path: root/fs/generic_acl.c
2007-07-17Introduce is_owner_or_cap() to wrap CAP_FOWNER use with fsuid checkSatyam Sharma
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant users to it. This is done because we want to avoid bugs in the future where we check for only effective fsuid of the current task against a file's owning uid, without simultaneously checking for CAP_FOWNER as well, thus violating its semantics. [ XFS uses special macros and structures, and in general looked ... untouchable, so we leave it alone -- but it has been looked over. ] The (current->fsuid != inode->i_uid) check in generic_permission() and exec_permission_lite() is left alone, because those operations are covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-29[PATCH] Generic infrastructure for aclsAndreas Gruenbacher
The patches solve the following problem: We want to grant access to devices based on who is logged in from where, etc. This includes switching back and forth between multiple user sessions, etc. Using ACLs to define device access for logged-in users gives us all the flexibility we need in order to fully solve the problem. Device special files nowadays usually live on tmpfs, hence tmpfs ACLs. Different distros have come up with solutions that solve the problem to different degrees: SUSE uses a resource manager which tracks login sessions and sets ACLs on device inodes as appropriate. RedHat uses pam_console, which changes the primary file ownership to the logged-in user. Others use a set of groups that users must be in in order to be granted the appropriate accesses. The freedesktop.org project plans to implement a combination of a console-tracker and a HAL-device-list based solution to grant access to devices to users, and more distros will likely follow this approach. These patches have first been posted here on 2 February 2005, and again on 8 January 2006. We have been shipping them in SLES9 and SLES10 with no problems reported. The previous submission is archived here: http://lkml.org/lkml/2006/1/8/229 http://lkml.org/lkml/2006/1/8/230 http://lkml.org/lkml/2006/1/8/231 This patch: Add some infrastructure for access control lists on in-memory filesystems such as tmpfs. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
