commit 21039132650281de06a169cbe8a0f7e5c578fd8b upstream.
with the way fs/namei.c:do_last() had been done, ->atomic_open()
instances needed to recognize the case when existing file got
found with O_EXCL|O_CREAT, either by falling back to finish_no_open()
or failing themselves. gfs2 one didn't.
Fixes: 6d4ade986f9c (GFS2: Add atomic_open support)
Cc: stable@kernel.org # v3.11
commit 6ff9b09e00a441599f3aacdf577254455a048bc9 upstream.
In gfs2_create_inode, after setting and releasing the acl / default_acl, the
acl / default_acl pointers are not set to NULL as they should be. In that
state, when the function reaches label fail_free_acls, gfs2_create_inode will
try to release the same acls again.
Fix that by setting the pointers to NULL after releasing the acls. Slightly
simplify the logic. Also, posix_acl_release checks for NULL already, so
there is no need to duplicate those checks here.
Fixes: e01580bf9e4d ("gfs2: use generic posix ACL infrastructure")
Reported-by: Pan Bian <bianpan2016@163.com>
Cc: stable@vger.kernel.org # v4.9+
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
Pull vfs xattr updates from Al Viro:
"xattr stuff from Andreas
This completes the switch to xattr_handler ->get()/->set() from
->getxattr/->setxattr/->removexattr"
* 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
vfs: Remove {get,set,remove}xattr inode operations
xattr: Stop calling {get,set,remove}xattr inode operations
vfs: Check for the IOP_XATTR flag in listxattr
xattr: Add __vfs_{get,set,remove}xattr helpers
libfs: Use IOP_XATTR flag for empty directory handling
vfs: Use IOP_XATTR flag for bad-inode handling
vfs: Add IOP_XATTR inode operations flag
vfs: Move xattr_resolve_name to the front of fs/xattr.c
ecryptfs: Switch to generic xattr handlers
sockfs: Get rid of getxattr iop
sockfs: getxattr: Fail with -EOPNOTSUPP for invalid attribute names
kernfs: Switch to generic xattr handlers
hfs: Switch to generic xattr handlers
jffs2: Remove jffs2_{get,set,remove}xattr macros
xattr: Remove unnecessary NULL attribute name check
Pull misc vfs updates from Al Viro:
"Assorted misc bits and pieces.
There are several single-topic branches left after this (rename2
series from Miklos, current_time series from Deepa Dinamani, xattr
series from Andreas, uaccess stuff from from me) and I'd prefer to
send those separately"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (39 commits)
proc: switch auxv to use of __mem_open()
hpfs: support FIEMAP
cifs: get rid of unused arguments of CIFSSMBWrite()
posix_acl: uapi header split
posix_acl: xattr representation cleanups
fs/aio.c: eliminate redundant loads in put_aio_ring_file
fs/internal.h: add const to ns_dentry_operations declaration
compat: remove compat_printk()
fs/buffer.c: make __getblk_slow() static
proc: unsigned file descriptors
fs/file: more unsigned file descriptors
fs: compat: remove redundant check of nr_segs
cachefiles: Fix attempt to read i_blocks after deleting file [ver #2]
cifs: don't use memcpy() to copy struct iov_iter
get rid of separate multipage fault-in primitives
fs: Avoid premature clearing of capabilities
fs: Give dentry to inode_change_ok() instead of inode
fuse: Propagate dentry down to inode_change_ok()
ceph: Propagate dentry down to inode_change_ok()
xfs: Propagate dentry down to inode_change_ok()
These inode operations are no longer used; remove them.
git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2
Pull gfs2 updates from Bob Peterson:
"We've only got six GFS2 patches for this merge window. In patch
order:
- Fabian Frederick submitted a nice cleanup that uses the BIT macro
rather than bit shifting.
- Andreas Gruenbacher contributed a patch that fixes a long-standing
annoyance whereby GFS2 warned about dirty pages.
- Andreas also fixed a problem with the recent extended attribute
readahead feature.
- Chao Yu contributed a patch that checks the return code from
function register_shrinker and reacts accordingly. Previously, it
was not checked.
- Andreas Gruenbacher also fixed a problem whereby incore file
timestamps were forgotten if the file was invalidated. This merely
moves the assignment inside the inode glock where it belongs.
- Andreas also fixed a problem where incore timestamps were not
initialized"
* tag 'gfs2-4.8.fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2:
gfs2: Initialize atime of I_NEW inodes
gfs2: Update file times after grabbing glock
gfs2: fix to detect failure of register_shrinker
gfs2: Fix extended attribute readahead optimization
gfs2: Remove dirty buffer warning from gfs2_releasepage
GFS2: use BIT() macro
CURRENT_TIME macro is not appropriate for filesystems as it
doesn't use the right granularity for filesystem timestamps.
Use current_time() instead.
CURRENT_TIME is also not y2038 safe.
This is also in preparation for the patch that transitions
vfs timestamps to use 64 bit time and hence make them
y2038 safe. As part of the effort current_time() will be
extended to do range checks. Hence, it is necessary for all
file system timestamps to use current_time(). Also,
current_time() will be transitioned along with vfs to be
y2038 safe.
Note that whenever a single call to current_time() is used
to change timestamps in different inodes, it is because they
share the same time granularity.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Felipe Balbi <balbi@kernel.org>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Acked-by: David Sterba <dsterba@suse.com>
Generated patch:
sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2`
sed -i "s/\brename2\b/rename/g" `git grep -wl rename2`
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
Fix for commit 719ee344: initialize atime of I_NEW inodes to 0 so that
the timestamps read from disk will always be more recent than the
initial timestamp, and the atime in the I_NEW inode will be set correctly.
inode_change_ok() will be resposible for clearing capabilities and IMA
extended attributes and as such will need dentry. Give it as an argument
to inode_change_ok() instead of an inode. Also rename inode_change_ok()
to setattr_prepare() to better relect that it does also some
modifications in addition to checks.
In most cases, EPERM is returned on immutable inode, and there're only a
few places returning EACCES. I noticed this when running LTP on
overlayfs, setxattr03 failed due to unexpected EACCES on immutable
inode.
So converting all EACCES to EPERM on immutable inode.
Acked-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
"We've got ten patches this time, half of which are related to a
plethora of nasty outcomes when inodes are transitioned from the
unlinked state to the free state. Small file systems are particularly
vulnerable to these problems, and it can manifest as mainly hangs, but
also file system corruption. The patches have been tested for
literally many weeks, with a very gruelling test, so I have a high
level of confidence.
- Andreas Gruenbacher wrote a series of five patches for various
lockups during the transition of inodes from unlinked to free.
The main patch is titled "Fix gfs2_lookup_by_inum lock inversion"
and the other four are support and cleanup patches related to that.
- Ben Marzinski contributed two patches with regard to a recreatable
problem when gfs2 tries to write a page to a file that is being
truncated, resulting in a BUG() in gfs2_remove_from_journal.
Note that Ben had to export vfs function __block_write_full_page to
get this to work properly. It's been posted a long time and he
talked to various VFS people about it, and nobody seemed to mind.
- I contributed 3 patches:
o The first one fixes a memory corruptor: a race in which one
process can overwrite the gl_object pointer set by another
process, causing kernel panic and other symptoms.
o The second patch fixes another race that resulted in a
false-positive BUG_ON. This occurred when resource group
reservations were freed by one process while another process
was trying to grab a new reservation in the same resource
group.
o The third patch fixes a problem with doing journal replay when
the journals are not all the same size"
* tag 'gfs2-4.7.fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2:
GFS2: Fix gfs2_replay_incr_blk for multiple journal sizes
GFS2: Check rs_free with rd_rsspin protection
gfs2: writeout truncated pages
fs: export __block_write_full_page
gfs2: Lock holder cleanup
gfs2: Large-filesystem fix for 32-bit systems
gfs2: Get rid of gfs2_ilookup
gfs2: Fix gfs2_lookup_by_inum lock inversion
gfs2: Initialize iopen glock holder for new inodes
GFS2: don't set rgrp gl_object until it's inserted into rgrp tree
->atomic_open() can be given an in-lookup dentry *or* a negative one
found in dcache. Use d_in_lookup() to tell one from another, rather
than d_unhashed().
Make the code more readable by cleaning up the different ways of
initializing lock holders and checking for initialized lock holders:
mark lock holders as uninitialized by setting the holder's glock to NULL
(gfs2_holder_mark_uninitialized) instead of zeroing out the entire
object or using a separate flag. Recognize initialized holders by their
non-NULL glock (gfs2_holder_initialized). Don't zero out holder objects
which are immeditiately initialized via gfs2_holder_init or
gfs2_glock_nq_init.
Commit ff34245d switched from iget5_locked to iget_locked among other
things, but iget_locked doesn't work for filesystems larger than 2^32
blocks on 32-bit systems. Switch back to iget5_locked. Filesystems
larger than 2^32 blocks are unrealistic to work well on 32-bit systems,
so this is mostly a code cleanliness fix.
Now that gfs2_lookup_by_inum only takes the inode glock for new inodes
(and not for cached inodes anymore), there no longer is a need to
optimize the cached-inode case in gfs2_get_dentry or delete_work_func,
and gfs2_ilookup can be removed.
In addition, gfs2_get_dentry wasn't checking the GFS2_DIF_SYSTEM flag in
i_diskflags in the gfs2_ilookup case (see gfs2_lookup_by_inum); this
inconsistency goes away as well.
The current gfs2_lookup_by_inum takes the glock of a presumed inode
identified by block number, verifies that the block is indeed an inode,
and then instantiates and reads the new inode via gfs2_inode_lookup.
However, instantiating a new inode may block on freeing a previous
instance of that inode (__wait_on_freeing_inode), and freeing an inode
requires to take the glock already held, leading to lock inversion and
deadlock.
Fix this by first instantiating the new inode, then verifying that the
block is an inode (if required), and then reading in the new inode, all
in gfs2_inode_lookup.
If the block we are looking for is not an inode, we discard the new
inode via iget_failed, which marks inodes as bad and unhashes them.
Other tasks waiting on that inode will get back a bad inode back from
ilookup or iget_locked; in that case, retry the lookup.
Pull GFS2 updates from Bob Peterson:
"We've got nine patches this time:
- Abhi Das has two patches that fix a GFS2 splice issue (and an
adjustment).
- Ben Marzinski has a patch which allows the proper unmount of a GFS2
file system after hitting a withdraw error.
- I have a patch to fix a problem where GFS2 would dereference an
error value, plus three cosmetic / refactoring patches.
- Daniel DeFreez has a patch to fix two glock reference count
problems, where GFS2 was not properly "uninitializing" its glock
holder on error paths.
- Denys Vlasenko has a patch to change a function to not be inlined,
thus reducing the memory footprint of the GFS2 module"
GFS2: Refactor gfs2_remove_from_journal
GFS2: Remove allocation parms from gfs2_rbm_find
gfs2: use inode_lock/unlock instead of accessing i_mutex directly
GFS2: Add calls to gfs2_holder_uninit in two error handlers
GFS2: Don't dereference inode in gfs2_inode_lookup until it's valid
GFS2: fs/gfs2/glock.c: Deinline do_error, save 1856 bytes
gfs2: Use gfs2 wrapper to sync inode before calling generic_file_splice_read()
GFS2: Get rid of dead code in inode_go_demote_ok
GFS2: ignore unlock failures after withdraw
Switch to the generic xattr handlers and take the necessary glocks at
the layer below. The following are the new xattr "entry points"; they
are called with the glock held already in the following cases:
gfs2_xattr_get: From SELinux, during lookups.
gfs2_xattr_set: The glock is never held.
gfs2_get_acl: From gfs2_create_inode -> posix_acl_create and
gfs2_setattr -> posix_acl_chmod.
gfs2_set_acl: From gfs2_setattr -> posix_acl_chmod.
Function gfs2_inode_lookup was dereferencing the inode, and after,
it checks for the value being NULL. We need to check that first.
"We only have six patches ready for this merge window:
- Arnd Bergmann contributed a patch that fixes an uninitialized
variable warning.
- The second patch avoids a kernel panic due to referencing an iopen
glock that may not be held, in an error path.
- The third patch fixes a rounding error that caused xfs_tests direct
IO write "fsx" tests to fail on GFS2.
- The fourth patch tidies up the code path when glocks are being
reused to recreate a dinode that was recently deleted.
- The fifth reverts an ages-old patch that should no longer be
needed, and which interfered with the transition of dinodes from
unlinked to free.
- And lastly, a patch to eliminate a function parameter that's not
needed"
* tag 'gfs2-merge-window' of git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2:
GFS2: Eliminate parameter non_block on gfs2_inode_lookup
GFS2: Don't filter out I_FREEING inodes anymore
GFS2: Prevent delete work from occurring on glocks used for create
GFS2: Fix direct IO write rounding error
gfs2: avoid uninitialized variable warning
GFS2: Check if iopen is held when deleting inode
Now that we're not filtering out I_FREEING inodes from our lookups
anymore, we can eliminate the non_block parameter from the lookup
function.
This patch basically reverts a very old patch from 2008,
7a9f53b3c1875bef22ad4588e818bc046ef183da, with the title
"Alternate gfs2_iget to avoid looking up inodes being freed".
The original patch was designed to avoid a deadlock caused by lock
ordering with try_rgrp_unlink. The patch forced the function to not
find inodes that were being removed by VFS. The problem is, that
made it impossible for nodes to delete their own unlinked dinodes
after a certain point in time, because the inode needed was not found
by this filtering process. There is no longer a need for the patch,
since function try_rgrp_unlink no longer locks the inode: All it does
is queue the glock onto the delete work_queue, so there should be no
more deadlock.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
This patch tries to prevent delete work (queued via iopen callback)
from executing if the glock is currently being used to create
a new inode.
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested},
inode_foo(inode) being mutex_foo(&inode->i_mutex).
Please, use those for access to ->i_mutex; over the coming cycle
->i_mutex will become rwsem, with ->lookup() done with it held
only shared.
"Here is a list of patches we've accumulated for GFS2 for the current
upstream merge window. Last window's set was short, but I warned that
this one would be bigger, and so it is. We've got 19 patches:
- A patch from Abhi Das to propagate the GFS2_DIF_SYSTEM bit so that
newly added journals don't get flagged, deleted, and recreated by
fsck.gfs2.
- Two patches from Andreas Gruenbacher to improve GFS2 performance
where extended attributes are involved.
- A patch from Andy Price to fix a suspicious rcu dereference error.
- Two patches from Ben Marzinski that rework how GFS2's NFS cookies
are managed. This fixes readdir problems with nfs-over-gfs2.
- A patch from Ben Marzinski that fixes a race in unmounting GFS2.
- A set of four patches from me to move the resource group
reservations inside the gfs2 inode to improve performance and fix a
bug whereby get_write_access improperly prevented some operations
like chown.
- A patch from me to spinlock-protect the setting of system statfs
file data. This was causing small discrepancies between df and du.
- A patch from me to reintroduce a timeout while clearing glocks
which was accidentally dropped some time ago.
- A patch from me to wait for iopen glock dequeues in order to
improve deleting of files that were unlinked from a different
cluster node.
- A patch from me to ensure metadata address spaces get truncated
when an inode is evicted.
- A patch from me to fix a bug in which a memory leak could occur in
some error cases when inodes were trying to be created.
- A patch to consistently use iopen glocks to transition from the
unlinked state to the deleted state.
- A patch to fix a glock reference count error when inode creation
fails.
- A patch from Junxiao Bi to fix an flock panic.
- A patch from Markus Elfring that removes an unnecessary if"
gfs2: fix flock panic issue
GFS2: Don't do glock put on when inode creation fails
GFS2: Always use iopen glock for gl_deletes
GFS2: Release iopen glock in gfs2_create_inode error cases
GFS2: Truncate address space mapping when deleting an inode
GFS2: Wait for iopen glock dequeues
gfs2: clear journal live bit in gfs2_log_flush
gfs2: change gfs2 readdir cookie
gfs2: keep offset when splitting dir leaf blocks
GFS2: Reintroduce a timeout in function gfs2_gl_hash_clear
GFS2: Update master statfs buffer with sd_statfs_spin locked
GFS2: Reduce size of incore inode
GFS2: Make rgrp reservations part of the gfs2_inode structure
GFS2: Extract quota data from reservations structure (revert 5407e24)
gfs2: Extended attribute readahead optimization
GFS2: Use rht_for_each_entry_rcu in glock_hash_walk
GFS2: Delete an unnecessary check before the function call "iput"
gfs2: Automatically set GFS2_DIF_SYSTEM flag on system files
Currently the error path of function gfs2_inode_lookup calls function
gfs2_glock_put corresponding to an earlier call to gfs2_glock_get for
the inode glock. That's wrong because the error path also calls
iget_failed() which eventually calls iput, which eventually calls
gfs2_evict_inode, which does another gfs2_glock_put. This double-put
can cause the glock reference count to get off.
Some error cases in gfs2_create_inode were not unlocking the iopen
glock, getting the reference count off. This adds the proper unlock.
The error logic in function gfs2_create_inode was also convoluted,
so this patch simplifies it. It also takes care of a bug in
which gfs2_qa_delete() was not called in an error case.
This patch changes every glock_dq for iopen glocks into a dq_wait.
This makes sure that iopen glocks do not outlive the inode itself.
In turn, that ensures that anyone trying to unlink the glock will
be able to find the inode when it receives a remote iopen callback.
Before this patch, multi-block reservation structures were allocated
from a special slab. This patch folds the structure into the gfs2_inode
structure. The disadvantage is that the gfs2_inode needs more memory,
even when a file is opened read-only. The advantages are: (a) we don't
need the special slab and the extra time it takes to allocate and
deallocate from it. (b) we no longer need to worry that the structure
exists for things like quota management. (c) This also allows us to
remove the calls to get_write_access and put_write_access since we
know the structure will exist.
new method: ->get_link(); replacement of ->follow_link(). The differences
are:
* inode and dentry are passed separately
* might be called both in RCU and non-RCU mode;
the former is indicated by passing it a NULL dentry.
* when called that way it isn't allowed to block
and should return ERR_PTR(-ECHILD) if it needs to be called
in non-RCU mode.
It's a flagday change - the old method is gone, all in-tree instances
converted. Conversion isn't hard; said that, so far very few instances
do not immediately bail out when called in RCU mode. That'll change
in the next commits.
This patch basically reverts the majority of patch 5407e24.
That patch eliminated the gfs2_qadata structure in favor of just
using the reservations structure. The problem with doing that is that
it increases the size of the reservations structure. That is not an
issue until it comes time to fold the reservations structure into the
inode in memory so we know it's always there. By separating out the
quota structure again, we aren't punishing the non-quota users by
making all the inodes bigger, requiring more slab space. This patch
creates a new slab area to allocate the quota stuff so it's managed
a little more sanely.
When new files and directories are created inside a parent directory
we automatically inherit the GFS2_DIF_SYSTEM flag (if set) and assign
it to the new file/dirs.
All new system files/dirs created in the metafs by, say gfs2_jadd,
will have this flag set because they will have parent directories in
the metafs whose GFS2_DIF_SYSTEM flag has already been set (most likely
by a previous mkfs.gfs2)
Signed-off-by: Abhi Das <adas@redhat.com>
git://git.kernel.org:/pub/scm/linux/kernel/git/gfs2/linux-gfs2
"Here are the patches we've accumulated for GFS2 for the current
upstream merge window. We have a good mixture this time. Here are
some of the features:
- Fix a problem with RO mounts writing to the journal.
- Further improvements to quotas on GFS2.
- Added support for rename2 and RENAME_EXCHANGE on GFS2.
- Increase performance by making glock lru_list less of a bottleneck.
- Increase performance by avoiding unnecessary buffer_head releases.
- Increase performance by using average glock round trip time from all CPUs.
- Fixes for some compiler warnings and minor white space issues.
- Other misc bug fixes"
* tag 'gfs2-merge-window' of git://git.kernel.org:/pub/scm/linux/kernel/git/gfs2/linux-gfs2:
GFS2: Don't brelse rgrp buffer_heads every allocation
GFS2: Don't add all glocks to the lru
gfs2: Don't support fallocate on jdata files
gfs2: s64 cast for negative quota value
gfs2: limit quota log messages
gfs2: fix quota updates on block boundaries
gfs2: fix shadow warning in gfs2_rbm_find()
gfs2: kerneldoc warning fixes
gfs2: convert simple_str to kstr
GFS2: make sure S_NOSEC flag isn't overwritten
GFS2: add support for rename2 and RENAME_EXCHANGE
gfs2: handle NULL rgd in set_rgrp_preferences
GFS2: inode.c: indent with TABs, not spaces
GFS2: mark the journal idle to fix ro mounts
GFS2: Average in only non-zero round-trip times for congestion stats
GFS2: Use average srttb value in congestion calculations
For smaller block sizes (512B, 1K, 2K), some quotas straddle block
boundaries such that the usage value is on one block and the rest
of the quota is on the previous block. In such cases, the value
does not get updated correctly. This patch fixes that by addressing
the boundary conditions correctly.
This patch also adds a (s64) cast that was missing in a call to
gfs2_quota_change() in inode.c
its only use is getting passed to nd_jump_link(), which can obtain
it from current->nameidata
a) instead of storing the symlink body (via nd_set_link()) and returning
an opaque pointer later passed to ->put_link(), ->follow_link() _stores_
that opaque pointer (into void * passed by address by caller) and returns
the symlink body. Returning ERR_PTR() on error, NULL on jump (procfs magic
symlinks) and pointer to symlink body for normal symlinks. Stored pointer
is ignored in all cases except the last one.
Storing NULL for opaque pointer (or not storing it at all) means no call
of ->put_link().
b) the body used to be passed to ->put_link() implicitly (via nameidata).
Now only the opaque pointer is. In the cases when we used the symlink body
to free stuff, ->follow_link() now should store it as opaque pointer in addition
to returning it.
gfs2 now uses the rename2 directory iop, and supports the
RENAME_EXCHANGE flag (as well as RENAME_NOREPLACE, which the vfs
takes care of).
Signed-off-by: Benjamin Marzinski <bmarzins redhat com>
Follow the same style used for the other functions in the same file.
Signed-off-by: Antonio Ospite <ao2@ao2.it>
Pull fourth vfs update from Al Viro:
"d_inode() annotations from David Howells (sat in for-next since before
the beginning of merge window) + four assorted fixes"
RCU pathwalk breakage when running into a symlink overmounting something
fix I_DIO_WAKEUP definition
direct-io: only inc/dec inode->i_dio_count for file systems
fs/9p: fix readdir()
VFS: assorted d_backing_inode() annotations
VFS: fs/inode.c helpers: d_inode() annotations
VFS: fs/cachefiles: d_backing_inode() annotations
VFS: fs library helpers: d_inode() annotations
VFS: assorted weird filesystems: d_inode() annotations
VFS: normal filesystems (and lustre): d_inode() annotations
VFS: security/: d_inode() annotations
VFS: security/: d_backing_inode() annotations
VFS: net/: d_inode() annotations
VFS: net/unix: d_backing_inode() annotations
VFS: kernel/: d_inode() annotations
VFS: audit: d_backing_inode() annotations
VFS: Fix up some ->d_inode accesses in the chelsio driver
VFS: Cachefiles should perform fs modifications on the top layer only
VFS: AF_UNIX sockets should call mknod on the top layer only
that's the bulk of filesystem drivers dealing with inodes of their own
Use struct gfs2_alloc_parms as an argument to gfs2_quota_check()
and gfs2_quota_lock_check() to check for quota violations while
accounting for the new blocks requested by the current operation
in ap->target.
Previously, the number of new blocks requested during an operation
were not accounted for during quota_check and would allow these
operations to exceed quota. This was not very apparent since most
operations allocated only 1 block at a time and quotas would get
violated in the next operation. i.e. quota excess would only be by
1 block or so. With fallocate, (where we allocate a bunch of blocks
at once) the quota excess is non-trivial and is addressed by this
patch.
This patch just removes a goto that did nothing.
In ->atomic_open(inode, dentry, file, opened) calling finish_no_open(file, NULL)
is equivalent to dget(dentry); return finish_no_open(file, dentry);
No need to open-code that...
dentry is always hashed and negative, inode - non-error, non-NULL and
non-directory. In such conditions d_splice_alias() is equivalent to
"d_instantiate(dentry, inode) and return NULL", which simplifies the
downstream code and is consistent with the "have to create a new object"
case.
