path: root/fs/gfs2/Makefile
2011-05-10GFS2: Rename ops_inode.c to inode.cSteven Whitehouse
This is the final part of the ops_inode.c/inode.c reordering. We are left with a single file called inode.c which now contains all the inode operations, as expected. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2011-05-10GFS2: Inode.c is empty now, remove itSteven Whitehouse
2011-03-17fs: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. And change ntfs-objs to ntfs-y for cleaner conditional inclusion. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-08-26GFS2: Rename eattr.[ch] as xattr.[ch]Steven Whitehouse
Use the more conventional name for the extended attribute support code. Update all the places which care. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-08-26GFS2: Clean up of extended attribute supportSteven Whitehouse
This has been on my list for some time. We need to change the way in which we handle extended attributes to allow faster file creation times (by reducing the number of transactions required) and the extended attribute code is the main obstacle to this. In addition to that, the VFS provides a way to demultiplex the xattr calls which we ought to be using, rather than rolling our own. This patch changes the GFS2 code to use that VFS feature and as a result the code shrinks by a couple of hundred lines or so, and becomes easier to read. I'm planning on doing further clean up work in this area, but this patch is a good start. The cleaned up code also uses the more usual "xattr" shorthand, I plan to eliminate the use of "eattr" eventually and in the mean time it serves as a flag as to which bits of the code have been updated. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-06-12GFS2: Add tracepointsSteven Whitehouse
This patch adds the ability to trace various aspects of the GFS2 filesystem. The trace points are divided into three groups, glocks, logging and bmap. These points have been chosen because they allow inspection of the major internal functions of GFS2 and they are also generic enough that they are unlikely to need any major changes as the filesystem evolves. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-05-22GFS2: Merge mount.c and ops_super.c into super.cSteven Whitehouse
mount.c only contained a single function, so is not really worth retaining on its own. All of the super related code is now either in super.c or ops_fstype.c Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-05-22GFS2: Clean up some file namesSteven Whitehouse
This patch renames the ops_*.c files which have no counterpart without the ops_ prefix in order to shorten the name and make it more readable. In addition, ops_address.h (which was very small) is moved into inode.h and inode.h is cleaned up by adding extern where required. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-03-24GFS2: Merge lock_dlm module into GFS2Steven Whitehouse
This is the big patch that I've been working on for some time now. There are many reasons for wanting to make this change such as: o Reducing overhead by eliminating duplicated fields between structures o Simplifcation of the code (reduces the code size by a fair bit) o The locking interface is now the DLM interface itself as proposed some time ago. o Fewer lookups of glocks when processing replies from the DLM o Fewer memory allocations/deallocations for each glock o Scope to do further optimisations in the future (but this patch is more than big enough for now!) Please note that (a) this patch relates to the lock_dlm module and not the DLM itself, that is still a separate module; and (b) that we retain the ability to build GFS2 as a standalone single node filesystem with out requiring the DLM. This patch needs a lot of testing, hence my keeping it I restarted my -git tree after the last merge window. That way, this has the maximum exposure before its merged. This is (modulo a few minor bug fixes) the same patch that I've been posting on and off the the last three months and its passed a number of different tests so far. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-01-05GFS2: Kill two daemons with one patchSteven Whitehouse
This patch removes the two daemons, gfs2_scand and gfs2_glockd and replaces them with a shrinker which is called from the VM. The net result is that GFS2 responds better when there is memory pressure, since it shrinks the glock cache at the same rate as the VFS shrinks the dcache and icache. There are no longer any time based criteria for shrinking glocks, they are kept until such time as the VM asks for more memory and then we demote just as many glocks as required. There are potential future changes to this code, including the possibility of sorting the glocks which are to be written back into inode number order, to get a better I/O ordering. It would be very useful to have an elevator based workqueue implementation for this, as that would automatically deal with the read I/O cases at the same time. This patch is my answer to Andrew Morton's remark, made during the initial review of GFS2, asking why GFS2 needs so many kernel threads, the answer being that it doesn't :-) This patch is a net loss of about 200 lines of code. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-06-27[GFS2] No lock_nolockSteven Whitehouse
This patch merges the lock_nolock module into GFS2 itself. As well as removing some of the overhead of the module, it also means that its now impossible to build GFS2 without a lock module (which would be a pointless thing to do anyway). We also plan to merge lock_dlm into GFS2 in the future, but that is a more tricky task, and will therefore be a separate patch. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: David Teigland <teigland@redhat.com>
2008-03-31[GFS2] Remove lm.[ch] and distribute contentSteven Whitehouse
The functions in lm.c were just wrappers which were mostly only used in one other file. By moving the functions to the files where they are being used, they can be marked static and also this will usually result in them being inlined since they are often only used from one point in the code. A couple of really trivial functions have been inlined by hand into the function which called them as it makes the code clearer to do that. We also gain from one fewer function call in the glock lock and unlock paths. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-01-25[GFS2] Use ->page_mkwrite() for mmap()Steven Whitehouse
This cleans up the mmap() code path for GFS2 by implementing the page_mkwrite function for GFS2. We are thus able to use the generic filemap_fault function for our ->fault() implementation. This now means that shared writable mappings will be much more efficiently shared across the cluster if there is a reasonable proportion of read activity (the greater proportion, the better). As a side effect, it also reduces the size of the code, removes special cases from readpage and readpages, and makes the code path easier to follow. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[GFS2] Fix sign problem in quota/statfs and cleanup _host structuresSteven Whitehouse
This patch fixes some sign issues which were accidentally introduced into the quota & statfs code during the endianess annotation process. Also included is a general clean up which moves all of the _host structures out of gfs2_ondisk.h (where they should not have been to start with) and into the places where they are actually used (often only one place). Also those _host structures which are not required any more are removed entirely (which is the eventual plan for all of them). The conversion routines from ondisk.c are also moved into the places where they are actually used, which for almost every one, was just one single place, so all those are now static functions. This also cleans up the end of gfs2_ondisk.h which no longer needs the #ifdef __KERNEL__. The net result is a reduction of about 100 lines of code, many functions now marked static plus the bug fixes as mentioned above. For good measure I ran the code through sparse after making these changes to check that there are no warnings generated. This fixes Red Hat bz #239686 Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-01[GFS2] Update copyright, tidy up incore.hSteven Whitehouse
As per comments from Jan Engelhardt <jengelh@linux01.gwdg.de> this updates the copyright message to say "version" in full rather than "v.2". Also incore.h has been updated to remove forward structure declarations which are not required. The gfs2_quota_lvb structure has now had endianess annotations added to it. Also quota.c has been updated so that we now store the lvb data locally in endian independant format to avoid needing a structure in host endianess too. As a result the endianess conversions are done as required at various points and thus the conversion routines in lvb.[ch] are no longer required. I've moved the one remaining constant in lvb.h thats used into lm.h and removed the unused lvb.[ch]. I have not changed the HIF_ constants. That is left to a later patch which I hope will unify the gh_flags and gh_iflags fields of the struct gfs2_holder. Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-07-26[GFS2] Remove page.[ch]Steven Whitehouse
The remaining routines in page.c were all only used in one other file, so they are now moved into the files where they are referenced and made static. Thus page.[ch] are no longer required. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-06-14[GFS2] Fix unlinked file handlingSteven Whitehouse
This patch fixes the way we have been dealing with unlinked, but still open files. It removes all limits (other than memory for inodes, as per every other filesystem) on numbers of these which we can support on GFS2. It also means that (like other fs) its the responsibility of the last process to close the file to deallocate the storage, rather than the person who did the unlinking. Note that with GFS2, those two events might take place on different nodes. Also there are a number of other changes: o We use the Linux inode subsystem as it was intended to be used, wrt allocating GFS2 inodes o The Linux inode cache is now the point which we use for local enforcement of only holding one copy of the inode in core at once (previous to this we used the glock layer). o We no longer use the unlinked "special" file. We just ignore it completely. This makes unlinking more efficient. o We now use the 4th block allocation state. The previously unused state is used to track unlinked but still open inodes. o gfs2_inoded is no longer needed o Several fields are now no longer needed (and removed) from the in core struct gfs2_inode o Several fields are no longer needed (and removed) from the in core superblock There are a number of future possible optimisations and clean ups which have been made possible by this patch. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-05-18[GFS2] Remove bits.c from the MakefileSteven Whitehouse
2006-04-24[GFS2] Tidy up Makefile & KconfigSteven Whitehouse
Remove select of SYSFS as requested by Greg KH. Change whitespace to tabs rather than spaces in places where it was incorrect and removed 'default m' as suggested by Adrian Bunk. Reorganised Makefile as suggested by Sam Ravnborg. Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: Greg KH <greg@kroah.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-02-08[GFS2] Make journaled data files identical to normal files on diskSteven Whitehouse
This is a very large patch, with a few still to be resolved issues so you might want to check out the previous head of the tree since this is known to be unstable. Fixes for the various bugs will be forthcoming shortly. This patch removes the special data format which has been used up till now for journaled data files. Directories still retain the old format so that they will remain on disk compatible with earlier releases. As a result you can now do the following with journaled data files: 1) mmap them 2) export them over NFS 3) convert to/from normal files whenever you want to (the zero length restriction is gone) In addition the level at which GFS' locking is done has changed for all files (since they all now use the page cache) such that the locking is done at the page cache level rather than the level of the fs operations. This should mean that things like loopback mounts and other things which touch the page cache directly should now work. Current known issues: 1. There is a lock mode inversion problem related to the resource group hold function which needs to be resolved. 2. Any significant amount of I/O causes an oops with an offset of hex 320 (NULL pointer dereference) which appears to be related to a journaled data buffer appearing on a list where it shouldn't be. 3. Direct I/O writes are disabled for the time being (will reappear later) 4. There is probably a deadlock between the page lock and GFS' locks under certain combinations of mmap and fs operation I/O. 5. Issue relating to ref counting on internally used inodes causes a hang on umount (discovered before this patch, and not fixed by it) 6. One part of the directory metadata is different from GFS1 and will need to be resolved before next release. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-01-30[GFS2] Remove unused file resize.cSteven Whitehouse
The code in this file is no longer used as the rindex file is now accessible to userspace, so can be read/written directly. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-01-17[GFS2] Fix typo in GFS2 MakefileDavid Teigland
A two line fix to the GFS2 Makefile. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steve Whitehouse <swhiteho@redhat.com>
2006-01-16[GFS2] The core of GFS2David Teigland
This patch contains all the core files for GFS2. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
