path: root/fs/gfs2/aops.c
2016-08-18gfs2: Remove dirty buffer warning from gfs2_releasepageAndreas Gruenbacher
Unlike what its documentation suggests, the releasepage address space operation can currently be called on dirty pages via shrink_active_list. This may eventually be changed when the remaining code relying on the current behavior has been fixed, but until then, it makes no sense to warn on dirty buffers in gfs2_releasepage. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Signed-off-by: Bob Peterson <rpeterso@redhat.com>
2016-08-02GFS2: use BIT() macroFabian Frederick
Replace 1 << value shift by more explicit BIT() macro Also fixes two bare unsigned definitions: WARNING: Prefer 'unsigned int' to bare use of 'unsigned' + unsigned hsize = BIT(ip->i_depth); Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Bob Peterson <rpeterso@redhat.com>
2016-06-27gfs2: writeout truncated pagesBenjamin Marzinski
When gfs2 attempts to write a page to a file that is being truncated, and notices that the page is completely outside of the file size, it tries to invalidate it. However, this may require a transaction for journaled data files to revoke any buffers from the page on the active items list. Unfortunately, this can happen inside a log flush, where a transaction cannot be started. Also, gfs2 may need to be able to remove the buffer from the ail1 list before it can finish the log flush. To deal with this, when writing a page of a file with data journalling enabled gfs2 now skips the check to see if the write is outside the file size, and simply writes it anyway. This situation can only occur when the truncate code still has the file locked exclusively, and hasn't marked this block as free in the metadata (which happens later in truc_dealloc). After gfs2 writes this page out, the truncation code will shortly invalidate it and write out any revokes if necessary. To do this, gfs2 now implements its own version of block_write_full_page without the check, and calls the newly exported __block_write_full_page. It also no longer calls gfs2_writepage_common from gfs2_jdata_writepage. Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com> Signed-off-by: Bob Peterson <rpeterso@redhat.com>
2016-05-20Merge tag 'gfs2-4.7.fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2 Pull GFS2 updates from Bob Peterson: "We've got nine patches this time: - Abhi Das has two patches that fix a GFS2 splice issue (and an adjustment). - Ben Marzinski has a patch which allows the proper unmount of a GFS2 file system after hitting a withdraw error. - I have a patch to fix a problem where GFS2 would dereference an error value, plus three cosmetic / refactoring patches. - Daniel DeFreez has a patch to fix two glock reference count problems, where GFS2 was not properly "uninitializing" its glock holder on error paths. - Denys Vlasenko has a patch to change a function to not be inlined, thus reducing the memory footprint of the GFS2 module" * tag 'gfs2-4.7.fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2: GFS2: Refactor gfs2_remove_from_journal GFS2: Remove allocation parms from gfs2_rbm_find gfs2: use inode_lock/unlock instead of accessing i_mutex directly GFS2: Add calls to gfs2_holder_uninit in two error handlers GFS2: Don't dereference inode in gfs2_inode_lookup until it's valid GFS2: fs/gfs2/glock.c: Deinline do_error, save 1856 bytes gfs2: Use gfs2 wrapper to sync inode before calling generic_file_splice_read() GFS2: Get rid of dead code in inode_go_demote_ok GFS2: ignore unlock failures after withdraw
2016-05-06GFS2: Refactor gfs2_remove_from_journalBob Peterson
This patch makes two simple changes to function gfs2_remove_from_journal. First, it removes the parameter that specifies the transaction. Since it's always passed in as current->journal_info, we might as well set that in the function rather than passing it in. Second, it changes the meta parameter to use an enum to make the code more clear. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Acked-by: Steven Whitehouse <swhiteho@redhat.com>
2016-05-01direct-io: eliminate the offset argument to ->direct_IOChristoph Hellwig
Including blkdev_direct_IO and dax_do_io. It has to be ki_pos to actually work, so eliminate the superflous argument. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-04-19GFS2: Add calls to gfs2_holder_uninit in two error handlersDaniel DeFreez
This patch fixes two locations that do not call gfs2_holder_uninit if gfs2_glock_nq returns an error. Signed-off-by: Daniel DeFreez <dcdefreez@ucdavis.edu> Signed-off-by: Bob Peterson <rpeterso@redhat.com>
2016-04-04mm, fs: get rid of PAGE_CACHE_* and page_cache_{get,release} macrosKirill A. Shutemov
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time ago with promise that one day it will be possible to implement page cache with bigger chunks than PAGE_SIZE. This promise never materialized. And unlikely will. We have many places where PAGE_CACHE_SIZE assumed to be equal to PAGE_SIZE. And it's constant source of confusion on whether PAGE_CACHE_* or PAGE_* constant should be used in a particular case, especially on the border between fs and mm. Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much breakage to be doable. Let's stop pretending that pages in page cache are special. They are not. The changes are pretty straight-forward: - <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN}; - page_cache_get() -> get_page(); - page_cache_release() -> put_page(); This patch contains automated changes generated with coccinelle using script below. For some reason, coccinelle doesn't patch header files. I've called spatch for them manually. The only adjustment after coccinelle is revert of changes to PAGE_CAHCE_ALIGN definition: we are going to drop it later. There are few places in the code where coccinelle didn't reach. I'll fix them manually in a separate patch. Comments and documentation also will be addressed with the separate patch. virtual patch @@ expression E; @@ - E << (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ expression E; @@ - E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ @@ - PAGE_CACHE_SHIFT + PAGE_SHIFT @@ @@ - PAGE_CACHE_SIZE + PAGE_SIZE @@ @@ - PAGE_CACHE_MASK + PAGE_MASK @@ expression E; @@ - PAGE_CACHE_ALIGN(E) + PAGE_ALIGN(E) @@ expression E; @@ - page_cache_get(E) + get_page(E) @@ expression E; @@ - page_cache_release(E) + put_page(E) Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-15GFS2: Fix direct IO write rounding errorBob Peterson
The fsx test in xfstests was failing because it was using direct IO writes which were using a bad calculation. It was using loff_t lstart = offset & (PAGE_CACHE_SIZE - 1); when it should be loff_t lstart = offset & ~(PAGE_CACHE_SIZE - 1); Thus, the write at offset 0x67e00 was calculating lstart to be 0xe00, the address of our corruption. Instead, it should have been 0x67000. This patch fixes the calculation. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Acked-by: Steven Whitehouse <swhiteho@redhat.com>
2015-11-24GFS2: Extract quota data from reservations structure (revert 5407e24)Bob Peterson
This patch basically reverts the majority of patch 5407e24. That patch eliminated the gfs2_qadata structure in favor of just using the reservations structure. The problem with doing that is that it increases the size of the reservations structure. That is not an issue until it comes time to fold the reservations structure into the inode in memory so we know it's always there. By separating out the quota structure again, we aren't punishing the non-quota users by making all the inodes bigger, requiring more slab space. This patch creates a new slab area to allocate the quota stuff so it's managed a little more sanely. Signed-off-by: Bob Peterson <rpeterso@redhat.com>
2015-06-27Merge tag 'gfs2-merge-window' of ↵Linus Torvalds
git://git.kernel.org:/pub/scm/linux/kernel/git/gfs2/linux-gfs2 Pull GFS2 updates from Bob Peterson: "Here are the patches we've accumulated for GFS2 for the current upstream merge window. We have a good mixture this time. Here are some of the features: - Fix a problem with RO mounts writing to the journal. - Further improvements to quotas on GFS2. - Added support for rename2 and RENAME_EXCHANGE on GFS2. - Increase performance by making glock lru_list less of a bottleneck. - Increase performance by avoiding unnecessary buffer_head releases. - Increase performance by using average glock round trip time from all CPUs. - Fixes for some compiler warnings and minor white space issues. - Other misc bug fixes" * tag 'gfs2-merge-window' of git://git.kernel.org:/pub/scm/linux/kernel/git/gfs2/linux-gfs2: GFS2: Don't brelse rgrp buffer_heads every allocation GFS2: Don't add all glocks to the lru gfs2: Don't support fallocate on jdata files gfs2: s64 cast for negative quota value gfs2: limit quota log messages gfs2: fix quota updates on block boundaries gfs2: fix shadow warning in gfs2_rbm_find() gfs2: kerneldoc warning fixes gfs2: convert simple_str to kstr GFS2: make sure S_NOSEC flag isn't overwritten GFS2: add support for rename2 and RENAME_EXCHANGE gfs2: handle NULL rgd in set_rgrp_preferences GFS2: inode.c: indent with TABs, not spaces GFS2: mark the journal idle to fix ro mounts GFS2: Average in only non-zero round-trip times for congestion stats GFS2: Use average srttb value in congestion calculations
2015-05-05gfs2: kerneldoc warning fixesFabian Frederick
Fixes the following kernel-doc warnings: Warning(fs/gfs2/aops.c:180): No description found for parameter 'wbc' Warning(fs/gfs2/aops.c:236): No description found for parameter 'end' Warning(fs/gfs2/aops.c:236): No description found for parameter 'done_index' Warning(fs/gfs2/aops.c:236): Excess function parameter 'writepage' description in 'gfs2_write_jdata_pagevec' Warning(fs/gfs2/aops.c:346): Excess function parameter 'writepage' description in 'gfs2_write_cache_jdata' Warning(fs/gfs2/aops.c:346): Excess function parameter 'data' description in 'gfs2_write_cache_jdata' Warning(fs/gfs2/aops.c:605): No description found for parameter 'file' Warning(fs/gfs2/aops.c:605): No description found for parameter 'mapping' Warning(fs/gfs2/aops.c:605): No description found for parameter 'pages' Warning(fs/gfs2/aops.c:605): No description found for parameter 'nr_pages' Warning(fs/gfs2/aops.c:870): No description found for parameter 'copied' Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Bob Peterson <rpeterso@redhat.com>
2015-04-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull third hunk of vfs changes from Al Viro: "This contains the ->direct_IO() changes from Omar + saner generic_write_checks() + dealing with fcntl()/{read,write}() races (mirroring O_APPEND/O_DIRECT into iocb->ki_flags and instead of repeatedly looking at ->f_flags, which can be changed by fcntl(2), check ->ki_flags - which cannot) + infrastructure bits for dhowells' d_inode annotations + Christophs switch of /dev/loop to vfs_iter_write()" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (30 commits) block: loop: switch to VFS ITER_BVEC configfs: Fix inconsistent use of file_inode() vs file->f_path.dentry->d_inode VFS: Make pathwalk use d_is_reg() rather than S_ISREG() VFS: Fix up debugfs to use d_is_dir() in place of S_ISDIR() VFS: Combine inode checks with d_is_negative() and d_is_positive() in pathwalk NFS: Don't use d_inode as a variable name VFS: Impose ordering on accesses of d_inode and d_flags VFS: Add owner-filesystem positive/negative dentry checks nfs: generic_write_checks() shouldn't be done on swapout... ocfs2: use __generic_file_write_iter() mirror O_APPEND and O_DIRECT into iocb->ki_flags switch generic_write_checks() to iocb and iter ocfs2: move generic_write_checks() before the alignment checks ocfs2_file_write_iter: stop messing with ppos udf_file_write_iter: reorder and simplify fuse: ->direct_IO() doesn't need generic_write_checks() ext4_file_write_iter: move generic_write_checks() up xfs_file_aio_write_checks: switch to iocb/iov_iter generic_write_checks(): drop isblk argument blkdev_write_iter: expand generic_file_checks() call in there ...
2015-04-14Merge tag 'gfs2-merge-window' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2 Pull GFS2 updates from Bob Peterson: "Here is a list of patches we've accumulated for GFS2 for the current upstream merge window. Most of the patches fix GFS2 quotas, which were not properly enforced. There's another that adds me as a GFS2 co-maintainer, and a couple patches that fix a kernel panic doing splice_write on GFS2 as well as a few correctness patches" * tag 'gfs2-merge-window' of git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2: gfs2: fix quota refresh race in do_glock() gfs2: incorrect check for debugfs returns gfs2: allow fallocate to max out quotas/fs efficiently gfs2: allow quota_check and inplace_reserve to return available blocks gfs2: perform quota checks against allocation parameters GFS2: Move gfs2_file_splice_write outside of #ifdef GFS2: Allocate reservation during splice_write GFS2: gfs2_set_acl(): Cache "no acl" as well Add myself (Bob Peterson) as a maintainer of GFS2
2015-04-11direct_IO: remove rw from a_ops->direct_IO()Omar Sandoval
Now that no one is using rw, remove it completely. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11direct_IO: use iov_iter_rw() instead of rw everywhereOmar Sandoval
The rw parameter to direct_IO is redundant with iov_iter->type, and treated slightly differently just about everywhere it's used: some users do rw & WRITE, and others do rw == WRITE where they should be doing a bitwise check. Simplify this with the new iov_iter_rw() helper, which always returns either READ or WRITE. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11Remove rw from {,__,do_}blockdev_direct_IO()Omar Sandoval
Most filesystems call through to these at some point, so we'll start here. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-03-25fs: move struct kiocb to fs.hChristoph Hellwig
struct kiocb now is a generic I/O container, so move it to fs.h. Also do a #include diet for aio.h while we're at it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-03-18gfs2: perform quota checks against allocation parametersAbhi Das
Use struct gfs2_alloc_parms as an argument to gfs2_quota_check() and gfs2_quota_lock_check() to check for quota violations while accounting for the new blocks requested by the current operation in ap->target. Previously, the number of new blocks requested during an operation were not accounted for during quota_check and would allow these operations to exceed quota. This was not very apparent since most operations allocated only 1 block at a time and quotas would get violated in the next operation. i.e. quota excess would only be by 1 block or so. With fallocate, (where we allocate a bunch of blocks at once) the quota excess is non-trivial and is addressed by this patch. Signed-off-by: Abhi Das <adas@redhat.com> Signed-off-by: Bob Peterson <rpeterso@redhat.com> Acked-by: Steven Whitehouse <swhiteho@redhat.com>
2015-01-20fs: export inode_to_bdi and use it in favor of mapping->backing_dev_infoChristoph Hellwig
Now that we got rid of the bdi abuse on character devices we can always use sb->s_bdi to get at the backing_dev_info for a file, except for the block device special case. Export inode_to_bdi and replace uses of mapping->backing_dev_info with it to prepare for the removal of mapping->backing_dev_info. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Jens Axboe <axboe@fb.com>
2014-06-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "This the bunch that sat in -next + lock_parent() fix. This is the minimal set; there's more pending stuff. In particular, I really hope to get acct.c fixes merged this cycle - we need that to deal sanely with delayed-mntput stuff. In the next pile, hopefully - that series is fairly short and localized (kernel/acct.c, fs/super.c and fs/namespace.c). In this pile: more iov_iter work. Most of prereqs for ->splice_write with sane locking order are there and Kent's dio rewrite would also fit nicely on top of this pile" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (70 commits) lock_parent: don't step on stale ->d_parent of all-but-freed one kill generic_file_splice_write() ceph: switch to iter_file_splice_write() shmem: switch to iter_file_splice_write() nfs: switch to iter_splice_write_file() fs/splice.c: remove unneeded exports ocfs2: switch to iter_file_splice_write() ->splice_write() via ->write_iter() bio_vec-backed iov_iter optimize copy_page_{to,from}_iter() bury generic_file_aio_{read,write} lustre: get rid of messing with iovecs ceph: switch to ->write_iter() ceph_sync_direct_write: stop poking into iov_iter guts ceph_sync_read: stop poking into iov_iter guts new helper: copy_page_from_iter() fuse: switch to ->write_iter() btrfs: switch to ->write_iter() ocfs2: switch to ->write_iter() xfs: switch to ->write_iter() ...
2014-06-04mm: non-atomically mark page accessed during page cache allocation where ↵Mel Gorman
possible aops->write_begin may allocate a new page and make it visible only to have mark_page_accessed called almost immediately after. Once the page is visible the atomic operations are necessary which is noticable overhead when writing to an in-memory filesystem like tmpfs but should also be noticable with fast storage. The objective of the patch is to initialse the accessed information with non-atomic operations before the page is visible. The bulk of filesystems directly or indirectly use grab_cache_page_write_begin or find_or_create_page for the initial allocation of a page cache page. This patch adds an init_page_accessed() helper which behaves like the first call to mark_page_accessed() but may called before the page is visible and can be done non-atomically. The primary APIs of concern in this care are the following and are used by most filesystems. find_get_page find_lock_page find_or_create_page grab_cache_page_nowait grab_cache_page_write_begin All of them are very similar in detail to the patch creates a core helper pagecache_get_page() which takes a flags parameter that affects its behavior such as whether the page should be marked accessed or not. Then old API is preserved but is basically a thin wrapper around this core function. Each of the filesystems are then updated to avoid calling mark_page_accessed when it is known that the VM interfaces have already done the job. There is a slight snag in that the timing of the mark_page_accessed() has now changed so in rare cases it's possible a page gets to the end of the LRU as PageReferenced where as previously it might have been repromoted. This is expected to be rare but it's worth the filesystem people thinking about it in case they see a problem with the timing change. It is also the case that some filesystems may be marking pages accessed that previously did not but it makes sense that filesystems have consistent behaviour in this regard. The test case used to evaulate this is a simple dd of a large file done multiple times with the file deleted on each iterations. The size of the file is 1/10th physical memory to avoid dirty page balancing. In the async case it will be possible that the workload completes without even hitting the disk and will have variable results but highlight the impact of mark_page_accessed for async IO. The sync results are expected to be more stable. The exception is tmpfs where the normal case is for the "IO" to not hit the disk. The test machine was single socket and UMA to avoid any scheduling or NUMA artifacts. Throughput and wall times are presented for sync IO, only wall times are shown for async as the granularity reported by dd and the variability is unsuitable for comparison. As async results were variable do to writback timings, I'm only reporting the maximum figures. The sync results were stable enough to make the mean and stddev uninteresting. The performance results are reported based on a run with no profiling. Profile data is based on a separate run with oprofile running. async dd 3.15.0-rc3 3.15.0-rc3 vanilla accessed-v2 ext3 Max elapsed 13.9900 ( 0.00%) 11.5900 ( 17.16%) tmpfs Max elapsed 0.5100 ( 0.00%) 0.4900 ( 3.92%) btrfs Max elapsed 12.8100 ( 0.00%) 12.7800 ( 0.23%) ext4 Max elapsed 18.6000 ( 0.00%) 13.3400 ( 28.28%) xfs Max elapsed 12.5600 ( 0.00%) 2.0900 ( 83.36%) The XFS figure is a bit strange as it managed to avoid a worst case by sheer luck but the average figures looked reasonable. samples percentage ext3 86107 0.9783 vmlinux-3.15.0-rc4-vanilla mark_page_accessed ext3 23833 0.2710 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed ext3 5036 0.0573 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed ext4 64566 0.8961 vmlinux-3.15.0-rc4-vanilla mark_page_accessed ext4 5322 0.0713 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed ext4 2869 0.0384 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed xfs 62126 1.7675 vmlinux-3.15.0-rc4-vanilla mark_page_accessed xfs 1904 0.0554 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed xfs 103 0.0030 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed btrfs 10655 0.1338 vmlinux-3.15.0-rc4-vanilla mark_page_accessed btrfs 2020 0.0273 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed btrfs 587 0.0079 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed tmpfs 59562 3.2628 vmlinux-3.15.0-rc4-vanilla mark_page_accessed tmpfs 1210 0.0696 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed tmpfs 94 0.0054 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed [akpm@linux-foundation.org: don't run init_page_accessed() against an uninitialised pointer] Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Vlastimil Babka <vbabka@suse.cz> Cc: Jan Kara <jack@suse.cz> Cc: Michal Hocko <mhocko@suse.cz> Cc: Hugh Dickins <hughd@google.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Tested-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-05-14GFS2: remove transaction glockBenjamin Marzinski
GFS2 has a transaction glock, which must be grabbed for every transaction, whose purpose is to deal with freezing the filesystem. Aside from this involving a large amount of locking, it is very easy to make the current fsfreeze code hang on unfreezing. This patch rewrites how gfs2 handles freezing the filesystem. The transaction glock is removed. In it's place is a freeze glock, which is cached (but not held) in a shared state by every node in the cluster when the filesystem is mounted. This lock only needs to be grabbed on freezing, and actions which need to be safe from freezing, like recovery. When a node wants to freeze the filesystem, it grabs this glock exclusively. When the freeze glock state changes on the nodes (either from shared to unlocked, or shared to exclusive), the filesystem does a special log flush. gfs2_log_flush() does all the work for flushing out the and shutting down the incore log, and then it tries to grab the freeze glock in a shared state again. Since the filesystem is stuck in gfs2_log_flush, no new transaction can start, and nothing can be written to disk. Unfreezing the filesytem simply involes dropping the freeze glock, allowing gfs2_log_flush() to grab and then release the shared lock, so it is cached for next time. However, in order for the unfreezing ioctl to occur, gfs2 needs to get a shared lock on the filesystem root directory inode to check permissions. If that glock has already been grabbed exclusively, fsfreeze will be unable to get the shared lock and unfreeze the filesystem. In order to allow the unfreeze, this patch makes gfs2 grab a shared lock on the filesystem root directory during the freeze, and hold it until it unfreezes the filesystem. The functions which need to grab a shared lock in order to allow the unfreeze ioctl to be issued now use the lock grabbed by the freeze code instead. The freeze and unfreeze code take care to make sure that this shared lock will not be dropped while another process is using it. Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2014-05-06switch {__,}blockdev_direct_IO() to iov_iterAl Viro
2014-05-06get rid of pointless iov_length() in ->direct_IO()Al Viro
all callers have iov_length(iter->iov, iter->nr_segs) == iov_iter_count(iter) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-05-06pass iov_iter to ->direct_IO()Al Viro
unmodified, for now Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-02-06GFS2: journal data writepages updateSteven Whitehouse
GFS2 has carried what is more or less a copy of the write_cache_pages() for some time. It seems that this copy has slipped behind the core code over time. This patch brings it back uptodate, and in addition adds the tracepoint which would otherwise be missing. We could go further, and eliminate some or all of the code duplication here. The issue is that if we do that, then the function we need to split out from the existing write_cache_pages(), which will look a lot like gfs2_jdata_write_pagevec(), would land up putting quite a lot of extra variables on the stack. I know that has been a problem in the past in the writeback code path, which is why I've hesitated to do it here. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2014-01-14GFS2: No need to invalidate pages for a dio readSteven Whitehouse
We recently fixed the writeback of pages prior to performing direct i/o, however the initial fix was perhaps a bit heavy handed. There is no need to invalidate pages if the direct i/o is only a read, since they will be identical to what has been flushed to disk anyway. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2014-01-03GFS2: Clean up releasepageSteven Whitehouse
For historical reasons, we drop and retake the log lock in ->releasepage() however, since there is no reason why we cannot hold the log lock over the whole function, this allows some simplification. In particular, pinning a buffer is only ever done under the log lock, so it is possible here to remove the test for pinned buffers in the second loop, since it is impossible for that to happen (it is also tested in the first loop). As a result, two tests made later in the second loop become constants and can also be reduced to the only possible branch. So the net result is to remove various bits of unreachable code and make this more readable. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-12-20GFS2: Fix incorrect invalidation for DIO/buffered I/OSteven Whitehouse
In patch 209806aba9d540dde3db0a5ce72307f85f33468f we allowed local deferred locks to be granted against a cached exclusive lock. That opened up a corner case which this patch now fixes. The solution to the problem is to check whether we have cached pages each time we do direct I/O and if so to unmap, flush and invalidate those pages. Since the glock state machine normally does that for us, mostly the code will be a no-op. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-10-02GFS2: Add allocation parameters structureSteven Whitehouse
This patch adds a structure to contain allocation parameters with the intention of future expansion of this structure. The idea is that we should be able to add more information about the allocation in the future in order to allow the allocator to make a better job of placing the requests on-disk. There is no functional difference from applying this patch. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-09-05GFS2: dirty inode correctly in gfs2_write_endBenjamin Marzinski
GFS2 was only setting I_DIRTY_DATASYNC on files that it wrote to, when it actually increased the file size. If gfs2_fsync was called without I_DIRTY_DATASYNC set, it didn't flush the incore data to the log before returning, so any metadata or journaled data changes were not getting fsynced. This meant that writes to the middle of files were not always getting fsynced properly. This patch makes gfs2 set I_DIRTY_DATASYNC whenever metadata has been updated during a write. It also make gfs2_sync flush the incore log if I_DIRTY_PAGES is set, and the file is using data journalling. This will make sure that all incore logged data gets written to disk before returning from a fsync. Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-08-27GFS2: Merge ordered and writeback writepageSteven Whitehouse
The writepages function was recently merged between writeback and ordered mode. This completes the change by doing the same with writepage. The remaining differences in writepage were left over from some earlier time and not actually doing anything useful. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-05-21gfs2: use ->invalidatepage() length argumentLukas Czerner
->invalidatepage() aop now accepts range to invalidate so we can make use of it in gfs2_invalidatepage(). Signed-off-by: Lukas Czerner <lczerner@redhat.com> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Cc: cluster-devel@redhat.com
2013-05-21mm: change invalidatepage prototype to accept lengthLukas Czerner
Currently there is no way to truncate partial page where the end truncate point is not at the end of the page. This is because it was not needed and the functionality was enough for file system truncate operation to work properly. However more file systems now support punch hole feature and it can benefit from mm supporting truncating page just up to the certain point. Specifically, with this functionality truncate_inode_pages_range() can be changed so it supports truncating partial page at the end of the range (currently it will BUG_ON() if 'end' is not at the end of the page). This commit changes the invalidatepage() address space operation prototype to accept range to be invalidated and update all the instances for it. We also change the block_invalidatepage() in the same way and actually make a use of the new length argument implementing range invalidation. Actual file system implementations will follow except the file systems where the changes are really simple and should not change the behaviour in any way .Implementation for truncate_page_range() which will be able to accept page unaligned ranges will follow as well. Signed-off-by: Lukas Czerner <lczerner@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Hugh Dickins <hughd@google.com>
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-08GFS2: replace gfs2_ail structure with gfs2_transBenjamin Marzinski
In order to allow transactions and log flushes to happen at the same time, gfs2 needs to move the transaction accounting and active items list code into the gfs2_trans structure. As a first step toward this, this patch removes the gfs2_ail structure, and handles the active items list in the gfs_trans structure. This keeps gfs2 from allocating an ail structure on log flushes, and gives us a struture that can later be used to store the transaction accounting outside of the gfs2 superblock structure. With this patch, at the end of a transaction, gfs2 will add the gfs2_trans structure to the superblock if there is not one already. This structure now has the active items fields that were previously in gfs2_ail. This is not necessary in the case where the transaction was simply used to add revokes, since these are never written outside of the journal, and thus, don't need an active items list. Also, in order to make sure that the transaction structure is not removed while it's still in use by gfs2_trans_end, unlocking the sd_log_flush_lock has to happen slightly later in ending the transaction. Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-01-29GFS2: Use ->writepages for ordered writesSteven Whitehouse
Instead of using a list of buffers to write ahead of the journal flush, this now uses a list of inodes and calls ->writepages via filemap_fdatawrite() in order to achieve the same thing. For most use cases this results in a shorter ordered write list, as well as much larger i/os being issued. The ordered write list is sorted by inode number before writing in order to retain the disk block ordering between inodes as per the previous code. The previous ordered write code used to conflict in its assumptions about how to write out the disk blocks with mpage_writepages() so that with this updated version we can also use mpage_writepages() for GFS2's ordered write, writepages implementation. So we will also send larger i/os from writeback too. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2013-01-29GFS2: Split gfs2_trans_add_bh() into twoSteven Whitehouse
There is little common content in gfs2_trans_add_bh() between the data and meta classes by the time that the functions which it calls are taken into account. The intent here is to split this into two separate functions. Stage one is to introduce gfs2_trans_add_data() and gfs2_trans_add_meta() and update the callers accordingly. Later patches will then pull in the content of gfs2_trans_add_bh() and its dependent functions in order to clean up the code in this area. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-11-07GFS2: Add Orlov allocatorSteven Whitehouse
Just like ext3, this works on the root directory and any directory with the +T flag set. Also, just like ext3, any subdirectory created in one of the just mentioned cases will be allocated to a random resource group (GFS2 equivalent of a block group). If you are creating a set of directories, each of which will contain a job running on a different node, then by setting +T on the parent directory before creating the subdirectories, each will land up in a different resource group, and thus resource group contention between nodes will be kept to a minimum. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-09-24GFS2: change function gfs2_direct_IO to use a normal gfs2_glock_dqBob Peterson
This patch changes function gfs2_direct_IO so that it uses a normal call to gfs2_glock_dq rather than a call to a multiple-dq of one item. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-09-24GFS2: Remove rs_requested field from reservationsSteven Whitehouse
The rs_requested field is left over from the original allocation code, however this should have been a parameter passed to the various functions from gfs2_inplace_reserve() and not a member of the reservation structure as the value is not required after the initial allocation. This also helps simplify the code since we no longer need to set the rs_requested to zero. Also the gfs2_inplace_release() function can also be simplified since the reservation structure will always be defined when it is called, and the only remaining task is to unlock the rgrp if required. It can also now be called unconditionally too, resulting in a further simplification. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-06-06GFS2: Fold quota data into the reservations structBob Peterson
This patch moves the ancillary quota data structures into the block reservations structure. This saves GFS2 some time and effort in allocating and deallocating the qadata structure. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-06-06GFS2: Extend the life of the reservationsBob Peterson
This patch lengthens the lifespan of the reservations structure for inodes. Before, they were allocated and deallocated for every write operation. With this patch, they are allocated when the first write occurs, and deallocated when the last process closes the file. It's more efficient to do it this way because it saves GFS2 a lot of unnecessary allocates and frees. It also gives us more flexibility for the future: (1) we can now fold the qadata structure back into the structure and save those alloc/frees, (2) we can use this for multi-block reservations. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-05-02GFS2: eliminate log elements and simplifyBob Peterson
This patch eliminates the gfs2_log_element data structure and rolls its two components into the gfs2_bufdata. This makes the code easier to understand and makes it easier to migrate to a rbtree to keep the list sorted. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-04-24GFS2: Remove unused argument from gfs2_internal_readAndrew Price
gfs2_internal_read accepts an unused ra_state argument, left over from when we did readahead on the rindex. Since there are currently no plans to add back this readahead, this patch removes the ra_state parameter and updates the functions which call gfs2_internal_read accordingly. Signed-off-by: Andrew Price <anprice@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-04-24GFS2: Remove bd_list_trSteven Whitehouse
This is another clean up in the logging code. This per-transaction list was largely unused. Its main function was to ensure that the number of buffers in a transaction was correct, however that counter was only used to check the number of buffers in the bd_list_tr, plus an assert at the end of each transaction. With the assert now changed to use the calculated buffer counts, we can remove both bd_list_tr and its associated counter. This should make the code easier to understand as well as shrinking a couple of structures. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-04-24GFS2: make function gfs2_page_add_databufs staticBob Peterson
This patch makes function gfs2_page_add_databufs static. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-04-10GFS2: Allow caching of rindex glockBob Peterson
This patch allows caching of the rindex glock. We were previously setting the GL_NOCACHE bit when the glock was released. That forced the rindex inode to be invalidated, which caused us to re-read rindex at the next access. However, it caused the glock to be unnecessarily bounced around the cluster. This patch allows the glock to remain cached, but it still causes the rindex to be re-read once it has been written to by gfs2_grow. Ben and I have tested single-node gfs2_grow cases and I've tested clustered gfs2_grow cases on my four-node cluster. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-03-20gfs2: remove the second argument of k[un]map_atomic()Cong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
