Commit 39b0555f didn't check for a failing bio_add_page in
gfs2_submit_bhs. This could cause I/O requests to get lost, and the
affected buffer heads to stay locked forever. Fix that by submitting
the current bio and allocating another one when bio_add_page fails. (It
is guaranteed that we can at least add one page to a bio.)
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
These two are confusing leftover of the old world order, combining
values of the REQ_OP_ and REQ_ namespaces. For callers that don't
special case we mostly just replace bi_rw with bio_data_dir or
op_is_write, except for the few cases where a switch over the REQ_OP_
values makes more sense. Any check for READA is replaced with an
explicit check for REQ_RAHEAD. Also remove the READA alias for
REQ_RAHEAD.
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Reviewed-by: Mike Christie <mchristi@redhat.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
Separate the op from the rq_flag_bits and have gfs2
set/get the bio using bio_set_op_attrs/bio_op.
Signed-off-by: Mike Christie <mchristi@redhat.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
This has ll_rw_block users pass in the operation and flags separately,
so ll_rw_block can setup the bio op and bi_rw flags on the bio that
is submitted.
This has submit_bh users pass in the operation and flags separately,
so submit_bh_wbc can setup the bio op and bi_rw flags on the bio that
is submitted.
This has callers of submit_bio/submit_bio_wait set the bio->bi_rw
instead of passing it in. This makes that use the same as
generic_make_request and how we set the other bio fields.
Fixed up fs/ext4/crypto.c
git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2
Pull GFS2 updates from Bob Peterson:
"We've got nine patches this time:
- Abhi Das has two patches that fix a GFS2 splice issue (and an
adjustment).
- Ben Marzinski has a patch which allows the proper unmount of a GFS2
file system after hitting a withdraw error.
- I have a patch to fix a problem where GFS2 would dereference an
error value, plus three cosmetic / refactoring patches.
- Daniel DeFreez has a patch to fix two glock reference count
problems, where GFS2 was not properly "uninitializing" its glock
holder on error paths.
- Denys Vlasenko has a patch to change a function to not be inlined,
thus reducing the memory footprint of the GFS2 module"
* tag 'gfs2-4.7.fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/gfs2/linux-gfs2:
GFS2: Refactor gfs2_remove_from_journal
GFS2: Remove allocation parms from gfs2_rbm_find
gfs2: use inode_lock/unlock instead of accessing i_mutex directly
GFS2: Add calls to gfs2_holder_uninit in two error handlers
GFS2: Don't dereference inode in gfs2_inode_lookup until it's valid
GFS2: fs/gfs2/glock.c: Deinline do_error, save 1856 bytes
gfs2: Use gfs2 wrapper to sync inode before calling generic_file_splice_read()
GFS2: Get rid of dead code in inode_go_demote_ok
GFS2: ignore unlock failures after withdraw
This patch makes two simple changes to function gfs2_remove_from_journal.
First, it removes the parameter that specifies the transaction.
Since it's always passed in as current->journal_info, we might as well
set that in the function rather than passing it in. Second, it changes
the meta parameter to use an enum to make the code more clear.
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
Instead of submitting a READ_SYNC bio for the inode and a READA bio for
the inode's extended attributes through submit_bh, submit a single READ_SYNC
bio for both through submit_bio when possible. This can be more
efficient on some kinds of block devices.
When gfs2 allocates an inode and its extended attribute block next to
each other at inode create time, the inode's directory entry indicates
that in de_rahead. In that case, we can readahead the extended
attribute block when we read in the inode.
What uniquely identifies a glock in the glock hash table is not
gl_name, but gl_name and its superblock pointer. This patch makes
the gl_name field correspond to a unique glock identifier. That will
allow us to simplify hashing with a future patch, since the hash
algorithm can then take the gl_name and hash its components in one
operation.
possible
aops->write_begin may allocate a new page and make it visible only to have
mark_page_accessed called almost immediately after. Once the page is
visible the atomic operations are necessary which is noticable overhead
when writing to an in-memory filesystem like tmpfs but should also be
noticable with fast storage. The objective of the patch is to initialse
the accessed information with non-atomic operations before the page is
visible.
The bulk of filesystems directly or indirectly use
grab_cache_page_write_begin or find_or_create_page for the initial
allocation of a page cache page. This patch adds an init_page_accessed()
helper which behaves like the first call to mark_page_accessed() but may
called before the page is visible and can be done non-atomically.
The primary APIs of concern in this care are the following and are used
by most filesystems.
find_get_page
find_lock_page
find_or_create_page
grab_cache_page_nowait
All of them are very similar in detail to the patch creates a core helper
pagecache_get_page() which takes a flags parameter that affects its
behavior such as whether the page should be marked accessed or not. Then
old API is preserved but is basically a thin wrapper around this core
function.
Each of the filesystems are then updated to avoid calling
mark_page_accessed when it is known that the VM interfaces have already
done the job. There is a slight snag in that the timing of the
mark_page_accessed() has now changed so in rare cases it's possible a page
gets to the end of the LRU as PageReferenced where as previously it might
have been repromoted. This is expected to be rare but it's worth the
filesystem people thinking about it in case they see a problem with the
timing change. It is also the case that some filesystems may be marking
pages accessed that previously did not but it makes sense that filesystems
have consistent behaviour in this regard.
The test case used to evaulate this is a simple dd of a large file done
multiple times with the file deleted on each iterations. The size of the
file is 1/10th physical memory to avoid dirty page balancing. In the
async case it will be possible that the workload completes without even
hitting the disk and will have variable results but highlight the impact
of mark_page_accessed for async IO. The sync results are expected to be
more stable. The exception is tmpfs where the normal case is for the "IO"
to not hit the disk.
The test machine was single socket and UMA to avoid any scheduling or NUMA
artifacts. Throughput and wall times are presented for sync IO, only wall
times are shown for async as the granularity reported by dd and the
variability is unsuitable for comparison. As async results were variable
do to writback timings, I'm only reporting the maximum figures. The sync
results were stable enough to make the mean and stddev uninteresting.
The performance results are reported based on a run with no profiling.
Profile data is based on a separate run with oprofile running.
async dd
3.15.0-rc3 3.15.0-rc3
vanilla accessed-v2
ext3 Max elapsed 13.9900 ( 0.00%) 11.5900 ( 17.16%)
tmpfs Max elapsed 0.5100 ( 0.00%) 0.4900 ( 3.92%)
btrfs Max elapsed 12.8100 ( 0.00%) 12.7800 ( 0.23%)
ext4 Max elapsed 18.6000 ( 0.00%) 13.3400 ( 28.28%)
xfs Max elapsed 12.5600 ( 0.00%) 2.0900 ( 83.36%)
The XFS figure is a bit strange as it managed to avoid a worst case by
sheer luck but the average figures looked reasonable.
samples percentage
ext3 86107 0.9783 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext3 23833 0.2710 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext3 5036 0.0573 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
ext4 64566 0.8961 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext4 5322 0.0713 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext4 2869 0.0384 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 62126 1.7675 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
xfs 1904 0.0554 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 103 0.0030 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
btrfs 10655 0.1338 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
btrfs 2020 0.0273 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
btrfs 587 0.0079 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
tmpfs 59562 3.2628 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
tmpfs 1210 0.0696 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
tmpfs 94 0.0054 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
[akpm@linux-foundation.org: don't run init_page_accessed() against an uninitialised pointer]
Cc: Jan Kara <jack@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Tested-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
Now that rgrps use the address space which is part of the super
block, we need to update gfs2_mapping2sbd() to take account of
that. The only way to do that easily is to use a different set
of address_space_operations for rgrps.
Reported-by: Abhi Das <adas@redhat.com>
Tested-by: Abhi Das <adas@redhat.com>
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
Now we have a master transaction into which other transactions
are merged, the accounting can be done using this master
transaction. We no longer require the superblock fields which
were being used for this function.
In addition, this allows for a clean up in calc_reserved()
making it rather easier understand. Also, by reducing the
number of variables used to track the buffers being added
and removed from the journal, a number of error checks are
now no longer required.
Prior to this patch, GFS2 had one address space for each rgrp,
stored in the glock. This patch changes them to use a single
address space in the super block. This therefore saves
(sizeof(struct address_space) * nr_of_rgrps) bytes of memory
and for large filesystems, that can be significant.
It would be nice to be able to do something similar and merge
the inode metadata address space into the same global
address space. However, that is rather more complicated as the
on-disk location doesn't have a 1:1 mapping with the inodes in
general. So while it could be done, it will be a more complicated
operation as it requires changing a lot more code paths.
This patch fixes a slab memory leak that sometimes can occur
for files with a very short lifespan. The problem occurs when
a dinode is deleted before it has gotten to the journal properly.
In the leak scenario, the bd object is pinned for journal
committment (queued to the metadata buffers queue: sd_log_le_buf)
but is subsequently unpinned and dequeued before it finds its way
to the ail or the revoke queue. In this rare circumstance, the bd
object needs to be freed from slab memory, or it is forgotten.
We have to be very careful how we do it, though, because
multiple processes can call gfs2_remove_from_journal. In order to
avoid double-frees, only the process that does the unpinning is
allowed to free the bd.
Since gfs2_sync_meta() is only called from a single file, lets move
it to lops.c where it is used, and mark it static. At the same
time, we can clean up the meta_io.h header too.
This patch looks at all the outstanding blocks in all the transactions
on the log, and moves the completed ones to the ail2 list. Then it
issues revokes for these blocks. This will hopefully speed things up
in situations where there is a lot of contention for glocks, especially
if they are acquired serially.
revoke_lo_before_commit will issue at most one log block's full of these
preemptive revokes. The amount of reserved log space that
gfs2_log_reserve() ignores has been incremented to allow for this extra
block.
This patch also consolidates the common revoke instructions into one
function, gfs2_add_revoke().
Signed-off-by: Benjamin Marzinski <bmarzins@redhat.com>
In order to allow transactions and log flushes to happen at the same
time, gfs2 needs to move the transaction accounting and active items
list code into the gfs2_trans structure. As a first step toward this,
this patch removes the gfs2_ail structure, and handles the active items
list in the gfs_trans structure. This keeps gfs2 from allocating an ail
structure on log flushes, and gives us a struture that can later be used
to store the transaction accounting outside of the gfs2 superblock
structure.
With this patch, at the end of a transaction, gfs2 will add the
gfs2_trans structure to the superblock if there is not one already.
This structure now has the active items fields that were previously in
gfs2_ail. This is not necessary in the case where the transaction was
simply used to add revokes, since these are never written outside of the
journal, and thus, don't need an active items list.
Also, in order to make sure that the transaction structure is not
removed while it's still in use by gfs2_trans_end, unlocking the
sd_log_flush_lock has to happen slightly later in ending the
transaction.
The locking in gfs2_attach_bufdata() was type specific (data/meta)
which made the function rather confusing. This patch moves the core
of gfs2_attach_bufdata() into trans.c renaming it gfs2_alloc_bufdata()
and moving the locking into gfs2_trans_add_data()/gfs2_trans_add_meta()
As a result all of the locking related to adding data and metadata to
the journal is now in these two functions. This should help to clarify
what is going on, and give us some opportunities to simplify in
some cases.
The pdflush thread is long gone, so this patch removes references to pdflush
from gfs comments.
Cc: Steven Whitehouse <swhiteho@redhat.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
This patch fixes buffer_head double free in following code path:
gfs2_block_map
=> gfs2_meta_inode_buffer
=> gfs2_meta_indirect_buffer
=> gfs2_meta_read
=> release_metapath
gfs2_block_map calls gfs2_meta_inode_buffer with &mp.mp_bh[0]
as an argument. mp.mp_bh are filled with zero at the beginning
of gfs2_block_map.
If gfs2_meta_inode_buffer returns non-zero value, gfs2_block_map
calls release_metapath to free buffers chained to mp.mp_bh.
release_metapath checks each slot of mp.mp_bh[i] and
free(with brelse) unless the slot is filled with NULL.
&mp.mp_bh[0] passed to gfs2_meta_inode_buffer is filled at
gfs2_meta_read. gfs2_meta_read is filled a buffer allocated with
gfs2_getbuf even if EIO occurs. When EIO occurs, the allocated buffer
is brelse'ed though the pointer(wrong poiner) points the brelse'ed is
passed back to caller via an argument bhp.
gfs2_meta_indirect_buffer, the caller also pass the wrong pointer
to its caller with EIO. Finally gfs2_block_map gets both EIO and
&mp.mp_bh[0] filled with the wrong pointer. release_metapath
calls brelse again on the wrong pointer.
Signed-off-by: Masatake YAMATO <yamato@redhat.com>
It turns out that the "new" parameter to function gfs2_meta_indirect_buffer
was always being passed in as zero. Therefore, this patch eliminates it
and simplifies the function.
This patch eliminates the gfs2_log_element data structure and
rolls its two components into the gfs2_bufdata. This makes the code
easier to understand and makes it easier to migrate to a rbtree
to keep the list sorted.
This is another clean up in the logging code. This per-transaction
list was largely unused. Its main function was to ensure that the
number of buffers in a transaction was correct, however that counter
was only used to check the number of buffers in the bd_list_tr, plus
an assert at the end of each transaction. With the assert now changed
to use the calculated buffer counts, we can remove both bd_list_tr and
its associated counter.
This should make the code easier to understand as well as shrinking
a couple of structures.
Christoph has split up REQ_PRIO from REQ_META. That means that
we can drop REQ_PRIO from places where is it not needed. I'm
not at all sure that the combination WRITE_FLUSH_FUA | REQ_PRIO
makes any kind of sense, anyway.
In addition, I've added REQ_META to one place in the code where
it was missing. REQ_PRIO has been left for read/writes triggered
by glock acquisition and writeback only. We can adjust it again
if required, but these are the most important points from a
performance perspective.
Add a new REQ_PRIO to let requests preempt others in the cfq I/O schedule,
and lave REQ_META purely for marking requests as metadata in blktrace.
All existing callers of REQ_META except for XFS are updated to also
set REQ_PRIO for now.
Reviewed-by: Namhyung Kim <namhyung@gmail.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
This adds support for two new flags. One keeps track of whether
the glock is on the LRU list or not. The other isn't really a
flag as such, but an indication of whether the glock has an
attached object or not. This indication is reported without
any locking, which is ok since we do not dereference the object
pointer but merely report whether it is NULL or not.
Also, this fixes one place where a tracepoint was missing, which
was at the point we remove deallocated blocks from the journal.
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits)
Documentation/iostats.txt: bit-size reference etc.
cfq-iosched: removing unnecessary think time checking
cfq-iosched: Don't clear queue stats when preempt.
blk-throttle: Reset group slice when limits are changed
blk-cgroup: Only give unaccounted_time under debug
cfq-iosched: Don't set active queue in preempt
block: fix non-atomic access to genhd inflight structures
block: attempt to merge with existing requests on plug flush
block: NULL dereference on error path in __blkdev_get()
cfq-iosched: Don't update group weights when on service tree
fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away
block: Require subsystems to explicitly allocate bio_set integrity mempool
jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
fs: make fsync_buffers_list() plug
mm: make generic_writepages() use plugging
blk-cgroup: Add unaccounted time to timeslice_used.
block: fixup plugging stubs for !CONFIG_BLOCK
block: remove obsolete comments for blkdev_issue_zeroout.
blktrace: Use rq->cmd_flags directly in blk_add_trace_rq.
Fix up conflicts in fs/{aio.c,super.c}
The previous patch missed a couple of places where the AIL list
needed locking, so this fixes up those places, plus a comment
is corrected too.
Cc: Dave Chinner <dchinner@redhat.com>
With the plugging now being explicitly controlled by the
submitter, callers need not pass down unplugging hints
to the block layer. If they want to unplug, it's because they
manually plugged on their own - in which case, they should just
unplug at will.
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
This removes more dead code that was somehow missed by commit 0d99519efef
(writeback: remove unused nonblocking and congestion checks). There are
no behavior change except for the removal of two entries from one of the
ext4 tracing interface.
The nonblocking checks in ->writepages are no longer used because the
flusher now prefer to block on get_request_wait() than to skip inodes on
IO congestion. The latter will lead to more seeky IO.
The nonblocking checks in ->writepage are no longer used because it's
redundant with the WB_SYNC_NONE check.
We no long set ->nonblocking in VM page out and page migration, because
a) it's effectively redundant with WB_SYNC_NONE in current code
b) it's old semantic of "Don't get stuck on request queues" is mis-behavior:
that would skip some dirty inodes on congestion and page out others, which
is unfair in terms of LRU age.
Inspired by Christoph Hellwig. Thanks!
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Sage Weil <sage@newdream.net>
Cc: Steve French <sfrench@samba.org>
Cc: Chris Mason <chris.mason@oracle.com>
Remove the current bio flags and reuse the request flags for the bio, too.
This allows to more easily trace the type of I/O from the filesystem
down to the block driver. There were two flags in the bio that were
missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've
renamed two request flags that had a superflous RW in them.
Note that the flags are in bio.h despite having the REQ_ name - as
blkdev.h includes bio.h that is the only way to go for now.
This patch removes an unneeded "err" variable that is always
returned as zero.
This patch contains various tweaks to how log flushes and active item writeback
work. gfs2_logd is now managed by a waitqueue, and gfs2_log_reseve now waits
for gfs2_logd to do the log flushing. Multiple functions were rewritten to
remove the need to call gfs2_log_lock(). Instead of using one test to see if
gfs2_logd had work to do, there are now seperate tests to check if there
are two many buffers in the incore log or if there are two many items on the
active items list.
This patch is a port of a patch Steve Whitehouse wrote about a year ago, with
some minor changes. Since gfs2_ail1_start always submits all the active items,
it no longer needs to keep track of the first ai submitted, so this has been
removed. In gfs2_log_reserve(), the order of the calls to
prepare_to_wait_exclusive() and wake_up() when firing off the logd thread has
been switched. If it called wake_up first there was a small window for a race,
where logd could run and return before gfs2_log_reserve was ready to get woken
up. If gfs2_logd ran, but did not free up enough blocks, gfs2_log_reserve()
would be left waiting for gfs2_logd to eventualy run because it timed out.
Finally, gt_logd_secs, which controls how long to wait before gfs2_logd times
out, and flushes the log, can now be set on mount with ar_commit.
Since the start of GFS2, an "extra" inode has been used to store
the metadata belonging to each inode. The only reason for using
this inode was to have an extra address space, the other fields
were unused. This means that the memory usage was rather inefficient.
The reason for keeping each inode's metadata in a separate address
space is that when glocks are requested on remote nodes, we need to
be able to efficiently locate the data and metadata which relating
to that glock (inode) in order to sync or sync and invalidate it
(depending on the remotely requested lock mode).
This patch adds a new type of glock, which has in addition to
its normal fields, has an address space. This applies to all
inode and rgrp glocks (but to no other glock types which remain
as before). As a result, we no longer need to have the second
inode.
This results in three major improvements:
1. A saving of approx 25% of memory used in caching inodes
2. A removal of the circular dependency between inodes and glocks
3. No confusion between "normal" and "metadata" inodes in super.c
Although the first of these is the more immediately apparent, the
second is just as important as it now enables a number of clean
ups at umount time. Those will be the subject of future patches.
Using ~0ULL was cauing sign issues in filemap_fdatawrite_range, so
use MAX_LFS_FILESIZE instead.
This patch renames the ops_*.c files which have no counterpart
without the ops_ prefix in order to shorten the name and make
it more readable. In addition, ops_address.h (which was very
small) is moved into inode.h and inode.h is cleaned up by
adding extern where required.
This adds a GFS2 specific writepage for metadata, rather than
continuing to use the VFS function. As a result we now tag all
our metadata I/O with the correct flag so that blktraces will
now be less confusing.
Also, the generic function was checking for a number of corner
cases which cannot happen on the metadata address spaces so that
this should be faster too.
After Jens recent updates:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=a1f242524c3c1f5d40f1c9c343427e34d1aadd6e
et al. this is a patch to bring gfs2 uptodate with the core
code. Also I've managed to squash another call to ll_rw_block()
along the way.
There is still one part of the GFS2 I/O paths which are not correctly
annotated and that is due to the sharing of the writeback code between
the data and metadata address spaces. I would like to change that too,
but this patch is still worth doing on its own, I think.
This cleans up a number of bits of code mostly based in glops.c.
A couple of simple functions have been merged into the callers
to make it more obvious what is going on, the mysterious raising
of i_writecount around the truncate_inode_pages() call has been
removed. The meta_go_* operations have been renamed rgrp_go_*
since that is the only lock type that they are used with.
The unused argument of gfs2_read_sb has been removed. Also
a bug has been fixed where a check for the rindex inode was
in the wrong callback. More comments are added, and the
debugging code is improved too.
This is the big patch that I've been working on for some time
now. There are many reasons for wanting to make this change
such as:
o Reducing overhead by eliminating duplicated fields between structures
o Simplifcation of the code (reduces the code size by a fair bit)
o The locking interface is now the DLM interface itself as proposed
some time ago.
o Fewer lookups of glocks when processing replies from the DLM
o Fewer memory allocations/deallocations for each glock
o Scope to do further optimisations in the future (but this patch is
more than big enough for now!)
Please note that (a) this patch relates to the lock_dlm module and
not the DLM itself, that is still a separate module; and (b) that
we retain the ability to build GFS2 as a standalone single node
filesystem with out requiring the DLM.
This patch needs a lot of testing, hence my keeping it I restarted
my -git tree after the last merge window. That way, this has the maximum
exposure before its merged. This is (modulo a few minor bug fixes) the
same patch that I've been posting on and off the the last three months
and its passed a number of different tests so far.
This patch implements a number of cleanups to the core of the
GFS2 glock code. As a result a lot of code is removed. It looks
like a really big change, but actually a large part of this patch
is either removing or moving existing code.
There are some new bits too though, such as the new run_queue()
function which is considerably streamlined. Highlights of this
patch include:
o Fixes a cluster coherency bug during SH -> EX lock conversions
o Removes the "glmutex" code in favour of a single bit lock
o Removes the ->go_xmote_bh() for inodes since it was duplicating
->go_lock()
o We now only use the ->lm_lock() function for both locks and
unlocks (i.e. unlock is a lock with target mode LM_ST_UNLOCKED)
o The fast path is considerably shortly, giving performance gains
especially with lock_nolock
o The glock_workqueue is now used for all the callbacks from the DLM
which allows us to simplify the lock_dlm module (see following patch)
o The way is now open to make further changes such as eliminating the two
threads (gfs2_glockd and gfs2_scand) in favour of a more efficient
scheme.
This patch has undergone extensive testing with various test suites
so it should be pretty stable by now.
Cc: Bob Peterson <rpeterso@redhat.com>
This patch fixes a GFS2 filesystem consistency error reported from
function do_strip. The problem was caused by a timing window
that allowed two vfs inodes to be created in memory that point
to the same file. The problem is fixed by making the vfs's
iget_test, iget_set mechanism check and set a new bit in the
in-core gfs2_inode structure while the vfs inode spin_lock is held.
This patch fixes a minor typo. Surprisingly, it still compiled.
This patch optimizes function gfs2_meta_read. Basically, gfs2_meta_wait
was being called regardless of whether a disk read was requested.
This just pulls that wait into the if that triggers the read.
This set of address space operations was missing a sync_page
operation.
The i_cache was designed to keep references to the indirect blocks
used during block mapping so that they didn't have to be looked
up continually. The idea failed because there are too many places
where the i_cache needs to be freed, and this has in the past been
the cause of many bugs.
In addition there was no performance benefit being gained since the
disk blocks in question were cached anyway. So this patch removes
it in order to simplify the code to prepare for other changes which
would otherwise have had to add further support for this feature.
