Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
CURRENT_TIME macro is not appropriate for filesystems as it
doesn't use the right granularity for filesystem timestamps.
Use current_time() instead.
CURRENT_TIME is also not y2038 safe.
This is also in preparation for the patch that transitions
vfs timestamps to use 64 bit time and hence make them
y2038 safe. As part of the effort current_time() will be
extended to do range checks. Hence, it is necessary for all
file system timestamps to use current_time(). Also,
current_time() will be transitioned along with vfs to be
y2038 safe.
Note that whenever a single call to current_time() is used
to change timestamps in different inodes, it is because they
share the same time granularity.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Felipe Balbi <balbi@kernel.org>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Acked-by: David Sterba <dsterba@suse.com>
Replace 1 << value shift by more explicit BIT() macro
Also fixes two bare unsigned definitions:
WARNING: Prefer 'unsigned int' to bare use of 'unsigned'
+ unsigned hsize = BIT(ip->i_depth);
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
Pull block driver updates from Jens Axboe:
"This branch also contains core changes. I've come to the conclusion
that from 4.9 and forward, I'll be doing just a single branch. We
often have dependencies between core and drivers, and it's hard to
always split them up appropriately without pulling core into drivers
when that happens.
That said, this contains:
- separate secure erase type for the core block layer, from
Christoph.
- set of discard fixes, from Christoph.
- bio shrinking fixes from Christoph, as a followup up to the
op/flags change in the core branch.
- map and append request fixes from Christoph.
- NVMeF (NVMe over Fabrics) code from Christoph. This is pretty
exciting!
- nvme-loop fixes from Arnd.
- removal of ->driverfs_dev from Dan, after providing a
device_add_disk() helper.
- bcache fixes from Bhaktipriya and Yijing.
- cdrom subchannel read fix from Vchannaiah.
- set of lightnvm updates from Wenwei, Matias, Johannes, and Javier.
- set of drbd updates and fixes from Fabian, Lars, and Philipp.
- mg_disk error path fix from Bart.
- user notification for failed device add for loop, from Minfei.
- NVMe in general:
+ NVMe delay quirk from Guilherme.
+ SR-IOV support and command retry limits from Keith.
+ fix for memory-less NUMA node from Masayoshi.
+ use UINT_MAX for discard sectors, from Minfei.
+ cancel IO fixes from Ming.
+ don't allocate unused major, from Neil.
+ error code fixup from Dan.
+ use constants for PSDT/FUSE from James.
+ variable init fix from Jay.
+ fabrics fixes from Ming, Sagi, and Wei.
+ various fixes"
* 'for-4.8/drivers' of git://git.kernel.dk/linux-block: (115 commits)
nvme/pci: Provide SR-IOV support
nvme: initialize variable before logical OR'ing it
block: unexport various bio mapping helpers
scsi/osd: open code blk_make_request
target: stop using blk_make_request
block: simplify and export blk_rq_append_bio
block: ensure bios return from blk_get_request are properly initialized
virtio_blk: use blk_rq_map_kern
memstick: don't allow REQ_TYPE_BLOCK_PC requests
block: shrink bio size again
block: simplify and cleanup bvec pool handling
block: get rid of bio_rw and READA
block: don't ignore -EOPNOTSUPP blkdev_issue_write_same
block: introduce BLKDEV_DISCARD_ZERO to fix zeroout
NVMe: don't allocate unused nvme_major
nvme: avoid crashes when node 0 is memoryless node.
nvme: Limit command retries
loop: Make user notify for adding loop device failed
nvme-loop: fix nvme-loop Kconfig dependencies
nvmet: fix return value check in nvmet_subsys_alloc()
Pull core block updates from Jens Axboe:
- the big change is the cleanup from Mike Christie, cleaning up our
uses of command types and modified flags. This is what will throw
some merge conflicts
- regression fix for the above for btrfs, from Vincent
- following up to the above, better packing of struct request from
Christoph
- a 2038 fix for blktrace from Arnd
- a few trivial/spelling fixes from Bart Van Assche
- a front merge check fix from Damien, which could cause issues on
SMR drives
- Atari partition fix from Gabriel
- convert cfq to highres timers, since jiffies isn't granular enough
for some devices these days. From Jan and Jeff
- CFQ priority boost fix idle classes, from me
- cleanup series from Ming, improving our bio/bvec iteration
- a direct issue fix for blk-mq from Omar
- fix for plug merging not involving the IO scheduler, like we do for
other types of merges. From Tahsin
- expose DAX type internally and through sysfs. From Toshi and Yigal
* 'for-4.8/core' of git://git.kernel.dk/linux-block: (76 commits)
block: Fix front merge check
block: do not merge requests without consulting with io scheduler
block: Fix spelling in a source code comment
block: expose QUEUE_FLAG_DAX in sysfs
block: add QUEUE_FLAG_DAX for devices to advertise their DAX support
Btrfs: fix comparison in __btrfs_map_block()
block: atari: Return early for unsupported sector size
Doc: block: Fix a typo in queue-sysfs.txt
cfq-iosched: Charge at least 1 jiffie instead of 1 ns
cfq-iosched: Fix regression in bonnie++ rewrite performance
cfq-iosched: Convert slice_resid from u64 to s64
block: Convert fifo_time from ulong to u64
blktrace: avoid using timespec
block/blk-cgroup.c: Declare local symbols static
block/bio-integrity.c: Add #include "blk.h"
block/partition-generic.c: Remove a set-but-not-used variable
block: bio: kill BIO_MAX_SIZE
cfq-iosched: temporarily boost queue priority for idle classes
block: drbd: avoid to use BIO_MAX_SIZE
block: bio: remove BIO_MAX_SECTORS
git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2
Pull gfs2 updates from Bob Peterson:
"We've got ten patches this time, half of which are related to a
plethora of nasty outcomes when inodes are transitioned from the
unlinked state to the free state. Small file systems are particularly
vulnerable to these problems, and it can manifest as mainly hangs, but
also file system corruption. The patches have been tested for
literally many weeks, with a very gruelling test, so I have a high
level of confidence.
- Andreas Gruenbacher wrote a series of five patches for various
lockups during the transition of inodes from unlinked to free.
The main patch is titled "Fix gfs2_lookup_by_inum lock inversion"
and the other four are support and cleanup patches related to that.
- Ben Marzinski contributed two patches with regard to a recreatable
problem when gfs2 tries to write a page to a file that is being
truncated, resulting in a BUG() in gfs2_remove_from_journal.
Note that Ben had to export vfs function __block_write_full_page to
get this to work properly. It's been posted a long time and he
talked to various VFS people about it, and nobody seemed to mind.
- I contributed 3 patches:
o The first one fixes a memory corruptor: a race in which one
process can overwrite the gl_object pointer set by another
process, causing kernel panic and other symptoms.
o The second patch fixes another race that resulted in a
false-positive BUG_ON. This occurred when resource group
reservations were freed by one process while another process
was trying to grab a new reservation in the same resource
group.
o The third patch fixes a problem with doing journal replay when
the journals are not all the same size"
* tag 'gfs2-4.7.fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2:
GFS2: Fix gfs2_replay_incr_blk for multiple journal sizes
GFS2: Check rs_free with rd_rsspin protection
gfs2: writeout truncated pages
fs: export __block_write_full_page
gfs2: Lock holder cleanup
gfs2: Large-filesystem fix for 32-bit systems
gfs2: Get rid of gfs2_ilookup
gfs2: Fix gfs2_lookup_by_inum lock inversion
gfs2: Initialize iopen glock holder for new inodes
GFS2: don't set rgrp gl_object until it's inserted into rgrp tree
These two are confusing leftover of the old world order, combining
values of the REQ_OP_ and REQ_ namespaces. For callers that don't
special case we mostly just replace bi_rw with bio_data_dir or
op_is_write, except for the few cases where a switch over the REQ_OP_
values makes more sense. Any check for READA is replaced with an
explicit check for REQ_RAHEAD. Also remove the READA alias for
REQ_RAHEAD.
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Reviewed-by: Mike Christie <mchristi@redhat.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
The current gfs2_lookup_by_inum takes the glock of a presumed inode
identified by block number, verifies that the block is indeed an inode,
and then instantiates and reads the new inode via gfs2_inode_lookup.
However, instantiating a new inode may block on freeing a previous
instance of that inode (__wait_on_freeing_inode), and freeing an inode
requires to take the glock already held, leading to lock inversion and
deadlock.
Fix this by first instantiating the new inode, then verifying that the
block is an inode (if required), and then reading in the new inode, all
in gfs2_inode_lookup.
If the block we are looking for is not an inode, we discard the new
inode via iget_failed, which marks inodes as bad and unhashes them.
Other tasks waiting on that inode will get back a bad inode back from
ilookup or iget_locked; in that case, retry the lookup.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
This has submit_bh users pass in the operation and flags separately,
so submit_bh_wbc can setup the bio op and bi_rw flags on the bio that
is submitted.
Signed-off-by: Mike Christie <mchristi@redhat.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
Most users of IS_ERR_VALUE() in the kernel are wrong, as they
pass an 'int' into a function that takes an 'unsigned long'
argument. This happens to work because the type is sign-extended
on 64-bit architectures before it gets converted into an
unsigned type.
However, anything that passes an 'unsigned short' or 'unsigned int'
argument into IS_ERR_VALUE() is guaranteed to be broken, as are
8-bit integers and types that are wider than 'unsigned long'.
Andrzej Hajda has already fixed a lot of the worst abusers that
were causing actual bugs, but it would be nice to prevent any
users that are not passing 'unsigned long' arguments.
This patch changes all users of IS_ERR_VALUE() that I could find
on 32-bit ARM randconfig builds and x86 allmodconfig. For the
moment, this doesn't change the definition of IS_ERR_VALUE()
because there are probably still architecture specific users
elsewhere.
Almost all the warnings I got are for files that are better off
using 'if (err)' or 'if (err < 0)'.
The only legitimate user I could find that we get a warning for
is the (32-bit only) freescale fman driver, so I did not remove
the IS_ERR_VALUE() there but changed the type to 'unsigned long'.
For 9pfs, I just worked around one user whose calling conventions
are so obscure that I did not dare change the behavior.
I was using this definition for testing:
#define IS_ERR_VALUE(x) ((unsigned long*)NULL == (typeof (x)*)NULL && \
unlikely((unsigned long long)(x) >= (unsigned long long)(typeof(x))-MAX_ERRNO))
which ends up making all 16-bit or wider types work correctly with
the most plausible interpretation of what IS_ERR_VALUE() was supposed
to return according to its users, but also causes a compile-time
warning for any users that do not pass an 'unsigned long' argument.
I suggested this approach earlier this year, but back then we ended
up deciding to just fix the users that are obviously broken. After
the initial warning that caused me to get involved in the discussion
(fs/gfs2/dir.c) showed up again in the mainline kernel, Linus
asked me to send the whole thing again.
[ Updated the 9p parts as per Al Viro - Linus ]
Cc: Andrzej Hajda <a.hajda@samsung.com>
Link: https://lkml.org/lkml/2016/1/7/363
Link: https://lkml.org/lkml/2016/5/27/486
Acked-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> # For nvmem part
Now that we're not filtering out I_FREEING inodes from our lookups
anymore, we can eliminate the non_block parameter from the lookup
function.
We get a bogus warning about a potential uninitialized variable
use in gfs2, because the compiler does not figure out that we
never use the leaf number if get_leaf_nr() returns an error:
fs/gfs2/dir.c: In function 'get_first_leaf':
fs/gfs2/dir.c:802:9: warning: 'leaf_no' may be used uninitialized in this function [-Wmaybe-uninitialized]
fs/gfs2/dir.c: In function 'dir_split_leaf':
fs/gfs2/dir.c:1021:8: warning: 'leaf_no' may be used uninitialized in this function [-Wmaybe-uninitialized]
Changing the 'if (!error)' to 'if (!IS_ERR_VALUE(error))' is
sufficient to let gcc understand that this is exactly the same
condition as in IS_ERR() so it can optimize the code path enough
to understand it.
gfs2 currently returns 31 bits of filename hash as a cookie that readdir
uses for an offset into the directory. When there are a large number of
directory entries, the likelihood of a collision goes up way too
quickly. GFS2 will now return cookies that are guaranteed unique for a
while, and then fail back to using 30 bits of filename hash.
Specifically, the directory leaf blocks are divided up into chunks based
on the minimum size of a gfs2 directory entry (48 bytes). Each entry's
cookie is based off the chunk where it starts, in the linked list of
leaf blocks that it hashes to (there are 131072 hash buckets). Directory
entries will have unique names until they take reach chunk 8192.
Assuming the largest filenames possible, and the least efficient spacing
possible, this new method will still be able to return unique names when
the previous method has statistically more than a 99% chance of a
collision. The non-unique names it fails back to are guaranteed to not
collide with the unique names.
unique cookies will be in this format:
- 1 bit "0" to make sure the the returned cookie is positive
- 17 bits for the hash table index
- 1 bit for the mode "0"
- 13 bits for the offset
non-unique cookies will be in this format:
- 1 bit for the mode "1"
- 13 more bits of the name hash
Another benefit of location based cookies, is that once a directory's
exhash table is fully extended (so that multiple hash table indexs do
not use the same leaf blocks), gfs2 can skip sorting the directory
entries until it reaches the non-unique ones, and then it only needs to
sort these. This provides a significant speed up for directory reads of
very large directories.
The only issue is that for these cookies to continue to point to the
correct entry as files are added and removed from the directory, gfs2
must keep the entries at the same offset in the leaf block when they are
split (see my previous patch). This means that until all the nodes in a
cluster are running with code that will split the directory leaf blocks
this way, none of the nodes can use the new cookie code. To deal with
this, gfs2 now has the mount option loccookie, which, if set, will make
it return these new location based cookies. This option must not be set
until all nodes in the cluster are at least running this version of the
kernel code, and you have guaranteed that there are no outstanding
cookies required by other software, such as NFS.
gfs2 uses some of the extra space at the end of the gfs2_dirent
structure to store the calculated readdir cookies. This keeps us from
needing to allocate a seperate array to hold these values. gfs2
recomputes the cookie stored in de_cookie for every readdir call. The
time it takes to do so is small, and if gfs2 expected this value to be
saved on disk, the new code wouldn't work correctly on filesystems
created with an earlier version of gfs2.
One issue with adding de_cookie to the union in the gfs2_dirent
structure is that it caused the union to align itself to a 4 byte
boundary, instead of its previous 2 byte boundary. This changed the
offset of de_rahead. To solve that, I pulled de_rahead out of the union,
since it does not need to be there.
Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com>
Currently, when gfs2 splits a directory leaf block, the dirents that
need to be copied to the new leaf block are packed into the start of it.
This is good for space efficiency. However, if gfs2 were to copy those
dirents into the exact same offset in the new leaf block as they had in
the old block, it would be able to generate a readdir cookie based on
the dirent location, that would be guaranteed to be unique up well past
where the current code is statistically almost guaranteed to have
collisions. So, gfs2 now keeps the dirent's offset in the block the
same when it copies it to the new leaf block.
When gfs2 allocates an inode and its extended attribute block next to
each other at inode create time, the inode's directory entry indicates
that in de_rahead. In that case, we can readahead the extended
attribute block when we read in the inode.
This patch changes function gfs2_dir_hash_inval so it uses the
i_lock spin_lock to protect the in-core hash table, i_hash_cache.
This will prevent double-frees due to a race between gfs2_evict_inode
and inode invalidation.
Convert the following where appropriate:
(1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry).
(2) S_ISREG(dentry->d_inode) to d_is_reg(dentry).
(3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more
complicated than it appears as some calls should be converted to
d_can_lookup() instead. The difference is whether the directory in
question is a real dir with a ->lookup op or whether it's a fake dir with
a ->d_automount op.
In some circumstances, we can subsume checks for dentry->d_inode not being
NULL into this, provided we the code isn't in a filesystem that expects
d_inode to be NULL if the dirent really *is* negative (ie. if we're going to
use d_inode() rather than d_backing_inode() to get the inode pointer).
Note that the dentry type field may be set to something other than
DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS
manages the fall-through from a negative dentry to a lower layer. In such a
case, the dentry type of the negative union dentry is set to the same as the
type of the lower dentry.
However, if you know d_inode is not NULL at the call site, then you can use
the d_is_xxx() functions even in a filesystem.
There is one further complication: a 0,0 chardev dentry may be labelled
DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was
intended for special directory entry types that don't have attached inodes.
The following perl+coccinelle script was used:
use strict;
my @callers;
open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') ||
die "Can't grep for S_ISDIR and co. callers";
@callers = <$fd>;
close($fd);
unless (@callers) {
print "No matches\n";
exit(0);
my @cocci = (
'expression E;',
'- S_ISLNK(E->d_inode->i_mode)',
'+ d_is_symlink(E)',
'expression E;',
'- S_ISDIR(E->d_inode->i_mode)',
'+ d_is_dir(E)',
'expression E;',
'- S_ISREG(E->d_inode->i_mode)',
'+ d_is_reg(E)' );
my $coccifile = "tmp.sp.cocci";
open($fd, ">$coccifile") || die $coccifile;
print($fd "$_\n") || die $coccifile foreach (@cocci);
close($fd);
foreach my $file (@callers) {
chomp $file;
print "Processing ", $file, "\n";
system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 ||
die "spatch failed";
[AV: overlayfs parts skipped]
leaf_dealloc uses vzalloc as a fallback to kzalloc(GFP_NOFS), so
it clearly does not want any shrinker activity within the fs itself.
convert vzalloc into __vmalloc(GFP_NOFS|__GFP_ZERO) to better achieve
this goal.
Signed-off-by: Oleg Drokin <green@linuxhacker.ru>
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
vfree() is allowed under spinlock these days, but it's cheaper when
it doesn't step into deferred case and here it's very easy to avoid.
This patch fixes a regression in the patch "GFS2: Remember directory
insert point", commit 2b47dad866d04f14c328f888ba5406057b8c7d33.
The problem had to do with the rename function: The function found
space for the new dirent, and remembered that location. But then the
old dirent was removed, which often moved the eligible location for
the renamed dirent. Putting the new dirent at the saved location
caused file system corruption.
This patch adds a new "save_loc" variable to struct gfs2_diradd.
If 1, the dirent location is saved. If 0, the dirent location is not
saved and the buffer_head is released as per previous behavior.
Add pr_fmt, remove embedded "GFS2: " prefixes.
This now consistently emits lower case "gfs2: " for each message.
Other miscellanea around these changes:
o Add missing newlines
o Coalesce formats
o Realign arguments
-All printk(KERN_foo converted to pr_foo().
-Messages updated to fit in 80 columns.
-fs_macros converted as well.
-fs_printk removed.
The intent of this new field in the directory entry is to
allow a subsequent lookup to know how many blocks, which
are contiguous with the inode, contain metadata which relates
to the inode. This will then allow the issuing of a single
read to read these blocks, rather than reading the inode
first, and then issuing a second read for the metadata.
This only works under some fairly strict conditions, since
we do not have back pointers from inodes to directory entries
we must ensure that the blocks referenced in this way will
always belong to the inode.
This rules out being able to use this system for indirect
blocks, as these can change as a result of truncate/rewrite.
So the idea here is to restrict this to xattr blocks only
for the time being. For most inodes, that means only a
single block. Also, when using ACLs and/or SELinux or
other LSMs, these will be added at inode creation time
so that they will be contiguous with the inode on disk and
also will almost always be needed when we read the inode in
for permissions checks.
Once an xattr block for an inode is allocated, it will never
change until the inode is deallocated.
This patch adds the new field, a further patch will add the
readahead in due course.
This patch adds four new fields to directory leaf blocks.
The intent is not to use them in the kernel itself, although
perhaps we may be able to use them as hints at some later date,
but instead to provide more information for debug/fsck use.
One new field adds a pointer to the inode to which the leaf
belongs. This can be useful if the pointer to the leaf block
has become corrupt, as it will allow us to know which inode
this block should be associated with. This field is set when
the leaf is created and never changed over its lifetime.
The second field is a "distance from the hash table" field.
The meaning is as follows:
0 = An old leaf in which this value has not been set
1 = This leaf is pointed to directly from the hash table
2+ = This leaf is part of a chain, pointed to by another leaf
block, the value gives the position in the chain.
The third and fourth fields combine to give a time stamp of
the most recent directory insertion or deletion from this
leaf block. The time stamp is not updated when a new leaf
block is chained from the current one. The code is currently
written such that the timestamp on the dir inode will match
that of the leaf block for the most recent insertion/deletion.
For backwards compatibility, any of these new fields which is
zero should be considered to be "unknown".
For most cases, only a single new block is needed when we reach
the point of converting from stuffed to exhash directory. The
exception being when the file name is so long that it will not
fit within the new leaf block.
So this patch adds a simple test for that situation so that we
do not need to request the full reservation size in this case.
Potentially we could calculate more accurately the value to use
in other cases too, but that is much more complicated to do and
it is doubtful that the benefit would outweigh the extra cost
in code complexity.
When we look to see if there is enough space to add a dir
entry without allocation, we have then been repeating the
same search later when we do the actual insertion. This
patch caches the details of the location in the gfs2_diradd
structure, so that we do not have to repeat the search.
This will provide a performance improvement which will be
greater as the size of the directory increases.
The intent is that this structure will hold the information
required when adding entries to a directory (linking). To
start with, it will contain only the number of blocks which
are required to link the new entry into the directory. The
current calculation returns either 0 or the maximim number of
blocks that can ever be requested by such a transaction.
The intent is that in a later patch, we can update the dir
code to calculate this value more accurately. In addition
further patches will also add further fields to the new
structure to increase its utility.
In addition this patch fixes a bug where the link used during
inode creation was adding requesting too many blocks in
some cases. This is harmless unless the fs is close to being
full.
Don't emit OOM warnings when k.alloc calls fail when
there there is a v.alloc immediately afterwards.
Converted a kmalloc/vmalloc with memset to kzalloc/vzalloc.
Acked-by: "Theodore Ts'o" <tytso@mit.edu>
Pull GFS2 updates from Steven Whitehouse:
"There are a few bug fixes for various, mostly very minor corner cases,
plus some interesting new features.
The new features include atomic_open whose main benefit will be the
reduction in locking overhead in case of combined lookup/create and
open operations, sorting the log buffer lists by block number to
improve the efficiency of AIL writeback, and aggressively issuing
revokes in gfs2_log_flush to reduce overhead when dropping glocks."
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-nmw:
GFS2: Reserve journal space for quota change in do_grow
GFS2: Fix fstrim boundary conditions
GFS2: fix warning message
GFS2: aggressively issue revokes in gfs2_log_flush
GFS2: fix regression in dir_double_exhash
GFS2: Add atomic_open support
GFS2: Only do one directory search on create
GFS2: fix error propagation in init_threads()
GFS2: Remove no-op wrapper function
GFS2: Cocci spatch "ptr_ret.spatch"
GFS2: Eliminate gfs2_rg_lops
GFS2: Sort buffer lists by inplace block number
Recent commit e8830d8 introduced a bug in function dir_double_exhash;
it was failing to set h in the fall-back case. This patch corrects it.
Creation of a new inode requires a directory search in order to ensure
that we are not trying to create an inode with the same name as an
existing one. This was hidden away inside the create_ok() function.
In the case that there was an existing inode, and a lookup can be
substituted for a create (which is the case with regular files
when the O_EXCL flag is not in use) then we were doing a second
lookup in order to return the inode.
This patch merges these two lookups into one. This can be done by
passing a flag to gfs2_dir_search() to tell it to just return -EEXIST
in the cases where we don't actually want to look up the inode.
This version has one more correction: the vmalloc calls are replaced
by __vmalloc calls to preserve the GFP_NOFS flag.
When GFS2's directory management code allocates buffers for a
directory hash table, if it can't get the memory it needs, it
currently gives a bad return code. Rather than giving an error,
this patch allows it to use virtual memory rather than kernel
memory for the hash table. This should make it possible for
directories to function properly, even when kernel memory becomes
very fragmented.
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace and namespace infrastructure changes from Eric W Biederman:
"This set of changes starts with a few small enhnacements to the user
namespace. reboot support, allowing more arbitrary mappings, and
support for mounting devpts, ramfs, tmpfs, and mqueuefs as just the
user namespace root.
I do my best to document that if you care about limiting your
unprivileged users that when you have the user namespace support
enabled you will need to enable memory control groups.
There is a minor bug fix to prevent overflowing the stack if someone
creates way too many user namespaces.
The bulk of the changes are a continuation of the kuid/kgid push down
work through the filesystems. These changes make using uids and gids
typesafe which ensures that these filesystems are safe to use when
multiple user namespaces are in use. The filesystems converted for
3.9 are ceph, 9p, afs, ocfs2, gfs2, ncpfs, nfs, nfsd, and cifs. The
changes for these filesystems were a little more involved so I split
the changes into smaller hopefully obviously correct changes.
XFS is the only filesystem that remains. I was hoping I could get
that in this release so that user namespace support would be enabled
with an allyesconfig or an allmodconfig but it looks like the xfs
changes need another couple of days before it they are ready."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (93 commits)
cifs: Enable building with user namespaces enabled.
cifs: Convert struct cifs_ses to use a kuid_t and a kgid_t
cifs: Convert struct cifs_sb_info to use kuids and kgids
cifs: Modify struct smb_vol to use kuids and kgids
cifs: Convert struct cifsFileInfo to use a kuid
cifs: Convert struct cifs_fattr to use kuid and kgids
cifs: Convert struct tcon_link to use a kuid.
cifs: Modify struct cifs_unix_set_info_args to hold a kuid_t and a kgid_t
cifs: Convert from a kuid before printing current_fsuid
cifs: Use kuids and kgids SID to uid/gid mapping
cifs: Pass GLOBAL_ROOT_UID and GLOBAL_ROOT_GID to keyring_alloc
cifs: Use BUILD_BUG_ON to validate uids and gids are the same size
cifs: Override unmappable incoming uids and gids
nfsd: Enable building with user namespaces enabled.
nfsd: Properly compare and initialize kuids and kgids
nfsd: Store ex_anon_uid and ex_anon_gid as kuids and kgids
nfsd: Modify nfsd4_cb_sec to use kuids and kgids
nfsd: Handle kuids and kgids in the nfs4acl to posix_acl conversion
nfsd: Convert nfsxdr to use kuids and kgids
nfsd: Convert nfs3xdr to use kuids and kgids
Split NO_QUOTA_CHANGE into NO_UID_QUTOA_CHANGE and NO_GID_QUTOA_CHANGE
so the constants may be well typed.
Cc: Steven Whitehouse <swhiteho@redhat.com>
There is little common content in gfs2_trans_add_bh() between the data
and meta classes by the time that the functions which it calls are
taken into account. The intent here is to split this into two
separate functions. Stage one is to introduce gfs2_trans_add_data()
and gfs2_trans_add_meta() and update the callers accordingly.
Later patches will then pull in the content of gfs2_trans_add_bh()
and its dependent functions in order to clean up the code in this
area.
This patch changes the gfs2_dir_add function so that it uses
the dirty_inode function (via mark_inode_dirty) rather than manually
updating the dinode.
This patch moves the ancillary quota data structures into the
block reservations structure. This saves GFS2 some time and
effort in allocating and deallocating the qadata structure.
This allows comparing hash and len in one operation on 64-bit
architectures. Right now only __d_lookup_rcu() takes advantage of this,
since that is the case we care most about.
The use of anonymous struct/unions hides the alternate 64-bit approach
from most users, the exception being a few cases where we initialize a
'struct qstr' with a static initializer. This makes the problematic
cases use a new QSTR_INIT() helper function for that (but initializing
just the name pointer with a "{ .name = xyzzy }" initializer remains
valid, as does just copying another qstr structure).
This patch removes the call from gfs2_blk2rgrd to function
gfs2_rindex_update and replaces it with individual calls.
The former way turned out to be too problematic.
This patch separates the code pertaining to allocations into two
parts: quota-related information and block reservations.
This patch also moves all the block reservation structure allocations to
function gfs2_inplace_reserve to simplify the code, and moves
the frees to function gfs2_inplace_release.
This patch is a revision of the one I previously posted.
I tried to integrate all the suggestions Steve gave.
The purpose of the patch is to change function gfs2_alloc_block
(allocate either a dinode block or an extent of data blocks)
to a more generic gfs2_alloc_blocks function that can
allocate both a dinode _and_ an extent of data blocks in the
same call. This will ultimately help us create a multi-block
reservation scheme to reduce file fragmentation.
This patch moves more toward a generic multi-block allocator that
takes a pointer to the number of data blocks to allocate, plus whether
or not to allocate a dinode. In theory, it could be called to allocate
(1) a single dinode block, (2) a group of one or more data blocks, or
(3) a dinode plus several data blocks.
GFS2 functions gfs2_alloc_block and gfs2_alloc_di do basically
the same things, with a few exceptions. This patch combines
the two functions into a slightly more generic gfs2_alloc_block.
Having one centralized block allocation function will reduce
code redundancy and make it easier to implement multi-block
reservations to reduce file fragmentation in the future.
As a result, we don't need to test it each time.
Cc: Bob Peterson <rpeterso@redhat.com>
This patch adds read-ahead capability to GFS2's
directory hash table management. It greatly improves
performance for some directory operations. For example:
In one of my file systems that has 1000 directories, each
of which has 1000 files, time to execute a recursive
ls (time ls -fR /mnt/gfs2 > /dev/null) was reduced
from 2m2.814s on a stock kernel to 0m45.938s.
Each block which is deallocated, requires a call to gfs2_rlist_add()
and each of those calls was calling gfs2_blk2rgrpd() in order to
figure out which rgrp the block belonged in. This can be speeded up
by making use of the rgrp cached in the inode. We also reset this
cached rgrp in case the block has changed rgrp. This should provide
a big reduction in gfs2_blk2rgrpd() calls during deallocation.
Since we have ruled out supporting online filesystem shrink,
it is possible to make the resource group list append only
during the life of a super block. This gives several benefits:
Firstly, we only need to read new rindex elements as they are added
rather than needing to reread the whole rindex file each time one
element is added.
Secondly, the rindex glock can be held for much shorter periods of
time, and is completely removed from the fast path for allocations.
The lock is taken in shared mode only when updating the resource
groups when the first allocation occurs, and after a grow has
taken place.
Thirdly, this results in a reduction in code size, and everything
gets a lot simpler to understand in this area.
The aim of this patch is to use the newly enhanced ->dirty_inode()
super block operation to deal with atime updates, rather than
piggy backing that code into ->write_inode() as is currently
done.
The net result is a simplification of the code in various places
and a reduction of the number of gfs2_dinode_out() calls since
this is now implied by ->dirty_inode().
Some of the mark_inode_dirty() calls have been moved under glocks
in order to take advantage of then being able to avoid locking in
->dirty_inode() when we already have suitable locks.
One consequence is that generic_write_end() now correctly deals
with file size updates, so that we do not need a separate check
for that afterwards. This also, indirectly, means that fdatasync
should work correctly on GFS2 - the current code always syncs the
metadata whether it needs to or not.
Has survived testing with postmark (with and without atime) and
also fsx.
Since there is now only a single caller to gfs2_dir_read_data()
and it has a number of constant arguments, we can factor
those out. Also some tests relating to the inode size were
being done twice.
