path: root/fs/gfs2/meta_io.c
2011-04-20GFS2: Improve tracing support (adds two flags)Steven Whitehouse
This adds support for two new flags. One keeps track of whether the glock is on the LRU list or not. The other isn't really a flag as such, but an indication of whether the glock has an attached object or not. This indication is reported without any locking, which is ok since we do not dereference the object pointer but merely report whether it is NULL or not. Also, this fixes one place where a tracepoint was missing, which was at the point we remove deallocated blocks from the journal. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-14GFS2: Update to AIL list lockingSteven Whitehouse
The previous patch missed a couple of places where the AIL list needed locking, so this fixes up those places, plus a comment is corrected too. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Dave Chinner <dchinner@redhat.com>
2011-03-10block: kill off REQ_UNPLUGJens Axboe
With the plugging now being explicitly controlled by the submitter, callers need not pass down unplugging hints to the block layer. If they want to unplug, it's because they manually plugged on their own - in which case, they should just unplug at will. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-26writeback: remove nonblocking/encountered_congestion referencesWu Fengguang
This removes more dead code that was somehow missed by commit 0d99519efef (writeback: remove unused nonblocking and congestion checks). There are no behavior change except for the removal of two entries from one of the ext4 tracing interface. The nonblocking checks in ->writepages are no longer used because the flusher now prefer to block on get_request_wait() than to skip inodes on IO congestion. The latter will lead to more seeky IO. The nonblocking checks in ->writepage are no longer used because it's redundant with the WB_SYNC_NONE check. We no long set ->nonblocking in VM page out and page migration, because a) it's effectively redundant with WB_SYNC_NONE in current code b) it's old semantic of "Don't get stuck on request queues" is mis-behavior: that would skip some dirty inodes on congestion and page out others, which is unfair in terms of LRU age. Inspired by Christoph Hellwig. Thanks! Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: David Howells <dhowells@redhat.com> Cc: Sage Weil <sage@newdream.net> Cc: Steve French <sfrench@samba.org> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-07block: unify flags for struct bio and struct requestChristoph Hellwig
Remove the current bio flags and reuse the request flags for the bio, too. This allows to more easily trace the type of I/O from the filesystem down to the block driver. There were two flags in the bio that were missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've renamed two request flags that had a superflous RW in them. Note that the flags are in bio.h despite having the REQ_ name - as blkdev.h includes bio.h that is the only way to go for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-05-12GFS2: Eliminate useless err variableBob Peterson
This patch removes an unneeded "err" variable that is always returned as zero. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-05-05GFS2: Various gfs2_logd improvementsBenjamin Marzinski
This patch contains various tweaks to how log flushes and active item writeback work. gfs2_logd is now managed by a waitqueue, and gfs2_log_reseve now waits for gfs2_logd to do the log flushing. Multiple functions were rewritten to remove the need to call gfs2_log_lock(). Instead of using one test to see if gfs2_logd had work to do, there are now seperate tests to check if there are two many buffers in the incore log or if there are two many items on the active items list. This patch is a port of a patch Steve Whitehouse wrote about a year ago, with some minor changes. Since gfs2_ail1_start always submits all the active items, it no longer needs to keep track of the first ai submitted, so this has been removed. In gfs2_log_reserve(), the order of the calls to prepare_to_wait_exclusive() and wake_up() when firing off the logd thread has been switched. If it called wake_up first there was a small window for a race, where logd could run and return before gfs2_log_reserve was ready to get woken up. If gfs2_logd ran, but did not free up enough blocks, gfs2_log_reserve() would be left waiting for gfs2_logd to eventualy run because it timed out. Finally, gt_logd_secs, which controls how long to wait before gfs2_logd times out, and flushes the log, can now be set on mount with ar_commit. Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-03-01GFS2: Metadata address space clean upSteven Whitehouse
Since the start of GFS2, an "extra" inode has been used to store the metadata belonging to each inode. The only reason for using this inode was to have an extra address space, the other fields were unused. This means that the memory usage was rather inefficient. The reason for keeping each inode's metadata in a separate address space is that when glocks are requested on remote nodes, we need to be able to efficiently locate the data and metadata which relating to that glock (inode) in order to sync or sync and invalidate it (depending on the remotely requested lock mode). This patch adds a new type of glock, which has in addition to its normal fields, has an address space. This applies to all inode and rgrp glocks (but to no other glock types which remain as before). As a result, we no longer need to have the second inode. This results in three major improvements: 1. A saving of approx 25% of memory used in caching inodes 2. A removal of the circular dependency between inodes and glocks 3. No confusion between "normal" and "metadata" inodes in super.c Although the first of these is the more immediately apparent, the second is just as important as it now enables a number of clean ups at umount time. Those will be the subject of future patches. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-01-11GFS2: Use MAX_LFS_FILESIZE for meta inode sizeSteven Whitehouse
Using ~0ULL was cauing sign issues in filemap_fdatawrite_range, so use MAX_LFS_FILESIZE instead. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-05-22GFS2: Clean up some file namesSteven Whitehouse
This patch renames the ops_*.c files which have no counterpart without the ops_ prefix in order to shorten the name and make it more readable. In addition, ops_address.h (which was very small) is moved into inode.h and inode.h is cleaned up by adding extern where required. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-05-11GFS2: Optimise writepage for metadataSteven Whitehouse
This adds a GFS2 specific writepage for metadata, rather than continuing to use the VFS function. As a result we now tag all our metadata I/O with the correct flag so that blktraces will now be less confusing. Also, the generic function was checking for a number of corner cases which cannot happen on the metadata address spaces so that this should be faster too. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-05-11GFS2: Update the rw flagsSteven Whitehouse
After Jens recent updates: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=a1f242524c3c1f5d40f1c9c343427e34d1aadd6e et al. this is a patch to bring gfs2 uptodate with the core code. Also I've managed to squash another call to ll_rw_block() along the way. There is still one part of the GFS2 I/O paths which are not correctly annotated and that is due to the sharing of the writeback code between the data and metadata address spaces. I would like to change that too, but this patch is still worth doing on its own, I think. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-03-24GFS2: Clean up of glops.cSteven Whitehouse
This cleans up a number of bits of code mostly based in glops.c. A couple of simple functions have been merged into the callers to make it more obvious what is going on, the mysterious raising of i_writecount around the truncate_inode_pages() call has been removed. The meta_go_* operations have been renamed rgrp_go_* since that is the only lock type that they are used with. The unused argument of gfs2_read_sb has been removed. Also a bug has been fixed where a check for the rindex inode was in the wrong callback. More comments are added, and the debugging code is improved too. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-03-24GFS2: Merge lock_dlm module into GFS2Steven Whitehouse
This is the big patch that I've been working on for some time now. There are many reasons for wanting to make this change such as: o Reducing overhead by eliminating duplicated fields between structures o Simplifcation of the code (reduces the code size by a fair bit) o The locking interface is now the DLM interface itself as proposed some time ago. o Fewer lookups of glocks when processing replies from the DLM o Fewer memory allocations/deallocations for each glock o Scope to do further optimisations in the future (but this patch is more than big enough for now!) Please note that (a) this patch relates to the lock_dlm module and not the DLM itself, that is still a separate module; and (b) that we retain the ability to build GFS2 as a standalone single node filesystem with out requiring the DLM. This patch needs a lot of testing, hence my keeping it I restarted my -git tree after the last merge window. That way, this has the maximum exposure before its merged. This is (modulo a few minor bug fixes) the same patch that I've been posting on and off the the last three months and its passed a number of different tests so far. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-06-27[GFS2] Clean up the glock coreSteven Whitehouse
This patch implements a number of cleanups to the core of the GFS2 glock code. As a result a lot of code is removed. It looks like a really big change, but actually a large part of this patch is either removing or moving existing code. There are some new bits too though, such as the new run_queue() function which is considerably streamlined. Highlights of this patch include: o Fixes a cluster coherency bug during SH -> EX lock conversions o Removes the "glmutex" code in favour of a single bit lock o Removes the ->go_xmote_bh() for inodes since it was duplicating ->go_lock() o We now only use the ->lm_lock() function for both locks and unlocks (i.e. unlock is a lock with target mode LM_ST_UNLOCKED) o The fast path is considerably shortly, giving performance gains especially with lock_nolock o The glock_workqueue is now used for all the callbacks from the DLM which allows us to simplify the lock_dlm module (see following patch) o The way is now open to make further changes such as eliminating the two threads (gfs2_glockd and gfs2_scand) in favour of a more efficient scheme. This patch has undergone extensive testing with various test suites so it should be pretty stable by now. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Bob Peterson <rpeterso@redhat.com>
2008-05-12[GFS2] filesystem consistency error from do_stripBob Peterson
This patch fixes a GFS2 filesystem consistency error reported from function do_strip. The problem was caused by a timing window that allowed two vfs inodes to be created in memory that point to the same file. The problem is fixed by making the vfs's iget_test, iget_set mechanism check and set a new bit in the in-core gfs2_inode structure while the vfs inode spin_lock is held. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-01-25[GFS2] Fix typoBob Peterson
This patch fixes a minor typo. Surprisingly, it still compiled. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-01-25[GFS2] Function meta_read optimizationBob Peterson
This patch optimizes function gfs2_meta_read. Basically, gfs2_meta_wait was being called regardless of whether a disk read was requested. This just pulls that wait into the if that triggers the read. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-01-25[GFS2] Add sync_page to metadata address space operationsSteven Whitehouse
This set of address space operations was missing a sync_page operation. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2008-01-25[GFS2] Remove useless i_cache from inodesSteven Whitehouse
The i_cache was designed to keep references to the indirect blocks used during block mapping so that they didn't have to be looked up continually. The idea failed because there are too many places where the i_cache needs to be freed, and this has in the past been the cause of many bugs. In addition there was no performance benefit being gained since the disk blocks in question were cached anyway. So this patch removes it in order to simplify the code to prepare for other changes which would otherwise have had to add further support for this feature. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-10-10[GFS2] Data corruption fixWendy Cheng
* GFS2 has been using i_cache array to store its indirect meta blocks. Its flush routine doesn't correctly clean up all the entries. The problem would show while multiple nodes do simultaneous writes to the same file. Upon glock exclusive lock transfer, if the file is a sparse file with large file size where the indirect meta blocks span multiple array entries with "zero" entries in between. The flush routine prematurely stops the flushing that leaves old (stale) entries around. This leads to several nasty issues, including data corruption. * Fix gfs2_get_block_noalloc checking to correctly return EIO upon unmapped buffer. Signed-off-by: Wendy Cheng <wcheng@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-10-10[GFS2] Clean up journaled data writingSteven Whitehouse
This patch cleans up the code for writing journaled data into the log. It also removes the need to allocate a small "tag" structure for each block written into the log. Instead we just keep count of the outstanding I/O so that we can be sure that its all been written at the correct time. Another result of this patch is that a number of ll_rw_block() calls have become submit_bh() calls, closing some races at the same time. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-10-10[GFS2] Clean up gfs2_trans_add_revoke()Steven Whitehouse
The following alters gfs2_trans_add_revoke() to take a struct gfs2_bufdata as an argument. This eliminates the memory allocation which was previously required by making use of the already existing struct gfs2_bufdata. It makes some sanity checks to ensure that the gfs2_bufdata has been removed from all the lists before its recycled as a revoke structure. This saves one memory allocation and one free per revoke structure. Also as a result, and to simplify the locking, since there is no longer any blocking code in gfs2_trans_add_revoke() we must hold the log lock whenever this function is called. This reduces the amount of times we take and unlock the log lock. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-10-10[GFS2] Move pin/unpin into lops.c, clean up lockingSteven Whitehouse
gfs2_pin and gfs2_unpin are only used in lops.c, despite being defined in meta_io.c, so this patch moves them into lops.c and makes them static. At the same time, its possible to clean up the locking in the buf and databuf _lo_add() functions so that we only need to grab the spinlock once. Also we have to move lock_buffer() around the _lo_add() functions since we can't do that in gfs2_pin() any more since we hold the spinlock for the duration of that function. As a result, the code shrinks by 12 lines and we do far fewer operations when adding buffers to the log. It also makes the code somewhat easier to read & understand. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[GFS2] assertion failure after writing to journaled file, umountRobert Peterson
This patch passes all my nasty tests that were causing the code to fail under one circumstance or another. Here is a complete summary of all changes from today's git tree, in order of appearance: 1. There are now separate variables for metadata buffer accounting. 2. Variable sd_log_num_hdrs is no longer needed, since the header accounting is taken care of by the reserve/refund sequence. 3. Fixed a tiny grammatical problem in a comment. 4. Added a new function "calc_reserved" to calculate the reserved log space. This isn't entirely necessary, but it has two benefits: First, it simplifies the gfs2_log_refund function greatly. Second, it allows for easier debugging because I could sprinkle the code with calls to this function to make sure the accounting is proper (by adding asserts and printks) at strategic point of the code. 5. In log_pull_tail there apparently was a kludge to fix up the accounting based on a "pull" parameter. The buffer accounting is now done properly, so the kludge was removed. 6. File sync operations were making a call to gfs2_log_flush that writes another journal header. Since that header was unplanned for (reserved) by the reserve/refund sequence, the free space had to be decremented so that when log_pull_tail gets called, the free space is be adjusted properly. (Did I hear you call that a kludge? well, maybe, but a lot more justifiable than the one I removed). 7. In the gfs2_log_shutdown code, it optionally syncs the log by specifying the PULL parameter to log_write_header. I'm not sure this is necessary anymore. It just seems to me there could be cases where shutdown is called while there are outstanding log buffers. 8. In the (data)buf_lo_before_commit functions, I changed some offset values from being calculated on the fly to being constants. That simplified some code and we might as well let the compiler do the calculation once rather than redoing those cycles at run time. 9. This version has my rewritten databuf_lo_add function. This version is much more like its predecessor, buf_lo_add, which makes it easier to understand. Again, this might not be necessary, but it seems as if this one works as well as the previous one, maybe even better, so I decided to leave it in. 10. In databuf_lo_before_commit, a previous data corruption problem was caused by going off the end of the buffer. The proper solution is to have the proper limit in place, rather than stopping earlier. (Thus my previous attempt to fix it is wrong). If you don't wrap the buffer, you're stopping too early and that causes more log buffer accounting problems. 11. In lops.h there are two new (previously mentioned) constants for figuring out the data offset for the journal buffers. 12. There are also two new functions, buf_limit and databuf_limit to calculate how many entries will fit in the buffer. 13. In function gfs2_meta_wipe, it needs to distinguish between pinned metadata buffers and journaled data buffers for proper journal buffer accounting. It can't use the JDATA gfs2_inode flag because it's sometimes passed the "real" inode and sometimes the "metadata inode" and the inode flags will be random bits in a metadata gfs2_inode. It needs to base its decision on which was passed in. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-02-11[PATCH] Transform kmem_cache_alloc()+memset(0) -> kmem_cache_zalloc().Robert P. J. Day
Replace appropriate pairs of "kmem_cache_alloc()" + "memset(0)" with the corresponding "kmem_cache_zalloc()" call. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Roland McGrath <roland@redhat.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Acked-by: Joel Becker <Joel.Becker@oracle.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Jan Kara <jack@ucw.cz> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-30[GFS2] Reduce number of arguments to meta_io.c:getbuf()Steven Whitehouse
Since the superblock and the address_space are determined by the glock, we might as well just pass that as the argument since all the callers already have that available. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-11-30[GFS2] Move gfs2_meta_syncfs() into log.cSteven Whitehouse
By moving gfs2_meta_syncfs() into log.c, gfs2_ail1_start() can be made static. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-11-30[GFS2] Fix journal flush problemSteven Whitehouse
This fixes a bug which resulted in poor performance due to flushing the journal too often. The code path in question was via the inode_go_sync() function in glops.c. The solution is not to flush the journal immediately when inodes are ejected from memory, but batch up the work for glockd to deal with later on. This means that glocks may now live on beyond the end of the lifetime of their inodes (but not very much longer in the normal case). Also fixed in this patch is a bug (which was hidden by the bug mentioned above) in calculation of the number of free journal blocks. The gfs2_logd process has been altered to be more responsive to the journal filling up. We now wake it up when the number of uncommitted journal blocks has reached the threshold level rather than trying to flush directly at the end of each transaction. This again means doing fewer, but larger, log flushes in general. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-10-03[GFS2] Move logging code into log.c (mostly)Steven Whitehouse
This moves the logging code from meta_io.c into log.c and glops.c. As a result the routines can now be static and all the logging code is together in log.c, leaving meta_io.c with just metadata i/o code in it. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-10-02[GFS2] Mark metadata reads for blktraceSteven Whitehouse
Mark the metadata reads so that blktrace knows what they are. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-28[GFS2] inode_diet: Replace inode.u.generic_ip with inode.i_private (gfs)Theodore Ts'o
The following patches reduce the size of the VFS inode structure by 28 bytes on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction in the inode size on a UP kernel that is configured in a production mode (i.e., with no spinlock or other debugging functions enabled; if you want to save memory taken up by in-core inodes, the first thing you should do is disable the debugging options; they are responsible for a huge amount of bloat in the VFS inode structure). This patch: The filesystem or device-specific pointer in the inode is inside a union, which is pretty pointless given that all 30+ users of this field have been using the void pointer. Get rid of the union and rename it to i_private, with a comment to explain who is allowed to use the void pointer. This is just a cleanup, but it allows us to reuse the union 'u' for something something where the union will actually be used. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-09-21[GFS2] Tidy up meta_io codeSteven Whitehouse
Fix a bug in the directory reading code, where we might have dereferenced a NULL pointer in case of OOM. Updated the directory code to use the new & improved version of gfs2_meta_ra() which now returns the first block that was being read. Previously it was releasing it requiring following code to grab the block again at each point it was called. Also turned off readahead on directory lookups since we are reading a hash table, and therefore reading the entries in order is very unlikely. Readahead is still used for all other calls to the directory reading function (e.g. when growing the hash table). Removed the DIO_START constant. Everywhere this was used, it was used to unconditionally start i/o aside from a couple of places, so I've removed it and made the couple of exceptions to this rule into separate functions. Also hunted through the other DIO flags and removed them as arguments from functions which were always called with the same combination of arguments. Updated gfs2_meta_indirect_buffer to be a bit more efficient and hopefully also be a bit easier to read. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-20[GFS2] Remove unused constantsSteven Whitehouse
Three of the DIO constants were not being used, so remove them. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-19[GFS2] Export lm_interface to kernel headersFabio Massimo Di Nitto
lm_interface.h has a few out of the tree clients such as GFS1 and userland tools. Right now, these clients keeps a copy of the file in their build tree that can go out of sync. Move lm_interface.h to include/linux, export it to userland and clean up fs/gfs2 to use the new location. Signed-off-by: Fabio M. Di Nitto <fabbione@ubuntu.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-04[GFS2] More style changesSteven Whitehouse
As per Jan Engelhardt's fourth email, this is the first part of the change set with a few minor style points. Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-04[GFS2] Change all types to uX styleSteven Whitehouse
This makes all fixed size types have consistent names. Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-04[GFS2] Align all labels against LH sideSteven Whitehouse
This makes everything consistent. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-09-01[GFS2] Update copyright, tidy up incore.hSteven Whitehouse
As per comments from Jan Engelhardt <jengelh@linux01.gwdg.de> this updates the copyright message to say "version" in full rather than "v.2". Also incore.h has been updated to remove forward structure declarations which are not required. The gfs2_quota_lvb structure has now had endianess annotations added to it. Also quota.c has been updated so that we now store the lvb data locally in endian independant format to avoid needing a structure in host endianess too. As a result the endianess conversions are done as required at various points and thus the conversion routines in lvb.[ch] are no longer required. I've moved the one remaining constant in lvb.h thats used into lm.h and removed the unused lvb.[ch]. I have not changed the HIF_ constants. That is left to a later patch which I hope will unify the gh_flags and gh_iflags fields of the struct gfs2_holder. Cc: Jan Engelhardt <jengelh@linux01.gwdg.de> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-08-18[GFS2] Fix leak of gfs2_bufdataSteven Whitehouse
This fixes a memory leak of struct gfs2_bufdata and also some problems in the ordered write handling code. It needs a bit more testing, but I believe that the reference counting of ordered write buffers should now be correct. This is aimed at fixing Red Hat bugzilla: #201028 and #201082 Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-07-11[GFS2] Fix deadlock in memory allocationSteven Whitehouse
We must not call GFP_KERNEL memory allocations while we are holding the log lock (read or write) since that may trigger a log flush resulting in a deadlock. Eventually we need to fix the locking in log.c, for now this solves the problem at the expense of freeing up memory as fast as we would like to. This needs to be revisited later on. Cc: Kevin Anderson <kanderso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-07-11[GFS2] Add generation numberSteven Whitehouse
This adds a generation number for the eventual use of NFS to the ondisk inode. Its backward compatible with the current code since it doesn't really matter what the generation number is to start with, and indeed since its set to zero, due to it being taken from padding in both the inode and rgrp header, it should be fine. The eventual plan is to use this rather than no_formal_ino in the NFS filehandles. At that point no_formal_ino will be unused. At the same time we also add a releasepages call back to the "normal" address space for gfs2 inodes. Also I've removed a one-linrer function thats not required any more. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-07-03[GFS2] Make our address_space_operations constSteven Whitehouse
As per Christoph's patch: http://www.kernel.org/git/?p=linux/kernel/git/steve/gfs2-2.6.git;a=commitdiff;h=f5e54d6e53a20cef45af7499e86164f0e0d16bb2 We mark struct address_space_operations const in GFS2. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-06-14[GFS2] Fix unlinked file handlingSteven Whitehouse
This patch fixes the way we have been dealing with unlinked, but still open files. It removes all limits (other than memory for inodes, as per every other filesystem) on numbers of these which we can support on GFS2. It also means that (like other fs) its the responsibility of the last process to close the file to deallocate the storage, rather than the person who did the unlinking. Note that with GFS2, those two events might take place on different nodes. Also there are a number of other changes: o We use the Linux inode subsystem as it was intended to be used, wrt allocating GFS2 inodes o The Linux inode cache is now the point which we use for local enforcement of only holding one copy of the inode in core at once (previous to this we used the glock layer). o We no longer use the unlinked "special" file. We just ignore it completely. This makes unlinking more efficient. o We now use the 4th block allocation state. The previously unused state is used to track unlinked but still open inodes. o gfs2_inoded is no longer needed o Several fields are now no longer needed (and removed) from the in core struct gfs2_inode o Several fields are no longer needed (and removed) from the in core superblock There are a number of future possible optimisations and clean ups which have been made possible by this patch. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-05-24[GFS2] Casts for printing 64bit numbersSteven Whitehouse
2006-05-18[GFS2] Update copyright date to 2006Steven Whitehouse
2006-05-18[GFS2] Remove semaphore.h from C filesSteven Whitehouse
We no longer use semaphores, everything has been converted to mutex or rwsem, so we don't need to include this header any more. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-05-18[GFS2] Drop log lock on I/O error & tidy upSteven Whitehouse
This patch drops the log spinlock when an I/O error occurs to avoid any possible problems in case of blocking or recursion in the I/O error routine. It also has a few cosmetic changes to tidy up various other files. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
