggers processing queued
write-back request which will write stale data to the hole soon.
Changed in v2 (thanks to Brian for suggestion):
- Do not truncate page cache until FUSE_FALLOCATE succeeded. Otherwise,
we can end up in returning -ENOTSUPP while user data is already punched
from page cache. Use filemap_write_and_wait_range() instead.
Changed in v3 (thanks to Miklos for suggestion):
- fuse_wait_on_writeback() is prone to livelocks; use fuse_set_nowrite()
instead. So far as we need a dirty-page barrier only, fuse_sync_writes()
should be enough.
- rebased to for-linus branch of fuse.git
truncate_pagecache() doesn't care about old size since commit
cedabed49b39 ("vfs: Fix vmtruncate() regression"). Let's drop it.
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
The feature prevents mistrusted filesystems (ie: FUSE mounts created by
unprivileged users) to grow a large number of dirty pages before
throttling. For such filesystems balance_dirty_pages always check bdi
counters against bdi limits. I.e. even if global "nr_dirty" is under
"freerun", it's not allowed to skip bdi checks. The only use case for now
is fuse: it sets bdi max_ratio to 1% by default and system administrators
are supposed to expect that this limit won't be exceeded.
The feature is on if a BDI is marked by BDI_CAP_STRICTLIMIT flag. A
filesystem may set the flag when it initializes its BDI.
The problematic scenario comes from the fact that nobody pays attention to
the NR_WRITEBACK_TEMP counter (i.e. number of pages under fuse
writeback). The implementation of fuse writeback releases original page
(by calling end_page_writeback) almost immediately. A fuse request queued
for real processing bears a copy of original page. Hence, if userspace
fuse daemon doesn't finalize write requests in timely manner, an
aggressive mmap writer can pollute virtually all memory by those temporary
fuse page copies. They are carefully accounted in NR_WRITEBACK_TEMP, but
nobody cares.
To make further explanations shorter, let me use "NR_WRITEBACK_TEMP
problem" as a shortcut for "a possibility of uncontrolled grow of amount
of RAM consumed by temporary pages allocated by kernel fuse to process
writeback".
The problem was very easy to reproduce. There is a trivial example
filesystem implementation in fuse userspace distribution: fusexmp_fh.c. I
added "sleep(1);" to the write methods, then recompiled and mounted it.
Then created a huge file on the mount point and run a simple program which
mmap-ed the file to a memory region, then wrote a data to the region. An
hour later I observed almost all RAM consumed by fuse writeback. Since
then some unrelated changes in kernel fuse made it more difficult to
reproduce, but it is still possible now.
Putting this theoretical happens-in-the-lab thing aside, there is another
thing that really hurts real world (FUSE) users. This is write-through
page cache policy FUSE currently uses. I.e. handling write(2), kernel
fuse populates page cache and flushes user data to the server
synchronously. This is excessively suboptimal. Pavel Emelyanov's patches
("writeback cache policy") solve the problem, but they also make resolving
NR_WRITEBACK_TEMP problem absolutely necessary. Otherwise, simply copying
a huge file to a fuse mount would result in memory starvation. Miklos,
the maintainer of FUSE, believes strictlimit feature the way to go.
And eventually putting FUSE topics aside, there is one more use-case for
strictlimit feature. Using a slow USB stick (mass storage) in a machine
with huge amount of RAM installed is a well-known pain. Let's make simple
computations. Assuming 64GB of RAM installed, existing implementation of
balance_dirty_pages will start throttling only after 9.6GB of RAM becomes
dirty (freerun == 15% of total RAM). So, the command "cp 9GB_file
/media/my-usb-storage/" may return in a few seconds, but subsequent
"umount /media/my-usb-storage/" will take more than two hours if effective
throughput of the storage is, to say, 1MB/sec.
After inclusion of strictlimit feature, it will be trivial to add a knob
(e.g. /sys/devices/virtual/bdi/x:y/strictlimit) to enable it on demand.
Manually or via udev rule. May be I'm wrong, but it seems to be quite a
natural desire to limit the amount of dirty memory for some devices we are
not fully trust (in the sense of sustainable throughput).
[akpm@linux-foundation.org: fix warning in page-writeback.c]
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse
Pull fuse bugfixes from Miklos Szeredi:
"Just a bunch of bugfixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse:
fuse: use list_for_each_entry() for list traversing
fuse: readdir: check for slash in names
fuse: hotfix truncate_pagecache() issue
fuse: invalidate inode attributes on xattr modification
fuse: postpone end_page_writeback() in fuse_writepage_locked()
Drop a subtree when we find that it has moved or been delated. This can be
done as long as there are no submounts under this location.
If the directory was moved and we come across the same directory in a
future lookup it will be reconnected by d_materialise_unique().
On errors unrelated to the filesystem's state (ENOMEM, ENOTCONN) return the
error itself from ->d_revalidate() insted of returning zero (invalid).
Also make a common label for invalidating the dentry. This will be used by
the next patch.
Use d_materialise_unique() instead of d_splice_alias(). This allows dentry
subtrees to be moved to a new place if there moved, even if something is
referencing a dentry in the subtree (open fd, cwd, etc..).
This will also allow us to drop a subtree if it is found to be replaced by
something else. In this case the disconnected subtree can later be
reconnected to its new location.
d_materialise_unique() ensures that a directory entry only ever has one
alias. We keep fc->inst_mutex around the calls for d_materialise_unique()
on directories to prevent a race with mkdir "stealing" the inode.
Userspace can add names containing a slash character to the directory
listing. Don't allow this as it could cause all sorts of trouble.
The way how fuse calls truncate_pagecache() from fuse_change_attributes()
is completely wrong. Because, w/o i_mutex held, we never sure whether
'oldsize' and 'attr->size' are valid by the time of execution of
truncate_pagecache(inode, oldsize, attr->size). In fact, as soon as we
released fc->lock in the middle of fuse_change_attributes(), we completely
loose control of actions which may happen with given inode until we reach
truncate_pagecache. The list of potentially dangerous actions includes
mmap-ed reads and writes, ftruncate(2) and write(2) extending file size.
The typical outcome of doing truncate_pagecache() with outdated arguments
is data corruption from user point of view. This is (in some sense)
acceptable in cases when the issue is triggered by a change of the file on
the server (i.e. externally wrt fuse operation), but it is absolutely
intolerable in scenarios when a single fuse client modifies a file without
any external intervention. A real life case I discovered by fsx-linux
looked like this:
1. Shrinking ftruncate(2) comes to fuse_do_setattr(). The latter sends
FUSE_SETATTR to the server synchronously, but before getting fc->lock ...
2. fuse_dentry_revalidate() is asynchronously called. It sends FUSE_LOOKUP
to the server synchronously, then calls fuse_change_attributes(). The
latter updates i_size, releases fc->lock, but before comparing oldsize vs
attr->size..
3. fuse_do_setattr() from the first step proceeds by acquiring fc->lock and
updating attributes and i_size, but now oldsize is equal to
outarg.attr.size because i_size has just been updated (step 2). Hence,
fuse_do_setattr() returns w/o calling truncate_pagecache().
4. As soon as ftruncate(2) completes, the user extends file size by
write(2) making a hole in the middle of file, then reads data from the hole
either by read(2) or mmap-ed read. The user expects to get zero data from
the hole, but gets stale data because truncate_pagecache() is not executed
yet.
The scenario above illustrates one side of the problem: not truncating the
page cache even though we should. Another side corresponds to truncating
page cache too late, when the state of inode changed significantly.
Theoretically, the following is possible:
i_size changed (due to our own fuse_do_setattr()) and is going to call
by the time that particular truncate_pagecache() is called ...
The result will be the lost of data user wrote on the fourth step.
The patch is a hotfix resolving the issue in a simplistic way: let's skip
dangerous i_size update and truncate_pagecache if an operation changing
file size is in progress. This simplistic approach looks correct for the
cases w/o external changes. And to handle them properly, more sophisticated
and intrusive techniques (e.g. NFS-like one) would be required. I'd like to
postpone it until the issue is well discussed on the mailing list(s).
Changed in v2:
- improved patch description to cover both sides of the issue.
Calls like setxattr and removexattr result in updation of ctime.
Therefore invalidate inode attributes to force a refresh.
Reviewed-by: Brian Foster <bfoster@redhat.com>
writeback. fuse_writepage_locked fills FUSE_WRITE request and releases
the original page by end_page_writeback.
4) fuse_do_setattr() completes and successfully returns. Since now, i_mutex
is free.
page->index.
6) fuse_writepage_locked proceeds by queueing FUSE_WRITE request.
fuse_send_writepage is supposed to crop inarg->size of the request,
but it doesn't because i_size has already been extended back.
Moving end_page_writeback to the end of fuse_writepage_locked fixes the
race because now the fact that truncate_pagecache is successfully returned
infers that fuse_writepage_locked has already called end_page_writeback.
And this, in turn, infers that fuse_flush_writepages has already called
fuse_send_writepage, and the latter used valid (shrunk) i_size. write(2)
could not extend it because of i_mutex held by ftruncate(2).
We want these fixes in this branch.
The dev_attrs field of struct class is going away soon, dev_groups
should be used instead. This converts the cuse class code to use the
correct field.
Acked-by: Miklos Szeredi <mszeredi@suse.cz>
