path: root/fs/gfs2/glops.c
2011-07-15GFS2: Add S_NOSEC supportSteven Whitehouse
This adds S_NOSEC support to GFS2. We set/reset the flag either when a user calls setattr or when we have just regained the glock from another node. The flag is only set if there are no xattrs on the inode and there is no suid bit set. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Reviewed-by: Andi Kleen <ak@linux.intel.com> Cc: Al Viro <viro@ZenIV.linux.org.uk>
2011-07-15GFS2: Automatically adjust glock min hold timeBob Peterson
This patch is a performance improvement for GFS2 in a clustered environment. It makes the glock hold time self-adjusting. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2011-07-15GFS2: Cache dir hash table in a contiguous bufferSteven Whitehouse
This patch adds a cache for the hash table to the directory code in order to help simplify the way in which the hash table is accessed. This is intended to be a first step towards introducing some performance improvements in the directory code. There are two follow ups that I'm hoping to see fairly shortly. One is to simplify the hash table reading code now that we always read the complete hash table, whether we want one entry or all of them. The other is to introduce readahead on the heads of the hash chains which are referred to from the table. The hash table is a maximum of 128k in size, so it is not worth trying to read it in small chunks. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2011-07-14GFS2: Resolve inode eviction and ail list interaction bugSteven Whitehouse
This patch contains a few misc fixes which resolve a recently reported issue. This patch has been a real team effort and has received a lot of testing. The first issue is that the ail lock needs to be held over a few more operations. The lock thats added into gfs2_releasepage() may possibly be a candidate for replacing with RCU at some future point, but at this stage we've gone for the obvious fix. The second issue is that gfs2_write_inode() can end up calling a glock recursively when called from gfs2_evict_inode() via the syncing code, so it needs a guard added. The third issue is that we either need to not truncate the metadata pages of inodes which have zero link count, but which we cannot deallocate due to them still being in use by other nodes, or we need to ensure that those pages have all made it through the journal and ail lists first. This patch takes the former approach, but the latter has also been tested and there is nothing to choose between them performance-wise. So again, we could revise that decision in the future. Also, the inode eviction process is now better documented. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Tested-by: Bob Peterson <rpeterso@redhat.com> Tested-by: Abhijith Das <adas@redhat.com> Reported-by: Barry J. Marson <bmarson@redhat.com> Reported-by: David Teigland <teigland@redhat.com>
2011-07-12GFS2: force a log flush when invalidating the rindex glockBenjamin Marzinski
Right now, there is nothing that forces the log to get flushed when a node drops its rindex glock so that another node can grow the filesystem. If the log doesn't get flushed, GFS2 can corrupt the sd_log_le_rg list in the following way. A node puts an rgd on the list in rg_lo_add(), and then the rindex glock is dropped so the other node can grow the filesystem. When the node reacquires the rindex glock, that rgd gets deleted in clear_rgrpdi() before ever being removed from the list by gfs2_log_flush(). This code simply forces a log flush when the rindex glock is invalidated, solving the problem. Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2011-05-09GFS2: Move gfs2_refresh_inode() and friends into glops.cSteven Whitehouse
Eventually there will only be a single caller of this code, so lets move it where it can be made static at some future date. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2011-04-20GFS2: Clean up fsync()Steven Whitehouse
This patch is designed to clean up GFS2's fsync implementation and ensure that it really does get everything on disk. Since ->write_inode() has been updated, we can call that via the vfs library function sync_inode_metadata() and the only remaining thing that has to be done is to ensure that we get any revoke records in the log after the inode has been written back. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2011-04-18GFS2: Don't try to deallocate unlinked inodes when mounted roSteven Whitehouse
This adds a couple of missing tests to avoid read-only nodes from attempting to deallocate unlinked inodes. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Reported-by: Michel Andre de la Porte <madelaporte@ubi.com>
2011-03-11GFS2: introduce AIL lockDave Chinner
The log lock is currently used to protect the AIL lists and the movements of buffers into and out of them. The lists are self contained and no log specific items outside the lists are accessed when starting or emptying the AIL lists. Hence the operation of the AIL does not require the protection of the log lock so split them out into a new AIL specific lock to reduce the amount of traffic on the log lock. This will also reduce the amount of serialisation that occurs when the gfs2_logd pushes on the AIL to move it forward. This reduces the impact of log pushing on sequential write throughput. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2011-01-21GFS2: Use RCU for glock hash tableSteven Whitehouse
This has a number of advantages: - Reduces contention on the hash table lock - Makes the code smaller and simpler - Should speed up glock dumps when under load - Removes ref count changing in examine_bucket - No longer need hash chain lock in glock_put() in common case There are some further changes which this enables and which we may do in the future. One is to look at using SLAB_RCU, and another is to look at using a per-cpu counter for the per-sb glock counter, since that is touched twice in the lifetime of each glock (but only used at umount time). Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-12-16GFS2: Don't flush delete workqueue when releasing the transaction lockSteven Whitehouse
There is no requirement to flush the delete workqueue before a gfs2 filesystem is suspended. The workqueue's work will just be suspended along with the rest of the tasks on the filesystem. The resolves a deadlock situation where the transaction lock's demotion code was trying to flush the delete workqueue while at the same time, the workqueue was waiting for the transaction lock. The delete workqueue is flushed by gfs2_make_fs_ro() already, so that umount/remount are correctly protected anyway. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-10-06GFS2: Fix type mapping for demote_rq interfaceSteven Whitehouse
Mostly the glock operations follow the type of the glock. The one exception is the transaction glock, so we need to check for that directly. Reported-by: Dr. David Alan Gilbert <linux@treblig.org> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-09-20GFS2: Remove i_disksizeSteven Whitehouse
With the update of the truncate code, ip->i_disksize and inode->i_size are merely copies of each other. This means we can remove ip->i_disksize and use inode->i_size exclusively reducing the size of a GFS2 inode by 8 bytes. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-01GFS2: Metadata address space clean upSteven Whitehouse
Since the start of GFS2, an "extra" inode has been used to store the metadata belonging to each inode. The only reason for using this inode was to have an extra address space, the other fields were unused. This means that the memory usage was rather inefficient. The reason for keeping each inode's metadata in a separate address space is that when glocks are requested on remote nodes, we need to be able to efficiently locate the data and metadata which relating to that glock (inode) in order to sync or sync and invalidate it (depending on the remotely requested lock mode). This patch adds a new type of glock, which has in addition to its normal fields, has an address space. This applies to all inode and rgrp glocks (but to no other glock types which remain as before). As a result, we no longer need to have the second inode. This results in three major improvements: 1. A saving of approx 25% of memory used in caching inodes 2. A removal of the circular dependency between inodes and glocks 3. No confusion between "normal" and "metadata" inodes in super.c Although the first of these is the more immediately apparent, the second is just as important as it now enables a number of clean ups at umount time. Those will be the subject of future patches. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-12-03GFS2: Use forget_all_cached_acls()Steven Whitehouse
Invalidate all the cached ACLs when we drop the glock. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-07-30GFS2: remove dcache entries for remote deleted inodesBenjamin Marzinski
When a file is deleted from a gfs2 filesystem on one node, a dcache entry for it may still exist on other nodes in the cluster. If this happens, gfs2 will be unable to free this file on disk. Because of this, it's possible to have a gfs2 filesystem with no files on it and no free space. With this patch, when a node receives a callback notifying it that the file is being deleted on another node, it schedules a new workqueue thread to remove the file's dcache entry. Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-05-20GFS2: Improve resource group error handlingSteven Whitehouse
This patch improves the error handling in the case where we discover that the summary information in the resource group doesn't match the bitmap information while in the process of allocating blocks. Originally this resulted in a kernel bug, but this patch changes that so that we return -EIO and print some messages explaining what went wrong, and how to fix it. We also remember locally not to try and allocate from the same rgrp again, so that a subsequent allocation in a different rgrp should succeed. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-04-20GFS2: Clear dirty bit at end of inode glock syncSteven Whitehouse
The dirty bit can get set during the inode glock sync. Its too complicated to change that at the moment, so this is the quick fix - to clear the bit again at the end of the function. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-03-24GFS2: Clean up of glops.cSteven Whitehouse
This cleans up a number of bits of code mostly based in glops.c. A couple of simple functions have been merged into the callers to make it more obvious what is going on, the mysterious raising of i_writecount around the truncate_inode_pages() call has been removed. The meta_go_* operations have been renamed rgrp_go_* since that is the only lock type that they are used with. The unused argument of gfs2_read_sb has been removed. Also a bug has been fixed where a check for the rindex inode was in the wrong callback. More comments are added, and the debugging code is improved too. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-03-24GFS2: Add a "demote a glock" interface to sysfsSteven Whitehouse
This adds a sysfs file called demote_rq to GFS2's per filesystem directory. Its possible to use this file to demote arbitrary glocks in exactly the same way as if a request had come in from a remote node. This is intended for testing issues relating to caching of data under glocks. Despite that, the interface is generic enough to send requests to any type of glock, but be careful as its not always safe to send an arbitrary message to an arbitrary glock. For that reason and to prevent DoS, this interface is restricted to root only. The messages look like this: <type>:<glocknumber> <mode> Example: echo -n "2:13324 EX" >/sys/fs/gfs2/unity:myfs/demote_rq Which means "please demote inode glock (type 2) number 13324 so that I can get an EX (exclusive) lock". The lock modes are those which would normally be sent by a remote node in its callback so if you want to unlock a glock, you use EX, to demote to shared, use SH or PR (depending on whether you like GFS2 or DLM lock modes better!). If the glock doesn't exist, you'll get -ENOENT returned. If the arguments don't make sense, you'll get -EINVAL returned. The plan is that this interface will be used in combination with the blktrace patch which I recently posted for comments although it is, of course, still useful in its own right. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-03-24GFS2: Fix deadlock on journal flushSteven Whitehouse
This patch fixes a deadlock when the journal is flushed and there are dirty inodes other than the one which caused the journal flush. Originally the journal flushing code was trying to obtain the transaction glock while running the flush code for an inode glock. We no longer require the transaction glock at this point in time since we know that any attempt to get the transaction glock from another node will result in a journal flush. So if we are flushing the journal, we can be sure that the transaction lock is still cached from when the transaction was started. By inlining a version of gfs2_trans_begin() (minus the bit which gets the transaction glock) we can avoid the deadlock problems caused if there is a demote request queued up on the transaction glock. In addition I've also moved the umount rwsem so that it covers the glock workqueue, since it all demotions are done by this workqueue now. That fixes a bug on umount which I came across while fixing the original problem. Reported-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-03-24GFS2: Merge lock_dlm module into GFS2Steven Whitehouse
This is the big patch that I've been working on for some time now. There are many reasons for wanting to make this change such as: o Reducing overhead by eliminating duplicated fields between structures o Simplifcation of the code (reduces the code size by a fair bit) o The locking interface is now the DLM interface itself as proposed some time ago. o Fewer lookups of glocks when processing replies from the DLM o Fewer memory allocations/deallocations for each glock o Scope to do further optimisations in the future (but this patch is more than big enough for now!) Please note that (a) this patch relates to the lock_dlm module and not the DLM itself, that is still a separate module; and (b) that we retain the ability to build GFS2 as a standalone single node filesystem with out requiring the DLM. This patch needs a lot of testing, hence my keeping it I restarted my -git tree after the last merge window. That way, this has the maximum exposure before its merged. This is (modulo a few minor bug fixes) the same patch that I've been posting on and off the the last three months and its passed a number of different tests so far. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-01-05GFS2: Kill two daemons with one patchSteven Whitehouse
This patch removes the two daemons, gfs2_scand and gfs2_glockd and replaces them with a shrinker which is called from the VM. The net result is that GFS2 responds better when there is memory pressure, since it shrinks the glock cache at the same rate as the VFS shrinks the dcache and icache. There are no longer any time based criteria for shrinking glocks, they are kept until such time as the VM asks for more memory and then we demote just as many glocks as required. There are potential future changes to this code, including the possibility of sorting the glocks which are to be written back into inode number order, to get a better I/O ordering. It would be very useful to have an elevator based workqueue implementation for this, as that would automatically deal with the read I/O cases at the same time. This patch is my answer to Andrew Morton's remark, made during the initial review of GFS2, asking why GFS2 needs so many kernel threads, the answer being that it doesn't :-) This patch is a net loss of about 200 lines of code. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-01-05GFS2: Fix "truncate in progress" hangSteven Whitehouse
Following on from the recent clean up of gfs2_quotad, this patch moves the processing of "truncate in progress" inodes from the glock workqueue into gfs2_quotad. This fixes a hang due to the "truncate in progress" processing requiring glocks in order to complete. It might seem odd to use gfs2_quotad for this particular item, but we have to use a pre-existing thread since creating a thread implies a GFP_KERNEL memory allocation which is not allowed from the glock workqueue context. Of the existing threads, gfs2_logd and gfs2_recoverd may deadlock if used for this operation. gfs2_scand and gfs2_glockd are both scheduled for removal at some (hopefully not too distant) future point. That leaves only gfs2_quotad whose workload is generally fairly light and is easily adapted for this extra task. Also, as a result of this change, it opens the way for a future patch to make the reading of the inode's information asynchronous with respect to the glock workqueue, which is another improvement that has been on the list for some time now. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-01-05GFS2: Add more detail to debugfs glock dumpsSteven Whitehouse
Although the glock dumps print quite a lot of information about the glocks themselves, there are more things which can be usefully added to the dump realting to the objects themselves. This patch adds a few more fields to the inode and resource group lines, which should be useful for debugging. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-01-05GFS2: Banish struct gfs2_dinode_hostSteven Whitehouse
The final field in gfs2_dinode_host was the i_flags field. Thats renamed to i_diskflags in order to avoid confusion with the existing inode flags, and moved into the inode proper at a suitable location to avoid creating a "hole". At that point struct gfs2_dinode_host is no longer needed and as promised (quite some time ago!) it can now be removed completely. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-06-27[GFS2] Clean up the glock coreSteven Whitehouse
This patch implements a number of cleanups to the core of the GFS2 glock code. As a result a lot of code is removed. It looks like a really big change, but actually a large part of this patch is either removing or moving existing code. There are some new bits too though, such as the new run_queue() function which is considerably streamlined. Highlights of this patch include: o Fixes a cluster coherency bug during SH -> EX lock conversions o Removes the "glmutex" code in favour of a single bit lock o Removes the ->go_xmote_bh() for inodes since it was duplicating ->go_lock() o We now only use the ->lm_lock() function for both locks and unlocks (i.e. unlock is a lock with target mode LM_ST_UNLOCKED) o The fast path is considerably shortly, giving performance gains especially with lock_nolock o The glock_workqueue is now used for all the callbacks from the DLM which allows us to simplify the lock_dlm module (see following patch) o The way is now open to make further changes such as eliminating the two threads (gfs2_glockd and gfs2_scand) in favour of a more efficient scheme. This patch has undergone extensive testing with various test suites so it should be pretty stable by now. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Bob Peterson <rpeterso@redhat.com>
2008-05-12[GFS2] filesystem consistency error from do_stripBob Peterson
This patch fixes a GFS2 filesystem consistency error reported from function do_strip. The problem was caused by a timing window that allowed two vfs inodes to be created in memory that point to the same file. The problem is fixed by making the vfs's iget_test, iget_set mechanism check and set a new bit in the in-core gfs2_inode structure while the vfs inode spin_lock is held. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-03-31[GFS2] Remove rgrp and glock version numbersBob Peterson
This patch further reduces GFS2's memory requirements by eliminating the 64-bit version number fields in lieu of a couple bits. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-01-25[GFS2] Reorder writeback for glock syncSteven Whitehouse
Previously we were doing (write data, wait for data, write metadata, wait for metadata). After this patch we so (write metadata, write data, wait for data, wait for metadata) which should be more efficient. Also I noticed that the drop_bh and xmote_bh functions were almost identical. In fact the only difference was a single test, and that test is such that in the drop_bh case, it would always evaluate to the correct result. As such we can use the xmote_bh functions in all the places where we were using the drop_bh function and remove the drop_bh functions. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-01-25[GFS2] Remove useless i_cache from inodesSteven Whitehouse
The i_cache was designed to keep references to the indirect blocks used during block mapping so that they didn't have to be looked up continually. The idea failed because there are too many places where the i_cache needs to be freed, and this has in the past been the cause of many bugs. In addition there was no performance benefit being gained since the disk blocks in question were cached anyway. So this patch removes it in order to simplify the code to prepare for other changes which would otherwise have had to add further support for this feature. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-01-25[GFS2] Use ->page_mkwrite() for mmap()Steven Whitehouse
This cleans up the mmap() code path for GFS2 by implementing the page_mkwrite function for GFS2. We are thus able to use the generic filemap_fault function for our ->fault() implementation. This now means that shared writable mappings will be much more efficiently shared across the cluster if there is a reasonable proportion of read activity (the greater proportion, the better). As a side effect, it also reduces the size of the code, removes special cases from readpage and readpages, and makes the code path easier to follow. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-10-10[GFS2] Clean up gfs2_trans_add_revoke()Steven Whitehouse
The following alters gfs2_trans_add_revoke() to take a struct gfs2_bufdata as an argument. This eliminates the memory allocation which was previously required by making use of the already existing struct gfs2_bufdata. It makes some sanity checks to ensure that the gfs2_bufdata has been removed from all the lists before its recycled as a revoke structure. This saves one memory allocation and one free per revoke structure. Also as a result, and to simplify the locking, since there is no longer any blocking code in gfs2_trans_add_revoke() we must hold the log lock whenever this function is called. This reduces the amount of times we take and unlock the log lock. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-10-10[GFS2] Introduce gfs2_remove_from_ailSteven Whitehouse
This collects together the operations required to remove a gfs2_bufdata from the ail lists. Its only called from two places to start with, but expect to see more of this function in future. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-10-10[GFS2] delay glock demote for a minimum hold timeBenjamin Marzinski
When a lot of IO, with some distributed mmap IO, is run on a GFS2 filesystem in a cluster, it will deadlock. The reason is that do_no_page() will repeatedly call gfs2_sharewrite_nopage(), because each node keeps giving up the glock too early, and is forced to call unmap_mapping_range(). This bumps the mapping->truncate_count sequence count, forcing do_no_page() to retry. This patch institutes a minimum glock hold time a tenth a second. This insures that even in heavy contention cases, the node has enough time to get some useful work done before it gives up the glock. A second issue is that when gfs2_glock_dq() is called from within a page fault to demote a lock, and the associated page needs to be written out, it will try to acqire a lock on it, but it has already been locked at a higher level. This patch puts makes gfs2_glock_dq() use the work queue as well, to avoid this issue. This is the same patch as Steve Whitehouse originally proposed to fix this issue, execpt that gfs2_glock_dq() now grabs a reference to the glock before it queues up the work on it. Signed-off-by: Benjamin E. Marzinski <bmarzins@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-10-10[GFS2] Clean up invalidatepage/releasepageSteven Whitehouse
This patch fixes some bugs relating to journaled data files by cleaning up the gfs2_invalidatepage() and gfs2_releasepage() functions. We now never block during gfs2_releasepage(), instead we always either release or refuse to release depending on the status of the buffers. This fixes Red Hat bugzillas #248969 and #252392. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Bob Peterson <rpeterso@redhat.com>
2007-07-09[GFS2] flush the glock completely in inode_go_syncBenjamin Marzinski
Fix for bz #231910 When filemap_fdatawrite() is called on the inode mapping in data=ordered mode, it will add the glock to the log. In inode_go_sync(), if you do the gfs2_log_flush() before this, after the filemap_fdatawrite() call, the glock and its associated data buffers will be on the log again. This means you can demote a lock from exclusive, without having it flushed from the log. The attached patch simply moves the gfs2_log_flush up to after the filemap_fdatawrite() call. Originally, I tried moving the gfs2_log_flush to after gfs2_meta_sync(), but that caused me to trip the following assert. GFS2: fsid=cypher-36:test.0: fatal: assertion "!buffer_busy(bh)" failed GFS2: fsid=cypher-36:test.0: function = gfs2_ail_empty_gl, file = fs/gfs2/glops.c, line = 61 It appears that gfs2_log_flush() puts some of the glocks buffers in the busy state and the filemap_fdatawrite() call is necessary to flush them. This makes me worry slightly that a related problem could happen because of moving the gfs2_log_flush() after the initial filemap_fdatawrite(), but I assume that gfs2_ail_empty_gl() would catch that case as well. Signed-off-by: Benjamin E. Marzinski <bmarzins@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-05-08Factor outstanding I/O error handlingGuillaume Chazarain
Cleanup: setting an outstanding error on a mapping was open coded too many times. Factor it out in mapping_set_error(). Signed-off-by: Guillaume Chazarain <guichaz@yahoo.fr> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-07[GFS2] Fix bz 229873, alternate test: assertion ↵Steven Whitehouse
"!ip->i_inode.i_mapping->nrpages" failed The following removes an incorrect assertion from the GFS2 glops code. This fixes Red Hat bz 229873. Thanks to Abhijith Das for testing the patch and confirming the fix. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Abhijith Das <adas@redhat.com>
2007-03-07[GFS2] Fix bz 230143, incorrect flushing of rgrpsSteven Whitehouse
The below patch fixes a problem where we were not flushing rgrps correctly. It only occurred in the specific case that a callback was received for an rgrp which was dirty and when a journal log flush had not already resulted in the rgrp being flushed anyway. This fixes Red Hat bz 230143, Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-02-05[GFS2] Tidy up glops callsSteven Whitehouse
This patch doesn't make any changes to the ordering of the various operations related to glocking, but it does tidy up the calls to the glops.c functions to make the structure more obvious. The two functions: gfs2_glock_xmote_th() and gfs2_glock_drop_th() can be made static within glock.c since they are called by every set of glock operations. The xmote_th and drop_th glock operations are then made conditional upon those two routines existing and called from the previously mentioned functions in glock.c respectively. Also it can be seen that the go_sync operation isn't needed since it can easily be replaced by calls to xmote_bh and drop_bh respectively. This results in no longer (confusingly) calling back into routines in glock.c from glops.c and also reducing the glock operations by one member. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-02-05[GFS2] Remove local exclusive glock modeSteven Whitehouse
Here is a patch for GFS2 to remove the local exclusive flag. In the places it was used, mutex's are always held earlier in the call path, so it appears redundant in the LM_ST_SHARED case. Also, the GFS2 holders were setting local exclusive in any case where the requested lock was LM_ST_EXCLUSIVE. So the other places in the glock code where the flag was tested have been replaced with tests for the lock state being LM_ST_EXCLUSIVE in order to ensure the logic is the same as before (i.e. LM_ST_EXCLUSIVE is always locally exclusive as well as globally exclusive). Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-02-05[GFS2] Remove the "greedy" function from glock.[ch]Steven Whitehouse
The "greedy" code was an attempt to retain glocks for a minimum length of time when they relate to mmap()ed files. The current implementation of this feature is not, however, ideal in that it required allocating memory in order to do this and its overly complicated. It also misses the mark by ignoring the other I/O operations which are just as likely to suffer from the same problem. So the plan is to remove this now and then add the functionality back as part of the glock state machine at a later date (and thus take into account all the possible users of this feature) Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-11-30[GFS2] Fix journal flush problemSteven Whitehouse
This fixes a bug which resulted in poor performance due to flushing the journal too often. The code path in question was via the inode_go_sync() function in glops.c. The solution is not to flush the journal immediately when inodes are ejected from memory, but batch up the work for glockd to deal with later on. This means that glocks may now live on beyond the end of the lifetime of their inodes (but not very much longer in the normal case). Also fixed in this patch is a bug (which was hidden by the bug mentioned above) in calculation of the number of free journal blocks. The gfs2_logd process has been altered to be more responsive to the journal filling up. We now wake it up when the number of uncommitted journal blocks has reached the threshold level rather than trying to flush directly at the end of each transaction. This again means doing fewer, but larger, log flushes in general. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-11-30[GFS2] Simplify glops functionsSteven Whitehouse
The go_sync callback took two flags, but one of them was set on every call, so this patch removes once of the flags and makes the previously conditional operations (on this flag), unconditional. The go_inval callback took three flags, each of which was set on every call to it. This patch removes the flags and makes the operations unconditional, which makes the logic rather more obvious. Two now unused flags are also removed from incore.h. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-11-30[GFS2] Remove gfs2_inode_attr_inSteven Whitehouse
This function wasn't really doing the right thing. There was no need to update the inode size at this point and the updating of the i_blocks field has now been moved to the places where di_blocks is updated. A result of this patch and some those preceeding it is that unlocking a glock is now a much more efficient process, since there is no longer any requirement to copy data from the gfs2 inode into the vfs inode at this point. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-11-30[GFS2] Shrink gfs2_inode (8) - i_vnSteven Whitehouse
This shrinks the size of the gfs2_inode by 8 bytes by replacing the version counter with a one bit valid/invalid flag. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-11-30[GFS2] Shrink gfs2_inode (3) - di_modeSteven Whitehouse
This removes the duplicate di_mode field in favour of using the inode->i_mode field. This saves 4 bytes. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
